- To: Josef Urban <Josef.Urban AT gmail.com>
- Subject: [Coq-Club] AITP 2024 FINAL CALL FOR CONTRIBUTIONS - EXTENDED DEADLINE May 12
- Date: Fri, 3 May 2024 10:09:27 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=josef.urban AT gmail.com; spf=Pass smtp.mailfrom=josef.urban AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb1-f177.google.com
- Ironport-data: A9a23:jVdG0ahBUMcbgCBYODc3W/B8X161wBQKZh0ujC45NGQN5FlHY01je htvCG6CPvyIZGT3etAgb9mz9BwCuJGDxoVkSgdo/CFnRitjpJueD7x1DG+gZnLIdpWroGFPt phFNIGYdKjYaleG+39B55C49SEUOZmgH+a6UqieUsxIbVcMYD87jh5+kPIOjIdtgNyoayuAo tqaT/f3YTdJ4BYqdDpLg06/gEk35qiq5WtC5gZWic1j5TcyqVFFVPrzGonqdxMUcqEMdsamS uDKyq2O/2+x13/B3fv4+lpTWhRiro/6ZWBiuFIOM0SRqkQqShgJ70oOHKF0hXG7JNm+t4sZJ N1l7fRcQOqyV0HGsLx1vxJwS0mSMUDakVNuzLfWXcG7liX7n3XQL/pGVR1nHI4iyLxLDnxt1 PZDCxcASC6tvrfjqF67YrEEasULKcDqOMYOsCglw2iGUrApRpfMR6iM7thdtNsyrpoWTLCOO oxDMGspNUufC/FMEg9/5JYWnuCzi3e5bidSoVS9qq8+4myVxwt0uFToGIOLJofRFJsNxi50o EqXzmDiHEkhLeW25j6h12KnptXwnjvCDdd6+LqQraMz2ALCmAT/EiY+Xlyi5PK9l0SWQMNaM 0VS+yw0rKF0+lbDczXmdxixoXrBrxRFHtQJTLJ85waKxa7ZpQ2eAwDoUwKtdvR/6J4XRgYYj GOGgvDID2dMl7Czd1yko+L8QSyJBQAZKmoLZCkhRAQD4sX+rIxbsv4pZoYzeEJSpo2qcQwc0 wy3QD4Ca6L/ZPPnOo2+9FHDxiOm/93HF1FqoArQWW2h40VyY4vNi22UBbrzvaYowGWxFwbpU J04dy62srtm4XalynblfQn1NOv1j8tpyRWF6bKVI7Ev9i6251modp1K7Td1KS9Ba5ldJWG2P BGN5lsIuPe/2UdGi4cnM+pd7Ox6ncDd+SjND628gidmO8QvKVLYoH0GibC4hD69zBREfV4D1 WezKpv1VSlLV8yLPRK5QOAS1bJjxyY1gwvuqWPTnnyaPU6lTCfNE98taQPQBshgtf/siFuPr 753aZDRoz0BC72WX8Ui2dRMRbz8BSNrW86eRg0+XrLrHzeK70lxUaeOn+t4JNINcmY8vr6gw 0xRk3RwkDLX7UAr4y3TApy6QOq3Bs4tnmFxJiE2I1ej1l4qZIvlvu9VdII6cfNjvKZvxOJ9B atNMciRIOV9ehKe8RQkbL75sNNDcjavjlmwJCaLWmU0UKNhYA3rweXaWDXT2hMANQeNjvtmk YacjlvaZbEhWzVdCN3nbaPz7lGp4lkYtuFAf2rJBdhxfk/T3pBgAHHzhKVvIuUnCxbK9h2F3 Sm4XDYaoujspdcu0d/r3KqrkaagI9FcLGF7QVbJzO+RHjbI20ae2ql8afasURGBcXLr6YOgS P5wzfqhAMYYnV1PjZVwI4xrwY06+dHrgb1QlSZgI1nmcHWpDaFGMFCd/MwSqJBI+KBViTG2V m2L5NNeH7eDY+HhMVwJITsafvax7u4VlhbS/MYKDh3DvgEvx4W+UGJWIxWoow5eJuEsMIoan MEQiPRP4Am70hcXItKKix5PzFu1L1sCbr4Gs68LC4q6myspzVB/OabnMBHU263WSdtwMRgNG AS21Y7inLVXw3TQf0UjTUbt2fVvvrVQmRRo4mJbGXG3tIvkvMIn5DxQ7jU9cSpNxDplze9YG zZmJm91F4q07hZqg8lJYE60ESoYWSyb11DDyXZSsnyESUPyB2rHA1AgCLzc4GEY7GNuUTxJ9 56IyGvecGjLfeOg+gAQSEJau/jYYtgpzTL7meejBNagM6ghRDjY3p+VemsDriX4DfMLhEHoo fdg+MByY/bZMRE8jrIaCY7A85gtUzGBeXJ/RM9+8JMzHW3zfC+43R6MIRuTfuJPP/n7zl+qO fdxJ85gVwWM6wjWl2o1XZUzGr5TmOIlwPEgebmxfG4PjOa5nwpT6ZnV8nDzuX8vT9BQiv0CE 4L2dQ+ZM2mulHBRyn7srs5FBzKCWuM6RjbAhcK7zOZYMKg4krBIUVoz2b6KrXmqIFNZ3xaLj jjiOY7S7cJfkLpJoaW9PJlHNQuOLfHLaN+p6yG26tRHUsPOO5zBtiQTsVjWAD5VNrowBfVym ai8j9rs+EbjorwNcnv4nqOZHPJj/vSCX+twM+P2IkJFnCCEZtTe3hsb9028Kr1LiNl45PT7Y yedd+2Laoczd/pG4X9aeQxyMkw4MLvmSLXkqQeWjeW+OjJE3SPpdNqYpGLUN0dFfSo2CrjCI w7TudP1w/tHrY5JVSQ2N9s/D7BWeFbcCLYbLfvvvjylD06tsFOImp3msTECsTjrKH21IPzW0 KL/ZCrVVUqN4fnT7dRjrYZNkAUdDy99jckOb0stwYNKpA7gPlEWD9Y2EMsgMY5VoBzQxZujR TDqbUkeMwvfcwlAUy3B5IXEYl/CKM0IY9v3H2l8tQfcISK7H5iJD7Zd5z9tqSU+MCfqyOa8b 8oS4DvsNxy22YtkXvsX+uf9u+p82/fG3TgdzCgRSSAp78o2Wt3mFUCNHTahkQTCGsDJ0VTBf C07HD8bBk68TkH1HIBrfHs99NT1et/w521AUMtN6I+3V0anIClox/j2OuW12boGBCjPDKBbX mv5HgNh/EjPskH+esIVVxYBjqp9CPbNFc+/REMmqcv+gInoglka0wg+cebjgS3sFMOz078Qq 9V030UDOQ==
- Ironport-hdrordr: A9a23:gm+bK6AsdGqRsHTlHeiOsseALOsnbusQ8zAXPh9KOHtom52j5q STdaogpHrJYW4qKQAdsPiaMqiBXn/QsbZpiLNhEItKLzOWyFdATbsSrLcKpgeMJ8SQzJ8j6U 4LScdD4ePLfAlHZKrBkXGF+zhJ+qiszEiH7d2umEuFZzsaP52Jd2xCey2m+nQffnhvOXLSfK DssPav3gDQUEj/Df7LRkXtPdKz2eEjz6iWMW9UO/dP0mDn5lnHic+YYnrouGZmb9oo+8Z/zY HrqX2q2kzJiYDA9vao7R6u030goqqd9jIsPr32tiAqQA+c1TqAVcBEYfmvrTo1qOag5BIBi9 /XuSotOMx19jf4Yny1iQGF4Xij7B8er1vZjXOIi3rqpsL0ABggDdBauI5fehzFr2I9odBH1r 5R1W7xjesTMfqAplW42zH7bWAtqqOGmwt6rQfVtQ0GbWIqUs4XkWXYxjIPLH5PJlOh1GltKp gcMCiV3oclTbtNBEqpklWHrebBYp10JGbEfqAI0PbljQR+rTRHx04ZycQDnnEGsJksIqM0ut gs7Z4JqJh+CsgRKapnDuYAXsffMB2ZffuEChPmHX33UK4AIH7DsJjx/fE84/yrYoUByN8olI 3GS04wjx9/R6vCM7zF4HRwyGGBfEytGTD2js1O7ZlwvbPxALLtLC2YUVgr18+tue8WDMHXU+ u6fMs+OY6sEUL+XYJSmwHuUZhbLncTFMUTp9YgQlqL5sbGMJfjuODXeOvaYLDtDTEnUGXiBW ZrZkm9GOxQqkSwHnPoihnYXH3gPkT54JJrCaDfu/MezYAcX7c8+TT8xT+Cl4i2wP15w+QLlW dFUcXae/mA1B2LFE7znhJUBiY=
- Ironport-phdr: A9a23:Fd61uhbWJ9IkRY0JVBqWTuT/LTFl2YqcDmcuAnoPtbtCf+yZ8oj4O wSHvLMx1g6PB9yKoKsd0KL/iOPJZy8p2dW7jDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgH c5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTajZb5+N gu6oRjVu8UZnIduN6g8wQbVr3VVfOhb2WxnKVWPkhjm4cu+4IBt+DlKtfI78M5AX6T6f6AmQ rFdET8rLWM76tD1uBfaVQeA6WcSXWsQkhpTHgjK9wr6UYvrsiv7reVyxi+XNtDrQL8uWDSi6 6BrSAL0iCoCKjU0/n3bhtB2galGpx2suxJyz5LJbI2MKPZyY77WcdcHSWdBW8pcUTFKDIGhY IsVF+cOMuhYoIv9qVUArhWwGBeiC//yxzJTnHD6wbc33v49HQ3a3gEtGc8FvnTOrNXyMacfS eS7zK7TzTrdYfNdxDny6JLTfR87p/GHQLV9ccjWyUk0CQzFgE+cqZH/PzyOzOsNtXOW7+VlV e21im4nrxt9rSSoxscpk4TEgJ8exV/Y+ytj2ok1OcG4R1BhYd6iCJZduDyWOpdqT888Q2xlu To2xqAYtJO/YSQEyJYqygDBZvGHfYWF/xLtWfifLDp6hH9oZrCyiRmu/EW91+HyWNW53VBXp SRLldnMs2oC1x3V6sWfUPR9/1uh2S6W2w/P7eFEJ040mrTBK5E/xL4/ioQcvV7EHi/sl0X6l LGZeV8/+umo9+vnYq/ppp6GN4NujQH+KKsultSjDuQ+KAgORHKX+eqm1LH750L5RKlKjvwtn anEq5DWP9gUpqm8AwJTz40t6A6/Ai+43NgEmXQLNlFIdRKdg4T3Jl3DJOr0Aeq9jlmuljpg2 u7LPrn8ApXWMnjMjq3hc6t8609d1gU+1cxT6pRJAb8bOv3zQFX+tNnAAx85LQO0x+HnBc141 owEWGKPBraVMaPJvlOV/+4vLfSAaY0XtTrnJPgl4PnujXA9mVADZ6WmwZwXaHWgEvRnJUWWf 2bsj88fHWsWugcyVu/nhV2YXTJNenq/W7gw6iw5BY+kFYvDQ5qigL2F3Ce1BJ1WYWVGB0iOE XfvbIWLRfkMZDiPIs97iTMLT76hRpQu1RGrrgD6yr5nIvDI9S0fsJLvzN516PbLmhEo6TN0F 9id032KT2xsg28EXyU207xnoUxh1leD1rB1jOBfFdxK/v9GTgM6NYPHwOFhENDzWgfBfs+TR 1q8Q9WmBysxTtMrzNMUbUZ9AYbqsheW/S2xDrFdqqaBDZp8poDbxHX/YftnwX/A/KYkhlgiB MBIMDv1qLR48l3xAJXEnQ2kjayjc+xI3inW+WnF0HCEtUdwXwt5UKGDVncaMBiF5e/l71/PG uf9QY8sNRFMnJffQkMrQtjgjFEcAezmJMybeWW63WG5GRePwLqIKovsYWQUmivHWwAfiw5G2 3GAOEAlAzu55XrEBWlsEknibQXx6+N3rlu0S0Y1y0eBaEgyn6Gt9EstjOeHA+gWwqpCvS4gr ztuG1Po3dXNBtTGuhBrdaN0btY04VMB3mXc5ERmJpL1CadkixYFdhhv+UPj0xIiEoJbjc0jt 28n1iJ3IKOclUJLLnaWhM+vfLLQLWb28VakbKu+Nkj29tGQ9+9P7f05rw+mpwS1Dg849H4h1 dBJ0nya75GMDQwIUJu3XFxlvx5976rXZCUw/ea2nTVlLLW0vzne2tkoGPptyxCueM1aOb+FE wm6GtMTBsynIugn01azaRdMMOdX/a8yd8SoEpnOkKysJ+tu2i+8h21ByI9420OIsSF7T6+A3 poIxe2ZwhrSTy313zLD+oj8nYFJYy1XH3Lqk3C1Qt4MIPcrLMBSVjj9Rq//js9zjJPsRXNCo VuqBldcndSsZQLXdVv2mwtZyUUQp3Wj3yq+1T191T8z/c/9lGTDxfrvcB0fNytFXm5n2B3uJ pO5gZYHRkKhaSAmkRKk4QDxwK0R98EdZyHDBFxFeST7NTQoUKyru7TEftRF4ZUAviBeUeD6a lefAO2YwVNSw2boGG1Qwyo+fjeht8DinhB0v2maKW56sHvTfcwYKQ733NXHXrYR2zMHQHM9k jzLHh2mONLv+9yIlpDFu+T4VmS7V5QVfzO5hY+HsSK64yVtD3jd17ixncbqH04nyyXy0fFlU CzJqFD3ZYyj26mhMO1hd1VlHxems5s8Stw4yNJhwshPhjATnd2N8GACkHvvPNk+u+q2d3cLS TMRgpbU7AXjxEx/PyeMzoP9WG+ax5gpbN27b2UKnyMlupoSWeHEsfoexHoz+wXn/mezKbBnk zwQyOUj8isfiuAN4k82yzmFR6oVFg9eNDDtkBKB65a/qr9WbSCha+vVtgI2kNa/AbWFugwZV mz+f8JoHyhr48s5LUjG2Xvb5YTted2WZtUW/E7x8V+In61OJZQ9m+BfzyhgIm/z+2A/wec9p RNr1JC++oOALi8+mcDxSg4dPTrzacQJ/zjrhqsLhcea0bekGZB5EykKVp/lHrq4VSgfvvP9O 0OSASUx/z2FTKHHE1bVuyIE5zrfVoqmPHaNKDwFwMV+EVODcVdHjllcXS1mzMVkUFn7nIq7L Bg/vndLuhb5skcelL4ubUKkFD6B/EHwLW5lLfrXZBtOslMcuQGMaZbYtqQrWHsAtpy58F7Td CrBO1UOXTlPAgveXxjiJuX8uoOGqrTeX7vkaaOJOOXry6QWVu/Ul83zlNI8onDUcJ3IZycqD uVniBMbDTYgRJufy3NXDHZO3yPVM5zC+0z6o3wr6Jj5qLOyBmeNrcOOE+cAa40+vUDrx/7ZZ 6jIw38mYTdAisFWnCGOlehZhQ9IzXkpLmjlEKxc53SUEuSKwf4RVERdM2QqZa4qp+oq1w1Jc 6Y3k/vT0bh1xr4wAlZBDxn6n92xINYNKCe7PU/GA0CCMPKHIyfKyof5e/H0T7oYl+hSuxCq3 FTTW0b+IjSOkSXoXBGzIKlNii+cJhlXpIC6dF5kF2HiSNvsbhDzPsVwiHU6xrg9h3WCMmB5U 3A0a0RWsriZ9j9VmN16Em1Fq2tvdKyKwnnGqebfLZkSvL1gBSE13+NW7XImyqdEuSFJQPsm/ Uma5tVqolygjqyO0m89CEsI+msN3tva+xw9Zva8lNEIQ3vP8RMT4H/FDh0Lo4EgEdjzo+VKz dOJkqvvKTBE+taS/M0GBsGSJtjUVRhpeRfvBjPQCxMICDCxMmSKzU5ai/ycsGCPpJE8gpfpk ZsKDLRcURZmc5FSQlQgB9EELJptC3k8lqWHiccT+XekhBzYRcEfr5qeE/zLXqqpJzGegr1JI RAPxPmrSOZbfp2+0EtkZF5gmY3MEEeFRtFBrBpqaQosqVlM+nxzJoXW803gYwKppnQUEKzs9 vbZogR7aOUpsjzr5gVuTrIrjC45kU10iN+8xD7IL2G3I6C3UoVbTSHzshppWq4=
- Ironport-sdr: 66349bc4_oAkc7dVrruapk2gaft3HcD1A+LPtVwEbj6kQ2BTYJdLmpNq NP8QunYVPqUda83VIDwzbOl3tgj6B6Ad0PsPCiA==
Artificial Intelligence and Theorem Proving,
AITP 2024
September 1-6, 2024, Aussois, France
http://aitp-conference.org/2024
Deadline: Extended to May 12, 2024
https://easychair.org/conferences/?conf=aitp2024
BACKGROUND
Large-scale semantic processing and strong computer assistance of
mathematics and science is our inevitable future. New combinations of
AI and reasoning methods and tools deployed over large mathematical
and scientific corpora will be instrumental to this task. The AITP
conference is the forum for discussing how to get there as soon as
possible, and the force driving the progress towards that.
TOPICS
- AI, machine learning and big-data methods in theorem proving and mathematics.
- Collaboration between automated and interactive theorem proving, in
particular their AI/ML aspects.
- Common-sense reasoning and reasoning in science, relations to general AI.
- Alignment and joint processing of formal, semi-formal, and informal
libraries, Formal Abstracts.
- Methods for large-scale computer understanding of mathematics and science.
- Combinations of linguistic/learning-based and semantic/reasoning methods
- Formal verification of AI and machine learning algorithms, explainable AI .
SESSIONS
There will be several focused sessions on AI for ATP, ITP, mathematics,
relations to general AI, Formal Abstracts, linguistic processing of
mathematics/science, modern AI and big-data methods, and several
sessions with contributed talks. The focused sessions will be based on
invited talks and discussion oriented.
CONFIRMED PARTICIPANTS/SPEAKERS/PANELISTS (TBC)
João Araújo, Universidade Nova de Lisboa
Thibault Gauthier, Czech Technical University in Prague
Ben Goertzel, SingularityNET
Sean Holden, University of Cambridge
Jan Jakubuv, Czech Technical University in Prague
Mikoláš Janota, University of Lisbon
Moa Johansson, Chalmers University
Cezary Kaliszyk, University of Innsbruck
Peter Koepke, University of Bonn
Konstantin Korovin, The University of Manchester
Tomáš Mikolov, Czech Technical University in Prague
Miroslav Olsak, University of Cambridge
J.D. Phillips, Northern Michigan University
Michael Rawson, TU Wien, Austria
Stephan Schulz, DHBW Stuttgart
Martin Suda, Czech Technical University in Prague
Josef Urban, Czech Technical University in Prague
Adam Vandervorst, SingularityNET
Sean Welleck, Carnegie Mellon University
Zsolt Zombori, Alfréd Rényi Institute of Mathematics
CONTRIBUTED TALKS
We solicit contributed talks. Selection of those will be based on
extended abstracts/short papers of 2 pages formatted with easychair.cls.
Submission is via EasyChair (https://easychair.org/conferences/?conf=aitp2024).
The extended abstracts are considered non-archival.
DATES
Submission deadline: Extended to May 12, 2024
Author notification: June 20, 2024
Conference registration: TBA
Camera-ready versions: TBA
Conference: September 1-6, 2024
PROGRAM COMMITTEE (TBC)
Jasmin Christian Blanchette, LMU Munich
David Cerna, Czech Academy of Sciences
Michael R. Douglas (co-chair), Stony Brook University
Ulrich Furbach, University of Koblenz
Thomas C. Hales, University of Pittsburgh
Cezary Kaliszyk (co-chair), University of Innsbruck
Mirek Olsak, University of Cambridge
Bartosz Piotrowski, IDEAS NCBR
Stephan Schulz (co-chair), DHBW Stuttgart
Josef Urban (co-chair), Czech Technical University in Prague
LOCATION AND PRICE
The conference will take place from September 1 to September 6 2024
in the CNRS Paul-Langevin Conference Center
(https://www.caes.cnrs.fr/sejours/centre-paul-langevin/) located in
the mountain village of Aussois in Savoy. Dominated by the "Dent
Parrachée", one of the highest peaks of La Vanoise, Aussois is located
on a sunny plateau at 1500 m altitude, offering a magnificent panorama
of the surrounding mountains and a direct access to the park of La
Vanoise in summer and downhill ski slopes or cross country slopes in
winter. The total price for accommodation, food and registration for
the five days will be around 600 EUR.
ARRIVAL/DEPARTURE
Aussois is less than 2h from the airports of Lyon, Geneve, Chambery,
Annecy, Grenoble and Turin. There are trains and buses from these
airports. Aussois is 7km from the Modane TGV station with direct
trains from/to Paris. We will organize a bus for the participants from
there to Aussois. Further buses to these airports / station can be
found at http://www.altibus.com/ .
ORGANIZERS
Cezary Kaliszyk and Josef Urban
AITP 2024
BACKGROUND
TOPICS
SESSIONS
CONTRIBUTED TALKS
DATES
LOCATION AND PRICE
ARRIVAL/DEPARTURE
ORGANIZERS
- [Coq-Club] AITP 2024 FINAL CALL FOR CONTRIBUTIONS - EXTENDED DEADLINE May 12, Josef Urban, 05/03/2024
