- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Termination checker rejecting equivalent functions
- Date: Wed, 6 Nov 2024 17:35:32 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Pass smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs2-store7.inria.fr
Hi Elias,
This is a classic but however subtle aspect of the guard-checker:
Require Import List.
Inductive foo :=
| Foo : foo
| Bar : list foo -> foo.
Fixpoint map1 {X Y} (f : X -> Y) l :=
match l with
| nil => nil
| x::l => f x :: map1 f l
end.
Fail Fixpoint op1 (x: foo) :=
match x with
| Foo => Foo
| Bar l => Bar (map1 op1 l)
end.
Definition map2 {X Y} (f : X -> Y) :=
fix loop l :=
match l with
| nil => nil
| x::l => f x :: loop l
end.
Fixpoint op2 (x: foo) :=
match x with
| Foo => Foo
| Bar l => Bar (map2 op2 l)
end.
Why does op1 fail (with map1) while op2 succeeds (with map2) ?
Let us unfold the definition of map2 inside of op2. Thus we get
match x with
| Foo => Foo
| Bar m => Bar ((fix loop l := match l with
| nil => nil
| x::l => op2 x :: loop l
end) m)
end.
after reduction of map2, ie substitution of f
with op2. This is possible because map2 is a
*Definition*. Giving a legit *nested* recursion scheme.
However, the unfolding with map1 fails
because Fixpoint map1 can only be unfolded when
its structural argument has a head constructor,
hence f does not get substituted with op1 and
then the guardchecker fails to detect structural
decrease.
The situation might change with 8.20+ however
as I recall a discussion on Zulip Coq.
Concerning
Fixpoint op4 (x: foo) :=
match x with
| Foo => Foo
| Bar l => Bar (myMap op4 l)
end
with myMap (f: foo -> foo) (l: list foo) :=
match l with
| nil => nil
| x :: xs => f x :: myMap f xs
end.
It gives the following *scary* warning
(* Not a fully mutually defined fixpoint
(op4 depends on myMap but not conversely).
Well-foundedness check may fail unexpectedly.
[non-full-mutual,fixpoints,default]
op4 is defined
myMap is defined
op4, myMap are recursively defined (guarded respectively on 1st, 2nd
arguments)
which means it accepts this mutual definition
even though it should not because foo and (list foo)
are not mutually defined inductive types. Maybe
the "non-full-mutual" option allows for this.
I wouldn't trust a code that produces such a warning.
For a legit mutually dependent fixpoint, you can try
Inductive foo :=
| Foo : foo
| Bar : lfoo -> foo
with lfoo :=
| Nil : lfoo
| Cons : foo -> lfoo -> lfoo.
match x with
| Foo => Foo
| Bar l => Bar (myMap l)
end
with myMap (l: lfoo) :=
match l with
| Nil => Nil
| Cons x xs => Cons (op4 x) (myMap xs)
end.
Best
Dominique
----- Mail original -----
> De: "Elias Castegren" <elias.castegren AT it.uu.se>
> À: "coq-club" <coq-club AT inria.fr>
> Envoyé: Mercredi 6 Novembre 2024 16:56:32
> Objet: [Coq-Club] Termination checker rejecting equivalent functions
> Hi all
> I ran into an issue I don’t understand yesterday, minimised below:
> I have a datatype where one constructor holds a list of recursive values:
> Inductive foo :=
>| Foo : foo
> Sometimes I want to apply operations to values of this type, and then I
> can use Coq’s standard map function to handle the Bar constructor:
> match x with
> | Foo => Foo
> | Bar l => Bar (List.map op1 l)
> end.
> (* Compiles OK! *)
> However, I am really using the TLC library and if I use the corresponding
> map function the termination checker complains (the two functions have
> the same type according to Check):
> match x with
> | Foo => Foo
> | Bar l => Bar (LibList.map op2 l)
> end.
> (* Recursive call to op2 has principal argument equal to "x0"
> instead of one of the following variables: "l" "l0".
> Recursive definition is:
> "fun x : foo =>
> match x with
> | Foo => Foo
> | Bar l => Bar (map op2 l)
> end".
> If I write a dedicated map function that is mutually recursive I get
> the same error:
> Fixpoint op3 (x: foo) :=
> match x with
> | Foo => Foo
> end
> with
> myMap (l: list foo) :=
> match l with
> | nil => nil
> | x :: xs => op3 x :: myMap xs
> end.
> (* Recursive call to op3 has principal argument equal to
> "x" instead of "xs".
> "fun l : list foo =>
> match l with
> | nil => nil
> end".
> However, if I write a slightly less dedicated map function as a
> mutually recursive function it works:
> match x with
> | Foo => Foo
> end
> match l with
> | nil => nil
> end.
> (* Compiles OK! *)
> Strangely, even though this is not a true mutually recursive
> definition, if I separate the two I get an error about the number
> of arguments which doesn’t make sense to me:
> Fixpoint myMap2 (f: foo -> foo) (l: list foo) :=
> match l with
> | nil => nil
> | x :: xs => f x :: myMap2 f xs
> end.
> Fixpoint op5 (x: foo) :=
> match x with
> | Foo => Foo
> | Bar l => Bar (myMap2 op5 l)
> end.
> (* Recursive call to op5 has not enough arguments.
> "fun x : foo =>
> match x with
> | Foo => Foo
> | Bar l => Bar (myMap op5 l)
> end".
> Any ideas of what is going on is greatly appreciated!
> /Elias
> När du har kontakt med oss på Uppsala universitet med e-post så innebär det
> att
> vi behandlar dina personuppgifter. För att läsa mer om hur vi gör det kan du
> läsa här: http://www.uu.se/om-uu/dataskydd-personuppgifter/
> E-mailing Uppsala University means that we will process your personal data.
> For
> more information on how this is performed, please read here:
> http://www.uu.se/en/about-uu/data-protection-policy
- [Coq-Club] Termination checker rejecting equivalent functions, Elias Castegren, 11/06/2024
- Re: [Coq-Club] Termination checker rejecting equivalent functions, Dominique Larchey-Wendling, 11/06/2024
