- From: Tom Hirschowitz <tom.hirschowitz AT univ-smb.fr>
- To: Coq Club <coq-club AT inria.fr>, types-announce AT lists.seas.upenn.edu
- Cc: Pierre Hyvernat <pierre.hyvernat AT univ-smb.fr>, Vincent Reverdy <vincent.reverdy AT lapp.in2p3.fr>
- Subject: [Coq-Club] Postdoc in Chambéry
- Date: Mon, 18 Nov 2024 14:59:56 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tom.hirschowitz AT univ-smb.fr; spf=Pass smtp.mailfrom=tom.hirschowitz AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout01-ext2.partage.renater.fr
- Dkim-filter: OpenDKIM Filter v2.10.3 zmtaauth05.partage.renater.fr 3A46C200D5
- Ironport-sdr: 673b485f_qNJKuC/Vn5G9+uP9hflBGh25bwGkYE/T2CXx8tDdB3iwJch 4CxymV0ZqEPjWy5+IzmCmFrE4Wz+bP+gXjwj71w==
Hi all,
The LAMA
https://lama.univ-smb.fr
offers a full-time, 18 month postdoc position starting February 2025. The
deadline is really soon: December 9! (Although the position should be
re-published if not filled.)
The details are here
https://univ-smb.nous-recrutons.fr/poste/nzyn17a55c-chercheur-post-doctorant-fh-usmb-shine-guli-anr-22-exes-0017/
and there
https://www.univ-smb.fr/wp-content/uploads/2024/11/offre-emploi-post-doc-2024-100__lama_guli_vf.pdf
but let us give a brief summary.
Most numerical simulation programs compute with very little checks for
physical consistency. Typically, adding a length (in metres) to a force (in
newtons) is not detected as an error by the programming language. But the
very purpose of type systems is to detect inconsistencies of a similar
nature. E.g., they prevent addition of numerical values with arrays. Until
now, programming language theorists have proposed solutions that are
conceptually clear, but too naive to cover all use cases. On the other hand,
other attempts tried to handle numerous cases independently, but eventually
came out as too complex to be usable.
The goal of the present postdoc position is to try and design a conceptually
clear solution covering all use cases.
The successful applicant will be based at LAMA, and work with Tom Hirschowitz
and Pierre Hyvernat, but also with Vincent Reverdy (who is a numerical
physicist and the Particle Physics Laboratory in Annecy).
Relevant skills for the position include: type theory, category theory,
programming language theory, programming in proof assistants, implementation
of programming languages. It is definitely not necessary to possess all these
skills to be successful.
Please don't hesitate to contact us if you have any question,
Tom Hirschowitz
Pierre Hyvernat
Vincent Reverdy
- [Coq-Club] Postdoc in Chambéry, Tom Hirschowitz, 11/18/2024
