- From: Richard Dapoigny <richard.dapoigny AT univ-smb.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Problem with definitions scope in imported module
- Date: Sun, 22 Dec 2024 19:57:27 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=richard.dapoigny AT univ-smb.fr; spf=Pass smtp.mailfrom=richard.dapoigny AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout02-ext4.partage.renater.fr
- Dkim-filter: OpenDKIM Filter v2.10.3 zmtaout04.partage.renater.fr 69770140270
- Ironport-sdr: 67686119_VzpjOiZDZZTUMK0zygz5bDRrK/yNBfp3e6ccLKWfw/l7EEZ xZm5Mn08B7WW/HDT6psBrWt3GBuu5OuaJYAxsvA==
I think it is clearly a problem of multiple inheritance. If I coerce, then it works :
Parameter NN : basis_mereo.N -> N.
Coercion NN : basis_mereo.N >-> N.
Lemma test : forall A, η A balls -> η A (el (NN Gspace)). -> ok
From: "mukesh tiwari" <mukeshtiwari.iiitm AT gmail.com>
To: "coq-club" <coq-club AT inria.fr>
Sent: Sunday, December 22, 2024 5:00:09 PM
Can you post a code snippet that I can run locally on my machine?
Best,
Mukesh
On Sun, 22 Dec 2024 at 15:13, richard <richard.dapoigny AT univ-smb.fr> wrote:
Thanks Mukesh for your prompt answer.
However, it does not work since in that case, variables in F3 become unknown.
Le 22/12/2024 à 14:03, mukesh tiwari a écrit :
Hi Richard,
In F2.v you have a definition *Module Mereology (M1 : UsualDecidableTypeFull) := DST_signature(M1).* and then the same in F3.v *Module Mereology (M1 : UsualDecidableTypeFull) := DST_signature(M1).*. I suspect when you redefining Mereology in F3 and subsequently importing F2.v, somehow it is causing some confusion. Trying removing the definition *Module Mereology (M1 : UsualDecidableTypeFull) := DST_signature(M1).* from F3.v and see if it works (I am not an expert in modules so I cannot say for sure it is the case).
Best,Mukesh
On Sun, 22 Dec 2024 at 12:15, richard <richard.dapoigny AT univ-smb.fr> wrote:
Dear coq members,
I have the following problem with importing definitions with multiples
coq modules:
I have a file F1.v :
Module DST_signature (M1 : UsualDecidableTypeFull).
Import M1.
End DST_signature.
then a file F2.v (there is a file F1.vo) :
Require Import F1.
(** Module Abstract *Structure **)
Module geometry_signature (M1 : UsualDecidableTypeFull).
Module basis_mereo := Mereology M1.
Import basis_mereo.
End geometry_signature.
and finally a file F3.v (there is a file F2.vo and a file F1.vo) :
Require Import F1.
Module AbstractStructure (M1 : UsualDecidableTypeFull).
Module basis_inst := Mereology M1.
Import basis_inst.
End AbstractStructure.
Require Import F2.
Module Tarski_geom (M1 : UsualDecidableTypeFull).
Import basis_mereo.
Module adt := AbstractStructure M1.
Import adt.
Module geom := geometry_signature M1.
Import geom.
Lemma test : forall A, η A balls -> η A (el Gspace). -> fail
End Tarski_geom.
While there is no problem for all variables defined in F1 there seems to
be a problem with variables defined in F2 since the error is :
The term "Gspace" has type "basis_mereo.N" while it is expected to have
type "N". (Gspace is defined in F2)
If someone has an idea to solve the problem?
Thanks in advance,
Richard
- Re: [Coq-Club] Problem with definitions scope in imported module, richard, 12/22/2024
- Re: [Coq-Club] Problem with definitions scope in imported module, mukesh tiwari, 12/22/2024
- Re: [Coq-Club] Problem with definitions scope in imported module, Richard Dapoigny, 12/22/2024
