coq-club - [Coq-Club] Haskell Symposium 2025 First Call for Papers
  • To: caml-list AT inria.fr, coq-club AT inria.fr, agda AT lists.chalmers.se, haskell-cafe AT haskell.org, types-announce AT lists.seas.upenn.edu
  • Subject: [Coq-Club] Haskell Symposium 2025 First Call for Papers
  • Date: Thu, 27 Mar 2025 12:09:37 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xnningxie AT gmail.com; spf=Pass smtp.mailfrom=xnningxie AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f53.google.com
  • Ironport-data: A9a23:cpVk4aJjdzfaDBQ+FE+Ra5ElxSXFcZb7ZxGr2PjKsXjdYENS0DNSz jAcCG/XO6rZY2ekedl+bIq/8BtQ6MTWmNVrSgUd+CA2RRqmi+KVXIXDdh+Y0wC6d5CYEho/t 63yTvGacajYm1eF/k/F3oDJ9CU6j+fSLlbFILasEjhrQgN5QzsWhxtmmuoo6qZlmtHR7zml4 LsemOWBfgb5s9JIGjhMsf/b80kw5K+aVA4w5zTSW9gb5DcyqFFOVPrzFYnpR1PkT49dGPKNR uqr5NlVKUuEl/uFIorNfofTKiXmcJaKVeS9oiY+t5yZv/R3jndaPpDXmxYrQRw/Zz2hx7idw TjW3HC6YV9B0qbkwIzxX/TEes3X0GIvFLLveBCCXcKvI0LuLUHUw6s3HFgMH4A86+RtW01S7 84lJ2VYBvyDr7reLLOTT+BtgoEuIJCuMt5E/H5nyj7dALAtRpWrr6fiv4cJmmdtwJoWTbCDP KL1ahI3BPjESw1JPFYRB4I/kc+ng3D+d3tTr1f9Sa8fujGJk1whieixWDbTUtHWddQLmBaon FzpxWD7Lk1GEvmN0TXQpxpAgceUwHqjB9NMfFGizdZhiViXg2gSEwE+Tkq+ufD/i0ikWtsZJ VZ80iEptO058FGhZsLsWgWx5n+CpB8VHdRKe9DW8ymIw6vQpguVXy0KE2UHZ9shu8s7Azct0 zdlgu8FGxQxioWVFyuN7422oBejOzJPAXMYVxILGF5tD8bYnKk/iRfGT9BGGaGzj8HoFTyY/ 9xshHhv71n0pZ5bv5hX7Wz6bySQSo8lpzPZCy3SV2Ohqw51PcurOtfu5l/c4vJNao2eSzFtX UToeeDPtYji7rnUy0Rhpdnh+pn3up5p1xWC3DZS82EJrWjFxpJaVdk4DMtCDEloKN0YXjTif VXevwhcjLcKYyfxNfYsM9PgWpx7pUQFKTgDfqCFBjapSsghHDJrAAkyPSZ8Iki0wBhzyf5vZ f93j+72XSpLWPsPIMWKqxc1iuJynn9vmws/tLj0yBOo1bfWZXieD9843KimP4gEAFe/iFyNq b53bpPUoz0GCbGWSneNreY7cwtRRVBlXsCeliCiXrTfSuaQMDt8U6eJqV7gEqQ595loehDgp C3kAx4DkgKn3hUq62yiMxheVV8mZr4nxVpTAMDmFQzAN6ELON70sPUsZNEscKM59edu6/dxQ rNXM4+DG/lDAHCPsTgUcZC3/sQoeQWJlDC+GXOvQAE+WJp8GC3P2NvvJTX0+Ac0UyGYiMoZo p+b7D39f6YtfQpZIfztWKqd9G/p5Xk5s8BubnTMOehWKRnN8pA1Cinfjc0XAsArKDfFzAS0z wy9XBUS/7HMh6QX89D5o7+OgKn0Mul5H2tcR3L665TvPwbk32OT+61ye8fWQiL8DUTf57eHS dhO6c3FINkrvQpvopVtNbRG1oc87IbfnKBbxQFaA3n7VVSnJbd+KH2g38MUlKly6pJGmAmxS GSd08J7POiXBcbbD1IhHgopQeCd3/UymDOJz/AUIl3/1RBn7oi8TkReEBmduhNzdIIvHtse/ t4gn8oK5yiUqBkgaI+Ghx8J0VW8FCULVqF/u6wKBIPutBEQ9WhDRp7hEQ7z3oCEboRdE0stI wLMvpH4uZZn+hPgfUYwRF/35sgMobQVuRtP8k0OGETRpPrBmc0M/UNw9RYZc11r6ytpgsxPP lplDUlXHZm13ixJgZFDVl+8GgsaCxy+/Ffw+mQzl2bYbheJU2DRHVI5IsKI2l4TyENHXz1h5 LrD4n3UYTXrW8DQ3yUJRk9urcL4f+Fx7gHvnMOGHdyPOpsHPR7Jp7CIXnVRjTfKGuYzi1/ji cgw2d1veIvpMSI0iI8qObmwjLg/ZkiNGz1ffKtH4qgMI1D5RBiz/jqrcGWaZcJHIq3xw3+SU sBBCJpGaEWj6XyosDseOK8rJo10lt4P4P4pWOviBUwCgoulggtZirDi3QmguzZzWPRrq9g3F a3JfTHbEmCwu2pdq1WQkOZ6YFiHcfs2Tyyi+tuq8dc5NYMJ68BtVkAQ7oGanVuoNClfwhbFm z+bOoH3ybR5xJVOjrncNPxJJz+JJOPZUMWK9wGOsOpyU+7fDPeWty0phwnmGy90IYouX89Gk OXRkdzvg2LAkrUEc0HYvJijC5h24d6WY9RUF/muKV9muDawAp7y0UET/0S9D4JDq/JGx8ydX wDjQtCBRd0UfNZ8xXNudClVFSgGOZn3dqvNoSCcreyGLwo0iyjrHYiCzmD4S11begsjGYzMO iWtt9mAvtln/ZlxXjkaDPRYMrpECV7EW5p+UebutDOdX1KasnnbtpTMzRMfuCz2UF+aG8PH4 LXAdBj0VDK2nIrqlNh5kYhDjic7PUZHo9sbXxwiooZtqjWAEmQ5A/wXMswGBrFqgyXC7szES w+XXlQyKxfWfGpiSgr90uTBTw3EJ+0pO/XFHBIL0X6QSR+LANKnPOM82AZmunt4Q262hqXvY 9QT4Wb5MRWN04lkD7RbrOCyheB8gOjW3DQU8ET6iNb/GAsaHa5M7nF6AQ5RTmbSJqkhTqkQy bQdHgiogX1XSHId1e5lcn9RXRwV5Xbhkm5uYiCIz9LS/Y6cyYWsDRE51/7bitU+gAYifdbih k8bg0OC5mmX3joYvq5BVxcBn/pvEfzSdiSlBPaLeODR9p1cLkwoOsoDmWwES8RKFMuz1b/Cv mHE3kXSz3hp5KycNHN6BOnJF19MvqowMgz0
  • Ironport-hdrordr: A9a23:uE7SCqg1BwJolFqRCzc+W796BXBQXhIji2hC6mlwRA09TyX4rb HXoB1/73XJYVkqKRQdcLy7Scu9qBDnhP1ICOsqTNCftWDd0QPCEGgI1/qF/9SPIVyGysdtkY hnaLZ3E9D9ABxXiszg8BCkH9tI+rW62ZHtq+Ob4HtkUB1wZ7sI1XYcNi+rVmNzACdJbKBWKH Ne3KV6TvibFEj/ov7bOpDNZYj+m+E=
  • Ironport-phdr: A9a23:EoJynxKhpttTaq2nbNmcuDlvWUAX0o4c3iYr45Yqw4hDbr6kt8y7e hCEv7M11BSQA9WLsLptsKn/jePJYS863d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T 4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbghGmjaxe69+I Am5oQnMt8QbgohvJ6gswRbVv3VEfPhbymxvKV+PhRjw4du+8oB++CpKofIh8MBAUaT+f6smS LFTESorPWMo6sD1rBfPVQSA6GcSXWUQiRpIHhPK7ArmUZfrsyv1rfRy1S+HNsDrV780WDCi7 6B2SB/0jSoMKjA0/H3LhsF2kalWpg+qqR5izI7OeIyaO/pwcK3ec90HW2ROQt1cWDZdDo6md YYDE/YNMOReooLgp1UOtxy+BQy0Ce33yz9IgHD23as70+QnHgHNwQ0vH9MQv3/Jq9j0O6ESU ea0zKnOwjXCYPJW1inm5YjHdxAuu/CMXbZqfcXNzkkvEhrIg1ONooPqIz2bzP4Cs3SH7+V+T +KvjXYqpx1+rDSzycohjovEiIwRx13A9yh13po5KNm2RUJlf9OpEJhdui+YOoZ1Xs4vQXxlt Dgkx7EaupO2cyoHxZcnyRPZdveJfY+I4hf5W+aQJzd1nGhld6ykhxms60eg0PHzVsmu0FpQq SpFiNbMumgN1xzU9siIVuF9/l+71TmT0ADT7+dJKl03m6rDM5Mt3KI8m54JvUnAHiL6glv6g LOVe0k++uWl5eLqaaj4q5+YKo90kR3+Pbo0msKiAOQ5MxYBUnCH9em6ybbt51f2QK9Qgf0zi qTZsI7VJcAcpqOhBg9ayIcj6xKmAzi4zdsUgGALLFxFdR+JlYTpNFbOIPf3Dfe7nVugiitkx /fDPrH5A5XNKGbMkKv5cLpj90JRzBA/wNNf6p5OFL0NPPH+VlXxudHWFhM5Nha7w+fjCNVzz IMeXmePD7eWMaPUt1+I5+QvI+aDZY8UpjnwMPcl5/v0gn84nV8RZ7Wm3ZwSaHygGPRpOF2WY WDwjdcZDWcKog0+QfT0hFGaSz5ce26yX74g5jE8EI+pEZ3MRoWpgLCY2Ce7H4ZWZnxdB1CXE Xbocp2EVO0WZCKTJM9hiD0EWqK7R48vzxGirBX6xKZ/LurI5i0Ysoru28Ry5+3KjB096Th0D 9mG3GyWVGF1nmYIRycs06xloEx9zE2D0alijPBCG9xT/aABbgBvPpfZy6l+CsvucgPHZNaAD li8Bp2tBih0RdYsyfcPZVx8EpOslFSL1iWmCpcRlqeXH9o/8qvY2nXrPIBmxjKO1KA6jFQiR o5EPGOrrq527AveA4qPlF+W0+62ZLwRx2vE8mGE0GyFsWlcURVsSuPeUHkEIFbOoNL/oE7OU uyAE7MiZy1Az8GEK61FIu3ogB0SVPHlOdLRc2O8s2i1DBeMgLiLady5KC0mwCzBBR1cwEgo9 nGcOF1mbs/Ai2fXDTg1UEnqf1up6u5m7nWyUk4zyQiOKUxnzbu8vBAP1rSHU/1G+LUCtW86r ilsWk6n1ofGDdyBoQVxfah0btY04VMB3mXc5ERmJpL1F6l5nRYFdhhv+Ubn1hF5EIJFxNgsq nIswxpzJIqX1VpAc3WT2pWjcqbPJDzU+xaiI7XTxkmY0NuS/fIX7+8krlz4oAyzPk8r8nEi3 tUMlnXBvdPFCw0dVZ+3WUEyn/Rjj5fdZCR1p4bd1Hk3dLKxrieHwNUxQu0s1hened5bdqKCD g77VcMAVYCoL6Qxll6lYwhhXqga/bMoP86ga/qN2bK6dOdmkjW8iG1b4Yd7mkuS/it4Q+TM0 t4L2fadlgeAUj79ih+mvKWV0chUYzcTGGWvyCXMC4tYZ6k0doEOSC+vL8Cx2tRilsv1QXcLv FWnBl4AxIqoYU/INw27jVAWjxxH5yH8yk7ah3Runjokr7SSxnnLyuXmL18cP3JTAXJllRHqK JS1iNYTWA6paRIonV2r/xWfpeATqaJhIm3UWUoNcTLxKjQoQq22t7yNc89CwJwtuCRTFu+7Z BrJL9y16wtfyC7lE2ZEkXorcTervJrpnhFSh2eULXI1p33cM5I41VLU49rSQuRU1zwNSXxji DXZMVO7OsGg4dSek5qrXvmWb2u6TdUTdCDqydjFry6n/ShxBgX5mfmvm9rhGAx80Cnh1tAsW z+a5Br7Z4Dq0ey9P4cFNgF4Aln97cVqG4xWnY45hZVW0n8fzpmY5nsIl27vPM4Tg/qvKipQA 2RTk5iIu0DswwV7I2iMxp7lW3n4oIMpfNS8bm4Mm2o8481MFKaI/elBlCpxrEC/qFGZavx8k zEBjPo2vSRC0qdZ5Ux3lnXbX+tBeCsQdTbhnBmJ8d2k+aBeZWL0NKO1yFI7hte5SreLvgBbX n/9PJYkBy55qMtlYzeumDX+7J/pfN7IYJcdrBqRxl3Qie5ULp0hl/ciii9uOGa7tnoggb1e7 1QmzdShsY6LJn84trK/BB9eOS30ausc/zjsieBVmcPcjOXNVt1xXz4MWpXvV/ehFjkf4O/mO wi5Gzo5sn6HGLDbEFzX+AJ8onnICZzuK2CPKSxT04B5XBfEbh864khcTHAgk5U+DAzv2MHxb BIz+GUK/lCh4hpUlrAzal+mAz+Z/lv3LG9zEsTXLQIKvF8eoR2OaorHsLo1R2YBr/jD5ESMM jDJOVoOVDlTHBTCXxe5ZvGv/YWSrbbeXLbvaauWJ+3J87QWVu/Ul831lNI6uW/dbIPXeSAya p9zkktbASImR4KAwWhJE2pP0HuTJ8+D+EXlon0x95/gtqStAEW1vMOOE+cAaIo0vUnn3eHbc bbX3XgcS34Q14tQlyWQmf5PgRhL0XEoL370TvwBrXKfFvuO3PIHSUdKMWUrc5IZp6MkglsXY JCd0IikkOUiyKZyUgYgNxSpjMitYYZiz3iVElTBCQ7LMb2HIWaO2MTreeanTqUWiuxIthq2s DLdEkn5Pz3FmSO7HxaoefpBii2WJnk88Mm0bwptBG7/TdnndgzzMdl5iiczyKE1gXWCPHAVM Dx1eUdA5rOK6iYQjvJ6Em1Hpn1rSIvM0z6e9PXdI40KvOFDBy11k6dX7C1/xeYOqi5DQ/Nxl W3Zqdsv61Cqn++TyyZ2BRpDrjEY4eDD9U5mOKjf6txBQSOepENLvTjWUUxa4YY+WbiN8+hKx 9PClbz+MmJH+tPQpo4HAtTMbdmAKDwnOAboHzjdCE0ESySqPCfRnR848rna+3uLo5w9spWpl oAJT+oRRFozF/UVGkVoNNMHKZZzGDgjlPTI6axArWr7txTXSMhA69rfUemOBPz0NDuDpbxNZ h9NzL+haIpObcv03EttblQ8l4PPURm1P5gFsmhqaQk6p19I+X51Qzgo2k7rXQiq5WcaCf++m hNeYu5WbuEk9TOq6FAydAKiTMoYlUAwnZDojWnUfmOqaqi3Wo5SBmz/sE1javsTrC56aASzm QpvMzKWHtps
  • Ironport-sdr: 67e5784f_UgzL6rYNJMa5add14R45rY7Ehm+bGC1CtulozQkIQjiozno OE7q0XmVJr35nd/ibUo9okwCjO8M6DoCy5PUqCw==
               Haskell Symposium 2025 Call for Papers
                 Thu 16 - Fri 17 Oct 2025, Singapore
    https://conf.researchr.org/home/icfp-splash-2025/haskellsymp-2025
The ACM SIGPLAN Haskell Symposium 2025 will be co-located with the 2025
International Conference on Functional Programming (ICFP) and the 2025
International Conference on Systems, Programming, Languages and Applications:
Software for Humanity (SPLASH).
The Haskell Symposium presents original research on Haskell, discusses practical
experience and future development of the language, and promotes other forms of
declarative programming.
 Submission deadline:    9 June  2025      (Mon)
 Notification:           17 July 2025      (Thu)
Deadlines are valid anywhere on Earth.
Papers should be submitted through HotCRP at: https://haskell25.hotcrp.com/
Topics of interest include:
 * Language design, with a focus on possible extensions and modifications of
   Haskell as well as critical discussions of the status quo;
 * Theory, such as formal semantics of the present language or future
   extensions, type systems, effects, metatheory, and foundations for
   program analysis and transformation;
 * Implementations, including program analysis and transformation,
   static and dynamic compilation for sequential, parallel, and distributed
   architectures, memory management, as well as foreign function and
   component interfaces;
 * Libraries, that demonstrate new ideas or techniques for functional
   programming in Haskell;
 * Tools, such as profilers, tracers, debuggers, preprocessors,
   and testing tools;
 * Applications, to scientific and symbolic computing, databases, multimedia,
   telecommunication, the web, and so forth;
 * Functional Pearls, being elegant and instructive programming examples;
 * Experience Reports, to document general practice and experience in
   education, industry, or other contexts;
 * Tutorials, to document how to use a particular language feature,
   programming technique, tool or library within the Haskell ecosystem;
 * System Demonstrations, based on running software rather than novel
   research results.
Program Committee
Andreas Abel                 Gothenburg University
Patrick Bahr                 IT University of Copenhagen
Matthew Fluet                Rochester Institute of Technology
Adam Gundry                  Well-Typed LLP
Xuejing Huang                IRIF
Hideya Iwasaki               Meiji University
Patricia Johann              Appalachian State University
Hsiang-Shang 'Josh' Ko       Institute of Information Science, Academia Sinica
András Kovács                University of Gothenburg and Chalmers University of Technology
Andres Löh                   Well-Typed LLP
J. Garrett Morris (co-chair) University of Iowa
Liam O'Connor                Australian National University
Maciej Piróg                 University of Wrocław
Arnaud Spiwack               Tweag
Meng Wang                    University of Bristol
Li-yao Xia                   Inria
Ningning Xie (co-chair)      University of Toronto
Gergő Érdi                   Standard Chartered Bank
If you have questions, please contact the chairs at: ningningxie AT cs.toronto.edu and garrett-morris AT uiowa.edu.
  • [Coq-Club] Haskell Symposium 2025 First Call for Papers, Ningning Xie, 03/27/2025
