Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Example spmv
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Example spmv
  • Date: Fri, 02 Apr 2010 18:16:51 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Nathalie Furmento wrote:
The example spmv from starpu/trunk segfaults.
Here what i did (on hannibal):
$ ../trunk/configure --enable-blas-lib=atlas --enable-debug --enable-verbose
$ make
$ libtool --mode=execute gdb ./examples/spmv/dw_spmv ...
(gdb) bt
#0 0x0000000000401e07 in cpu_spmv (descr=0x7fffe98438f8, arg=0x0) at
../../trunk/examples/spmv/dw_spmv.c:120
#1 0x00007ffff7bcdeb7 in execute_job_on_cpu (j=0x7fffe98439a0,
cpu_args=0x7ffff7ddb5a0) at ../../trunk/src/drivers/cpu/driver_cpu.c:60
#2 0x00007ffff7bce291 in _starpu_cpu_worker (arg=0x7ffff7ddb5a0) at
../../trunk/src/drivers/cpu/driver_cpu.c:180
#3 0x00007ffff219473a in start_thread (arg=<value optimized out>) at
pthread_create.c:300
#4 0x00007ffff1f0569d in clone () at
../sysdeps/unix/sysv/linux/x86_64/clone.S:112
#5 0x0000000000000000 in ?? ()
(gdb) list
115 for (row = 0; row < nrow; row++)
116 {
117 float tmp = 0.0f;
118 unsigned index;
119
120 unsigned firstindex = rowptr[row] - firstelem;
121 unsigned lastindex = rowptr[row+1] - firstelem;
122
123 for (index = firstindex; index < lastindex; index++)
124 {
(gdb) p rowptr
$1 = (uint32_t *) 0x0
(gdb)
By looking at the source code of the application and StarPU, i could not
figure out how rowptr could end up
being NULL. I first thought it was a problem with the csr filter, i looked at
it with Samuel, and it seems to be
correct.
The application needs the --enable-blas-lib=atlas to be compiled, and so is not tested
with a regular "make check".
We should probably change that.
Thanks,
Nathalie
Hi Nathalie,
Thanks for the report, there was actually a bug in the filter implementation which should be fixed by commit #1950.
I agree that we should find a way to have a more intensive test suite so that we detect such issues ... Similarly there are some problems which only appear when some options are disabled (eg. --disable-cuda). Perhaps we should refresh tests/coverage/coverage-test.sh which has gone unmaintained for a while ?
Cédric
Cédric AUGONNET
PhD student -- Runtime Team
http://runtime.bordeaux.inria.fr/augonnet/
INRIA Bordeaux - LaBRI
Haut de le page
