Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Juhoor Mehdi <mehdi.juhoor@etu.u-bordeaux1.fr>
- Subject: [Starpu-devel] Matrix Filters
- Date: Mon, 12 Jul 2010 17:25:11 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
I have a question about the filters. I have a sample application which defines a matrix, partitions it in 2 blocks, and sets the elements of the i-st block to i.
Here the output i get with the filter *starpu_block_filter_func*:
IN Matrix:
10 11 12 13
14 15 16 17
18 19 20 21
22 23 24 25
OUT Matrix:
0 0 1 1
1 1 1 1
1 1 20 21
22 23 24 25
And with the filter *starpu_vertical_block_filter_func*
IN Matrix:
10 11 12 13
14 15 16 17
18 19 20 21
22 23 24 25
OUT Matrix:
0 0 0 0
0 0 0 0
1 1 1 1
1 1 1 1
So it is working fine with *starpu_vertical_block_filter_func*, but not with *starpu_block_filter_func*.
Any ideas on what's wrong ....
Thanks,
Nathalie
/* * StarPU * Copyright (C) INRIA 2008-2009 (see AUTHORS file) * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU Lesser General Public License as published by * the Free Software Foundation; either version 2.1 of the License, or (at * your option) any later version. * * This program is distributed in the hope that it will be useful, but * WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. * * See the GNU Lesser General Public License in COPYING.LGPL for more details. */ #include <starpu.h> #define NX 4 #define NY 4 #define PARTS 2 void cpu_func(void *buffers[], void *cl_arg) { unsigned i, j; int *factor = cl_arg; /* length of the matrix */ unsigned nx = STARPU_GET_MATRIX_NX(buffers[0]); unsigned ny = STARPU_GET_MATRIX_NY(buffers[0]); /* local copy of the matrix pointer */ int *val = (int *)STARPU_GET_MATRIX_PTR(buffers[0]); for(j=0; j<ny ; j++) { for(i=0; i<nx ; i++) val[(j*nx)+i] = *factor; } } int main(int argc, char **argv) { unsigned i, j, n=10; int matrix[NX*NY]; starpu_data_handle handle; int factor=1; starpu_codelet cl = { .where = STARPU_CPU, .cpu_func = cpu_func, .nbuffers = 1 }; fprintf(stderr,"IN Matrix: \n"); for(j=0 ; j<NY ; j++) { for(i=0 ; i<NX ; i++) { matrix[(j*NX)+i] = n++; fprintf(stderr, "%d ", matrix[(j*NX)+i]); } fprintf(stderr,"\n"); } fprintf(stderr,"\n"); starpu_init(NULL); /* Declare data to StarPU */ starpu_matrix_data_register(&handle, 0, (uintptr_t)matrix, NX, NX, NY, sizeof(matrix[0])); /* Partition the matrix in PARTS sub-matrices */ struct starpu_data_filter f = { .filter_func = starpu_vertical_block_filter_func, .nchildren = PARTS, .get_nchildren = NULL, .get_child_ops = NULL }; starpu_data_partition(handle, &f); /* Submit a task on each sub-vector */ for (i=0; i<PARTS; i++) { starpu_data_handle sub_handle = starpu_data_get_sub_data(handle, 1, i); struct starpu_task *task = starpu_task_create(); factor = i;//10; task->buffers[0].handle = sub_handle; task->buffers[0].mode = STARPU_RW; task->cl = &cl; task->synchronous = 1; task->cl_arg = &factor; task->cl_arg_size = sizeof(factor); starpu_task_submit(task); } starpu_data_unpartition(handle, 0); starpu_data_unregister(handle); starpu_shutdown(); fprintf(stderr,"OUT Matrix: \n"); for(j=0 ; j<NY ; j++) { for(i=0 ; i<NX ; i++) { fprintf(stderr, "%2d ", matrix[(j*NX)+i]); } fprintf(stderr,"\n"); } fprintf(stderr,"\n"); return 0; }
- [Starpu-devel] Matrix Filters, Nathalie Furmento, 12/07/2010
- Re: [Starpu-devel] Matrix Filters, Cédric Augonnet, 12/07/2010
- Re: [Starpu-devel] Matrix Filters, Nathalie Furmento, 12/07/2010
