Archives de la liste
- To: Denis Barthou <denis.barthou@inria.fr>
- Cc: Emmanuel Jeannot <emmanuel.jeannot@labri.fr>, raymond.namyst@inria.fr, starpu-devel@lists.gforge.inria.fr, alexandre.denis@inria.fr
- Subject: Re: [Starpu-devel] SOCL
- Date: Wed, 17 Nov 2010 20:59:45 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, Le 17/11/2010 18:53, Denis Barthou a écrit : Hi, I just have questions on the first part so far. 2010/11/14 Sylvain HENRY <sylvain.henry@inria.fr>
From OpenCL spec: clEnqueueReadBuffer(cl_command_queue /*
command_queue */,Hi Cedric, Le 14/11/2010 10:53, Cédric Augonnet a écrit : Hi Sylvain, This is not a full answer, but just a few questions to help us understand your issues a little better... Current implementation: SOCL uses a fake StarPU computation task to schedule data transfers. This fake task uses memcpy or blocking clEnqueueRead/WriteBuffer to copy data. This has several drawbacks: - computing devices are considered busy while they are in fact waiting for DMA transfer to complete - data transfer may not be optimal (DMA where memcpy could have been used, etc.) We are current looking how to add an efficient starp_data_cpy function. This function copies the content of a handle into another, and a callback is possibly executed when the transfer is done. We still use a task internally, but we'll look how to do that better in the future. Sylvain, what are the input/output data (from StarPU point of view) of your copy task ? cl_mem /* buffer */, cl_bool /* blocking_read */, size_t /* offset */, size_t /* cb */, void * /* ptr */, cl_uint /* num_events_in_wait_list */, const cl_event * /* event_wait_list */, cl_event * /* event */) We implement this as follows: 1) We retrieve the StarPU data associated to "buffer" (source data): B = buffer->handle 2) We store other parameters (offset, cb and ptr) in a struct P 3) B is used as input data of the copy task, P is passed to the task too as non managed data 4) The copy task is submitted with appropriate dependencies and performs memcpy or clEnqueueReadBuffer. To me, I think it would be more natural to perform a transfer by defining a no-op task, with inputs and outputs. Its input is the same as its output and corresponds to the data to copy, and the task is pinned to a particular architecture (this task is just a pass-thru, forcing data to be transfered/copied to the necessary architecture). So this issue boils down to know how to pin a particular task to a particular architecture, bypassing StarPU mapping heuristics. What am I missing ? :-) Implementing clEnqueueWriteBuffer (copy N bytes from Ptr (host memory) into Buffer at Offset) with this solution would be even harder. From a higher perspective, in OpenCL all tasks are statically mapped to a particular device. When the user programs a data transfer to a device, it's because later on, there is a task mapped to a particular device that is going to use it. In starPU, tasks are not mapped by the user to some device. So there's no point in executing data transfers to a particular device if you cannot ensure the task that is using this data is executed on this same device, right ? To push a bit further, explicit copies and transfers are
just due to the need for OpenCL to map everything to a device.
One stupid conversion for StarPU would be to ... ignore all
explicit copies and transfers, and it should work... Can you
give me a scenario where it doesn't ?? Or formulated in
another way, how do you make sure in the conversion
OpenCL->StarPU that the data you've just transfered will be
used by a task executed on the same device ?
You need to remember that StarPU is seen as single device. clCreateBuffer allocate memory in StarPU's virtual device memory and clEnqueueRead/WriteBuffer are used to copy between host memory and StarPU's virtual device memory. A buffer in StarPU's virtual memory is in fact a set of buffer instances (using my own terminology). There is at most one buffer instance per device per buffer. Each buffer instance can be in a different state (kind of MESI protocol). We don't want to transfer data to a particular physical device. However we need one instance (on any device) of the source/destination buffer to read from/write to. What we need is a way to select this buffer instance. Currently it is left to the *task* scheduler to select it (i.e. our copy task takes source or destination buffer as input or output). Using pinning, we could choose this buffer instance but we don't have as much information to make a good choice as StarPU (topology, current buffer instance states, etc.). Cheers Sylvain
- StarPU's execution/transfer traces are wrong
I meant that when we use computational tasks to perform data
transfers, StarPU has no way to detect this (obviously), thus
traces are quite wrong (missing data transfers).Report this issue then ... do you have a specific example? I mention this just to explain why the current SOCL implementation is bad. 2) Buffer map/unmap OpenCL can schedule buffer mapping/unmapping anytime in the command graph. StarPU can only map/unmap synchronously (i.e. the mapping command cannot have dependencies on other commands). Current implementation: SOCL uses a fake StarPU CPU computation task to schedule the map/unmap commands. The fake task has the buffer to map as an input to force data transfer in host memory and to make starpu_data_acquire (map command) non blocking. Isn't that what the starpu_data_acquire function does ? (you have an asynchronous function that does similar things, starpu_data_acquire_cb). If not, how does it differ from your needs ? - restricted to CPU worker - with only implicit data dependencies - detached What we need is: - no callback. Host code will test/wait returned event to execute something - explicit dependencies (depends on some events) - "not detached" (returns an event) We need the same thing for "unmap". Kernel compilation & scheduling OpenCL kernels may not be portable. StarPU assumes that every OpenCL kernel can be executed on any OpenCL device. Current implementation: we suppose that every OpenCL kernel can be executed on every OpenCL device, even if it's wrong. We are looking how to change the codelet interface so that we can express more constraints that with the current "where" field. For instance we would certainly add constraints on the available memory, or the availability of double precision, or specify that the task may only execute on a subset of workers. [..] What is left to do: 1) Manage data transfers from/to host memory and between buffers Scheduling of these commands is easily done with events/triggers. However performing data transfers correctly is still bogus. This implies modifications in the way StarPU manages data requests and data transfers. (cf "DataWizard" code) We could implement some starpu_data_cpy_{to,from}_interface functions which take a handle and copy its content into or from an interface provided by the application (that is not attached to a handle). Would something like that be useful to you ? int foo[1024]; struct vector_interface vector = {.nx = 1024, .ptr = foo, .elemsize = sizeof(int)}; starpu_data_cpy_to_interface(handle, &vector); Currently we: - Create a new data: pouet = starpu_data_variable_register(foo, 1024...) - Schedule one StarPU task with available kernels for CPU and OpenCL. -- This task has "pouet" and the original buffer as input/output -- CPU kernel performs memcpy -- OpenCL kernel performs clEnqueueRead/WriteBuffer With the new API we could: - Create a dummy task T that does nothing - Use starpu_data_cpy_interface in its callback to transfer data (blocking problem... that would lead you to starpu_data_cpy_to_interface_cb) - Execute another dummy task (associated to the returned event of this data transfer) to signal dependencies that this one completed Ideally, I'd like starpu_data_cpy_to_interface(handle, interface, int num_events, event*, event*) 2) Kernel compilation and execution 2.1) OpenCL compilers can be slow (NVIDIA...). We may choose not to compile every kernel for every device (what is currently done). 2.2) Some kernels may not be executed on some devices. Short term solution: we may try to compile kernels on devices. If compilation fails, we need a way to exclude failing devices from the list of devices on which the kernel may be scheduled. That would certainly be part of the per-codelet constraints that i mentioned earlier. 3.4) Thread-safety: check StarPU thread-safety. You mean: check OpenCL thread-safety safety :) We should detect what is non-thread safe in OpenCL and add locks around these methods in the OpenCL driver (we did that for the init phase already). 1) execute StarPU OpenCL codelets one at a time, even on different devices (coarse-grained) or 2) alias OpenCL API that is allowed in StarPU's OpenCL codelets and force users to use it (fine-grained) or 3) force StarPU codelet declaration in a totally declarative way Cheers, Sylvain Best, Cédric --Denis |
- [Starpu-devel] SOCL, Sylvain HENRY, 09/11/2010
- <Suite(s) possible(s)>
- Re: [Starpu-devel] SOCL, Cédric Augonnet, 14/11/2010
- Re: [Starpu-devel] SOCL, Sylvain HENRY, 15/11/2010
- Re: [Starpu-devel] SOCL, Denis Barthou, 17/11/2010
- Re: [Starpu-devel] SOCL, Sylvain HENRY, 17/11/2010
- Re: [Starpu-devel] SOCL, Denis Barthou, 18/11/2010
- Re: [Starpu-devel] SOCL, Sylvain HENRY, 18/11/2010
