Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Building StarPU on Windows
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Building StarPU on Windows
  • Date: Mon, 21 Feb 2011 19:06:02 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I see that StarPU 0.4 is available for Windows in binary form. However, it does not look like the OpenCL support is enabled in the library (from looking in the config.h and seeing #defines for OpenCL are commented out, unlike CUDA, for example). Is that indeed the case?
Also, the build instructions assume and require a Unix-like infrastructure (autotools, make, sh) and so the question is a) Which of those for Windows should be used e.g. Cygwin? Mingw? and b) has anyone gotten StarPU built and used with MSVC?
Regards,
George Russell
Haut de le page
