Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Documentation Patch for Building on Windows
- Date: Wed, 20 Apr 2011 16:37:32 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
A small patch is attached. Visual C++ 2010 seems to
work, there appears no need to mandate 2008. Cheers, George |
--- README.dev (revision 3576)
+++ README.dev (working copy)
@@ -23,15 +23,24 @@
http://www.open-mpi.org/projects/hwloc
-4. Install Microsoft Visual C++ 2008 Studio Express
+4. Install Microsoft Visual C++ 2008/2010 Studio Express
http://www.microsoft.com/express/Downloads
- On cygwin (and mingw), add in your path the following directories:
- export PATH=/cygdrive/c/Program Files/Microsoft Visual Studio
9.0/Common7/IDE:$PATH
9.0/VC/bin:$PATH
+ On cygwin (and mingw), add in your path the following directories.
+ (adjusting where necessary for the Installation location on 64 and 32bit
+ Windows versions)
+ Note that in mingw, the leading /cygdrive is not permitted.
+ On cygwin, with Visual C++ 2008 e.g.;
+ export PATH="/cygdrive/c/Program Files/Microsoft Visual Studio
9.0/Common7/IDE":$PATH
9.0/VC/bin":$PATH
+ On MingW, with Visual C++ 2010, e.g.;
+ export PATH="/c/Program Files (x86)/Microsoft Visual Studio
10.0/Common7/IDE":$PATH
10.0/VC/bin":$PATH
Try to call <lib.exe> and <link.exe> from MinGW, else no .def or .lib file
will be produced.
- [Starpu-devel] Documentation Patch for Building on Windows, George Russell, 20/04/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Documentation Patch for Building on Windows, Samuel Thibault, 20/04/2011
