Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: Usman Dastgeer <usman.dastgeer@liu.se>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Fwd: Re: StarPU OpenCL on Mac
- Date: Thu, 4 Aug 2011 13:54:36 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Nathalie Furmento, le Wed 27 Jul 2011 11:15:12 +0200, a écrit :
> I knew about this -framework OpenCL in Mac as I used it with other
> applications. The problem is when using it with StarPU. What I
> understood
> from your response is that configure does not need to detect OpenCL.
It does need to detect OpenCL, else OpenCL will get disabled throughout
all parts of StarPU. Nathalie, we should perhaps simply try to make
configure add "-framework OpenCL" to CFLAGS on macos?
In the meanwhile, Usman, you should be able to use something like:
CFLAGS="-framework OpenCL" ./configure
etc. to make not only the Makefiles, but also configure use the
-framework OpenCL option.
Samuel
- Re: [Starpu-devel] Fwd: Re: StarPU OpenCL on Mac, Samuel Thibault, 04/08/2011
