Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU: subgraph_repeat_regenerate.c
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] StarPU: subgraph_repeat_regenerate.c
  • Date: Thu, 8 Sep 2011 16:05:24 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I am frequently experiencing crashes with the 'subgraph_repeat_regenerate'
test of the StarPU test suite.
The crashes frequency is about 1 crash out of 5 runs with '--enable-debug'
enabled. Frequency is slightly higher without --enable-debug
The machine used is a regular node from the PlaFRIM machine without GPU (e.g.
a 'fourmi' node).
Module list:
1) tools/svn/1.6.11 6) compiler/gcc/4.6.0
2) lib/gmp/5.0.1 7) tools/autoconf/2.68
3) lib/mpfr/3.0.0 8) tools/automake/1.11.1
4) lib/mpc/0.8.2 9) tools/libtool/2.4
5) lib/libelf/0.8.13
Configure settings:
../trunk/configure --prefix=/home/aumage/SVN/StarPU/install
--with-fxt=/home/aumage/local/src/FxT/install --enable-gcc-extensions
--disable-cuda --enable-debug
Program output:
./subgraph_repeat_regenerate
pthread_mutex_lock : Invalid argument
Abandon (core dumped)
GDB output:
Core was generated by `./subgraph_repeat_regenerate'.
Program terminated with signal 6, Aborted.
#0 0x00007f445a2f7645 in raise () from /lib64/libc.so.6
(gdb) bt
#1 0x00007f445a2f8c33 in abort () from /lib64/libc.so.6
#2 0x00007f445a630764 in _starpu_submit_job (j=0x7f444c001350,
do_not_increment_nsubmitted=1) at ../../trunk/src/core/task.c:209
#3 0x00007f445a62fd0c in _starpu_handle_job_termination (j=0x7f444c001350,
job_is_already_locked=0) at ../../trunk/src/core/jobs.c:229
#4 0x00007f445a65e7cb in _starpu_cpu_worker (arg=0x7f445a874a40) at
../../trunk/src/drivers/cpu/driver_cpu.c:197
#5 0x00007f4459829070 in start_thread () from /lib64/libpthread.so.0
#6 0x00007f445a39810d in clone () from /lib64/libc.so.6
#7 0x0000000000000000 in ?? ()
Note: every coredump I got shows the same backtrace with the location of the
bug at task.c:209
Olivier
Haut de le page
