Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Introducing the GNU C Extensions
- Date: Fri, 09 Sep 2011 14:12:55 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
I am trying with the current SVN revision. Here how far i got: $ gcc --version gcc (Debian 4.6.1-4) 4.6.1 Copyright (C) 2011 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. $ ../configure --enable-gcc-extensions configure: error: This compiler lacks GCC plug-in support. This contradicts README which reads "Plug-ins are supported starting from GCC 4.5." However, i am able to configure using CC=/usr/lib/gcc-snapshot/bin/gcc. I then have to patch gcc-plugin/src/starpu.c and gcc-plugin/src/c-expr.y as the include files c-common.h and c-pragma.h are available in the directory c-family. -#include <c-common.h> -#include <c-pragma.h> +#include <c-family/c-common.h> +#include <c-family/c-pragma.h> make fails then with the following error: make[2]: Entering directory `/net/inria/home/nfurmento/work/starpu/trunk/build/gcc-plugin/examples' /usr/lib/gcc-snapshot/bin/gcc -DHAVE_CONFIG_H -I. -I../../../gcc-plugin/examples -I../../src/common -I../../include -I../../gcc-plugin/src -I../../../include -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -I/usr/local/cuda/include -D_GNU_SOURCE -fplugin="../../gcc-plugin/src/.libs/starpu.so" -Wall -g -O2 -O3 -gdwarf-2 -g3 -MT matrix-mult.o -MD -MP -MF .deps/matrix-mult.Tpo -c -o matrix-mult.o ../../../gcc-plugin/examples/matrix-mult.c cc1: error: cannot load plugin ../../gcc-plugin/src/.libs/starpu.so ../../gcc-plugin/src/.libs/starpu.so: undefined symbol: cgraph_mark_needed_node The file gcc-plugin/src/.libs/starpu.so exists, but i could not find which library defines cgraph_mark_needed_node Thanks for any help, Nathalie On 08/09/2011 16:22, Ludovic Courtès wrote: 87aaafktat.fsf@inria.fr">Hello, As you may have noticed, trunk now includes a GCC plug-in, which gets built when configuring StarPU with ‘--enable-gcc-extensions’ (see ‘gcc-plugin/README’ for details.) The GCC plug-in extends the GNU C language with annotations and constructs that aim to make it easier and less error-prone to write StarPU code. For instance, tasks/codelets are declared and defined like standard C functions, only with an annotation; invoking a task is like calling a regular C function. Several pragmas wrap operations on data items, synchronization, etc. They support a more concise writing style and allow static checks to performed. The manual contains the beginning of a documentation (info "(starpu) C Extensions"). Additional details can be found in the test suite and examples. This is work in progress and the extensions only cover a fraction of StarPU’s API, but I would very much like feedback on the approach, and testing. I’m in particular interested in comments on the mapping of StarPU features to language constructs, and their usability. Thanks! Ludo’._______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] Introducing the GNU C Extensions, Ludovic Courtès, 08/09/2011
- Re: [Starpu-devel] Introducing the GNU C Extensions, Nathalie Furmento, 09/09/2011
