Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Integrating MPI and starpu
- Date: Mon, 12 Sep 2011 12:10:18 +0530
- Bcc:
- Importance: Normal
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
- Sensitivity:
Dear Sir,
I am trying to experiment with starpu with MPI. And am stuck with the following issues.
1. How to run starpu so that it "sees" CPU resources of a machine with different IP address.
In my experimental setup I run MPI over LAN using MPICH. How do I configure starpu so
that it "sees" my machines.
For example
I have MPICH installed over 2 machines with ip addresses x and y.
Now if I install starpu (configure, make and make install) on both my machines separately,
is it okay or do i need to do something else.
As these machines are dual core, I was successful in running the stencil5 example using
MPI using both the cores on the same machine.
2. When I install Starpu, during configure step, it shows that number of cpus is 16.
The processor is i3-530, which is a dual core processor and each core has 2 hyperthreads.
Thus the resource is actually at max 4. Can u please explain why the number 16 is reported.
Has something gone wrong during the installation of starpu?
For example
With Thanks and Regards
Mrs Rakhi Hemani
Senior Lecturer
CS/IT, JIIT NOIDA,
INDIA.
Mrs Rakhi Hemani
Senior Lecturer
CS/IT, JIIT NOIDA,
INDIA.
x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x—x---x---x---x---x---x---x---x---x---x---x---x---x---x
Disclaimer: This message and any files transmitted with it are not necessarily the views of JIIT. This message is confidential and intended solely for the use of the individual or entity to whom it is addressed. If you are not the intended recipient or agent responsible for delivering to the intended recipient, you are hereby notified that any use, review, dissemination, distribution or copying is strictly prohibited. The Institute is not responsible for the Viruses, Trojans, Spy wares present in attachments, if any, and it accepts no liability for any damage caused by the same.
- [Starpu-devel] Integrating MPI and starpu, rakhi.hemani, 12/09/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Integrating MPI and starpu, Samuel Thibault, 13/09/2011
