Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Fwd: [Starpu-commits] r4125 - trunk
- Date: Wed, 21 Sep 2011 13:21:24 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
By reverting the commits, when bison is not installed on the
machine, configure will succeed but make will fail. Is it what we want? Regards, Nathalie -------- Original Message -------- Subject: [Starpu-commits] r4125 - trunk Date: Tue, 20 Sep 2011 17:17:20 +0200 (CEST) From: lcourtes@users.gforge.inria.fr To: starpu-commits@lists.gforge.inria.fr Author: lcourtes Date: 2011-09-20 17:17:19 +0200 (Tue, 20 Sep 2011) New Revision: 4125 Modified: trunk/configure.ac Log: configure: Don't abort when Bison isn't there. This reverts r4122 and r4116. Modified: trunk/configure.ac =================================================================== --- trunk/configure.ac 2011-09-20 14:51:08 UTC (rev 4124) +++ trunk/configure.ac 2011-09-20 15:17:19 UTC (rev 4125) @@ -1121,14 +1121,7 @@ # Bison is used to generate the C _expression_ parser. The generated # parser is part of the distribution, though. -AC_PATH_PROG([YACC], [yacc]) -if test "x$YACC" = "x"; then - AC_MSG_ERROR([Compiler yacc not available]) -fi -AC_PATH_PROG([BISON], [bison]) -if test "x$BISON" = "x"; then - AC_MSG_ERROR([Compiler bison not available]) -fi +AC_PROG_YACC AM_CONDITIONAL([BUILD_GCC_PLUGIN], [test "x$build_gcc_plugin" = "xyes"]) AM_CONDITIONAL([HAVE_GUILE], [test "x$GUILE" != "x"]) _______________________________________________ Starpu-commits mailing list Starpu-commits@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-commits |
- [Starpu-devel] Fwd: [Starpu-commits] r4125 - trunk, Nathalie Furmento, 21/09/2011
- Re: [Starpu-devel] Fwd: [Starpu-commits] r4125 - trunk, Ludovic Courtès, 22/09/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Fwd: [Starpu-commits] r4125 - trunk, Samuel Thibault, 21/09/2011
