Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU CUDA problem
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU CUDA problem
  • Date: Tue, 27 Sep 2011 13:48:13 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
The format of the perfmodels changed in revision 4127. You should try to remove the old perfmodels (they are in $HOME/.starpu/sampling/codelets/).
Cyril.
On 09/27/2011 12:04 PM, Usman Dastgeer wrote:
Hello,
With StarPU revision # 4156, I have some problem with using CUDA backend. I
have attached the log file. The problem occurs even when running given starpu
examples (vector_scal, block etc.)
Here is the output for "vector_scal" example
BEFORE: First element was 1.000000
BEFORE: Last element was 2048.000000
[starpu][load_sched_policy] Use eager scheduler (greedy policy)
[starpu][_starpu_launch_drivers] initialising worker 0
[starpu][_starpu_cuda_worker] cuda (Tesla M2050) dev id 0 thread is ready to
run on CPU 0 !
[starpu][_starpu_load_history_based_model] Opening performance model file
/home/usmda/.starpu/sampling//codelets/vector_scale.fermi for model
vector_scale ... [starpu][_starpu_load_history_based_model] File exists
[starpu][parse_model_file] Parsing 1 CPUs
[starpu][parse_model_file] Parsing 0 CUDA devices
[starpu][parse_model_file] Parsing 0 OpenCL devices
[starpu][parse_model_file] Parsing 0 Gordon devices
/home/usmda/.starpu/sampling//codelets/vector_scale_power.fermi for model
vector_scale_power ... [starpu][_starpu_load_history_based_model] File exists
[starpu][parse_model_file] Parsing 0 CPUs
oops in copy_cuda_async_common ... invalid argument
vector_scal: drivers/cuda/driver_cuda.c:384: starpu_cuda_report_error:
Assertion `0' failed.
Aborted
and for "block" example
run on CPU 0 !
No worker may execute this task
block: drivers/cuda/driver_cuda.c:384: starpu_cuda_report_error: Assertion
`0' failed.
Aborted
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
