Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Andrey Baranov <abaranov.ua@gmail.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] [Starpu-bugs] starpu tests failed
- Date: Fri, 14 Oct 2011 10:01:47 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Andrey, The Cuda driver code fails if the number of available devices is greater than the value given to --enable-maxcudadev. That has been fixed in the current version of StarPU (in the subversion trunk). We are planning to have a new release of StarPU in the near future. In the meantime, you should instead use the following configure command: ./configure --enable-nmaxcpus=1 --with-cuda-dir=/usr/local/cuda/ --disable-opencl and set the variable STARPU_NCUDA=1 before executing any StarPU application, e.g STARPU_NCUDA=1 make check Regards, Nathalie On 13/10/2011 21:46, Andrey Baranov wrote: Hello,
I was trying to install StarPu 0.9.1 on my system and got
errors on checking phase and message that i should report to
this mail address
19 of 20 tests failed
Please report to starpu-bugs@lists.gforge.inria.fr
Log is attached to this message.
For installation following configuration was used:
./configure --enable-nmaxcpus=1 --enable-maxcudadev=1
Looking forward for you help.
Thank you,
Andrey Baranov
_______________________________________________ Starpu-bugs mailing list Starpu-bugs@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-bugs |
- Re: [Starpu-devel] [Starpu-bugs] starpu tests failed, Nathalie Furmento, 14/10/2011
