Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Andrey Baranov <abaranov.ua@gmail.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] [Starpu-bugs] Model debug compile problem
- Date: Wed, 19 Oct 2011 11:36:04 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear Andrey, Thanks for reporting the bug. It has been fixed in the Subversion server, and will be available in the next nightly release. In the meantime, you can just use your modified local version. Regards, Nathalie On 19/10/2011 01:03, Andrey Baranov wrote: Hello, I was installing StarPu nightly latest with
option --enable-model-debug and got error message:
core/perfmodel/perfmodel_history.c:988: warning: initialization from incompatible pointer type core/perfmodel/perfmodel_history.c:990: error: dereferencing pointer to incomplete type core/perfmodel/perfmodel_history.c:991: error: dereferencing pointer to incomplete type core/perfmodel/perfmodel_history.c:992: error: dereferencing pointer to incomplete type Seems like this line is wrong:
struct starpu_data_handle_t *handle = task->buffers[i].handle; This fix works fine for me:
starpu_data_handle handle = task->buffers[i].handle; Thank you, Andrey Baranov _______________________________________________ Starpu-bugs mailing list Starpu-bugs@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-bugs |
- Re: [Starpu-devel] [Starpu-bugs] Model debug compile problem, Nathalie Furmento, 19/10/2011
