Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] How to add own example code to build using Starpu
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, ASD D <ajitsdeshpande@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] How to add own example code to build using Starpu
  • Date: Tue, 1 Nov 2011 22:29:19 +0000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks Samuel. Will try modifying  the Makefile.am to add my example.
On Tue, Nov 1, 2011 at 10:15 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASD D, le Tue 01 Nov 2011 16:16:03 +0100, a écrit :
> But after make, when i checked the folder basic_examples , I do not see any
> executable for my exampled code there.  Why so?
Because automake maintainers does not want to implement wildcards, so
you have to add explicitly to examples/Makefile.am before running
autogen.sh
> 1] What process is to be followed to build ones own opencl code udner starpu?
There is nothing really particular. Once installed, you can use StarPU's
.pc file, as documented in chapter 3 (Using StarPU). The path to the .cl
kernel files can be relative to the current directory, or absolute, as
fits you best.
Samuel
Haut de le page
