Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] How to use a latest version of starpu library
- Date: Tue, 06 Dec 2011 15:47:43 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, If your build system uses pkg-config, you need to configure it to find your custom version of StarPU: export PKG_CONFIG_PATH=$HOME/lib/pkgconfig:$PKG_CONFIG_PATH Then set LD_LIBRARY_PATH to use your custom version of StarPU: export LD_LIBRARY_PATH=$HOME/lib:$LD_LIBRARY_PATH Cheers Sylvain Le 05/12/2011 15:02, ASUDE ASUDE a écrit : Hi, Might not be related to starpu runtime per se, but - How do I make my build system to use the newer version of this starpu shared library present in a different folder than the system default of /usr/local/lib? I have an app I am building with starpu using ./configure and make. By default the app links/uses the starpu shared library present in the folder /usr/local/lib/libstarpu.so.0, but I have downloaded the latest source for this Starpu and installed it in my home $HOME/lib/. I tried using this new library as an input to the configure command as below and even removed the /usr/local/lib from my LD_LIBRARY_PATH, but still when I check with ldd, it seems to show the executable is built with the old version of the library in /usr/local/lib. ./configure LDFLAGS="-l:$HOME/lib/libstarpu.so.0"
How do I make my build system to use the newer version of this starpu shared library present in a different folder than the system default of /usr/local/lib? Do I need to modify anything in my build related makefiles, configure files?
-AD _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] How to use a latest version of starpu library, ASUDE ASUDE, 05/12/2011
- Re: [Starpu-devel] How to use a latest version of starpu library, Sylvain HENRY, 06/12/2011
- Re: [Starpu-devel] How to use a latest version of starpu library, Nathalie Furmento, 07/12/2011
