Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] initialised SCRATCH buffer
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Xavier Lacoste <xavier.lacoste@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] initialised SCRATCH buffer
  • Date: Thu, 5 Jan 2012 10:58:05 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Xavier Lacoste, le Thu 05 Jan 2012 10:33:44 +0100, a écrit :
> I would like StarPU to build the array using a function of the codelet
> arguments at the same time he moves data to the executing device.
Do you mean that the initialization value needs to depend on the
parameters of the task? Can't the codelet do the initialization itself
in such case, since it'll have to be done for each task anyway?
What we were planning to implement was only a way to initialize the
scratch buffer when it is allocated, i.e. once for good and not once for
each task (unless the buffer gets evicted due to low memory conditions).
Samuel
Haut de le page
