Archives de la liste
- To: <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] StarPU make check failure
- Date: Thu, 2 Feb 2012 09:52:32 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, below is an excerpt from make check on starpu-1.0.0rc1. It suggests I should let you know.
Thanks,
Jonathan.
PASS: core/declare_deps_after_submission
PASS: core/declare_deps_after_submission_synchronous
#tasks : 65536
[error] test is blocked since 600 seconds. Mark it as failed
FAIL: core/get_current_task
PASS: core/starpu_worker_exists
Token: 42
PASS: datawizard/acquire_cb
1 of 92 tests failed
(2 tests were not run)
Please report to starpu-devel@lists.gforge.inria.fr
Scanned by iCritical.
- [Starpu-devel] StarPU make check failure, Jonathan Hogg, 02/02/2012
- Re: [Starpu-devel] StarPU make check failure, Ludovic Courtès, 02/02/2012
- Re: [Starpu-devel] StarPU make check failure, Jonathan Hogg, 02/02/2012
- Re: [Starpu-devel] StarPU make check failure, Nathalie Furmento, 02/02/2012
