Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU on macos ?
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Pierre RAMET <ramet@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU on macos ?
  • Date: Tue, 07 Feb 2012 15:55:05 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Pierre,
tests/datawizard/reclaim is trying to allocate 16 buffers of 64 Mb on the machine, that could explain why your machine is down.
You can either try to re-configure StarPU with the option --enable-slow-machine (to be given to configure), that will reduce the size of the buffers to 64 kb. You can also try to install hwloc first, and re-install StarPU, that will reduce the number of buffers being allocated.
Cheers,
Nathalie
On 07/02/2012 15:37, Pierre RAMET wrote:
Hello,
While I was waiting to add an old gcc compiler 4.4 on my server (4.6 is
known to be not compatible with CUDA...), I have try to install StarPU
on my laptop (macbook air with Lion)...
No problem during the compilation of the trunk version (svn 5526), but
during the "make check", it fails on :
PASS: datawizard/dining_philosophers
5042 = 42 + 5000
10042 = 5042 + 5000
PASS: datawizard/manual_reduction
PASS: datawizard/readers_and_writers
PASS: datawizard/unpartition
PASS: datawizard/user_interaction_implicit
Allocate 16 buffers and create 1000 tasks
^Cmake[4]: *** [check-TESTS] Interrupt: 2
make[3]: *** [check-am] Interrupt: 2
make[2]: *** [check-recursive] Interrupt: 2
make[1]: *** [check] Interrupt: 2
make: *** [check-recursive] Interrupt: 2
tthor-2:trunk ramet$ ps -ef | grep reclaim
501 29764 1 0 3:19 ttys000 2:32.67
/Users/ramet/Work/starpu/trunk/tests/datawizard/.libs/reclaim
501 29839 2234 0 3:21 ttys000 0:00.00 grep reclaim
tthor-2:trunk ramet$ kill -9 29764
I need to stop the "reclaim" process that use 150% of the cpus but never
end ...
There is no hurry :)
Pierre.
PS: Xavier notices a regression in StarPU about performances between
release 0.9 et 1rc ...
PaStiX-over-StarPU with "audi" matrix, multicore kernels only :
StarPU 0.9 : about 200s with 8 cores
StarPU 1rc : more than 1000s with the same 8 cores
Haut de le page
