Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Usman Dastgeer <usman.dastgeer@liu.se>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] OpenMP example
- Date: Tue, 14 Feb 2012 11:58:20 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Samuel Thibault, le Tue 14 Feb 2012 11:55:28 +0100, a écrit :
> Usman Dastgeer, le Tue 14 Feb 2012 11:07:19 +0100, a écrit :
> > I tried executing OpenMP example (examples/openmp/vector_scal) using gcc
> > as
> > suggested:
> > gcc -fopenmp vector_scal.c -o vector_scal $(pkg-config --cflags
> > libstarpu) $
> > (pkg-config --libs libstarpu)
> > However it still executes the parallel task with 1 CPU and other 15 CPU
> > workers
> > are not used. What am I missing?
> Are you running it with the pheft scheduler? The example makes it the
> default by itself only from revision 5315.
Also, it needs to be run several times to calibrate the performance
models (and even then, it might just prefer to run with 1 cpu, which is
faster than several).
Samuel
- Re: [Starpu-devel] OpenMP example, Samuel Thibault, 14/02/2012
- Re: [Starpu-devel] OpenMP example, Usman Dastgeer, 14/02/2012
