Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU Question regarding gated connections
Archives de la liste
Chronologique Discussions
  • To: "Sidelnik, Albert" <asideln2@illinois.edu>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU Question regarding gated connections
  • Date: Thu, 23 Feb 2012 20:46:56 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Please send mails to the starpu-devel mailing list, that's where you
will get an answer fastest and most reliably :)
Sidelnik, Albert, le Thu 23 Feb 2012 20:00:38 +0100, a écrit :
> Does StarPU have support for "gated" functionality between the
> different incoming/outgoing edges from a codelet. For example,
> given a node that has two incoming edges (dependences), is there a
> way to cause the codelet to execute when only one of the incoming
> edges resolves rather than executing when both are resolved. Intel
> TBB flow graphs have this support, and I was wondering if there
> is something similar in StarPU. If so, can you point me to some
> examples/documentation where this used?
Ah, interesting idea. I believe we can make the tags do that easily.
I'll do it.
Samuel
Haut de le page
