Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Patch request for the multiformat interface
- Date: Wed, 29 Feb 2012 12:16:00 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Nathalie Furmento, le Wed 29 Feb 2012 11:42:48 +0100, a écrit :
> Index: include/starpu_data_interfaces.h
> --- include/starpu_data_interfaces.h (r??vision 5892)
> +++ include/starpu_data_interfaces.h (copie de travail)
> @@ -350,27 +350,19 @@
> struct starpu_multiformat_data_interface_ops
> size_t cpu_elemsize;
> -#ifdef STARPU_USE_OPENCL
> size_t opencl_elemsize;
> struct starpu_codelet *cpu_to_opencl_cl;
> struct starpu_codelet *opencl_to_cpu_cl;
> -#endif
> -#ifdef STARPU_USE_CUDA
> size_t cuda_elemsize;
> struct starpu_codelet *cpu_to_cuda_cl;
> struct starpu_codelet *cuda_to_cpu_cl;
> -#endif
> struct starpu_multiformat_interface
> void *cpu_ptr;
> void *cuda_ptr;
> -#endif
> void *opencl_ptr;
> -#endif
> uint32_t nx;
> struct starpu_multiformat_data_interface_ops *ops;
> @@ -378,15 +370,8 @@
> void starpu_multiformat_data_register(starpu_data_handle_t *handle,
> uint32_t home_node, void *ptr, uint32_t nobjects, struct
> starpu_multiformat_data_interface_ops *format_ops);
> #define STARPU_MULTIFORMAT_GET_CPU_PTR(interface) (((struct
> starpu_multiformat_interface *)(interface))->cpu_ptr)
> #define STARPU_MULTIFORMAT_GET_CUDA_PTR(interface) (((struct
> starpu_multiformat_interface *)(interface))->cuda_ptr)
> -#endif
> #define STARPU_MULTIFORMAT_GET_OPENCL_PTR(interface) (((struct
> starpu_multiformat_interface *)(interface))->opencl_ptr)
> -#endif
> #define STARPU_MULTIFORMAT_GET_NX(interface) (((struct
> starpu_multiformat_interface *)(interface))->nx)
> enum starpu_data_interface_id
> starpu_handle_get_interface_id(starpu_data_handle_t handle);
That part, for sure, is fine, the interface shouldn't depend on whether
CUDA/OpenCL is enabled.
The rest, not necessarily:
> Index: src/core/sched_policy.c
> --- src/core/sched_policy.c (r??vision 5892)
> +++ src/core/sched_policy.c (copie de travail)
> @@ -357,31 +357,23 @@
> case STARPU_CPU_RAM:
> STARPU_ASSERT(0);
> case STARPU_CUDA_RAM:
> conversion_task->cl = mf_ops->cuda_to_cpu_cl;
> break;
> -#endif
> case STARPU_OPENCL_RAM:
> conversion_task->cl = mf_ops->opencl_to_cpu_cl;
> break;
> -#endif
> default:
> fprintf(stderr, "Oops : %u\n", handle->mf_node);
> STARPU_ASSERT(0);
> break;
> conversion_task->cl = mf_ops->cpu_to_cuda_cl;
> break;
> -#endif
> conversion_task->cl = mf_ops->cpu_to_opencl_cl;
> break;
> -#endif
> case STARPU_SPU_LS: /* Not supported */
> default:
> STARPU_ASSERT(0);
For instance there it's better to error if we don't have CUDA/OpenCL but
somehow the manage to find such a node, and thus keep the ifdefs.
> Index: src/datawizard/interfaces/multiformat_interface.c
> --- src/datawizard/interfaces/multiformat_interface.c (r??vision 5892)
> +++ src/datawizard/interfaces/multiformat_interface.c (copie de travail)
> @@ -174,24 +174,16 @@
> uint32_t nobjects,
> struct
> _starpu_codelet_check_deprecated_fields(format_ops->cpu_to_opencl_cl);
> _starpu_codelet_check_deprecated_fields(format_ops->opencl_to_cpu_cl);
> -#endif
> _starpu_codelet_check_deprecated_fields(format_ops->cpu_to_cuda_cl);
> _starpu_codelet_check_deprecated_fields(format_ops->cuda_to_cpu_cl);
> -#endif
These should indeed probably be always enabled, to always do the correction.
> struct starpu_multiformat_interface multiformat =
> .cpu_ptr = ptr,
> .cuda_ptr = NULL,
> -#endif
> -#ifdef STARPu_USE_OPENCL
> .opencl_ptr = NULL,
> -#endif
> .nx = nobjects,
> .ops = format_ops
That's fine too, it'd be set to NULL anyway.
> @@ -211,12 +203,8 @@
> return ((multiformat_a->nx == multiformat_b->nx)
> && (multiformat_a->ops->cpu_elemsize ==
> multiformat_b->ops->cpu_elemsize)
> && (multiformat_a->ops->cuda_elemsize ==
> multiformat_b->ops->cuda_elemsize)
> -#endif
> && (multiformat_a->ops->opencl_elemsize ==
> multiformat_b->ops->opencl_elemsize)
> -#endif
These should probably not always be enabled, because their content might
be undefined, thus keep the ifdefs.
> Index: src/datawizard/interfaces/data_interface.c
> --- src/datawizard/interfaces/data_interface.c (r??vision 5895)
> +++ src/datawizard/interfaces/data_interface.c (copie de travail)
> @@ -482,16 +482,12 @@
> mf_ops = (struct
> starpu_multiformat_data_interface_ops *)
> handle->ops->get_mf_ops(format_interface);
> switch (node_kind)
> break;
> -#endif
> break;
> -#endif
> case STARPU_CPU_RAM: /* Impossible ! */
> default:
It's better to error out, so keep the ifdefs.
Samuel
- [Starpu-devel] Patch request for the multiformat interface, Nathalie Furmento, 29/02/2012
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Patch request for the multiformat interface, Samuel Thibault, 29/02/2012
