Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: uma boregowda <umaboregowda@gmail.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] (sans objet)
- Date: Fri, 16 Mar 2012 11:14:32 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Uma, I am not sure i understand exactly your inquiry. When compiling StarPU, the applications indeed produce a libtool wrapper script and the executable itself. This is specific to libtool and is certainly not required to execute a StarPU application. if you add your application to the existing examples directory, and modify Makefile.am accordingly, compiling it will provide the wrapper script. But if you compile your application in your own directory by using pkg-config as explained in the documentation, you will then produce a executable which does not need the libtool wrapper script. Cheers, Nathalie On 16/03/2012 03:11, uma boregowda wrote: Hi, In example folder, there are wrapper scrpits for many programs. Why wrapper scripts are not given to few programs ? May i know, why? Now if i write a new program, how to write wrapper script, for it to be compiled and executed. with best wishes uma _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- Re: [Starpu-devel] (sans objet), (suite)
- Message indisponible
- Re: [Starpu-devel] (sans objet), Ludovic Courtès, 15/03/2012
- Re: [Starpu-devel] (sans objet), uma boregowda, 15/03/2012
- Re: [Starpu-devel] (sans objet), uma boregowda, 16/03/2012
- [Starpu-devel] Fwd: (sans objet), uma boregowda, 15/03/2012
- [Starpu-devel] (sans objet), uma boregowda, 16/03/2012
- Re: [Starpu-devel] (sans objet), Nathalie Furmento, 16/03/2012
- Re: [Starpu-devel] (sans objet), uma boregowda, 18/03/2012
- Re: [Starpu-devel] (sans objet), Nathalie Furmento, 18/03/2012
- Re: [Starpu-devel] (sans objet), Cedric Augonnet, 19/03/2012
