Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: "Sidelnik, Albert" <asideln2@illinois.edu>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Nested codelets?
- Date: Wed, 18 Apr 2012 10:49:35 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Sidelnik, Albert, le Wed 18 Apr 2012 08:31:18 +0200, a écrit :
> I'm working on a compiler to generate StarPU code directly from a
> high-level parallel language. In trying to support nested parallelism from
> this language, I'm wondering whether StarPU supports the ability to spawn
> new codelets directly from within a currently executing codelet (assume
> execution is only on a CPU).
Yes, you can spawn codelets. Even for the GPU case, since you have a
host part where you can run things on the CPU.
> If so, what are the main restrictions on which routines can or cannot be
> called?
They have to be non-blocking. You can not wait for a task for instance:
it might have been assigned to the very CPU you are making wait, and
thus never complete.
> For example, can I invoke starpu_tag_notify_from_apps() from a codelet in
> order to control the execution a successor codelet? I have not seen any
> examples in the StarPU release that show how to do this.
Yes, you can. Simply call it.
> Also, maybe I might have missed this in the StarPU manual, but is there a
> specific ordering on when callback functions are called for a completed
> codelet? Can I assume that the callback will be invoked before it's
> dependences are resolved?
No, we notify dependencies before calling the callback (and that was
missing in the doc indeed, thanks). That was made to be able to e.g.
free a dependency tag between them.
Samuel
- [Starpu-devel] Nested codelets?, Sidelnik, Albert, 18/04/2012
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Nested codelets?, Samuel Thibault, 18/04/2012
