Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] bad performance scaling behavior of cholesky decomposition
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] bad performance scaling behavior of cholesky decomposition
  • Date: Fri, 11 May 2012 16:49:41 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Runtime Group and StarPU users,
I've successfully installed StarPU 1.0.0 on our GPU cluster (a 24 nodes
cluster + a slightly beefier frontend, each node is equipped with 2
Xeon CPU X5650@2.67GHz, 2 Tesla S2050 GPU and 48 GB of RAM).
In order to compile the StarPU library along with the examples and the
tests suite I've used the gcc 4.4.3 compiler, the CUDA4.1 toolkit,
mkl10.3 library. I've got hwloc, cuda, fxt enabled as the build
configuration shows:
StarPU 1.0 build configuration:
Maximum number of CPUs: 64
Maximum number of CUDA devices: 4
Maximum number of OpenCL devices: 8
Maximum number of memory nodes: 5
Maximum number of task buffers: 8
GPU-GPU transfers: yes
Allocation cache: no
Magma enabled: no
BLAS library: mkl
hwloc: yes
FxT trace enabled: yes
StarPU-Top: no
StarPU Extensions:
MPI enabled: yes
MPI test suite: 0
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
SOCL enabled: no
The build that I have obtained passes all the sanity checks (leaving
alone a couple of tests marked "SKIPPED" by the test script).
I've able to run the Cholesky decomposition example (cholesky_tile_tag
binary file) given in the StarPU without any problem and I've got a
reasonable performance profile when using 6 CPU cores with a single GPU
which is comparable with what is reported in various StarPU related
publications.
Problems arise when I try to run the Cholesky decomposition over 12 CPU
cores and 2 Tesla GPU. I was expecting a nearly linear scaling whilst
the 12core + 2GPU calculation takes about
the same amount of time of the 6 cores + 1GPU calculation. Hence, no
performance scaling at all!
By taking a look to the Pajé trace for the two calculation one finds
that in the single GPU calculation all the workers are busy during the
calculation with a relatively small amount of blocked state.
On the other hand, the 12 core + 2 GPU calculation pajé trace shows
that only one of the 2 GPU is busy, while the other one is mostly in a
blocked state. Furthermore, the CPU cores are basically
in the "blocked state" during the whole calculation.
Usually I launch the cholesky_tile_tag with the environment:
export STARPU_SCHED=dmda ( or dmdar, heft, ws)
export STARPU_GENERATE_TRACE=1
export STARPU_HOSTNAME=ella
and -size from 4096 up to 64000
Please, find attached to this mail two trace file that show the behavior
I described above: the 1.6.1 file contains the 6 cpu + 1gpu case, while
the 1.12.2 the 12 cpu +2 gpu case.
Clearly, I'm doing something wrong, but I can't figure out what could
be. Any help/suggestion will be greatly appreciated.
With best regards,
Mario
%EventDef PajeDefineContainerType 1
% Alias string
% ContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEventType 2
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineStateType 3
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineVariableType 4
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineLinkType 5
% Alias string
% SourceContainerType string
% DestContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEntityValue 6
% Alias string
% EntityType string
% Name string
% Color color
%EndEventDef
%EventDef PajeCreateContainer 7
% Time date
% Alias string
% Type string
% Container string
% Name string
%EndEventDef
%EventDef PajeDestroyContainer 8
% Time date
% Name string
% Type string
%EndEventDef
%EventDef PajeNewEvent 9
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajeSetState 10
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajePushState 11
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajePopState 12
% Time date
% Type string
% Container string
%EndEventDef
%EventDef PajeSetVariable 13
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeAddVariable 14
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeSubVariable 15
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeStartLink 18
% Time date
% Type string
% Container string
% Value string
% SourceContainer string
% Key string
%EndEventDef
%EventDef PajeEndLink 19
% Time date
% Type string
% Container string
% Value string
% DestContainer string
% Key string
%EndEventDef
1 MPIP 0 "MPI Program"
1 P MPIP "Program"
1 Mn P "Memory Node"
1 T Mn "Worker"
1 Sc P "Scheduler State"
2 event T "event type"
3 S T "Thread State"
3 MS Mn "Memory Node State"
4 ntask Sc "Number of tasks"
4 bw Mn "Bandwidth"
6 I S Initializing "0.0 .7 1.0"
6 D S Deinitializing "0.0 .1 .7"
6 Fi S FetchingInput "1.0 .1 1.0"
6 Po S PushingOutput "0.1 1.0 1.0"
6 C S Callback ".0 .3 .8"
6 B S Blocked ".9 .1 .0"
6 Sl S Sleeping ".9 .1 .0"
6 P S Progressing ".4 .1 .6"
6 A MS Allocating ".4 .1 .0"
6 Ar MS AllocatingReuse ".1 .1 .8"
6 R MS Reclaiming ".0 .1 .4"
6 Co MS DriverCopy ".3 .5 .1"
6 CoA MS DriverCopyAsync ".1 .3 .1"
6 No MS Nothing ".0 .0 .0"
5 MPIL MPIP P P MPIL
5 L P Mn Mn L
7 0.000000 MPIroot MPIP 0 root
7 0.000000 p P MPIroot program
7 0.000000 sched Sc p scheduler
13 0.000000 ntask sched 0.0
7 0.000000 0 Mn p MEMNODE0
13 0.000000 bw MEMNODE0 0.0
7 0.000000 1 Mn p MEMNODE1
13 0.000000 bw MEMNODE1 0.0
7 0.000000 2 Mn p MEMNODE2
13 0.000000 bw MEMNODE2 0.0
7 0.000000 679 T MEMNODE1 679
10 0.000000 S 679 I
7 0.000000 680 T MEMNODE2 680
10 0.000000 S 680 I
7 0.000000 681 T MEMNODE0 681
10 0.000000 S 681 I
7 0.000000 682 T MEMNODE0 682
10 0.000000 S 682 I
7 0.000000 683 T MEMNODE0 683
10 0.000000 S 683 I
10 0.000000 S 681 B
10 0.000000 S 682 B
7 0.000000 684 T MEMNODE0 684
10 0.000000 S 684 I
10 0.000000 S 683 B
10 0.000000 S 684 B
7 0.000000 685 T MEMNODE0 685
10 0.000000 S 685 I
10 0.000000 S 685 B
7 0.000000 686 T MEMNODE0 686
10 0.000000 S 686 I
10 0.000000 S 686 B
7 0.000000 688 T MEMNODE0 688
10 0.000000 S 688 I
10 0.000000 S 688 B
7 0.000000 689 T MEMNODE0 689
10 0.000000 S 689 I
7 0.000000 690 T MEMNODE0 690
10 0.000000 S 690 I
10 0.000000 S 689 B
10 0.000000 S 690 B
7 0.000000 687 T MEMNODE0 687
10 0.000000 S 687 I
10 0.000000 S 687 B
10 608.926025 S 680 B
10 1211.709961 S 679 B
10 1211.828979 S 679 Fi
10 1211.833008 S 680 Fi
10 1211.833008 S 679 B
10 1211.833984 S 680 B
6 execute_on_all_wrapper S execute_on_all_wrapper "0.000000
0.600000 0.400000"
10 1211.843994 S 679 execute_on_all_wrapper
10 1211.845947 S 680 execute_on_all_wrapper
10 1216.366943 S 64 B
10 1216.376953 S 679 Po
10 1216.378052 S 679 B
10 1216.661011 S 65 B
10 1216.662964 S 680 Po
10 1216.662964 S 680 B
10 19413.996094 MS MEMNODE2 A
13 19414.193359 ntask sched 1.000000
10 19414.455078 MS MEMNODE2 No
10 19414.462891 MS MEMNODE2 Co
18 19414.462891 L p 4000000 MEMNODE0 com_1
10 19414.482422 MS MEMNODE2 CoA
10 19415.890625 MS MEMNODE2 No
19 19415.890625 L p 2273874960 MEMNODE2 com_2273874768
13 19415.906250 ntask sched 0.000000
10 19415.910156 S 680 Fi
10 19416.101562 MS MEMNODE2 No
19 19416.101562 L p 4000000 MEMNODE2 com_1
10 19416.103516 S 680 B
6 chol_model_11 S chol_model_11 "0.000000 0.600000
0.400000"
10 19416.111328 S 680 chol_model_11
10 19490.517578 S 65 B
10 19490.523438 S 680 Po
10 19490.531250 S 680 B
13 19490.648438 ntask sched 1.000000
13 19490.679688 ntask sched 2.000000
13 19490.707031 ntask sched 3.000000
13 19490.734375 ntask sched 4.000000
13 19490.763672 ntask sched 5.000000
13 19490.792969 ntask sched 6.000000
13 19490.820312 ntask sched 7.000000
13 19490.849609 ntask sched 8.000000
13 19490.878906 ntask sched 9.000000
13 19490.908203 ntask sched 10.000000
13 19490.935547 ntask sched 11.000000
13 19490.964844 ntask sched 12.000000
13 19490.992188 ntask sched 13.000000
13 19491.021484 ntask sched 14.000000
13 19491.048828 ntask sched 15.000000
10 19491.054688 MS MEMNODE2 A
10 19491.177734 MS MEMNODE2 No
10 19491.179688 MS MEMNODE2 Co
18 19491.179688 L p 4000000 MEMNODE0 com_2
10 19491.189453 MS MEMNODE2 CoA
10 19492.435547 MS MEMNODE2 No
19 19492.435547 L p 2273874960 MEMNODE2 com_2273874768
10 19492.439453 MS MEMNODE2 A
10 19492.574219 MS MEMNODE2 No
10 19492.576172 MS MEMNODE2 Co
18 19492.576172 L p 4000000 MEMNODE0 com_3
10 19492.582031 MS MEMNODE2 CoA
10 19493.849609 MS MEMNODE2 No
19 19493.849609 L p 2273874960 MEMNODE2 com_2273874768
10 19493.855469 MS MEMNODE2 A
10 19493.980469 MS MEMNODE2 No
10 19493.984375 MS MEMNODE2 Co
18 19493.984375 L p 4000000 MEMNODE0 com_4
10 19493.990234 MS MEMNODE2 CoA
10 19495.257812 MS MEMNODE2 No
19 19495.257812 L p 2273874960 MEMNODE2 com_2273874768
10 19495.263672 MS MEMNODE2 A
10 19495.390625 MS MEMNODE2 No
10 19495.392578 MS MEMNODE2 Co
18 19495.392578 L p 4000000 MEMNODE0 com_5
10 19495.414062 MS MEMNODE2 CoA
10 19496.697266 MS MEMNODE2 No
19 19496.697266 L p 2273874960 MEMNODE2 com_2273874768
10 19496.701172 MS MEMNODE2 A
10 19496.826172 MS MEMNODE2 No
10 19496.828125 MS MEMNODE2 Co
18 19496.828125 L p 4000000 MEMNODE0 com_6
10 19496.847656 MS MEMNODE2 CoA
10 19498.109375 MS MEMNODE2 No
19 19498.109375 L p 2273874960 MEMNODE2 com_2273874768
10 19498.115234 MS MEMNODE2 A
10 19498.238281 MS MEMNODE2 No
10 19498.240234 MS MEMNODE2 Co
18 19498.240234 L p 4000000 MEMNODE0 com_7
10 19498.255859 MS MEMNODE2 CoA
10 19499.531250 MS MEMNODE2 No
19 19499.531250 L p 2273874960 MEMNODE2 com_2273874768
10 19499.537109 MS MEMNODE2 A
10 19499.660156 MS MEMNODE2 No
10 19499.662109 MS MEMNODE2 Co
18 19499.662109 L p 4000000 MEMNODE0 com_8
10 19499.677734 MS MEMNODE2 CoA
10 19500.945312 MS MEMNODE2 No
19 19500.945312 L p 2273874960 MEMNODE2 com_2273874768
10 19500.951172 MS MEMNODE2 A
10 19501.072266 MS MEMNODE2 No
10 19501.074219 MS MEMNODE2 Co
18 19501.074219 L p 4000000 MEMNODE0 com_9
10 19501.091797 MS MEMNODE2 CoA
10 19502.359375 MS MEMNODE2 No
19 19502.359375 L p 2273874960 MEMNODE2 com_2273874768
10 19502.363281 MS MEMNODE2 A
10 19502.498047 MS MEMNODE2 No
10 19502.501953 MS MEMNODE2 Co
18 19502.501953 L p 4000000 MEMNODE0 com_10
10 19502.517578 MS MEMNODE2 CoA
10 19503.773438 MS MEMNODE2 No
19 19503.773438 L p 2273874960 MEMNODE2 com_2273874768
10 19503.777344 MS MEMNODE2 A
10 19503.910156 MS MEMNODE2 No
10 19503.912109 MS MEMNODE2 Co
18 19503.912109 L p 4000000 MEMNODE0 com_11
10 19503.923828 MS MEMNODE2 CoA
10 19505.191406 MS MEMNODE2 No
19 19505.191406 L p 2273874960 MEMNODE2 com_2273874768
10 19505.195312 MS MEMNODE2 A
10 19505.326172 MS MEMNODE2 No
10 19505.328125 MS MEMNODE2 Co
18 19505.328125 L p 4000000 MEMNODE0 com_12
10 19505.339844 MS MEMNODE2 CoA
10 19506.611328 MS MEMNODE2 No
19 19506.611328 L p 2273874960 MEMNODE2 com_2273874768
10 19506.615234 MS MEMNODE2 A
10 19506.740234 MS MEMNODE2 No
10 19506.742188 MS MEMNODE2 Co
18 19506.742188 L p 4000000 MEMNODE0 com_13
10 19506.757812 MS MEMNODE2 CoA
10 19508.021484 MS MEMNODE2 No
19 19508.021484 L p 2273874960 MEMNODE2 com_2273874768
10 19508.025391 MS MEMNODE2 A
10 19508.160156 MS MEMNODE2 No
10 19508.162109 MS MEMNODE2 Co
18 19508.162109 L p 4000000 MEMNODE0 com_14
10 19508.173828 MS MEMNODE2 CoA
10 19509.435547 MS MEMNODE2 No
19 19509.435547 L p 2273874960 MEMNODE2 com_2273874768
10 19509.439453 MS MEMNODE2 A
10 19509.578125 MS MEMNODE2 No
10 19509.582031 MS MEMNODE2 Co
18 19509.582031 L p 4000000 MEMNODE0 com_15
10 19509.595703 MS MEMNODE2 CoA
10 19510.861328 MS MEMNODE2 No
19 19510.861328 L p 2273874960 MEMNODE2 com_2273874768
10 19510.865234 MS MEMNODE2 A
10 19510.998047 MS MEMNODE2 No
10 19511.001953 MS MEMNODE2 Co
18 19511.001953 L p 4000000 MEMNODE0 com_16
10 19511.013672 MS MEMNODE2 CoA
10 19512.287109 MS MEMNODE2 No
19 19512.287109 L p 2273874960 MEMNODE2 com_2273874768
13 19512.294922 ntask sched 14.000000
10 19512.296875 S 680 Fi
10 19512.335938 MS MEMNODE2 No
19 19512.335938 L p 4000000 MEMNODE2 com_15
10 19512.361328 MS MEMNODE2 No
19 19512.361328 L p 4000000 MEMNODE2 com_14
10 19512.384766 MS MEMNODE2 No
19 19512.384766 L p 4000000 MEMNODE2 com_13
10 19512.408203 MS MEMNODE2 No
19 19512.408203 L p 4000000 MEMNODE2 com_12
10 19512.433594 MS MEMNODE2 No
19 19512.433594 L p 4000000 MEMNODE2 com_11
10 19512.457031 MS MEMNODE2 No
19 19512.457031 L p 4000000 MEMNODE2 com_10
10 19512.480469 MS MEMNODE2 No
19 19512.480469 L p 4000000 MEMNODE2 com_9
10 19512.501953 MS MEMNODE2 No
19 19512.501953 L p 4000000 MEMNODE2 com_8
10 19512.531250 MS MEMNODE2 No
19 19512.531250 L p 4000000 MEMNODE2 com_7
10 19512.554688 MS MEMNODE2 No
19 19512.554688 L p 4000000 MEMNODE2 com_6
10 19512.578125 MS MEMNODE2 No
19 19512.578125 L p 4000000 MEMNODE2 com_5
10 19512.601562 MS MEMNODE2 No
19 19512.601562 L p 4000000 MEMNODE2 com_4
10 19512.625000 MS MEMNODE2 No
19 19512.625000 L p 4000000 MEMNODE2 com_3
10 19512.648438 MS MEMNODE2 No
19 19512.648438 L p 4000000 MEMNODE2 com_2
10 19512.673828 MS MEMNODE2 No
19 19512.673828 L p 4000000 MEMNODE2 com_16
10 19512.675781 S 680 B
6 chol_model_21 S chol_model_21 "0.000000 0.600000
0.400000"
10 19512.679688 S 680 chol_model_21
10 19521.033203 S 65 B
10 19521.060547 S 680 Po
10 19521.064453 S 680 B
13 19521.164062 ntask sched 15.000000
10 19521.171875 MS MEMNODE2 A
10 19521.294922 MS MEMNODE2 No
10 19521.296875 MS MEMNODE2 Co
18 19521.296875 L p 4000000 MEMNODE0 com_17
10 19521.302734 MS MEMNODE2 CoA
10 19522.548828 MS MEMNODE2 No
19 19522.548828 L p 2273874960 MEMNODE2 com_2273874768
13 19522.554688 ntask sched 14.000000
10 19522.556641 S 680 Fi
10 19522.744141 MS MEMNODE2 No
19 19522.744141 L p 4000000 MEMNODE2 com_17
10 19522.746094 S 680 B
6 chol_model_22 S chol_model_22 "0.000000 0.600000
0.400000"
10 19522.746094 S 680 chol_model_22
10 19525.945312 S 65 B
10 19525.945312 S 680 Po
10 19525.947266 S 680 B
13 19525.955078 ntask sched 13.000000
10 19525.957031 S 680 Fi
10 19525.957031 S 680 B
10 19525.960938 S 680 chol_model_21
10 19534.181641 S 65 B
10 19534.183594 S 680 Po
10 19534.183594 S 680 B
13 19534.220703 ntask sched 14.000000
13 19534.251953 ntask sched 15.000000
10 19534.257812 MS MEMNODE2 A
10 19534.373047 MS MEMNODE2 No
10 19534.376953 MS MEMNODE2 Co
18 19534.376953 L p 4000000 MEMNODE0 com_18
10 19534.392578 MS MEMNODE2 CoA
10 19535.748047 MS MEMNODE2 No
19 19535.748047 L p 2273874960 MEMNODE2 com_2273874768
10 19535.753906 MS MEMNODE2 A
10 19535.876953 MS MEMNODE2 No
10 19535.878906 MS MEMNODE2 Co
18 19535.878906 L p 4000000 MEMNODE0 com_19
10 19535.890625 MS MEMNODE2 CoA
10 19537.156250 MS MEMNODE2 No
19 19537.156250 L p 2273874960 MEMNODE2 com_2273874768
13 19537.162109 ntask sched 14.000000
10 19537.164062 S 680 Fi
10 19537.201172 MS MEMNODE2 No
19 19537.201172 L p 4000000 MEMNODE2 com_18
10 19537.345703 MS MEMNODE2 No
19 19537.345703 L p 4000000 MEMNODE2 com_19
10 19537.347656 S 680 B
10 19537.349609 S 680 chol_model_22
10 19540.630859 S 65 B
10 19540.632812 S 680 Po
10 19540.634766 S 680 B
13 19540.644531 ntask sched 13.000000
10 19540.644531 S 680 Fi
10 19540.646484 S 680 B
10 19540.646484 S 680 chol_model_22
10 19543.875000 S 65 B
10 19543.876953 S 680 Po
10 19543.876953 S 680 B
13 19543.886719 ntask sched 12.000000
10 19543.888672 S 680 Fi
10 19543.888672 S 680 B
10 19543.892578 S 680 chol_model_21
10 19552.113281 S 65 B
10 19552.115234 S 680 Po
10 19552.117188 S 680 B
13 19552.158203 ntask sched 13.000000
13 19552.189453 ntask sched 14.000000
13 19552.220703 ntask sched 15.000000
10 19552.226562 MS MEMNODE2 A
10 19552.345703 MS MEMNODE2 No
10 19552.347656 MS MEMNODE2 Co
18 19552.347656 L p 4000000 MEMNODE0 com_20
10 19552.363281 MS MEMNODE2 CoA
10 19553.609375 MS MEMNODE2 No
19 19553.609375 L p 2273874960 MEMNODE2 com_2273874768
10 19553.615234 MS MEMNODE2 A
10 19553.738281 MS MEMNODE2 No
10 19553.742188 MS MEMNODE2 Co
18 19553.742188 L p 4000000 MEMNODE0 com_21
10 19553.746094 MS MEMNODE2 CoA
10 19555.013672 MS MEMNODE2 No
19 19555.013672 L p 2273874960 MEMNODE2 com_2273874768
10 19555.019531 MS MEMNODE2 A
10 19555.142578 MS MEMNODE2 No
10 19555.144531 MS MEMNODE2 Co
18 19555.144531 L p 4000000 MEMNODE0 com_22
10 19555.150391 MS MEMNODE2 CoA
10 19556.414062 MS MEMNODE2 No
19 19556.414062 L p 2273874960 MEMNODE2 com_2273874768
13 19556.421875 ntask sched 14.000000
10 19556.423828 S 680 Fi
10 19556.460938 MS MEMNODE2 No
19 19556.460938 L p 4000000 MEMNODE2 com_21
10 19556.486328 MS MEMNODE2 No
19 19556.486328 L p 4000000 MEMNODE2 com_20
10 19556.605469 MS MEMNODE2 No
19 19556.605469 L p 4000000 MEMNODE2 com_22
10 19556.607422 S 680 B
10 19556.609375 S 680 chol_model_22
10 19559.933594 S 65 B
10 19559.935547 S 680 Po
10 19559.937500 S 680 B
13 19559.945312 ntask sched 13.000000
10 19559.947266 S 680 Fi
10 19559.947266 S 680 B
10 19559.949219 S 680 chol_model_22
10 19563.175781 S 65 B
10 19563.177734 S 680 Po
10 19563.179688 S 680 B
13 19563.185547 ntask sched 12.000000
10 19563.187500 S 680 Fi
10 19563.189453 S 680 B
10 19563.189453 S 680 chol_model_22
10 19566.398438 S 65 B
10 19566.398438 S 680 Po
10 19566.400391 S 680 B
13 19566.408203 ntask sched 11.000000
10 19566.410156 S 680 Fi
10 19566.410156 S 680 B
10 19566.414062 S 680 chol_model_21
10 19574.626953 S 65 B
10 19574.628906 S 680 Po
10 19574.630859 S 680 B
13 19574.671875 ntask sched 12.000000
13 19574.701172 ntask sched 13.000000
13 19574.732422 ntask sched 14.000000
13 19574.763672 ntask sched 15.000000
10 19574.767578 MS MEMNODE2 A
10 19574.890625 MS MEMNODE2 No
10 19574.892578 MS MEMNODE2 Co
18 19574.892578 L p 4000000 MEMNODE0 com_23
10 19574.898438 MS MEMNODE2 CoA
10 19576.144531 MS MEMNODE2 No
19 19576.144531 L p 2273874960 MEMNODE2 com_2273874768
10 19576.150391 MS MEMNODE2 A
10 19576.273438 MS MEMNODE2 No
10 19576.275391 MS MEMNODE2 Co
18 19576.275391 L p 4000000 MEMNODE0 com_24
10 19576.281250 MS MEMNODE2 CoA
10 19577.550781 MS MEMNODE2 No
19 19577.550781 L p 2273874960 MEMNODE2 com_2273874768
10 19577.556641 MS MEMNODE2 A
10 19577.683594 MS MEMNODE2 No
10 19577.685547 MS MEMNODE2 Co
18 19577.685547 L p 4000000 MEMNODE0 com_25
10 19577.705078 MS MEMNODE2 CoA
10 19578.968750 MS MEMNODE2 No
19 19578.968750 L p 2273874960 MEMNODE2 com_2273874768
10 19578.974609 MS MEMNODE2 A
10 19579.099609 MS MEMNODE2 No
10 19579.101562 MS MEMNODE2 Co
18 19579.101562 L p 4000000 MEMNODE0 com_26
10 19579.115234 MS MEMNODE2 CoA
10 19580.380859 MS MEMNODE2 No
19 19580.380859 L p 2273874960 MEMNODE2 com_2273874768
13 19580.388672 ntask sched 14.000000
10 19580.390625 S 680 Fi
10 19580.429688 MS MEMNODE2 No
19 19580.429688 L p 4000000 MEMNODE2 com_25
10 19580.453125 MS MEMNODE2 No
19 19580.453125 L p 4000000 MEMNODE2 com_24
10 19580.478516 MS MEMNODE2 No
19 19580.478516 L p 4000000 MEMNODE2 com_23
10 19580.574219 MS MEMNODE2 No
19 19580.574219 L p 4000000 MEMNODE2 com_26
10 19580.576172 S 680 B
10 19580.578125 S 680 chol_model_22
10 19583.841797 S 65 B
10 19583.843750 S 680 Po
10 19583.845703 S 680 B
13 19583.857422 ntask sched 13.000000
10 19583.859375 S 680 Fi
10 19583.859375 S 680 B
10 19583.861328 S 680 chol_model_22
10 19587.158203 S 65 B
10 19587.158203 S 680 Po
10 19587.160156 S 680 B
13 19587.169922 ntask sched 12.000000
10 19587.171875 S 680 Fi
10 19587.171875 S 680 B
10 19587.173828 S 680 chol_model_22
10 19590.451172 S 65 B
10 19590.453125 S 680 Po
10 19590.455078 S 680 B
13 19590.462891 ntask sched 11.000000
10 19590.464844 S 680 Fi
10 19590.466797 S 680 B
10 19590.466797 S 680 chol_model_22
10 19593.681641 S 65 B
10 19593.683594 S 680 Po
10 19593.685547 S 680 B
13 19593.693359 ntask sched 10.000000
10 19593.693359 S 680 Fi
10 19593.695312 S 680 B
10 19593.697266 S 680 chol_model_21
10 19601.910156 S 65 B
10 19601.912109 S 680 Po
10 19601.914062 S 680 B
13 19601.957031 ntask sched 11.000000
13 19601.986328 ntask sched 12.000000
13 19602.017578 ntask sched 13.000000
13 19602.046875 ntask sched 14.000000
13 19602.078125 ntask sched 15.000000
10 19602.083984 MS MEMNODE2 A
10 19602.207031 MS MEMNODE2 No
10 19602.210938 MS MEMNODE2 Co
18 19602.210938 L p 4000000 MEMNODE0 com_27
10 19602.216797 MS MEMNODE2 CoA
10 19603.457031 MS MEMNODE2 No
19 19603.457031 L p 2273874960 MEMNODE2 com_2273874768
10 19603.462891 MS MEMNODE2 A
10 19603.591797 MS MEMNODE2 No
10 19603.593750 MS MEMNODE2 Co
18 19603.593750 L p 4000000 MEMNODE0 com_28
10 19603.611328 MS MEMNODE2 CoA
10 19604.884766 MS MEMNODE2 No
19 19604.884766 L p 2273874960 MEMNODE2 com_2273874768
10 19604.888672 MS MEMNODE2 A
10 19605.023438 MS MEMNODE2 No
10 19605.025391 MS MEMNODE2 Co
18 19605.025391 L p 4000000 MEMNODE0 com_29
10 19605.031250 MS MEMNODE2 CoA
10 19606.300781 MS MEMNODE2 No
19 19606.300781 L p 2273874960 MEMNODE2 com_2273874768
10 19606.304688 MS MEMNODE2 A
10 19615.205078 MS MEMNODE2 No
10 19615.207031 MS MEMNODE2 Co
18 19615.207031 L p 4000000 MEMNODE0 com_30
10 19615.212891 MS MEMNODE2 CoA
10 19616.478516 MS MEMNODE2 No
19 19616.478516 L p 2273874960 MEMNODE2 com_2273874768
10 19616.482422 MS MEMNODE2 A
10 19616.613281 MS MEMNODE2 No
10 19616.615234 MS MEMNODE2 Co
18 19616.615234 L p 4000000 MEMNODE0 com_31
10 19616.621094 MS MEMNODE2 CoA
10 19617.888672 MS MEMNODE2 No
19 19617.888672 L p 2273874960 MEMNODE2 com_2273874768
13 19617.896484 ntask sched 14.000000
10 19617.898438 S 680 Fi
10 19617.935547 MS MEMNODE2 No
19 19617.935547 L p 4000000 MEMNODE2 com_30
10 19617.960938 MS MEMNODE2 No
19 19617.960938 L p 4000000 MEMNODE2 com_29
10 19617.984375 MS MEMNODE2 No
19 19617.984375 L p 4000000 MEMNODE2 com_28
10 19618.009766 MS MEMNODE2 No
19 19618.009766 L p 4000000 MEMNODE2 com_27
10 19618.076172 MS MEMNODE2 No
19 19618.076172 L p 4000000 MEMNODE2 com_31
10 19618.078125 S 680 B
10 19618.080078 S 680 chol_model_22
10 19621.429688 S 65 B
10 19621.431641 S 680 Po
10 19621.433594 S 680 B
13 19621.445312 ntask sched 13.000000
10 19621.447266 S 680 Fi
10 19621.447266 S 680 B
10 19621.449219 S 680 chol_model_22
10 19624.730469 S 65 B
10 19624.732422 S 680 Po
10 19624.732422 S 680 B
13 19624.742188 ntask sched 12.000000
10 19624.744141 S 680 Fi
10 19624.746094 S 680 B
10 19624.746094 S 680 chol_model_22
10 19628.064453 S 65 B
10 19628.066406 S 680 Po
10 19628.068359 S 680 B
13 19628.076172 ntask sched 11.000000
10 19628.076172 S 680 Fi
10 19628.078125 S 680 B
10 19628.080078 S 680 chol_model_22
10 19631.306641 S 65 B
10 19631.306641 S 680 Po
10 19631.308594 S 680 B
13 19631.318359 ntask sched 10.000000
10 19631.318359 S 680 Fi
10 19631.320312 S 680 B
10 19631.320312 S 680 chol_model_22
10 19634.546875 S 65 B
10 19634.546875 S 680 Po
10 19634.548828 S 680 B
13 19634.556641 ntask sched 9.000000
10 19634.558594 S 680 Fi
10 19634.560547 S 680 B
10 19634.562500 S 680 chol_model_21
10 19642.855469 S 65 B
10 19642.857422 S 680 Po
10 19642.859375 S 680 B
13 19642.900391 ntask sched 10.000000
13 19642.931641 ntask sched 11.000000
13 19642.962891 ntask sched 12.000000
13 19642.992188 ntask sched 13.000000
13 19643.023438 ntask sched 14.000000
13 19643.052734 ntask sched 15.000000
10 19643.058594 MS MEMNODE2 A
10 19643.195312 MS MEMNODE2 No
10 19643.197266 MS MEMNODE2 Co
18 19643.197266 L p 4000000 MEMNODE0 com_32
10 19643.203125 MS MEMNODE2 CoA
10 19644.443359 MS MEMNODE2 No
19 19644.443359 L p 2273874960 MEMNODE2 com_2273874768
10 19644.447266 MS MEMNODE2 A
10 19644.580078 MS MEMNODE2 No
10 19644.582031 MS MEMNODE2 Co
18 19644.582031 L p 4000000 MEMNODE0 com_33
10 19644.587891 MS MEMNODE2 CoA
10 19645.849609 MS MEMNODE2 No
19 19645.849609 L p 2273874960 MEMNODE2 com_2273874768
10 19645.855469 MS MEMNODE2 A
10 19645.978516 MS MEMNODE2 No
10 19645.980469 MS MEMNODE2 Co
18 19645.980469 L p 4000000 MEMNODE0 com_34
10 19645.986328 MS MEMNODE2 CoA
10 19647.257812 MS MEMNODE2 No
19 19647.257812 L p 2273874960 MEMNODE2 com_2273874768
10 19647.263672 MS MEMNODE2 A
10 19647.386719 MS MEMNODE2 No
10 19647.390625 MS MEMNODE2 Co
18 19647.390625 L p 4000000 MEMNODE0 com_35
10 19647.414062 MS MEMNODE2 CoA
10 19648.683594 MS MEMNODE2 No
19 19648.683594 L p 2273874960 MEMNODE2 com_2273874768
10 19648.687500 MS MEMNODE2 A
10 19648.814453 MS MEMNODE2 No
10 19648.816406 MS MEMNODE2 Co
18 19648.816406 L p 4000000 MEMNODE0 com_36
10 19648.830078 MS MEMNODE2 CoA
10 19650.097656 MS MEMNODE2 No
19 19650.097656 L p 2273874960 MEMNODE2 com_2273874768
10 19650.101562 MS MEMNODE2 A
10 19650.230469 MS MEMNODE2 No
10 19650.234375 MS MEMNODE2 Co
18 19650.234375 L p 4000000 MEMNODE0 com_37
10 19650.240234 MS MEMNODE2 CoA
10 19651.513672 MS MEMNODE2 No
19 19651.513672 L p 2273874960 MEMNODE2 com_2273874768
13 19651.519531 ntask sched 14.000000
10 19651.523438 S 680 Fi
10 19651.562500 MS MEMNODE2 No
19 19651.562500 L p 4000000 MEMNODE2 com_36
10 19651.587891 MS MEMNODE2 No
19 19651.587891 L p 4000000 MEMNODE2 com_35
10 19651.611328 MS MEMNODE2 No
19 19651.611328 L p 4000000 MEMNODE2 com_34
10 19651.634766 MS MEMNODE2 No
19 19651.634766 L p 4000000 MEMNODE2 com_33
10 19651.658203 MS MEMNODE2 No
19 19651.658203 L p 4000000 MEMNODE2 com_32
10 19651.699219 MS MEMNODE2 No
19 19651.699219 L p 4000000 MEMNODE2 com_37
10 19651.701172 S 680 B
10 19651.703125 S 680 chol_model_22
10 19654.966797 S 65 B
10 19654.968750 S 680 Po
10 19654.970703 S 680 B
13 19654.980469 ntask sched 13.000000
10 19654.982422 S 680 Fi
10 19654.984375 S 680 B
10 19654.984375 S 680 chol_model_22
10 19658.218750 S 65 B
10 19658.220703 S 680 Po
10 19658.222656 S 680 B
13 19658.230469 ntask sched 12.000000
10 19658.232422 S 680 Fi
10 19658.234375 S 680 B
10 19658.234375 S 680 chol_model_22
10 19661.476562 S 65 B
10 19661.476562 S 680 Po
10 19661.478516 S 680 B
13 19661.488281 ntask sched 11.000000
10 19661.490234 S 680 Fi
10 19661.492188 S 680 B
10 19661.492188 S 680 chol_model_22
10 19664.816406 S 65 B
10 19664.818359 S 680 Po
10 19664.820312 S 680 B
13 19664.828125 ntask sched 10.000000
10 19664.828125 S 680 Fi
10 19664.830078 S 680 B
10 19664.830078 S 680 chol_model_22
10 19668.042969 S 65 B
10 19668.044922 S 680 Po
10 19668.046875 S 680 B
13 19668.054688 ntask sched 9.000000
10 19668.054688 S 680 Fi
10 19668.056641 S 680 B
10 19668.056641 S 680 chol_model_22
10 19671.251953 S 65 B
10 19671.251953 S 680 Po
10 19671.253906 S 680 B
13 19671.261719 ntask sched 8.000000
10 19671.263672 S 680 Fi
10 19671.265625 S 680 B
10 19671.267578 S 680 chol_model_21
10 19679.478516 S 65 B
10 19679.480469 S 680 Po
10 19679.482422 S 680 B
13 19679.531250 ntask sched 9.000000
13 19679.562500 ntask sched 10.000000
13 19679.593750 ntask sched 11.000000
13 19679.625000 ntask sched 12.000000
13 19679.654297 ntask sched 13.000000
13 19679.685547 ntask sched 14.000000
13 19679.716797 ntask sched 15.000000
10 19679.722656 MS MEMNODE2 A
10 19679.843750 MS MEMNODE2 No
10 19679.845703 MS MEMNODE2 Co
18 19679.845703 L p 4000000 MEMNODE0 com_38
10 19679.851562 MS MEMNODE2 CoA
10 19681.087891 MS MEMNODE2 No
19 19681.087891 L p 2273874960 MEMNODE2 com_2273874768
10 19681.091797 MS MEMNODE2 A
10 19681.218750 MS MEMNODE2 No
10 19681.220703 MS MEMNODE2 Co
18 19681.220703 L p 4000000 MEMNODE0 com_39
10 19681.242188 MS MEMNODE2 CoA
10 19682.513672 MS MEMNODE2 No
19 19682.513672 L p 2273874960 MEMNODE2 com_2273874768
10 19682.517578 MS MEMNODE2 A
10 19682.642578 MS MEMNODE2 No
10 19682.644531 MS MEMNODE2 Co
18 19682.644531 L p 4000000 MEMNODE0 com_40
10 19682.658203 MS MEMNODE2 CoA
10 19683.929688 MS MEMNODE2 No
19 19683.929688 L p 2273874960 MEMNODE2 com_2273874768
10 19683.933594 MS MEMNODE2 A
10 19684.060547 MS MEMNODE2 No
10 19684.062500 MS MEMNODE2 Co
18 19684.062500 L p 4000000 MEMNODE0 com_41
10 19684.078125 MS MEMNODE2 CoA
10 19685.343750 MS MEMNODE2 No
19 19685.343750 L p 2273874960 MEMNODE2 com_2273874768
10 19685.349609 MS MEMNODE2 A
10 19685.474609 MS MEMNODE2 No
10 19685.476562 MS MEMNODE2 Co
18 19685.476562 L p 4000000 MEMNODE0 com_42
10 19685.494141 MS MEMNODE2 CoA
10 19686.763672 MS MEMNODE2 No
19 19686.763672 L p 2273874960 MEMNODE2 com_2273874768
10 19686.769531 MS MEMNODE2 A
10 19686.894531 MS MEMNODE2 No
10 19686.896484 MS MEMNODE2 Co
18 19686.896484 L p 4000000 MEMNODE0 com_43
10 19686.914062 MS MEMNODE2 CoA
10 19688.183594 MS MEMNODE2 No
19 19688.183594 L p 2273874960 MEMNODE2 com_2273874768
10 19688.189453 MS MEMNODE2 A
10 19688.312500 MS MEMNODE2 No
10 19688.320312 MS MEMNODE2 Co
18 19688.320312 L p 4000000 MEMNODE0 com_44
10 19688.335938 MS MEMNODE2 CoA
10 19689.609375 MS MEMNODE2 No
19 19689.609375 L p 2273874960 MEMNODE2 com_2273874768
13 19689.615234 ntask sched 14.000000
10 19689.619141 S 680 Fi
10 19689.656250 MS MEMNODE2 No
19 19689.656250 L p 4000000 MEMNODE2 com_43
10 19689.681641 MS MEMNODE2 No
19 19689.681641 L p 4000000 MEMNODE2 com_42
10 19689.705078 MS MEMNODE2 No
19 19689.705078 L p 4000000 MEMNODE2 com_41
10 19689.728516 MS MEMNODE2 No
19 19689.728516 L p 4000000 MEMNODE2 com_40
10 19689.753906 MS MEMNODE2 No
19 19689.753906 L p 4000000 MEMNODE2 com_39
10 19689.777344 MS MEMNODE2 No
19 19689.777344 L p 4000000 MEMNODE2 com_38
10 19689.800781 MS MEMNODE2 No
19 19689.800781 L p 4000000 MEMNODE2 com_44
10 19689.802734 S 680 B
10 19689.804688 S 680 chol_model_22
10 19693.150391 S 65 B
10 19693.152344 S 680 Po
10 19693.154297 S 680 B
13 19693.164062 ntask sched 13.000000
10 19693.166016 S 680 Fi
10 19693.167969 S 680 B
10 19693.167969 S 680 chol_model_22
10 19696.390625 S 65 B
10 19696.390625 S 680 Po
10 19696.392578 S 680 B
13 19696.400391 ntask sched 12.000000
10 19696.402344 S 680 Fi
10 19696.402344 S 680 B
10 19696.404297 S 680 chol_model_22
10 19699.730469 S 65 B
10 19699.730469 S 680 Po
10 19699.732422 S 680 B
13 19699.740234 ntask sched 11.000000
10 19699.742188 S 680 Fi
10 19699.742188 S 680 B
10 19699.744141 S 680 chol_model_22
10 19703.031250 S 65 B
10 19703.033203 S 680 Po
10 19703.035156 S 680 B
13 19703.042969 ntask sched 10.000000
10 19703.044922 S 680 Fi
10 19703.046875 S 680 B
10 19703.048828 S 680 chol_model_22
10 19706.347656 S 65 B
10 19706.347656 S 680 Po
10 19706.349609 S 680 B
13 19706.357422 ntask sched 9.000000
10 19706.359375 S 680 Fi
10 19706.361328 S 680 B
10 19706.361328 S 680 chol_model_22
10 19709.578125 S 65 B
10 19709.578125 S 680 Po
10 19709.580078 S 680 B
13 19709.589844 ntask sched 8.000000
10 19709.591797 S 680 Fi
10 19709.591797 S 680 B
10 19709.593750 S 680 chol_model_22
10 19712.875000 S 65 B
10 19712.875000 S 680 Po
10 19712.876953 S 680 B
13 19712.884766 ntask sched 7.000000
10 19712.886719 S 680 Fi
10 19712.888672 S 680 B
10 19712.890625 S 680 chol_model_21
10 19721.121094 S 65 B
10 19721.125000 S 680 Po
10 19721.126953 S 680 B
13 19721.171875 ntask sched 8.000000
13 19721.201172 ntask sched 9.000000
13 19721.232422 ntask sched 10.000000
13 19721.263672 ntask sched 11.000000
13 19721.292969 ntask sched 12.000000
13 19721.322266 ntask sched 13.000000
13 19721.353516 ntask sched 14.000000
13 19721.384766 ntask sched 15.000000
10 19721.388672 MS MEMNODE2 A
10 19721.529297 MS MEMNODE2 No
10 19721.531250 MS MEMNODE2 Co
18 19721.531250 L p 4000000 MEMNODE0 com_45
10 19721.539062 MS MEMNODE2 CoA
10 19722.783203 MS MEMNODE2 No
19 19722.783203 L p 2273874960 MEMNODE2 com_2273874768
10 19722.789062 MS MEMNODE2 A
10 19722.914062 MS MEMNODE2 No
10 19722.917969 MS MEMNODE2 Co
18 19722.917969 L p 4000000 MEMNODE0 com_46
10 19722.923828 MS MEMNODE2 CoA
10 19724.187500 MS MEMNODE2 No
19 19724.187500 L p 2273874960 MEMNODE2 com_2273874768
10 19724.191406 MS MEMNODE2 A
10 19724.316406 MS MEMNODE2 No
10 19724.318359 MS MEMNODE2 Co
18 19724.318359 L p 4000000 MEMNODE0 com_47
10 19724.324219 MS MEMNODE2 CoA
10 19725.593750 MS MEMNODE2 No
19 19725.593750 L p 2273874960 MEMNODE2 com_2273874768
10 19725.597656 MS MEMNODE2 A
10 19725.726562 MS MEMNODE2 No
10 19725.728516 MS MEMNODE2 Co
18 19725.728516 L p 4000000 MEMNODE0 com_48
10 19725.734375 MS MEMNODE2 CoA
10 19726.996094 MS MEMNODE2 No
19 19726.996094 L p 2273874960 MEMNODE2 com_2273874768
10 19727.001953 MS MEMNODE2 A
10 19727.128906 MS MEMNODE2 No
10 19727.130859 MS MEMNODE2 Co
18 19727.130859 L p 4000000 MEMNODE0 com_49
10 19727.142578 MS MEMNODE2 CoA
10 19728.410156 MS MEMNODE2 No
19 19728.410156 L p 2273874960 MEMNODE2 com_2273874768
10 19728.414062 MS MEMNODE2 A
10 19728.544922 MS MEMNODE2 No
10 19728.548828 MS MEMNODE2 Co
18 19728.548828 L p 4000000 MEMNODE0 com_50
10 19728.556641 MS MEMNODE2 CoA
10 19729.818359 MS MEMNODE2 No
19 19729.818359 L p 2273874960 MEMNODE2 com_2273874768
10 19729.822266 MS MEMNODE2 A
10 19729.949219 MS MEMNODE2 No
10 19729.953125 MS MEMNODE2 Co
18 19729.953125 L p 4000000 MEMNODE0 com_51
10 19729.960938 MS MEMNODE2 CoA
10 19731.224609 MS MEMNODE2 No
19 19731.224609 L p 2273874960 MEMNODE2 com_2273874768
10 19731.230469 MS MEMNODE2 A
10 19731.355469 MS MEMNODE2 No
10 19731.357422 MS MEMNODE2 Co
18 19731.357422 L p 4000000 MEMNODE0 com_52
10 19731.363281 MS MEMNODE2 CoA
10 19732.636719 MS MEMNODE2 No
19 19732.636719 L p 2273874960 MEMNODE2 com_2273874768
13 19732.642578 ntask sched 14.000000
10 19732.646484 S 680 Fi
10 19732.683594 MS MEMNODE2 No
19 19732.683594 L p 4000000 MEMNODE2 com_51
10 19732.708984 MS MEMNODE2 No
19 19732.708984 L p 4000000 MEMNODE2 com_50
10 19732.732422 MS MEMNODE2 No
19 19732.732422 L p 4000000 MEMNODE2 com_49
10 19732.759766 MS MEMNODE2 No
19 19732.759766 L p 4000000 MEMNODE2 com_48
10 19732.783203 MS MEMNODE2 No
19 19732.783203 L p 4000000 MEMNODE2 com_47
10 19732.808594 MS MEMNODE2 No
19 19732.808594 L p 4000000 MEMNODE2 com_46
10 19732.832031 MS MEMNODE2 No
19 19732.832031 L p 4000000 MEMNODE2 com_45
10 19732.855469 MS MEMNODE2 No
19 19732.855469 L p 4000000 MEMNODE2 com_52
10 19732.857422 S 680 B
10 19732.859375 S 680 chol_model_22
10 19736.187500 S 65 B
10 19736.189453 S 680 Po
10 19736.191406 S 680 B
13 19736.201172 ntask sched 13.000000
10 19736.203125 S 680 Fi
10 19736.205078 S 680 B
10 19736.205078 S 680 chol_model_22
10 19739.445312 S 65 B
10 19739.445312 S 680 Po
10 19739.449219 S 680 B
13 19739.455078 ntask sched 12.000000
10 19739.457031 S 680 Fi
10 19739.458984 S 680 B
10 19739.460938 S 680 chol_model_22
10 19742.757812 S 65 B
10 19742.759766 S 680 Po
10 19742.761719 S 680 B
13 19742.769531 ntask sched 11.000000
10 19742.771484 S 680 Fi
10 19742.773438 S 680 B
10 19742.773438 S 680 chol_model_22
10 19746.113281 S 65 B
10 19746.115234 S 680 Po
10 19746.117188 S 680 B
13 19746.126953 ntask sched 10.000000
10 19746.128906 S 680 Fi
10 19746.130859 S 680 B
10 19746.130859 S 680 chol_model_22
10 19749.427734 S 65 B
10 19749.427734 S 680 Po
10 19749.429688 S 680 B
13 19749.439453 ntask sched 9.000000
10 19749.441406 S 680 Fi
10 19749.443359 S 680 B
10 19749.443359 S 680 chol_model_22
10 19752.669922 S 65 B
10 19752.669922 S 680 Po
10 19752.671875 S 680 B
13 19752.683594 ntask sched 8.000000
10 19752.685547 S 680 Fi
10 19752.685547 S 680 B
10 19752.687500 S 680 chol_model_22
10 19755.968750 S 65 B
10 19755.968750 S 680 Po
10 19755.970703 S 680 B
13 19755.978516 ntask sched 7.000000
10 19755.980469 S 680 Fi
10 19755.980469 S 680 B
10 19755.982422 S 680 chol_model_22
10 19759.191406 S 65 B
10 19759.193359 S 680 Po
10 19759.195312 S 680 B
13 19759.203125 ntask sched 6.000000
10 19759.203125 S 680 Fi
10 19759.205078 S 680 B
10 19759.208984 S 680 chol_model_21
10 19767.419922 S 65 B
10 19767.421875 S 680 Po
10 19767.423828 S 680 B
13 19767.464844 ntask sched 7.000000
13 19767.494141 ntask sched 8.000000
13 19767.531250 ntask sched 9.000000
13 19767.562500 ntask sched 10.000000
13 19767.593750 ntask sched 11.000000
13 19767.623047 ntask sched 12.000000
13 19767.654297 ntask sched 13.000000
13 19767.685547 ntask sched 14.000000
13 19767.716797 ntask sched 15.000000
10 19767.720703 MS MEMNODE2 A
10 19767.849609 MS MEMNODE2 No
10 19767.851562 MS MEMNODE2 Co
18 19767.851562 L p 4000000 MEMNODE0 com_53
10 19767.857422 MS MEMNODE2 CoA
10 19769.101562 MS MEMNODE2 No
19 19769.101562 L p 2273874960 MEMNODE2 com_2273874768
10 19769.105469 MS MEMNODE2 A
10 19769.234375 MS MEMNODE2 No
10 19769.238281 MS MEMNODE2 Co
18 19769.238281 L p 4000000 MEMNODE0 com_54
10 19769.242188 MS MEMNODE2 CoA
10 19770.517578 MS MEMNODE2 No
19 19770.517578 L p 2273874960 MEMNODE2 com_2273874768
10 19770.521484 MS MEMNODE2 A
10 19770.646484 MS MEMNODE2 No
10 19770.648438 MS MEMNODE2 Co
18 19770.648438 L p 4000000 MEMNODE0 com_55
10 19770.654297 MS MEMNODE2 CoA
10 19771.921875 MS MEMNODE2 No
19 19771.921875 L p 2273874960 MEMNODE2 com_2273874768
10 19771.927734 MS MEMNODE2 A
10 19772.054688 MS MEMNODE2 No
10 19772.056641 MS MEMNODE2 Co
18 19772.056641 L p 4000000 MEMNODE0 com_56
10 19772.062500 MS MEMNODE2 CoA
10 19773.333984 MS MEMNODE2 No
19 19773.333984 L p 2273874960 MEMNODE2 com_2273874768
10 19773.339844 MS MEMNODE2 A
10 19773.464844 MS MEMNODE2 No
10 19773.468750 MS MEMNODE2 Co
18 19773.468750 L p 4000000 MEMNODE0 com_57
10 19773.472656 MS MEMNODE2 CoA
10 19785.480469 MS MEMNODE2 No
19 19785.480469 L p 2273874960 MEMNODE2 com_2273874768
10 19785.484375 MS MEMNODE2 A
10 19785.734375 MS MEMNODE2 No
10 19785.736328 MS MEMNODE2 Co
18 19785.736328 L p 4000000 MEMNODE0 com_58
10 19785.744141 MS MEMNODE2 CoA
10 19787.009766 MS MEMNODE2 No
19 19787.009766 L p 2273874960 MEMNODE2 com_2273874768
10 19787.013672 MS MEMNODE2 A
10 19787.146484 MS MEMNODE2 No
10 19787.148438 MS MEMNODE2 Co
18 19787.148438 L p 4000000 MEMNODE0 com_59
10 19787.156250 MS MEMNODE2 CoA
10 19788.421875 MS MEMNODE2 No
19 19788.421875 L p 2273874960 MEMNODE2 com_2273874768
10 19788.425781 MS MEMNODE2 A
10 19788.564453 MS MEMNODE2 No
10 19788.566406 MS MEMNODE2 Co
18 19788.566406 L p 4000000 MEMNODE0 com_60
10 19788.572266 MS MEMNODE2 CoA
10 19789.839844 MS MEMNODE2 No
19 19789.839844 L p 2273874960 MEMNODE2 com_2273874768
10 19789.843750 MS MEMNODE2 A
10 19789.974609 MS MEMNODE2 No
10 19789.976562 MS MEMNODE2 Co
18 19789.976562 L p 4000000 MEMNODE0 com_61
10 19789.984375 MS MEMNODE2 CoA
10 19791.248047 MS MEMNODE2 No
19 19791.248047 L p 2273874960 MEMNODE2 com_2273874768
13 19791.257812 ntask sched 14.000000
10 19791.259766 S 680 Fi
10 19791.296875 MS MEMNODE2 No
19 19791.296875 L p 4000000 MEMNODE2 com_60
10 19791.322266 MS MEMNODE2 No
19 19791.322266 L p 4000000 MEMNODE2 com_59
10 19791.347656 MS MEMNODE2 No
19 19791.347656 L p 4000000 MEMNODE2 com_58
10 19791.371094 MS MEMNODE2 No
19 19791.371094 L p 4000000 MEMNODE2 com_57
10 19791.394531 MS MEMNODE2 No
19 19791.394531 L p 4000000 MEMNODE2 com_56
10 19791.419922 MS MEMNODE2 No
19 19791.419922 L p 4000000 MEMNODE2 com_55
10 19791.443359 MS MEMNODE2 No
19 19791.443359 L p 4000000 MEMNODE2 com_54
10 19791.466797 MS MEMNODE2 No
19 19791.466797 L p 4000000 MEMNODE2 com_53
10 19791.490234 MS MEMNODE2 No
19 19791.490234 L p 4000000 MEMNODE2 com_61
10 19791.492188 S 680 B
10 19791.494141 S 680 chol_model_22
10 19794.814453 S 65 B
10 19794.816406 S 680 Po
10 19794.818359 S 680 B
13 19794.828125 ntask sched 13.000000
10 19794.830078 S 680 Fi
10 19794.832031 S 680 B
10 19794.832031 S 680 chol_model_22
10 19798.062500 S 65 B
10 19798.062500 S 680 Po
10 19798.064453 S 680 B
13 19798.072266 ntask sched 12.000000
10 19798.074219 S 680 Fi
10 19798.076172 S 680 B
10 19798.076172 S 680 chol_model_22
10 19811.449219 S 65 B
10 19811.451172 S 680 Po
10 19811.453125 S 680 B
13 19811.462891 ntask sched 11.000000
10 19811.464844 S 680 Fi
10 19811.464844 S 680 B
10 19811.466797 S 680 chol_model_22
10 19814.757812 S 65 B
10 19814.759766 S 680 Po
10 19814.761719 S 680 B
13 19814.769531 ntask sched 10.000000
10 19814.771484 S 680 Fi
10 19814.771484 S 680 B
10 19814.773438 S 680 chol_model_22
10 19818.083984 S 65 B
10 19818.085938 S 680 Po
10 19818.087891 S 680 B
13 19818.093750 ntask sched 9.000000
10 19818.095703 S 680 Fi
10 19818.097656 S 680 B
10 19818.097656 S 680 chol_model_22
10 19821.322266 S 65 B
10 19821.322266 S 680 Po
10 19821.324219 S 680 B
13 19821.332031 ntask sched 8.000000
10 19821.335938 S 680 Fi
10 19821.337891 S 680 B
10 19821.337891 S 680 chol_model_22
10 19824.613281 S 65 B
10 19824.613281 S 680 Po
10 19824.615234 S 680 B
13 19824.623047 ntask sched 7.000000
10 19824.625000 S 680 Fi
10 19824.626953 S 680 B
10 19824.626953 S 680 chol_model_22
10 19827.902344 S 65 B
10 19827.904297 S 680 Po
10 19827.904297 S 680 B
13 19827.914062 ntask sched 6.000000
10 19827.916016 S 680 Fi
10 19827.917969 S 680 B
10 19827.917969 S 680 chol_model_22
10 19831.144531 S 65 B
10 19831.144531 S 680 Po
10 19831.146484 S 680 B
13 19831.154297 ntask sched 5.000000
10 19831.156250 S 680 Fi
10 19831.156250 S 680 B
10 19831.160156 S 680 chol_model_21
10 19839.378906 S 65 B
10 19839.382812 S 680 Po
10 19839.384766 S 680 B
13 19839.425781 ntask sched 6.000000
13 19839.455078 ntask sched 7.000000
13 19839.486328 ntask sched 8.000000
13 19839.521484 ntask sched 9.000000
13 19839.552734 ntask sched 10.000000
13 19839.582031 ntask sched 11.000000
13 19839.613281 ntask sched 12.000000
13 19839.644531 ntask sched 13.000000
13 19839.673828 ntask sched 14.000000
13 19839.703125 ntask sched 15.000000
10 19839.708984 MS MEMNODE2 A
10 19839.835938 MS MEMNODE2 No
10 19839.839844 MS MEMNODE2 Co
18 19839.839844 L p 4000000 MEMNODE0 com_62
10 19839.843750 MS MEMNODE2 CoA
10 19841.082031 MS MEMNODE2 No
19 19841.082031 L p 2273874960 MEMNODE2 com_2273874768
10 19841.087891 MS MEMNODE2 A
10 19850.000000 MS MEMNODE2 No
10 19850.001953 MS MEMNODE2 Co
18 19850.001953 L p 4000000 MEMNODE0 com_63
10 19850.007812 MS MEMNODE2 CoA
10 19851.273438 MS MEMNODE2 No
19 19851.273438 L p 2273874960 MEMNODE2 com_2273874768
10 19851.279297 MS MEMNODE2 A
10 19851.408203 MS MEMNODE2 No
10 19851.410156 MS MEMNODE2 Co
18 19851.410156 L p 4000000 MEMNODE0 com_64
10 19851.417969 MS MEMNODE2 CoA
10 19852.689453 MS MEMNODE2 No
19 19852.689453 L p 2273874960 MEMNODE2 com_2273874768
10 19852.695312 MS MEMNODE2 A
10 19852.824219 MS MEMNODE2 No
10 19852.826172 MS MEMNODE2 Co
18 19852.826172 L p 4000000 MEMNODE0 com_65
10 19852.841797 MS MEMNODE2 CoA
10 19854.109375 MS MEMNODE2 No
19 19854.109375 L p 2273874960 MEMNODE2 com_2273874768
10 19854.117188 MS MEMNODE2 A
10 19854.250000 MS MEMNODE2 No
10 19854.251953 MS MEMNODE2 Co
18 19854.251953 L p 4000000 MEMNODE0 com_66
10 19854.259766 MS MEMNODE2 CoA
10 19855.529297 MS MEMNODE2 No
19 19855.529297 L p 2273874960 MEMNODE2 com_2273874768
10 19855.535156 MS MEMNODE2 A
10 19855.664062 MS MEMNODE2 No
10 19855.667969 MS MEMNODE2 Co
18 19855.667969 L p 4000000 MEMNODE0 com_67
10 19855.673828 MS MEMNODE2 CoA
10 19856.935547 MS MEMNODE2 No
19 19856.935547 L p 2273874960 MEMNODE2 com_2273874768
10 19856.939453 MS MEMNODE2 A
10 19857.068359 MS MEMNODE2 No
10 19857.072266 MS MEMNODE2 Co
18 19857.072266 L p 4000000 MEMNODE0 com_68
10 19857.076172 MS MEMNODE2 CoA
10 19858.341797 MS MEMNODE2 No
19 19858.341797 L p 2273874960 MEMNODE2 com_2273874768
10 19858.347656 MS MEMNODE2 A
10 19858.476562 MS MEMNODE2 No
10 19858.478516 MS MEMNODE2 Co
18 19858.478516 L p 4000000 MEMNODE0 com_69
10 19858.484375 MS MEMNODE2 CoA
10 19859.753906 MS MEMNODE2 No
19 19859.753906 L p 2273874960 MEMNODE2 com_2273874768
10 19859.757812 MS MEMNODE2 A
10 19859.890625 MS MEMNODE2 No
10 19859.892578 MS MEMNODE2 Co
18 19859.892578 L p 4000000 MEMNODE0 com_70
10 19859.900391 MS MEMNODE2 CoA
10 19861.162109 MS MEMNODE2 No
19 19861.162109 L p 2273874960 MEMNODE2 com_2273874768
10 19861.167969 MS MEMNODE2 A
10 19861.302734 MS MEMNODE2 No
10 19861.306641 MS MEMNODE2 Co
18 19861.306641 L p 4000000 MEMNODE0 com_71
10 19861.312500 MS MEMNODE2 CoA
10 19862.583984 MS MEMNODE2 No
19 19862.583984 L p 2273874960 MEMNODE2 com_2273874768
13 19862.591797 ntask sched 14.000000
10 19862.593750 S 680 Fi
10 19862.632812 MS MEMNODE2 No
19 19862.632812 L p 4000000 MEMNODE2 com_70
10 19862.656250 MS MEMNODE2 No
19 19862.656250 L p 4000000 MEMNODE2 com_69
10 19862.681641 MS MEMNODE2 No
19 19862.681641 L p 4000000 MEMNODE2 com_68
10 19862.705078 MS MEMNODE2 No
19 19862.705078 L p 4000000 MEMNODE2 com_67
10 19862.730469 MS MEMNODE2 No
19 19862.730469 L p 4000000 MEMNODE2 com_66
10 19862.753906 MS MEMNODE2 No
19 19862.753906 L p 4000000 MEMNODE2 com_65
10 19862.777344 MS MEMNODE2 No
19 19862.777344 L p 4000000 MEMNODE2 com_64
10 19862.800781 MS MEMNODE2 No
19 19862.800781 L p 4000000 MEMNODE2 com_63
10 19862.824219 MS MEMNODE2 No
19 19862.824219 L p 4000000 MEMNODE2 com_62
10 19862.855469 MS MEMNODE2 No
19 19862.855469 L p 4000000 MEMNODE2 com_71
10 19862.865234 S 680 B
10 19862.865234 S 680 chol_model_22
10 19866.201172 S 65 B
10 19866.203125 S 680 Po
10 19866.205078 S 680 B
13 19866.214844 ntask sched 13.000000
10 19866.216797 S 680 Fi
10 19866.218750 S 680 B
10 19866.218750 S 680 chol_model_22
10 19869.537109 S 65 B
10 19869.537109 S 680 Po
10 19869.539062 S 680 B
13 19869.548828 ntask sched 12.000000
10 19869.550781 S 680 Fi
10 19869.550781 S 680 B
10 19869.552734 S 680 chol_model_22
10 19872.773438 S 65 B
10 19872.773438 S 680 Po
10 19872.775391 S 680 B
13 19872.783203 ntask sched 11.000000
10 19872.785156 S 680 Fi
10 19872.787109 S 680 B
10 19872.787109 S 680 chol_model_22
10 19876.078125 S 65 B
10 19876.078125 S 680 Po
10 19876.080078 S 680 B
13 19876.087891 ntask sched 10.000000
10 19876.089844 S 680 Fi
10 19876.091797 S 680 B
10 19876.093750 S 680 chol_model_22
10 19879.322266 S 65 B
10 19879.324219 S 680 Po
10 19879.326172 S 680 B
13 19879.333984 ntask sched 9.000000
10 19879.335938 S 680 Fi
10 19879.337891 S 680 B
10 19879.337891 S 680 chol_model_22
10 19882.570312 S 65 B
10 19882.570312 S 680 Po
10 19882.572266 S 680 B
13 19882.582031 ntask sched 8.000000
10 19882.582031 S 680 Fi
10 19882.585938 S 680 B
10 19882.585938 S 680 chol_model_22
10 19885.882812 S 65 B
10 19885.882812 S 680 Po
10 19885.884766 S 680 B
13 19885.892578 ntask sched 7.000000
10 19885.894531 S 680 Fi
10 19885.896484 S 680 B
10 19885.896484 S 680 chol_model_22
10 19889.230469 S 65 B
10 19889.232422 S 680 Po
10 19889.234375 S 680 B
13 19889.242188 ntask sched 6.000000
10 19889.244141 S 680 Fi
10 19889.246094 S 680 B
10 19889.246094 S 680 chol_model_22
10 19892.546875 S 65 B
10 19892.548828 S 680 Po
10 19892.550781 S 680 B
13 19892.558594 ntask sched 5.000000
10 19892.560547 S 680 Fi
10 19892.560547 S 680 B
10 19892.562500 S 680 chol_model_22
10 19895.777344 S 65 B
10 19895.777344 S 680 Po
10 19895.779297 S 680 B
13 19895.787109 ntask sched 4.000000
10 19895.789062 S 680 Fi
10 19895.791016 S 680 B
10 19895.794922 S 680 chol_model_21
10 19904.035156 S 65 B
10 19904.037109 S 680 Po
10 19904.039062 S 680 B
13 19904.080078 ntask sched 5.000000
13 19904.113281 ntask sched 6.000000
13 19904.146484 ntask sched 7.000000
13 19904.177734 ntask sched 8.000000
13 19904.207031 ntask sched 9.000000
13 19904.238281 ntask sched 10.000000
13 19904.269531 ntask sched 11.000000
13 19904.298828 ntask sched 12.000000
13 19904.328125 ntask sched 13.000000
13 19904.359375 ntask sched 14.000000
13 19904.390625 ntask sched 15.000000
10 19904.396484 MS MEMNODE2 A
10 19904.533203 MS MEMNODE2 No
10 19904.535156 MS MEMNODE2 Co
18 19904.535156 L p 4000000 MEMNODE0 com_72
10 19904.541016 MS MEMNODE2 CoA
10 19905.779297 MS MEMNODE2 No
19 19905.779297 L p 2273874960 MEMNODE2 com_2273874768
10 19905.783203 MS MEMNODE2 A
10 19905.917969 MS MEMNODE2 No
10 19905.919922 MS MEMNODE2 Co
18 19905.919922 L p 4000000 MEMNODE0 com_73
10 19905.939453 MS MEMNODE2 CoA
10 19907.212891 MS MEMNODE2 No
19 19907.212891 L p 2273874960 MEMNODE2 com_2273874768
10 19907.218750 MS MEMNODE2 A
10 19907.353516 MS MEMNODE2 No
10 19907.355469 MS MEMNODE2 Co
18 19907.355469 L p 4000000 MEMNODE0 com_74
10 19907.363281 MS MEMNODE2 CoA
10 19908.632812 MS MEMNODE2 No
19 19908.632812 L p 2273874960 MEMNODE2 com_2273874768
10 19908.638672 MS MEMNODE2 A
10 19908.773438 MS MEMNODE2 No
10 19908.775391 MS MEMNODE2 Co
18 19908.775391 L p 4000000 MEMNODE0 com_75
10 19908.781250 MS MEMNODE2 CoA
10 19910.042969 MS MEMNODE2 No
19 19910.042969 L p 2273874960 MEMNODE2 com_2273874768
10 19910.048828 MS MEMNODE2 A
10 19910.183594 MS MEMNODE2 No
10 19910.185547 MS MEMNODE2 Co
18 19910.185547 L p 4000000 MEMNODE0 com_76
10 19910.191406 MS MEMNODE2 CoA
10 19911.570312 MS MEMNODE2 No
19 19911.570312 L p 2273874960 MEMNODE2 com_2273874768
10 19911.576172 MS MEMNODE2 A
10 19911.708984 MS MEMNODE2 No
10 19911.712891 MS MEMNODE2 Co
18 19911.712891 L p 4000000 MEMNODE0 com_77
10 19911.716797 MS MEMNODE2 CoA
10 19912.984375 MS MEMNODE2 No
19 19912.984375 L p 2273874960 MEMNODE2 com_2273874768
10 19912.990234 MS MEMNODE2 A
10 19913.123047 MS MEMNODE2 No
10 19913.125000 MS MEMNODE2 Co
18 19913.125000 L p 4000000 MEMNODE0 com_78
10 19913.130859 MS MEMNODE2 CoA
10 19914.390625 MS MEMNODE2 No
19 19914.390625 L p 2273874960 MEMNODE2 com_2273874768
10 19914.396484 MS MEMNODE2 A
10 19914.539062 MS MEMNODE2 No
10 19914.542969 MS MEMNODE2 Co
18 19914.542969 L p 4000000 MEMNODE0 com_79
10 19914.548828 MS MEMNODE2 CoA
10 19915.810547 MS MEMNODE2 No
19 19915.810547 L p 2273874960 MEMNODE2 com_2273874768
10 19915.814453 MS MEMNODE2 A
10 19915.949219 MS MEMNODE2 No
10 19915.951172 MS MEMNODE2 Co
18 19915.951172 L p 4000000 MEMNODE0 com_80
10 19915.957031 MS MEMNODE2 CoA
10 19917.224609 MS MEMNODE2 No
19 19917.224609 L p 2273874960 MEMNODE2 com_2273874768
10 19917.228516 MS MEMNODE2 A
10 19917.363281 MS MEMNODE2 No
10 19917.365234 MS MEMNODE2 Co
18 19917.365234 L p 4000000 MEMNODE0 com_81
10 19917.371094 MS MEMNODE2 CoA
10 19918.644531 MS MEMNODE2 No
19 19918.644531 L p 2273874960 MEMNODE2 com_2273874768
10 19918.650391 MS MEMNODE2 A
10 19918.783203 MS MEMNODE2 No
10 19918.785156 MS MEMNODE2 Co
18 19918.785156 L p 4000000 MEMNODE0 com_82
10 19918.792969 MS MEMNODE2 CoA
10 19920.056641 MS MEMNODE2 No
19 19920.056641 L p 2273874960 MEMNODE2 com_2273874768
13 19920.064453 ntask sched 14.000000
10 19920.066406 S 680 Fi
10 19920.105469 MS MEMNODE2 No
19 19920.105469 L p 4000000 MEMNODE2 com_81
10 19920.132812 MS MEMNODE2 No
19 19920.132812 L p 4000000 MEMNODE2 com_80
10 19920.156250 MS MEMNODE2 No
19 19920.156250 L p 4000000 MEMNODE2 com_79
10 19920.179688 MS MEMNODE2 No
19 19920.179688 L p 4000000 MEMNODE2 com_78
10 19920.203125 MS MEMNODE2 No
19 19920.203125 L p 4000000 MEMNODE2 com_77
10 19920.228516 MS MEMNODE2 No
19 19920.228516 L p 4000000 MEMNODE2 com_76
10 19920.253906 MS MEMNODE2 No
19 19920.253906 L p 4000000 MEMNODE2 com_75
10 19920.277344 MS MEMNODE2 No
19 19920.277344 L p 4000000 MEMNODE2 com_74
10 19920.300781 MS MEMNODE2 No
19 19920.300781 L p 4000000 MEMNODE2 com_73
10 19920.324219 MS MEMNODE2 No
19 19920.324219 L p 4000000 MEMNODE2 com_72
10 19920.349609 MS MEMNODE2 No
19 19920.349609 L p 4000000 MEMNODE2 com_82
10 19920.351562 S 680 B
10 19920.351562 S 680 chol_model_22
10 19923.611328 S 65 B
10 19923.613281 S 680 Po
10 19923.615234 S 680 B
13 19923.626953 ntask sched 13.000000
10 19923.628906 S 680 Fi
10 19923.630859 S 680 B
10 19923.630859 S 680 chol_model_22
10 19926.958984 S 65 B
10 19926.958984 S 680 Po
10 19926.962891 S 680 B
13 19926.970703 ntask sched 12.000000
10 19926.972656 S 680 Fi
10 19926.972656 S 680 B
10 19926.974609 S 680 chol_model_22
10 19930.248047 S 65 B
10 19930.250000 S 680 Po
10 19930.251953 S 680 B
13 19930.259766 ntask sched 11.000000
10 19930.261719 S 680 Fi
10 19930.263672 S 680 B
10 19930.263672 S 680 chol_model_22
10 19933.582031 S 65 B
10 19933.583984 S 680 Po
10 19933.585938 S 680 B
13 19933.593750 ntask sched 10.000000
10 19933.595703 S 680 Fi
10 19933.597656 S 680 B
10 19933.597656 S 680 chol_model_22
10 19936.832031 S 65 B
10 19936.832031 S 680 Po
10 19936.833984 S 680 B
13 19936.841797 ntask sched 9.000000
10 19936.843750 S 680 Fi
10 19936.845703 S 680 B
10 19936.845703 S 680 chol_model_22
10 19940.078125 S 65 B
10 19940.080078 S 680 Po
10 19940.082031 S 680 B
13 19940.091797 ntask sched 8.000000
10 19940.093750 S 680 Fi
10 19940.095703 S 680 B
10 19940.095703 S 680 chol_model_22
10 19943.398438 S 65 B
10 19943.398438 S 680 Po
10 19943.400391 S 680 B
13 19943.408203 ntask sched 7.000000
10 19943.410156 S 680 Fi
10 19943.412109 S 680 B
10 19943.412109 S 680 chol_model_22
10 19946.736328 S 65 B
10 19946.736328 S 680 Po
10 19946.738281 S 680 B
13 19946.746094 ntask sched 6.000000
10 19946.748047 S 680 Fi
10 19946.748047 S 680 B
10 19946.750000 S 680 chol_model_22
10 19950.019531 S 65 B
10 19950.019531 S 680 Po
10 19950.021484 S 680 B
13 19950.029297 ntask sched 5.000000
10 19950.031250 S 680 Fi
10 19950.033203 S 680 B
10 19950.033203 S 680 chol_model_22
10 19953.330078 S 65 B
10 19953.332031 S 680 Po
10 19953.333984 S 680 B
13 19953.341797 ntask sched 4.000000
10 19953.343750 S 680 Fi
10 19953.345703 S 680 B
10 19953.345703 S 680 chol_model_22
10 19956.603516 S 65 B
10 19956.605469 S 680 Po
10 19956.605469 S 680 B
13 19956.615234 ntask sched 3.000000
10 19956.615234 S 680 Fi
10 19956.617188 S 680 B
10 19956.621094 S 680 chol_model_21
10 19964.841797 S 65 B
10 19964.843750 S 680 Po
10 19964.845703 S 680 B
13 19964.886719 ntask sched 4.000000
13 19964.917969 ntask sched 5.000000
13 19964.947266 ntask sched 6.000000
13 19964.978516 ntask sched 7.000000
13 19965.009766 ntask sched 8.000000
13 19965.039062 ntask sched 9.000000
13 19965.070312 ntask sched 10.000000
13 19965.101562 ntask sched 11.000000
13 19965.134766 ntask sched 12.000000
13 19965.162109 ntask sched 13.000000
13 19965.193359 ntask sched 14.000000
13 19965.224609 ntask sched 15.000000
10 19965.228516 MS MEMNODE2 A
10 19965.363281 MS MEMNODE2 No
10 19965.365234 MS MEMNODE2 Co
18 19965.365234 L p 4000000 MEMNODE0 com_83
10 19965.371094 MS MEMNODE2 CoA
10 19966.621094 MS MEMNODE2 No
19 19966.621094 L p 2273874960 MEMNODE2 com_2273874768
10 19966.626953 MS MEMNODE2 A
10 19966.775391 MS MEMNODE2 No
10 19966.777344 MS MEMNODE2 Co
18 19966.777344 L p 4000000 MEMNODE0 com_84
10 19966.787109 MS MEMNODE2 CoA
10 19968.050781 MS MEMNODE2 No
19 19968.050781 L p 2273874960 MEMNODE2 com_2273874768
10 19968.056641 MS MEMNODE2 A
10 19968.201172 MS MEMNODE2 No
10 19968.203125 MS MEMNODE2 Co
18 19968.203125 L p 4000000 MEMNODE0 com_85
10 19968.214844 MS MEMNODE2 CoA
10 19969.480469 MS MEMNODE2 No
19 19969.480469 L p 2273874960 MEMNODE2 com_2273874768
10 19969.484375 MS MEMNODE2 A
10 19969.626953 MS MEMNODE2 No
10 19969.628906 MS MEMNODE2 Co
18 19969.628906 L p 4000000 MEMNODE0 com_86
10 19969.634766 MS MEMNODE2 CoA
10 19970.898438 MS MEMNODE2 No
19 19970.898438 L p 2273874960 MEMNODE2 com_2273874768
10 19970.904297 MS MEMNODE2 A
10 19971.037109 MS MEMNODE2 No
10 19971.039062 MS MEMNODE2 Co
18 19971.039062 L p 4000000 MEMNODE0 com_87
10 19971.046875 MS MEMNODE2 CoA
10 19972.310547 MS MEMNODE2 No
19 19972.310547 L p 2273874960 MEMNODE2 com_2273874768
10 19972.316406 MS MEMNODE2 A
10 19972.449219 MS MEMNODE2 No
10 19972.451172 MS MEMNODE2 Co
18 19972.451172 L p 4000000 MEMNODE0 com_88
10 19972.457031 MS MEMNODE2 CoA
10 19973.726562 MS MEMNODE2 No
19 19973.726562 L p 2273874960 MEMNODE2 com_2273874768
10 19973.730469 MS MEMNODE2 A
10 19973.865234 MS MEMNODE2 No
10 19973.867188 MS MEMNODE2 Co
18 19973.867188 L p 4000000 MEMNODE0 com_89
10 19973.888672 MS MEMNODE2 CoA
10 19975.160156 MS MEMNODE2 No
19 19975.160156 L p 2273874960 MEMNODE2 com_2273874768
10 19975.166016 MS MEMNODE2 A
10 19975.306641 MS MEMNODE2 No
10 19975.308594 MS MEMNODE2 Co
18 19975.308594 L p 4000000 MEMNODE0 com_90
10 19975.322266 MS MEMNODE2 CoA
10 19976.595703 MS MEMNODE2 No
19 19976.595703 L p 2273874960 MEMNODE2 com_2273874768
10 19976.599609 MS MEMNODE2 A
10 19976.742188 MS MEMNODE2 No
10 19976.744141 MS MEMNODE2 Co
18 19976.744141 L p 4000000 MEMNODE0 com_91
10 19976.757812 MS MEMNODE2 CoA
10 19978.019531 MS MEMNODE2 No
19 19978.019531 L p 2273874960 MEMNODE2 com_2273874768
10 19978.023438 MS MEMNODE2 A
10 19978.173828 MS MEMNODE2 No
10 19978.175781 MS MEMNODE2 Co
18 19978.175781 L p 4000000 MEMNODE0 com_92
10 19978.189453 MS MEMNODE2 CoA
10 19979.455078 MS MEMNODE2 No
19 19979.455078 L p 2273874960 MEMNODE2 com_2273874768
10 19979.460938 MS MEMNODE2 A
10 19979.613281 MS MEMNODE2 No
10 19979.615234 MS MEMNODE2 Co
18 19979.615234 L p 4000000 MEMNODE0 com_93
10 19979.621094 MS MEMNODE2 CoA
10 19980.890625 MS MEMNODE2 No
19 19980.890625 L p 2273874960 MEMNODE2 com_2273874768
10 19980.894531 MS MEMNODE2 A
10 19981.027344 MS MEMNODE2 No
10 19981.031250 MS MEMNODE2 Co
18 19981.031250 L p 4000000 MEMNODE0 com_94
10 19981.035156 MS MEMNODE2 CoA
10 19982.304688 MS MEMNODE2 No
19 19982.304688 L p 2273874960 MEMNODE2 com_2273874768
13 19982.312500 ntask sched 14.000000
10 19982.314453 S 680 Fi
10 19982.353516 MS MEMNODE2 No
19 19982.353516 L p 4000000 MEMNODE2 com_93
10 19982.378906 MS MEMNODE2 No
19 19982.378906 L p 4000000 MEMNODE2 com_92
10 19982.402344 MS MEMNODE2 No
19 19982.402344 L p 4000000 MEMNODE2 com_91
10 19982.427734 MS MEMNODE2 No
19 19982.427734 L p 4000000 MEMNODE2 com_90
10 19982.451172 MS MEMNODE2 No
19 19982.451172 L p 4000000 MEMNODE2 com_89
10 19982.476562 MS MEMNODE2 No
19 19982.476562 L p 4000000 MEMNODE2 com_88
10 19982.501953 MS MEMNODE2 No
19 19982.501953 L p 4000000 MEMNODE2 com_87
10 19982.531250 MS MEMNODE2 No
19 19982.531250 L p 4000000 MEMNODE2 com_86
10 19982.554688 MS MEMNODE2 No
19 19982.554688 L p 4000000 MEMNODE2 com_85
10 19982.576172 MS MEMNODE2 No
19 19982.576172 L p 4000000 MEMNODE2 com_84
10 19982.601562 MS MEMNODE2 No
19 19982.601562 L p 4000000 MEMNODE2 com_83
10 19982.625000 MS MEMNODE2 No
19 19982.625000 L p 4000000 MEMNODE2 com_94
10 19982.626953 S 680 B
10 19982.628906 S 680 chol_model_22
10 19985.951172 S 65 B
10 19985.953125 S 680 Po
10 19985.955078 S 680 B
13 19985.966797 ntask sched 13.000000
10 19985.968750 S 680 Fi
10 19985.970703 S 680 B
10 19985.970703 S 680 chol_model_22
10 19989.179688 S 65 B
10 19989.181641 S 680 Po
10 19989.183594 S 680 B
13 19989.191406 ntask sched 12.000000
10 19989.193359 S 680 Fi
10 19989.195312 S 680 B
10 19989.195312 S 680 chol_model_22
10 19992.482422 S 65 B
10 19992.482422 S 680 Po
10 19992.484375 S 680 B
13 19992.494141 ntask sched 11.000000
10 19992.496094 S 680 Fi
10 19992.498047 S 680 B
10 19992.498047 S 680 chol_model_22
10 19995.806641 S 65 B
10 19995.806641 S 680 Po
10 19995.808594 S 680 B
13 19995.816406 ntask sched 10.000000
10 19995.818359 S 680 Fi
10 19995.820312 S 680 B
10 19995.820312 S 680 chol_model_22
10 19999.044922 S 65 B
10 19999.044922 S 680 Po
10 19999.046875 S 680 B
13 19999.054688 ntask sched 9.000000
10 19999.056641 S 680 Fi
10 19999.058594 S 680 B
10 19999.058594 S 680 chol_model_22
10 20002.373047 S 65 B
10 20002.375000 S 680 Po
10 20002.376953 S 680 B
13 20002.386719 ntask sched 8.000000
10 20002.388672 S 680 Fi
10 20002.388672 S 680 B
10 20002.390625 S 680 chol_model_22
10 20005.705078 S 65 B
10 20005.705078 S 680 Po
10 20005.707031 S 680 B
13 20005.716797 ntask sched 7.000000
10 20005.718750 S 680 Fi
10 20005.720703 S 680 B
10 20005.720703 S 680 chol_model_22
10 20008.955078 S 65 B
10 20008.957031 S 680 Po
10 20008.958984 S 680 B
13 20008.966797 ntask sched 6.000000
10 20008.968750 S 680 Fi
10 20008.970703 S 680 B
10 20008.970703 S 680 chol_model_22
10 20012.291016 S 65 B
10 20012.292969 S 680 Po
10 20012.294922 S 680 B
13 20012.300781 ntask sched 5.000000
10 20012.302734 S 680 Fi
10 20012.304688 S 680 B
10 20012.304688 S 680 chol_model_22
10 20015.566406 S 65 B
10 20015.568359 S 680 Po
10 20015.570312 S 680 B
13 20015.578125 ntask sched 4.000000
10 20015.580078 S 680 Fi
10 20015.582031 S 680 B
10 20015.582031 S 680 chol_model_22
10 20018.865234 S 65 B
10 20018.867188 S 680 Po
10 20018.869141 S 680 B
13 20018.876953 ntask sched 3.000000
10 20018.878906 S 680 Fi
10 20018.878906 S 680 B
10 20018.880859 S 680 chol_model_22
10 20022.070312 S 65 B
10 20022.070312 S 680 Po
10 20022.072266 S 680 B
13 20022.080078 ntask sched 2.000000
10 20022.082031 S 680 Fi
10 20022.083984 S 680 B
10 20022.087891 S 680 chol_model_21
10 20030.296875 S 65 B
10 20030.298828 S 680 Po
10 20030.300781 S 680 B
13 20030.343750 ntask sched 3.000000
13 20030.373047 ntask sched 4.000000
13 20030.402344 ntask sched 5.000000
13 20030.433594 ntask sched 6.000000
13 20030.462891 ntask sched 7.000000
13 20030.492188 ntask sched 8.000000
13 20030.529297 ntask sched 9.000000
13 20030.560547 ntask sched 10.000000
13 20030.591797 ntask sched 11.000000
13 20030.621094 ntask sched 12.000000
13 20030.650391 ntask sched 13.000000
13 20030.681641 ntask sched 14.000000
13 20030.712891 ntask sched 15.000000
10 20030.718750 MS MEMNODE2 A
10 20030.853516 MS MEMNODE2 No
10 20030.855469 MS MEMNODE2 Co
18 20030.855469 L p 4000000 MEMNODE0 com_95
10 20030.859375 MS MEMNODE2 CoA
10 20032.107422 MS MEMNODE2 No
19 20032.107422 L p 2273874960 MEMNODE2 com_2273874768
10 20032.111328 MS MEMNODE2 A
10 20032.246094 MS MEMNODE2 No
10 20032.248047 MS MEMNODE2 Co
18 20032.248047 L p 4000000 MEMNODE0 com_96
10 20032.255859 MS MEMNODE2 CoA
10 20033.529297 MS MEMNODE2 No
19 20033.529297 L p 2273874960 MEMNODE2 com_2273874768
10 20033.533203 MS MEMNODE2 A
10 20042.501953 MS MEMNODE2 No
10 20042.503906 MS MEMNODE2 Co
18 20042.503906 L p 4000000 MEMNODE0 com_97
10 20042.515625 MS MEMNODE2 CoA
10 20043.779297 MS MEMNODE2 No
19 20043.779297 L p 2273874960 MEMNODE2 com_2273874768
10 20043.783203 MS MEMNODE2 A
10 20043.919922 MS MEMNODE2 No
10 20043.921875 MS MEMNODE2 Co
18 20043.921875 L p 4000000 MEMNODE0 com_98
10 20043.927734 MS MEMNODE2 CoA
10 20045.201172 MS MEMNODE2 No
19 20045.201172 L p 2273874960 MEMNODE2 com_2273874768
10 20045.205078 MS MEMNODE2 A
10 20045.343750 MS MEMNODE2 No
10 20045.345703 MS MEMNODE2 Co
18 20045.345703 L p 4000000 MEMNODE0 com_99
10 20045.351562 MS MEMNODE2 CoA
10 20046.623047 MS MEMNODE2 No
19 20046.623047 L p 2273874960 MEMNODE2 com_2273874768
10 20046.628906 MS MEMNODE2 A
10 20046.765625 MS MEMNODE2 No
10 20046.767578 MS MEMNODE2 Co
18 20046.767578 L p 4000000 MEMNODE0 com_100
10 20046.773438 MS MEMNODE2 CoA
10 20048.033203 MS MEMNODE2 No
19 20048.033203 L p 2273874960 MEMNODE2 com_2273874768
10 20048.037109 MS MEMNODE2 A
10 20048.177734 MS MEMNODE2 No
10 20048.181641 MS MEMNODE2 Co
18 20048.181641 L p 4000000 MEMNODE0 com_101
10 20048.201172 MS MEMNODE2 CoA
10 20049.468750 MS MEMNODE2 No
19 20049.468750 L p 2273874960 MEMNODE2 com_2273874768
10 20049.472656 MS MEMNODE2 A
10 20049.617188 MS MEMNODE2 No
10 20049.619141 MS MEMNODE2 Co
18 20049.619141 L p 4000000 MEMNODE0 com_102
10 20049.634766 MS MEMNODE2 CoA
10 20050.916016 MS MEMNODE2 No
19 20050.916016 L p 2273874960 MEMNODE2 com_2273874768
10 20050.921875 MS MEMNODE2 A
10 20051.068359 MS MEMNODE2 No
10 20051.070312 MS MEMNODE2 Co
18 20051.070312 L p 4000000 MEMNODE0 com_103
10 20051.083984 MS MEMNODE2 CoA
10 20052.349609 MS MEMNODE2 No
19 20052.349609 L p 2273874960 MEMNODE2 com_2273874768
10 20052.355469 MS MEMNODE2 A
10 20052.503906 MS MEMNODE2 No
10 20052.505859 MS MEMNODE2 Co
18 20052.505859 L p 4000000 MEMNODE0 com_104
10 20052.519531 MS MEMNODE2 CoA
10 20053.767578 MS MEMNODE2 No
19 20053.767578 L p 2273874960 MEMNODE2 com_2273874768
10 20053.771484 MS MEMNODE2 A
10 20053.912109 MS MEMNODE2 No
10 20053.914062 MS MEMNODE2 Co
18 20053.914062 L p 4000000 MEMNODE0 com_105
10 20053.919922 MS MEMNODE2 CoA
10 20055.183594 MS MEMNODE2 No
19 20055.183594 L p 2273874960 MEMNODE2 com_2273874768
10 20055.187500 MS MEMNODE2 A
10 20055.326172 MS MEMNODE2 No
10 20055.328125 MS MEMNODE2 Co
18 20055.328125 L p 4000000 MEMNODE0 com_106
10 20055.345703 MS MEMNODE2 CoA
10 20056.617188 MS MEMNODE2 No
19 20056.617188 L p 2273874960 MEMNODE2 com_2273874768
10 20056.621094 MS MEMNODE2 A
10 20056.759766 MS MEMNODE2 No
10 20056.761719 MS MEMNODE2 Co
18 20056.761719 L p 4000000 MEMNODE0 com_107
10 20056.777344 MS MEMNODE2 CoA
10 20058.042969 MS MEMNODE2 No
19 20058.042969 L p 2273874960 MEMNODE2 com_2273874768
13 20058.050781 ntask sched 14.000000
10 20058.052734 S 680 Fi
10 20058.091797 MS MEMNODE2 No
19 20058.091797 L p 4000000 MEMNODE2 com_106
10 20058.117188 MS MEMNODE2 No
19 20058.117188 L p 4000000 MEMNODE2 com_105
10 20058.142578 MS MEMNODE2 No
19 20058.142578 L p 4000000 MEMNODE2 com_104
10 20058.167969 MS MEMNODE2 No
19 20058.167969 L p 4000000 MEMNODE2 com_103
10 20058.191406 MS MEMNODE2 No
19 20058.191406 L p 4000000 MEMNODE2 com_102
10 20058.214844 MS MEMNODE2 No
19 20058.214844 L p 4000000 MEMNODE2 com_101
10 20058.238281 MS MEMNODE2 No
19 20058.238281 L p 4000000 MEMNODE2 com_100
10 20058.261719 MS MEMNODE2 No
19 20058.261719 L p 4000000 MEMNODE2 com_99
10 20058.283203 MS MEMNODE2 No
19 20058.283203 L p 4000000 MEMNODE2 com_98
10 20058.306641 MS MEMNODE2 No
19 20058.306641 L p 4000000 MEMNODE2 com_97
10 20058.330078 MS MEMNODE2 No
19 20058.330078 L p 4000000 MEMNODE2 com_96
10 20058.353516 MS MEMNODE2 No
19 20058.353516 L p 4000000 MEMNODE2 com_95
10 20058.376953 MS MEMNODE2 No
19 20058.376953 L p 4000000 MEMNODE2 com_107
10 20058.378906 S 680 B
10 20058.380859 S 680 chol_model_22
10 20061.746094 S 65 B
10 20061.746094 S 680 Po
10 20061.750000 S 680 B
13 20061.759766 ntask sched 13.000000
10 20061.761719 S 680 Fi
10 20061.763672 S 680 B
10 20061.763672 S 680 chol_model_22
10 20065.003906 S 65 B
10 20065.005859 S 680 Po
10 20065.007812 S 680 B
13 20065.015625 ntask sched 12.000000
10 20065.017578 S 680 Fi
10 20065.019531 S 680 B
10 20065.019531 S 680 chol_model_22
10 20068.335938 S 65 B
10 20068.335938 S 680 Po
10 20068.337891 S 680 B
13 20068.345703 ntask sched 11.000000
10 20068.347656 S 680 Fi
10 20068.349609 S 680 B
10 20068.349609 S 680 chol_model_22
10 20071.589844 S 65 B
10 20071.591797 S 680 Po
10 20071.593750 S 680 B
13 20071.601562 ntask sched 10.000000
10 20071.601562 S 680 Fi
10 20071.603516 S 680 B
10 20071.605469 S 680 chol_model_22
10 20074.843750 S 65 B
10 20074.843750 S 680 Po
10 20074.845703 S 680 B
13 20074.853516 ntask sched 9.000000
10 20074.855469 S 680 Fi
10 20074.857422 S 680 B
10 20074.857422 S 680 chol_model_22
10 20078.103516 S 65 B
10 20078.103516 S 680 Po
10 20078.105469 S 680 B
13 20078.113281 ntask sched 8.000000
10 20078.115234 S 680 Fi
10 20078.117188 S 680 B
10 20078.117188 S 680 chol_model_22
10 20081.402344 S 65 B
10 20081.402344 S 680 Po
10 20081.404297 S 680 B
13 20081.412109 ntask sched 7.000000
10 20081.412109 S 680 Fi
10 20081.414062 S 680 B
10 20081.416016 S 680 chol_model_22
10 20084.660156 S 65 B
10 20084.660156 S 680 Po
10 20084.662109 S 680 B
13 20084.671875 ntask sched 6.000000
10 20084.673828 S 680 Fi
10 20084.675781 S 680 B
10 20084.675781 S 680 chol_model_22
10 20087.980469 S 65 B
10 20087.980469 S 680 Po
10 20087.982422 S 680 B
13 20087.990234 ntask sched 5.000000
10 20087.992188 S 680 Fi
10 20087.992188 S 680 B
10 20087.994141 S 680 chol_model_22
10 20091.187500 S 65 B
10 20091.187500 S 680 Po
10 20091.189453 S 680 B
13 20091.197266 ntask sched 4.000000
10 20091.199219 S 680 Fi
10 20091.201172 S 680 B
10 20091.201172 S 680 chol_model_22
10 20094.498047 S 65 B
10 20094.498047 S 680 Po
10 20094.500000 S 680 B
13 20094.507812 ntask sched 3.000000
10 20094.515625 S 680 Fi
10 20094.517578 S 680 B
10 20094.517578 S 680 chol_model_22
10 20097.845703 S 65 B
10 20097.847656 S 680 Po
10 20097.849609 S 680 B
13 20097.857422 ntask sched 2.000000
10 20097.859375 S 680 Fi
10 20097.861328 S 680 B
10 20097.861328 S 680 chol_model_22
10 20101.150391 S 65 B
10 20101.150391 S 680 Po
10 20101.152344 S 680 B
13 20101.160156 ntask sched 1.000000
10 20101.162109 S 680 Fi
10 20101.162109 S 680 B
10 20101.166016 S 680 chol_model_21
10 20109.378906 S 65 B
10 20109.380859 S 680 Po
10 20109.382812 S 680 B
13 20109.423828 ntask sched 2.000000
13 20109.453125 ntask sched 3.000000
13 20109.484375 ntask sched 4.000000
13 20109.519531 ntask sched 5.000000
13 20109.550781 ntask sched 6.000000
13 20109.580078 ntask sched 7.000000
13 20109.611328 ntask sched 8.000000
13 20109.642578 ntask sched 9.000000
13 20109.671875 ntask sched 10.000000
13 20109.701172 ntask sched 11.000000
13 20109.732422 ntask sched 12.000000
13 20109.763672 ntask sched 13.000000
13 20109.792969 ntask sched 14.000000
13 20109.822266 ntask sched 15.000000
10 20109.828125 MS MEMNODE2 A
10 20109.966797 MS MEMNODE2 No
10 20109.968750 MS MEMNODE2 Co
18 20109.968750 L p 4000000 MEMNODE0 com_108
10 20109.974609 MS MEMNODE2 CoA
10 20111.220703 MS MEMNODE2 No
19 20111.220703 L p 2273874960 MEMNODE2 com_2273874768
10 20111.224609 MS MEMNODE2 A
10 20111.361328 MS MEMNODE2 No
10 20111.363281 MS MEMNODE2 Co
18 20111.363281 L p 4000000 MEMNODE0 com_109
10 20111.369141 MS MEMNODE2 CoA
10 20112.642578 MS MEMNODE2 No
19 20112.642578 L p 2273874960 MEMNODE2 com_2273874768
10 20112.646484 MS MEMNODE2 A
10 20112.783203 MS MEMNODE2 No
10 20112.785156 MS MEMNODE2 Co
18 20112.785156 L p 4000000 MEMNODE0 com_110
10 20112.791016 MS MEMNODE2 CoA
10 20114.060547 MS MEMNODE2 No
19 20114.060547 L p 2273874960 MEMNODE2 com_2273874768
10 20114.066406 MS MEMNODE2 A
10 20114.212891 MS MEMNODE2 No
10 20114.214844 MS MEMNODE2 Co
18 20114.214844 L p 4000000 MEMNODE0 com_111
10 20114.220703 MS MEMNODE2 CoA
10 20115.482422 MS MEMNODE2 No
19 20115.482422 L p 2273874960 MEMNODE2 com_2273874768
10 20115.486328 MS MEMNODE2 A
10 20115.630859 MS MEMNODE2 No
10 20115.632812 MS MEMNODE2 Co
18 20115.632812 L p 4000000 MEMNODE0 com_112
10 20115.638672 MS MEMNODE2 CoA
10 20116.902344 MS MEMNODE2 No
19 20116.902344 L p 2273874960 MEMNODE2 com_2273874768
10 20116.908203 MS MEMNODE2 A
10 20117.046875 MS MEMNODE2 No
10 20117.048828 MS MEMNODE2 Co
18 20117.048828 L p 4000000 MEMNODE0 com_113
10 20117.054688 MS MEMNODE2 CoA
10 20118.326172 MS MEMNODE2 No
19 20118.326172 L p 2273874960 MEMNODE2 com_2273874768
10 20118.332031 MS MEMNODE2 A
10 20118.472656 MS MEMNODE2 No
10 20118.474609 MS MEMNODE2 Co
18 20118.474609 L p 4000000 MEMNODE0 com_114
10 20118.496094 MS MEMNODE2 CoA
10 20119.765625 MS MEMNODE2 No
19 20119.765625 L p 2273874960 MEMNODE2 com_2273874768
10 20119.771484 MS MEMNODE2 A
10 20119.914062 MS MEMNODE2 No
10 20119.917969 MS MEMNODE2 Co
18 20119.917969 L p 4000000 MEMNODE0 com_115
10 20119.923828 MS MEMNODE2 CoA
10 20121.187500 MS MEMNODE2 No
19 20121.187500 L p 2273874960 MEMNODE2 com_2273874768
10 20121.193359 MS MEMNODE2 A
10 20121.332031 MS MEMNODE2 No
10 20121.333984 MS MEMNODE2 Co
18 20121.333984 L p 4000000 MEMNODE0 com_116
10 20121.339844 MS MEMNODE2 CoA
10 20122.613281 MS MEMNODE2 No
19 20122.613281 L p 2273874960 MEMNODE2 com_2273874768
10 20122.617188 MS MEMNODE2 A
10 20122.759766 MS MEMNODE2 No
10 20122.763672 MS MEMNODE2 Co
18 20122.763672 L p 4000000 MEMNODE0 com_117
10 20122.767578 MS MEMNODE2 CoA
10 20124.029297 MS MEMNODE2 No
19 20124.029297 L p 2273874960 MEMNODE2 com_2273874768
10 20124.033203 MS MEMNODE2 A
10 20124.179688 MS MEMNODE2 No
10 20124.181641 MS MEMNODE2 Co
18 20124.181641 L p 4000000 MEMNODE0 com_118
10 20124.187500 MS MEMNODE2 CoA
10 20125.449219 MS MEMNODE2 No
19 20125.449219 L p 2273874960 MEMNODE2 com_2273874768
10 20125.455078 MS MEMNODE2 A
10 20125.601562 MS MEMNODE2 No
10 20125.605469 MS MEMNODE2 Co
18 20125.605469 L p 4000000 MEMNODE0 com_119
10 20125.611328 MS MEMNODE2 CoA
10 20126.876953 MS MEMNODE2 No
19 20126.876953 L p 2273874960 MEMNODE2 com_2273874768
10 20126.882812 MS MEMNODE2 A
10 20127.023438 MS MEMNODE2 No
10 20127.025391 MS MEMNODE2 Co
18 20127.025391 L p 4000000 MEMNODE0 com_120
10 20127.046875 MS MEMNODE2 CoA
10 20128.314453 MS MEMNODE2 No
19 20128.314453 L p 2273874960 MEMNODE2 com_2273874768
10 20128.318359 MS MEMNODE2 A
10 20128.458984 MS MEMNODE2 No
10 20128.462891 MS MEMNODE2 Co
18 20128.462891 L p 4000000 MEMNODE0 com_121
10 20128.474609 MS MEMNODE2 CoA
10 20129.746094 MS MEMNODE2 No
19 20129.746094 L p 2273874960 MEMNODE2 com_2273874768
13 20129.753906 ntask sched 14.000000
10 20129.755859 S 680 Fi
10 20129.794922 MS MEMNODE2 No
19 20129.794922 L p 4000000 MEMNODE2 com_120
10 20129.820312 MS MEMNODE2 No
19 20129.820312 L p 4000000 MEMNODE2 com_119
10 20129.845703 MS MEMNODE2 No
19 20129.845703 L p 4000000 MEMNODE2 com_118
10 20129.869141 MS MEMNODE2 No
19 20129.869141 L p 4000000 MEMNODE2 com_117
10 20129.894531 MS MEMNODE2 No
19 20129.894531 L p 4000000 MEMNODE2 com_116
10 20129.917969 MS MEMNODE2 No
19 20129.917969 L p 4000000 MEMNODE2 com_115
10 20129.941406 MS MEMNODE2 No
19 20129.941406 L p 4000000 MEMNODE2 com_114
10 20129.964844 MS MEMNODE2 No
19 20129.964844 L p 4000000 MEMNODE2 com_113
10 20129.988281 MS MEMNODE2 No
19 20129.988281 L p 4000000 MEMNODE2 com_112
10 20130.011719 MS MEMNODE2 No
19 20130.011719 L p 4000000 MEMNODE2 com_111
10 20130.035156 MS MEMNODE2 No
19 20130.035156 L p 4000000 MEMNODE2 com_110
10 20130.060547 MS MEMNODE2 No
19 20130.060547 L p 4000000 MEMNODE2 com_109
10 20130.082031 MS MEMNODE2 No
19 20130.082031 L p 4000000 MEMNODE2 com_108
10 20130.109375 MS MEMNODE2 No
19 20130.109375 L p 4000000 MEMNODE2 com_121
10 20130.111328 S 680 B
10 20130.113281 S 680 chol_model_22
10 20133.406250 S 65 B
10 20133.408203 S 680 Po
10 20133.410156 S 680 B
13 20133.419922 ntask sched 13.000000
10 20133.421875 S 680 Fi
10 20133.423828 S 680 B
10 20133.423828 S 680 chol_model_22
10 20136.736328 S 65 B
10 20136.736328 S 680 Po
10 20136.738281 S 680 B
13 20136.746094 ntask sched 12.000000
10 20136.748047 S 680 Fi
10 20136.748047 S 680 B
10 20136.750000 S 680 chol_model_22
10 20139.976562 S 65 B
10 20139.976562 S 680 Po
10 20139.978516 S 680 B
13 20139.986328 ntask sched 11.000000
10 20139.988281 S 680 Fi
10 20139.990234 S 680 B
10 20139.990234 S 680 chol_model_22
10 20143.273438 S 65 B
10 20143.273438 S 680 Po
10 20143.275391 S 680 B
13 20143.283203 ntask sched 10.000000
10 20143.285156 S 680 Fi
10 20143.287109 S 680 B
10 20143.287109 S 680 chol_model_22
10 20146.607422 S 65 B
10 20146.607422 S 680 Po
10 20146.609375 S 680 B
13 20146.617188 ntask sched 9.000000
10 20146.619141 S 680 Fi
10 20146.621094 S 680 B
10 20146.621094 S 680 chol_model_22
10 20149.849609 S 65 B
10 20149.849609 S 680 Po
10 20149.851562 S 680 B
13 20149.861328 ntask sched 8.000000
10 20149.863281 S 680 Fi
10 20149.863281 S 680 B
10 20149.865234 S 680 chol_model_22
10 20153.152344 S 65 B
10 20153.154297 S 680 Po
10 20153.156250 S 680 B
13 20153.164062 ntask sched 7.000000
10 20153.167969 S 680 Fi
10 20153.167969 S 680 B
10 20153.169922 S 680 chol_model_22
10 20156.398438 S 65 B
10 20156.400391 S 680 Po
10 20156.402344 S 680 B
13 20156.408203 ntask sched 6.000000
10 20156.410156 S 680 Fi
10 20156.412109 S 680 B
10 20156.412109 S 680 chol_model_22
10 20159.732422 S 65 B
10 20159.734375 S 680 Po
10 20159.736328 S 680 B
13 20159.744141 ntask sched 5.000000
10 20159.746094 S 680 Fi
10 20159.748047 S 680 B
10 20159.748047 S 680 chol_model_22
10 20163.072266 S 65 B
10 20163.072266 S 680 Po
10 20163.074219 S 680 B
13 20163.082031 ntask sched 4.000000
10 20163.083984 S 680 Fi
10 20163.087891 S 680 B
10 20163.087891 S 680 chol_model_22
10 20166.388672 S 65 B
10 20166.388672 S 680 Po
10 20166.390625 S 680 B
13 20166.398438 ntask sched 3.000000
10 20166.400391 S 680 Fi
10 20166.402344 S 680 B
10 20166.402344 S 680 chol_model_22
10 20169.703125 S 65 B
10 20169.705078 S 680 Po
10 20169.705078 S 680 B
13 20169.714844 ntask sched 2.000000
10 20169.716797 S 680 Fi
10 20169.718750 S 680 B
10 20169.718750 S 680 chol_model_22
10 20173.003906 S 65 B
10 20173.005859 S 680 Po
10 20173.007812 S 680 B
13 20173.013672 ntask sched 1.000000
10 20173.015625 S 680 Fi
10 20173.017578 S 680 B
10 20173.017578 S 680 chol_model_22
10 20176.314453 S 65 B
10 20176.316406 S 680 Po
10 20176.318359 S 680 B
13 20176.324219 ntask sched 0.000000
10 20176.326172 S 680 Fi
10 20176.328125 S 680 B
10 20176.330078 S 680 chol_model_21
10 20184.546875 S 65 B
10 20184.548828 S 680 Po
10 20184.550781 S 680 B
13 20184.591797 ntask sched 1.000000
13 20184.621094 ntask sched 2.000000
13 20184.650391 ntask sched 3.000000
13 20184.681641 ntask sched 4.000000
13 20184.712891 ntask sched 5.000000
13 20184.742188 ntask sched 6.000000
13 20184.773438 ntask sched 7.000000
13 20184.804688 ntask sched 8.000000
13 20184.835938 ntask sched 9.000000
13 20184.865234 ntask sched 10.000000
13 20184.896484 ntask sched 11.000000
13 20184.927734 ntask sched 12.000000
13 20184.957031 ntask sched 13.000000
13 20184.986328 ntask sched 14.000000
13 20185.017578 ntask sched 15.000000
10 20185.023438 MS MEMNODE2 A
10 20185.169922 MS MEMNODE2 No
10 20185.171875 MS MEMNODE2 Co
18 20185.171875 L p 4000000 MEMNODE0 com_122
10 20185.177734 MS MEMNODE2 CoA
10 20186.421875 MS MEMNODE2 No
19 20186.421875 L p 2273874960 MEMNODE2 com_2273874768
10 20186.425781 MS MEMNODE2 A
10 20186.574219 MS MEMNODE2 No
10 20186.576172 MS MEMNODE2 Co
18 20186.576172 L p 4000000 MEMNODE0 com_123
10 20186.582031 MS MEMNODE2 CoA
10 20187.847656 MS MEMNODE2 No
19 20187.847656 L p 2273874960 MEMNODE2 com_2273874768
10 20187.851562 MS MEMNODE2 A
10 20187.992188 MS MEMNODE2 No
10 20187.994141 MS MEMNODE2 Co
18 20187.994141 L p 4000000 MEMNODE0 com_124
10 20187.998047 MS MEMNODE2 CoA
10 20189.269531 MS MEMNODE2 No
19 20189.269531 L p 2273874960 MEMNODE2 com_2273874768
10 20189.273438 MS MEMNODE2 A
10 20189.417969 MS MEMNODE2 No
10 20189.419922 MS MEMNODE2 Co
18 20189.419922 L p 4000000 MEMNODE0 com_125
10 20189.425781 MS MEMNODE2 CoA
10 20190.697266 MS MEMNODE2 No
19 20190.697266 L p 2273874960 MEMNODE2 com_2273874768
10 20190.703125 MS MEMNODE2 A
10 20190.847656 MS MEMNODE2 No
10 20190.849609 MS MEMNODE2 Co
18 20190.849609 L p 4000000 MEMNODE0 com_126
10 20190.857422 MS MEMNODE2 CoA
10 20192.126953 MS MEMNODE2 No
19 20192.126953 L p 2273874960 MEMNODE2 com_2273874768
10 20192.130859 MS MEMNODE2 A
10 20192.273438 MS MEMNODE2 No
10 20192.277344 MS MEMNODE2 Co
18 20192.277344 L p 4000000 MEMNODE0 com_127
10 20192.281250 MS MEMNODE2 CoA
10 20193.552734 MS MEMNODE2 No
19 20193.552734 L p 2273874960 MEMNODE2 com_2273874768
10 20193.558594 MS MEMNODE2 A
10 20193.714844 MS MEMNODE2 No
10 20193.716797 MS MEMNODE2 Co
18 20193.716797 L p 4000000 MEMNODE0 com_128
10 20193.728516 MS MEMNODE2 CoA
10 20194.990234 MS MEMNODE2 No
19 20194.990234 L p 2273874960 MEMNODE2 com_2273874768
10 20194.996094 MS MEMNODE2 A
10 20195.150391 MS MEMNODE2 No
10 20195.152344 MS MEMNODE2 Co
18 20195.152344 L p 4000000 MEMNODE0 com_129
10 20195.162109 MS MEMNODE2 CoA
10 20196.423828 MS MEMNODE2 No
19 20196.423828 L p 2273874960 MEMNODE2 com_2273874768
10 20196.429688 MS MEMNODE2 A
10 20205.351562 MS MEMNODE2 No
10 20205.353516 MS MEMNODE2 Co
18 20205.353516 L p 4000000 MEMNODE0 com_130
10 20205.365234 MS MEMNODE2 CoA
10 20206.640625 MS MEMNODE2 No
19 20206.640625 L p 2273874960 MEMNODE2 com_2273874768
10 20206.644531 MS MEMNODE2 A
10 20206.798828 MS MEMNODE2 No
10 20206.800781 MS MEMNODE2 Co
18 20206.800781 L p 4000000 MEMNODE0 com_131
10 20206.812500 MS MEMNODE2 CoA
10 20208.076172 MS MEMNODE2 No
19 20208.076172 L p 2273874960 MEMNODE2 com_2273874768
10 20208.082031 MS MEMNODE2 A
10 20208.236328 MS MEMNODE2 No
10 20208.238281 MS MEMNODE2 Co
18 20208.238281 L p 4000000 MEMNODE0 com_132
10 20208.250000 MS MEMNODE2 CoA
10 20209.525391 MS MEMNODE2 No
19 20209.525391 L p 2273874960 MEMNODE2 com_2273874768
10 20209.531250 MS MEMNODE2 A
10 20209.685547 MS MEMNODE2 No
10 20209.687500 MS MEMNODE2 Co
18 20209.687500 L p 4000000 MEMNODE0 com_133
10 20209.697266 MS MEMNODE2 CoA
10 20210.964844 MS MEMNODE2 No
19 20210.964844 L p 2273874960 MEMNODE2 com_2273874768
10 20210.968750 MS MEMNODE2 A
10 20211.121094 MS MEMNODE2 No
10 20211.123047 MS MEMNODE2 Co
18 20211.123047 L p 4000000 MEMNODE0 com_134
10 20211.136719 MS MEMNODE2 CoA
10 20212.400391 MS MEMNODE2 No
19 20212.400391 L p 2273874960 MEMNODE2 com_2273874768
10 20212.406250 MS MEMNODE2 A
10 20212.562500 MS MEMNODE2 No
10 20212.566406 MS MEMNODE2 Co
18 20212.566406 L p 4000000 MEMNODE0 com_135
10 20212.576172 MS MEMNODE2 CoA
10 20213.839844 MS MEMNODE2 No
19 20213.839844 L p 2273874960 MEMNODE2 com_2273874768
10 20213.845703 MS MEMNODE2 A
10 20213.994141 MS MEMNODE2 No
10 20213.996094 MS MEMNODE2 Co
18 20213.996094 L p 4000000 MEMNODE0 com_136
10 20214.007812 MS MEMNODE2 CoA
10 20215.275391 MS MEMNODE2 No
19 20215.275391 L p 2273874960 MEMNODE2 com_2273874768
13 20215.283203 ntask sched 14.000000
10 20215.285156 S 680 Fi
10 20215.324219 MS MEMNODE2 No
19 20215.324219 L p 4000000 MEMNODE2 com_135
10 20215.349609 MS MEMNODE2 No
19 20215.349609 L p 4000000 MEMNODE2 com_134
10 20215.373047 MS MEMNODE2 No
19 20215.373047 L p 4000000 MEMNODE2 com_133
10 20215.396484 MS MEMNODE2 No
19 20215.396484 L p 4000000 MEMNODE2 com_132
10 20215.421875 MS MEMNODE2 No
19 20215.421875 L p 4000000 MEMNODE2 com_131
10 20215.445312 MS MEMNODE2 No
19 20215.445312 L p 4000000 MEMNODE2 com_130
10 20215.468750 MS MEMNODE2 No
19 20215.468750 L p 4000000 MEMNODE2 com_129
10 20215.492188 MS MEMNODE2 No
19 20215.492188 L p 4000000 MEMNODE2 com_128
10 20215.521484 MS MEMNODE2 No
19 20215.521484 L p 4000000 MEMNODE2 com_127
10 20215.544922 MS MEMNODE2 No
19 20215.544922 L p 4000000 MEMNODE2 com_126
10 20215.568359 MS MEMNODE2 No
19 20215.568359 L p 4000000 MEMNODE2 com_125
10 20215.593750 MS MEMNODE2 No
19 20215.593750 L p 4000000 MEMNODE2 com_124
10 20215.615234 MS MEMNODE2 No
19 20215.615234 L p 4000000 MEMNODE2 com_123
10 20215.638672 MS MEMNODE2 No
19 20215.638672 L p 4000000 MEMNODE2 com_122
10 20215.662109 MS MEMNODE2 No
19 20215.662109 L p 4000000 MEMNODE2 com_136
10 20215.664062 S 680 B
10 20215.666016 S 680 chol_model_22
10 20218.933594 S 65 B
10 20218.935547 S 680 Po
10 20218.939453 S 680 B
13 20218.949219 ntask sched 13.000000
10 20218.951172 S 680 Fi
10 20218.953125 S 680 B
10 20218.953125 S 680 chol_model_22
10 20222.216797 S 65 B
10 20222.218750 S 680 Po
10 20222.220703 S 680 B
13 20222.228516 ntask sched 12.000000
10 20222.228516 S 680 Fi
10 20222.230469 S 680 B
10 20222.230469 S 680 chol_model_22
10 20225.451172 S 65 B
10 20225.451172 S 680 Po
10 20225.453125 S 680 B
13 20225.462891 ntask sched 11.000000
10 20225.462891 S 680 Fi
10 20225.464844 S 680 B
10 20225.466797 S 680 chol_model_22
10 20228.677734 S 65 B
10 20228.679688 S 680 Po
10 20228.681641 S 680 B
13 20228.687500 ntask sched 10.000000
10 20228.689453 S 680 Fi
10 20228.691406 S 680 B
10 20228.691406 S 680 chol_model_22
10 20231.880859 S 65 B
10 20231.880859 S 680 Po
10 20231.882812 S 680 B
13 20231.890625 ntask sched 9.000000
10 20231.892578 S 680 Fi
10 20231.894531 S 680 B
10 20231.894531 S 680 chol_model_22
10 20235.128906 S 65 B
10 20235.130859 S 680 Po
10 20235.132812 S 680 B
13 20235.140625 ntask sched 8.000000
10 20235.140625 S 680 Fi
10 20235.142578 S 680 B
10 20235.144531 S 680 chol_model_22
10 20238.388672 S 65 B
10 20238.388672 S 680 Po
10 20238.390625 S 680 B
13 20238.398438 ntask sched 7.000000
10 20238.400391 S 680 Fi
10 20238.402344 S 680 B
10 20238.402344 S 680 chol_model_22
10 20241.710938 S 65 B
10 20241.712891 S 680 Po
10 20241.714844 S 680 B
13 20241.722656 ntask sched 6.000000
10 20241.724609 S 680 Fi
10 20241.724609 S 680 B
10 20241.726562 S 680 chol_model_22
10 20244.957031 S 65 B
10 20244.958984 S 680 Po
10 20244.960938 S 680 B
13 20244.968750 ntask sched 5.000000
10 20244.970703 S 680 Fi
10 20244.970703 S 680 B
10 20244.972656 S 680 chol_model_22
10 20248.189453 S 65 B
10 20248.189453 S 680 Po
10 20248.191406 S 680 B
13 20248.199219 ntask sched 4.000000
10 20248.201172 S 680 Fi
10 20248.203125 S 680 B
10 20248.203125 S 680 chol_model_22
10 20251.435547 S 65 B
10 20251.435547 S 680 Po
10 20251.437500 S 680 B
13 20251.445312 ntask sched 3.000000
10 20251.447266 S 680 Fi
10 20251.449219 S 680 B
10 20251.449219 S 680 chol_model_22
10 20254.757812 S 65 B
10 20254.759766 S 680 Po
10 20254.761719 S 680 B
13 20254.769531 ntask sched 2.000000
10 20254.769531 S 680 Fi
10 20254.771484 S 680 B
10 20254.771484 S 680 chol_model_22
10 20257.996094 S 65 B
10 20257.996094 S 680 Po
10 20257.998047 S 680 B
13 20258.007812 ntask sched 1.000000
10 20258.007812 S 680 Fi
10 20258.009766 S 680 B
10 20258.011719 S 680 chol_model_22
10 20261.216797 S 65 B
10 20261.216797 S 680 Po
10 20261.218750 S 680 B
13 20261.226562 ntask sched 0.000000
10 20261.228516 S 680 Fi
10 20261.230469 S 680 B
10 20261.230469 S 680 chol_model_22
10 20264.503906 S 65 B
10 20264.505859 S 680 Po
10 20264.507812 S 680 B
13 20264.550781 ntask sched 1.000000
13 20264.556641 ntask sched 0.000000
10 20264.556641 S 680 Fi
10 20264.558594 S 680 B
10 20264.560547 S 680 chol_model_11
10 20264.560547 S 65 B
10 20264.562500 S 680 Po
10 20264.564453 S 680 B
13 20264.603516 ntask sched 1.000000
13 20264.632813 ntask sched 2.000000
13 20264.662110 ntask sched 3.000000
13 20264.664063 ntask sched 2.000000
10 20264.666016 S 679 Fi
13 20264.691407 ntask sched 3.000000
13 20264.718750 ntask sched 4.000000
13 20264.748047 ntask sched 5.000000
13 20264.775391 ntask sched 6.000000
13 20264.802735 ntask sched 7.000000
13 20264.830078 ntask sched 8.000000
13 20264.857422 ntask sched 9.000000
13 20264.886719 ntask sched 10.000000
13 20264.914063 ntask sched 11.000000
10 20264.916016 MS MEMNODE0 Co
18 20264.916016 L p 4000000 MEMNODE2 com_137
13 20264.916016 ntask sched 10.000000
10 20264.919922 S 681 Fi
10 20264.925781 MS MEMNODE0 CoA
13 20264.943360 ntask sched 11.000000
10 20264.945313 MS MEMNODE0 Co
18 20264.945313 L p 4000000 MEMNODE2 com_138
13 20264.972657 ntask sched 12.000000
10 20264.974610 MS MEMNODE0 Co
18 20264.974610 L p 4000000 MEMNODE2 com_139
10 20264.978516 MS MEMNODE0 Co
18 20264.978516 L p 4000000 MEMNODE2 com_140
13 20264.992188 ntask sched 11.000000
10 20264.994141 S 683 Fi
10 20266.955078 MS MEMNODE0 No
19 20266.955078 L p 2273874960 MEMNODE0 com_2273874768
10 20266.966797 MS MEMNODE0 CoA
10 20266.974610 MS MEMNODE0 CoA
10 20268.472657 MS MEMNODE0 No
19 20268.472657 L p 2273874960 MEMNODE0 com_2273874768
10 20268.492188 MS MEMNODE0 CoA
13 20268.501953 ntask sched 10.000000
10 20268.503907 S 682 Fi
10 20270.039063 MS MEMNODE0 No
19 20270.039063 L p 2273874960 MEMNODE0 com_2273874768
10 20272.048828 MS MEMNODE0 No
19 20272.048828 L p 2273874968 MEMNODE0 com_2273874768
10 20272.058594 MS MEMNODE0 No
19 20272.058594 L p 4000000 MEMNODE0 com_138
10 20272.060547 MS MEMNODE0 Co
18 20272.060547 L p 4000000 MEMNODE2 com_141
10 20272.062500 MS MEMNODE0 No
19 20272.062500 L p 4000000 MEMNODE0 com_137
10 20272.066407 MS MEMNODE0 CoA
10 20274.095703 MS MEMNODE0 No
19 20274.095703 L p 2273874960 MEMNODE0 com_2273874768
10 20274.099610 MS MEMNODE0 No
19 20274.099610 L p 4000000 MEMNODE0 com_139
10 20274.103516 MS MEMNODE0 Co
18 20274.103516 L p 4000000 MEMNODE2 com_142
10 20274.109375 MS MEMNODE0 CoA
10 20276.123047 MS MEMNODE0 No
19 20276.123047 L p 2273874960 MEMNODE0 com_2273874768
10 20276.130860 MS MEMNODE0 Co
18 20276.130860 L p 4000000 MEMNODE2 com_143
10 20276.136719 MS MEMNODE0 CoA
10 20278.150391 MS MEMNODE0 No
19 20278.150391 L p 2273874960 MEMNODE0 com_2273874768
10 20278.156250 MS MEMNODE0 Co
18 20278.156250 L p 4000000 MEMNODE2 com_144
10 20278.162110 MS MEMNODE0 CoA
10 20280.189453 MS MEMNODE0 No
19 20280.189453 L p 2273874960 MEMNODE0 com_2273874768
13 20280.197266 ntask sched 9.000000
10 20280.199219 S 680 Fi
10 20280.201172 S 680 B
10 20280.232422 S 680 chol_model_21
10 20288.478516 S 65 B
10 20288.480469 S 680 Po
10 20288.480469 S 680 B
13 20288.519531 ntask sched 10.000000
10 20288.527344 MS MEMNODE0 No
19 20288.527344 L p 4000000 MEMNODE0 com_144
10 20288.529297 MS MEMNODE1 A
10 20288.529297 MS MEMNODE0 No
19 20288.529297 L p 4000000 MEMNODE0 com_143
10 20288.533203 MS MEMNODE0 No
19 20288.533203 L p 4000000 MEMNODE0 com_142
10 20288.535157 MS MEMNODE0 No
19 20288.535157 L p 4000000 MEMNODE0 com_141
10 20288.537110 MS MEMNODE0 No
19 20288.537110 L p 4000000 MEMNODE0 com_140
10 20288.539063 MS MEMNODE0 Co
18 20288.539063 L p 4000000 MEMNODE2 com_145
10 20288.544922 MS MEMNODE0 CoA
10 20288.701172 MS MEMNODE1 No
10 20288.705078 MS MEMNODE1 Co
18 20288.705078 L p 4000000 MEMNODE0 com_146
10 20288.712891 MS MEMNODE1 CoA
10 20290.037110 MS MEMNODE1 No
19 20290.037110 L p 2273874960 MEMNODE1 com_2273874768
10 20290.044922 MS MEMNODE1 A
10 20290.162110 MS MEMNODE1 No
10 20290.164063 MS MEMNODE1 Co
18 20290.164063 L p 4000000 MEMNODE0 com_147
10 20290.169922 MS MEMNODE1 CoA
10 20290.593750 MS MEMNODE0 No
19 20290.593750 L p 2273874960 MEMNODE0 com_2273874768
13 20290.601563 ntask sched 9.000000
10 20290.601563 S 680 Fi
10 20290.603516 S 680 B
10 20290.605469 S 680 chol_model_22
10 20291.367188 MS MEMNODE1 No
19 20291.367188 L p 2273874960 MEMNODE1 com_2273874768
10 20291.373047 MS MEMNODE1 A
10 20291.500000 MS MEMNODE1 No
10 20291.503907 MS MEMNODE1 Co
18 20291.503907 L p 4000000 MEMNODE0 com_148
10 20291.507813 MS MEMNODE1 CoA
10 20292.669922 MS MEMNODE1 No
19 20292.669922 L p 2273874960 MEMNODE1 com_2273874768
10 20292.675781 MS MEMNODE1 A
10 20292.802735 MS MEMNODE1 No
10 20292.804688 MS MEMNODE1 Co
18 20292.804688 L p 4000000 MEMNODE0 com_149
10 20292.822266 MS MEMNODE1 CoA
10 20293.835938 S 65 B
10 20293.837891 S 680 Po
10 20293.839844 S 680 B
10 20293.871094 MS MEMNODE0 No
19 20293.871094 L p 4000000 MEMNODE0 com_145
10 20293.871094 S 681 B
10 20293.873047 S 683 B
13 20293.873047 ntask sched 8.000000
10 20293.873047 S 682 B
10 20293.873047 S 681 chol_model_21
10 20293.873047 S 680 Fi
10 20293.873047 S 683 chol_model_21
10 20293.875000 S 682 chol_model_21
10 20293.875000 S 680 B
10 20293.878907 S 680 chol_model_21
10 20293.984375 MS MEMNODE1 No
19 20293.984375 L p 2273874960 MEMNODE1 com_2273874768
10 20293.990235 MS MEMNODE1 A
10 20294.117188 MS MEMNODE1 No
10 20294.119141 MS MEMNODE1 Co
18 20294.119141 L p 4000000 MEMNODE0 com_150
10 20294.126953 MS MEMNODE1 CoA
10 20295.289063 MS MEMNODE1 No
19 20295.289063 L p 2273874960 MEMNODE1 com_2273874768
10 20295.328125 MS MEMNODE1 No
19 20295.328125 L p 4000000 MEMNODE1 com_149
10 20295.353516 MS MEMNODE1 No
19 20295.353516 L p 4000000 MEMNODE1 com_148
10 20295.376953 MS MEMNODE1 No
19 20295.376953 L p 4000000 MEMNODE1 com_147
10 20295.400391 MS MEMNODE1 No
19 20295.400391 L p 4000000 MEMNODE1 com_146
10 20295.402344 MS MEMNODE1 A
10 20295.521485 MS MEMNODE1 No
10 20295.523438 MS MEMNODE1 Co
18 20295.523438 L p 4000000 MEMNODE0 com_151
10 20295.531250 MS MEMNODE1 CoA
10 20296.693360 MS MEMNODE1 No
19 20296.693360 L p 2273874960 MEMNODE1 com_2273874768
10 20296.734375 MS MEMNODE1 No
19 20296.734375 L p 4000000 MEMNODE1 com_150
10 20296.884766 MS MEMNODE1 No
19 20296.884766 L p 4000000 MEMNODE1 com_151
10 20296.884766 S 679 B
10 20296.890625 S 679 chol_model_21
10 20302.138672 S 65 B
10 20302.142578 S 680 Po
10 20302.144531 S 680 B
13 20302.185547 ntask sched 9.000000
13 20302.214844 ntask sched 10.000000
13 20302.220703 ntask sched 9.000000
10 20302.222657 S 680 Fi
10 20302.222657 S 680 B
10 20302.224610 S 680 chol_model_22
10 20305.222657 S 64 B
10 20305.226563 S 679 Po
10 20305.228516 S 679 B
13 20305.269531 ntask sched 10.000000
13 20305.296875 ntask sched 11.000000
13 20305.324219 ntask sched 12.000000
10 20305.330078 MS MEMNODE0 Co
18 20305.330078 L p 4000000 MEMNODE1 com_152
10 20305.335938 MS MEMNODE0 CoA
10 20305.595703 S 65 B
10 20305.597657 S 680 Po
10 20305.599610 S 680 B
13 20305.607422 ntask sched 11.000000
10 20305.609375 S 680 Fi
10 20306.769531 MS MEMNODE0 No
19 20306.769531 L p 2273874960 MEMNODE0 com_2273874768
13 20306.777344 ntask sched 10.000000
10 20306.779297 S 679 Fi
10 20306.781250 S 679 B
10 20306.810547 S 679 chol_model_21
10 20315.119141 S 64 B
10 20315.121094 S 679 Po
10 20315.123047 S 679 B
13 20315.158203 ntask sched 11.000000
13 20315.185547 ntask sched 12.000000
13 20315.214844 ntask sched 13.000000
13 20315.240235 ntask sched 14.000000
10 20315.248047 MS MEMNODE0 No
19 20315.248047 L p 4000000 MEMNODE0 com_152
10 20315.251953 MS MEMNODE0 Co
18 20315.251953 L p 4000000 MEMNODE1 com_153
10 20315.253907 MS MEMNODE2 Co
18 20315.253907 L p 4000000 MEMNODE0 com_154
10 20315.255860 MS MEMNODE0 CoA
10 20315.271485 MS MEMNODE2 CoA
10 20316.679688 MS MEMNODE2 No
19 20316.679688 L p 2273874960 MEMNODE2 com_2273874768
10 20316.761719 MS MEMNODE0 No
19 20316.761719 L p 2273874968 MEMNODE0 com_2273874768
13 20316.767578 ntask sched 13.000000
10 20316.769531 S 679 Fi
10 20316.771485 S 679 B
10 20316.808594 S 679 chol_model_21
10 20316.875000 MS MEMNODE2 No
19 20316.875000 L p 4000000 MEMNODE2 com_154
10 20316.878907 S 680 B
10 20316.880860 S 680 chol_model_22
10 20320.207031 S 65 B
10 20320.208985 S 680 Po
10 20320.212891 S 680 B
13 20320.222657 ntask sched 12.000000
10 20320.224610 S 680 Fi
10 20325.115235 S 64 B
10 20325.117188 S 679 Po
10 20325.119141 S 679 B
13 20325.154297 ntask sched 13.000000
13 20325.183594 ntask sched 14.000000
13 20325.208985 ntask sched 15.000000
13 20325.238281 ntask sched 16.000000
13 20325.267578 ntask sched 17.000000
10 20325.275391 MS MEMNODE0 No
19 20325.275391 L p 4000000 MEMNODE0 com_153
10 20325.277344 MS MEMNODE2 Co
18 20325.277344 L p 4000000 MEMNODE0 com_155
10 20325.277344 MS MEMNODE0 Co
18 20325.277344 L p 4000000 MEMNODE1 com_156
10 20325.281250 MS MEMNODE0 CoA
10 20325.296875 MS MEMNODE2 CoA
10 20326.714844 MS MEMNODE2 No
19 20326.714844 L p 2273874960 MEMNODE2 com_2273874768
10 20326.808594 MS MEMNODE0 No
19 20326.808594 L p 2273874968 MEMNODE0 com_2273874768
13 20326.814453 ntask sched 16.000000
10 20326.816407 S 679 Fi
10 20326.818360 S 679 B
10 20326.855469 S 679 chol_model_21
10 20326.910157 MS MEMNODE2 No
19 20326.910157 L p 4000000 MEMNODE2 com_155
10 20326.916016 S 680 B
10 20326.917969 S 680 chol_model_22
10 20330.244141 S 65 B
10 20330.246094 S 680 Po
10 20330.248047 S 680 B
13 20330.259766 ntask sched 15.000000
10 20330.261719 S 680 Fi
10 20335.164063 S 64 B
10 20335.164063 S 679 Po
10 20335.166016 S 679 B
13 20335.201172 ntask sched 16.000000
13 20335.230469 ntask sched 17.000000
13 20335.259766 ntask sched 18.000000
13 20335.287110 ntask sched 19.000000
13 20335.314453 ntask sched 20.000000
13 20335.341797 ntask sched 21.000000
10 20335.349610 MS MEMNODE0 No
19 20335.349610 L p 4000000 MEMNODE0 com_156
10 20335.351563 MS MEMNODE0 Co
18 20335.351563 L p 4000000 MEMNODE1 com_157
10 20335.351563 MS MEMNODE2 Co
18 20335.351563 L p 4000000 MEMNODE0 com_158
10 20335.361328 MS MEMNODE0 CoA
10 20335.367188 MS MEMNODE2 CoA
10 20336.707031 MS MEMNODE2 No
19 20336.707031 L p 2273874960 MEMNODE2 com_2273874768
10 20336.890625 MS MEMNODE0 No
19 20336.890625 L p 2273874968 MEMNODE0 com_2273874768
13 20336.896485 ntask sched 20.000000
10 20336.898438 S 679 Fi
10 20336.900391 S 679 B
10 20336.902344 MS MEMNODE2 No
19 20336.902344 L p 4000000 MEMNODE2 com_158
10 20336.906250 S 680 B
10 20336.908203 S 680 chol_model_22
10 20336.931641 S 679 chol_model_21
10 20340.232422 S 65 B
10 20340.234375 S 680 Po
10 20340.236328 S 680 B
13 20340.246094 ntask sched 19.000000
10 20340.248047 S 680 Fi
10 20345.244141 S 64 B
10 20345.246094 S 679 Po
10 20345.246094 S 679 B
13 20345.281250 ntask sched 20.000000
10 20345.302735 S 0 B
10 20345.304688 S 682 Po
10 20345.306641 S 682 B
13 20345.310547 ntask sched 21.000000
13 20345.339844 ntask sched 22.000000
13 20345.349610 ntask sched 23.000000
10 20345.349610 MS MEMNODE2 Co
18 20345.349610 L p 4000000 MEMNODE0 com_159
10 20345.359375 MS MEMNODE2 CoA
13 20345.367188 ntask sched 24.000000
13 20345.392578 ntask sched 25.000000
13 20345.419922 ntask sched 26.000000
13 20345.453125 ntask sched 27.000000
10 20345.458985 MS MEMNODE0 No
19 20345.458985 L p 4000000 MEMNODE0 com_157
10 20345.462891 MS MEMNODE0 Co
18 20345.462891 L p 4000000 MEMNODE1 com_160
10 20345.466797 MS MEMNODE0 CoA
10 20345.527344 S 0 B
10 20345.529297 S 683 Po
10 20345.531250 S 683 B
10 20345.550781 S 0 B
10 20345.552735 S 681 Po
10 20345.554688 S 681 B
13 20345.568360 ntask sched 28.000000
13 20345.593750 ntask sched 29.000000
13 20345.597657 ntask sched 30.000000
13 20345.628907 ntask sched 31.000000
13 20345.656250 ntask sched 32.000000
13 20345.685547 ntask sched 33.000000
13 20345.712891 ntask sched 34.000000
13 20345.742188 ntask sched 35.000000
10 20346.660157 MS MEMNODE2 No
19 20346.660157 L p 2273874960 MEMNODE2 com_2273874768
10 20346.667969 MS MEMNODE2 Co
18 20346.667969 L p 4000000 MEMNODE0 com_161
10 20346.675781 MS MEMNODE2 CoA
10 20347.031250 MS MEMNODE0 No
19 20347.031250 L p 2273874960 MEMNODE0 com_2273874768
13 20347.070313 ntask sched 36.000000
13 20347.082031 ntask sched 37.000000
13 20347.099610 ntask sched 38.000000
10 20347.136719 MS MEMNODE0 No
19 20347.136719 L p 4000000 MEMNODE0 com_160
10 20347.990235 MS MEMNODE2 No
19 20347.990235 L p 0 MEMNODE2 com_0
10 20347.996094 MS MEMNODE2 Co
18 20347.996094 L p 4000000 MEMNODE0 com_162
10 20348.005860 MS MEMNODE2 CoA
13 20348.007813 ntask sched 39.000000
13 20348.042969 ntask sched 40.000000
13 20348.044922 ntask sched 41.000000
13 20348.072266 ntask sched 42.000000
13 20348.076172 ntask sched 43.000000
13 20348.105469 ntask sched 44.000000
13 20348.107422 ntask sched 45.000000
13 20348.134766 ntask sched 46.000000
13 20348.138672 ntask sched 47.000000
13 20348.166016 ntask sched 48.000000
13 20348.167969 ntask sched 49.000000
13 20348.197266 ntask sched 50.000000
13 20348.224610 ntask sched 51.000000
10 20349.269531 MS MEMNODE2 No
19 20349.269531 L p 2273874960 MEMNODE2 com_2273874768
10 20349.273438 MS MEMNODE2 Co
18 20349.273438 L p 4000000 MEMNODE0 com_163
10 20349.279297 MS MEMNODE2 CoA
13 20349.314453 ntask sched 52.000000
10 20350.560547 MS MEMNODE2 No
19 20350.560547 L p 2273874960 MEMNODE2 com_2273874768
10 20350.566407 MS MEMNODE2 Co
18 20350.566407 L p 4000000 MEMNODE0 com_164
10 20350.572266 MS MEMNODE2 CoA
13 20350.578125 ntask sched 53.000000
10 20351.853516 MS MEMNODE2 No
19 20351.853516 L p 2273874960 MEMNODE2 com_2273874768
10 20351.890625 MS MEMNODE2 No
19 20351.890625 L p 4000000 MEMNODE2 com_163
10 20351.914063 MS MEMNODE2 No
19 20351.914063 L p 4000000 MEMNODE2 com_162
10 20351.939453 MS MEMNODE2 No
19 20351.939453 L p 4000000 MEMNODE2 com_161
10 20351.964844 MS MEMNODE2 No
19 20351.964844 L p 4000000 MEMNODE2 com_159
10 20351.968750 S 680 B
10 20351.968750 S 680 chol_model_22
10 20355.314453 S 65 B
10 20355.316407 S 680 Po
10 20355.318360 S 680 B
10 20355.351563 MS MEMNODE2 No
19 20355.351563 L p 4000000 MEMNODE2 com_164
13 20355.353516 ntask sched 52.000000
10 20355.355469 S 680 Fi
10 20355.359375 S 680 B
10 20355.359375 S 680 chol_model_22
10 20358.666016 S 65 B
10 20358.666016 S 680 Po
10 20358.669922 S 680 B
13 20358.675781 ntask sched 51.000000
10 20358.677735 S 680 Fi
10 20358.679688 S 680 B
10 20358.679688 S 680 chol_model_22
10 20361.910157 S 65 B
10 20361.912110 S 680 Po
10 20361.914063 S 680 B
13 20361.921875 ntask sched 50.000000
10 20361.923828 S 680 Fi
10 20361.925781 S 680 B
10 20361.925781 S 680 chol_model_22
10 20365.166016 S 65 B
10 20365.167969 S 680 Po
10 20365.169922 S 680 B
13 20365.177735 ntask sched 49.000000
10 20365.177735 S 680 Fi
10 20365.179688 S 680 B
10 20365.181641 S 680 chol_model_22
10 20368.460938 S 65 B
10 20368.460938 S 680 Po
10 20368.462891 S 680 B
13 20368.470703 ntask sched 48.000000
10 20368.472657 S 680 Fi
10 20368.474610 S 680 B
10 20368.474610 S 680 chol_model_22
10 20371.792969 S 65 B
10 20371.794922 S 680 Po
10 20371.794922 S 680 B
13 20371.802735 ntask sched 47.000000
10 20371.804688 S 680 Fi
10 20371.806641 S 680 B
10 20371.806641 S 680 chol_model_22
10 20375.046875 S 65 B
10 20375.046875 S 680 Po
10 20375.048828 S 680 B
13 20375.054688 ntask sched 46.000000
10 20375.056641 S 680 Fi
10 20375.058594 S 680 B
10 20375.060547 S 680 chol_model_22
10 20378.392578 S 65 B
10 20378.394531 S 680 Po
10 20378.394531 S 680 B
13 20378.402344 ntask sched 45.000000
10 20378.404297 S 680 Fi
10 20378.406250 S 680 B
10 20378.406250 S 680 chol_model_22
10 20381.742188 S 65 B
10 20381.742188 S 680 Po
10 20381.746094 S 680 B
13 20381.753907 ntask sched 44.000000
10 20381.753907 S 680 Fi
10 20381.755860 S 680 B
10 20381.757813 S 680 chol_model_22
10 20385.050781 S 65 B
10 20385.052735 S 680 Po
10 20385.052735 S 680 B
13 20385.060547 ntask sched 43.000000
10 20385.062500 S 680 Fi
10 20385.064453 S 680 B
10 20385.064453 S 680 chol_model_22
10 20388.343750 S 65 B
10 20388.343750 S 680 Po
10 20388.345703 S 680 B
13 20388.353516 ntask sched 42.000000
10 20388.355469 S 680 Fi
10 20388.357422 S 680 B
10 20388.357422 S 680 chol_model_22
10 20391.671875 S 65 B
10 20391.671875 S 680 Po
10 20391.673828 S 680 B
13 20391.681641 ntask sched 41.000000
10 20391.683594 S 680 Fi
10 20391.685547 S 680 B
10 20391.685547 S 680 chol_model_22
10 20394.988281 S 65 B
10 20394.988281 S 680 Po
10 20394.990235 S 680 B
13 20395.000000 ntask sched 40.000000
10 20395.000000 S 680 Fi
10 20395.003907 S 680 B
10 20395.003907 S 680 chol_model_22
10 20398.244141 S 65 B
10 20398.244141 S 680 Po
10 20398.246094 S 680 B
13 20398.255860 ntask sched 39.000000
10 20398.255860 S 680 Fi
10 20398.257813 S 680 B
10 20398.257813 S 680 chol_model_22
10 20401.515625 S 65 B
10 20401.515625 S 680 Po
10 20401.517578 S 680 B
13 20401.523438 ntask sched 38.000000
10 20401.525391 S 680 Fi
10 20401.527344 S 680 B
10 20401.527344 S 680 chol_model_22
10 20404.814453 S 65 B
10 20404.816407 S 680 Po
10 20404.818360 S 680 B
13 20404.826172 ntask sched 37.000000
10 20404.828125 S 680 Fi
10 20404.830078 S 680 B
10 20404.830078 S 680 chol_model_22
10 20408.140625 S 65 B
10 20408.140625 S 680 Po
10 20408.142578 S 680 B
13 20408.150391 ntask sched 36.000000
10 20408.150391 S 680 Fi
10 20408.152344 S 680 B
10 20408.154297 S 680 chol_model_22
10 20411.468750 S 65 B
10 20411.470703 S 680 Po
10 20411.470703 S 680 B
13 20411.478516 ntask sched 35.000000
10 20411.480469 S 680 Fi
10 20411.482422 S 680 B
10 20411.482422 S 680 chol_model_22
10 20414.707031 S 65 B
10 20414.708985 S 680 Po
10 20414.710938 S 680 B
13 20414.718750 ntask sched 34.000000
10 20414.720703 S 680 Fi
10 20414.720703 S 680 B
10 20414.722657 S 680 chol_model_22
10 20418.015625 S 65 B
10 20418.015625 S 680 Po
10 20418.017578 S 680 B
13 20418.025391 ntask sched 33.000000
10 20418.027344 S 680 Fi
10 20418.029297 S 680 B
10 20418.029297 S 680 chol_model_22
10 20421.369141 S 65 B
10 20421.371094 S 680 Po
10 20421.373047 S 680 B
13 20421.380860 ntask sched 32.000000
10 20421.382813 S 680 Fi
10 20421.382813 S 680 B
10 20421.384766 S 680 chol_model_22
10 20424.607422 S 65 B
10 20424.609375 S 680 Po
10 20424.611328 S 680 B
13 20424.619141 ntask sched 31.000000
10 20424.619141 S 680 Fi
10 20424.621094 S 680 B
10 20424.623047 S 680 chol_model_22
10 20427.916016 S 65 B
10 20427.917969 S 680 Po
10 20427.919922 S 680 B
13 20427.929688 ntask sched 30.000000
10 20427.931641 S 680 Fi
10 20427.933594 S 680 B
10 20427.933594 S 680 chol_model_22
10 20431.240235 S 65 B
10 20431.242188 S 680 Po
10 20431.244141 S 680 B
13 20431.251953 ntask sched 29.000000
10 20431.253907 S 680 Fi
10 20431.255860 S 680 B
10 20431.255860 S 680 chol_model_22
10 20434.539063 S 65 B
10 20434.541016 S 680 Po
10 20434.541016 S 680 B
13 20434.550781 ntask sched 28.000000
10 20434.552735 S 680 Fi
10 20434.554688 S 680 B
10 20434.554688 S 680 chol_model_22
10 20437.886719 S 65 B
10 20437.886719 S 680 Po
10 20437.888672 S 680 B
13 20437.896485 ntask sched 27.000000
10 20437.898438 S 680 Fi
10 20437.900391 S 680 B
10 20437.900391 S 680 chol_model_22
10 20441.138672 S 65 B
10 20441.138672 S 680 Po
10 20441.140625 S 680 B
13 20441.148438 ntask sched 26.000000
10 20441.150391 S 680 Fi
10 20441.152344 S 680 B
10 20441.152344 S 680 chol_model_22
10 20444.455078 S 65 B
10 20444.457031 S 680 Po
10 20444.458985 S 680 B
13 20444.466797 ntask sched 25.000000
10 20444.468750 S 680 Fi
10 20444.468750 S 680 B
10 20444.470703 S 680 chol_model_22
10 20447.798828 S 65 B
10 20447.800781 S 680 Po
10 20447.800781 S 680 B
13 20447.810547 ntask sched 24.000000
10 20447.812500 S 680 Fi
10 20447.814453 S 680 B
10 20447.814453 S 680 chol_model_22
10 20451.105469 S 65 B
10 20451.105469 S 680 Po
10 20451.107422 S 680 B
13 20451.115235 ntask sched 23.000000
10 20451.117188 S 680 Fi
10 20451.119141 S 680 B
10 20451.119141 S 680 chol_model_22
10 20454.406250 S 65 B
10 20454.408203 S 680 Po
10 20454.410157 S 680 B
13 20454.417969 ntask sched 22.000000
10 20454.419922 S 680 Fi
10 20454.421875 S 680 B
10 20454.421875 S 680 chol_model_22
10 20457.734375 S 65 B
10 20457.734375 S 680 Po
10 20457.736328 S 680 B
13 20457.744141 ntask sched 21.000000
10 20457.746094 S 680 Fi
10 20457.748047 S 680 B
10 20457.748047 S 680 chol_model_22
10 20460.970703 S 65 B
10 20460.972657 S 680 Po
10 20460.974610 S 680 B
13 20460.982422 ntask sched 20.000000
10 20460.984375 S 680 Fi
10 20460.984375 S 680 B
10 20460.986328 S 680 chol_model_22
10 20464.193360 S 65 B
10 20464.195313 S 680 Po
10 20464.197266 S 680 B
13 20464.205078 ntask sched 19.000000
10 20464.207031 S 680 Fi
10 20464.208985 S 680 B
10 20464.210938 S 680 chol_model_22
10 20467.505860 S 65 B
10 20467.505860 S 680 Po
10 20467.507813 S 680 B
13 20467.515625 ntask sched 18.000000
10 20467.517578 S 680 Fi
10 20467.519531 S 680 B
10 20467.519531 S 680 chol_model_22
10 20470.826172 S 65 B
10 20470.828125 S 680 Po
10 20470.830078 S 680 B
13 20470.837891 ntask sched 17.000000
10 20470.839844 S 680 Fi
10 20470.839844 S 680 B
10 20470.841797 S 680 chol_model_22
10 20474.146485 S 65 B
10 20474.146485 S 680 Po
10 20474.148438 S 680 B
13 20474.156250 ntask sched 16.000000
10 20474.158203 S 680 Fi
10 20474.160157 S 680 B
10 20474.160157 S 680 chol_model_22
10 20477.470703 S 65 B
10 20477.472657 S 680 Po
10 20477.474610 S 680 B
13 20477.480469 ntask sched 15.000000
10 20477.482422 S 680 Fi
10 20477.484375 S 680 B
10 20477.484375 S 680 chol_model_22
10 20480.699219 S 65 B
10 20480.699219 S 680 Po
10 20480.701172 S 680 B
13 20480.708985 ntask sched 14.000000
10 20480.710938 S 680 Fi
10 20480.712891 S 680 B
10 20480.712891 S 680 chol_model_22
10 20484.013672 S 65 B
10 20484.015625 S 680 Po
10 20484.017578 S 680 B
13 20484.025391 ntask sched 13.000000
10 20484.025391 S 680 Fi
10 20484.027344 S 680 B
10 20484.029297 S 680 chol_model_22
10 20487.269531 S 65 B
10 20487.269531 S 680 Po
10 20487.271485 S 680 B
13 20487.279297 ntask sched 12.000000
10 20487.281250 S 680 Fi
10 20487.283203 S 680 B
10 20487.283203 S 680 chol_model_22
10 20490.480469 S 65 B
10 20490.480469 S 680 Po
10 20490.482422 S 680 B
13 20490.490235 ntask sched 11.000000
10 20490.492188 S 680 Fi
10 20490.494141 S 680 B
10 20490.494141 S 680 chol_model_22
10 20493.730469 S 65 B
10 20493.730469 S 680 Po
10 20493.732422 S 680 B
13 20493.742188 ntask sched 10.000000
10 20493.744141 S 680 Fi
10 20493.744141 S 680 B
10 20493.746094 S 680 chol_model_22
10 20497.050781 S 65 B
10 20497.052735 S 680 Po
10 20497.054688 S 680 B
13 20497.060547 ntask sched 9.000000
10 20497.062500 S 680 Fi
10 20497.064453 S 680 B
10 20497.064453 S 680 chol_model_22
10 20500.343750 S 65 B
10 20500.345703 S 680 Po
10 20500.347657 S 680 B
13 20500.355469 ntask sched 8.000000
10 20500.357422 S 680 Fi
10 20500.359375 S 680 B
10 20500.359375 S 680 chol_model_22
10 20503.599610 S 65 B
10 20503.601563 S 680 Po
10 20503.601563 S 680 B
13 20503.611328 ntask sched 7.000000
10 20503.611328 S 680 Fi
10 20503.613281 S 680 B
10 20503.613281 S 680 chol_model_22
10 20506.861328 S 65 B
10 20506.861328 S 680 Po
10 20506.863281 S 680 B
13 20506.871094 ntask sched 6.000000
10 20506.873047 S 680 Fi
10 20506.875000 S 680 B
10 20506.875000 S 680 chol_model_22
10 20510.099610 S 65 B
10 20510.099610 S 680 Po
10 20510.101563 S 680 B
13 20510.109375 ntask sched 5.000000
10 20510.111328 S 680 Fi
10 20510.111328 S 680 B
10 20510.113281 S 680 chol_model_22
10 20513.326172 S 65 B
10 20513.326172 S 680 Po
10 20513.328125 S 680 B
13 20513.335938 ntask sched 4.000000
10 20513.337891 S 680 Fi
10 20513.339844 S 680 B
10 20513.339844 S 680 chol_model_22
10 20516.552735 S 65 B
10 20516.552735 S 680 Po
10 20516.554688 S 680 B
13 20516.562500 ntask sched 3.000000
10 20516.564453 S 680 Fi
10 20516.564453 S 680 B
10 20516.568360 S 680 chol_model_21
10 20524.781250 S 65 B
10 20524.783203 S 680 Po
10 20524.785157 S 680 B
13 20524.824219 ntask sched 4.000000
13 20524.855469 ntask sched 5.000000
13 20524.884766 ntask sched 6.000000
13 20524.914063 ntask sched 7.000000
13 20524.947266 ntask sched 8.000000
13 20524.976563 ntask sched 9.000000
13 20525.009766 ntask sched 10.000000
13 20525.039063 ntask sched 11.000000
13 20525.066407 ntask sched 12.000000
13 20525.095703 ntask sched 13.000000
13 20525.126953 ntask sched 14.000000
13 20525.132813 ntask sched 13.000000
10 20525.134766 S 680 Fi
10 20525.136719 S 680 B
10 20525.136719 S 680 chol_model_22
10 20528.482422 S 65 B
10 20528.482422 S 680 Po
10 20528.484375 S 680 B
13 20528.492188 ntask sched 12.000000
10 20528.494141 S 680 Fi
10 20528.496094 S 680 B
10 20528.496094 S 680 chol_model_22
10 20531.798828 S 65 B
10 20531.798828 S 680 Po
10 20531.800781 S 680 B
13 20531.806641 ntask sched 11.000000
10 20531.808594 S 680 Fi
10 20531.810547 S 680 B
10 20531.810547 S 680 chol_model_22
10 20535.105469 S 65 B
10 20535.105469 S 680 Po
10 20535.107422 S 680 B
13 20535.115235 ntask sched 10.000000
10 20535.117188 S 680 Fi
10 20535.117188 S 680 B
10 20535.119141 S 680 chol_model_22
10 20538.333985 S 65 B
10 20538.335938 S 680 Po
10 20538.337891 S 680 B
13 20538.343750 ntask sched 9.000000
10 20538.345703 S 680 Fi
10 20538.347657 S 680 B
10 20538.347657 S 680 chol_model_22
10 20541.574219 S 65 B
10 20541.574219 S 680 Po
10 20541.576172 S 680 B
13 20541.583985 ntask sched 8.000000
10 20541.585938 S 680 Fi
10 20541.587891 S 680 B
10 20541.587891 S 680 chol_model_22
10 20544.867188 S 65 B
10 20544.867188 S 680 Po
10 20544.869141 S 680 B
13 20544.876953 ntask sched 7.000000
10 20544.878907 S 680 Fi
10 20544.880860 S 680 B
10 20544.880860 S 680 chol_model_22
10 20548.101563 S 65 B
10 20548.103516 S 680 Po
10 20548.105469 S 680 B
13 20548.111328 ntask sched 6.000000
10 20548.113281 S 680 Fi
10 20548.115235 S 680 B
10 20548.115235 S 680 chol_model_22
10 20551.390625 S 65 B
10 20551.390625 S 680 Po
10 20551.392578 S 680 B
13 20551.398438 ntask sched 5.000000
10 20551.400391 S 680 Fi
10 20551.402344 S 680 B
10 20551.402344 S 680 chol_model_22
10 20554.697266 S 65 B
10 20554.699219 S 680 Po
10 20554.699219 S 680 B
13 20554.707031 ntask sched 4.000000
10 20554.708985 S 680 Fi
10 20554.710938 S 680 B
10 20554.710938 S 680 chol_model_22
10 20558.019531 S 65 B
10 20558.019531 S 680 Po
10 20558.021485 S 680 B
13 20558.029297 ntask sched 3.000000
10 20558.029297 S 680 Fi
10 20558.031250 S 680 B
10 20558.031250 S 680 chol_model_22
10 20561.343750 S 65 B
10 20561.345703 S 680 Po
10 20561.347657 S 680 B
13 20561.353516 ntask sched 2.000000
10 20561.355469 S 680 Fi
10 20561.357422 S 680 B
10 20561.359375 S 680 chol_model_21
10 20569.580078 S 65 B
10 20569.582031 S 680 Po
10 20569.582031 S 680 B
13 20569.619141 ntask sched 3.000000
13 20569.650391 ntask sched 4.000000
13 20569.681641 ntask sched 5.000000
13 20569.710938 ntask sched 6.000000
13 20569.738281 ntask sched 7.000000
13 20569.769531 ntask sched 8.000000
13 20569.800781 ntask sched 9.000000
13 20569.828125 ntask sched 10.000000
13 20569.859375 ntask sched 11.000000
13 20569.888672 ntask sched 12.000000
13 20569.917969 ntask sched 13.000000
13 20569.947266 ntask sched 14.000000
13 20569.953125 ntask sched 13.000000
10 20569.955078 S 680 Fi
10 20569.955078 S 680 B
10 20569.957031 S 680 chol_model_22
10 20573.187500 S 65 B
10 20573.189453 S 680 Po
10 20573.191407 S 680 B
13 20573.199219 ntask sched 12.000000
10 20573.199219 S 680 Fi
10 20573.203125 S 680 B
10 20573.203125 S 680 chol_model_22
10 20576.412110 S 65 B
10 20576.414063 S 680 Po
10 20576.414063 S 680 B
13 20576.423828 ntask sched 11.000000
10 20576.423828 S 680 Fi
10 20576.425781 S 680 B
10 20576.427735 S 680 chol_model_22
10 20579.648438 S 65 B
10 20579.648438 S 680 Po
10 20579.650391 S 680 B
13 20579.658203 ntask sched 10.000000
10 20579.660157 S 680 Fi
10 20579.662110 S 680 B
10 20579.662110 S 680 chol_model_22
10 20582.972657 S 65 B
10 20582.972657 S 680 Po
10 20582.974610 S 680 B
13 20582.982422 ntask sched 9.000000
10 20582.982422 S 680 Fi
10 20582.986328 S 680 B
10 20582.986328 S 680 chol_model_22
10 20586.207031 S 65 B
10 20586.207031 S 680 Po
10 20586.208985 S 680 B
13 20586.218750 ntask sched 8.000000
10 20586.220703 S 680 Fi
10 20586.222657 S 680 B
10 20586.222657 S 680 chol_model_22
10 20589.521485 S 65 B
10 20589.523438 S 680 Po
10 20589.525391 S 680 B
13 20589.533203 ntask sched 7.000000
10 20589.535157 S 680 Fi
10 20589.537110 S 680 B
10 20589.537110 S 680 chol_model_22
10 20592.773438 S 65 B
10 20592.775391 S 680 Po
10 20592.777344 S 680 B
13 20592.785157 ntask sched 6.000000
10 20592.787110 S 680 Fi
10 20592.787110 S 680 B
10 20592.789063 S 680 chol_model_22
10 20596.089844 S 65 B
10 20596.089844 S 680 Po
10 20596.091797 S 680 B
13 20596.099610 ntask sched 5.000000
10 20596.099610 S 680 Fi
10 20596.101563 S 680 B
10 20596.101563 S 680 chol_model_22
10 20599.414063 S 65 B
10 20599.414063 S 680 Po
10 20599.416016 S 680 B
13 20599.423828 ntask sched 4.000000
10 20599.425781 S 680 Fi
10 20599.425781 S 680 B
10 20599.427735 S 680 chol_model_22
10 20602.742188 S 65 B
10 20602.742188 S 680 Po
10 20602.744141 S 680 B
13 20602.751953 ntask sched 3.000000
10 20602.753907 S 680 Fi
10 20602.755860 S 680 B
10 20602.755860 S 680 chol_model_22
10 20606.060547 S 65 B
10 20606.060547 S 680 Po
10 20606.062500 S 680 B
13 20606.070313 ntask sched 2.000000
10 20606.072266 S 680 Fi
10 20606.074219 S 680 B
10 20606.074219 S 680 chol_model_22
10 20609.322266 S 65 B
10 20609.324219 S 680 Po
10 20609.324219 S 680 B
13 20609.335938 ntask sched 1.000000
10 20609.337891 S 680 Fi
10 20609.339844 S 680 B
10 20609.341797 S 680 chol_model_21
10 20617.560547 S 65 B
10 20617.562500 S 680 Po
10 20617.562500 S 680 B
13 20617.597657 ntask sched 2.000000
13 20617.628907 ntask sched 3.000000
13 20617.658203 ntask sched 4.000000
13 20617.689453 ntask sched 5.000000
13 20617.718750 ntask sched 6.000000
13 20617.750000 ntask sched 7.000000
13 20617.781250 ntask sched 8.000000
13 20617.812500 ntask sched 9.000000
13 20617.843750 ntask sched 10.000000
13 20617.873047 ntask sched 11.000000
13 20617.904297 ntask sched 12.000000
13 20617.933594 ntask sched 13.000000
13 20617.964844 ntask sched 14.000000
13 20617.968750 ntask sched 13.000000
10 20617.970703 S 680 Fi
10 20617.970703 S 680 B
10 20617.972657 S 680 chol_model_22
10 20621.189453 S 65 B
10 20621.191407 S 680 Po
10 20621.193360 S 680 B
13 20621.201172 ntask sched 12.000000
10 20621.201172 S 680 Fi
10 20621.203125 S 680 B
10 20621.203125 S 680 chol_model_22
10 20624.505860 S 65 B
10 20624.505860 S 680 Po
10 20624.507813 S 680 B
13 20624.517578 ntask sched 11.000000
10 20624.517578 S 680 Fi
10 20624.519531 S 680 B
10 20624.521485 S 680 chol_model_22
10 20627.744141 S 65 B
10 20627.744141 S 680 Po
10 20627.746094 S 680 B
13 20627.753907 ntask sched 10.000000
10 20627.755860 S 680 Fi
10 20627.757813 S 680 B
10 20627.757813 S 680 chol_model_22
10 20631.080078 S 65 B
10 20631.080078 S 680 Po
10 20631.082031 S 680 B
13 20631.089844 ntask sched 9.000000
10 20631.091797 S 680 Fi
10 20631.093750 S 680 B
10 20631.093750 S 680 chol_model_22
10 20634.298828 S 65 B
10 20634.298828 S 680 Po
10 20634.300781 S 680 B
13 20634.308594 ntask sched 8.000000
10 20634.308594 S 680 Fi
10 20634.310547 S 680 B
10 20634.310547 S 680 chol_model_22
10 20637.599610 S 65 B
10 20637.601563 S 680 Po
10 20637.603516 S 680 B
13 20637.609375 ntask sched 7.000000
10 20637.611328 S 680 Fi
10 20637.613281 S 680 B
10 20637.613281 S 680 chol_model_22
10 20640.921875 S 65 B
10 20640.923828 S 680 Po
10 20640.923828 S 680 B
13 20640.933594 ntask sched 6.000000
10 20640.935547 S 680 Fi
10 20640.935547 S 680 B
10 20640.937500 S 680 chol_model_22
10 20644.248047 S 65 B
10 20644.248047 S 680 Po
10 20644.250000 S 680 B
13 20644.259766 ntask sched 5.000000
10 20644.261719 S 680 Fi
10 20644.263672 S 680 B
10 20644.263672 S 680 chol_model_22
10 20647.486328 S 65 B
10 20647.488281 S 680 Po
10 20647.490235 S 680 B
13 20647.498047 ntask sched 4.000000
10 20647.498047 S 680 Fi
10 20647.500000 S 680 B
10 20647.500000 S 680 chol_model_22
10 20650.734375 S 65 B
10 20650.734375 S 680 Po
10 20650.736328 S 680 B
13 20650.744141 ntask sched 3.000000
10 20650.746094 S 680 Fi
10 20650.746094 S 680 B
10 20650.748047 S 680 chol_model_22
10 20653.974610 S 65 B
10 20653.974610 S 680 Po
10 20653.976563 S 680 B
13 20653.986328 ntask sched 2.000000
10 20653.986328 S 680 Fi
10 20653.988281 S 680 B
10 20653.988281 S 680 chol_model_22
10 20657.275391 S 65 B
10 20657.275391 S 680 Po
10 20657.277344 S 680 B
13 20657.285157 ntask sched 1.000000
10 20657.287110 S 680 Fi
10 20657.287110 S 680 B
10 20657.287110 S 680 chol_model_22
10 20660.507813 S 65 B
10 20660.507813 S 680 Po
10 20660.509766 S 680 B
13 20660.517578 ntask sched 0.000000
10 20660.517578 S 680 Fi
10 20660.519531 S 680 B
10 20660.521485 S 680 chol_model_21
10 20668.730469 S 65 B
10 20668.732422 S 680 Po
10 20668.734375 S 680 B
13 20668.771485 ntask sched 1.000000
13 20668.802735 ntask sched 2.000000
13 20668.832031 ntask sched 3.000000
13 20668.863281 ntask sched 4.000000
13 20668.894531 ntask sched 5.000000
13 20668.923828 ntask sched 6.000000
13 20668.955078 ntask sched 7.000000
13 20668.988281 ntask sched 8.000000
13 20669.017578 ntask sched 9.000000
13 20669.048828 ntask sched 10.000000
13 20669.078125 ntask sched 11.000000
13 20669.109375 ntask sched 12.000000
13 20669.138672 ntask sched 13.000000
13 20669.169922 ntask sched 14.000000
13 20669.175781 ntask sched 13.000000
10 20669.175781 S 680 Fi
10 20669.177735 S 680 B
10 20669.179688 S 680 chol_model_22
10 20672.486328 S 65 B
10 20672.486328 S 680 Po
10 20672.488281 S 680 B
13 20672.496094 ntask sched 12.000000
10 20672.498047 S 680 Fi
10 20672.500000 S 680 B
10 20672.500000 S 680 chol_model_22
10 20675.828125 S 65 B
10 20675.828125 S 680 Po
10 20675.830078 S 680 B
13 20675.837891 ntask sched 11.000000
10 20675.839844 S 680 Fi
10 20675.841797 S 680 B
10 20675.841797 S 680 chol_model_22
10 20679.144531 S 65 B
10 20679.144531 S 680 Po
10 20679.146485 S 680 B
13 20679.154297 ntask sched 10.000000
10 20679.156250 S 680 Fi
10 20679.158203 S 680 B
10 20679.158203 S 680 chol_model_22
10 20682.416016 S 65 B
10 20682.417969 S 680 Po
10 20682.419922 S 680 B
13 20682.433594 ntask sched 9.000000
10 20682.433594 S 680 Fi
10 20682.435547 S 680 B
10 20682.437500 S 680 chol_model_22
10 20685.779297 S 65 B
10 20685.781250 S 680 Po
10 20685.783203 S 680 B
13 20685.791016 ntask sched 8.000000
10 20685.792969 S 680 Fi
10 20685.794922 S 680 B
10 20685.794922 S 680 chol_model_22
10 20689.074219 S 65 B
10 20689.074219 S 680 Po
10 20689.076172 S 680 B
13 20689.085938 ntask sched 7.000000
10 20689.087891 S 680 Fi
10 20689.089844 S 680 B
10 20689.089844 S 680 chol_model_22
10 20703.166016 S 65 B
10 20703.167969 S 680 Po
10 20703.169922 S 680 B
13 20703.177735 ntask sched 6.000000
10 20703.179688 S 680 Fi
10 20703.181641 S 680 B
10 20703.181641 S 680 chol_model_22
10 20706.496094 S 65 B
10 20706.496094 S 680 Po
10 20706.498047 S 680 B
13 20706.505860 ntask sched 5.000000
10 20706.507813 S 680 Fi
10 20706.507813 S 680 B
10 20706.509766 S 680 chol_model_22
10 20709.812500 S 65 B
10 20709.812500 S 680 Po
10 20709.814453 S 680 B
13 20709.822266 ntask sched 4.000000
10 20709.824219 S 680 Fi
10 20709.826172 S 680 B
10 20709.826172 S 680 chol_model_22
10 20713.062500 S 65 B
10 20713.064453 S 680 Po
10 20713.066407 S 680 B
13 20713.074219 ntask sched 3.000000
10 20713.074219 S 680 Fi
10 20713.076172 S 680 B
10 20713.076172 S 680 chol_model_22
10 20716.355469 S 65 B
10 20716.357422 S 680 Po
10 20716.357422 S 680 B
13 20716.365235 ntask sched 2.000000
10 20716.367188 S 680 Fi
10 20716.369141 S 680 B
10 20716.369141 S 680 chol_model_22
10 20729.527344 S 65 B
10 20729.529297 S 680 Po
10 20729.531250 S 680 B
13 20729.539063 ntask sched 1.000000
10 20729.541016 S 680 Fi
10 20729.544922 S 680 B
10 20729.544922 S 680 chol_model_22
10 20732.822266 S 65 B
10 20732.824219 S 680 Po
10 20732.826172 S 680 B
13 20732.833985 ntask sched 0.000000
10 20732.835938 S 680 Fi
10 20732.835938 S 680 B
10 20732.837891 S 680 chol_model_22
10 20736.115235 S 65 B
10 20736.117188 S 680 Po
10 20736.117188 S 680 B
13 20736.152344 ntask sched 1.000000
13 20736.160157 ntask sched 0.000000
10 20736.160157 S 680 Fi
10 20736.162110 S 680 B
10 20736.164063 S 680 chol_model_11
10 20809.427735 S 65 B
10 20809.435547 S 680 Po
10 20809.437500 S 680 B
13 20809.474610 ntask sched 1.000000
13 20809.505860 ntask sched 2.000000
13 20809.535157 ntask sched 3.000000
13 20809.544922 ntask sched 2.000000
10 20809.548828 S 679 Fi
13 20809.568360 ntask sched 3.000000
13 20809.597657 ntask sched 4.000000
13 20809.623047 ntask sched 5.000000
13 20809.652344 ntask sched 6.000000
13 20809.679688 ntask sched 7.000000
13 20809.705078 ntask sched 8.000000
13 20809.732422 ntask sched 9.000000
13 20809.761719 ntask sched 10.000000
13 20809.796875 ntask sched 11.000000
10 20809.800781 MS MEMNODE0 Co
18 20809.800781 L p 4000000 MEMNODE2 com_165
13 20809.802735 ntask sched 10.000000
10 20809.804688 S 681 Fi
10 20809.810547 MS MEMNODE0 CoA
13 20809.826172 ntask sched 11.000000
10 20809.828125 MS MEMNODE0 Co
18 20809.828125 L p 4000000 MEMNODE2 com_166
10 20809.832031 MS MEMNODE0 Co
18 20809.832031 L p 4000000 MEMNODE2 com_167
13 20809.839844 ntask sched 10.000000
10 20809.841797 S 682 Fi
10 20811.837891 MS MEMNODE0 No
19 20811.837891 L p 2273874960 MEMNODE0 com_2273874768
10 20811.853516 MS MEMNODE0 CoA
10 20811.865235 MS MEMNODE0 CoA
10 20813.363281 MS MEMNODE0 No
19 20813.363281 L p 2273874960 MEMNODE0 com_2273874768
10 20815.482422 MS MEMNODE0 No
19 20815.482422 L p 2273874968 MEMNODE0 com_2273874768
10 20815.488281 MS MEMNODE0 No
19 20815.488281 L p 4000000 MEMNODE0 com_165
10 20815.490235 MS MEMNODE0 Co
18 20815.490235 L p 4000000 MEMNODE2 com_168
10 20815.515625 MS MEMNODE0 CoA
10 20817.554688 MS MEMNODE0 No
19 20817.554688 L p 2273874960 MEMNODE0 com_2273874768
10 20817.560547 MS MEMNODE0 No
19 20817.560547 L p 4000000 MEMNODE0 com_166
10 20817.562500 MS MEMNODE0 Co
18 20817.562500 L p 4000000 MEMNODE2 com_169
10 20817.576172 MS MEMNODE0 CoA
10 20819.599610 MS MEMNODE0 No
19 20819.599610 L p 2273874960 MEMNODE0 com_2273874768
10 20819.605469 MS MEMNODE0 Co
18 20819.605469 L p 4000000 MEMNODE2 com_170
10 20819.619141 MS MEMNODE0 CoA
10 20821.634766 MS MEMNODE0 No
19 20821.634766 L p 2273874960 MEMNODE0 com_2273874768
10 20821.638672 MS MEMNODE0 Co
18 20821.638672 L p 4000000 MEMNODE2 com_171
10 20821.652344 MS MEMNODE0 CoA
10 20823.673828 MS MEMNODE0 No
19 20823.673828 L p 2273874960 MEMNODE0 com_2273874768
10 20823.679688 MS MEMNODE0 Co
18 20823.679688 L p 4000000 MEMNODE2 com_172
10 20823.693360 MS MEMNODE0 CoA
10 20825.705078 MS MEMNODE0 No
19 20825.705078 L p 2273874960 MEMNODE0 com_2273874768
13 20825.712891 ntask sched 9.000000
10 20825.714844 S 680 Fi
10 20825.716797 S 680 B
10 20825.748047 S 680 chol_model_21
10 20834.019531 S 65 B
10 20834.021485 S 680 Po
10 20834.023438 S 680 B
13 20834.058594 ntask sched 10.000000
10 20834.066407 MS MEMNODE0 No
19 20834.066407 L p 4000000 MEMNODE0 com_172
10 20834.068360 MS MEMNODE1 A
10 20834.068360 MS MEMNODE0 No
19 20834.068360 L p 4000000 MEMNODE0 com_171
10 20834.070313 MS MEMNODE0 No
19 20834.070313 L p 4000000 MEMNODE0 com_170
10 20834.072266 MS MEMNODE0 No
19 20834.072266 L p 4000000 MEMNODE0 com_169
10 20834.074219 MS MEMNODE0 No
19 20834.074219 L p 4000000 MEMNODE0 com_168
10 20834.076172 MS MEMNODE0 No
19 20834.076172 L p 4000000 MEMNODE0 com_167
10 20834.078125 S 681 B
13 20834.078125 ntask sched 9.000000
10 20834.080078 S 680 Fi
10 20834.080078 S 681 chol_model_21
10 20834.080078 S 682 B
10 20834.080078 S 680 B
10 20834.082031 S 680 chol_model_22
10 20834.082031 S 682 chol_model_21
10 20834.207031 MS MEMNODE1 No
10 20834.210938 MS MEMNODE1 Co
18 20834.210938 L p 4000000 MEMNODE0 com_173
10 20834.216797 MS MEMNODE1 CoA
10 20835.363281 MS MEMNODE1 No
19 20835.363281 L p 2273874960 MEMNODE1 com_2273874768
10 20835.371094 MS MEMNODE1 A
10 20835.490235 MS MEMNODE1 No
10 20835.492188 MS MEMNODE1 Co
18 20835.492188 L p 4000000 MEMNODE0 com_174
10 20835.498047 MS MEMNODE1 CoA
10 20836.658203 MS MEMNODE1 No
19 20836.658203 L p 2273874960 MEMNODE1 com_2273874768
10 20836.662110 MS MEMNODE1 A
10 20836.785157 MS MEMNODE1 No
10 20836.787110 MS MEMNODE1 Co
18 20836.787110 L p 4000000 MEMNODE0 com_175
10 20836.794922 MS MEMNODE1 CoA
10 20837.314453 S 65 B
10 20837.314453 S 680 Po
10 20837.316407 S 680 B
13 20837.324219 ntask sched 8.000000
10 20837.326172 S 680 Fi
10 20837.328125 S 680 B
10 20837.330078 S 680 chol_model_21
10 20837.960938 MS MEMNODE1 No
19 20837.960938 L p 2273874960 MEMNODE1 com_2273874768
10 20837.964844 MS MEMNODE1 A
10 20838.087891 MS MEMNODE1 No
10 20838.089844 MS MEMNODE1 Co
18 20838.089844 L p 4000000 MEMNODE0 com_176
10 20838.111328 MS MEMNODE1 CoA
10 20839.271485 MS MEMNODE1 No
19 20839.271485 L p 2273874960 MEMNODE1 com_2273874768
10 20839.277344 MS MEMNODE1 A
10 20839.394531 MS MEMNODE1 No
10 20839.398438 MS MEMNODE1 Co
18 20839.398438 L p 4000000 MEMNODE0 com_177
10 20839.404297 MS MEMNODE1 CoA
10 20840.568360 MS MEMNODE1 No
19 20840.568360 L p 2273874960 MEMNODE1 com_2273874768
10 20840.572266 MS MEMNODE1 A
10 20840.691407 MS MEMNODE1 No
10 20840.693360 MS MEMNODE1 Co
18 20840.693360 L p 4000000 MEMNODE0 com_178
10 20840.699219 MS MEMNODE1 CoA
10 20841.859375 MS MEMNODE1 No
19 20841.859375 L p 2273874960 MEMNODE1 com_2273874768
10 20841.898438 MS MEMNODE1 No
19 20841.898438 L p 4000000 MEMNODE1 com_177
10 20841.923828 MS MEMNODE1 No
19 20841.923828 L p 4000000 MEMNODE1 com_176
10 20841.947266 MS MEMNODE1 No
19 20841.947266 L p 4000000 MEMNODE1 com_175
10 20841.972657 MS MEMNODE1 No
19 20841.972657 L p 4000000 MEMNODE1 com_174
10 20841.998047 MS MEMNODE1 No
19 20841.998047 L p 4000000 MEMNODE1 com_173
10 20842.050781 MS MEMNODE1 No
19 20842.050781 L p 4000000 MEMNODE1 com_178
10 20842.050781 S 679 B
10 20842.056641 S 679 chol_model_21
10 20845.544922 S 65 B
10 20845.546875 S 680 Po
10 20845.548828 S 680 B
13 20845.587891 ntask sched 9.000000
13 20845.615235 ntask sched 10.000000
13 20845.621094 ntask sched 9.000000
10 20845.623047 S 680 Fi
10 20845.623047 S 680 B
10 20845.623047 S 680 chol_model_22
10 20848.935547 S 65 B
10 20848.937500 S 680 Po
10 20848.939453 S 680 B
13 20848.945313 ntask sched 8.000000
10 20848.947266 S 680 Fi
10 20848.947266 S 680 B
10 20848.949219 S 680 chol_model_22
10 20850.380860 S 64 B
10 20850.384766 S 679 Po
10 20850.386719 S 679 B
13 20850.433594 ntask sched 9.000000
13 20850.462891 ntask sched 10.000000
13 20850.490235 ntask sched 11.000000
10 20850.494141 MS MEMNODE0 Co
18 20850.494141 L p 4000000 MEMNODE1 com_179
10 20850.503907 MS MEMNODE0 CoA
10 20852.089844 MS MEMNODE0 No
19 20852.089844 L p 2273874960 MEMNODE0 com_2273874768
13 20852.095703 ntask sched 10.000000
10 20852.097657 S 679 Fi
10 20852.099610 S 679 B
10 20852.134766 S 679 chol_model_21
10 20852.162110 S 65 B
10 20852.162110 S 680 Po
10 20852.164063 S 680 B
13 20852.171875 ntask sched 9.000000
10 20852.173828 S 680 Fi
10 20860.439453 S 64 B
10 20860.441407 S 679 Po
10 20860.443360 S 679 B
13 20860.478516 ntask sched 10.000000
13 20860.505860 ntask sched 11.000000
13 20860.533203 ntask sched 12.000000
13 20860.560547 ntask sched 13.000000
10 20860.568360 MS MEMNODE0 No
19 20860.568360 L p 4000000 MEMNODE0 com_179
10 20860.570313 MS MEMNODE0 Co
18 20860.570313 L p 4000000 MEMNODE1 com_180
10 20860.572266 MS MEMNODE2 Co
18 20860.572266 L p 4000000 MEMNODE0 com_181
10 20860.576172 MS MEMNODE0 CoA
10 20860.585938 MS MEMNODE2 CoA
10 20861.910157 MS MEMNODE2 No
19 20861.910157 L p 2273874960 MEMNODE2 com_2273874768
10 20862.050781 MS MEMNODE0 No
19 20862.050781 L p 2273874968 MEMNODE0 com_2273874768
13 20862.058594 ntask sched 12.000000
10 20862.058594 S 679 Fi
10 20862.060547 S 679 B
10 20862.097657 S 679 chol_model_21
10 20862.128907 MS MEMNODE2 No
19 20862.128907 L p 4000000 MEMNODE2 com_181
10 20862.130860 S 680 B
10 20862.132813 S 680 chol_model_22
10 20865.458985 S 65 B
10 20865.460938 S 680 Po
10 20865.462891 S 680 B
13 20865.472657 ntask sched 11.000000
10 20865.474610 S 680 Fi
10 20870.400391 S 64 B
10 20870.402344 S 679 Po
10 20870.404297 S 679 B
13 20870.447266 ntask sched 12.000000
13 20870.474610 ntask sched 13.000000
13 20870.501953 ntask sched 14.000000
13 20870.529297 ntask sched 15.000000
13 20870.556641 ntask sched 16.000000
10 20870.566407 MS MEMNODE0 No
19 20870.566407 L p 4000000 MEMNODE0 com_180
10 20870.568360 MS MEMNODE2 Co
18 20870.568360 L p 4000000 MEMNODE0 com_182
10 20870.568360 MS MEMNODE0 Co
18 20870.568360 L p 4000000 MEMNODE1 com_183
10 20870.572266 MS MEMNODE0 CoA
10 20870.578125 MS MEMNODE2 CoA
10 20871.892578 MS MEMNODE2 No
19 20871.892578 L p 2273874960 MEMNODE2 com_2273874768
10 20872.050781 MS MEMNODE0 No
19 20872.050781 L p 2273874968 MEMNODE0 com_2273874768
13 20872.058594 ntask sched 15.000000
10 20872.058594 S 679 Fi
10 20872.060547 S 679 B
10 20872.091797 MS MEMNODE2 No
19 20872.091797 L p 4000000 MEMNODE2 com_182
10 20872.093750 S 680 B
10 20872.095703 S 680 chol_model_22
10 20872.117188 S 679 chol_model_21
10 20875.398438 S 65 B
10 20875.400391 S 680 Po
10 20875.402344 S 680 B
13 20875.412110 ntask sched 14.000000
10 20875.414063 S 680 Fi
10 20880.425781 S 64 B
10 20880.425781 S 679 Po
10 20880.427735 S 679 B
13 20880.468750 ntask sched 15.000000
13 20880.494141 ntask sched 16.000000
13 20880.521485 ntask sched 17.000000
13 20880.548828 ntask sched 18.000000
13 20880.578125 ntask sched 19.000000
13 20880.605469 ntask sched 20.000000
10 20880.611328 MS MEMNODE0 No
19 20880.611328 L p 4000000 MEMNODE0 com_183
10 20880.615235 MS MEMNODE0 Co
18 20880.615235 L p 4000000 MEMNODE1 com_184
10 20880.615235 MS MEMNODE2 Co
18 20880.615235 L p 4000000 MEMNODE0 com_185
10 20880.619141 MS MEMNODE0 CoA
10 20880.623047 MS MEMNODE2 CoA
10 20881.925781 MS MEMNODE2 No
19 20881.925781 L p 2273874960 MEMNODE2 com_2273874768
10 20882.121094 MS MEMNODE2 No
19 20882.121094 L p 4000000 MEMNODE2 com_185
10 20882.123047 S 680 B
10 20882.125000 S 680 chol_model_22
10 20882.142578 MS MEMNODE0 No
19 20882.142578 L p 2273874960 MEMNODE0 com_2273874768
13 20882.150391 ntask sched 19.000000
10 20882.150391 S 679 Fi
10 20882.152344 S 679 B
10 20882.183594 S 679 chol_model_21
10 20882.445313 S 0 B
10 20882.447266 S 682 Po
10 20882.451172 S 682 B
13 20882.490235 ntask sched 20.000000
13 20882.521485 ntask sched 21.000000
13 20882.550781 ntask sched 22.000000
13 20882.578125 ntask sched 23.000000
10 20882.580078 S 0 B
10 20882.582031 S 681 Po
10 20882.585938 S 681 B
13 20882.607422 ntask sched 24.000000
13 20882.621094 ntask sched 25.000000
13 20882.634766 ntask sched 26.000000
13 20882.648438 ntask sched 27.000000
13 20882.662110 ntask sched 28.000000
13 20882.679688 ntask sched 29.000000
13 20882.707031 ntask sched 30.000000
13 20882.734375 ntask sched 31.000000
13 20882.763672 ntask sched 32.000000
13 20882.789063 ntask sched 33.000000
13 20882.818360 ntask sched 34.000000
10 20885.361328 S 65 B
10 20885.363281 S 680 Po
10 20885.365235 S 680 B
10 20885.371094 MS MEMNODE2 Co
18 20885.371094 L p 4000000 MEMNODE0 com_186
10 20885.378907 MS MEMNODE2 CoA
10 20886.593750 MS MEMNODE2 No
19 20886.593750 L p 2273874960 MEMNODE2 com_2273874768
10 20886.597657 MS MEMNODE2 Co
18 20886.597657 L p 4000000 MEMNODE0 com_187
10 20886.603516 MS MEMNODE2 CoA
10 20887.835938 MS MEMNODE2 No
19 20887.835938 L p 2273874960 MEMNODE2 com_2273874768
13 20887.841797 ntask sched 33.000000
10 20887.843750 S 680 Fi
10 20887.878907 MS MEMNODE2 No
19 20887.878907 L p 4000000 MEMNODE2 com_186
10 20888.033203 MS MEMNODE2 No
19 20888.033203 L p 4000000 MEMNODE2 com_187
10 20888.035157 S 680 B
10 20888.037110 S 680 chol_model_22
10 20890.492188 S 64 B
10 20890.492188 S 679 Po
10 20890.494141 S 679 B
13 20890.529297 ntask sched 34.000000
13 20890.558594 ntask sched 35.000000
13 20890.585938 ntask sched 36.000000
13 20890.611328 ntask sched 37.000000
13 20890.640625 ntask sched 38.000000
13 20890.667969 ntask sched 39.000000
13 20890.695313 ntask sched 40.000000
13 20890.722657 ntask sched 41.000000
13 20890.750000 ntask sched 42.000000
10 20890.757813 MS MEMNODE0 No
19 20890.757813 L p 4000000 MEMNODE0 com_184
10 20890.759766 MS MEMNODE0 Co
18 20890.759766 L p 4000000 MEMNODE1 com_188
10 20890.765625 MS MEMNODE0 CoA
10 20891.263672 S 65 B
10 20891.265625 S 680 Po
10 20891.267578 S 680 B
10 20891.275391 MS MEMNODE2 Co
18 20891.275391 L p 4000000 MEMNODE0 com_189
10 20891.283203 MS MEMNODE2 CoA
10 20892.343750 MS MEMNODE0 No
19 20892.343750 L p 2273874960 MEMNODE0 com_2273874768
10 20892.392578 MS MEMNODE0 No
19 20892.392578 L p 4000000 MEMNODE0 com_188
10 20892.568360 MS MEMNODE2 No
19 20892.568360 L p 0 MEMNODE2 com_0
13 20892.574219 ntask sched 41.000000
10 20892.576172 S 680 Fi
10 20892.582031 MS MEMNODE2 Co
18 20892.582031 L p 4000000 MEMNODE0 com_190
10 20892.587891 MS MEMNODE2 CoA
10 20893.867188 MS MEMNODE2 No
19 20893.867188 L p 2273874960 MEMNODE2 com_2273874768
10 20893.902344 MS MEMNODE2 No
19 20893.902344 L p 4000000 MEMNODE2 com_189
10 20894.056641 MS MEMNODE2 No
19 20894.056641 L p 4000000 MEMNODE2 com_190
10 20894.060547 S 680 B
10 20894.060547 S 680 chol_model_22
10 20897.339844 S 65 B
10 20897.341797 S 680 Po
10 20897.343750 S 680 B
13 20897.351563 ntask sched 40.000000
10 20897.353516 S 680 Fi
10 20897.355469 S 680 B
10 20897.357422 S 680 chol_model_22
10 20900.687500 S 65 B
10 20900.689453 S 680 Po
10 20900.691407 S 680 B
13 20900.697266 ntask sched 39.000000
10 20900.699219 S 680 Fi
10 20900.701172 S 680 B
10 20900.703125 S 680 chol_model_22
10 20903.949219 S 65 B
10 20903.951172 S 680 Po
10 20903.953125 S 680 B
13 20903.960938 ntask sched 38.000000
10 20903.962891 S 680 Fi
10 20903.964844 S 680 B
10 20903.964844 S 680 chol_model_22
10 20907.287110 S 65 B
10 20907.287110 S 680 Po
10 20907.289063 S 680 B
13 20907.296875 ntask sched 37.000000
10 20907.298828 S 680 Fi
10 20907.300781 S 680 B
10 20907.300781 S 680 chol_model_22
10 20910.533203 S 65 B
10 20910.533203 S 680 Po
10 20910.535157 S 680 B
13 20910.542969 ntask sched 36.000000
10 20910.544922 S 680 Fi
10 20910.546875 S 680 B
10 20910.546875 S 680 chol_model_22
10 20913.781250 S 65 B
10 20913.781250 S 680 Po
10 20913.783203 S 680 B
13 20913.791016 ntask sched 35.000000
10 20913.792969 S 680 Fi
10 20913.794922 S 680 B
10 20913.796875 S 680 chol_model_22
10 20917.107422 S 65 B
10 20917.107422 S 680 Po
10 20917.109375 S 680 B
13 20917.117188 ntask sched 34.000000
10 20917.119141 S 680 Fi
10 20917.121094 S 680 B
10 20917.121094 S 680 chol_model_22
10 20920.425781 S 65 B
10 20920.427735 S 680 Po
10 20920.433594 S 680 B
13 20920.441407 ntask sched 33.000000
10 20920.443360 S 680 Fi
10 20920.445313 S 680 B
10 20920.447266 S 680 chol_model_22
10 20923.658203 S 65 B
10 20923.660157 S 680 Po
10 20923.662110 S 680 B
13 20923.669922 ntask sched 32.000000
10 20923.671875 S 680 Fi
10 20923.671875 S 680 B
10 20923.673828 S 680 chol_model_22
10 20926.882813 S 65 B
10 20926.882813 S 680 Po
10 20926.884766 S 680 B
13 20926.892578 ntask sched 31.000000
10 20926.894531 S 680 Fi
10 20926.896485 S 680 B
10 20926.896485 S 680 chol_model_22
10 20930.205078 S 65 B
10 20930.207031 S 680 Po
10 20930.208985 S 680 B
13 20930.216797 ntask sched 30.000000
10 20930.216797 S 680 Fi
10 20930.218750 S 680 B
10 20930.220703 S 680 chol_model_22
10 20933.515625 S 65 B
10 20933.515625 S 680 Po
10 20933.517578 S 680 B
13 20933.525391 ntask sched 29.000000
10 20933.525391 S 680 Fi
10 20933.527344 S 680 B
10 20933.529297 S 680 chol_model_22
10 20936.855469 S 65 B
10 20936.855469 S 680 Po
10 20936.857422 S 680 B
13 20936.865235 ntask sched 28.000000
10 20936.867188 S 680 Fi
10 20936.869141 S 680 B
10 20936.869141 S 680 chol_model_22
10 20940.189453 S 65 B
10 20940.189453 S 680 Po
10 20940.191407 S 680 B
13 20940.199219 ntask sched 27.000000
10 20940.201172 S 680 Fi
10 20940.201172 S 680 B
10 20940.203125 S 680 chol_model_22
10 20943.419922 S 65 B
10 20943.421875 S 680 Po
10 20943.421875 S 680 B
13 20943.437500 ntask sched 26.000000
10 20943.437500 S 680 Fi
10 20943.439453 S 680 B
10 20943.441407 S 680 chol_model_22
10 20946.697266 S 65 B
10 20946.699219 S 680 Po
10 20946.699219 S 680 B
13 20946.707031 ntask sched 25.000000
10 20946.710938 S 680 Fi
10 20946.712891 S 680 B
10 20946.712891 S 680 chol_model_22
10 20950.029297 S 65 B
10 20950.029297 S 680 Po
10 20950.031250 S 680 B
13 20950.037110 ntask sched 24.000000
10 20950.039063 S 680 Fi
10 20950.041016 S 680 B
10 20950.041016 S 680 chol_model_22
10 20953.294922 S 65 B
10 20953.294922 S 680 Po
10 20953.296875 S 680 B
13 20953.304688 ntask sched 23.000000
10 20953.306641 S 680 Fi
10 20953.308594 S 680 B
10 20953.308594 S 680 chol_model_22
10 20956.552735 S 65 B
10 20956.552735 S 680 Po
10 20956.554688 S 680 B
13 20956.564453 ntask sched 22.000000
10 20956.564453 S 680 Fi
10 20956.566407 S 680 B
10 20956.566407 S 680 chol_model_22
10 20959.804688 S 65 B
10 20959.804688 S 680 Po
10 20959.806641 S 680 B
13 20959.816407 ntask sched 21.000000
10 20959.818360 S 680 Fi
10 20959.820313 S 680 B
10 20959.820313 S 680 chol_model_22
10 20963.058594 S 65 B
10 20963.058594 S 680 Po
10 20963.060547 S 680 B
13 20963.068360 ntask sched 20.000000
10 20963.070313 S 680 Fi
10 20963.072266 S 680 B
10 20963.072266 S 680 chol_model_22
10 20966.296875 S 65 B
10 20966.296875 S 680 Po
10 20966.298828 S 680 B
13 20966.306641 ntask sched 19.000000
10 20966.308594 S 680 Fi
10 20966.310547 S 680 B
10 20966.310547 S 680 chol_model_22
10 20969.611328 S 65 B
10 20969.611328 S 680 Po
10 20969.613281 S 680 B
13 20969.621094 ntask sched 18.000000
10 20969.623047 S 680 Fi
10 20969.625000 S 680 B
10 20969.625000 S 680 chol_model_22
10 20972.929688 S 65 B
10 20972.931641 S 680 Po
10 20972.933594 S 680 B
13 20972.941407 ntask sched 17.000000
10 20972.943360 S 680 Fi
10 20972.945313 S 680 B
10 20972.945313 S 680 chol_model_22
10 20976.169922 S 65 B
10 20976.171875 S 680 Po
10 20976.173828 S 680 B
13 20976.179688 ntask sched 16.000000
10 20976.181641 S 680 Fi
10 20976.183594 S 680 B
10 20976.183594 S 680 chol_model_22
10 20979.476563 S 65 B
10 20979.476563 S 680 Po
10 20979.478516 S 680 B
13 20979.486328 ntask sched 15.000000
10 20979.488281 S 680 Fi
10 20979.490235 S 680 B
10 20979.490235 S 680 chol_model_22
10 20982.798828 S 65 B
10 20982.798828 S 680 Po
10 20982.800781 S 680 B
13 20982.808594 ntask sched 14.000000
10 20982.810547 S 680 Fi
10 20982.810547 S 680 B
10 20982.812500 S 680 chol_model_22
10 20986.029297 S 65 B
10 20986.031250 S 680 Po
10 20986.031250 S 680 B
13 20986.041016 ntask sched 13.000000
10 20986.041016 S 680 Fi
10 20986.044922 S 680 B
10 20986.044922 S 680 chol_model_22
10 20989.255860 S 65 B
10 20989.255860 S 680 Po
10 20989.257813 S 680 B
13 20989.265625 ntask sched 12.000000
10 20989.267578 S 680 Fi
10 20989.269531 S 680 B
10 20989.269531 S 680 chol_model_22
10 20992.601563 S 65 B
10 20992.603516 S 680 Po
10 20992.603516 S 680 B
13 20992.613281 ntask sched 11.000000
10 20992.613281 S 680 Fi
10 20992.615235 S 680 B
10 20992.617188 S 680 chol_model_22
10 20995.837891 S 65 B
10 20995.839844 S 680 Po
10 20995.839844 S 680 B
13 20995.847657 ntask sched 10.000000
10 20995.849610 S 680 Fi
10 20995.851563 S 680 B
10 20995.851563 S 680 chol_model_22
10 20999.064453 S 65 B
10 20999.064453 S 680 Po
10 20999.066407 S 680 B
13 20999.074219 ntask sched 9.000000
10 20999.074219 S 680 Fi
10 20999.076172 S 680 B
10 20999.078125 S 680 chol_model_22
10 21002.308594 S 65 B
10 21002.308594 S 680 Po
10 21002.310547 S 680 B
13 21002.318360 ntask sched 8.000000
10 21002.320313 S 680 Fi
10 21002.322266 S 680 B
10 21002.322266 S 680 chol_model_22
10 21005.625000 S 65 B
10 21005.626953 S 680 Po
10 21005.628907 S 680 B
13 21005.636719 ntask sched 7.000000
10 21005.638672 S 680 Fi
10 21005.640625 S 680 B
10 21005.640625 S 680 chol_model_22
10 21008.957031 S 65 B
10 21008.957031 S 680 Po
10 21008.960938 S 680 B
13 21008.968750 ntask sched 6.000000
10 21008.968750 S 680 Fi
10 21008.970703 S 680 B
10 21008.972657 S 680 chol_model_22
10 21012.281250 S 65 B
10 21012.283203 S 680 Po
10 21012.285157 S 680 B
13 21012.291016 ntask sched 5.000000
10 21012.294922 S 680 Fi
10 21012.296875 S 680 B
10 21012.296875 S 680 chol_model_22
10 21015.535157 S 65 B
10 21015.537110 S 680 Po
10 21015.539063 S 680 B
13 21015.546875 ntask sched 4.000000
10 21015.546875 S 680 Fi
10 21015.548828 S 680 B
10 21015.550781 S 680 chol_model_22
10 21018.775391 S 65 B
10 21018.775391 S 680 Po
10 21018.777344 S 680 B
13 21018.783203 ntask sched 3.000000
10 21018.785157 S 680 Fi
10 21018.787110 S 680 B
10 21018.791016 S 680 chol_model_21
10 21027.031250 S 65 B
10 21027.033203 S 680 Po
10 21027.035157 S 680 B
13 21027.074219 ntask sched 4.000000
13 21027.105469 ntask sched 5.000000
13 21027.136719 ntask sched 6.000000
13 21027.166016 ntask sched 7.000000
13 21027.195313 ntask sched 8.000000
13 21027.226563 ntask sched 9.000000
13 21027.257813 ntask sched 10.000000
13 21027.285157 ntask sched 11.000000
13 21027.314453 ntask sched 12.000000
13 21027.343750 ntask sched 13.000000
13 21027.349610 ntask sched 12.000000
10 21027.351563 S 680 Fi
10 21027.353516 S 680 B
10 21027.353516 S 680 chol_model_22
10 21030.605469 S 65 B
10 21030.607422 S 680 Po
10 21030.609375 S 680 B
13 21030.617188 ntask sched 11.000000
10 21030.619141 S 680 Fi
10 21030.621094 S 680 B
10 21030.621094 S 680 chol_model_22
10 21033.933594 S 65 B
10 21033.933594 S 680 Po
10 21033.935547 S 680 B
13 21033.943360 ntask sched 10.000000
10 21033.945313 S 680 Fi
10 21033.945313 S 680 B
10 21033.947266 S 680 chol_model_22
10 21037.257813 S 65 B
10 21037.257813 S 680 Po
10 21037.259766 S 680 B
13 21037.265625 ntask sched 9.000000
10 21037.267578 S 680 Fi
10 21037.269531 S 680 B
10 21037.269531 S 680 chol_model_22
10 21040.501953 S 65 B
10 21040.503907 S 680 Po
10 21040.505860 S 680 B
13 21040.513672 ntask sched 8.000000
10 21040.513672 S 680 Fi
10 21040.515625 S 680 B
10 21040.515625 S 680 chol_model_22
10 21043.730469 S 65 B
10 21043.730469 S 680 Po
10 21043.732422 S 680 B
13 21043.740235 ntask sched 7.000000
10 21043.742188 S 680 Fi
10 21043.744141 S 680 B
10 21043.744141 S 680 chol_model_22
10 21047.027344 S 65 B
10 21047.027344 S 680 Po
10 21047.029297 S 680 B
13 21047.037110 ntask sched 6.000000
10 21047.037110 S 680 Fi
10 21047.039063 S 680 B
10 21047.039063 S 680 chol_model_22
10 21050.265625 S 65 B
10 21050.265625 S 680 Po
10 21050.267578 S 680 B
13 21050.275391 ntask sched 5.000000
10 21050.277344 S 680 Fi
10 21050.279297 S 680 B
10 21050.279297 S 680 chol_model_22
10 21053.503907 S 65 B
10 21053.503907 S 680 Po
10 21053.505860 S 680 B
13 21053.513672 ntask sched 4.000000
10 21053.513672 S 680 Fi
10 21053.517578 S 680 B
10 21053.517578 S 680 chol_model_22
10 21056.750000 S 65 B
10 21056.751953 S 680 Po
10 21056.753907 S 680 B
13 21056.759766 ntask sched 3.000000
10 21056.761719 S 680 Fi
10 21056.761719 S 680 B
10 21056.763672 S 680 chol_model_22
10 21059.982422 S 65 B
10 21059.984375 S 680 Po
10 21059.986328 S 680 B
13 21059.992188 ntask sched 2.000000
10 21059.994141 S 680 Fi
10 21059.996094 S 680 B
10 21059.998047 S 680 chol_model_21
10 21068.261719 S 65 B
10 21068.263672 S 680 Po
10 21068.265625 S 680 B
13 21068.300781 ntask sched 3.000000
13 21068.328125 ntask sched 4.000000
13 21068.359375 ntask sched 5.000000
13 21068.388672 ntask sched 6.000000
13 21068.419922 ntask sched 7.000000
13 21068.455078 ntask sched 8.000000
13 21068.484375 ntask sched 9.000000
13 21068.515625 ntask sched 10.000000
13 21068.546875 ntask sched 11.000000
13 21068.574219 ntask sched 12.000000
13 21068.603516 ntask sched 13.000000
13 21068.607422 ntask sched 12.000000
10 21068.609375 S 680 Fi
10 21068.611328 S 680 B
10 21068.611328 S 680 chol_model_22
10 21071.949219 S 65 B
10 21071.949219 S 680 Po
10 21071.951172 S 680 B
13 21071.960938 ntask sched 11.000000
10 21071.962891 S 680 Fi
10 21071.964844 S 680 B
10 21071.966797 S 680 chol_model_22
10 21075.281250 S 65 B
10 21075.281250 S 680 Po
10 21075.283203 S 680 B
13 21075.291016 ntask sched 10.000000
10 21075.294922 S 680 Fi
10 21075.294922 S 680 B
10 21075.296875 S 680 chol_model_22
10 21078.531250 S 65 B
10 21078.531250 S 680 Po
10 21078.533203 S 680 B
13 21078.542969 ntask sched 9.000000
10 21078.544922 S 680 Fi
10 21078.546875 S 680 B
10 21078.546875 S 680 chol_model_22
10 21081.861328 S 65 B
10 21081.863281 S 680 Po
10 21081.863281 S 680 B
13 21081.873047 ntask sched 8.000000
10 21081.875000 S 680 Fi
10 21081.875000 S 680 B
10 21081.876953 S 680 chol_model_22
10 21085.175781 S 65 B
10 21085.175781 S 680 Po
10 21085.177735 S 680 B
13 21085.185547 ntask sched 7.000000
10 21085.187500 S 680 Fi
10 21085.187500 S 680 B
10 21085.189453 S 680 chol_model_22
10 21088.398438 S 65 B
10 21088.398438 S 680 Po
10 21088.400391 S 680 B
13 21088.408203 ntask sched 6.000000
10 21088.408203 S 680 Fi
10 21088.410157 S 680 B
10 21088.410157 S 680 chol_model_22
10 21091.744141 S 65 B
10 21091.746094 S 680 Po
10 21091.746094 S 680 B
13 21091.755860 ntask sched 5.000000
10 21091.755860 S 680 Fi
10 21091.757813 S 680 B
10 21091.757813 S 680 chol_model_22
10 21095.068360 S 65 B
10 21095.070313 S 680 Po
10 21095.072266 S 680 B
13 21095.078125 ntask sched 4.000000
10 21095.080078 S 680 Fi
10 21095.082031 S 680 B
10 21095.082031 S 680 chol_model_22
10 21098.306641 S 65 B
10 21098.308594 S 680 Po
10 21098.310547 S 680 B
13 21098.318360 ntask sched 3.000000
10 21098.318360 S 680 Fi
10 21098.320313 S 680 B
10 21098.320313 S 680 chol_model_22
10 21101.634766 S 65 B
10 21101.634766 S 680 Po
10 21101.636719 S 680 B
13 21101.644531 ntask sched 2.000000
10 21101.644531 S 680 Fi
10 21101.646485 S 680 B
10 21101.646485 S 680 chol_model_22
10 21104.968750 S 65 B
10 21104.970703 S 680 Po
10 21104.972657 S 680 B
13 21104.978516 ntask sched 1.000000
10 21104.980469 S 680 Fi
10 21104.982422 S 680 B
10 21104.986328 S 680 chol_model_21
10 21113.212891 S 65 B
10 21113.212891 S 680 Po
10 21113.214844 S 680 B
13 21113.250000 ntask sched 2.000000
13 21113.279297 ntask sched 3.000000
13 21113.310547 ntask sched 4.000000
13 21113.339844 ntask sched 5.000000
13 21113.369141 ntask sched 6.000000
13 21113.400391 ntask sched 7.000000
13 21113.435547 ntask sched 8.000000
13 21113.464844 ntask sched 9.000000
13 21113.496094 ntask sched 10.000000
13 21113.527344 ntask sched 11.000000
13 21113.556641 ntask sched 12.000000
13 21113.587891 ntask sched 13.000000
13 21113.593750 ntask sched 12.000000
10 21113.593750 S 680 Fi
10 21113.595703 S 680 B
10 21113.595703 S 680 chol_model_22
10 21116.814453 S 65 B
10 21116.814453 S 680 Po
10 21116.816407 S 680 B
13 21116.824219 ntask sched 11.000000
10 21116.824219 S 680 Fi
10 21116.826172 S 680 B
10 21116.828125 S 680 chol_model_22
10 21120.123047 S 65 B
10 21120.123047 S 680 Po
10 21120.125000 S 680 B
13 21120.132813 ntask sched 10.000000
10 21120.134766 S 680 Fi
10 21120.134766 S 680 B
10 21120.136719 S 680 chol_model_22
10 21123.423828 S 65 B
10 21123.425781 S 680 Po
10 21123.427735 S 680 B
13 21123.439453 ntask sched 9.000000
10 21123.441407 S 680 Fi
10 21123.441407 S 680 B
10 21123.443360 S 680 chol_model_22
10 21126.691407 S 65 B
10 21126.693360 S 680 Po
10 21126.695313 S 680 B
13 21126.701172 ntask sched 8.000000
10 21126.703125 S 680 Fi
10 21126.705078 S 680 B
10 21126.705078 S 680 chol_model_22
10 21129.937500 S 65 B
10 21129.937500 S 680 Po
10 21129.939453 S 680 B
13 21129.947266 ntask sched 7.000000
10 21129.947266 S 680 Fi
10 21129.949219 S 680 B
10 21129.949219 S 680 chol_model_22
10 21133.216797 S 65 B
10 21133.216797 S 680 Po
10 21133.218750 S 680 B
13 21133.224610 ntask sched 6.000000
10 21133.226563 S 680 Fi
10 21133.228516 S 680 B
10 21133.228516 S 680 chol_model_22
10 21136.468750 S 65 B
10 21136.468750 S 680 Po
10 21136.470703 S 680 B
13 21136.478516 ntask sched 5.000000
10 21136.480469 S 680 Fi
10 21136.482422 S 680 B
10 21136.482422 S 680 chol_model_22
10 21139.787110 S 65 B
10 21139.789063 S 680 Po
10 21139.791016 S 680 B
13 21139.798828 ntask sched 4.000000
10 21139.800781 S 680 Fi
10 21139.802735 S 680 B
10 21139.802735 S 680 chol_model_22
10 21143.085938 S 65 B
10 21143.085938 S 680 Po
10 21143.087891 S 680 B
13 21143.093750 ntask sched 3.000000
10 21143.095703 S 680 Fi
10 21143.097657 S 680 B
10 21143.097657 S 680 chol_model_22
10 21146.406250 S 65 B
10 21146.406250 S 680 Po
10 21146.408203 S 680 B
13 21146.416016 ntask sched 2.000000
10 21146.417969 S 680 Fi
10 21146.419922 S 680 B
10 21146.419922 S 680 chol_model_22
10 21149.621094 S 65 B
10 21149.621094 S 680 Po
10 21149.623047 S 680 B
13 21149.630860 ntask sched 1.000000
10 21149.632813 S 680 Fi
10 21149.634766 S 680 B
10 21149.634766 S 680 chol_model_22
10 21152.939453 S 65 B
10 21152.939453 S 680 Po
10 21152.941407 S 680 B
13 21152.949219 ntask sched 0.000000
10 21152.953125 S 680 Fi
10 21152.953125 S 680 B
10 21152.957031 S 680 chol_model_21
10 21161.164063 S 65 B
10 21161.166016 S 680 Po
10 21161.169922 S 680 B
13 21161.203125 ntask sched 1.000000
13 21161.234375 ntask sched 2.000000
13 21161.263672 ntask sched 3.000000
13 21161.292969 ntask sched 4.000000
13 21161.324219 ntask sched 5.000000
13 21161.353516 ntask sched 6.000000
13 21161.384766 ntask sched 7.000000
13 21161.414063 ntask sched 8.000000
13 21161.449219 ntask sched 9.000000
13 21161.480469 ntask sched 10.000000
13 21161.509766 ntask sched 11.000000
13 21161.539063 ntask sched 12.000000
13 21161.570313 ntask sched 13.000000
13 21161.574219 ntask sched 12.000000
10 21161.576172 S 680 Fi
10 21161.578125 S 680 B
10 21161.578125 S 680 chol_model_22
10 21164.802735 S 65 B
10 21164.804688 S 680 Po
10 21164.806641 S 680 B
13 21164.814453 ntask sched 11.000000
10 21164.814453 S 680 Fi
10 21164.816407 S 680 B
10 21164.816407 S 680 chol_model_22
10 21168.138672 S 65 B
10 21168.140625 S 680 Po
10 21168.140625 S 680 B
13 21168.150391 ntask sched 10.000000
10 21168.152344 S 680 Fi
10 21168.154297 S 680 B
10 21168.154297 S 680 chol_model_22
10 21171.373047 S 65 B
10 21171.373047 S 680 Po
10 21171.375000 S 680 B
13 21171.382813 ntask sched 9.000000
10 21171.384766 S 680 Fi
10 21171.386719 S 680 B
10 21171.386719 S 680 chol_model_22
10 21174.666016 S 65 B
10 21174.666016 S 680 Po
10 21174.669922 S 680 B
13 21174.677735 ntask sched 8.000000
10 21174.677735 S 680 Fi
10 21174.679688 S 680 B
10 21174.681641 S 680 chol_model_22
10 21177.978516 S 65 B
10 21177.980469 S 680 Po
10 21177.980469 S 680 B
13 21177.988281 ntask sched 7.000000
10 21177.990235 S 680 Fi
10 21177.992188 S 680 B
10 21177.992188 S 680 chol_model_22
10 21181.224610 S 65 B
10 21181.224610 S 680 Po
10 21181.226563 S 680 B
13 21181.234375 ntask sched 6.000000
10 21181.236328 S 680 Fi
10 21181.236328 S 680 B
10 21181.238281 S 680 chol_model_22
10 21184.505860 S 65 B
10 21184.505860 S 680 Po
10 21184.507813 S 680 B
13 21184.515625 ntask sched 5.000000
10 21184.517578 S 680 Fi
10 21184.519531 S 680 B
10 21184.519531 S 680 chol_model_22
10 21187.822266 S 65 B
10 21187.822266 S 680 Po
10 21187.824219 S 680 B
13 21187.832031 ntask sched 4.000000
10 21187.833985 S 680 Fi
10 21187.835938 S 680 B
10 21187.835938 S 680 chol_model_22
10 21191.126953 S 65 B
10 21191.128907 S 680 Po
10 21191.130860 S 680 B
13 21191.136719 ntask sched 3.000000
10 21191.138672 S 680 Fi
10 21191.140625 S 680 B
10 21191.140625 S 680 chol_model_22
10 21194.466797 S 65 B
10 21194.466797 S 680 Po
10 21194.468750 S 680 B
13 21194.476563 ntask sched 2.000000
10 21194.478516 S 680 Fi
10 21194.478516 S 680 B
10 21194.480469 S 680 chol_model_22
10 21197.779297 S 65 B
10 21197.781250 S 680 Po
10 21197.783203 S 680 B
13 21197.789063 ntask sched 1.000000
10 21197.791016 S 680 Fi
10 21197.792969 S 680 B
10 21197.794922 S 680 chol_model_22
10 21201.017578 S 65 B
10 21201.017578 S 680 Po
10 21201.019531 S 680 B
13 21201.027344 ntask sched 0.000000
10 21201.029297 S 680 Fi
10 21201.029297 S 680 B
10 21201.031250 S 680 chol_model_22
10 21204.248047 S 65 B
10 21204.248047 S 680 Po
10 21204.250000 S 680 B
13 21204.285157 ntask sched 1.000000
13 21204.289063 ntask sched 0.000000
10 21204.291016 S 680 Fi
10 21204.291016 S 680 B
10 21204.296875 S 680 chol_model_11
10 21277.800781 S 65 B
10 21277.802735 S 680 Po
10 21277.804688 S 680 B
13 21277.841797 ntask sched 1.000000
13 21277.871094 ntask sched 2.000000
13 21277.902344 ntask sched 3.000000
13 21277.910157 ntask sched 2.000000
10 21277.912110 S 679 Fi
13 21277.937500 ntask sched 3.000000
13 21277.966797 ntask sched 4.000000
13 21277.994141 ntask sched 5.000000
13 21278.023438 ntask sched 6.000000
13 21278.050781 ntask sched 7.000000
13 21278.078125 ntask sched 8.000000
13 21278.103516 ntask sched 9.000000
13 21278.132813 ntask sched 10.000000
13 21278.160157 ntask sched 11.000000
10 21278.162110 MS MEMNODE0 Co
18 21278.162110 L p 4000000 MEMNODE2 com_191
10 21278.164063 MS MEMNODE0 Co
18 21278.164063 L p 4000000 MEMNODE2 com_192
10 21278.175781 MS MEMNODE0 CoA
10 21278.183594 MS MEMNODE0 CoA
10 21280.210938 MS MEMNODE0 No
19 21280.210938 L p 2273874960 MEMNODE0 com_2273874768
10 21282.294922 MS MEMNODE0 No
19 21282.294922 L p 2273874968 MEMNODE0 com_2273874768
13 21282.304688 ntask sched 10.000000
10 21282.304688 S 681 Fi
10 21282.308594 MS MEMNODE0 Co
18 21282.308594 L p 4000000 MEMNODE2 com_193
10 21282.316407 MS MEMNODE0 CoA
10 21284.345703 MS MEMNODE0 No
19 21284.345703 L p 2273874960 MEMNODE0 com_2273874768
10 21284.347657 MS MEMNODE0 No
19 21284.347657 L p 4000000 MEMNODE0 com_191
10 21284.351563 MS MEMNODE0 Co
18 21284.351563 L p 4000000 MEMNODE2 com_194
10 21284.357422 MS MEMNODE0 CoA
10 21286.371094 MS MEMNODE0 No
19 21286.371094 L p 2273874960 MEMNODE0 com_2273874768
10 21286.375000 MS MEMNODE0 Co
18 21286.375000 L p 4000000 MEMNODE2 com_195
10 21286.382813 MS MEMNODE0 CoA
10 21288.400391 MS MEMNODE0 No
19 21288.400391 L p 2273874960 MEMNODE0 com_2273874768
10 21288.404297 MS MEMNODE0 Co
18 21288.404297 L p 4000000 MEMNODE2 com_196
10 21288.414063 MS MEMNODE0 CoA
10 21290.447266 MS MEMNODE0 No
19 21290.447266 L p 2273874960 MEMNODE0 com_2273874768
10 21290.453125 MS MEMNODE0 Co
18 21290.453125 L p 4000000 MEMNODE2 com_197
10 21290.460938 MS MEMNODE0 CoA
10 21292.478516 MS MEMNODE0 No
19 21292.478516 L p 2273874960 MEMNODE0 com_2273874768
13 21292.486328 ntask sched 9.000000
10 21292.488281 S 680 Fi
10 21292.490235 S 680 B
10 21292.521485 S 680 chol_model_21
10 21300.787110 S 65 B
10 21300.789063 S 680 Po
10 21300.791016 S 680 B
13 21300.826172 ntask sched 10.000000
10 21300.837891 MS MEMNODE0 No
19 21300.837891 L p 4000000 MEMNODE0 com_197
10 21300.839844 MS MEMNODE1 A
10 21300.839844 MS MEMNODE0 No
19 21300.839844 L p 4000000 MEMNODE0 com_196
10 21300.841797 MS MEMNODE0 No
19 21300.841797 L p 4000000 MEMNODE0 com_195
10 21300.843750 MS MEMNODE0 No
19 21300.843750 L p 4000000 MEMNODE0 com_194
10 21300.847657 MS MEMNODE0 No
19 21300.847657 L p 4000000 MEMNODE0 com_193
10 21300.849610 MS MEMNODE0 No
19 21300.849610 L p 4000000 MEMNODE0 com_192
13 21300.851563 ntask sched 9.000000
10 21300.853516 S 680 Fi
10 21300.853516 S 680 B
10 21300.855469 S 680 chol_model_22
10 21300.855469 S 681 B
10 21300.857422 S 681 chol_model_21
10 21300.966797 MS MEMNODE1 No
10 21300.970703 MS MEMNODE1 Co
18 21300.970703 L p 4000000 MEMNODE0 com_198
10 21300.974610 MS MEMNODE1 CoA
10 21302.105469 MS MEMNODE1 No
19 21302.105469 L p 2273874960 MEMNODE1 com_2273874768
10 21302.113281 MS MEMNODE1 A
10 21302.232422 MS MEMNODE1 No
10 21302.234375 MS MEMNODE1 Co
18 21302.234375 L p 4000000 MEMNODE0 com_199
10 21302.238281 MS MEMNODE1 CoA
10 21303.392578 MS MEMNODE1 No
19 21303.392578 L p 2273874960 MEMNODE1 com_2273874768
10 21303.398438 MS MEMNODE1 A
10 21303.519531 MS MEMNODE1 No
10 21303.521485 MS MEMNODE1 Co
18 21303.521485 L p 4000000 MEMNODE0 com_200
10 21303.527344 MS MEMNODE1 CoA
10 21304.070313 S 65 B
10 21304.070313 S 680 Po
10 21304.072266 S 680 B
13 21304.080078 ntask sched 8.000000
10 21304.080078 S 680 Fi
10 21304.082031 S 680 B
10 21304.085938 S 680 chol_model_21
10 21304.681641 MS MEMNODE1 No
19 21304.681641 L p 2273874960 MEMNODE1 com_2273874768
10 21304.685547 MS MEMNODE1 A
10 21304.804688 MS MEMNODE1 No
10 21304.806641 MS MEMNODE1 Co
18 21304.806641 L p 4000000 MEMNODE0 com_201
10 21304.810547 MS MEMNODE1 CoA
10 21305.972657 MS MEMNODE1 No
19 21305.972657 L p 2273874960 MEMNODE1 com_2273874768
10 21305.976563 MS MEMNODE1 A
10 21306.093750 MS MEMNODE1 No
10 21306.095703 MS MEMNODE1 Co
18 21306.095703 L p 4000000 MEMNODE0 com_202
10 21306.101563 MS MEMNODE1 CoA
10 21307.261719 MS MEMNODE1 No
19 21307.261719 L p 2273874960 MEMNODE1 com_2273874768
10 21307.267578 MS MEMNODE1 A
10 21307.386719 MS MEMNODE1 No
10 21307.388672 MS MEMNODE1 Co
18 21307.388672 L p 4000000 MEMNODE0 com_203
10 21307.410157 MS MEMNODE1 CoA
10 21308.576172 MS MEMNODE1 No
19 21308.576172 L p 2273874960 MEMNODE1 com_2273874768
10 21308.613281 MS MEMNODE1 No
19 21308.613281 L p 4000000 MEMNODE1 com_202
10 21308.640625 MS MEMNODE1 No
19 21308.640625 L p 4000000 MEMNODE1 com_201
10 21308.664063 MS MEMNODE1 No
19 21308.664063 L p 4000000 MEMNODE1 com_200
10 21308.689453 MS MEMNODE1 No
19 21308.689453 L p 4000000 MEMNODE1 com_199
10 21308.712891 MS MEMNODE1 No
19 21308.712891 L p 4000000 MEMNODE1 com_198
10 21308.765625 MS MEMNODE1 No
19 21308.765625 L p 4000000 MEMNODE1 com_203
10 21308.765625 S 679 B
10 21308.771485 S 679 chol_model_21
10 21312.351563 S 65 B
10 21312.353516 S 680 Po
10 21312.355469 S 680 B
13 21312.392578 ntask sched 9.000000
13 21312.421875 ntask sched 10.000000
13 21312.425781 ntask sched 9.000000
10 21312.427735 S 680 Fi
10 21312.427735 S 680 B
10 21312.435547 S 680 chol_model_22
10 21315.662110 S 65 B
10 21315.662110 S 680 Po
10 21315.664063 S 680 B
13 21315.671875 ntask sched 8.000000
10 21315.673828 S 680 Fi
10 21315.673828 S 680 B
10 21315.675781 S 680 chol_model_22
10 21317.101563 S 64 B
10 21317.105469 S 679 Po
10 21317.107422 S 679 B
13 21317.150391 ntask sched 9.000000
13 21317.179688 ntask sched 10.000000
13 21317.208985 ntask sched 11.000000
10 21317.214844 MS MEMNODE0 Co
18 21317.214844 L p 4000000 MEMNODE1 com_204
10 21317.220703 MS MEMNODE0 CoA
10 21318.804688 MS MEMNODE0 No
19 21318.804688 L p 2273874960 MEMNODE0 com_2273874768
13 21318.812500 ntask sched 10.000000
10 21318.814453 S 679 Fi
10 21318.816407 S 679 B
10 21318.847657 S 679 chol_model_21
10 21318.888672 S 65 B
10 21318.890625 S 680 Po
10 21318.892578 S 680 B
13 21318.900391 ntask sched 9.000000
10 21318.900391 S 680 Fi
10 21327.148438 S 64 B
10 21327.150391 S 679 Po
10 21327.152344 S 679 B
13 21327.187500 ntask sched 10.000000
13 21327.214844 ntask sched 11.000000
13 21327.242188 ntask sched 12.000000
13 21327.267578 ntask sched 13.000000
10 21327.275391 MS MEMNODE0 No
19 21327.275391 L p 4000000 MEMNODE0 com_204
10 21327.277344 MS MEMNODE2 Co
18 21327.277344 L p 4000000 MEMNODE0 com_205
10 21327.279297 MS MEMNODE0 Co
18 21327.279297 L p 4000000 MEMNODE1 com_206
10 21327.285157 MS MEMNODE0 CoA
10 21327.287110 MS MEMNODE2 CoA
10 21328.574219 MS MEMNODE2 No
19 21328.574219 L p 2273874960 MEMNODE2 com_2273874768
10 21328.771485 MS MEMNODE2 No
19 21328.771485 L p 4000000 MEMNODE2 com_205
10 21328.773438 S 680 B
10 21328.775391 S 680 chol_model_22
10 21328.826172 MS MEMNODE0 No
19 21328.826172 L p 2273874960 MEMNODE0 com_2273874768
13 21328.833985 ntask sched 12.000000
10 21328.835938 S 679 Fi
10 21328.837891 S 679 B
10 21328.869141 S 679 chol_model_21
10 21332.070313 S 65 B
10 21332.072266 S 680 Po
10 21332.074219 S 680 B
13 21332.082031 ntask sched 11.000000
10 21332.082031 S 680 Fi
10 21337.183594 S 64 B
10 21337.185547 S 679 Po
10 21337.187500 S 679 B
13 21337.222657 ntask sched 12.000000
13 21337.250000 ntask sched 13.000000
13 21337.277344 ntask sched 14.000000
13 21337.306641 ntask sched 15.000000
13 21337.332031 ntask sched 16.000000
10 21337.343750 MS MEMNODE0 No
19 21337.343750 L p 4000000 MEMNODE0 com_206
10 21337.345703 MS MEMNODE2 Co
18 21337.345703 L p 4000000 MEMNODE0 com_207
10 21337.345703 MS MEMNODE0 Co
18 21337.345703 L p 4000000 MEMNODE1 com_208
10 21337.353516 MS MEMNODE2 CoA
10 21337.353516 MS MEMNODE0 CoA
10 21338.652344 MS MEMNODE2 No
19 21338.652344 L p 2273874960 MEMNODE2 com_2273874768
10 21338.816407 MS MEMNODE0 No
19 21338.816407 L p 2273874968 MEMNODE0 com_2273874768
13 21338.822266 ntask sched 15.000000
10 21338.824219 S 679 Fi
10 21338.826172 S 679 B
10 21338.849610 MS MEMNODE2 No
19 21338.849610 L p 4000000 MEMNODE2 com_207
10 21338.853516 S 680 B
10 21338.853516 S 680 chol_model_22
10 21338.875000 S 679 chol_model_21
10 21342.068360 S 65 B
10 21342.070313 S 680 Po
10 21342.072266 S 680 B
13 21342.080078 ntask sched 14.000000
10 21342.080078 S 680 Fi
10 21347.183594 S 64 B
10 21347.185547 S 679 Po
10 21347.187500 S 679 B
13 21347.222657 ntask sched 15.000000
13 21347.250000 ntask sched 16.000000
13 21347.277344 ntask sched 17.000000
13 21347.306641 ntask sched 18.000000
13 21347.332031 ntask sched 19.000000
13 21347.359375 ntask sched 20.000000
10 21347.367188 MS MEMNODE0 No
19 21347.367188 L p 4000000 MEMNODE0 com_208
10 21347.369141 MS MEMNODE0 Co
18 21347.369141 L p 4000000 MEMNODE1 com_209
10 21347.369141 MS MEMNODE2 Co
18 21347.369141 L p 4000000 MEMNODE0 com_210
10 21347.375000 MS MEMNODE0 CoA
10 21347.378907 MS MEMNODE2 CoA
10 21348.666016 MS MEMNODE2 No
19 21348.666016 L p 2273874960 MEMNODE2 com_2273874768
10 21348.861328 MS MEMNODE2 No
19 21348.861328 L p 4000000 MEMNODE2 com_210
10 21348.865235 S 680 B
10 21348.867188 S 680 chol_model_22
10 21348.878907 MS MEMNODE0 No
19 21348.878907 L p 2273874960 MEMNODE0 com_2273874768
13 21348.884766 ntask sched 19.000000
10 21348.886719 S 679 Fi
10 21348.888672 S 679 B
10 21348.919922 S 679 chol_model_21
10 21349.359375 S 0 B
10 21349.363281 S 681 Po
10 21349.365235 S 681 B
13 21349.402344 ntask sched 20.000000
13 21349.439453 ntask sched 21.000000
13 21349.466797 ntask sched 22.000000
13 21349.496094 ntask sched 23.000000
13 21349.525391 ntask sched 24.000000
13 21349.554688 ntask sched 25.000000
13 21349.580078 ntask sched 26.000000
10 21352.171875 S 65 B
10 21352.173828 S 680 Po
10 21352.175781 S 680 B
10 21352.181641 MS MEMNODE2 Co
18 21352.181641 L p 4000000 MEMNODE0 com_211
10 21352.193360 MS MEMNODE2 CoA
10 21353.361328 MS MEMNODE2 No
19 21353.361328 L p 2273874960 MEMNODE2 com_2273874768
13 21353.367188 ntask sched 25.000000
10 21353.369141 S 680 Fi
10 21353.560547 MS MEMNODE2 No
19 21353.560547 L p 4000000 MEMNODE2 com_211
10 21353.562500 S 680 B
10 21353.562500 S 680 chol_model_22
10 21356.783203 S 65 B
10 21356.785157 S 680 Po
10 21356.787110 S 680 B
13 21356.794922 ntask sched 24.000000
10 21356.794922 S 680 Fi
10 21356.796875 S 680 B
10 21356.798828 S 680 chol_model_22
10 21357.226563 S 64 B
10 21357.228516 S 679 Po
10 21357.230469 S 679 B
13 21357.263672 ntask sched 25.000000
13 21357.291016 ntask sched 26.000000
13 21357.318360 ntask sched 27.000000
13 21357.345703 ntask sched 28.000000
13 21357.373047 ntask sched 29.000000
13 21357.402344 ntask sched 30.000000
13 21357.429688 ntask sched 31.000000
13 21357.460938 ntask sched 32.000000
10 21357.468750 MS MEMNODE0 No
19 21357.468750 L p 4000000 MEMNODE0 com_209
10 21357.470703 MS MEMNODE0 Co
18 21357.470703 L p 4000000 MEMNODE1 com_212
10 21357.474610 MS MEMNODE0 CoA
10 21359.015625 MS MEMNODE0 No
19 21359.015625 L p 2273874960 MEMNODE0 com_2273874768
10 21359.060547 MS MEMNODE0 No
19 21359.060547 L p 4000000 MEMNODE0 com_212
10 21360.033203 S 65 B
10 21360.035157 S 680 Po
10 21360.037110 S 680 B
10 21360.044922 MS MEMNODE2 Co
18 21360.044922 L p 4000000 MEMNODE0 com_213
10 21360.052735 MS MEMNODE2 CoA
10 21361.294922 MS MEMNODE2 No
19 21361.294922 L p 2273874960 MEMNODE2 com_2273874768
10 21361.300781 MS MEMNODE2 Co
18 21361.300781 L p 4000000 MEMNODE0 com_214
10 21361.308594 MS MEMNODE2 CoA
10 21362.593750 MS MEMNODE2 No
19 21362.593750 L p 2273874960 MEMNODE2 com_2273874768
13 21362.599610 ntask sched 31.000000
10 21362.601563 S 680 Fi
10 21362.636719 MS MEMNODE2 No
19 21362.636719 L p 4000000 MEMNODE2 com_213
10 21362.785157 MS MEMNODE2 No
19 21362.785157 L p 4000000 MEMNODE2 com_214
10 21362.787110 S 680 B
10 21362.789063 S 680 chol_model_22
10 21366.111328 S 65 B
10 21366.111328 S 680 Po
10 21366.113281 S 680 B
13 21366.123047 ntask sched 30.000000
10 21366.125000 S 680 Fi
10 21366.126953 S 680 B
10 21366.126953 S 680 chol_model_22
10 21369.369141 S 65 B
10 21369.371094 S 680 Po
10 21369.373047 S 680 B
13 21369.382813 ntask sched 29.000000
10 21369.382813 S 680 Fi
10 21369.384766 S 680 B
10 21369.386719 S 680 chol_model_22
10 21372.685547 S 65 B
10 21372.685547 S 680 Po
10 21372.687500 S 680 B
13 21372.695313 ntask sched 28.000000
10 21372.697266 S 680 Fi
10 21372.699219 S 680 B
10 21372.699219 S 680 chol_model_22
10 21376.017578 S 65 B
10 21376.019531 S 680 Po
10 21376.021485 S 680 B
13 21376.029297 ntask sched 27.000000
10 21376.031250 S 680 Fi
10 21376.033203 S 680 B
10 21376.033203 S 680 chol_model_22
10 21379.244141 S 65 B
10 21379.244141 S 680 Po
10 21379.246094 S 680 B
13 21379.253907 ntask sched 26.000000
10 21379.255860 S 680 Fi
10 21379.257813 S 680 B
10 21379.257813 S 680 chol_model_22
10 21382.572266 S 65 B
10 21382.574219 S 680 Po
10 21382.576172 S 680 B
13 21382.583985 ntask sched 25.000000
10 21382.585938 S 680 Fi
10 21382.587891 S 680 B
10 21382.587891 S 680 chol_model_22
10 21385.796875 S 65 B
10 21385.798828 S 680 Po
10 21385.800781 S 680 B
13 21385.806641 ntask sched 24.000000
10 21385.808594 S 680 Fi
10 21385.810547 S 680 B
10 21385.812500 S 680 chol_model_22
10 21389.134766 S 65 B
10 21389.134766 S 680 Po
10 21389.136719 S 680 B
13 21389.144531 ntask sched 23.000000
10 21389.146485 S 680 Fi
10 21389.148438 S 680 B
10 21389.148438 S 680 chol_model_22
10 21392.464844 S 65 B
10 21392.464844 S 680 Po
10 21392.466797 S 680 B
13 21392.474610 ntask sched 22.000000
10 21392.474610 S 680 Fi
10 21392.476563 S 680 B
10 21392.478516 S 680 chol_model_22
10 21395.781250 S 65 B
10 21395.783203 S 680 Po
10 21395.783203 S 680 B
13 21395.791016 ntask sched 21.000000
10 21395.792969 S 680 Fi
10 21395.794922 S 680 B
10 21395.794922 S 680 chol_model_22
10 21399.080078 S 65 B
10 21399.080078 S 680 Po
10 21399.082031 S 680 B
13 21399.089844 ntask sched 20.000000
10 21399.091797 S 680 Fi
10 21399.091797 S 680 B
10 21399.093750 S 680 chol_model_22
10 21402.400391 S 65 B
10 21402.400391 S 680 Po
10 21402.402344 S 680 B
13 21402.410157 ntask sched 19.000000
10 21402.410157 S 680 Fi
10 21402.412110 S 680 B
10 21402.412110 S 680 chol_model_22
10 21405.652344 S 65 B
10 21405.654297 S 680 Po
10 21405.656250 S 680 B
13 21405.662110 ntask sched 18.000000
10 21405.664063 S 680 Fi
10 21405.666016 S 680 B
10 21405.666016 S 680 chol_model_22
10 21408.892578 S 65 B
10 21408.892578 S 680 Po
10 21408.894531 S 680 B
13 21408.902344 ntask sched 17.000000
10 21408.904297 S 680 Fi
10 21408.906250 S 680 B
10 21408.906250 S 680 chol_model_22
10 21412.125000 S 65 B
10 21412.126953 S 680 Po
10 21412.128907 S 680 B
13 21412.136719 ntask sched 16.000000
10 21412.138672 S 680 Fi
10 21412.140625 S 680 B
10 21412.140625 S 680 chol_model_22
10 21415.378907 S 65 B
10 21415.378907 S 680 Po
10 21415.380860 S 680 B
13 21415.388672 ntask sched 15.000000
10 21415.390625 S 680 Fi
10 21415.392578 S 680 B
10 21415.392578 S 680 chol_model_22
10 21418.708985 S 65 B
10 21418.710938 S 680 Po
10 21418.710938 S 680 B
13 21418.720703 ntask sched 14.000000
10 21418.722657 S 680 Fi
10 21418.722657 S 680 B
10 21418.724610 S 680 chol_model_22
10 21421.947266 S 65 B
10 21421.949219 S 680 Po
10 21421.951172 S 680 B
13 21421.958985 ntask sched 13.000000
10 21421.960938 S 680 Fi
10 21421.962891 S 680 B
10 21421.962891 S 680 chol_model_22
10 21425.181641 S 65 B
10 21425.183594 S 680 Po
10 21425.185547 S 680 B
13 21425.193360 ntask sched 12.000000
10 21425.195313 S 680 Fi
10 21425.195313 S 680 B
10 21425.197266 S 680 chol_model_22
10 21428.500000 S 65 B
10 21428.501953 S 680 Po
10 21428.503907 S 680 B
13 21428.513672 ntask sched 11.000000
10 21428.513672 S 680 Fi
10 21428.517578 S 680 B
10 21428.517578 S 680 chol_model_22
10 21431.808594 S 65 B
10 21431.810547 S 680 Po
10 21431.812500 S 680 B
13 21431.820313 ntask sched 10.000000
10 21431.822266 S 680 Fi
10 21431.824219 S 680 B
10 21431.824219 S 680 chol_model_22
10 21435.136719 S 65 B
10 21435.136719 S 680 Po
10 21435.138672 S 680 B
13 21435.146485 ntask sched 9.000000
10 21435.146485 S 680 Fi
10 21435.148438 S 680 B
10 21435.148438 S 680 chol_model_22
10 21438.445313 S 65 B
10 21438.445313 S 680 Po
10 21438.447266 S 680 B
13 21438.457031 ntask sched 8.000000
10 21438.458985 S 680 Fi
10 21438.460938 S 680 B
10 21438.460938 S 680 chol_model_22
10 21441.787110 S 65 B
10 21441.787110 S 680 Po
10 21441.789063 S 680 B
13 21441.796875 ntask sched 7.000000
10 21441.798828 S 680 Fi
10 21441.800781 S 680 B
10 21441.800781 S 680 chol_model_22
10 21445.023438 S 65 B
10 21445.023438 S 680 Po
10 21445.025391 S 680 B
13 21445.033203 ntask sched 6.000000
10 21445.033203 S 680 Fi
10 21445.035157 S 680 B
10 21445.037110 S 680 chol_model_22
10 21448.314453 S 65 B
10 21448.314453 S 680 Po
10 21448.316407 S 680 B
13 21448.324219 ntask sched 5.000000
10 21448.324219 S 680 Fi
10 21448.326172 S 680 B
10 21448.328125 S 680 chol_model_22
10 21451.636719 S 65 B
10 21451.636719 S 680 Po
10 21451.638672 S 680 B
13 21451.644531 ntask sched 4.000000
10 21451.646485 S 680 Fi
10 21451.648438 S 680 B
10 21451.648438 S 680 chol_model_22
10 21454.939453 S 65 B
10 21454.941407 S 680 Po
10 21454.943360 S 680 B
13 21454.951172 ntask sched 3.000000
10 21454.953125 S 680 Fi
10 21454.955078 S 680 B
10 21454.957031 S 680 chol_model_21
10 21463.140625 S 65 B
10 21463.142578 S 680 Po
10 21463.142578 S 680 B
13 21463.181641 ntask sched 4.000000
13 21463.210938 ntask sched 5.000000
13 21463.240235 ntask sched 6.000000
13 21463.271485 ntask sched 7.000000
13 21463.302735 ntask sched 8.000000
13 21463.332031 ntask sched 9.000000
13 21463.363281 ntask sched 10.000000
13 21463.392578 ntask sched 11.000000
13 21463.423828 ntask sched 12.000000
13 21463.427735 ntask sched 11.000000
10 21463.429688 S 680 Fi
10 21463.435547 S 680 B
10 21463.437500 S 680 chol_model_22
10 21466.673828 S 65 B
10 21466.675781 S 680 Po
10 21466.677735 S 680 B
13 21466.685547 ntask sched 10.000000
10 21466.685547 S 680 Fi
10 21466.687500 S 680 B
10 21466.689453 S 680 chol_model_22
10 21469.947266 S 65 B
10 21469.947266 S 680 Po
10 21469.949219 S 680 B
13 21469.957031 ntask sched 9.000000
10 21469.958985 S 680 Fi
10 21469.960938 S 680 B
10 21469.960938 S 680 chol_model_22
10 21473.269531 S 65 B
10 21473.269531 S 680 Po
10 21473.271485 S 680 B
13 21473.277344 ntask sched 8.000000
10 21473.279297 S 680 Fi
10 21473.281250 S 680 B
10 21473.281250 S 680 chol_model_22
10 21476.566407 S 65 B
10 21476.568360 S 680 Po
10 21476.570313 S 680 B
13 21476.576172 ntask sched 7.000000
10 21476.578125 S 680 Fi
10 21476.580078 S 680 B
10 21476.580078 S 680 chol_model_22
10 21479.814453 S 65 B
10 21479.814453 S 680 Po
10 21479.816407 S 680 B
13 21479.824219 ntask sched 6.000000
10 21479.826172 S 680 Fi
10 21479.826172 S 680 B
10 21479.828125 S 680 chol_model_22
10 21483.052735 S 65 B
10 21483.052735 S 680 Po
10 21483.054688 S 680 B
13 21483.060547 ntask sched 5.000000
10 21483.062500 S 680 Fi
10 21483.064453 S 680 B
10 21483.064453 S 680 chol_model_22
10 21486.386719 S 65 B
10 21486.388672 S 680 Po
10 21486.390625 S 680 B
13 21486.396485 ntask sched 4.000000
10 21486.396485 S 680 Fi
10 21486.398438 S 680 B
10 21486.398438 S 680 chol_model_22
10 21489.710938 S 65 B
10 21489.710938 S 680 Po
10 21489.712891 S 680 B
13 21489.720703 ntask sched 3.000000
10 21489.720703 S 680 Fi
10 21489.722657 S 680 B
10 21489.724610 S 680 chol_model_22
10 21492.964844 S 65 B
10 21492.964844 S 680 Po
10 21492.966797 S 680 B
13 21492.974610 ntask sched 2.000000
10 21492.974610 S 680 Fi
10 21492.976563 S 680 B
10 21492.980469 S 680 chol_model_21
10 21501.191407 S 65 B
10 21501.193360 S 680 Po
10 21501.195313 S 680 B
13 21501.230469 ntask sched 3.000000
13 21501.261719 ntask sched 4.000000
13 21501.291016 ntask sched 5.000000
13 21501.322266 ntask sched 6.000000
13 21501.351563 ntask sched 7.000000
13 21501.382813 ntask sched 8.000000
13 21501.412110 ntask sched 9.000000
13 21501.449219 ntask sched 10.000000
13 21501.480469 ntask sched 11.000000
13 21501.511719 ntask sched 12.000000
13 21501.517578 ntask sched 11.000000
10 21501.517578 S 680 Fi
10 21501.519531 S 680 B
10 21501.519531 S 680 chol_model_22
10 21504.816407 S 65 B
10 21504.816407 S 680 Po
10 21504.818360 S 680 B
13 21504.826172 ntask sched 10.000000
10 21504.828125 S 680 Fi
10 21504.830078 S 680 B
10 21504.830078 S 680 chol_model_22
10 21508.074219 S 65 B
10 21508.074219 S 680 Po
10 21508.076172 S 680 B
13 21508.091797 ntask sched 9.000000
10 21508.093750 S 680 Fi
10 21508.095703 S 680 B
10 21508.097657 S 680 chol_model_22
10 21511.339844 S 65 B
10 21511.341797 S 680 Po
10 21511.343750 S 680 B
13 21511.351563 ntask sched 8.000000
10 21511.351563 S 680 Fi
10 21511.353516 S 680 B
10 21511.353516 S 680 chol_model_22
10 21514.677735 S 65 B
10 21514.677735 S 680 Po
10 21514.679688 S 680 B
13 21514.687500 ntask sched 7.000000
10 21514.687500 S 680 Fi
10 21514.689453 S 680 B
10 21514.689453 S 680 chol_model_22
10 21517.927735 S 65 B
10 21517.931641 S 680 Po
10 21517.931641 S 680 B
13 21517.939453 ntask sched 6.000000
10 21517.941407 S 680 Fi
10 21517.941407 S 680 B
10 21517.943360 S 680 chol_model_22
10 21521.160157 S 65 B
10 21521.162110 S 680 Po
10 21521.164063 S 680 B
13 21521.171875 ntask sched 5.000000
10 21521.173828 S 680 Fi
10 21521.175781 S 680 B
10 21521.175781 S 680 chol_model_22
10 21524.398438 S 65 B
10 21524.398438 S 680 Po
10 21524.400391 S 680 B
13 21524.408203 ntask sched 4.000000
10 21524.410157 S 680 Fi
10 21524.410157 S 680 B
10 21524.410157 S 680 chol_model_22
10 21527.626953 S 65 B
10 21527.626953 S 680 Po
10 21527.628907 S 680 B
13 21527.636719 ntask sched 3.000000
10 21527.638672 S 680 Fi
10 21527.638672 S 680 B
10 21527.640625 S 680 chol_model_22
10 21530.861328 S 65 B
10 21530.861328 S 680 Po
10 21530.863281 S 680 B
13 21530.869141 ntask sched 2.000000
10 21530.871094 S 680 Fi
10 21530.873047 S 680 B
10 21530.873047 S 680 chol_model_22
10 21534.160157 S 65 B
10 21534.160157 S 680 Po
10 21534.162110 S 680 B
13 21534.169922 ntask sched 1.000000
10 21534.171875 S 680 Fi
10 21534.173828 S 680 B
10 21534.175781 S 680 chol_model_21
10 21542.425781 S 65 B
10 21542.425781 S 680 Po
10 21542.427735 S 680 B
13 21542.470703 ntask sched 2.000000
13 21542.500000 ntask sched 3.000000
13 21542.529297 ntask sched 4.000000
13 21542.560547 ntask sched 5.000000
13 21542.589844 ntask sched 6.000000
13 21542.619141 ntask sched 7.000000
13 21542.650391 ntask sched 8.000000
13 21542.681641 ntask sched 9.000000
13 21542.712891 ntask sched 10.000000
13 21542.742188 ntask sched 11.000000
13 21542.773438 ntask sched 12.000000
13 21542.777344 ntask sched 11.000000
10 21542.779297 S 680 Fi
10 21542.781250 S 680 B
10 21542.781250 S 680 chol_model_22
10 21546.097657 S 65 B
10 21546.097657 S 680 Po
10 21546.099610 S 680 B
13 21546.107422 ntask sched 10.000000
10 21546.109375 S 680 Fi
10 21546.111328 S 680 B
10 21546.111328 S 680 chol_model_22
10 21549.332031 S 65 B
10 21549.332031 S 680 Po
10 21549.335938 S 680 B
13 21549.345703 ntask sched 9.000000
10 21549.345703 S 680 Fi
10 21549.347657 S 680 B
10 21549.349610 S 680 chol_model_22
10 21552.644531 S 65 B
10 21552.644531 S 680 Po
10 21552.646485 S 680 B
13 21552.654297 ntask sched 8.000000
10 21552.656250 S 680 Fi
10 21552.658203 S 680 B
10 21552.658203 S 680 chol_model_22
10 21555.888672 S 65 B
10 21555.890625 S 680 Po
10 21555.890625 S 680 B
13 21555.898438 ntask sched 7.000000
10 21555.900391 S 680 Fi
10 21555.902344 S 680 B
10 21555.902344 S 680 chol_model_22
10 21559.175781 S 65 B
10 21559.175781 S 680 Po
10 21559.177735 S 680 B
13 21559.185547 ntask sched 6.000000
10 21559.185547 S 680 Fi
10 21559.187500 S 680 B
10 21559.189453 S 680 chol_model_22
10 21562.511719 S 65 B
10 21562.513672 S 680 Po
10 21562.515625 S 680 B
13 21562.521485 ntask sched 5.000000
10 21562.523438 S 680 Fi
10 21562.525391 S 680 B
10 21562.525391 S 680 chol_model_22
10 21565.820313 S 65 B
10 21565.820313 S 680 Po
10 21565.822266 S 680 B
13 21565.830078 ntask sched 4.000000
10 21565.832031 S 680 Fi
10 21565.832031 S 680 B
10 21565.833985 S 680 chol_model_22
10 21569.169922 S 65 B
10 21569.171875 S 680 Po
10 21569.173828 S 680 B
13 21569.179688 ntask sched 3.000000
10 21569.181641 S 680 Fi
10 21569.183594 S 680 B
10 21569.183594 S 680 chol_model_22
10 21572.404297 S 65 B
10 21572.404297 S 680 Po
10 21572.406250 S 680 B
13 21572.414063 ntask sched 2.000000
10 21572.416016 S 680 Fi
10 21572.417969 S 680 B
10 21572.419922 S 680 chol_model_22
10 21575.714844 S 65 B
10 21575.714844 S 680 Po
10 21575.716797 S 680 B
13 21575.724610 ntask sched 1.000000
10 21575.726563 S 680 Fi
10 21575.726563 S 680 B
10 21575.728516 S 680 chol_model_22
10 21578.957031 S 65 B
10 21578.957031 S 680 Po
10 21578.960938 S 680 B
13 21578.968750 ntask sched 0.000000
10 21578.970703 S 680 Fi
10 21578.970703 S 680 B
10 21578.974610 S 680 chol_model_21
10 21587.207031 S 65 B
10 21587.208985 S 680 Po
10 21587.210938 S 680 B
13 21587.246094 ntask sched 1.000000
13 21587.277344 ntask sched 2.000000
13 21587.306641 ntask sched 3.000000
13 21587.335938 ntask sched 4.000000
13 21587.365235 ntask sched 5.000000
13 21587.396485 ntask sched 6.000000
13 21587.427735 ntask sched 7.000000
13 21587.462891 ntask sched 8.000000
13 21587.494141 ntask sched 9.000000
13 21587.525391 ntask sched 10.000000
13 21587.554688 ntask sched 11.000000
13 21587.585938 ntask sched 12.000000
13 21587.591797 ntask sched 11.000000
10 21587.591797 S 680 Fi
10 21587.593750 S 680 B
10 21587.593750 S 680 chol_model_22
10 21590.861328 S 65 B
10 21590.863281 S 680 Po
10 21590.865235 S 680 B
13 21590.873047 ntask sched 10.000000
10 21590.873047 S 680 Fi
10 21590.875000 S 680 B
10 21590.875000 S 680 chol_model_22
10 21594.171875 S 65 B
10 21594.171875 S 680 Po
10 21594.173828 S 680 B
13 21594.183594 ntask sched 9.000000
10 21594.183594 S 680 Fi
10 21594.185547 S 680 B
10 21594.185547 S 680 chol_model_22
10 21597.408203 S 65 B
10 21597.408203 S 680 Po
10 21597.410157 S 680 B
13 21597.417969 ntask sched 8.000000
10 21597.419922 S 680 Fi
10 21597.421875 S 680 B
10 21597.421875 S 680 chol_model_22
10 21600.744141 S 65 B
10 21600.744141 S 680 Po
10 21600.746094 S 680 B
13 21600.755860 ntask sched 7.000000
10 21600.757813 S 680 Fi
10 21600.757813 S 680 B
10 21600.759766 S 680 chol_model_22
10 21604.003907 S 65 B
10 21604.005860 S 680 Po
10 21604.005860 S 680 B
13 21604.013672 ntask sched 6.000000
10 21604.013672 S 680 Fi
10 21604.015625 S 680 B
10 21604.017578 S 680 chol_model_22
10 21607.234375 S 65 B
10 21607.234375 S 680 Po
10 21607.236328 S 680 B
13 21607.244141 ntask sched 5.000000
10 21607.246094 S 680 Fi
10 21607.248047 S 680 B
10 21607.248047 S 680 chol_model_22
10 21610.572266 S 65 B
10 21610.574219 S 680 Po
10 21610.574219 S 680 B
13 21610.583985 ntask sched 4.000000
10 21610.585938 S 680 Fi
10 21610.587891 S 680 B
10 21610.587891 S 680 chol_model_22
10 21613.863281 S 65 B
10 21613.865235 S 680 Po
10 21613.867188 S 680 B
13 21613.875000 ntask sched 3.000000
10 21613.876953 S 680 Fi
10 21613.878907 S 680 B
10 21613.878907 S 680 chol_model_22
10 21617.181641 S 65 B
10 21617.181641 S 680 Po
10 21617.183594 S 680 B
13 21617.189453 ntask sched 2.000000
10 21617.191407 S 680 Fi
10 21617.193360 S 680 B
10 21617.193360 S 680 chol_model_22
10 21620.441407 S 65 B
10 21620.443360 S 680 Po
10 21620.445313 S 680 B
13 21620.453125 ntask sched 1.000000
10 21620.453125 S 680 Fi
10 21620.455078 S 680 B
10 21620.455078 S 680 chol_model_22
10 21623.681641 S 65 B
10 21623.681641 S 680 Po
10 21623.683594 S 680 B
13 21623.691407 ntask sched 0.000000
10 21623.691407 S 680 Fi
10 21623.693360 S 680 B
10 21623.693360 S 680 chol_model_22
10 21626.978516 S 65 B
10 21626.978516 S 680 Po
10 21626.980469 S 680 B
13 21627.015625 ntask sched 1.000000
13 21627.021485 ntask sched 0.000000
10 21627.021485 S 680 Fi
10 21627.023438 S 680 B
10 21627.025391 S 680 chol_model_11
10 21711.773438 S 65 B
10 21711.775391 S 680 Po
10 21711.775391 S 680 B
13 21711.812500 ntask sched 1.000000
13 21711.843750 ntask sched 2.000000
13 21711.875000 ntask sched 3.000000
13 21711.886719 ntask sched 2.000000
10 21711.888672 S 679 Fi
13 21711.908203 ntask sched 3.000000
13 21711.939453 ntask sched 4.000000
13 21711.966797 ntask sched 5.000000
13 21711.994141 ntask sched 6.000000
13 21712.021485 ntask sched 7.000000
13 21712.048828 ntask sched 8.000000
13 21712.074219 ntask sched 9.000000
13 21712.101563 ntask sched 10.000000
10 21712.107422 MS MEMNODE0 Co
18 21712.107422 L p 4000000 MEMNODE2 com_215
10 21712.115235 MS MEMNODE0 CoA
10 21714.152344 MS MEMNODE0 No
19 21714.152344 L p 2273874960 MEMNODE0 com_2273874768
10 21714.160157 MS MEMNODE0 Co
18 21714.160157 L p 4000000 MEMNODE2 com_216
10 21714.166016 MS MEMNODE0 CoA
10 21716.179688 MS MEMNODE0 No
19 21716.179688 L p 2273874960 MEMNODE0 com_2273874768
10 21716.183594 MS MEMNODE0 Co
18 21716.183594 L p 4000000 MEMNODE2 com_217
10 21716.191407 MS MEMNODE0 CoA
10 21718.205078 MS MEMNODE0 No
19 21718.205078 L p 2273874960 MEMNODE0 com_2273874768
10 21718.218750 MS MEMNODE0 Co
18 21718.218750 L p 4000000 MEMNODE2 com_218
10 21718.228516 MS MEMNODE0 CoA
10 21731.148438 MS MEMNODE0 No
19 21731.148438 L p 2273874960 MEMNODE0 com_2273874768
10 21731.154297 MS MEMNODE0 Co
18 21731.154297 L p 4000000 MEMNODE2 com_219
10 21731.160157 MS MEMNODE0 CoA
10 21733.177735 MS MEMNODE0 No
19 21733.177735 L p 2273874960 MEMNODE0 com_2273874768
10 21733.183594 MS MEMNODE0 Co
18 21733.183594 L p 4000000 MEMNODE2 com_220
10 21733.191407 MS MEMNODE0 CoA
10 21735.207031 MS MEMNODE0 No
19 21735.207031 L p 2273874960 MEMNODE0 com_2273874768
13 21735.216797 ntask sched 9.000000
10 21735.216797 S 680 Fi
10 21735.218750 S 680 B
10 21735.250000 S 680 chol_model_21
10 21743.509766 S 65 B
10 21743.509766 S 680 Po
10 21743.511719 S 680 B
13 21743.548828 ntask sched 10.000000
10 21743.556641 MS MEMNODE0 No
19 21743.556641 L p 4000000 MEMNODE0 com_220
10 21743.558594 MS MEMNODE0 No
19 21743.558594 L p 4000000 MEMNODE0 com_219
10 21743.558594 MS MEMNODE1 A
10 21743.560547 MS MEMNODE0 No
19 21743.560547 L p 4000000 MEMNODE0 com_218
10 21743.564453 MS MEMNODE0 No
19 21743.564453 L p 4000000 MEMNODE0 com_217
10 21743.566407 MS MEMNODE0 No
19 21743.566407 L p 4000000 MEMNODE0 com_216
10 21743.568360 MS MEMNODE0 No
19 21743.568360 L p 4000000 MEMNODE0 com_215
13 21743.570313 ntask sched 9.000000
10 21743.572266 S 680 Fi
10 21743.572266 S 680 B
10 21743.574219 S 680 chol_model_22
10 21743.685547 MS MEMNODE1 No
10 21743.687500 MS MEMNODE1 Co
18 21743.687500 L p 4000000 MEMNODE0 com_221
10 21743.693360 MS MEMNODE1 CoA
10 21744.818360 MS MEMNODE1 No
19 21744.818360 L p 2273874960 MEMNODE1 com_2273874768
10 21744.826172 MS MEMNODE1 A
10 21744.945313 MS MEMNODE1 No
10 21744.947266 MS MEMNODE1 Co
18 21744.947266 L p 4000000 MEMNODE0 com_222
10 21744.951172 MS MEMNODE1 CoA
10 21746.099610 MS MEMNODE1 No
19 21746.099610 L p 2273874960 MEMNODE1 com_2273874768
10 21746.105469 MS MEMNODE1 A
10 21746.228516 MS MEMNODE1 No
10 21746.230469 MS MEMNODE1 Co
18 21746.230469 L p 4000000 MEMNODE0 com_223
10 21746.234375 MS MEMNODE1 CoA
10 21746.882813 S 65 B
10 21746.884766 S 680 Po
10 21746.886719 S 680 B
13 21746.892578 ntask sched 8.000000
10 21746.894531 S 680 Fi
10 21746.896485 S 680 B
10 21746.898438 S 680 chol_model_21
10 21747.386719 MS MEMNODE1 No
19 21747.386719 L p 2273874960 MEMNODE1 com_2273874768
10 21747.390625 MS MEMNODE1 A
10 21747.515625 MS MEMNODE1 No
10 21747.517578 MS MEMNODE1 Co
18 21747.517578 L p 4000000 MEMNODE0 com_224
10 21747.523438 MS MEMNODE1 CoA
10 21748.681641 MS MEMNODE1 No
19 21748.681641 L p 2273874960 MEMNODE1 com_2273874768
10 21748.685547 MS MEMNODE1 A
10 21748.804688 MS MEMNODE1 No
10 21748.806641 MS MEMNODE1 Co
18 21748.806641 L p 4000000 MEMNODE0 com_225
10 21748.812500 MS MEMNODE1 CoA
10 21749.970703 MS MEMNODE1 No
19 21749.970703 L p 2273874960 MEMNODE1 com_2273874768
10 21749.974610 MS MEMNODE1 A
10 21750.095703 MS MEMNODE1 No
10 21750.097657 MS MEMNODE1 Co
18 21750.097657 L p 4000000 MEMNODE0 com_226
10 21750.107422 MS MEMNODE1 CoA
10 21751.261719 MS MEMNODE1 No
19 21751.261719 L p 2273874960 MEMNODE1 com_2273874768
10 21751.300781 MS MEMNODE1 No
19 21751.300781 L p 4000000 MEMNODE1 com_225
10 21751.326172 MS MEMNODE1 No
19 21751.326172 L p 4000000 MEMNODE1 com_224
10 21751.351563 MS MEMNODE1 No
19 21751.351563 L p 4000000 MEMNODE1 com_223
10 21751.375000 MS MEMNODE1 No
19 21751.375000 L p 4000000 MEMNODE1 com_222
10 21751.398438 MS MEMNODE1 No
19 21751.398438 L p 4000000 MEMNODE1 com_221
10 21751.457031 MS MEMNODE1 No
19 21751.457031 L p 4000000 MEMNODE1 com_226
10 21751.458985 S 679 B
10 21751.464844 S 679 chol_model_21
10 21755.169922 S 65 B
10 21755.171875 S 680 Po
10 21755.171875 S 680 B
13 21755.208985 ntask sched 9.000000
13 21755.238281 ntask sched 10.000000
13 21755.242188 ntask sched 9.000000
10 21755.244141 S 680 Fi
10 21755.246094 S 680 B
10 21755.246094 S 680 chol_model_22
10 21758.492188 S 65 B
10 21758.494141 S 680 Po
10 21758.496094 S 680 B
13 21758.501953 ntask sched 8.000000
10 21758.503907 S 680 Fi
10 21758.505860 S 680 B
10 21758.505860 S 680 chol_model_22
10 21759.794922 S 64 B
10 21759.798828 S 679 Po
10 21759.800781 S 679 B
13 21759.843750 ntask sched 9.000000
13 21759.873047 ntask sched 10.000000
13 21759.902344 ntask sched 11.000000
10 21759.908203 MS MEMNODE0 Co
18 21759.908203 L p 4000000 MEMNODE1 com_227
10 21759.921875 MS MEMNODE0 CoA
10 21761.513672 MS MEMNODE0 No
19 21761.513672 L p 2273874960 MEMNODE0 com_2273874768
13 21761.521485 ntask sched 10.000000
10 21761.523438 S 679 Fi
10 21761.525391 S 679 B
10 21761.556641 S 679 chol_model_21
10 21761.794922 S 65 B
10 21761.796875 S 680 Po
10 21761.798828 S 680 B
13 21761.804688 ntask sched 9.000000
10 21761.806641 S 680 Fi
10 21769.863281 S 64 B
10 21769.865235 S 679 Po
10 21769.867188 S 679 B
13 21769.904297 ntask sched 10.000000
13 21769.935547 ntask sched 11.000000
13 21769.962891 ntask sched 12.000000
13 21769.990235 ntask sched 13.000000
10 21770.000000 MS MEMNODE0 No
19 21770.000000 L p 4000000 MEMNODE0 com_227
10 21770.001953 MS MEMNODE0 Co
18 21770.001953 L p 4000000 MEMNODE1 com_229
10 21770.001953 MS MEMNODE2 Co
18 21770.001953 L p 4000000 MEMNODE0 com_228
10 21770.007813 MS MEMNODE0 CoA
10 21770.011719 MS MEMNODE2 CoA
10 21771.304688 MS MEMNODE2 No
19 21771.304688 L p 2273874960 MEMNODE2 com_2273874768
10 21771.435547 MS MEMNODE0 No
19 21771.435547 L p 2273874968 MEMNODE0 com_2273874768
13 21771.445313 ntask sched 12.000000
10 21771.447266 S 679 Fi
10 21771.449219 S 679 B
10 21771.486328 S 679 chol_model_21
10 21771.515625 MS MEMNODE2 No
19 21771.515625 L p 4000000 MEMNODE2 com_228
10 21771.519531 S 680 B
10 21771.521485 S 680 chol_model_22
10 21774.746094 S 65 B
10 21774.746094 S 680 Po
10 21774.748047 S 680 B
13 21774.757813 ntask sched 11.000000
10 21774.759766 S 680 Fi
10 21779.791016 S 64 B
10 21779.792969 S 679 Po
10 21779.794922 S 679 B
13 21779.828125 ntask sched 12.000000
13 21779.857422 ntask sched 13.000000
13 21779.884766 ntask sched 14.000000
13 21779.912110 ntask sched 15.000000
13 21779.941407 ntask sched 16.000000
10 21779.949219 MS MEMNODE0 No
19 21779.949219 L p 4000000 MEMNODE0 com_229
10 21779.951172 MS MEMNODE2 Co
18 21779.951172 L p 4000000 MEMNODE0 com_230
10 21779.951172 MS MEMNODE0 Co
18 21779.951172 L p 4000000 MEMNODE1 com_231
10 21779.957031 MS MEMNODE0 CoA
10 21779.960938 MS MEMNODE2 CoA
10 21781.244141 MS MEMNODE2 No
19 21781.244141 L p 2273874960 MEMNODE2 com_2273874768
10 21781.410157 MS MEMNODE0 No
19 21781.410157 L p 2273874968 MEMNODE0 com_2273874768
13 21781.419922 ntask sched 15.000000
10 21781.419922 S 679 Fi
10 21781.421875 S 679 B
10 21781.449219 MS MEMNODE2 No
19 21781.449219 L p 4000000 MEMNODE2 com_230
10 21781.451172 S 680 B
10 21781.453125 S 680 chol_model_22
10 21781.476563 S 679 chol_model_21
10 21784.660157 S 65 B
10 21784.660157 S 680 Po
10 21784.662110 S 680 B
13 21784.669922 ntask sched 14.000000
10 21784.671875 S 680 Fi
10 21789.796875 S 64 B
10 21789.798828 S 679 Po
10 21789.800781 S 679 B
13 21789.835938 ntask sched 15.000000
13 21789.863281 ntask sched 16.000000
13 21789.890625 ntask sched 17.000000
13 21789.919922 ntask sched 18.000000
13 21789.945313 ntask sched 19.000000
13 21789.974610 ntask sched 20.000000
10 21789.982422 MS MEMNODE0 No
19 21789.982422 L p 4000000 MEMNODE0 com_231
10 21789.984375 MS MEMNODE2 Co
18 21789.984375 L p 4000000 MEMNODE0 com_232
10 21789.984375 MS MEMNODE0 Co
18 21789.984375 L p 4000000 MEMNODE1 com_233
10 21789.990235 MS MEMNODE0 CoA
10 21789.992188 MS MEMNODE2 CoA
10 21791.275391 MS MEMNODE2 No
19 21791.275391 L p 2273874960 MEMNODE2 com_2273874768
10 21791.474610 MS MEMNODE2 No
19 21791.474610 L p 4000000 MEMNODE2 com_232
10 21791.476563 S 680 B
10 21791.478516 S 680 chol_model_22
10 21791.496094 MS MEMNODE0 No
19 21791.496094 L p 2273874960 MEMNODE0 com_2273874768
13 21791.503907 ntask sched 19.000000
10 21791.505860 S 679 Fi
10 21791.507813 S 679 B
10 21791.537110 S 679 chol_model_21
10 21794.794922 S 65 B
10 21794.794922 S 680 Po
10 21794.796875 S 680 B
13 21794.804688 ntask sched 18.000000
10 21794.806641 S 680 Fi
10 21799.845703 S 64 B
10 21799.847657 S 679 Po
10 21799.849610 S 679 B
13 21799.884766 ntask sched 19.000000
13 21799.910157 ntask sched 20.000000
13 21799.939453 ntask sched 21.000000
13 21799.968750 ntask sched 22.000000
13 21799.994141 ntask sched 23.000000
13 21800.023438 ntask sched 24.000000
13 21800.050781 ntask sched 25.000000
10 21800.058594 MS MEMNODE0 No
19 21800.058594 L p 4000000 MEMNODE0 com_233
10 21800.060547 MS MEMNODE0 Co
18 21800.060547 L p 4000000 MEMNODE1 com_234
10 21800.060547 MS MEMNODE2 Co
18 21800.060547 L p 4000000 MEMNODE0 com_235
10 21800.066407 MS MEMNODE0 CoA
10 21800.068360 MS MEMNODE2 CoA
10 21801.355469 MS MEMNODE2 No
19 21801.355469 L p 2273874960 MEMNODE2 com_2273874768
10 21801.554688 MS MEMNODE2 No
19 21801.554688 L p 4000000 MEMNODE2 com_235
10 21801.556641 S 680 B
10 21801.558594 S 680 chol_model_22
10 21801.648438 MS MEMNODE0 No
19 21801.648438 L p 2273874960 MEMNODE0 com_2273874768
10 21801.691407 MS MEMNODE0 No
19 21801.691407 L p 4000000 MEMNODE0 com_234
10 21804.798828 S 65 B
10 21804.798828 S 680 Po
10 21804.800781 S 680 B
10 21804.808594 MS MEMNODE2 Co
18 21804.808594 L p 4000000 MEMNODE0 com_236
10 21804.816407 MS MEMNODE2 CoA
10 21806.058594 MS MEMNODE2 No
19 21806.058594 L p 2273874960 MEMNODE2 com_2273874768
13 21806.064453 ntask sched 24.000000
10 21806.066407 S 680 Fi
10 21806.255860 MS MEMNODE2 No
19 21806.255860 L p 4000000 MEMNODE2 com_236
10 21806.257813 S 680 B
10 21806.259766 S 680 chol_model_22
10 21809.535157 S 65 B
10 21809.537110 S 680 Po
10 21809.539063 S 680 B
13 21809.546875 ntask sched 23.000000
10 21809.548828 S 680 Fi
10 21809.550781 S 680 B
10 21809.550781 S 680 chol_model_22
10 21812.759766 S 65 B
10 21812.761719 S 680 Po
10 21812.763672 S 680 B
13 21812.771485 ntask sched 22.000000
10 21812.773438 S 680 Fi
10 21812.775391 S 680 B
10 21812.775391 S 680 chol_model_22
10 21816.093750 S 65 B
10 21816.093750 S 680 Po
10 21816.095703 S 680 B
13 21816.105469 ntask sched 21.000000
10 21816.105469 S 680 Fi
10 21816.107422 S 680 B
10 21816.109375 S 680 chol_model_22
10 21819.330078 S 65 B
10 21819.332031 S 680 Po
10 21819.333985 S 680 B
13 21819.341797 ntask sched 20.000000
10 21819.343750 S 680 Fi
10 21819.343750 S 680 B
10 21819.345703 S 680 chol_model_22
10 21822.630860 S 65 B
10 21822.632813 S 680 Po
10 21822.634766 S 680 B
13 21822.642578 ntask sched 19.000000
10 21822.644531 S 680 Fi
10 21822.646485 S 680 B
10 21822.646485 S 680 chol_model_22
10 21825.855469 S 65 B
10 21825.855469 S 680 Po
10 21825.857422 S 680 B
13 21825.865235 ntask sched 18.000000
10 21825.865235 S 680 Fi
10 21825.867188 S 680 B
10 21825.869141 S 680 chol_model_22
10 21829.113281 S 65 B
10 21829.115235 S 680 Po
10 21829.117188 S 680 B
13 21829.125000 ntask sched 17.000000
10 21829.126953 S 680 Fi
10 21829.128907 S 680 B
10 21829.128907 S 680 chol_model_22
10 21832.425781 S 65 B
10 21832.425781 S 680 Po
10 21832.427735 S 680 B
13 21832.443360 ntask sched 16.000000
10 21832.445313 S 680 Fi
10 21832.447266 S 680 B
10 21832.447266 S 680 chol_model_22
10 21835.740235 S 65 B
10 21835.742188 S 680 Po
10 21835.744141 S 680 B
13 21835.753907 ntask sched 15.000000
10 21835.753907 S 680 Fi
10 21835.755860 S 680 B
10 21835.757813 S 680 chol_model_22
10 21838.990235 S 65 B
10 21838.990235 S 680 Po
10 21838.992188 S 680 B
13 21839.000000 ntask sched 14.000000
10 21839.001953 S 680 Fi
10 21839.003907 S 680 B
10 21839.003907 S 680 chol_model_22
10 21842.236328 S 65 B
10 21842.238281 S 680 Po
10 21842.240235 S 680 B
13 21842.248047 ntask sched 13.000000
10 21842.250000 S 680 Fi
10 21842.251953 S 680 B
10 21842.253907 S 680 chol_model_22
10 21845.564453 S 65 B
10 21845.564453 S 680 Po
10 21845.566407 S 680 B
13 21845.574219 ntask sched 12.000000
10 21845.576172 S 680 Fi
10 21845.578125 S 680 B
10 21845.578125 S 680 chol_model_22
10 21848.867188 S 65 B
10 21848.867188 S 680 Po
10 21848.869141 S 680 B
13 21848.878907 ntask sched 11.000000
10 21848.878907 S 680 Fi
10 21848.880860 S 680 B
10 21848.882813 S 680 chol_model_22
10 21852.132813 S 65 B
10 21852.132813 S 680 Po
10 21852.134766 S 680 B
13 21852.142578 ntask sched 10.000000
10 21852.144531 S 680 Fi
10 21852.146485 S 680 B
10 21852.146485 S 680 chol_model_22
10 21855.328125 S 65 B
10 21855.330078 S 680 Po
10 21855.332031 S 680 B
13 21855.339844 ntask sched 9.000000
10 21855.341797 S 680 Fi
10 21855.343750 S 680 B
10 21855.343750 S 680 chol_model_22
10 21858.632813 S 65 B
10 21858.632813 S 680 Po
10 21858.634766 S 680 B
13 21858.642578 ntask sched 8.000000
10 21858.642578 S 680 Fi
10 21858.644531 S 680 B
10 21858.646485 S 680 chol_model_22
10 21861.878907 S 65 B
10 21861.878907 S 680 Po
10 21861.880860 S 680 B
13 21861.888672 ntask sched 7.000000
10 21861.888672 S 680 Fi
10 21861.890625 S 680 B
10 21861.892578 S 680 chol_model_22
10 21865.109375 S 65 B
10 21865.111328 S 680 Po
10 21865.113281 S 680 B
13 21865.119141 ntask sched 6.000000
10 21865.121094 S 680 Fi
10 21865.123047 S 680 B
10 21865.125000 S 680 chol_model_22
10 21868.363281 S 65 B
10 21868.365235 S 680 Po
10 21868.367188 S 680 B
13 21868.373047 ntask sched 5.000000
10 21868.375000 S 680 Fi
10 21868.378907 S 680 B
10 21868.378907 S 680 chol_model_22
10 21871.685547 S 65 B
10 21871.685547 S 680 Po
10 21871.687500 S 680 B
13 21871.697266 ntask sched 4.000000
10 21871.697266 S 680 Fi
10 21871.699219 S 680 B
10 21871.701172 S 680 chol_model_22
10 21874.929688 S 65 B
10 21874.931641 S 680 Po
10 21874.933594 S 680 B
13 21874.941407 ntask sched 3.000000
10 21874.943360 S 680 Fi
10 21874.945313 S 680 B
10 21874.947266 S 680 chol_model_21
10 21883.169922 S 65 B
10 21883.171875 S 680 Po
10 21883.173828 S 680 B
13 21883.214844 ntask sched 4.000000
13 21883.242188 ntask sched 5.000000
13 21883.273438 ntask sched 6.000000
13 21883.304688 ntask sched 7.000000
13 21883.333985 ntask sched 8.000000
13 21883.363281 ntask sched 9.000000
13 21883.394531 ntask sched 10.000000
13 21883.425781 ntask sched 11.000000
13 21883.429688 ntask sched 10.000000
10 21883.437500 S 680 Fi
10 21883.437500 S 680 B
10 21883.439453 S 680 chol_model_22
10 21886.753907 S 65 B
10 21886.753907 S 680 Po
10 21886.755860 S 680 B
13 21886.763672 ntask sched 9.000000
10 21886.763672 S 680 Fi
10 21886.765625 S 680 B
10 21886.765625 S 680 chol_model_22
10 21890.052735 S 65 B
10 21890.054688 S 680 Po
10 21890.054688 S 680 B
13 21890.062500 ntask sched 8.000000
10 21890.064453 S 680 Fi
10 21890.064453 S 680 B
10 21890.066407 S 680 chol_model_22
10 21893.380860 S 65 B
10 21893.382813 S 680 Po
10 21893.382813 S 680 B
13 21893.390625 ntask sched 7.000000
10 21893.392578 S 680 Fi
10 21893.392578 S 680 B
10 21893.394531 S 680 chol_model_22
10 21896.687500 S 65 B
10 21896.689453 S 680 Po
10 21896.691407 S 680 B
13 21896.697266 ntask sched 6.000000
10 21896.699219 S 680 Fi
10 21896.701172 S 680 B
10 21896.701172 S 680 chol_model_22
10 21899.998047 S 65 B
10 21900.000000 S 680 Po
10 21900.001953 S 680 B
13 21900.009766 ntask sched 5.000000
10 21900.011719 S 680 Fi
10 21900.011719 S 680 B
10 21900.013672 S 680 chol_model_22
10 21903.332031 S 65 B
10 21903.332031 S 680 Po
10 21903.333985 S 680 B
13 21903.341797 ntask sched 4.000000
10 21903.341797 S 680 Fi
10 21903.343750 S 680 B
10 21903.345703 S 680 chol_model_22
10 21906.587891 S 65 B
10 21906.589844 S 680 Po
10 21906.589844 S 680 B
13 21906.597657 ntask sched 3.000000
10 21906.599610 S 680 Fi
10 21906.601563 S 680 B
10 21906.601563 S 680 chol_model_22
10 21909.824219 S 65 B
10 21909.824219 S 680 Po
10 21909.826172 S 680 B
13 21909.833985 ntask sched 2.000000
10 21909.835938 S 680 Fi
10 21909.837891 S 680 B
10 21909.839844 S 680 chol_model_21
10 21918.052735 S 65 B
10 21918.052735 S 680 Po
10 21918.054688 S 680 B
13 21918.089844 ntask sched 3.000000
13 21918.119141 ntask sched 4.000000
13 21918.150391 ntask sched 5.000000
13 21918.179688 ntask sched 6.000000
13 21918.207031 ntask sched 7.000000
13 21918.238281 ntask sched 8.000000
13 21918.267578 ntask sched 9.000000
13 21918.298828 ntask sched 10.000000
13 21918.328125 ntask sched 11.000000
13 21918.333985 ntask sched 10.000000
10 21918.335938 S 680 Fi
10 21918.335938 S 680 B
10 21918.337891 S 680 chol_model_22
10 21921.634766 S 65 B
10 21921.636719 S 680 Po
10 21921.638672 S 680 B
13 21921.646485 ntask sched 9.000000
10 21921.648438 S 680 Fi
10 21921.648438 S 680 B
10 21921.650391 S 680 chol_model_22
10 21924.933594 S 65 B
10 21924.935547 S 680 Po
10 21924.935547 S 680 B
13 21924.943360 ntask sched 8.000000
10 21924.945313 S 680 Fi
10 21924.947266 S 680 B
10 21924.947266 S 680 chol_model_22
10 21928.240235 S 65 B
10 21928.242188 S 680 Po
10 21928.244141 S 680 B
13 21928.251953 ntask sched 7.000000
10 21928.253907 S 680 Fi
10 21928.255860 S 680 B
10 21928.255860 S 680 chol_model_22
10 21931.554688 S 65 B
10 21931.556641 S 680 Po
10 21931.558594 S 680 B
13 21931.564453 ntask sched 6.000000
10 21931.566407 S 680 Fi
10 21931.568360 S 680 B
10 21931.568360 S 680 chol_model_22
10 21934.857422 S 65 B
10 21934.859375 S 680 Po
10 21934.859375 S 680 B
13 21934.867188 ntask sched 5.000000
10 21934.869141 S 680 Fi
10 21934.871094 S 680 B
10 21934.871094 S 680 chol_model_22
10 21938.169922 S 65 B
10 21938.171875 S 680 Po
10 21938.173828 S 680 B
13 21938.179688 ntask sched 4.000000
10 21938.181641 S 680 Fi
10 21938.183594 S 680 B
10 21938.183594 S 680 chol_model_22
10 21941.412110 S 65 B
10 21941.414063 S 680 Po
10 21941.414063 S 680 B
13 21941.423828 ntask sched 3.000000
10 21941.425781 S 680 Fi
10 21941.425781 S 680 B
10 21941.427735 S 680 chol_model_22
10 21944.738281 S 65 B
10 21944.738281 S 680 Po
10 21944.740235 S 680 B
13 21944.748047 ntask sched 2.000000
10 21944.750000 S 680 Fi
10 21944.750000 S 680 B
10 21944.751953 S 680 chol_model_22
10 21948.048828 S 65 B
10 21948.050781 S 680 Po
10 21948.052735 S 680 B
13 21948.058594 ntask sched 1.000000
10 21948.060547 S 680 Fi
10 21948.062500 S 680 B
10 21948.064453 S 680 chol_model_21
10 21956.281250 S 65 B
10 21956.283203 S 680 Po
10 21956.283203 S 680 B
13 21956.320313 ntask sched 2.000000
13 21956.349610 ntask sched 3.000000
13 21956.380860 ntask sched 4.000000
13 21956.410157 ntask sched 5.000000
13 21956.445313 ntask sched 6.000000
13 21956.476563 ntask sched 7.000000
13 21956.507813 ntask sched 8.000000
13 21956.537110 ntask sched 9.000000
13 21956.568360 ntask sched 10.000000
13 21956.597657 ntask sched 11.000000
13 21956.603516 ntask sched 10.000000
10 21956.605469 S 680 Fi
10 21956.605469 S 680 B
10 21956.607422 S 680 chol_model_22
10 21959.929688 S 65 B
10 21959.931641 S 680 Po
10 21959.933594 S 680 B
13 21959.939453 ntask sched 9.000000
10 21959.941407 S 680 Fi
10 21959.941407 S 680 B
10 21959.943360 S 680 chol_model_22
10 21963.242188 S 65 B
10 21963.242188 S 680 Po
10 21963.244141 S 680 B
13 21963.251953 ntask sched 8.000000
10 21963.253907 S 680 Fi
10 21963.255860 S 680 B
10 21963.255860 S 680 chol_model_22
10 21966.486328 S 65 B
10 21966.488281 S 680 Po
10 21966.490235 S 680 B
13 21966.496094 ntask sched 7.000000
10 21966.498047 S 680 Fi
10 21966.500000 S 680 B
10 21966.500000 S 680 chol_model_22
10 21969.792969 S 65 B
10 21969.794922 S 680 Po
10 21969.796875 S 680 B
13 21969.804688 ntask sched 6.000000
10 21969.804688 S 680 Fi
10 21969.806641 S 680 B
10 21969.806641 S 680 chol_model_22
10 21973.107422 S 65 B
10 21973.107422 S 680 Po
10 21973.109375 S 680 B
13 21973.119141 ntask sched 5.000000
10 21973.119141 S 680 Fi
10 21973.121094 S 680 B
10 21973.121094 S 680 chol_model_22
10 21976.353516 S 65 B
10 21976.353516 S 680 Po
10 21976.355469 S 680 B
13 21976.361328 ntask sched 4.000000
10 21976.363281 S 680 Fi
10 21976.365235 S 680 B
10 21976.365235 S 680 chol_model_22
10 21979.654297 S 65 B
10 21979.656250 S 680 Po
10 21979.658203 S 680 B
13 21979.666016 ntask sched 3.000000
10 21979.669922 S 680 Fi
10 21979.669922 S 680 B
10 21979.671875 S 680 chol_model_22
10 21982.974610 S 65 B
10 21982.974610 S 680 Po
10 21982.976563 S 680 B
13 21982.986328 ntask sched 2.000000
10 21982.986328 S 680 Fi
10 21982.988281 S 680 B
10 21982.988281 S 680 chol_model_22
10 21986.236328 S 65 B
10 21986.238281 S 680 Po
10 21986.240235 S 680 B
13 21986.246094 ntask sched 1.000000
10 21986.248047 S 680 Fi
10 21986.248047 S 680 B
10 21986.250000 S 680 chol_model_22
10 21989.466797 S 65 B
10 21989.468750 S 680 Po
10 21989.468750 S 680 B
13 21989.476563 ntask sched 0.000000
10 21989.478516 S 680 Fi
10 21989.480469 S 680 B
10 21989.482422 S 680 chol_model_21
10 21997.687500 S 65 B
10 21997.689453 S 680 Po
10 21997.691407 S 680 B
13 21997.726563 ntask sched 1.000000
13 21997.757813 ntask sched 2.000000
13 21997.787110 ntask sched 3.000000
13 21997.818360 ntask sched 4.000000
13 21997.849610 ntask sched 5.000000
13 21997.878907 ntask sched 6.000000
13 21997.912110 ntask sched 7.000000
13 21997.941407 ntask sched 8.000000
13 21997.974610 ntask sched 9.000000
13 21998.003907 ntask sched 10.000000
13 21998.033203 ntask sched 11.000000
13 21998.039063 ntask sched 10.000000
10 21998.039063 S 680 Fi
10 21998.041016 S 680 B
10 21998.041016 S 680 chol_model_22
10 22001.294922 S 65 B
10 22001.294922 S 680 Po
10 22001.296875 S 680 B
13 22001.302735 ntask sched 9.000000
10 22001.304688 S 680 Fi
10 22001.306641 S 680 B
10 22001.306641 S 680 chol_model_22
10 22004.646485 S 65 B
10 22004.648438 S 680 Po
10 22004.650391 S 680 B
13 22004.658203 ntask sched 8.000000
10 22004.660157 S 680 Fi
10 22004.662110 S 680 B
10 22004.662110 S 680 chol_model_22
10 22007.972657 S 65 B
10 22007.974610 S 680 Po
10 22007.976563 S 680 B
13 22007.986328 ntask sched 7.000000
10 22007.988281 S 680 Fi
10 22007.988281 S 680 B
10 22007.990235 S 680 chol_model_22
10 22011.312500 S 65 B
10 22011.314453 S 680 Po
10 22011.316407 S 680 B
13 22011.324219 ntask sched 6.000000
10 22011.326172 S 680 Fi
10 22011.326172 S 680 B
10 22011.328125 S 680 chol_model_22
10 22014.550781 S 65 B
10 22014.550781 S 680 Po
10 22014.552735 S 680 B
13 22014.560547 ntask sched 5.000000
10 22014.560547 S 680 Fi
10 22014.562500 S 680 B
10 22014.564453 S 680 chol_model_22
10 22017.853516 S 65 B
10 22017.853516 S 680 Po
10 22017.855469 S 680 B
13 22017.863281 ntask sched 4.000000
10 22017.865235 S 680 Fi
10 22017.867188 S 680 B
10 22017.867188 S 680 chol_model_22
10 22021.103516 S 65 B
10 22021.103516 S 680 Po
10 22021.105469 S 680 B
13 22021.113281 ntask sched 3.000000
10 22021.115235 S 680 Fi
10 22021.115235 S 680 B
10 22021.117188 S 680 chol_model_22
10 22024.353516 S 65 B
10 22024.353516 S 680 Po
10 22024.355469 S 680 B
13 22024.365235 ntask sched 2.000000
10 22024.367188 S 680 Fi
10 22024.367188 S 680 B
10 22024.369141 S 680 chol_model_22
10 22027.652344 S 65 B
10 22027.652344 S 680 Po
10 22027.654297 S 680 B
13 22027.662110 ntask sched 1.000000
10 22027.664063 S 680 Fi
10 22027.666016 S 680 B
10 22027.666016 S 680 chol_model_22
10 22030.886719 S 65 B
10 22030.888672 S 680 Po
10 22030.890625 S 680 B
13 22030.902344 ntask sched 0.000000
10 22030.904297 S 680 Fi
10 22030.904297 S 680 B
10 22030.906250 S 680 chol_model_22
10 22034.103516 S 65 B
10 22034.105469 S 680 Po
10 22034.105469 S 680 B
13 22034.140625 ntask sched 1.000000
13 22034.146485 ntask sched 0.000000
10 22034.146485 S 680 Fi
10 22034.148438 S 680 B
10 22034.150391 S 680 chol_model_11
10 22107.882813 S 65 B
10 22107.884766 S 680 Po
10 22107.886719 S 680 B
13 22107.923828 ntask sched 1.000000
13 22107.955078 ntask sched 2.000000
13 22107.986328 ntask sched 3.000000
13 22107.992188 ntask sched 2.000000
10 22107.996094 S 679 Fi
13 22108.019531 ntask sched 3.000000
13 22108.046875 ntask sched 4.000000
13 22108.074219 ntask sched 5.000000
13 22108.103516 ntask sched 6.000000
13 22108.130860 ntask sched 7.000000
13 22108.158203 ntask sched 8.000000
13 22108.185547 ntask sched 9.000000
10 22108.189453 MS MEMNODE0 Co
18 22108.189453 L p 4000000 MEMNODE2 com_237
10 22108.201172 MS MEMNODE0 CoA
10 22110.230469 MS MEMNODE0 No
19 22110.230469 L p 2273874960 MEMNODE0 com_2273874768
10 22110.236328 MS MEMNODE0 Co
18 22110.236328 L p 4000000 MEMNODE2 com_238
10 22110.244141 MS MEMNODE0 CoA
10 22112.267578 MS MEMNODE0 No
19 22112.267578 L p 2273874960 MEMNODE0 com_2273874768
10 22112.273438 MS MEMNODE0 Co
18 22112.273438 L p 4000000 MEMNODE2 com_239
10 22112.279297 MS MEMNODE0 CoA
10 22114.291016 MS MEMNODE0 No
19 22114.291016 L p 2273874960 MEMNODE0 com_2273874768
10 22114.296875 MS MEMNODE0 Co
18 22114.296875 L p 4000000 MEMNODE2 com_240
10 22114.308594 MS MEMNODE0 CoA
10 22116.328125 MS MEMNODE0 No
19 22116.328125 L p 2273874960 MEMNODE0 com_2273874768
10 22116.335938 MS MEMNODE0 Co
18 22116.335938 L p 4000000 MEMNODE2 com_241
10 22116.341797 MS MEMNODE0 CoA
10 22118.351563 MS MEMNODE0 No
19 22118.351563 L p 2273874960 MEMNODE0 com_2273874768
13 22118.357422 ntask sched 8.000000
10 22118.359375 S 680 Fi
10 22118.361328 S 680 B
10 22118.392578 S 680 chol_model_21
10 22126.648438 S 65 B
10 22126.650391 S 680 Po
10 22126.652344 S 680 B
13 22126.689453 ntask sched 9.000000
10 22126.697266 MS MEMNODE0 No
19 22126.697266 L p 4000000 MEMNODE0 com_241
10 22126.699219 MS MEMNODE1 A
10 22126.699219 MS MEMNODE0 No
19 22126.699219 L p 4000000 MEMNODE0 com_240
10 22126.703125 MS MEMNODE0 No
19 22126.703125 L p 4000000 MEMNODE0 com_239
10 22126.705078 MS MEMNODE0 No
19 22126.705078 L p 4000000 MEMNODE0 com_238
10 22126.707031 MS MEMNODE0 No
19 22126.707031 L p 4000000 MEMNODE0 com_237
13 22126.708985 ntask sched 8.000000
10 22126.710938 S 680 Fi
10 22126.712891 S 680 B
10 22126.712891 S 680 chol_model_22
10 22126.826172 MS MEMNODE1 No
10 22126.828125 MS MEMNODE1 Co
18 22126.828125 L p 4000000 MEMNODE0 com_242
10 22126.835938 MS MEMNODE1 CoA
10 22127.968750 MS MEMNODE1 No
19 22127.968750 L p 2273874960 MEMNODE1 com_2273874768
10 22127.976563 MS MEMNODE1 A
10 22128.095703 MS MEMNODE1 No
10 22128.097657 MS MEMNODE1 Co
18 22128.097657 L p 4000000 MEMNODE0 com_243
10 22128.103516 MS MEMNODE1 CoA
10 22129.251953 MS MEMNODE1 No
19 22129.251953 L p 2273874960 MEMNODE1 com_2273874768
10 22129.257813 MS MEMNODE1 A
10 22138.123047 MS MEMNODE1 No
10 22138.125000 MS MEMNODE1 Co
18 22138.125000 L p 4000000 MEMNODE0 com_244
10 22138.132813 MS MEMNODE1 CoA
10 22138.148438 S 65 B
10 22138.148438 S 680 Po
10 22138.150391 S 680 B
13 22138.158203 ntask sched 7.000000
10 22138.160157 S 680 Fi
10 22138.160157 S 680 B
10 22138.164063 S 680 chol_model_21
10 22139.294922 MS MEMNODE1 No
19 22139.294922 L p 2273874960 MEMNODE1 com_2273874768
10 22139.300781 MS MEMNODE1 A
10 22139.421875 MS MEMNODE1 No
10 22139.423828 MS MEMNODE1 Co
18 22139.423828 L p 4000000 MEMNODE0 com_245
10 22139.429688 MS MEMNODE1 CoA
10 22140.587891 MS MEMNODE1 No
19 22140.587891 L p 2273874960 MEMNODE1 com_2273874768
10 22140.591797 MS MEMNODE1 A
10 22140.712891 MS MEMNODE1 No
10 22140.714844 MS MEMNODE1 Co
18 22140.714844 L p 4000000 MEMNODE0 com_246
10 22140.720703 MS MEMNODE1 CoA
10 22141.875000 MS MEMNODE1 No
19 22141.875000 L p 2273874960 MEMNODE1 com_2273874768
10 22141.916016 MS MEMNODE1 No
19 22141.916016 L p 4000000 MEMNODE1 com_245
10 22141.941407 MS MEMNODE1 No
19 22141.941407 L p 4000000 MEMNODE1 com_244
10 22141.966797 MS MEMNODE1 No
19 22141.966797 L p 4000000 MEMNODE1 com_243
10 22141.990235 MS MEMNODE1 No
19 22141.990235 L p 4000000 MEMNODE1 com_242
10 22142.064453 MS MEMNODE1 No
19 22142.064453 L p 4000000 MEMNODE1 com_246
10 22142.066407 S 679 B
10 22142.072266 S 679 chol_model_21
10 22146.457031 S 65 B
10 22146.458985 S 680 Po
10 22146.460938 S 680 B
13 22146.496094 ntask sched 8.000000
13 22146.525391 ntask sched 9.000000
13 22146.529297 ntask sched 8.000000
10 22146.531250 S 680 Fi
10 22146.531250 S 680 B
10 22146.533203 S 680 chol_model_22
10 22149.767578 S 65 B
10 22149.769531 S 680 Po
10 22149.771485 S 680 B
13 22149.777344 ntask sched 7.000000
10 22149.777344 S 680 Fi
10 22149.779297 S 680 B
10 22149.779297 S 680 chol_model_22
10 22150.398438 S 64 B
10 22150.402344 S 679 Po
10 22150.404297 S 679 B
13 22150.451172 ntask sched 8.000000
13 22150.482422 ntask sched 9.000000
13 22150.511719 ntask sched 10.000000
10 22150.519531 MS MEMNODE0 Co
18 22150.519531 L p 4000000 MEMNODE1 com_247
10 22150.525391 MS MEMNODE0 CoA
10 22151.951172 MS MEMNODE0 No
19 22151.951172 L p 2273874960 MEMNODE0 com_2273874768
13 22151.958985 ntask sched 9.000000
10 22151.960938 S 679 Fi
10 22151.962891 S 679 B
10 22151.994141 S 679 chol_model_21
10 22153.072266 S 65 B
10 22153.072266 S 680 Po
10 22153.074219 S 680 B
13 22153.082031 ntask sched 8.000000
10 22153.083985 S 680 Fi
10 22160.300781 S 64 B
10 22160.302735 S 679 Po
10 22160.304688 S 679 B
13 22160.339844 ntask sched 9.000000
13 22160.367188 ntask sched 10.000000
13 22160.394531 ntask sched 11.000000
13 22160.423828 ntask sched 12.000000
10 22160.431641 MS MEMNODE0 No
19 22160.431641 L p 4000000 MEMNODE0 com_247
10 22160.437500 MS MEMNODE0 Co
18 22160.437500 L p 4000000 MEMNODE1 com_248
10 22160.437500 MS MEMNODE2 Co
18 22160.437500 L p 4000000 MEMNODE0 com_249
10 22160.441407 MS MEMNODE0 CoA
10 22160.445313 MS MEMNODE2 CoA
10 22161.726563 MS MEMNODE2 No
19 22161.726563 L p 2273874960 MEMNODE2 com_2273874768
10 22161.880860 MS MEMNODE0 No
19 22161.880860 L p 2273874968 MEMNODE0 com_2273874768
13 22161.888672 ntask sched 11.000000
10 22161.888672 S 679 Fi
10 22161.890625 S 679 B
10 22161.923828 MS MEMNODE2 No
19 22161.923828 L p 4000000 MEMNODE2 com_249
10 22161.927735 S 680 B
10 22161.929688 S 680 chol_model_22
10 22161.951172 S 679 chol_model_21
10 22165.158203 S 65 B
10 22165.158203 S 680 Po
10 22165.160157 S 680 B
13 22165.169922 ntask sched 10.000000
10 22165.171875 S 680 Fi
10 22170.259766 S 64 B
10 22170.261719 S 679 Po
10 22170.263672 S 679 B
13 22170.300781 ntask sched 11.000000
13 22170.328125 ntask sched 12.000000
13 22170.355469 ntask sched 13.000000
13 22170.384766 ntask sched 14.000000
13 22170.412110 ntask sched 15.000000
10 22170.419922 MS MEMNODE0 No
19 22170.419922 L p 4000000 MEMNODE0 com_248
10 22170.421875 MS MEMNODE2 Co
18 22170.421875 L p 4000000 MEMNODE0 com_251
10 22170.421875 MS MEMNODE0 Co
18 22170.421875 L p 4000000 MEMNODE1 com_250
10 22170.427735 MS MEMNODE0 CoA
10 22170.437500 MS MEMNODE2 CoA
10 22171.718750 MS MEMNODE2 No
19 22171.718750 L p 2273874960 MEMNODE2 com_2273874768
10 22171.917969 MS MEMNODE2 No
19 22171.917969 L p 4000000 MEMNODE2 com_251
10 22171.921875 MS MEMNODE0 No
19 22171.921875 L p 0 MEMNODE0 com_0
10 22171.921875 S 680 B
10 22171.923828 S 680 chol_model_22
13 22171.927735 ntask sched 14.000000
10 22171.929688 S 679 Fi
10 22171.931641 S 679 B
10 22171.964844 S 679 chol_model_21
10 22175.226563 S 65 B
10 22175.228516 S 680 Po
10 22175.230469 S 680 B
13 22175.238281 ntask sched 13.000000
10 22175.238281 S 680 Fi
10 22180.279297 S 64 B
10 22180.279297 S 679 Po
10 22180.281250 S 679 B
13 22180.316407 ntask sched 14.000000
13 22180.343750 ntask sched 15.000000
13 22180.371094 ntask sched 16.000000
13 22180.398438 ntask sched 17.000000
13 22180.427735 ntask sched 18.000000
13 22180.458985 ntask sched 19.000000
10 22180.466797 MS MEMNODE0 No
19 22180.466797 L p 4000000 MEMNODE0 com_250
10 22180.468750 MS MEMNODE2 Co
18 22180.468750 L p 4000000 MEMNODE0 com_252
10 22180.468750 MS MEMNODE0 Co
18 22180.468750 L p 4000000 MEMNODE1 com_253
10 22180.472657 MS MEMNODE0 CoA
10 22180.476563 MS MEMNODE2 CoA
10 22181.763672 MS MEMNODE2 No
19 22181.763672 L p 2273874960 MEMNODE2 com_2273874768
10 22181.957031 MS MEMNODE2 No
19 22181.957031 L p 4000000 MEMNODE2 com_252
10 22181.960938 S 680 B
10 22181.962891 S 680 chol_model_22
10 22182.033203 MS MEMNODE0 No
19 22182.033203 L p 2273874960 MEMNODE0 com_2273874768
10 22182.076172 MS MEMNODE0 No
19 22182.076172 L p 4000000 MEMNODE0 com_253
10 22185.183594 S 65 B
10 22185.185547 S 680 Po
10 22185.187500 S 680 B
10 22185.195313 MS MEMNODE2 Co
18 22185.195313 L p 4000000 MEMNODE0 com_254
10 22185.205078 MS MEMNODE2 CoA
10 22186.453125 MS MEMNODE2 No
19 22186.453125 L p 2273874960 MEMNODE2 com_2273874768
13 22186.460938 ntask sched 18.000000
10 22186.462891 S 680 Fi
10 22186.648438 MS MEMNODE2 No
19 22186.648438 L p 4000000 MEMNODE2 com_254
10 22186.652344 S 680 B
10 22186.652344 S 680 chol_model_22
10 22189.945313 S 65 B
10 22189.947266 S 680 Po
10 22189.949219 S 680 B
13 22189.957031 ntask sched 17.000000
10 22189.957031 S 680 Fi
10 22189.960938 S 680 B
10 22189.960938 S 680 chol_model_22
10 22193.263672 S 65 B
10 22193.265625 S 680 Po
10 22193.267578 S 680 B
13 22193.275391 ntask sched 16.000000
10 22193.277344 S 680 Fi
10 22193.279297 S 680 B
10 22193.279297 S 680 chol_model_22
10 22196.564453 S 65 B
10 22196.566407 S 680 Po
10 22196.568360 S 680 B
13 22196.576172 ntask sched 15.000000
10 22196.576172 S 680 Fi
10 22196.578125 S 680 B
10 22196.580078 S 680 chol_model_22
10 22199.865235 S 65 B
10 22199.865235 S 680 Po
10 22199.867188 S 680 B
13 22199.876953 ntask sched 14.000000
10 22199.878907 S 680 Fi
10 22199.880860 S 680 B
10 22199.880860 S 680 chol_model_22
10 22203.066407 S 65 B
10 22203.066407 S 680 Po
10 22203.068360 S 680 B
13 22203.076172 ntask sched 13.000000
10 22203.078125 S 680 Fi
10 22203.080078 S 680 B
10 22203.080078 S 680 chol_model_22
10 22206.294922 S 65 B
10 22206.294922 S 680 Po
10 22206.296875 S 680 B
13 22206.304688 ntask sched 12.000000
10 22206.306641 S 680 Fi
10 22206.308594 S 680 B
10 22206.308594 S 680 chol_model_22
10 22209.636719 S 65 B
10 22209.638672 S 680 Po
10 22209.638672 S 680 B
13 22209.648438 ntask sched 11.000000
10 22209.648438 S 680 Fi
10 22209.650391 S 680 B
10 22209.652344 S 680 chol_model_22
10 22212.968750 S 65 B
10 22212.968750 S 680 Po
10 22212.970703 S 680 B
13 22212.978516 ntask sched 10.000000
10 22212.978516 S 680 Fi
10 22212.980469 S 680 B
10 22212.982422 S 680 chol_model_22
10 22216.201172 S 65 B
10 22216.203125 S 680 Po
10 22216.205078 S 680 B
13 22216.212891 ntask sched 9.000000
10 22216.214844 S 680 Fi
10 22216.216797 S 680 B
10 22216.216797 S 680 chol_model_22
10 22219.449219 S 65 B
10 22219.449219 S 680 Po
10 22219.451172 S 680 B
13 22219.462891 ntask sched 8.000000
10 22219.464844 S 680 Fi
10 22219.466797 S 680 B
10 22219.466797 S 680 chol_model_22
10 22222.746094 S 65 B
10 22222.748047 S 680 Po
10 22222.748047 S 680 B
13 22222.757813 ntask sched 7.000000
10 22222.759766 S 680 Fi
10 22222.761719 S 680 B
10 22222.761719 S 680 chol_model_22
10 22225.988281 S 65 B
10 22225.990235 S 680 Po
10 22225.992188 S 680 B
13 22226.000000 ntask sched 6.000000
10 22226.000000 S 680 Fi
10 22226.003907 S 680 B
10 22226.003907 S 680 chol_model_22
10 22229.330078 S 65 B
10 22229.330078 S 680 Po
10 22229.332031 S 680 B
13 22229.341797 ntask sched 5.000000
10 22229.341797 S 680 Fi
10 22229.343750 S 680 B
10 22229.345703 S 680 chol_model_22
10 22232.642578 S 65 B
10 22232.644531 S 680 Po
10 22232.644531 S 680 B
13 22232.652344 ntask sched 4.000000
10 22232.654297 S 680 Fi
10 22232.656250 S 680 B
10 22232.656250 S 680 chol_model_22
10 22235.880860 S 65 B
10 22235.880860 S 680 Po
10 22235.882813 S 680 B
13 22235.892578 ntask sched 3.000000
10 22235.892578 S 680 Fi
10 22235.894531 S 680 B
10 22235.898438 S 680 chol_model_21
10 22244.109375 S 65 B
10 22244.111328 S 680 Po
10 22244.113281 S 680 B
13 22244.152344 ntask sched 4.000000
13 22244.183594 ntask sched 5.000000
13 22244.212891 ntask sched 6.000000
13 22244.244141 ntask sched 7.000000
13 22244.275391 ntask sched 8.000000
13 22244.306641 ntask sched 9.000000
13 22244.335938 ntask sched 10.000000
13 22244.343750 ntask sched 9.000000
10 22244.345703 S 680 Fi
10 22244.345703 S 680 B
10 22244.347657 S 680 chol_model_22
10 22247.652344 S 65 B
10 22247.652344 S 680 Po
10 22247.654297 S 680 B
13 22247.662110 ntask sched 8.000000
10 22247.664063 S 680 Fi
10 22247.666016 S 680 B
10 22247.666016 S 680 chol_model_22
10 22250.906250 S 65 B
10 22250.906250 S 680 Po
10 22250.908203 S 680 B
13 22250.916016 ntask sched 7.000000
10 22250.916016 S 680 Fi
10 22250.919922 S 680 B
10 22250.919922 S 680 chol_model_22
10 22254.152344 S 65 B
10 22254.152344 S 680 Po
10 22254.154297 S 680 B
13 22254.162110 ntask sched 6.000000
10 22254.164063 S 680 Fi
10 22254.166016 S 680 B
10 22254.166016 S 680 chol_model_22
10 22257.453125 S 65 B
10 22257.455078 S 680 Po
10 22257.457031 S 680 B
13 22257.464844 ntask sched 5.000000
10 22257.466797 S 680 Fi
10 22257.466797 S 680 B
10 22257.468750 S 680 chol_model_22
10 22260.699219 S 65 B
10 22260.701172 S 680 Po
10 22260.701172 S 680 B
13 22260.710938 ntask sched 4.000000
10 22260.712891 S 680 Fi
10 22260.712891 S 680 B
10 22260.714844 S 680 chol_model_22
10 22263.998047 S 65 B
10 22264.000000 S 680 Po
10 22264.001953 S 680 B
13 22264.009766 ntask sched 3.000000
10 22264.011719 S 680 Fi
10 22264.011719 S 680 B
10 22264.013672 S 680 chol_model_22
10 22267.306641 S 65 B
10 22267.308594 S 680 Po
10 22267.308594 S 680 B
13 22267.316407 ntask sched 2.000000
10 22267.318360 S 680 Fi
10 22267.320313 S 680 B
10 22267.322266 S 680 chol_model_21
10 22275.529297 S 65 B
10 22275.531250 S 680 Po
10 22275.533203 S 680 B
13 22275.568360 ntask sched 3.000000
13 22275.599610 ntask sched 4.000000
13 22275.630860 ntask sched 5.000000
13 22275.658203 ntask sched 6.000000
13 22275.689453 ntask sched 7.000000
13 22275.718750 ntask sched 8.000000
13 22275.751953 ntask sched 9.000000
13 22275.783203 ntask sched 10.000000
13 22275.787110 ntask sched 9.000000
10 22275.789063 S 680 Fi
10 22275.789063 S 680 B
10 22275.791016 S 680 chol_model_22
10 22279.097657 S 65 B
10 22279.099610 S 680 Po
10 22279.101563 S 680 B
13 22279.109375 ntask sched 8.000000
10 22279.111328 S 680 Fi
10 22279.111328 S 680 B
10 22279.113281 S 680 chol_model_22
10 22282.326172 S 65 B
10 22282.326172 S 680 Po
10 22282.328125 S 680 B
13 22282.335938 ntask sched 7.000000
10 22282.337891 S 680 Fi
10 22282.337891 S 680 B
10 22282.339844 S 680 chol_model_22
10 22285.566407 S 65 B
10 22285.568360 S 680 Po
10 22285.568360 S 680 B
13 22285.576172 ntask sched 6.000000
10 22285.578125 S 680 Fi
10 22285.578125 S 680 B
10 22285.580078 S 680 chol_model_22
10 22288.824219 S 65 B
10 22288.826172 S 680 Po
10 22288.826172 S 680 B
13 22288.833985 ntask sched 5.000000
10 22288.835938 S 680 Fi
10 22288.837891 S 680 B
10 22288.837891 S 680 chol_model_22
10 22292.136719 S 65 B
10 22292.138672 S 680 Po
10 22292.140625 S 680 B
13 22292.148438 ntask sched 4.000000
10 22292.148438 S 680 Fi
10 22292.150391 S 680 B
10 22292.150391 S 680 chol_model_22
10 22295.437500 S 65 B
10 22295.437500 S 680 Po
10 22295.439453 S 680 B
13 22295.447266 ntask sched 3.000000
10 22295.449219 S 680 Fi
10 22295.449219 S 680 B
10 22295.451172 S 680 chol_model_22
10 22298.677735 S 65 B
10 22298.677735 S 680 Po
10 22298.679688 S 680 B
13 22298.685547 ntask sched 2.000000
10 22298.687500 S 680 Fi
10 22298.689453 S 680 B
10 22298.689453 S 680 chol_model_22
10 22301.976563 S 65 B
10 22301.976563 S 680 Po
10 22301.978516 S 680 B
13 22301.994141 ntask sched 1.000000
10 22301.996094 S 680 Fi
10 22301.998047 S 680 B
10 22302.000000 S 680 chol_model_21
10 22310.228516 S 65 B
10 22310.230469 S 680 Po
10 22310.232422 S 680 B
13 22310.269531 ntask sched 2.000000
13 22310.298828 ntask sched 3.000000
13 22310.328125 ntask sched 4.000000
13 22310.357422 ntask sched 5.000000
13 22310.386719 ntask sched 6.000000
13 22310.419922 ntask sched 7.000000
13 22310.455078 ntask sched 8.000000
13 22310.486328 ntask sched 9.000000
13 22310.515625 ntask sched 10.000000
13 22310.529297 ntask sched 9.000000
10 22310.529297 S 680 Fi
10 22310.531250 S 680 B
10 22310.533203 S 680 chol_model_22
10 22313.818360 S 65 B
10 22313.820313 S 680 Po
10 22313.822266 S 680 B
13 22313.828125 ntask sched 8.000000
10 22313.830078 S 680 Fi
10 22313.832031 S 680 B
10 22313.832031 S 680 chol_model_22
10 22317.019531 S 65 B
10 22317.019531 S 680 Po
10 22317.021485 S 680 B
13 22317.029297 ntask sched 7.000000
10 22317.029297 S 680 Fi
10 22317.031250 S 680 B
10 22317.033203 S 680 chol_model_22
10 22320.275391 S 65 B
10 22320.277344 S 680 Po
10 22320.277344 S 680 B
13 22320.287110 ntask sched 6.000000
10 22320.287110 S 680 Fi
10 22320.289063 S 680 B
10 22320.289063 S 680 chol_model_22
10 22323.599610 S 65 B
10 22323.599610 S 680 Po
10 22323.601563 S 680 B
13 22323.609375 ntask sched 5.000000
10 22323.611328 S 680 Fi
10 22323.611328 S 680 B
10 22323.613281 S 680 chol_model_22
10 22326.900391 S 65 B
10 22326.902344 S 680 Po
10 22326.902344 S 680 B
13 22326.910157 ntask sched 4.000000
10 22326.912110 S 680 Fi
10 22326.912110 S 680 B
10 22326.914063 S 680 chol_model_22
10 22330.224610 S 65 B
10 22330.226563 S 680 Po
10 22330.226563 S 680 B
13 22330.234375 ntask sched 3.000000
10 22330.236328 S 680 Fi
10 22330.238281 S 680 B
10 22330.238281 S 680 chol_model_22
10 22333.498047 S 65 B
10 22333.500000 S 680 Po
10 22333.501953 S 680 B
13 22333.509766 ntask sched 2.000000
10 22333.509766 S 680 Fi
10 22333.511719 S 680 B
10 22333.511719 S 680 chol_model_22
10 22336.742188 S 65 B
10 22336.742188 S 680 Po
10 22336.744141 S 680 B
13 22336.751953 ntask sched 1.000000
10 22336.753907 S 680 Fi
10 22336.753907 S 680 B
10 22336.755860 S 680 chol_model_22
10 22339.982422 S 65 B
10 22339.982422 S 680 Po
10 22339.984375 S 680 B
13 22339.992188 ntask sched 0.000000
10 22339.994141 S 680 Fi
10 22339.994141 S 680 B
10 22339.998047 S 680 chol_model_21
10 22348.205078 S 65 B
10 22348.207031 S 680 Po
10 22348.208985 S 680 B
13 22348.244141 ntask sched 1.000000
13 22348.275391 ntask sched 2.000000
13 22348.306641 ntask sched 3.000000
13 22348.335938 ntask sched 4.000000
13 22348.367188 ntask sched 5.000000
13 22348.398438 ntask sched 6.000000
13 22348.429688 ntask sched 7.000000
13 22348.464844 ntask sched 8.000000
13 22348.496094 ntask sched 9.000000
13 22348.525391 ntask sched 10.000000
13 22348.531250 ntask sched 9.000000
10 22348.531250 S 680 Fi
10 22348.533203 S 680 B
10 22348.533203 S 680 chol_model_22
10 22351.816407 S 65 B
10 22351.816407 S 680 Po
10 22351.818360 S 680 B
13 22351.826172 ntask sched 8.000000
10 22351.828125 S 680 Fi
10 22351.828125 S 680 B
10 22351.830078 S 680 chol_model_22
10 22355.109375 S 65 B
10 22355.111328 S 680 Po
10 22355.113281 S 680 B
13 22355.121094 ntask sched 7.000000
10 22355.123047 S 680 Fi
10 22355.125000 S 680 B
10 22355.125000 S 680 chol_model_22
10 22358.419922 S 65 B
10 22358.421875 S 680 Po
10 22358.423828 S 680 B
13 22358.429688 ntask sched 6.000000
10 22358.431641 S 680 Fi
10 22358.439453 S 680 B
10 22358.439453 S 680 chol_model_22
10 22361.669922 S 65 B
10 22361.669922 S 680 Po
10 22361.671875 S 680 B
13 22361.679688 ntask sched 5.000000
10 22361.681641 S 680 Fi
10 22361.683594 S 680 B
10 22361.683594 S 680 chol_model_22
10 22364.990235 S 65 B
10 22364.990235 S 680 Po
10 22364.992188 S 680 B
13 22365.000000 ntask sched 4.000000
10 22365.001953 S 680 Fi
10 22365.003907 S 680 B
10 22365.003907 S 680 chol_model_22
10 22368.287110 S 65 B
10 22368.289063 S 680 Po
10 22368.291016 S 680 B
13 22368.298828 ntask sched 3.000000
10 22368.300781 S 680 Fi
10 22368.302735 S 680 B
10 22368.302735 S 680 chol_model_22
10 22371.587891 S 65 B
10 22371.587891 S 680 Po
10 22371.589844 S 680 B
13 22371.597657 ntask sched 2.000000
10 22371.599610 S 680 Fi
10 22371.599610 S 680 B
10 22371.601563 S 680 chol_model_22
10 22374.900391 S 65 B
10 22374.900391 S 680 Po
10 22374.902344 S 680 B
13 22374.910157 ntask sched 1.000000
10 22374.912110 S 680 Fi
10 22374.914063 S 680 B
10 22374.914063 S 680 chol_model_22
10 22378.222657 S 65 B
10 22378.224610 S 680 Po
10 22378.224610 S 680 B
13 22378.232422 ntask sched 0.000000
10 22378.234375 S 680 Fi
10 22378.236328 S 680 B
10 22378.236328 S 680 chol_model_22
10 22381.529297 S 65 B
10 22381.529297 S 680 Po
10 22381.531250 S 680 B
13 22381.564453 ntask sched 1.000000
13 22381.572266 ntask sched 0.000000
10 22381.572266 S 680 Fi
10 22381.574219 S 680 B
10 22381.576172 S 680 chol_model_11
10 22464.078125 S 65 B
10 22464.078125 S 680 Po
10 22464.080078 S 680 B
13 22464.117188 ntask sched 1.000000
13 22464.148438 ntask sched 2.000000
13 22464.179688 ntask sched 3.000000
13 22464.185547 ntask sched 2.000000
10 22464.187500 S 679 Fi
13 22464.212891 ntask sched 3.000000
13 22464.238281 ntask sched 4.000000
13 22464.265625 ntask sched 5.000000
13 22464.291016 ntask sched 6.000000
13 22464.320313 ntask sched 7.000000
13 22464.347657 ntask sched 8.000000
10 22464.351563 MS MEMNODE0 Co
18 22464.351563 L p 4000000 MEMNODE2 com_255
10 22464.363281 MS MEMNODE0 CoA
10 22466.384766 MS MEMNODE0 No
19 22466.384766 L p 2273874960 MEMNODE0 com_2273874768
10 22466.390625 MS MEMNODE0 Co
18 22466.390625 L p 4000000 MEMNODE2 com_256
10 22466.396485 MS MEMNODE0 CoA
10 22468.419922 MS MEMNODE0 No
19 22468.419922 L p 2273874960 MEMNODE0 com_2273874768
10 22468.425781 MS MEMNODE0 Co
18 22468.425781 L p 4000000 MEMNODE2 com_257
10 22468.431641 MS MEMNODE0 CoA
10 22470.449219 MS MEMNODE0 No
19 22470.449219 L p 2273874960 MEMNODE0 com_2273874768
10 22470.455078 MS MEMNODE0 Co
18 22470.455078 L p 4000000 MEMNODE2 com_258
10 22470.476563 MS MEMNODE0 CoA
10 22472.498047 MS MEMNODE0 No
19 22472.498047 L p 2273874960 MEMNODE0 com_2273874768
10 22472.503907 MS MEMNODE0 Co
18 22472.503907 L p 4000000 MEMNODE2 com_259
10 22472.519531 MS MEMNODE0 CoA
10 22474.539063 MS MEMNODE0 No
19 22474.539063 L p 2273874960 MEMNODE0 com_2273874768
13 22474.546875 ntask sched 7.000000
10 22474.548828 S 680 Fi
10 22474.550781 S 680 B
10 22474.582031 S 680 chol_model_21
10 22482.822266 S 65 B
10 22482.824219 S 680 Po
10 22482.826172 S 680 B
13 22482.863281 ntask sched 8.000000
10 22482.873047 MS MEMNODE0 No
19 22482.873047 L p 4000000 MEMNODE0 com_259
10 22482.876953 MS MEMNODE0 No
19 22482.876953 L p 4000000 MEMNODE0 com_258
10 22482.878907 MS MEMNODE1 A
10 22482.878907 MS MEMNODE0 No
19 22482.878907 L p 4000000 MEMNODE0 com_257
10 22482.882813 MS MEMNODE0 No
19 22482.882813 L p 4000000 MEMNODE0 com_256
10 22482.884766 MS MEMNODE0 No
19 22482.884766 L p 4000000 MEMNODE0 com_255
13 22482.886719 ntask sched 7.000000
10 22482.886719 S 680 Fi
10 22482.888672 S 680 B
10 22482.888672 S 680 chol_model_22
10 22483.007813 MS MEMNODE1 No
10 22483.009766 MS MEMNODE1 Co
18 22483.009766 L p 4000000 MEMNODE0 com_260
10 22483.015625 MS MEMNODE1 CoA
10 22484.140625 MS MEMNODE1 No
19 22484.140625 L p 2273874960 MEMNODE1 com_2273874768
10 22484.150391 MS MEMNODE1 A
10 22484.269531 MS MEMNODE1 No
10 22484.271485 MS MEMNODE1 Co
18 22484.271485 L p 4000000 MEMNODE0 com_261
10 22484.277344 MS MEMNODE1 CoA
10 22485.431641 MS MEMNODE1 No
19 22485.431641 L p 2273874960 MEMNODE1 com_2273874768
10 22485.439453 MS MEMNODE1 A
10 22485.560547 MS MEMNODE1 No
10 22485.562500 MS MEMNODE1 Co
18 22485.562500 L p 4000000 MEMNODE0 com_262
10 22485.568360 MS MEMNODE1 CoA
10 22486.208985 S 65 B
10 22486.210938 S 680 Po
10 22486.212891 S 680 B
13 22486.218750 ntask sched 6.000000
10 22486.220703 S 680 Fi
10 22486.222657 S 680 B
10 22486.224610 S 680 chol_model_21
10 22486.716797 MS MEMNODE1 No
19 22486.716797 L p 2273874960 MEMNODE1 com_2273874768
10 22486.720703 MS MEMNODE1 A
10 22486.843750 MS MEMNODE1 No
10 22486.845703 MS MEMNODE1 Co
18 22486.845703 L p 4000000 MEMNODE0 com_263
10 22486.849610 MS MEMNODE1 CoA
10 22488.003907 MS MEMNODE1 No
19 22488.003907 L p 2273874960 MEMNODE1 com_2273874768
10 22488.007813 MS MEMNODE1 A
10 22488.126953 MS MEMNODE1 No
10 22488.128907 MS MEMNODE1 Co
18 22488.128907 L p 4000000 MEMNODE0 com_264
10 22488.134766 MS MEMNODE1 CoA
10 22489.292969 MS MEMNODE1 No
19 22489.292969 L p 2273874960 MEMNODE1 com_2273874768
10 22489.332031 MS MEMNODE1 No
19 22489.332031 L p 4000000 MEMNODE1 com_263
10 22489.357422 MS MEMNODE1 No
19 22489.357422 L p 4000000 MEMNODE1 com_262
10 22489.382813 MS MEMNODE1 No
19 22489.382813 L p 4000000 MEMNODE1 com_261
10 22489.406250 MS MEMNODE1 No
19 22489.406250 L p 4000000 MEMNODE1 com_260
10 22489.484375 MS MEMNODE1 No
19 22489.484375 L p 4000000 MEMNODE1 com_264
10 22489.486328 S 679 B
10 22489.492188 S 679 chol_model_21
10 22494.494141 S 65 B
10 22494.496094 S 680 Po
10 22494.498047 S 680 B
13 22494.533203 ntask sched 7.000000
13 22494.564453 ntask sched 8.000000
13 22494.570313 ntask sched 7.000000
10 22494.570313 S 680 Fi
10 22494.572266 S 680 B
10 22494.574219 S 680 chol_model_22
10 22497.824219 S 64 B
10 22497.826172 S 679 Po
10 22497.830078 S 679 B
10 22497.849610 S 65 B
10 22497.851563 S 680 Po
10 22497.853516 S 680 B
13 22497.861328 ntask sched 6.000000
10 22497.861328 S 680 Fi
10 22497.863281 S 680 B
10 22497.863281 S 680 chol_model_22
13 22497.873047 ntask sched 7.000000
13 22497.904297 ntask sched 8.000000
13 22497.935547 ntask sched 9.000000
10 22497.941407 MS MEMNODE0 Co
18 22497.941407 L p 4000000 MEMNODE1 com_265
10 22497.947266 MS MEMNODE0 CoA
10 22499.373047 MS MEMNODE0 No
19 22499.373047 L p 2273874960 MEMNODE0 com_2273874768
13 22499.382813 ntask sched 8.000000
10 22499.384766 S 679 Fi
10 22499.384766 S 679 B
10 22499.416016 S 679 chol_model_21
10 22501.107422 S 65 B
10 22501.109375 S 680 Po
10 22501.111328 S 680 B
13 22501.119141 ntask sched 7.000000
10 22501.121094 S 680 Fi
10 22507.728516 S 64 B
10 22507.730469 S 679 Po
10 22507.732422 S 679 B
13 22507.767578 ntask sched 8.000000
13 22507.798828 ntask sched 9.000000
13 22507.824219 ntask sched 10.000000
13 22507.853516 ntask sched 11.000000
10 22507.861328 MS MEMNODE0 No
19 22507.861328 L p 4000000 MEMNODE0 com_265
10 22507.863281 MS MEMNODE0 Co
18 22507.863281 L p 4000000 MEMNODE1 com_266
10 22507.863281 MS MEMNODE2 Co
18 22507.863281 L p 4000000 MEMNODE0 com_267
10 22507.867188 MS MEMNODE0 CoA
10 22507.873047 MS MEMNODE2 CoA
10 22509.148438 MS MEMNODE2 No
19 22509.148438 L p 2273874960 MEMNODE2 com_2273874768
10 22509.296875 MS MEMNODE0 No
19 22509.296875 L p 2273874968 MEMNODE0 com_2273874768
13 22509.304688 ntask sched 10.000000
10 22509.304688 S 679 Fi
10 22509.306641 S 679 B
10 22509.341797 S 679 chol_model_21
10 22509.371094 MS MEMNODE2 No
19 22509.371094 L p 4000000 MEMNODE2 com_267
10 22509.375000 S 680 B
10 22509.375000 S 680 chol_model_22
10 22512.632813 S 65 B
10 22512.632813 S 680 Po
10 22512.634766 S 680 B
13 22512.644531 ntask sched 9.000000
10 22512.644531 S 680 Fi
10 22517.648438 S 64 B
10 22517.650391 S 679 Po
10 22517.652344 S 679 B
13 22517.689453 ntask sched 10.000000
13 22517.716797 ntask sched 11.000000
13 22517.744141 ntask sched 12.000000
13 22517.773438 ntask sched 13.000000
13 22517.800781 ntask sched 14.000000
10 22517.808594 MS MEMNODE0 No
19 22517.808594 L p 4000000 MEMNODE0 com_266
10 22517.812500 MS MEMNODE2 Co
18 22517.812500 L p 4000000 MEMNODE0 com_268
10 22517.812500 MS MEMNODE0 Co
18 22517.812500 L p 4000000 MEMNODE1 com_269
10 22517.816407 MS MEMNODE0 CoA
10 22517.820313 MS MEMNODE2 CoA
10 22519.103516 MS MEMNODE2 No
19 22519.103516 L p 2273874960 MEMNODE2 com_2273874768
10 22519.300781 MS MEMNODE0 No
19 22519.300781 L p 2273874968 MEMNODE0 com_2273874768
10 22519.300781 MS MEMNODE2 No
19 22519.300781 L p 4000000 MEMNODE2 com_268
10 22519.302735 S 680 B
10 22519.302735 S 680 chol_model_22
13 22519.306641 ntask sched 13.000000
10 22519.308594 S 679 Fi
10 22519.310547 S 679 B
10 22519.343750 S 679 chol_model_21
10 22522.619141 S 65 B
10 22522.619141 S 680 Po
10 22522.621094 S 680 B
13 22522.630860 ntask sched 12.000000
10 22522.632813 S 680 Fi
10 22527.654297 S 64 B
10 22527.656250 S 679 Po
10 22527.658203 S 679 B
13 22527.693360 ntask sched 13.000000
13 22527.720703 ntask sched 14.000000
13 22527.746094 ntask sched 15.000000
13 22527.775391 ntask sched 16.000000
13 22527.802735 ntask sched 17.000000
13 22527.832031 ntask sched 18.000000
10 22527.839844 MS MEMNODE0 No
19 22527.839844 L p 4000000 MEMNODE0 com_269
10 22527.841797 MS MEMNODE2 Co
18 22527.841797 L p 4000000 MEMNODE0 com_270
10 22527.841797 MS MEMNODE0 Co
18 22527.841797 L p 4000000 MEMNODE1 com_271
10 22527.851563 MS MEMNODE2 CoA
10 22527.853516 MS MEMNODE0 CoA
10 22529.146485 MS MEMNODE2 No
19 22529.146485 L p 2273874960 MEMNODE2 com_2273874768
10 22529.341797 MS MEMNODE2 No
19 22529.341797 L p 4000000 MEMNODE2 com_270
10 22529.343750 S 680 B
10 22529.345703 S 680 chol_model_22
10 22529.410157 MS MEMNODE0 No
19 22529.410157 L p 2273874960 MEMNODE0 com_2273874768
10 22529.455078 MS MEMNODE0 No
19 22529.455078 L p 4000000 MEMNODE0 com_271
10 22532.640625 S 65 B
10 22532.640625 S 680 Po
10 22532.642578 S 680 B
10 22532.652344 MS MEMNODE2 Co
18 22532.652344 L p 4000000 MEMNODE0 com_272
10 22532.660157 MS MEMNODE2 CoA
10 22533.900391 MS MEMNODE2 No
19 22533.900391 L p 2273874960 MEMNODE2 com_2273874768
13 22533.906250 ntask sched 17.000000
10 22533.908203 S 680 Fi
10 22534.097657 MS MEMNODE2 No
19 22534.097657 L p 4000000 MEMNODE2 com_272
10 22534.101563 S 680 B
10 22534.103516 S 680 chol_model_22
10 22537.423828 S 65 B
10 22537.423828 S 680 Po
10 22537.425781 S 680 B
13 22537.439453 ntask sched 16.000000
10 22537.441407 S 680 Fi
10 22537.443360 S 680 B
10 22537.445313 S 680 chol_model_22
10 22540.716797 S 65 B
10 22540.718750 S 680 Po
10 22540.720703 S 680 B
13 22540.726563 ntask sched 15.000000
10 22540.728516 S 680 Fi
10 22540.730469 S 680 B
10 22540.730469 S 680 chol_model_22
10 22544.050781 S 65 B
10 22544.052735 S 680 Po
10 22544.052735 S 680 B
13 22544.062500 ntask sched 14.000000
10 22544.064453 S 680 Fi
10 22544.064453 S 680 B
10 22544.066407 S 680 chol_model_22
10 22547.351563 S 65 B
10 22547.353516 S 680 Po
10 22547.353516 S 680 B
13 22547.361328 ntask sched 13.000000
10 22547.363281 S 680 Fi
10 22547.365235 S 680 B
10 22547.365235 S 680 chol_model_22
10 22550.640625 S 65 B
10 22550.640625 S 680 Po
10 22550.642578 S 680 B
13 22550.650391 ntask sched 12.000000
10 22550.652344 S 680 Fi
10 22550.654297 S 680 B
10 22550.654297 S 680 chol_model_22
10 22553.955078 S 65 B
10 22553.955078 S 680 Po
10 22553.957031 S 680 B
13 22553.966797 ntask sched 11.000000
10 22553.968750 S 680 Fi
10 22553.968750 S 680 B
10 22553.970703 S 680 chol_model_22
10 22557.261719 S 65 B
10 22557.261719 S 680 Po
10 22557.263672 S 680 B
13 22557.271485 ntask sched 10.000000
10 22557.273438 S 680 Fi
10 22557.273438 S 680 B
10 22557.275391 S 680 chol_model_22
10 22560.503907 S 65 B
10 22560.503907 S 680 Po
10 22560.505860 S 680 B
13 22560.515625 ntask sched 9.000000
10 22560.515625 S 680 Fi
10 22560.517578 S 680 B
10 22560.519531 S 680 chol_model_22
10 22563.750000 S 65 B
10 22563.751953 S 680 Po
10 22563.753907 S 680 B
13 22563.761719 ntask sched 8.000000
10 22563.763672 S 680 Fi
10 22563.765625 S 680 B
10 22563.765625 S 680 chol_model_22
10 22567.054688 S 65 B
10 22567.054688 S 680 Po
10 22567.056641 S 680 B
13 22567.062500 ntask sched 7.000000
10 22567.064453 S 680 Fi
10 22567.066407 S 680 B
10 22567.066407 S 680 chol_model_22
10 22570.289063 S 65 B
10 22570.291016 S 680 Po
10 22570.292969 S 680 B
13 22570.302735 ntask sched 6.000000
10 22570.304688 S 680 Fi
10 22570.306641 S 680 B
10 22570.306641 S 680 chol_model_22
10 22573.525391 S 65 B
10 22573.525391 S 680 Po
10 22573.527344 S 680 B
13 22573.537110 ntask sched 5.000000
10 22573.539063 S 680 Fi
10 22573.539063 S 680 B
10 22573.541016 S 680 chol_model_22
10 22576.845703 S 65 B
10 22576.845703 S 680 Po
10 22576.847657 S 680 B
13 22576.855469 ntask sched 4.000000
10 22576.857422 S 680 Fi
10 22576.859375 S 680 B
10 22576.861328 S 680 chol_model_22
10 22580.183594 S 65 B
10 22580.185547 S 680 Po
10 22580.185547 S 680 B
13 22580.193360 ntask sched 3.000000
10 22580.195313 S 680 Fi
10 22580.197266 S 680 B
10 22580.197266 S 680 chol_model_22
10 22583.400391 S 65 B
10 22583.402344 S 680 Po
10 22583.402344 S 680 B
13 22583.410157 ntask sched 2.000000
10 22583.412110 S 680 Fi
10 22583.414063 S 680 B
10 22583.417969 S 680 chol_model_21
10 22591.650391 S 65 B
10 22591.652344 S 680 Po
10 22591.654297 S 680 B
13 22591.691407 ntask sched 3.000000
13 22591.718750 ntask sched 4.000000
13 22591.750000 ntask sched 5.000000
13 22591.779297 ntask sched 6.000000
13 22591.810547 ntask sched 7.000000
13 22591.839844 ntask sched 8.000000
13 22591.871094 ntask sched 9.000000
13 22591.878907 ntask sched 8.000000
10 22591.878907 S 680 Fi
10 22591.880860 S 680 B
10 22591.880860 S 680 chol_model_22
10 22595.128907 S 65 B
10 22595.130860 S 680 Po
10 22595.132813 S 680 B
13 22595.138672 ntask sched 7.000000
10 22595.140625 S 680 Fi
10 22595.142578 S 680 B
10 22595.142578 S 680 chol_model_22
10 22598.396485 S 65 B
10 22598.396485 S 680 Po
10 22598.398438 S 680 B
13 22598.406250 ntask sched 6.000000
10 22598.406250 S 680 Fi
10 22598.408203 S 680 B
10 22598.410157 S 680 chol_model_22
10 22601.716797 S 65 B
10 22601.718750 S 680 Po
10 22601.720703 S 680 B
13 22601.726563 ntask sched 5.000000
10 22601.728516 S 680 Fi
10 22601.730469 S 680 B
10 22601.730469 S 680 chol_model_22
10 22605.060547 S 65 B
10 22605.060547 S 680 Po
10 22605.062500 S 680 B
13 22605.070313 ntask sched 4.000000
10 22605.072266 S 680 Fi
10 22605.072266 S 680 B
10 22605.074219 S 680 chol_model_22
10 22608.275391 S 65 B
10 22608.277344 S 680 Po
10 22608.277344 S 680 B
13 22608.287110 ntask sched 3.000000
10 22608.287110 S 680 Fi
10 22608.289063 S 680 B
10 22608.289063 S 680 chol_model_22
10 22611.597657 S 65 B
10 22611.597657 S 680 Po
10 22611.599610 S 680 B
13 22611.607422 ntask sched 2.000000
10 22611.609375 S 680 Fi
10 22611.611328 S 680 B
10 22611.611328 S 680 chol_model_22
10 22614.853516 S 65 B
10 22614.853516 S 680 Po
10 22614.855469 S 680 B
13 22614.869141 ntask sched 1.000000
10 22614.869141 S 680 Fi
10 22614.871094 S 680 B
10 22614.875000 S 680 chol_model_21
10 22623.082031 S 65 B
10 22623.085938 S 680 Po
10 22623.085938 S 680 B
13 22623.121094 ntask sched 2.000000
13 22623.152344 ntask sched 3.000000
13 22623.183594 ntask sched 4.000000
13 22623.212891 ntask sched 5.000000
13 22623.242188 ntask sched 6.000000
13 22623.273438 ntask sched 7.000000
13 22623.304688 ntask sched 8.000000
13 22623.335938 ntask sched 9.000000
13 22623.339844 ntask sched 8.000000
10 22623.341797 S 680 Fi
10 22623.341797 S 680 B
10 22623.343750 S 680 chol_model_22
10 22626.650391 S 65 B
10 22626.650391 S 680 Po
10 22626.652344 S 680 B
13 22626.660157 ntask sched 7.000000
10 22626.660157 S 680 Fi
10 22626.662110 S 680 B
10 22626.664063 S 680 chol_model_22
10 22629.951172 S 65 B
10 22629.951172 S 680 Po
10 22629.953125 S 680 B
13 22629.960938 ntask sched 6.000000
10 22629.962891 S 680 Fi
10 22629.964844 S 680 B
10 22629.964844 S 680 chol_model_22
10 22633.265625 S 65 B
10 22633.265625 S 680 Po
10 22633.267578 S 680 B
13 22633.285157 ntask sched 5.000000
10 22633.287110 S 680 Fi
10 22633.289063 S 680 B
10 22633.289063 S 680 chol_model_22
10 22636.578125 S 65 B
10 22636.578125 S 680 Po
10 22636.580078 S 680 B
13 22636.587891 ntask sched 4.000000
10 22636.589844 S 680 Fi
10 22636.591797 S 680 B
10 22636.591797 S 680 chol_model_22
10 22639.880860 S 65 B
10 22639.882813 S 680 Po
10 22639.884766 S 680 B
13 22639.890625 ntask sched 3.000000
10 22639.892578 S 680 Fi
10 22639.892578 S 680 B
10 22639.894531 S 680 chol_model_22
10 22643.169922 S 65 B
10 22643.171875 S 680 Po
10 22643.173828 S 680 B
13 22643.179688 ntask sched 2.000000
10 22643.181641 S 680 Fi
10 22643.183594 S 680 B
10 22643.183594 S 680 chol_model_22
10 22646.490235 S 65 B
10 22646.490235 S 680 Po
10 22646.492188 S 680 B
13 22646.500000 ntask sched 1.000000
10 22646.500000 S 680 Fi
10 22646.501953 S 680 B
10 22646.503907 S 680 chol_model_22
10 22649.707031 S 65 B
10 22649.707031 S 680 Po
10 22649.708985 S 680 B
13 22649.716797 ntask sched 0.000000
10 22649.718750 S 680 Fi
10 22649.720703 S 680 B
10 22649.722657 S 680 chol_model_21
10 22657.955078 S 65 B
10 22657.957031 S 680 Po
10 22657.957031 S 680 B
13 22657.994141 ntask sched 1.000000
13 22658.025391 ntask sched 2.000000
13 22658.056641 ntask sched 3.000000
13 22658.085938 ntask sched 4.000000
13 22658.117188 ntask sched 5.000000
13 22658.146485 ntask sched 6.000000
13 22658.177735 ntask sched 7.000000
13 22658.207031 ntask sched 8.000000
13 22658.238281 ntask sched 9.000000
13 22658.242188 ntask sched 8.000000
10 22658.244141 S 680 Fi
10 22658.246094 S 680 B
10 22658.246094 S 680 chol_model_22
10 22661.531250 S 65 B
10 22661.533203 S 680 Po
10 22661.535157 S 680 B
13 22661.541016 ntask sched 7.000000
10 22661.544922 S 680 Fi
10 22661.544922 S 680 B
10 22661.546875 S 680 chol_model_22
10 22664.839844 S 65 B
10 22664.841797 S 680 Po
10 22664.843750 S 680 B
13 22664.851563 ntask sched 6.000000
10 22664.851563 S 680 Fi
10 22664.853516 S 680 B
10 22664.855469 S 680 chol_model_22
10 22668.175781 S 65 B
10 22668.175781 S 680 Po
10 22668.177735 S 680 B
13 22668.185547 ntask sched 5.000000
10 22668.187500 S 680 Fi
10 22668.189453 S 680 B
10 22668.189453 S 680 chol_model_22
10 22671.482422 S 65 B
10 22671.484375 S 680 Po
10 22671.486328 S 680 B
13 22671.494141 ntask sched 4.000000
10 22671.494141 S 680 Fi
10 22671.496094 S 680 B
10 22671.496094 S 680 chol_model_22
10 22674.835938 S 65 B
10 22674.837891 S 680 Po
10 22674.837891 S 680 B
13 22674.845703 ntask sched 3.000000
10 22674.847657 S 680 Fi
10 22674.849610 S 680 B
10 22674.849610 S 680 chol_model_22
10 22678.150391 S 65 B
10 22678.150391 S 680 Po
10 22678.152344 S 680 B
13 22678.160157 ntask sched 2.000000
10 22678.162110 S 680 Fi
10 22678.162110 S 680 B
10 22678.164063 S 680 chol_model_22
10 22681.476563 S 65 B
10 22681.476563 S 680 Po
10 22681.478516 S 680 B
13 22681.484375 ntask sched 1.000000
10 22681.486328 S 680 Fi
10 22681.488281 S 680 B
10 22681.488281 S 680 chol_model_22
10 22684.705078 S 65 B
10 22684.705078 S 680 Po
10 22684.707031 S 680 B
13 22684.714844 ntask sched 0.000000
10 22684.716797 S 680 Fi
10 22684.716797 S 680 B
10 22684.718750 S 680 chol_model_22
10 22687.923828 S 65 B
10 22687.925781 S 680 Po
10 22687.927735 S 680 B
13 22687.960938 ntask sched 1.000000
13 22687.964844 ntask sched 0.000000
10 22687.966797 S 680 Fi
10 22687.966797 S 680 B
10 22687.970703 S 680 chol_model_11
10 22785.326172 S 65 B
10 22785.328125 S 680 Po
10 22785.330078 S 680 B
13 22785.369141 ntask sched 1.000000
13 22785.398438 ntask sched 2.000000
13 22785.429688 ntask sched 3.000000
13 22785.431641 ntask sched 2.000000
10 22785.439453 S 679 Fi
13 22785.466797 ntask sched 3.000000
13 22785.494141 ntask sched 4.000000
13 22785.523438 ntask sched 5.000000
13 22785.552735 ntask sched 6.000000
13 22785.578125 ntask sched 7.000000
10 22785.583985 MS MEMNODE0 Co
18 22785.583985 L p 4000000 MEMNODE2 com_273
10 22785.593750 MS MEMNODE0 CoA
10 22787.617188 MS MEMNODE0 No
19 22787.617188 L p 2273874960 MEMNODE0 com_2273874768
10 22787.623047 MS MEMNODE0 Co
18 22787.623047 L p 4000000 MEMNODE2 com_274
10 22787.632813 MS MEMNODE0 CoA
10 22789.648438 MS MEMNODE0 No
19 22789.648438 L p 2273874960 MEMNODE0 com_2273874768
10 22789.652344 MS MEMNODE0 Co
18 22789.652344 L p 4000000 MEMNODE2 com_275
10 22789.660157 MS MEMNODE0 CoA
10 22791.679688 MS MEMNODE0 No
19 22791.679688 L p 2273874960 MEMNODE0 com_2273874768
10 22791.685547 MS MEMNODE0 Co
18 22791.685547 L p 4000000 MEMNODE2 com_276
10 22791.693360 MS MEMNODE0 CoA
10 22793.705078 MS MEMNODE0 No
19 22793.705078 L p 2273874960 MEMNODE0 com_2273874768
10 22793.710938 MS MEMNODE0 Co
18 22793.710938 L p 4000000 MEMNODE2 com_277
10 22793.716797 MS MEMNODE0 CoA
10 22795.732422 MS MEMNODE0 No
19 22795.732422 L p 2273874960 MEMNODE0 com_2273874768
13 22795.740235 ntask sched 6.000000
10 22795.740235 S 680 Fi
10 22795.742188 S 680 B
10 22795.773438 S 680 chol_model_21
10 22804.068360 S 65 B
10 22804.070313 S 680 Po
10 22804.070313 S 680 B
13 22804.107422 ntask sched 7.000000
10 22804.117188 MS MEMNODE0 No
19 22804.117188 L p 4000000 MEMNODE0 com_277
10 22804.119141 MS MEMNODE1 A
10 22804.119141 MS MEMNODE0 No
19 22804.119141 L p 4000000 MEMNODE0 com_276
10 22804.123047 MS MEMNODE0 No
19 22804.123047 L p 4000000 MEMNODE0 com_275
10 22804.125000 MS MEMNODE0 No
19 22804.125000 L p 4000000 MEMNODE0 com_274
10 22804.126953 MS MEMNODE0 No
19 22804.126953 L p 4000000 MEMNODE0 com_273
13 22804.128907 ntask sched 6.000000
10 22804.130860 S 680 Fi
10 22804.130860 S 680 B
10 22804.132813 S 680 chol_model_22
10 22804.248047 MS MEMNODE1 No
10 22804.251953 MS MEMNODE1 Co
18 22804.251953 L p 4000000 MEMNODE0 com_278
10 22804.259766 MS MEMNODE1 CoA
10 22805.390625 MS MEMNODE1 No
19 22805.390625 L p 2273874960 MEMNODE1 com_2273874768
10 22805.398438 MS MEMNODE1 A
10 22805.519531 MS MEMNODE1 No
10 22805.521485 MS MEMNODE1 Co
18 22805.521485 L p 4000000 MEMNODE0 com_279
10 22805.527344 MS MEMNODE1 CoA
10 22806.675781 MS MEMNODE1 No
19 22806.675781 L p 2273874960 MEMNODE1 com_2273874768
10 22806.681641 MS MEMNODE1 A
10 22806.802735 MS MEMNODE1 No
10 22806.804688 MS MEMNODE1 Co
18 22806.804688 L p 4000000 MEMNODE0 com_280
10 22806.810547 MS MEMNODE1 CoA
10 22807.351563 S 65 B
10 22807.351563 S 680 Po
10 22807.353516 S 680 B
13 22807.361328 ntask sched 5.000000
10 22807.361328 S 680 Fi
10 22807.363281 S 680 B
10 22807.365235 S 680 chol_model_21
10 22807.966797 MS MEMNODE1 No
19 22807.966797 L p 2273874960 MEMNODE1 com_2273874768
10 22807.970703 MS MEMNODE1 A
10 22808.093750 MS MEMNODE1 No
10 22808.095703 MS MEMNODE1 Co
18 22808.095703 L p 4000000 MEMNODE0 com_281
10 22808.099610 MS MEMNODE1 CoA
10 22809.255860 MS MEMNODE1 No
19 22809.255860 L p 2273874960 MEMNODE1 com_2273874768
10 22809.259766 MS MEMNODE1 A
10 22809.378907 MS MEMNODE1 No
10 22809.380860 MS MEMNODE1 Co
18 22809.380860 L p 4000000 MEMNODE0 com_282
10 22809.386719 MS MEMNODE1 CoA
10 22810.544922 MS MEMNODE1 No
19 22810.544922 L p 2273874960 MEMNODE1 com_2273874768
10 22810.582031 MS MEMNODE1 No
19 22810.582031 L p 4000000 MEMNODE1 com_281
10 22810.609375 MS MEMNODE1 No
19 22810.609375 L p 4000000 MEMNODE1 com_280
10 22810.634766 MS MEMNODE1 No
19 22810.634766 L p 4000000 MEMNODE1 com_279
10 22810.658203 MS MEMNODE1 No
19 22810.658203 L p 4000000 MEMNODE1 com_278
10 22810.732422 MS MEMNODE1 No
19 22810.732422 L p 4000000 MEMNODE1 com_282
10 22810.734375 S 679 B
10 22810.740235 S 679 chol_model_21
10 22815.640625 S 65 B
10 22815.642578 S 680 Po
10 22815.644531 S 680 B
13 22815.679688 ntask sched 6.000000
13 22815.708985 ntask sched 7.000000
13 22815.712891 ntask sched 6.000000
10 22815.714844 S 680 Fi
10 22815.714844 S 680 B
10 22815.716797 S 680 chol_model_22
10 22819.037110 S 65 B
10 22819.039063 S 680 Po
10 22819.039063 S 680 B
13 22819.048828 ntask sched 5.000000
10 22819.048828 S 680 Fi
10 22819.050781 S 680 B
10 22819.050781 S 680 chol_model_22
10 22819.070313 S 64 B
10 22819.074219 S 679 Po
10 22819.076172 S 679 B
13 22819.119141 ntask sched 6.000000
13 22819.148438 ntask sched 7.000000
13 22819.179688 ntask sched 8.000000
10 22819.185547 MS MEMNODE0 Co
18 22819.185547 L p 4000000 MEMNODE1 com_283
10 22819.193360 MS MEMNODE0 CoA
10 22820.615235 MS MEMNODE0 No
19 22820.615235 L p 2273874960 MEMNODE0 com_2273874768
13 22820.621094 ntask sched 7.000000
10 22820.623047 S 679 Fi
10 22820.625000 S 679 B
10 22820.656250 S 679 chol_model_21
10 22822.269531 S 65 B
10 22822.269531 S 680 Po
10 22822.271485 S 680 B
13 22822.279297 ntask sched 6.000000
10 22822.279297 S 680 Fi
10 22828.968750 S 64 B
10 22828.970703 S 679 Po
10 22828.972657 S 679 B
13 22829.007813 ntask sched 7.000000
13 22829.035157 ntask sched 8.000000
13 22829.062500 ntask sched 9.000000
13 22829.089844 ntask sched 10.000000
10 22829.097657 MS MEMNODE0 No
19 22829.097657 L p 4000000 MEMNODE0 com_283
10 22829.099610 MS MEMNODE0 Co
18 22829.099610 L p 4000000 MEMNODE1 com_284
10 22829.101563 MS MEMNODE2 Co
18 22829.101563 L p 4000000 MEMNODE0 com_285
10 22829.105469 MS MEMNODE0 CoA
10 22829.113281 MS MEMNODE2 CoA
10 22830.388672 MS MEMNODE2 No
19 22830.388672 L p 2273874960 MEMNODE2 com_2273874768
10 22830.533203 MS MEMNODE0 No
19 22830.533203 L p 2273874968 MEMNODE0 com_2273874768
13 22830.541016 ntask sched 9.000000
10 22830.541016 S 679 Fi
10 22830.544922 S 679 B
10 22830.580078 S 679 chol_model_21
10 22830.609375 MS MEMNODE2 No
19 22830.609375 L p 4000000 MEMNODE2 com_285
10 22830.613281 S 680 B
10 22830.615235 S 680 chol_model_22
10 22833.949219 S 65 B
10 22833.949219 S 680 Po
10 22833.951172 S 680 B
13 22833.958985 ntask sched 8.000000
10 22833.960938 S 680 Fi
10 22838.886719 S 64 B
10 22838.888672 S 679 Po
10 22838.890625 S 679 B
13 22838.925781 ntask sched 9.000000
13 22838.953125 ntask sched 10.000000
13 22838.978516 ntask sched 11.000000
13 22839.007813 ntask sched 12.000000
13 22839.033203 ntask sched 13.000000
10 22839.041016 MS MEMNODE0 No
19 22839.041016 L p 4000000 MEMNODE0 com_284
10 22839.044922 MS MEMNODE2 Co
18 22839.044922 L p 4000000 MEMNODE0 com_286
10 22839.044922 MS MEMNODE0 Co
18 22839.044922 L p 4000000 MEMNODE1 com_287
10 22839.052735 MS MEMNODE0 CoA
10 22839.052735 MS MEMNODE2 CoA
10 22840.332031 MS MEMNODE2 No
19 22840.332031 L p 2273874960 MEMNODE2 com_2273874768
10 22840.529297 MS MEMNODE0 No
19 22840.529297 L p 2273874968 MEMNODE0 com_2273874768
10 22840.529297 MS MEMNODE2 No
19 22840.529297 L p 4000000 MEMNODE2 com_286
10 22840.533203 S 680 B
10 22840.535157 S 680 chol_model_22
13 22840.537110 ntask sched 12.000000
10 22840.537110 S 679 Fi
10 22840.539063 S 679 B
10 22840.572266 S 679 chol_model_21
10 22843.830078 S 65 B
10 22843.830078 S 680 Po
10 22843.832031 S 680 B
13 22843.841797 ntask sched 11.000000
10 22843.841797 S 680 Fi
10 22848.880860 S 64 B
10 22848.882813 S 679 Po
10 22848.882813 S 679 B
13 22848.919922 ntask sched 12.000000
13 22848.947266 ntask sched 13.000000
13 22848.974610 ntask sched 14.000000
13 22849.003907 ntask sched 15.000000
13 22849.031250 ntask sched 16.000000
13 22849.058594 ntask sched 17.000000
10 22849.066407 MS MEMNODE0 No
19 22849.066407 L p 4000000 MEMNODE0 com_287
10 22849.068360 MS MEMNODE0 Co
18 22849.068360 L p 4000000 MEMNODE1 com_288
10 22849.068360 MS MEMNODE2 Co
18 22849.068360 L p 4000000 MEMNODE0 com_289
10 22849.076172 MS MEMNODE0 CoA
10 22849.078125 MS MEMNODE2 CoA
10 22850.371094 MS MEMNODE2 No
19 22850.371094 L p 2273874960 MEMNODE2 com_2273874768
10 22850.568360 MS MEMNODE2 No
19 22850.568360 L p 4000000 MEMNODE2 com_289
10 22850.572266 S 680 B
10 22850.572266 S 680 chol_model_22
10 22850.625000 MS MEMNODE0 No
19 22850.625000 L p 2273874960 MEMNODE0 com_2273874768
10 22850.667969 MS MEMNODE0 No
19 22850.667969 L p 4000000 MEMNODE0 com_288
10 22853.810547 S 65 B
10 22853.810547 S 680 Po
10 22853.812500 S 680 B
10 22853.820313 MS MEMNODE2 Co
18 22853.820313 L p 4000000 MEMNODE0 com_290
10 22853.828125 MS MEMNODE2 CoA
10 22855.074219 MS MEMNODE2 No
19 22855.074219 L p 2273874960 MEMNODE2 com_2273874768
13 22855.080078 ntask sched 16.000000
10 22855.080078 S 680 Fi
10 22855.269531 MS MEMNODE2 No
19 22855.269531 L p 4000000 MEMNODE2 com_290
10 22855.271485 S 680 B
10 22855.271485 S 680 chol_model_22
10 22858.564453 S 65 B
10 22858.566407 S 680 Po
10 22858.568360 S 680 B
13 22858.576172 ntask sched 15.000000
10 22858.578125 S 680 Fi
10 22858.580078 S 680 B
10 22858.580078 S 680 chol_model_22
10 22861.824219 S 65 B
10 22861.824219 S 680 Po
10 22861.826172 S 680 B
13 22861.833985 ntask sched 14.000000
10 22861.835938 S 680 Fi
10 22861.837891 S 680 B
10 22861.837891 S 680 chol_model_22
10 22865.130860 S 65 B
10 22865.132813 S 680 Po
10 22865.134766 S 680 B
13 22865.140625 ntask sched 13.000000
10 22865.142578 S 680 Fi
10 22865.144531 S 680 B
10 22865.144531 S 680 chol_model_22
10 22868.441407 S 65 B
10 22868.443360 S 680 Po
10 22868.445313 S 680 B
13 22868.451172 ntask sched 12.000000
10 22868.453125 S 680 Fi
10 22868.455078 S 680 B
10 22868.455078 S 680 chol_model_22
10 22871.658203 S 65 B
10 22871.658203 S 680 Po
10 22871.660157 S 680 B
13 22871.669922 ntask sched 11.000000
10 22871.671875 S 680 Fi
10 22871.673828 S 680 B
10 22871.673828 S 680 chol_model_22
10 22874.921875 S 65 B
10 22874.923828 S 680 Po
10 22874.925781 S 680 B
13 22874.931641 ntask sched 10.000000
10 22874.933594 S 680 Fi
10 22874.935547 S 680 B
10 22874.935547 S 680 chol_model_22
10 22878.222657 S 65 B
10 22878.224610 S 680 Po
10 22878.224610 S 680 B
13 22878.232422 ntask sched 9.000000
10 22878.234375 S 680 Fi
10 22878.236328 S 680 B
10 22878.236328 S 680 chol_model_22
10 22881.478516 S 65 B
10 22881.478516 S 680 Po
10 22881.480469 S 680 B
13 22881.488281 ntask sched 8.000000
10 22881.488281 S 680 Fi
10 22881.492188 S 680 B
10 22881.492188 S 680 chol_model_22
10 22884.796875 S 65 B
10 22884.798828 S 680 Po
10 22884.800781 S 680 B
13 22884.808594 ntask sched 7.000000
10 22884.810547 S 680 Fi
10 22884.810547 S 680 B
10 22884.812500 S 680 chol_model_22
10 22888.136719 S 65 B
10 22888.138672 S 680 Po
10 22888.140625 S 680 B
13 22888.148438 ntask sched 6.000000
10 22888.148438 S 680 Fi
10 22888.150391 S 680 B
10 22888.152344 S 680 chol_model_22
10 22891.380860 S 65 B
10 22891.380860 S 680 Po
10 22891.382813 S 680 B
13 22891.388672 ntask sched 5.000000
10 22891.390625 S 680 Fi
10 22891.392578 S 680 B
10 22891.394531 S 680 chol_model_22
10 22894.701172 S 65 B
10 22894.703125 S 680 Po
10 22894.703125 S 680 B
13 22894.712891 ntask sched 4.000000
10 22894.714844 S 680 Fi
10 22894.716797 S 680 B
10 22894.716797 S 680 chol_model_22
10 22898.050781 S 65 B
10 22898.050781 S 680 Po
10 22898.052735 S 680 B
13 22898.060547 ntask sched 3.000000
10 22898.062500 S 680 Fi
10 22898.064453 S 680 B
10 22898.064453 S 680 chol_model_22
10 22901.363281 S 65 B
10 22901.363281 S 680 Po
10 22901.365235 S 680 B
13 22901.373047 ntask sched 2.000000
10 22901.375000 S 680 Fi
10 22901.376953 S 680 B
10 22901.378907 S 680 chol_model_22
10 22904.593750 S 65 B
10 22904.593750 S 680 Po
10 22904.595703 S 680 B
13 22904.603516 ntask sched 1.000000
10 22904.605469 S 680 Fi
10 22904.605469 S 680 B
10 22904.609375 S 680 chol_model_21
10 22912.826172 S 65 B
10 22912.828125 S 680 Po
10 22912.830078 S 680 B
13 22912.873047 ntask sched 2.000000
13 22912.902344 ntask sched 3.000000
13 22912.933594 ntask sched 4.000000
13 22912.962891 ntask sched 5.000000
13 22912.992188 ntask sched 6.000000
13 22913.023438 ntask sched 7.000000
13 22913.050781 ntask sched 8.000000
13 22913.056641 ntask sched 7.000000
10 22913.056641 S 680 Fi
10 22913.058594 S 680 B
10 22913.058594 S 680 chol_model_22
10 22916.361328 S 65 B
10 22916.361328 S 680 Po
10 22916.363281 S 680 B
13 22916.371094 ntask sched 6.000000
10 22916.373047 S 680 Fi
10 22916.373047 S 680 B
10 22916.375000 S 680 chol_model_22
10 22919.681641 S 65 B
10 22919.683594 S 680 Po
10 22919.685547 S 680 B
13 22919.691407 ntask sched 5.000000
10 22919.693360 S 680 Fi
10 22919.695313 S 680 B
10 22919.695313 S 680 chol_model_22
10 22923.027344 S 65 B
10 22923.027344 S 680 Po
10 22923.029297 S 680 B
13 22923.035157 ntask sched 4.000000
10 22923.037110 S 680 Fi
10 22923.039063 S 680 B
10 22923.039063 S 680 chol_model_22
10 22926.312500 S 65 B
10 22926.314453 S 680 Po
10 22926.314453 S 680 B
13 22926.322266 ntask sched 3.000000
10 22926.324219 S 680 Fi
10 22926.326172 S 680 B
10 22926.326172 S 680 chol_model_22
10 22929.558594 S 65 B
10 22929.558594 S 680 Po
10 22929.560547 S 680 B
13 22929.568360 ntask sched 2.000000
10 22929.570313 S 680 Fi
10 22929.572266 S 680 B
10 22929.572266 S 680 chol_model_22
10 22932.804688 S 65 B
10 22932.806641 S 680 Po
10 22932.806641 S 680 B
13 22932.814453 ntask sched 1.000000
10 22932.816407 S 680 Fi
10 22932.816407 S 680 B
10 22932.818360 S 680 chol_model_22
10 22936.027344 S 65 B
10 22936.027344 S 680 Po
10 22936.029297 S 680 B
13 22936.037110 ntask sched 0.000000
10 22936.039063 S 680 Fi
10 22936.041016 S 680 B
10 22936.044922 S 680 chol_model_21
10 22944.255860 S 65 B
10 22944.257813 S 680 Po
10 22944.259766 S 680 B
13 22944.296875 ntask sched 1.000000
13 22944.326172 ntask sched 2.000000
13 22944.357422 ntask sched 3.000000
13 22944.386719 ntask sched 4.000000
13 22944.416016 ntask sched 5.000000
13 22944.453125 ntask sched 6.000000
13 22944.482422 ntask sched 7.000000
13 22944.513672 ntask sched 8.000000
13 22944.519531 ntask sched 7.000000
10 22944.519531 S 680 Fi
10 22944.521485 S 680 B
10 22944.521485 S 680 chol_model_22
10 22947.742188 S 65 B
10 22947.742188 S 680 Po
10 22947.744141 S 680 B
13 22947.753907 ntask sched 6.000000
10 22947.755860 S 680 Fi
10 22947.757813 S 680 B
10 22947.757813 S 680 chol_model_22
10 22950.988281 S 65 B
10 22950.988281 S 680 Po
10 22950.990235 S 680 B
13 22951.000000 ntask sched 5.000000
10 22951.000000 S 680 Fi
10 22951.003907 S 680 B
10 22951.003907 S 680 chol_model_22
10 22954.304688 S 65 B
10 22954.304688 S 680 Po
10 22954.306641 S 680 B
13 22954.312500 ntask sched 4.000000
10 22954.314453 S 680 Fi
10 22954.316407 S 680 B
10 22954.316407 S 680 chol_model_22
10 22957.605469 S 65 B
10 22957.607422 S 680 Po
10 22957.609375 S 680 B
13 22957.615235 ntask sched 3.000000
10 22957.617188 S 680 Fi
10 22957.619141 S 680 B
10 22957.619141 S 680 chol_model_22
10 22960.916016 S 65 B
10 22960.917969 S 680 Po
10 22960.919922 S 680 B
13 22960.927735 ntask sched 2.000000
10 22960.927735 S 680 Fi
10 22960.929688 S 680 B
10 22960.929688 S 680 chol_model_22
10 22964.154297 S 65 B
10 22964.156250 S 680 Po
10 22964.156250 S 680 B
13 22964.164063 ntask sched 1.000000
10 22964.166016 S 680 Fi
10 22964.167969 S 680 B
10 22964.169922 S 680 chol_model_22
10 22967.482422 S 65 B
10 22967.484375 S 680 Po
10 22967.484375 S 680 B
13 22967.492188 ntask sched 0.000000
10 22967.494141 S 680 Fi
10 22967.494141 S 680 B
10 22967.496094 S 680 chol_model_22
10 22970.708985 S 65 B
10 22970.710938 S 680 Po
10 22970.710938 S 680 B
13 22970.746094 ntask sched 1.000000
13 22970.750000 ntask sched 0.000000
10 22970.751953 S 680 Fi
10 22970.753907 S 680 B
10 22970.755860 S 680 chol_model_11
10 23044.195313 S 65 B
10 23044.197266 S 680 Po
10 23044.199219 S 680 B
13 23044.236328 ntask sched 1.000000
13 23044.265625 ntask sched 2.000000
13 23044.298828 ntask sched 3.000000
13 23044.306641 ntask sched 2.000000
10 23044.308594 S 679 Fi
13 23044.332031 ntask sched 3.000000
13 23044.359375 ntask sched 4.000000
13 23044.388672 ntask sched 5.000000
13 23044.416016 ntask sched 6.000000
10 23044.419922 MS MEMNODE0 Co
18 23044.419922 L p 4000000 MEMNODE2 com_291
10 23044.427735 MS MEMNODE0 CoA
10 23046.460938 MS MEMNODE0 No
19 23046.460938 L p 2273874960 MEMNODE0 com_2273874768
10 23046.466797 MS MEMNODE0 Co
18 23046.466797 L p 4000000 MEMNODE2 com_292
10 23046.474610 MS MEMNODE0 CoA
10 23048.492188 MS MEMNODE0 No
19 23048.492188 L p 2273874960 MEMNODE0 com_2273874768
10 23048.498047 MS MEMNODE0 Co
18 23048.498047 L p 4000000 MEMNODE2 com_293
10 23048.505860 MS MEMNODE0 CoA
10 23050.523438 MS MEMNODE0 No
19 23050.523438 L p 2273874960 MEMNODE0 com_2273874768
10 23050.529297 MS MEMNODE0 Co
18 23050.529297 L p 4000000 MEMNODE2 com_294
10 23050.537110 MS MEMNODE0 CoA
10 23052.558594 MS MEMNODE0 No
19 23052.558594 L p 2273874960 MEMNODE0 com_2273874768
13 23052.566407 ntask sched 5.000000
10 23052.568360 S 680 Fi
10 23052.570313 S 680 B
10 23052.601563 S 680 chol_model_21
10 23060.904297 S 65 B
10 23060.906250 S 680 Po
10 23060.908203 S 680 B
13 23060.945313 ntask sched 6.000000
10 23060.953125 MS MEMNODE0 No
19 23060.953125 L p 4000000 MEMNODE0 com_294
10 23060.955078 MS MEMNODE1 A
10 23060.957031 MS MEMNODE0 No
19 23060.957031 L p 4000000 MEMNODE0 com_293
10 23060.958985 MS MEMNODE0 No
19 23060.958985 L p 4000000 MEMNODE0 com_292
10 23060.960938 MS MEMNODE0 No
19 23060.960938 L p 4000000 MEMNODE0 com_291
13 23060.962891 ntask sched 5.000000
10 23060.964844 S 680 Fi
10 23060.964844 S 680 B
10 23060.966797 S 680 chol_model_22
10 23061.085938 MS MEMNODE1 No
10 23061.087891 MS MEMNODE1 Co
18 23061.087891 L p 4000000 MEMNODE0 com_295
10 23061.095703 MS MEMNODE1 CoA
10 23062.222657 MS MEMNODE1 No
19 23062.222657 L p 2273874960 MEMNODE1 com_2273874768
10 23062.228516 MS MEMNODE1 A
10 23062.355469 MS MEMNODE1 No
10 23062.357422 MS MEMNODE1 Co
18 23062.357422 L p 4000000 MEMNODE0 com_296
10 23062.363281 MS MEMNODE1 CoA
10 23063.513672 MS MEMNODE1 No
19 23063.513672 L p 2273874960 MEMNODE1 com_2273874768
10 23063.519531 MS MEMNODE1 A
10 23063.640625 MS MEMNODE1 No
10 23063.642578 MS MEMNODE1 Co
18 23063.642578 L p 4000000 MEMNODE0 com_297
10 23063.648438 MS MEMNODE1 CoA
10 23064.300781 S 65 B
10 23064.300781 S 680 Po
10 23064.302735 S 680 B
13 23064.310547 ntask sched 4.000000
10 23064.312500 S 680 Fi
10 23064.312500 S 680 B
10 23064.316407 S 680 chol_model_21
10 23064.802735 MS MEMNODE1 No
19 23064.802735 L p 2273874960 MEMNODE1 com_2273874768
10 23064.806641 MS MEMNODE1 A
10 23064.931641 MS MEMNODE1 No
10 23064.933594 MS MEMNODE1 Co
18 23064.933594 L p 4000000 MEMNODE0 com_298
10 23064.939453 MS MEMNODE1 CoA
10 23066.095703 MS MEMNODE1 No
19 23066.095703 L p 2273874960 MEMNODE1 com_2273874768
10 23066.134766 MS MEMNODE1 No
19 23066.134766 L p 4000000 MEMNODE1 com_297
10 23066.158203 MS MEMNODE1 No
19 23066.158203 L p 4000000 MEMNODE1 com_296
10 23066.183594 MS MEMNODE1 No
19 23066.183594 L p 4000000 MEMNODE1 com_295
10 23066.285157 MS MEMNODE1 No
19 23066.285157 L p 4000000 MEMNODE1 com_298
10 23066.287110 S 679 B
10 23066.291016 S 679 chol_model_21
10 23072.589844 S 65 B
10 23072.591797 S 680 Po
10 23072.593750 S 680 B
13 23072.626953 ntask sched 5.000000
13 23072.656250 ntask sched 6.000000
13 23072.660157 ntask sched 5.000000
10 23072.662110 S 680 Fi
10 23072.664063 S 680 B
10 23072.664063 S 680 chol_model_22
10 23074.621094 S 64 B
10 23074.625000 S 679 Po
10 23074.628907 S 679 B
13 23074.669922 ntask sched 6.000000
13 23074.699219 ntask sched 7.000000
13 23074.730469 ntask sched 8.000000
10 23074.736328 MS MEMNODE0 Co
18 23074.736328 L p 4000000 MEMNODE1 com_299
10 23074.742188 MS MEMNODE0 CoA
10 23076.003907 S 65 B
10 23076.005860 S 680 Po
10 23076.007813 S 680 B
13 23076.015625 ntask sched 7.000000
10 23076.015625 S 680 Fi
10 23076.222657 MS MEMNODE0 No
19 23076.222657 L p 2273874960 MEMNODE0 com_2273874768
13 23076.230469 ntask sched 6.000000
10 23076.232422 S 679 Fi
10 23076.234375 S 679 B
10 23076.265625 S 679 chol_model_21
10 23084.570313 S 64 B
10 23084.572266 S 679 Po
10 23084.574219 S 679 B
13 23084.609375 ntask sched 7.000000
13 23084.638672 ntask sched 8.000000
13 23084.666016 ntask sched 9.000000
13 23084.695313 ntask sched 10.000000
10 23084.701172 MS MEMNODE0 No
19 23084.701172 L p 4000000 MEMNODE0 com_299
10 23084.705078 MS MEMNODE2 Co
18 23084.705078 L p 4000000 MEMNODE0 com_300
10 23084.705078 MS MEMNODE0 Co
18 23084.705078 L p 4000000 MEMNODE1 com_301
10 23084.712891 MS MEMNODE0 CoA
10 23084.714844 MS MEMNODE2 CoA
10 23086.000000 MS MEMNODE2 No
19 23086.000000 L p 2273874960 MEMNODE2 com_2273874768
10 23086.177735 MS MEMNODE0 No
19 23086.177735 L p 2273874968 MEMNODE0 com_2273874768
13 23086.185547 ntask sched 9.000000
10 23086.187500 S 679 Fi
10 23086.187500 S 679 B
10 23086.195313 MS MEMNODE2 No
19 23086.195313 L p 4000000 MEMNODE2 com_300
10 23086.197266 S 680 B
10 23086.199219 S 680 chol_model_22
10 23086.220703 S 679 chol_model_21
10 23089.507813 S 65 B
10 23089.507813 S 680 Po
10 23089.509766 S 680 B
13 23089.517578 ntask sched 8.000000
10 23089.519531 S 680 Fi
10 23094.535157 S 64 B
10 23094.535157 S 679 Po
10 23094.537110 S 679 B
13 23094.574219 ntask sched 9.000000
13 23094.601563 ntask sched 10.000000
13 23094.630860 ntask sched 11.000000
13 23094.656250 ntask sched 12.000000
13 23094.685547 ntask sched 13.000000
10 23094.691407 MS MEMNODE0 No
19 23094.691407 L p 4000000 MEMNODE0 com_301
10 23094.693360 MS MEMNODE0 Co
18 23094.693360 L p 4000000 MEMNODE1 com_302
10 23094.695313 MS MEMNODE2 Co
18 23094.695313 L p 4000000 MEMNODE0 com_303
10 23094.701172 MS MEMNODE0 CoA
10 23094.701172 MS MEMNODE2 CoA
10 23095.990235 MS MEMNODE2 No
19 23095.990235 L p 2273874960 MEMNODE2 com_2273874768
10 23096.185547 MS MEMNODE2 No
19 23096.185547 L p 4000000 MEMNODE2 com_303
10 23096.187500 S 680 B
10 23096.189453 S 680 chol_model_22
10 23096.259766 MS MEMNODE0 No
19 23096.259766 L p 2273874960 MEMNODE0 com_2273874768
10 23096.302735 MS MEMNODE0 No
19 23096.302735 L p 4000000 MEMNODE0 com_302
10 23099.521485 S 65 B
10 23099.521485 S 680 Po
10 23099.523438 S 680 B
10 23099.531250 MS MEMNODE2 Co
18 23099.531250 L p 4000000 MEMNODE0 com_304
10 23099.537110 MS MEMNODE2 CoA
10 23100.777344 MS MEMNODE2 No
19 23100.777344 L p 2273874960 MEMNODE2 com_2273874768
13 23100.785157 ntask sched 12.000000
10 23100.787110 S 680 Fi
10 23100.976563 MS MEMNODE2 No
19 23100.976563 L p 4000000 MEMNODE2 com_304
10 23100.978516 S 680 B
10 23100.980469 S 680 chol_model_22
10 23104.304688 S 65 B
10 23104.306641 S 680 Po
10 23104.308594 S 680 B
13 23104.316407 ntask sched 11.000000
10 23104.318360 S 680 Fi
10 23104.320313 S 680 B
10 23104.320313 S 680 chol_model_22
10 23107.550781 S 65 B
10 23107.550781 S 680 Po
10 23107.552735 S 680 B
13 23107.560547 ntask sched 10.000000
10 23107.562500 S 680 Fi
10 23107.564453 S 680 B
10 23107.566407 S 680 chol_model_22
10 23110.919922 S 65 B
10 23110.921875 S 680 Po
10 23110.923828 S 680 B
13 23110.931641 ntask sched 9.000000
10 23110.931641 S 680 Fi
10 23110.933594 S 680 B
10 23110.933594 S 680 chol_model_22
10 23114.164063 S 65 B
10 23114.164063 S 680 Po
10 23114.166016 S 680 B
13 23114.175781 ntask sched 8.000000
10 23114.175781 S 680 Fi
10 23114.177735 S 680 B
10 23114.179688 S 680 chol_model_22
10 23117.423828 S 65 B
10 23117.423828 S 680 Po
10 23117.425781 S 680 B
13 23117.433594 ntask sched 7.000000
10 23117.439453 S 680 Fi
10 23117.441407 S 680 B
10 23117.443360 S 680 chol_model_22
10 23120.669922 S 65 B
10 23120.669922 S 680 Po
10 23120.671875 S 680 B
13 23120.679688 ntask sched 6.000000
10 23120.681641 S 680 Fi
10 23120.683594 S 680 B
10 23120.683594 S 680 chol_model_22
10 23124.019531 S 65 B
10 23124.021485 S 680 Po
10 23124.021485 S 680 B
13 23124.031250 ntask sched 5.000000
10 23124.031250 S 680 Fi
10 23124.033203 S 680 B
10 23124.035157 S 680 chol_model_22
10 23127.363281 S 65 B
10 23127.363281 S 680 Po
10 23127.365235 S 680 B
13 23127.373047 ntask sched 4.000000
10 23127.375000 S 680 Fi
10 23127.376953 S 680 B
10 23127.378907 S 680 chol_model_22
10 23130.591797 S 65 B
10 23130.593750 S 680 Po
10 23130.595703 S 680 B
13 23130.603516 ntask sched 3.000000
10 23130.603516 S 680 Fi
10 23130.605469 S 680 B
10 23130.607422 S 680 chol_model_22
10 23133.820313 S 65 B
10 23133.820313 S 680 Po
10 23133.822266 S 680 B
13 23133.830078 ntask sched 2.000000
10 23133.832031 S 680 Fi
10 23133.835938 S 680 B
10 23133.835938 S 680 chol_model_22
10 23137.042969 S 65 B
10 23137.044922 S 680 Po
10 23137.044922 S 680 B
13 23137.052735 ntask sched 1.000000
10 23137.054688 S 680 Fi
10 23137.056641 S 680 B
10 23137.060547 S 680 chol_model_21
10 23145.339844 S 65 B
10 23145.341797 S 680 Po
10 23145.341797 S 680 B
13 23145.380860 ntask sched 2.000000
13 23145.410157 ntask sched 3.000000
13 23145.445313 ntask sched 4.000000
13 23145.476563 ntask sched 5.000000
13 23145.507813 ntask sched 6.000000
13 23145.537110 ntask sched 7.000000
13 23145.544922 ntask sched 6.000000
10 23145.544922 S 680 Fi
10 23145.546875 S 680 B
10 23145.548828 S 680 chol_model_22
10 23148.841797 S 65 B
10 23148.841797 S 680 Po
10 23148.843750 S 680 B
13 23148.851563 ntask sched 5.000000
10 23148.853516 S 680 Fi
10 23148.855469 S 680 B
10 23148.855469 S 680 chol_model_22
10 23152.138672 S 65 B
10 23152.140625 S 680 Po
10 23152.140625 S 680 B
13 23152.148438 ntask sched 4.000000
10 23152.148438 S 680 Fi
10 23152.150391 S 680 B
10 23152.152344 S 680 chol_model_22
10 23155.470703 S 65 B
10 23155.472657 S 680 Po
10 23155.474610 S 680 B
13 23155.482422 ntask sched 3.000000
10 23155.482422 S 680 Fi
10 23155.484375 S 680 B
10 23155.484375 S 680 chol_model_22
10 23158.810547 S 65 B
10 23158.810547 S 680 Po
10 23158.812500 S 680 B
13 23158.820313 ntask sched 2.000000
10 23158.822266 S 680 Fi
10 23158.824219 S 680 B
10 23158.824219 S 680 chol_model_22
10 23162.148438 S 65 B
10 23162.150391 S 680 Po
10 23162.150391 S 680 B
13 23162.158203 ntask sched 1.000000
10 23162.160157 S 680 Fi
10 23162.160157 S 680 B
10 23162.162110 S 680 chol_model_22
10 23165.384766 S 65 B
10 23165.384766 S 680 Po
10 23165.386719 S 680 B
13 23165.394531 ntask sched 0.000000
10 23165.396485 S 680 Fi
10 23165.396485 S 680 B
10 23165.400391 S 680 chol_model_21
10 23173.617188 S 65 B
10 23173.619141 S 680 Po
10 23173.619141 S 680 B
13 23173.656250 ntask sched 1.000000
13 23173.687500 ntask sched 2.000000
13 23173.716797 ntask sched 3.000000
13 23173.746094 ntask sched 4.000000
13 23173.777344 ntask sched 5.000000
13 23173.806641 ntask sched 6.000000
13 23173.839844 ntask sched 7.000000
13 23173.843750 ntask sched 6.000000
10 23173.845703 S 680 Fi
10 23173.847657 S 680 B
10 23173.847657 S 680 chol_model_22
10 23177.175781 S 65 B
10 23177.175781 S 680 Po
10 23177.177735 S 680 B
13 23177.185547 ntask sched 5.000000
10 23177.187500 S 680 Fi
10 23177.189453 S 680 B
10 23177.189453 S 680 chol_model_22
10 23180.417969 S 65 B
10 23180.419922 S 680 Po
10 23180.419922 S 680 B
13 23180.427735 ntask sched 4.000000
10 23180.429688 S 680 Fi
10 23180.431641 S 680 B
10 23180.431641 S 680 chol_model_22
10 23183.746094 S 65 B
10 23183.748047 S 680 Po
10 23183.750000 S 680 B
13 23183.757813 ntask sched 3.000000
10 23183.759766 S 680 Fi
10 23183.759766 S 680 B
10 23183.761719 S 680 chol_model_22
10 23187.082031 S 65 B
10 23187.082031 S 680 Po
10 23187.085938 S 680 B
13 23187.091797 ntask sched 2.000000
10 23187.093750 S 680 Fi
10 23187.095703 S 680 B
10 23187.095703 S 680 chol_model_22
10 23190.410157 S 65 B
10 23190.410157 S 680 Po
10 23190.412110 S 680 B
13 23190.419922 ntask sched 1.000000
10 23190.421875 S 680 Fi
10 23190.423828 S 680 B
10 23190.423828 S 680 chol_model_22
10 23193.662110 S 65 B
10 23193.662110 S 680 Po
10 23193.664063 S 680 B
13 23193.671875 ntask sched 0.000000
10 23193.673828 S 680 Fi
10 23193.673828 S 680 B
10 23193.675781 S 680 chol_model_22
10 23196.884766 S 65 B
10 23196.884766 S 680 Po
10 23196.886719 S 680 B
13 23196.921875 ntask sched 1.000000
10 23196.925781 MS MEMNODE0 Co
18 23196.925781 L p 4000000 MEMNODE2 com_305
10 23196.935547 MS MEMNODE0 CoA
13 23196.939453 ntask sched 0.000000
10 23196.941407 S 681 Fi
10 23198.958985 MS MEMNODE0 No
19 23198.958985 L p 2273874960 MEMNODE0 com_2273874768
10 23199.029297 MS MEMNODE0 No
19 23199.029297 L p 4000000 MEMNODE0 com_305
10 23199.044922 S 681 B
10 23199.046875 S 681 chol_model_11
10 23266.896485 S 0 B
10 23266.898438 S 681 Po
10 23266.900391 S 681 B
13 23266.937500 ntask sched 1.000000
10 23266.937500 MS MEMNODE2 Co
18 23266.937500 L p 4000000 MEMNODE0 com_306
10 23266.951172 MS MEMNODE2 CoA
10 23268.091797 MS MEMNODE2 No
19 23268.091797 L p 2273874960 MEMNODE2 com_2273874768
13 23268.097657 ntask sched 0.000000
10 23268.099610 S 680 Fi
13 23268.148438 ntask sched 1.000000
13 23268.177735 ntask sched 2.000000
10 23268.179688 MS MEMNODE1 A
10 23268.314453 MS MEMNODE1 No
10 23268.316407 MS MEMNODE1 Co
18 23268.316407 L p 4000000 MEMNODE0 com_307
10 23268.324219 MS MEMNODE1 CoA
10 23269.525391 MS MEMNODE1 No
19 23269.525391 L p 2273874960 MEMNODE1 com_2273874768
13 23269.531250 ntask sched 1.000000
10 23269.533203 S 679 Fi
10 23269.562500 MS MEMNODE2 No
19 23269.562500 L p 4000000 MEMNODE2 com_306
10 23269.564453 MS MEMNODE0 Co
18 23269.564453 L p 4000000 MEMNODE2 com_308
10 23269.570313 MS MEMNODE0 CoA
13 23269.607422 ntask sched 2.000000
13 23269.660157 ntask sched 3.000000
13 23269.687500 ntask sched 4.000000
10 23269.734375 MS MEMNODE1 No
19 23269.734375 L p 4000000 MEMNODE1 com_307
10 23271.605469 MS MEMNODE0 No
19 23271.605469 L p 0 MEMNODE0 com_0
10 23271.613281 S 680 B
10 23271.646485 S 680 chol_model_21
10 23279.853516 S 65 B
10 23279.855469 S 680 Po
10 23279.857422 S 680 B
13 23279.892578 ntask sched 5.000000
10 23279.902344 MS MEMNODE0 No
19 23279.902344 L p 4000000 MEMNODE0 com_308
10 23279.904297 MS MEMNODE1 A
10 23279.906250 MS MEMNODE0 Co
18 23279.906250 L p 4000000 MEMNODE2 com_309
10 23279.910157 MS MEMNODE0 CoA
10 23280.037110 MS MEMNODE1 No
10 23280.039063 MS MEMNODE1 Co
18 23280.039063 L p 4000000 MEMNODE0 com_310
10 23280.044922 MS MEMNODE1 CoA
10 23281.226563 MS MEMNODE1 No
19 23281.226563 L p 2273874960 MEMNODE1 com_2273874768
10 23281.421875 MS MEMNODE1 No
19 23281.421875 L p 4000000 MEMNODE1 com_310
10 23281.421875 S 679 B
10 23281.427735 S 679 chol_model_21
10 23281.953125 MS MEMNODE0 No
19 23281.953125 L p 2273874960 MEMNODE0 com_2273874768
13 23281.960938 ntask sched 4.000000
10 23281.960938 S 680 Fi
10 23281.962891 S 680 B
10 23281.964844 S 680 chol_model_22
10 23285.228516 S 65 B
10 23285.230469 S 680 Po
10 23285.230469 S 680 B
13 23285.265625 ntask sched 5.000000
10 23285.269531 MS MEMNODE0 Co
18 23285.269531 L p 4000000 MEMNODE2 com_311
13 23285.273438 ntask sched 4.000000
10 23285.275391 S 681 Fi
10 23285.279297 MS MEMNODE0 CoA
10 23287.330078 MS MEMNODE0 No
19 23287.330078 L p 2273874960 MEMNODE0 com_2273874768
10 23287.332031 MS MEMNODE0 No
19 23287.332031 L p 4000000 MEMNODE0 com_309
13 23287.335938 ntask sched 3.000000
10 23287.337891 S 680 Fi
10 23287.337891 S 680 B
10 23287.367188 S 680 chol_model_21
10 23287.406250 MS MEMNODE0 No
19 23287.406250 L p 4000000 MEMNODE0 com_311
10 23287.410157 S 681 B
10 23287.410157 S 681 chol_model_11
10 23289.742188 S 64 B
10 23289.744141 S 679 Po
10 23289.746094 S 679 B
13 23289.785157 ntask sched 4.000000
13 23289.812500 ntask sched 5.000000
10 23289.818360 MS MEMNODE1 A
10 23289.941407 MS MEMNODE1 No
10 23289.943360 MS MEMNODE1 Co
18 23289.943360 L p 4000000 MEMNODE0 com_312
10 23289.949219 MS MEMNODE1 CoA
10 23291.103516 MS MEMNODE1 No
19 23291.103516 L p 2273874960 MEMNODE1 com_2273874768
10 23291.107422 MS MEMNODE0 Co
18 23291.107422 L p 4000000 MEMNODE1 com_313
10 23291.113281 MS MEMNODE0 CoA
10 23292.843750 MS MEMNODE0 No
19 23292.843750 L p 2273874960 MEMNODE0 com_2273874768
13 23292.851563 ntask sched 4.000000
10 23292.853516 S 679 Fi
10 23292.886719 MS MEMNODE1 No
19 23292.886719 L p 4000000 MEMNODE1 com_312
10 23292.888672 S 679 B
10 23292.912110 S 679 chol_model_21
10 23295.605469 S 65 B
10 23295.607422 S 680 Po
10 23295.609375 S 680 B
13 23295.644531 ntask sched 5.000000
13 23295.673828 ntask sched 6.000000
13 23295.703125 ntask sched 7.000000
13 23295.708985 ntask sched 6.000000
10 23295.710938 S 680 Fi
10 23295.710938 S 680 B
10 23295.712891 S 680 chol_model_22
10 23298.933594 S 65 B
10 23298.933594 S 680 Po
10 23298.935547 S 680 B
13 23298.943360 ntask sched 5.000000
10 23298.943360 S 680 Fi
10 23301.232422 S 64 B
10 23301.232422 S 679 Po
10 23301.234375 S 679 B
13 23301.271485 ntask sched 6.000000
13 23301.298828 ntask sched 7.000000
13 23301.324219 ntask sched 8.000000
13 23301.351563 ntask sched 9.000000
10 23301.359375 MS MEMNODE0 No
19 23301.359375 L p 4000000 MEMNODE0 com_313
10 23301.363281 MS MEMNODE2 Co
18 23301.363281 L p 4000000 MEMNODE0 com_314
10 23301.363281 MS MEMNODE0 Co
18 23301.363281 L p 4000000 MEMNODE1 com_315
10 23301.367188 MS MEMNODE0 CoA
10 23301.371094 MS MEMNODE2 CoA
10 23302.664063 MS MEMNODE2 No
19 23302.664063 L p 2273874960 MEMNODE2 com_2273874768
10 23302.861328 MS MEMNODE2 No
19 23302.861328 L p 4000000 MEMNODE2 com_314
10 23302.865235 S 680 B
10 23302.865235 S 680 chol_model_22
10 23302.998047 MS MEMNODE0 No
19 23302.998047 L p 2273874960 MEMNODE0 com_2273874768
10 23303.048828 MS MEMNODE0 No
19 23303.048828 L p 4000000 MEMNODE0 com_315
10 23306.179688 S 65 B
10 23306.179688 S 680 Po
10 23306.181641 S 680 B
10 23306.189453 MS MEMNODE2 Co
18 23306.189453 L p 4000000 MEMNODE0 com_316
10 23306.195313 MS MEMNODE2 CoA
10 23307.443360 MS MEMNODE2 No
19 23307.443360 L p 2273874960 MEMNODE2 com_2273874768
13 23307.449219 ntask sched 8.000000
10 23307.451172 S 680 Fi
10 23307.640625 MS MEMNODE2 No
19 23307.640625 L p 4000000 MEMNODE2 com_316
10 23307.644531 S 680 B
10 23307.646485 S 680 chol_model_22
10 23310.947266 S 65 B
10 23310.947266 S 680 Po
10 23310.949219 S 680 B
13 23310.957031 ntask sched 7.000000
10 23310.960938 S 680 Fi
10 23310.960938 S 680 B
10 23310.962891 S 680 chol_model_22
10 23314.175781 S 65 B
10 23314.177735 S 680 Po
10 23314.177735 S 680 B
13 23314.185547 ntask sched 6.000000
10 23314.187500 S 680 Fi
10 23314.189453 S 680 B
10 23314.189453 S 680 chol_model_22
10 23317.427735 S 65 B
10 23317.429688 S 680 Po
10 23317.429688 S 680 B
13 23317.443360 ntask sched 5.000000
10 23317.445313 S 680 Fi
10 23317.445313 S 680 B
10 23317.447266 S 680 chol_model_22
10 23320.753907 S 65 B
10 23320.753907 S 680 Po
10 23320.755860 S 680 B
13 23320.763672 ntask sched 4.000000
10 23320.763672 S 680 Fi
10 23320.765625 S 680 B
10 23320.767578 S 680 chol_model_22
10 23324.050781 S 65 B
10 23324.052735 S 680 Po
10 23324.052735 S 680 B
13 23324.062500 ntask sched 3.000000
10 23324.064453 S 680 Fi
10 23324.066407 S 680 B
10 23324.066407 S 680 chol_model_22
10 23327.279297 S 65 B
10 23327.281250 S 680 Po
10 23327.283203 S 680 B
13 23327.289063 ntask sched 2.000000
10 23327.291016 S 680 Fi
10 23327.294922 S 680 B
10 23327.294922 S 680 chol_model_22
10 23330.632813 S 65 B
10 23330.634766 S 680 Po
10 23330.636719 S 680 B
13 23330.644531 ntask sched 1.000000
10 23330.646485 S 680 Fi
10 23330.648438 S 680 B
10 23330.652344 S 680 chol_model_21
10 23338.855469 S 65 B
10 23338.857422 S 680 Po
10 23338.859375 S 680 B
13 23338.894531 ntask sched 2.000000
13 23338.923828 ntask sched 3.000000
13 23338.953125 ntask sched 4.000000
13 23338.984375 ntask sched 5.000000
13 23339.013672 ntask sched 6.000000
13 23339.019531 ntask sched 5.000000
10 23339.019531 S 680 Fi
10 23339.021485 S 680 B
10 23339.021485 S 680 chol_model_22
10 23342.363281 S 65 B
10 23342.363281 S 680 Po
10 23342.365235 S 680 B
13 23342.373047 ntask sched 4.000000
10 23342.375000 S 680 Fi
10 23342.376953 S 680 B
10 23342.378907 S 680 chol_model_22
10 23345.578125 S 65 B
10 23345.578125 S 680 Po
10 23345.580078 S 680 B
13 23345.589844 ntask sched 3.000000
10 23345.589844 S 680 Fi
10 23345.591797 S 680 B
10 23345.593750 S 680 chol_model_22
10 23348.910157 S 65 B
10 23348.910157 S 680 Po
10 23348.912110 S 680 B
13 23348.919922 ntask sched 2.000000
10 23348.921875 S 680 Fi
10 23348.921875 S 680 B
10 23348.923828 S 680 chol_model_22
10 23352.173828 S 65 B
10 23352.173828 S 680 Po
10 23352.175781 S 680 B
13 23352.183594 ntask sched 1.000000
10 23352.183594 S 680 Fi
10 23352.185547 S 680 B
10 23352.187500 S 680 chol_model_22
10 23355.320313 S 0 B
10 23355.322266 S 681 Po
10 23355.324219 S 681 B
10 23355.363281 MS MEMNODE1 A
13 23355.363281 ntask sched 2.000000
10 23355.500000 MS MEMNODE1 No
10 23355.501953 MS MEMNODE1 Co
18 23355.501953 L p 4000000 MEMNODE0 com_317
10 23355.509766 MS MEMNODE1 CoA
10 23355.519531 S 65 B
10 23355.521485 S 680 Po
10 23355.521485 S 680 B
10 23355.529297 MS MEMNODE0 Co
18 23355.529297 L p 4000000 MEMNODE2 com_318
10 23355.541016 MS MEMNODE0 CoA
10 23356.765625 MS MEMNODE1 No
19 23356.765625 L p 2273874960 MEMNODE1 com_2273874768
13 23356.771485 ntask sched 1.000000
10 23356.773438 S 679 Fi
13 23356.818360 ntask sched 2.000000
13 23356.867188 ntask sched 3.000000
13 23356.894531 ntask sched 4.000000
10 23356.966797 MS MEMNODE1 No
19 23356.966797 L p 4000000 MEMNODE1 com_317
10 23357.648438 MS MEMNODE0 No
19 23357.648438 L p 0 MEMNODE0 com_0
13 23357.656250 ntask sched 3.000000
10 23357.656250 S 680 Fi
10 23357.662110 MS MEMNODE2 Co
18 23357.662110 L p 4000000 MEMNODE0 com_319
10 23357.671875 MS MEMNODE2 CoA
10 23358.849610 MS MEMNODE2 No
19 23358.849610 L p 2273874960 MEMNODE2 com_2273874768
10 23358.855469 MS MEMNODE0 Co
18 23358.855469 L p 4000000 MEMNODE2 com_320
10 23358.861328 MS MEMNODE0 CoA
10 23361.027344 MS MEMNODE0 No
19 23361.027344 L p 2273874960 MEMNODE0 com_2273874768
10 23361.064453 MS MEMNODE2 No
19 23361.064453 L p 4000000 MEMNODE2 com_319
10 23361.087891 MS MEMNODE0 No
19 23361.087891 L p 4000000 MEMNODE0 com_318
10 23361.089844 MS MEMNODE1 A
10 23361.091797 S 680 B
10 23361.117188 S 680 chol_model_21
10 23361.222657 MS MEMNODE1 No
10 23361.224610 MS MEMNODE1 Co
18 23361.224610 L p 4000000 MEMNODE0 com_321
10 23361.230469 MS MEMNODE1 CoA
10 23362.359375 MS MEMNODE1 No
19 23362.359375 L p 2273874960 MEMNODE1 com_2273874768
10 23362.556641 MS MEMNODE1 No
19 23362.556641 L p 4000000 MEMNODE1 com_321
10 23362.558594 S 679 B
10 23362.562500 S 679 chol_model_21
10 23369.339844 S 65 B
10 23369.341797 S 680 Po
10 23369.343750 S 680 B
13 23369.380860 ntask sched 4.000000
10 23369.386719 MS MEMNODE0 No
19 23369.386719 L p 4000000 MEMNODE0 com_320
13 23369.388672 ntask sched 3.000000
10 23369.390625 S 680 Fi
10 23369.390625 S 680 B
10 23369.392578 S 680 chol_model_22
10 23370.875000 S 64 B
10 23370.876953 S 679 Po
10 23370.878907 S 679 B
13 23370.916016 ntask sched 4.000000
13 23370.947266 ntask sched 5.000000
10 23370.953125 MS MEMNODE1 A
10 23371.072266 MS MEMNODE1 No
10 23371.074219 MS MEMNODE1 Co
18 23371.074219 L p 4000000 MEMNODE0 com_322
10 23371.078125 MS MEMNODE1 CoA
10 23372.214844 MS MEMNODE1 No
19 23372.214844 L p 2273874960 MEMNODE1 com_2273874768
10 23372.218750 MS MEMNODE0 Co
18 23372.218750 L p 4000000 MEMNODE1 com_323
10 23372.224610 MS MEMNODE0 CoA
10 23372.625000 S 65 B
10 23372.625000 S 680 Po
10 23372.628907 S 680 B
13 23372.636719 ntask sched 4.000000
10 23372.636719 S 680 Fi
10 23373.935547 MS MEMNODE0 No
19 23373.935547 L p 2273874960 MEMNODE0 com_2273874768
13 23373.943360 ntask sched 3.000000
10 23373.943360 S 679 Fi
10 23373.976563 MS MEMNODE1 No
19 23373.976563 L p 4000000 MEMNODE1 com_322
10 23373.978516 S 679 B
10 23374.003907 S 679 chol_model_21
10 23382.320313 S 64 B
10 23382.322266 S 679 Po
10 23382.324219 S 679 B
13 23382.359375 ntask sched 4.000000
13 23382.386719 ntask sched 5.000000
13 23382.414063 ntask sched 6.000000
10 23382.423828 MS MEMNODE0 No
19 23382.423828 L p 4000000 MEMNODE0 com_323
10 23382.425781 MS MEMNODE2 Co
18 23382.425781 L p 4000000 MEMNODE0 com_324
10 23382.425781 MS MEMNODE0 Co
18 23382.425781 L p 4000000 MEMNODE1 com_325
10 23382.429688 MS MEMNODE0 CoA
10 23382.433594 MS MEMNODE2 CoA
10 23383.718750 MS MEMNODE2 No
19 23383.718750 L p 2273874960 MEMNODE2 com_2273874768
10 23383.912110 MS MEMNODE2 No
19 23383.912110 L p 4000000 MEMNODE2 com_324
10 23383.916016 S 680 B
10 23383.916016 S 680 chol_model_22
10 23384.035157 MS MEMNODE0 No
19 23384.035157 L p 2273874960 MEMNODE0 com_2273874768
10 23384.078125 MS MEMNODE0 No
19 23384.078125 L p 4000000 MEMNODE0 com_325
10 23387.232422 S 65 B
10 23387.234375 S 680 Po
10 23387.236328 S 680 B
10 23387.244141 MS MEMNODE2 Co
18 23387.244141 L p 4000000 MEMNODE0 com_326
10 23387.250000 MS MEMNODE2 CoA
10 23388.498047 MS MEMNODE2 No
19 23388.498047 L p 2273874960 MEMNODE2 com_2273874768
13 23388.505860 ntask sched 5.000000
10 23388.507813 S 680 Fi
10 23388.695313 MS MEMNODE2 No
19 23388.695313 L p 4000000 MEMNODE2 com_326
10 23388.697266 S 680 B
10 23388.697266 S 680 chol_model_22
10 23391.955078 S 65 B
10 23391.955078 S 680 Po
10 23391.957031 S 680 B
13 23391.966797 ntask sched 4.000000
10 23391.968750 S 680 Fi
10 23391.970703 S 680 B
10 23391.970703 S 680 chol_model_22
10 23395.214844 S 65 B
10 23395.214844 S 680 Po
10 23395.216797 S 680 B
13 23395.226563 ntask sched 3.000000
10 23395.228516 S 680 Fi
10 23395.230469 S 680 B
10 23395.230469 S 680 chol_model_22
10 23398.566407 S 65 B
10 23398.566407 S 680 Po
10 23398.568360 S 680 B
13 23398.576172 ntask sched 2.000000
10 23398.578125 S 680 Fi
10 23398.580078 S 680 B
10 23398.580078 S 680 chol_model_22
10 23401.826172 S 65 B
10 23401.826172 S 680 Po
10 23401.828125 S 680 B
13 23401.837891 ntask sched 1.000000
10 23401.839844 S 680 Fi
10 23401.839844 S 680 B
10 23401.843750 S 680 chol_model_21
10 23410.042969 S 65 B
10 23410.044922 S 680 Po
10 23410.046875 S 680 B
13 23410.082031 ntask sched 2.000000
13 23410.111328 ntask sched 3.000000
13 23410.140625 ntask sched 4.000000
13 23410.173828 ntask sched 5.000000
13 23410.179688 ntask sched 4.000000
10 23410.181641 S 680 Fi
10 23410.183594 S 680 B
10 23410.183594 S 680 chol_model_22
10 23413.505860 S 65 B
10 23413.505860 S 680 Po
10 23413.507813 S 680 B
13 23413.515625 ntask sched 3.000000
10 23413.515625 S 680 Fi
10 23413.517578 S 680 B
10 23413.517578 S 680 chol_model_22
10 23416.744141 S 65 B
10 23416.744141 S 680 Po
10 23416.746094 S 680 B
13 23416.753907 ntask sched 2.000000
10 23416.755860 S 680 Fi
10 23416.755860 S 680 B
10 23416.757813 S 680 chol_model_22
10 23420.085938 S 65 B
10 23420.085938 S 680 Po
10 23420.087891 S 680 B
13 23420.095703 ntask sched 1.000000
10 23420.095703 S 680 Fi
10 23420.097657 S 680 B
10 23420.097657 S 680 chol_model_22
10 23423.388672 S 65 B
10 23423.390625 S 680 Po
10 23423.390625 S 680 B
13 23423.398438 ntask sched 0.000000
10 23423.400391 S 680 Fi
10 23423.400391 S 680 B
10 23423.404297 S 680 chol_model_21
10 23431.605469 S 65 B
10 23431.607422 S 680 Po
10 23431.607422 S 680 B
13 23431.644531 ntask sched 1.000000
13 23431.673828 ntask sched 2.000000
13 23431.703125 ntask sched 3.000000
13 23431.734375 ntask sched 4.000000
13 23431.765625 ntask sched 5.000000
13 23431.794922 ntask sched 6.000000
13 23431.800781 ntask sched 5.000000
10 23431.802735 S 680 Fi
10 23431.802735 S 680 B
10 23431.804688 S 680 chol_model_22
10 23435.033203 S 65 B
10 23435.035157 S 680 Po
10 23435.035157 S 680 B
13 23435.044922 ntask sched 4.000000
10 23435.044922 S 680 Fi
10 23435.046875 S 680 B
10 23435.048828 S 680 chol_model_22
10 23438.353516 S 65 B
10 23438.355469 S 680 Po
10 23438.355469 S 680 B
13 23438.363281 ntask sched 3.000000
10 23438.365235 S 680 Fi
10 23438.365235 S 680 B
10 23438.367188 S 680 chol_model_22
10 23441.699219 S 65 B
10 23441.701172 S 680 Po
10 23441.701172 S 680 B
13 23441.710938 ntask sched 2.000000
10 23441.710938 S 680 Fi
10 23441.712891 S 680 B
10 23441.712891 S 680 chol_model_22
10 23445.035157 S 65 B
10 23445.035157 S 680 Po
10 23445.037110 S 680 B
13 23445.046875 ntask sched 1.000000
10 23445.048828 S 680 Fi
10 23445.048828 S 680 B
10 23445.050781 S 680 chol_model_22
10 23448.271485 S 65 B
10 23448.271485 S 680 Po
10 23448.273438 S 680 B
13 23448.283203 ntask sched 0.000000
10 23448.285157 S 680 Fi
10 23448.287110 S 680 B
10 23448.287110 S 680 chol_model_22
10 23451.621094 S 65 B
10 23451.623047 S 680 Po
10 23451.625000 S 680 B
13 23451.658203 ntask sched 1.000000
13 23451.666016 ntask sched 0.000000
10 23451.666016 S 680 Fi
10 23451.667969 S 680 B
10 23451.671875 S 680 chol_model_21
10 23459.906250 S 65 B
10 23459.908203 S 680 Po
10 23459.910157 S 680 B
13 23459.943360 ntask sched 1.000000
13 23459.974610 ntask sched 2.000000
13 23460.003907 ntask sched 3.000000
13 23460.033203 ntask sched 4.000000
13 23460.064453 ntask sched 5.000000
13 23460.068360 ntask sched 4.000000
10 23460.070313 S 680 Fi
10 23460.070313 S 680 B
10 23460.072266 S 680 chol_model_22
10 23463.386719 S 65 B
10 23463.386719 S 680 Po
10 23463.388672 S 680 B
13 23463.396485 ntask sched 3.000000
10 23463.398438 S 680 Fi
10 23463.398438 S 680 B
10 23463.400391 S 680 chol_model_22
10 23466.750000 S 65 B
10 23466.750000 S 680 Po
10 23466.751953 S 680 B
13 23466.761719 ntask sched 2.000000
10 23466.761719 S 680 Fi
10 23466.763672 S 680 B
10 23466.763672 S 680 chol_model_22
10 23470.003907 S 65 B
10 23470.003907 S 680 Po
10 23470.005860 S 680 B
13 23470.013672 ntask sched 1.000000
10 23470.013672 S 680 Fi
10 23470.015625 S 680 B
10 23470.015625 S 680 chol_model_22
10 23473.312500 S 65 B
10 23473.314453 S 680 Po
10 23473.316407 S 680 B
13 23473.322266 ntask sched 0.000000
10 23473.324219 S 680 Fi
10 23473.326172 S 680 B
10 23473.326172 S 680 chol_model_22
10 23476.650391 S 65 B
10 23476.650391 S 680 Po
10 23476.652344 S 680 B
13 23476.687500 ntask sched 1.000000
10 23476.689453 MS MEMNODE0 Co
18 23476.689453 L p 4000000 MEMNODE2 com_327
10 23476.699219 MS MEMNODE0 CoA
13 23476.701172 ntask sched 0.000000
10 23476.703125 S 681 Fi
10 23478.197266 MS MEMNODE0 No
19 23478.197266 L p 2273874960 MEMNODE0 com_2273874768
10 23478.265625 MS MEMNODE0 No
19 23478.265625 L p 4000000 MEMNODE0 com_327
10 23478.267578 S 681 B
10 23478.269531 S 681 chol_model_11
10 23546.052735 S 0 B
10 23546.054688 S 681 Po
10 23546.056641 S 681 B
13 23546.093750 ntask sched 1.000000
10 23546.095703 MS MEMNODE2 Co
18 23546.095703 L p 4000000 MEMNODE0 com_328
10 23546.105469 MS MEMNODE2 CoA
10 23547.238281 MS MEMNODE2 No
19 23547.238281 L p 2273874960 MEMNODE2 com_2273874768
13 23547.244141 ntask sched 0.000000
10 23547.246094 S 680 Fi
13 23547.281250 ntask sched 1.000000
13 23547.322266 ntask sched 2.000000
10 23547.322266 MS MEMNODE0 Co
18 23547.322266 L p 4000000 MEMNODE2 com_329
10 23547.324219 MS MEMNODE1 A
10 23547.328125 MS MEMNODE0 CoA
10 23547.470703 MS MEMNODE1 No
10 23547.472657 MS MEMNODE1 Co
18 23547.472657 L p 4000000 MEMNODE0 com_330
10 23547.478516 MS MEMNODE1 CoA
10 23548.798828 MS MEMNODE1 No
19 23548.798828 L p 2273874960 MEMNODE1 com_2273874768
13 23548.804688 ntask sched 1.000000
10 23548.806641 S 679 Fi
13 23548.832031 ntask sched 2.000000
10 23548.994141 MS MEMNODE1 No
19 23548.994141 L p 4000000 MEMNODE1 com_330
10 23549.568360 MS MEMNODE0 No
19 23549.568360 L p 0 MEMNODE0 com_0
10 23549.605469 MS MEMNODE2 No
19 23549.605469 L p 4000000 MEMNODE2 com_328
10 23549.609375 S 680 B
10 23549.632813 S 680 chol_model_21
10 23557.841797 S 65 B
10 23557.843750 S 680 Po
10 23557.845703 S 680 B
13 23557.880860 ntask sched 3.000000
10 23557.890625 MS MEMNODE0 No
19 23557.890625 L p 4000000 MEMNODE0 com_329
13 23557.892578 ntask sched 2.000000
10 23557.892578 MS MEMNODE1 A
10 23557.894531 S 680 Fi
10 23557.894531 S 680 B
10 23557.896485 S 680 chol_model_22
10 23558.011719 MS MEMNODE1 No
10 23558.013672 MS MEMNODE1 Co
18 23558.013672 L p 4000000 MEMNODE0 com_331
10 23558.017578 MS MEMNODE1 CoA
10 23559.144531 MS MEMNODE1 No
19 23559.144531 L p 2273874960 MEMNODE1 com_2273874768
10 23559.337891 MS MEMNODE1 No
19 23559.337891 L p 4000000 MEMNODE1 com_331
10 23559.339844 S 679 B
10 23559.343750 S 679 chol_model_21
10 23561.113281 S 65 B
10 23561.113281 S 680 Po
10 23561.115235 S 680 B
13 23561.148438 ntask sched 3.000000
10 23561.148438 MS MEMNODE0 Co
18 23561.148438 L p 4000000 MEMNODE2 com_332
13 23561.152344 ntask sched 2.000000
10 23561.154297 S 680 Fi
10 23561.156250 S 680 B
10 23561.156250 MS MEMNODE0 CoA
10 23561.158203 S 680 chol_model_21
10 23563.156250 MS MEMNODE0 No
19 23563.156250 L p 2273874960 MEMNODE0 com_2273874768
13 23563.189453 ntask sched 1.000000
10 23563.189453 S 681 Fi
10 23564.423828 MS MEMNODE0 No
19 23564.423828 L p 4000000 MEMNODE0 com_332
10 23564.423828 S 681 B
10 23564.425781 S 681 chol_model_11
10 23567.652344 S 64 B
10 23567.654297 S 679 Po
10 23567.654297 S 679 B
13 23567.691407 ntask sched 2.000000
13 23567.718750 ntask sched 3.000000
10 23567.722657 MS MEMNODE0 Co
18 23567.722657 L p 4000000 MEMNODE1 com_333
10 23567.732422 MS MEMNODE0 CoA
10 23569.337891 MS MEMNODE0 No
19 23569.337891 L p 2273874960 MEMNODE0 com_2273874768
10 23569.380860 MS MEMNODE0 No
19 23569.380860 L p 4000000 MEMNODE0 com_333
10 23571.378907 S 65 B
10 23571.380860 S 680 Po
10 23571.382813 S 680 B
13 23571.416016 ntask sched 4.000000
13 23571.451172 ntask sched 5.000000
13 23571.482422 ntask sched 6.000000
10 23571.486328 MS MEMNODE2 Co
18 23571.486328 L p 4000000 MEMNODE0 com_334
10 23571.492188 MS MEMNODE2 CoA
10 23572.734375 MS MEMNODE2 No
19 23572.734375 L p 2273874960 MEMNODE2 com_2273874768
13 23572.740235 ntask sched 5.000000
10 23572.742188 S 680 Fi
10 23572.744141 S 680 B
10 23572.746094 S 680 chol_model_22
10 23576.056641 S 65 B
10 23576.058594 S 680 Po
10 23576.060547 S 680 B
10 23576.093750 MS MEMNODE2 No
19 23576.093750 L p 4000000 MEMNODE2 com_334
13 23576.095703 ntask sched 4.000000
10 23576.095703 S 680 Fi
10 23576.097657 S 680 B
10 23576.099610 S 680 chol_model_22
10 23579.390625 S 65 B
10 23579.392578 S 680 Po
10 23579.392578 S 680 B
13 23579.402344 ntask sched 3.000000
10 23579.402344 S 680 Fi
10 23579.404297 S 680 B
10 23579.406250 S 680 chol_model_22
10 23582.687500 S 65 B
10 23582.687500 S 680 Po
10 23582.689453 S 680 B
13 23582.697266 ntask sched 2.000000
10 23582.699219 S 680 Fi
10 23582.701172 S 680 B
10 23582.701172 S 680 chol_model_22
10 23585.929688 S 65 B
10 23585.931641 S 680 Po
10 23585.931641 S 680 B
13 23585.939453 ntask sched 1.000000
10 23585.941407 S 680 Fi
10 23585.943360 S 680 B
10 23585.943360 S 680 chol_model_22
10 23589.246094 S 65 B
10 23589.246094 S 680 Po
10 23589.248047 S 680 B
13 23589.255860 ntask sched 0.000000
10 23589.257813 S 680 Fi
10 23589.259766 S 680 B
10 23589.261719 S 680 chol_model_21
10 23597.494141 S 65 B
10 23597.496094 S 680 Po
10 23597.496094 S 680 B
13 23597.531250 ntask sched 1.000000
13 23597.562500 ntask sched 2.000000
13 23597.591797 ntask sched 3.000000
13 23597.621094 ntask sched 4.000000
13 23597.626953 ntask sched 3.000000
10 23597.628907 S 680 Fi
10 23597.630860 S 680 B
10 23597.632813 S 680 chol_model_22
10 23600.886719 S 65 B
10 23600.886719 S 680 Po
10 23600.888672 S 680 B
13 23600.896485 ntask sched 2.000000
10 23600.896485 S 680 Fi
10 23600.898438 S 680 B
10 23600.900391 S 680 chol_model_22
10 23604.203125 S 65 B
10 23604.205078 S 680 Po
10 23604.207031 S 680 B
13 23604.214844 ntask sched 1.000000
10 23604.216797 S 680 Fi
10 23604.216797 S 680 B
10 23604.218750 S 680 chol_model_22
10 23607.480469 S 65 B
10 23607.480469 S 680 Po
10 23607.482422 S 680 B
13 23607.490235 ntask sched 0.000000
10 23607.490235 S 680 Fi
10 23607.492188 S 680 B
10 23607.494141 S 680 chol_model_22
10 23610.785157 S 65 B
10 23610.785157 S 680 Po
10 23610.787110 S 680 B
10 23631.966797 S 0 B
10 23631.968750 S 681 Po
10 23631.968750 S 681 B
13 23632.005860 ntask sched 1.000000
10 23632.005860 MS MEMNODE2 Co
18 23632.005860 L p 4000000 MEMNODE0 com_335
10 23632.013672 MS MEMNODE2 CoA
10 23633.140625 MS MEMNODE2 No
19 23633.140625 L p 2273874960 MEMNODE2 com_2273874768
13 23633.146485 ntask sched 0.000000
10 23633.148438 S 680 Fi
13 23633.179688 ntask sched 1.000000
13 23633.210938 ntask sched 2.000000
10 23633.210938 MS MEMNODE1 A
10 23633.339844 MS MEMNODE1 No
10 23633.341797 MS MEMNODE1 Co
18 23633.341797 L p 4000000 MEMNODE0 com_336
10 23633.347657 MS MEMNODE1 CoA
10 23634.546875 MS MEMNODE1 No
19 23634.546875 L p 2273874960 MEMNODE1 com_2273874768
13 23634.554688 ntask sched 1.000000
10 23634.554688 S 679 Fi
10 23634.583985 MS MEMNODE2 No
19 23634.583985 L p 4000000 MEMNODE2 com_335
10 23634.585938 MS MEMNODE0 Co
18 23634.585938 L p 4000000 MEMNODE2 com_337
10 23634.591797 MS MEMNODE0 CoA
10 23634.755860 MS MEMNODE1 No
19 23634.755860 L p 4000000 MEMNODE1 com_336
10 23636.628907 MS MEMNODE0 No
19 23636.628907 L p 0 MEMNODE0 com_0
10 23636.634766 S 680 B
10 23636.669922 S 680 chol_model_21
10 23644.884766 S 65 B
10 23644.886719 S 680 Po
10 23644.888672 S 680 B
13 23644.921875 ntask sched 2.000000
10 23644.931641 MS MEMNODE0 No
19 23644.931641 L p 4000000 MEMNODE0 com_337
10 23644.933594 MS MEMNODE1 A
13 23644.933594 ntask sched 1.000000
10 23644.933594 S 680 Fi
10 23644.935547 S 680 B
10 23644.935547 S 680 chol_model_22
10 23645.054688 MS MEMNODE1 No
10 23645.056641 MS MEMNODE1 Co
18 23645.056641 L p 4000000 MEMNODE0 com_338
10 23645.064453 MS MEMNODE1 CoA
10 23646.189453 MS MEMNODE1 No
19 23646.189453 L p 2273874960 MEMNODE1 com_2273874768
10 23646.384766 MS MEMNODE1 No
19 23646.384766 L p 4000000 MEMNODE1 com_338
10 23646.386719 S 679 B
10 23646.388672 S 679 chol_model_21
10 23648.236328 S 65 B
10 23648.238281 S 680 Po
10 23648.238281 S 680 B
13 23648.273438 ntask sched 2.000000
10 23648.273438 MS MEMNODE0 Co
18 23648.273438 L p 4000000 MEMNODE2 com_339
13 23648.279297 ntask sched 1.000000
10 23648.279297 S 680 Fi
10 23648.281250 S 680 B
10 23648.283203 MS MEMNODE0 CoA
10 23648.283203 S 680 chol_model_21
10 23650.285157 MS MEMNODE0 No
19 23650.285157 L p 2273874960 MEMNODE0 com_2273874768
13 23650.304688 ntask sched 0.000000
10 23650.306641 S 681 Fi
10 23651.578125 MS MEMNODE0 No
19 23651.578125 L p 4000000 MEMNODE0 com_339
10 23651.580078 S 681 B
10 23651.580078 S 681 chol_model_11
10 23654.701172 S 64 B
10 23654.703125 S 679 Po
10 23654.705078 S 679 B
13 23654.742188 ntask sched 1.000000
13 23654.769531 ntask sched 2.000000
10 23654.775391 MS MEMNODE0 Co
18 23654.775391 L p 4000000 MEMNODE1 com_340
10 23654.781250 MS MEMNODE0 CoA
10 23656.384766 MS MEMNODE0 No
19 23656.384766 L p 2273874960 MEMNODE0 com_2273874768
10 23656.427735 MS MEMNODE0 No
19 23656.427735 L p 4000000 MEMNODE0 com_340
10 23658.507813 S 65 B
10 23658.509766 S 680 Po
10 23658.511719 S 680 B
13 23658.546875 ntask sched 3.000000
13 23658.578125 ntask sched 4.000000
13 23658.607422 ntask sched 5.000000
10 23658.611328 MS MEMNODE2 Co
18 23658.611328 L p 4000000 MEMNODE0 com_341
10 23658.623047 MS MEMNODE2 CoA
10 23659.861328 MS MEMNODE2 No
19 23659.861328 L p 2273874960 MEMNODE2 com_2273874768
13 23659.867188 ntask sched 4.000000
10 23659.869141 S 680 Fi
10 23660.058594 MS MEMNODE2 No
19 23660.058594 L p 4000000 MEMNODE2 com_341
10 23660.062500 S 680 B
10 23660.062500 S 680 chol_model_22
10 23663.390625 S 65 B
10 23663.392578 S 680 Po
10 23663.392578 S 680 B
13 23663.400391 ntask sched 3.000000
10 23663.402344 S 680 Fi
10 23663.404297 S 680 B
10 23663.404297 S 680 chol_model_22
10 23666.669922 S 65 B
10 23666.671875 S 680 Po
10 23666.671875 S 680 B
13 23666.681641 ntask sched 2.000000
10 23666.681641 S 680 Fi
10 23666.683594 S 680 B
10 23666.685547 S 680 chol_model_22
10 23669.908203 S 65 B
10 23669.910157 S 680 Po
10 23669.912110 S 680 B
13 23669.921875 ntask sched 1.000000
10 23669.921875 S 680 Fi
10 23669.923828 S 680 B
10 23669.923828 S 680 chol_model_22
10 23673.148438 S 65 B
10 23673.148438 S 680 Po
10 23673.150391 S 680 B
13 23673.158203 ntask sched 0.000000
10 23673.160157 S 680 Fi
10 23673.162110 S 680 B
10 23673.162110 S 680 chol_model_22
10 23676.373047 S 65 B
10 23676.375000 S 680 Po
10 23676.376953 S 680 B
10 23719.527344 S 0 B
10 23719.529297 S 681 Po
10 23719.531250 S 681 B
13 23719.568360 ntask sched 1.000000
10 23719.568360 MS MEMNODE2 Co
18 23719.568360 L p 4000000 MEMNODE0 com_342
10 23719.576172 MS MEMNODE2 CoA
10 23730.503907 MS MEMNODE2 No
19 23730.503907 L p 2273874960 MEMNODE2 com_2273874768
13 23730.509766 ntask sched 0.000000
10 23730.511719 S 680 Fi
13 23730.541016 ntask sched 1.000000
10 23730.701172 MS MEMNODE2 No
19 23730.701172 L p 4000000 MEMNODE2 com_342
10 23730.703125 S 680 B
10 23730.705078 S 680 chol_model_21
10 23738.929688 S 65 B
10 23738.931641 S 680 Po
10 23738.933594 S 680 B
13 23738.968750 ntask sched 2.000000
13 23738.974610 ntask sched 1.000000
10 23738.976563 S 680 Fi
10 23738.976563 S 680 B
10 23738.976563 S 680 chol_model_22
10 23742.207031 S 65 B
10 23742.208985 S 680 Po
10 23742.210938 S 680 B
13 23742.244141 ntask sched 2.000000
10 23742.246094 MS MEMNODE0 Co
18 23742.246094 L p 4000000 MEMNODE2 com_343
13 23742.250000 ntask sched 1.000000
10 23742.250000 S 680 Fi
10 23742.251953 S 680 B
10 23742.253907 MS MEMNODE0 CoA
10 23742.255860 S 680 chol_model_21
13 23742.279297 ntask sched 0.000000
10 23742.281250 S 681 Fi
10 23743.718750 MS MEMNODE0 No
19 23743.718750 L p 2273874960 MEMNODE0 com_2273874768
10 23744.996094 MS MEMNODE0 No
19 23744.996094 L p 4000000 MEMNODE0 com_343
10 23744.998047 S 681 B
10 23744.998047 S 681 chol_model_11
10 23751.935547 S 65 B
10 23751.937500 S 680 Po
10 23751.939453 S 680 B
13 23751.972657 ntask sched 1.000000
13 23752.003907 ntask sched 2.000000
13 23752.009766 ntask sched 1.000000
10 23752.009766 S 680 Fi
10 23752.011719 S 680 B
10 23752.011719 S 680 chol_model_22
10 23755.310547 S 65 B
10 23755.310547 S 680 Po
10 23755.312500 S 680 B
13 23755.320313 ntask sched 0.000000
10 23755.320313 S 680 Fi
10 23755.322266 S 680 B
10 23755.322266 S 680 chol_model_22
10 23758.632813 S 65 B
10 23758.634766 S 680 Po
10 23758.634766 S 680 B
10 23812.462891 S 0 B
10 23812.464844 S 681 Po
10 23812.466797 S 681 B
13 23812.500000 ntask sched 1.000000
10 23812.500000 MS MEMNODE2 Co
18 23812.500000 L p 4000000 MEMNODE0 com_344
10 23812.509766 MS MEMNODE2 CoA
10 23813.636719 MS MEMNODE2 No
19 23813.636719 L p 2273874960 MEMNODE2 com_2273874768
13 23813.642578 ntask sched 0.000000
10 23813.644531 S 680 Fi
10 23813.835938 MS MEMNODE2 No
19 23813.835938 L p 4000000 MEMNODE2 com_344
10 23813.837891 S 680 B
10 23813.841797 S 680 chol_model_21
10 23822.056641 S 65 B
10 23822.058594 S 680 Po
10 23822.060547 S 680 B
13 23822.095703 ntask sched 1.000000
13 23822.101563 ntask sched 0.000000
10 23822.101563 S 680 Fi
10 23822.103516 S 680 B
10 23822.103516 S 680 chol_model_22
10 23825.339844 S 65 B
10 23825.339844 S 680 Po
10 23825.341797 S 680 B
13 23825.375000 ntask sched 1.000000
10 23825.376953 MS MEMNODE0 Co
18 23825.376953 L p 4000000 MEMNODE2 com_345
10 23825.386719 MS MEMNODE0 CoA
13 23825.392578 ntask sched 0.000000
10 23825.394531 S 681 Fi
10 23826.900391 MS MEMNODE0 No
19 23826.900391 L p 2273874960 MEMNODE0 com_2273874768
10 23826.951172 MS MEMNODE0 No
19 23826.951172 L p 4000000 MEMNODE0 com_345
10 23826.953125 S 681 B
10 23826.953125 S 681 chol_model_11
10 23894.976563 S 0 B
10 23894.978516 S 681 Po
10 23894.980469 S 681 B
10 23898.523438 MS MEMNODE0 Co
18 23898.523438 L p 4000000 MEMNODE2 com_346
10 23898.533203 MS MEMNODE0 CoA
10 23900.619141 MS MEMNODE0 No
19 23900.619141 L p 2273874960 MEMNODE0 com_2273874768
10 23900.666016 MS MEMNODE0 No
19 23900.666016 L p 4000000 MEMNODE0 com_346
10 23901.988281 MS MEMNODE0 Co
18 23901.988281 L p 4000000 MEMNODE2 com_347
10 23901.996094 MS MEMNODE0 CoA
10 23904.015625 MS MEMNODE0 No
19 23904.015625 L p 2273874960 MEMNODE0 com_2273874768
10 23904.058594 MS MEMNODE0 No
19 23904.058594 L p 4000000 MEMNODE0 com_347
10 23905.654297 MS MEMNODE0 Co
18 23905.654297 L p 4000000 MEMNODE2 com_348
10 23905.666016 MS MEMNODE0 CoA
10 23907.714844 MS MEMNODE0 No
19 23907.714844 L p 2273874960 MEMNODE0 com_2273874768
10 23907.763672 MS MEMNODE0 No
19 23907.763672 L p 4000000 MEMNODE0 com_348
10 23908.484375 MS MEMNODE0 Co
18 23908.484375 L p 4000000 MEMNODE2 com_349
10 23908.494141 MS MEMNODE0 CoA
10 23910.550781 MS MEMNODE0 No
19 23910.550781 L p 2273874960 MEMNODE0 com_2273874768
10 23910.597657 MS MEMNODE0 No
19 23910.597657 L p 4000000 MEMNODE0 com_349
10 23912.000000 MS MEMNODE0 Co
18 23912.000000 L p 4000000 MEMNODE2 com_350
10 23912.263672 MS MEMNODE0 CoA
10 23947.681641 MS MEMNODE0 No
19 23947.681641 L p 2273874960 MEMNODE0 com_2273874768
10 23947.767578 MS MEMNODE0 No
19 23947.767578 L p 4000000 MEMNODE0 com_350
10 23948.232422 MS MEMNODE0 Co
18 23948.232422 L p 4000000 MEMNODE2 com_351
10 23948.240235 MS MEMNODE0 CoA
10 23950.289063 MS MEMNODE0 No
19 23950.289063 L p 2273874960 MEMNODE0 com_2273874768
10 23950.337891 MS MEMNODE0 No
19 23950.337891 L p 4000000 MEMNODE0 com_351
10 23950.855469 MS MEMNODE0 Co
18 23950.855469 L p 4000000 MEMNODE2 com_352
10 23950.867188 MS MEMNODE0 CoA
10 23952.378907 MS MEMNODE0 No
19 23952.378907 L p 2273874960 MEMNODE0 com_2273874768
10 23952.427735 MS MEMNODE0 No
19 23952.427735 L p 4000000 MEMNODE0 com_352
10 23953.490235 MS MEMNODE0 Co
18 23953.490235 L p 4000000 MEMNODE2 com_353
10 23953.498047 MS MEMNODE0 CoA
10 23955.087891 MS MEMNODE0 No
19 23955.087891 L p 2273874960 MEMNODE0 com_2273874768
10 23955.228516 MS MEMNODE0 No
19 23955.228516 L p 4000000 MEMNODE0 com_353
10 23956.289063 MS MEMNODE0 Co
18 23956.289063 L p 4000000 MEMNODE2 com_354
10 23956.298828 MS MEMNODE0 CoA
10 23989.238281 MS MEMNODE0 No
19 23989.238281 L p 2273874960 MEMNODE0 com_2273874768
10 23989.292969 MS MEMNODE0 No
19 23989.292969 L p 4000000 MEMNODE0 com_354
10 23990.031250 MS MEMNODE0 Co
18 23990.031250 L p 4000000 MEMNODE2 com_355
10 23990.039063 MS MEMNODE0 CoA
10 23992.097657 MS MEMNODE0 No
19 23992.097657 L p 2273874960 MEMNODE0 com_2273874768
10 23992.142578 MS MEMNODE0 No
19 23992.142578 L p 4000000 MEMNODE0 com_355
10 23993.587891 MS MEMNODE0 Co
18 23993.587891 L p 4000000 MEMNODE2 com_356
10 23993.603516 MS MEMNODE0 CoA
10 23995.660157 MS MEMNODE0 No
19 23995.660157 L p 2273874960 MEMNODE0 com_2273874768
10 23995.707031 MS MEMNODE0 No
19 23995.707031 L p 4000000 MEMNODE0 com_356
10 23997.179688 MS MEMNODE0 Co
18 23997.179688 L p 4000000 MEMNODE2 com_357
10 23997.355469 MS MEMNODE0 CoA
10 24032.781250 MS MEMNODE0 No
19 24032.781250 L p 2273874960 MEMNODE0 com_2273874768
10 24033.003907 MS MEMNODE0 No
19 24033.003907 L p 4000000 MEMNODE0 com_357
10 24034.064453 MS MEMNODE0 Co
18 24034.064453 L p 4000000 MEMNODE2 com_358
10 24034.072266 MS MEMNODE0 CoA
10 24036.121094 MS MEMNODE0 No
19 24036.121094 L p 2273874960 MEMNODE0 com_2273874768
10 24036.171875 MS MEMNODE0 No
19 24036.171875 L p 4000000 MEMNODE0 com_358
10 24037.154297 MS MEMNODE0 Co
18 24037.154297 L p 4000000 MEMNODE2 com_359
10 24037.164063 MS MEMNODE0 CoA
10 24039.171875 MS MEMNODE0 No
19 24039.171875 L p 2273874960 MEMNODE0 com_2273874768
10 24039.218750 MS MEMNODE0 No
19 24039.218750 L p 4000000 MEMNODE0 com_359
10 24040.064453 MS MEMNODE0 Co
18 24040.064453 L p 4000000 MEMNODE2 com_360
10 24040.078125 MS MEMNODE0 CoA
10 24063.269531 MS MEMNODE0 No
19 24063.269531 L p 2273874960 MEMNODE0 com_2273874768
10 24063.330078 MS MEMNODE0 No
19 24063.330078 L p 4000000 MEMNODE0 com_360
10 24063.947266 MS MEMNODE0 Co
18 24063.947266 L p 4000000 MEMNODE2 com_361
10 24063.962891 MS MEMNODE0 CoA
10 24065.978516 MS MEMNODE0 No
19 24065.978516 L p 2273874960 MEMNODE0 com_2273874768
10 24066.025391 MS MEMNODE0 No
19 24066.025391 L p 4000000 MEMNODE0 com_361
10 24066.343750 MS MEMNODE0 Co
18 24066.343750 L p 4000000 MEMNODE2 com_362
10 24066.351563 MS MEMNODE0 CoA
10 24068.363281 MS MEMNODE0 No
19 24068.363281 L p 2273874960 MEMNODE0 com_2273874768
10 24068.419922 MS MEMNODE0 No
19 24068.419922 L p 4000000 MEMNODE0 com_362
10 24068.830078 MS MEMNODE0 Co
18 24068.830078 L p 4000000 MEMNODE2 com_363
10 24068.837891 MS MEMNODE0 CoA
10 24070.316407 MS MEMNODE0 No
19 24070.316407 L p 2273874960 MEMNODE0 com_2273874768
10 24070.363281 MS MEMNODE0 No
19 24070.363281 L p 4000000 MEMNODE0 com_363
10 24071.009766 MS MEMNODE0 Co
18 24071.009766 L p 4000000 MEMNODE2 com_364
10 24071.031250 MS MEMNODE0 CoA
10 24073.083985 MS MEMNODE0 No
19 24073.083985 L p 2273874960 MEMNODE0 com_2273874768
10 24073.130860 MS MEMNODE0 No
19 24073.130860 L p 4000000 MEMNODE0 com_364
10 24074.548828 MS MEMNODE0 Co
18 24074.548828 L p 4000000 MEMNODE2 com_365
10 24074.556641 MS MEMNODE0 CoA
10 24076.041016 MS MEMNODE0 No
19 24076.041016 L p 2273874960 MEMNODE0 com_2273874768
10 24076.093750 MS MEMNODE0 No
19 24076.093750 L p 4000000 MEMNODE0 com_365
10 24076.687500 MS MEMNODE0 Co
18 24076.687500 L p 4000000 MEMNODE2 com_366
10 24076.695313 MS MEMNODE0 CoA
10 24078.195313 MS MEMNODE0 No
19 24078.195313 L p 2273874960 MEMNODE0 com_2273874768
10 24078.244141 MS MEMNODE0 No
19 24078.244141 L p 4000000 MEMNODE0 com_366
10 24079.230469 MS MEMNODE0 Co
18 24079.230469 L p 4000000 MEMNODE2 com_367
10 24079.464844 MS MEMNODE0 CoA
10 24107.054688 MS MEMNODE0 No
19 24107.054688 L p 2273874960 MEMNODE0 com_2273874768
10 24107.101563 MS MEMNODE0 No
19 24107.101563 L p 4000000 MEMNODE0 com_367
10 24107.310547 MS MEMNODE0 Co
18 24107.310547 L p 4000000 MEMNODE2 com_368
10 24107.316407 MS MEMNODE0 CoA
10 24109.371094 MS MEMNODE0 No
19 24109.371094 L p 2273874960 MEMNODE0 com_2273874768
10 24109.509766 MS MEMNODE0 No
19 24109.509766 L p 4000000 MEMNODE0 com_368
10 24109.925781 MS MEMNODE0 Co
18 24109.925781 L p 4000000 MEMNODE2 com_369
10 24109.935547 MS MEMNODE0 CoA
10 24111.412110 MS MEMNODE0 No
19 24111.412110 L p 2273874960 MEMNODE0 com_2273874768
10 24111.554688 MS MEMNODE0 No
19 24111.554688 L p 4000000 MEMNODE0 com_369
10 24113.062500 MS MEMNODE0 Co
18 24113.062500 L p 4000000 MEMNODE2 com_370
10 24113.072266 MS MEMNODE0 CoA
10 24115.121094 MS MEMNODE0 No
19 24115.121094 L p 2273874960 MEMNODE0 com_2273874768
10 24115.187500 MS MEMNODE0 No
19 24115.187500 L p 4000000 MEMNODE0 com_370
10 24115.625000 MS MEMNODE0 Co
18 24115.625000 L p 4000000 MEMNODE2 com_371
10 24115.644531 MS MEMNODE0 CoA
10 24117.695313 MS MEMNODE0 No
19 24117.695313 L p 2273874960 MEMNODE0 com_2273874768
10 24117.750000 MS MEMNODE0 No
19 24117.750000 L p 4000000 MEMNODE0 com_371
10 24118.904297 MS MEMNODE0 Co
18 24118.904297 L p 4000000 MEMNODE2 com_372
10 24118.912110 MS MEMNODE0 CoA
10 24120.396485 MS MEMNODE0 No
19 24120.396485 L p 2273874960 MEMNODE0 com_2273874768
10 24120.466797 MS MEMNODE0 No
19 24120.466797 L p 4000000 MEMNODE0 com_372
10 24121.144531 MS MEMNODE0 Co
18 24121.144531 L p 4000000 MEMNODE2 com_373
10 24121.156250 MS MEMNODE0 CoA
10 24123.210938 MS MEMNODE0 No
19 24123.210938 L p 2273874960 MEMNODE0 com_2273874768
10 24123.251953 MS MEMNODE0 No
19 24123.251953 L p 4000000 MEMNODE0 com_373
10 24123.738281 MS MEMNODE0 Co
18 24123.738281 L p 4000000 MEMNODE2 com_374
10 24123.746094 MS MEMNODE0 CoA
10 24125.759766 MS MEMNODE0 No
19 24125.759766 L p 2273874960 MEMNODE0 com_2273874768
10 24125.812500 MS MEMNODE0 No
19 24125.812500 L p 4000000 MEMNODE0 com_374
10 24126.808594 MS MEMNODE0 Co
18 24126.808594 L p 4000000 MEMNODE2 com_375
10 24126.816407 MS MEMNODE0 CoA
10 24128.828125 MS MEMNODE0 No
19 24128.828125 L p 2273874960 MEMNODE0 com_2273874768
10 24128.882813 MS MEMNODE0 No
19 24128.882813 L p 4000000 MEMNODE0 com_375
10 24130.589844 MS MEMNODE0 Co
18 24130.589844 L p 4000000 MEMNODE2 com_376
10 24130.605469 MS MEMNODE0 CoA
10 24132.613281 MS MEMNODE0 No
19 24132.613281 L p 2273874960 MEMNODE0 com_2273874768
10 24132.669922 MS MEMNODE0 No
19 24132.669922 L p 4000000 MEMNODE0 com_376
10 24133.375000 MS MEMNODE0 Co
18 24133.375000 L p 4000000 MEMNODE2 com_377
10 24133.384766 MS MEMNODE0 CoA
10 24134.904297 MS MEMNODE0 No
19 24134.904297 L p 2273874960 MEMNODE0 com_2273874768
10 24135.181641 MS MEMNODE0 No
19 24135.181641 L p 4000000 MEMNODE0 com_377
10 24136.164063 MS MEMNODE0 Co
18 24136.164063 L p 4000000 MEMNODE2 com_378
10 24136.173828 MS MEMNODE0 CoA
10 24137.654297 MS MEMNODE0 No
19 24137.654297 L p 2273874960 MEMNODE0 com_2273874768
10 24137.705078 MS MEMNODE0 No
19 24137.705078 L p 4000000 MEMNODE0 com_378
10 24138.791016 MS MEMNODE0 Co
18 24138.791016 L p 4000000 MEMNODE2 com_379
10 24138.798828 MS MEMNODE0 CoA
10 24140.802735 MS MEMNODE0 No
19 24140.802735 L p 2273874960 MEMNODE0 com_2273874768
10 24140.845703 MS MEMNODE0 No
19 24140.845703 L p 4000000 MEMNODE0 com_379
10 24141.748047 MS MEMNODE0 Co
18 24141.748047 L p 4000000 MEMNODE2 com_380
10 24141.925781 MS MEMNODE0 CoA
10 24176.953125 MS MEMNODE0 No
19 24176.953125 L p 2273874960 MEMNODE0 com_2273874768
10 24177.062500 MS MEMNODE0 No
19 24177.062500 L p 4000000 MEMNODE0 com_380
10 24178.687500 MS MEMNODE0 Co
18 24178.687500 L p 4000000 MEMNODE2 com_381
10 24178.943360 MS MEMNODE0 CoA
10 24216.964844 MS MEMNODE0 No
19 24216.964844 L p 2273874960 MEMNODE0 com_2273874768
10 24217.101563 MS MEMNODE0 No
19 24217.101563 L p 4000000 MEMNODE0 com_381
10 24217.865235 MS MEMNODE0 Co
18 24217.865235 L p 4000000 MEMNODE2 com_382
10 24217.875000 MS MEMNODE0 CoA
10 24219.373047 MS MEMNODE0 No
19 24219.373047 L p 2273874960 MEMNODE0 com_2273874768
10 24219.431641 MS MEMNODE0 No
19 24219.431641 L p 4000000 MEMNODE0 com_382
10 24220.775391 MS MEMNODE0 Co
18 24220.775391 L p 4000000 MEMNODE2 com_383
10 24220.783203 MS MEMNODE0 CoA
10 24222.283203 MS MEMNODE0 No
19 24222.283203 L p 2273874960 MEMNODE0 com_2273874768
10 24222.343750 MS MEMNODE0 No
19 24222.343750 L p 4000000 MEMNODE0 com_383
10 24222.869141 MS MEMNODE0 Co
18 24222.869141 L p 4000000 MEMNODE2 com_384
10 24223.199219 MS MEMNODE0 CoA
10 24256.410157 MS MEMNODE0 No
19 24256.410157 L p 2273874960 MEMNODE0 com_2273874768
10 24256.658203 MS MEMNODE0 No
19 24256.658203 L p 4000000 MEMNODE0 com_384
10 24257.066407 MS MEMNODE0 Co
18 24257.066407 L p 4000000 MEMNODE2 com_385
10 24257.074219 MS MEMNODE0 CoA
10 24258.601563 MS MEMNODE0 No
19 24258.601563 L p 2273874960 MEMNODE0 com_2273874768
10 24258.648438 MS MEMNODE0 No
19 24258.648438 L p 4000000 MEMNODE0 com_385
10 24259.625000 MS MEMNODE0 Co
18 24259.625000 L p 4000000 MEMNODE2 com_386
10 24259.753907 MS MEMNODE0 CoA
10 24294.011719 MS MEMNODE0 No
19 24294.011719 L p 2273874960 MEMNODE0 com_2273874768
10 24294.091797 MS MEMNODE0 No
19 24294.091797 L p 4000000 MEMNODE0 com_386
10 24295.214844 MS MEMNODE0 Co
18 24295.214844 L p 4000000 MEMNODE2 com_387
10 24295.337891 MS MEMNODE0 CoA
10 24328.244141 MS MEMNODE0 No
19 24328.244141 L p 2273874960 MEMNODE0 com_2273874768
10 24328.617188 MS MEMNODE0 No
19 24328.617188 L p 4000000 MEMNODE0 com_387
10 24330.566407 MS MEMNODE0 Co
18 24330.566407 L p 4000000 MEMNODE2 com_388
10 24330.580078 MS MEMNODE0 CoA
10 24332.597657 MS MEMNODE0 No
19 24332.597657 L p 2273874960 MEMNODE0 com_2273874768
10 24332.976563 MS MEMNODE0 No
19 24332.976563 L p 4000000 MEMNODE0 com_388
10 24333.373047 MS MEMNODE0 Co
18 24333.373047 L p 4000000 MEMNODE2 com_389
10 24333.572266 MS MEMNODE0 CoA
10 24367.421875 MS MEMNODE0 No
19 24367.421875 L p 2273874960 MEMNODE0 com_2273874768
10 24367.923828 MS MEMNODE0 No
19 24367.923828 L p 4000000 MEMNODE0 com_389
10 24369.232422 MS MEMNODE0 Co
18 24369.232422 L p 4000000 MEMNODE2 com_390
10 24369.242188 MS MEMNODE0 CoA
10 24370.718750 MS MEMNODE0 No
19 24370.718750 L p 2273874960 MEMNODE0 com_2273874768
10 24370.759766 MS MEMNODE0 No
19 24370.759766 L p 4000000 MEMNODE0 com_390
10 24371.558594 MS MEMNODE0 Co
18 24371.558594 L p 4000000 MEMNODE2 com_391
10 24371.570313 MS MEMNODE0 CoA
10 24373.068360 MS MEMNODE0 No
19 24373.068360 L p 2273874960 MEMNODE0 com_2273874768
10 24373.115235 MS MEMNODE0 No
19 24373.115235 L p 4000000 MEMNODE0 com_391
10 24373.658203 MS MEMNODE0 Co
18 24373.658203 L p 4000000 MEMNODE2 com_392
10 24373.667969 MS MEMNODE0 CoA
10 24375.720703 MS MEMNODE0 No
19 24375.720703 L p 2273874960 MEMNODE0 com_2273874768
10 24375.761719 MS MEMNODE0 No
19 24375.761719 L p 4000000 MEMNODE0 com_392
10 24376.726563 MS MEMNODE0 Co
18 24376.726563 L p 4000000 MEMNODE2 com_393
10 24376.736328 MS MEMNODE0 CoA
10 24378.744141 MS MEMNODE0 No
19 24378.744141 L p 2273874960 MEMNODE0 com_2273874768
10 24378.814453 MS MEMNODE0 No
19 24378.814453 L p 4000000 MEMNODE0 com_393
10 24379.556641 MS MEMNODE0 Co
18 24379.556641 L p 4000000 MEMNODE2 com_394
10 24379.660157 MS MEMNODE0 CoA
10 24415.113281 MS MEMNODE0 No
19 24415.113281 L p 2273874960 MEMNODE0 com_2273874768
10 24415.564453 MS MEMNODE0 No
19 24415.564453 L p 4000000 MEMNODE0 com_394
10 24417.203125 MS MEMNODE0 Co
18 24417.203125 L p 4000000 MEMNODE2 com_395
10 24417.208985 MS MEMNODE0 CoA
10 24418.718750 MS MEMNODE0 No
19 24418.718750 L p 2273874960 MEMNODE0 com_2273874768
10 24418.779297 MS MEMNODE0 No
19 24418.779297 L p 4000000 MEMNODE0 com_395
10 24419.490235 MS MEMNODE0 Co
18 24419.490235 L p 4000000 MEMNODE2 com_396
10 24419.498047 MS MEMNODE0 CoA
10 24421.011719 MS MEMNODE0 No
19 24421.011719 L p 2273874960 MEMNODE0 com_2273874768
10 24421.066407 MS MEMNODE0 No
19 24421.066407 L p 4000000 MEMNODE0 com_396
10 24422.699219 MS MEMNODE0 Co
18 24422.699219 L p 4000000 MEMNODE2 com_397
10 24422.724610 MS MEMNODE0 CoA
10 24424.773438 MS MEMNODE0 No
19 24424.773438 L p 2273874960 MEMNODE0 com_2273874768
10 24424.826172 MS MEMNODE0 No
19 24424.826172 L p 4000000 MEMNODE0 com_397
10 24425.447266 MS MEMNODE0 Co
18 24425.447266 L p 4000000 MEMNODE2 com_398
10 24425.453125 MS MEMNODE0 CoA
10 24426.962891 MS MEMNODE0 No
19 24426.962891 L p 2273874960 MEMNODE0 com_2273874768
10 24427.023438 MS MEMNODE0 No
19 24427.023438 L p 4000000 MEMNODE0 com_398
10 24427.964844 MS MEMNODE0 Co
18 24427.964844 L p 4000000 MEMNODE2 com_399
10 24427.970703 MS MEMNODE0 CoA
10 24430.025391 MS MEMNODE0 No
19 24430.025391 L p 2273874960 MEMNODE0 com_2273874768
10 24430.078125 MS MEMNODE0 No
19 24430.078125 L p 4000000 MEMNODE0 com_399
10 24431.066407 MS MEMNODE0 Co
18 24431.066407 L p 4000000 MEMNODE2 com_400
10 24431.238281 MS MEMNODE0 CoA
10 24465.273438 MS MEMNODE0 No
19 24465.273438 L p 2273874960 MEMNODE0 com_2273874768
10 24465.636719 MS MEMNODE0 No
19 24465.636719 L p 4000000 MEMNODE0 com_400
10 24466.449219 MS MEMNODE0 Co
18 24466.449219 L p 4000000 MEMNODE2 com_401
10 24466.455078 MS MEMNODE0 CoA
10 24467.953125 MS MEMNODE0 No
19 24467.953125 L p 2273874960 MEMNODE0 com_2273874768
10 24468.009766 MS MEMNODE0 No
19 24468.009766 L p 4000000 MEMNODE0 com_401
10 24468.402344 MS MEMNODE0 Co
18 24468.402344 L p 4000000 MEMNODE2 com_402
10 24468.800781 MS MEMNODE0 CoA
10 24472.396485 MS MEMNODE0 No
19 24472.396485 L p 2273874960 MEMNODE0 com_2273874768
10 24472.453125 MS MEMNODE0 No
19 24472.453125 L p 4000000 MEMNODE0 com_402
10 24474.773438 MS MEMNODE0 Co
18 24474.773438 L p 4000000 MEMNODE2 com_403
10 24474.781250 MS MEMNODE0 CoA
10 24476.828125 MS MEMNODE0 No
19 24476.828125 L p 2273874960 MEMNODE0 com_2273874768
10 24476.869141 MS MEMNODE0 No
19 24476.869141 L p 4000000 MEMNODE0 com_403
10 24477.933594 MS MEMNODE0 Co
18 24477.933594 L p 4000000 MEMNODE2 com_404
10 24478.394531 MS MEMNODE0 CoA
10 24513.667969 MS MEMNODE0 No
19 24513.667969 L p 2273874960 MEMNODE0 com_2273874768
10 24513.955078 MS MEMNODE0 No
19 24513.955078 L p 4000000 MEMNODE0 com_404
10 24515.517578 MS MEMNODE0 Co
18 24515.517578 L p 4000000 MEMNODE2 com_405
10 24515.537110 MS MEMNODE0 CoA
10 24517.013672 MS MEMNODE0 No
19 24517.013672 L p 2273874960 MEMNODE0 com_2273874768
10 24517.056641 MS MEMNODE0 No
19 24517.056641 L p 4000000 MEMNODE0 com_405
10 24517.501953 MS MEMNODE0 Co
18 24517.501953 L p 4000000 MEMNODE2 com_406
10 24517.509766 MS MEMNODE0 CoA
10 24519.564453 MS MEMNODE0 No
19 24519.564453 L p 2273874960 MEMNODE0 com_2273874768
10 24519.619141 MS MEMNODE0 No
19 24519.619141 L p 4000000 MEMNODE0 com_406
10 24520.642578 MS MEMNODE0 Co
18 24520.642578 L p 4000000 MEMNODE2 com_407
10 24520.658203 MS MEMNODE0 CoA
10 24522.667969 MS MEMNODE0 No
19 24522.667969 L p 2273874960 MEMNODE0 com_2273874768
10 24522.714844 MS MEMNODE0 No
19 24522.714844 L p 4000000 MEMNODE0 com_407
10 24524.189453 MS MEMNODE0 Co
18 24524.189453 L p 4000000 MEMNODE2 com_408
10 24524.201172 MS MEMNODE0 CoA
10 24526.253907 MS MEMNODE0 No
19 24526.253907 L p 2273874960 MEMNODE0 com_2273874768
10 24526.294922 MS MEMNODE0 No
19 24526.294922 L p 4000000 MEMNODE0 com_408
10 24527.923828 MS MEMNODE0 Co
18 24527.923828 L p 4000000 MEMNODE2 com_409
10 24527.933594 MS MEMNODE0 CoA
10 24529.443360 MS MEMNODE0 No
19 24529.443360 L p 2273874960 MEMNODE0 com_2273874768
10 24529.486328 MS MEMNODE0 No
19 24529.486328 L p 4000000 MEMNODE0 com_409
10 24529.896485 MS MEMNODE0 Co
18 24529.896485 L p 4000000 MEMNODE2 com_410
10 24529.906250 MS MEMNODE0 CoA
10 24531.408203 MS MEMNODE0 No
19 24531.408203 L p 2273874960 MEMNODE0 com_2273874768
10 24531.453125 MS MEMNODE0 No
19 24531.453125 L p 4000000 MEMNODE0 com_410
10 24532.189453 MS MEMNODE0 Co
18 24532.189453 L p 4000000 MEMNODE2 com_411
10 24532.197266 MS MEMNODE0 CoA
10 24533.705078 MS MEMNODE0 No
19 24533.705078 L p 2273874960 MEMNODE0 com_2273874768
10 24533.755860 MS MEMNODE0 No
19 24533.755860 L p 4000000 MEMNODE0 com_411
10 24535.531250 MS MEMNODE0 Co
18 24535.531250 L p 4000000 MEMNODE2 com_412
10 24535.539063 MS MEMNODE0 CoA
10 24537.550781 MS MEMNODE0 No
19 24537.550781 L p 2273874960 MEMNODE0 com_2273874768
10 24537.593750 MS MEMNODE0 No
19 24537.593750 L p 4000000 MEMNODE0 com_412
10 24538.183594 MS MEMNODE0 Co
18 24538.183594 L p 4000000 MEMNODE2 com_413
10 24538.193360 MS MEMNODE0 CoA
10 24540.199219 MS MEMNODE0 No
19 24540.199219 L p 2273874960 MEMNODE0 com_2273874768
10 24540.269531 MS MEMNODE0 No
19 24540.269531 L p 4000000 MEMNODE0 com_413
10 24540.888672 MS MEMNODE0 Co
18 24540.888672 L p 4000000 MEMNODE2 com_414
10 24541.271485 MS MEMNODE0 CoA
10 24579.750000 MS MEMNODE0 No
19 24579.750000 L p 2273874960 MEMNODE0 com_2273874768
10 24580.005860 MS MEMNODE0 No
19 24580.005860 L p 4000000 MEMNODE0 com_414
10 24580.888672 MS MEMNODE0 Co
18 24580.888672 L p 4000000 MEMNODE2 com_415
10 24580.902344 MS MEMNODE0 CoA
10 24582.406250 MS MEMNODE0 No
19 24582.406250 L p 2273874960 MEMNODE0 com_2273874768
10 24582.707031 MS MEMNODE0 No
19 24582.707031 L p 4000000 MEMNODE0 com_415
10 24583.031250 MS MEMNODE0 Co
18 24583.031250 L p 4000000 MEMNODE2 com_416
10 24583.046875 MS MEMNODE0 CoA
10 24584.546875 MS MEMNODE0 No
19 24584.546875 L p 2273874960 MEMNODE0 com_2273874768
10 24584.601563 MS MEMNODE0 No
19 24584.601563 L p 4000000 MEMNODE0 com_416
10 24585.236328 MS MEMNODE0 Co
18 24585.236328 L p 4000000 MEMNODE2 com_417
10 24585.246094 MS MEMNODE0 CoA
10 24586.761719 MS MEMNODE0 No
19 24586.761719 L p 2273874960 MEMNODE0 com_2273874768
10 24586.808594 MS MEMNODE0 No
19 24586.808594 L p 4000000 MEMNODE0 com_417
10 24587.720703 MS MEMNODE0 Co
18 24587.720703 L p 4000000 MEMNODE2 com_418
10 24587.728516 MS MEMNODE0 CoA
10 24589.781250 MS MEMNODE0 No
19 24589.781250 L p 2273874960 MEMNODE0 com_2273874768
10 24589.822266 MS MEMNODE0 No
19 24589.822266 L p 4000000 MEMNODE0 com_418
10 24590.402344 MS MEMNODE0 Co
18 24590.402344 L p 4000000 MEMNODE2 com_419
10 24590.412110 MS MEMNODE0 CoA
10 24592.470703 MS MEMNODE0 No
19 24592.470703 L p 2273874960 MEMNODE0 com_2273874768
10 24592.517578 MS MEMNODE0 No
19 24592.517578 L p 4000000 MEMNODE0 com_419
10 24593.646485 S 679 Fi
10 24593.648438 S 679 B
10 24593.648438 S 679 execute_on_all_wrapper
10 24593.697266 S 680 Fi
10 24593.697266 S 680 B
10 24593.699219 S 680 execute_on_all_wrapper
10 24593.882813 S 65 B
10 24593.882813 S 680 Po
10 24593.884766 S 680 B
10 24594.179688 S 64 B
10 24594.181641 S 679 Po
10 24594.183594 S 679 B
10 24594.507813 S 680 D
10 24594.507813 S 679 D
10 24594.507813 S 687 D
10 24594.511719 S 682 D
10 24594.513672 S 690 D
10 24594.513672 S 681 D
10 24594.515625 S 683 D
10 24594.517578 S 685 D
10 24594.523438 S 686 D
10 24594.523438 S 688 D
10 24594.525391 S 684 D
8 24594.527344 687 T
8 24594.527344 688 T
8 24594.527344 685 T
8 24594.527344 690 T
8 24594.527344 686 T
8 24594.529297 681 T
10 24594.531250 S 689 D
8 24594.531250 683 T
8 24594.531250 684 T
8 24594.531250 682 T
8 24594.533203 689 T
8 24661.923828 679 T
8 24737.357422 680 T
13 19332.380860 bw MEMNODE0 2441.001221
13 19332.380860 bw MEMNODE2 2441.001221
13 19334.019531 bw MEMNODE0 0.000000
13 19334.019531 bw MEMNODE2 0.000000
13 19409.097657 bw MEMNODE0 186.317322
13 19409.097657 bw MEMNODE2 186.317322
13 19410.494141 bw MEMNODE0 385.830231
13 19410.494141 bw MEMNODE2 385.830231
13 19411.902344 bw MEMNODE0 600.685425
13 19411.902344 bw MEMNODE2 600.685425
13 19413.310547 bw MEMNODE0 833.439148
13 19413.310547 bw MEMNODE2 833.439148
13 19414.746094 bw MEMNODE0 1087.785889
13 19414.746094 bw MEMNODE2 1087.785889
13 19416.158203 bw MEMNODE0 1367.682007
13 19416.158203 bw MEMNODE2 1367.682007
13 19417.580078 bw MEMNODE0 1679.212280
13 19417.580078 bw MEMNODE2 1679.212280
13 19418.992188 bw MEMNODE0 2029.897217
13 19418.992188 bw MEMNODE2 2029.897217
13 19420.419922 bw MEMNODE0 2431.702148
13 19420.419922 bw MEMNODE2 2431.702148
13 19421.830078 bw MEMNODE0 2901.104004
13 19421.830078 bw MEMNODE2 2901.104004
13 19423.246094 bw MEMNODE0 3466.069580
13 19423.246094 bw MEMNODE2 3466.069580
13 19424.660157 bw MEMNODE0 4174.965332
13 19424.660157 bw MEMNODE2 4174.965332
13 19426.080078 bw MEMNODE0 5127.523438
13 19426.080078 bw MEMNODE2 5127.523438
13 19427.500000 bw MEMNODE0 6580.005859
13 19427.500000 bw MEMNODE2 6580.005859
13 19428.919922 bw MEMNODE0 8972.529297
13 19428.919922 bw MEMNODE2 8972.529297
13 19430.253907 bw MEMNODE0 7520.046875
13 19430.253907 bw MEMNODE2 7520.046875
13 19430.279297 bw MEMNODE0 6567.488770
13 19430.279297 bw MEMNODE2 6567.488770
13 19430.302735 bw MEMNODE0 5858.592773
13 19430.302735 bw MEMNODE2 5858.592773
13 19430.326172 bw MEMNODE0 5293.627441
13 19430.326172 bw MEMNODE2 5293.627441
13 19430.351563 bw MEMNODE0 4824.225586
13 19430.351563 bw MEMNODE2 4824.225586
13 19430.375000 bw MEMNODE0 4422.420410
13 19430.375000 bw MEMNODE2 4422.420410
13 19430.398438 bw MEMNODE0 4071.735352
13 19430.398438 bw MEMNODE2 4071.735352
13 19430.419922 bw MEMNODE0 3760.205078
13 19430.419922 bw MEMNODE2 3760.205078
13 19430.449219 bw MEMNODE0 3480.309082
13 19430.449219 bw MEMNODE2 3480.309082
13 19430.472657 bw MEMNODE0 3225.962402
13 19430.472657 bw MEMNODE2 3225.962402
13 19430.496094 bw MEMNODE0 2993.208740
13 19430.496094 bw MEMNODE2 2993.208740
13 19430.519531 bw MEMNODE0 2778.353516
13 19430.519531 bw MEMNODE2 2778.353516
13 19430.542969 bw MEMNODE0 2578.840576
13 19430.542969 bw MEMNODE2 2578.840576
13 19430.566407 bw MEMNODE0 2392.523193
13 19430.566407 bw MEMNODE2 2392.523193
13 19430.591797 bw MEMNODE0 -0.000244
13 19430.591797 bw MEMNODE2 -0.000244
13 19439.214844 bw MEMNODE0 2763.832520
13 19439.214844 bw MEMNODE2 2763.832520
13 19440.662110 bw MEMNODE0 -0.000244
13 19440.662110 bw MEMNODE2 -0.000244
13 19452.294922 bw MEMNODE0 1416.320679
13 19452.294922 bw MEMNODE2 1416.320679
13 19453.796875 bw MEMNODE0 4143.351074
13 19453.796875 bw MEMNODE2 4143.351074
13 19455.119141 bw MEMNODE0 2727.030273
13 19455.119141 bw MEMNODE2 2727.030273
13 19455.263672 bw MEMNODE0 -0.000244
13 19455.263672 bw MEMNODE2 -0.000244
13 19470.265625 bw MEMNODE0 966.493408
13 19470.265625 bw MEMNODE2 966.493408
13 19471.660157 bw MEMNODE0 2437.757812
13 19471.660157 bw MEMNODE2 2437.757812
13 19473.062500 bw MEMNODE0 5175.725586
13 19473.062500 bw MEMNODE2 5175.725586
13 19474.378907 bw MEMNODE0 3704.461182
13 19474.378907 bw MEMNODE2 3704.461182
13 19474.404297 bw MEMNODE0 2737.967529
13 19474.404297 bw MEMNODE2 2737.967529
13 19474.523438 bw MEMNODE0 -0.000488
13 19474.523438 bw MEMNODE2 -0.000488
13 19492.810547 bw MEMNODE0 716.083435
13 19492.810547 bw MEMNODE2 716.083435
13 19494.193360 bw MEMNODE0 1673.540161
13 19494.193360 bw MEMNODE2 1673.540161
13 19495.603516 bw MEMNODE0 3131.191406
13 19495.603516 bw MEMNODE2 3131.191406
13 19497.019531 bw MEMNODE0 5847.372070
13 19497.019531 bw MEMNODE2 5847.372070
13 19498.347657 bw MEMNODE0 4389.720703
13 19498.347657 bw MEMNODE2 4389.720703
13 19498.371094 bw MEMNODE0 3432.263916
13 19498.371094 bw MEMNODE2 3432.263916
13 19498.396485 bw MEMNODE0 2716.179932
13 19498.396485 bw MEMNODE2 2716.179932
13 19498.492188 bw MEMNODE0 -0.000488
13 19498.492188 bw MEMNODE2 -0.000488
13 19520.128907 bw MEMNODE0 253.182846
13 19520.128907 bw MEMNODE2 253.182846
13 19521.511719 bw MEMNODE0 531.141602
13 19521.511719 bw MEMNODE2 531.141602
13 19522.943360 bw MEMNODE0 840.367065
13 19522.943360 bw MEMNODE2 840.367065
13 19533.125000 bw MEMNODE0 2306.365723
13 19533.125000 bw MEMNODE2 2306.365723
13 19534.533203 bw MEMNODE0 5044.333984
13 19534.533203 bw MEMNODE2 5044.333984
13 19535.853516 bw MEMNODE0 3578.335449
13 19535.853516 bw MEMNODE2 3578.335449
13 19535.878907 bw MEMNODE0 3269.110107
13 19535.878907 bw MEMNODE2 3269.110107
13 19535.902344 bw MEMNODE0 2991.151367
13 19535.902344 bw MEMNODE2 2991.151367
13 19535.927735 bw MEMNODE0 2737.968018
13 19535.927735 bw MEMNODE2 2737.968018
13 19535.994141 bw MEMNODE0 0.000000
13 19535.994141 bw MEMNODE2 0.000000
13 19561.115235 bw MEMNODE0 472.760864
13 19561.115235 bw MEMNODE2 472.760864
13 19562.500000 bw MEMNODE0 1039.916748
13 19562.500000 bw MEMNODE2 1039.916748
13 19563.898438 bw MEMNODE0 1750.287842
13 19563.898438 bw MEMNODE2 1750.287842
13 19565.308594 bw MEMNODE0 2703.289307
13 19565.308594 bw MEMNODE2 2703.289307
13 19566.734375 bw MEMNODE0 4159.903809
13 19566.734375 bw MEMNODE2 4159.903809
13 19568.152344 bw MEMNODE0 6890.570312
13 19568.152344 bw MEMNODE2 6890.570312
13 19569.480469 bw MEMNODE0 5433.956055
13 19569.480469 bw MEMNODE2 5433.956055
13 19569.505860 bw MEMNODE0 4480.954590
13 19569.505860 bw MEMNODE2 4480.954590
13 19569.529297 bw MEMNODE0 3770.583496
13 19569.529297 bw MEMNODE2 3770.583496
13 19569.552735 bw MEMNODE0 3203.427734
13 19569.552735 bw MEMNODE2 3203.427734
13 19569.576172 bw MEMNODE0 2730.666992
13 19569.576172 bw MEMNODE2 2730.666992
13 19569.617188 bw MEMNODE0 0.000244
13 19569.617188 bw MEMNODE2 0.000244
13 19597.763672 bw MEMNODE0 402.753448
13 19597.763672 bw MEMNODE2 402.753448
13 19599.138672 bw MEMNODE0 871.510620
13 19599.138672 bw MEMNODE2 871.510620
13 19600.562500 bw MEMNODE0 1436.164551
13 19600.562500 bw MEMNODE2 1436.164551
13 19601.980469 bw MEMNODE0 2145.060303
13 19601.980469 bw MEMNODE2 2145.060303
13 19603.394531 bw MEMNODE0 3096.291016
13 19603.394531 bw MEMNODE2 3096.291016
13 19604.814453 bw MEMNODE0 4545.689453
13 19604.814453 bw MEMNODE2 4545.689453
13 19606.238281 bw MEMNODE0 7247.536133
13 19606.238281 bw MEMNODE2 7247.536133
13 19607.574219 bw MEMNODE0 5798.137695
13 19607.574219 bw MEMNODE2 5798.137695
13 19607.599610 bw MEMNODE0 4846.906738
13 19607.599610 bw MEMNODE2 4846.906738
13 19607.623047 bw MEMNODE0 4138.010742
13 19607.623047 bw MEMNODE2 4138.010742
13 19607.646485 bw MEMNODE0 3573.356689
13 19607.646485 bw MEMNODE2 3573.356689
13 19607.671875 bw MEMNODE0 3104.599609
13 19607.671875 bw MEMNODE2 3104.599609
13 19607.695313 bw MEMNODE0 2701.846436
13 19607.695313 bw MEMNODE2 2701.846436
13 19607.718750 bw MEMNODE0 -0.000488
13 19607.718750 bw MEMNODE2 -0.000488
13 19639.449219 bw MEMNODE0 353.957336
13 19639.449219 bw MEMNODE2 353.957336
13 19640.835938 bw MEMNODE0 758.380737
13 19640.835938 bw MEMNODE2 758.380737
13 19642.236328 bw MEMNODE0 1230.923462
13 19642.236328 bw MEMNODE2 1230.923462
13 19643.646485 bw MEMNODE0 1799.812378
13 19643.646485 bw MEMNODE2 1799.812378
13 19645.048828 bw MEMNODE0 2513.898926
13 19645.048828 bw MEMNODE2 2513.898926
13 19646.466797 bw MEMNODE0 3475.401367
13 19646.466797 bw MEMNODE2 3475.401367
13 19647.871094 bw MEMNODE0 4940.351562
13 19647.871094 bw MEMNODE2 4940.351562
13 19649.275391 bw MEMNODE0 7610.495117
13 19649.275391 bw MEMNODE2 7610.495117
13 19650.601563 bw MEMNODE0 6145.544922
13 19650.601563 bw MEMNODE2 6145.544922
13 19650.626953 bw MEMNODE0 5184.042480
13 19650.626953 bw MEMNODE2 5184.042480
13 19650.650391 bw MEMNODE0 4469.956055
13 19650.650391 bw MEMNODE2 4469.956055
13 19650.677735 bw MEMNODE0 3901.067139
13 19650.677735 bw MEMNODE2 3901.067139
13 19650.701172 bw MEMNODE0 3428.524414
13 19650.701172 bw MEMNODE2 3428.524414
13 19650.726563 bw MEMNODE0 3024.101074
13 19650.726563 bw MEMNODE2 3024.101074
13 19650.750000 bw MEMNODE0 2670.143311
13 19650.750000 bw MEMNODE2 2670.143311
13 19650.773438 bw MEMNODE0 0.000000
13 19650.773438 bw MEMNODE2 0.000000
13 19685.769531 bw MEMNODE0 169.382187
13 19685.769531 bw MEMNODE2 169.382187
13 19687.156250 bw MEMNODE0 349.521179
13 19687.156250 bw MEMNODE2 349.521179
13 19688.566407 bw MEMNODE0 542.092896
13 19688.566407 bw MEMNODE2 542.092896
13 19689.974610 bw MEMNODE0 748.940674
13 19689.974610 bw MEMNODE2 748.940674
13 19691.386719 bw MEMNODE0 972.375122
13 19691.386719 bw MEMNODE2 972.375122
13 19703.654297 bw MEMNODE0 1685.218750
13 19703.654297 bw MEMNODE2 1685.218750
13 19705.066407 bw MEMNODE0 2643.571533
13 19705.066407 bw MEMNODE2 2643.571533
13 19706.484375 bw MEMNODE0 4108.521484
13 19706.484375 bw MEMNODE2 4108.521484
13 19707.894531 bw MEMNODE0 6751.102051
13 19707.894531 bw MEMNODE2 6751.102051
13 19709.214844 bw MEMNODE0 5286.152344
13 19709.214844 bw MEMNODE2 5286.152344
13 19709.240235 bw MEMNODE0 4327.799316
13 19709.240235 bw MEMNODE2 4327.799316
13 19709.265625 bw MEMNODE0 3614.955566
13 19709.265625 bw MEMNODE2 3614.955566
13 19709.289063 bw MEMNODE0 3391.521240
13 19709.289063 bw MEMNODE2 3391.521240
13 19709.312500 bw MEMNODE0 3184.673340
13 19709.312500 bw MEMNODE2 3184.673340
13 19709.337891 bw MEMNODE0 2992.101562
13 19709.337891 bw MEMNODE2 2992.101562
13 19709.361328 bw MEMNODE0 2811.962646
13 19709.361328 bw MEMNODE2 2811.962646
13 19709.384766 bw MEMNODE0 2642.580566
13 19709.384766 bw MEMNODE2 2642.580566
13 19709.408203 bw MEMNODE0 0.000000
13 19709.408203 bw MEMNODE2 0.000000
13 19757.757813 bw MEMNODE0 174.031265
13 19757.757813 bw MEMNODE2 174.031265
13 19767.919922 bw MEMNODE0 486.559875
13 19767.919922 bw MEMNODE2 486.559875
13 19769.328125 bw MEMNODE0 838.449951
13 19769.328125 bw MEMNODE2 838.449951
13 19770.744141 bw MEMNODE0 1241.361572
13 19770.744141 bw MEMNODE2 1241.361572
13 19772.169922 bw MEMNODE0 1713.142334
13 19772.169922 bw MEMNODE2 1713.142334
13 19773.585938 bw MEMNODE0 2281.557617
13 19773.585938 bw MEMNODE2 2281.557617
13 19774.990235 bw MEMNODE0 2994.649414
13 19774.990235 bw MEMNODE2 2994.649414
13 19776.396485 bw MEMNODE0 3952.106201
13 19776.396485 bw MEMNODE2 3952.106201
13 19777.810547 bw MEMNODE0 5411.835449
13 19777.810547 bw MEMNODE2 5411.835449
13 19779.224610 bw MEMNODE0 7994.433105
13 19779.224610 bw MEMNODE2 7994.433105
13 19780.550781 bw MEMNODE0 6534.704102
13 19780.550781 bw MEMNODE2 6534.704102
13 19780.574219 bw MEMNODE0 5577.247559
13 19780.574219 bw MEMNODE2 5577.247559
13 19780.599610 bw MEMNODE0 4864.155762
13 19780.599610 bw MEMNODE2 4864.155762
13 19780.623047 bw MEMNODE0 4295.740723
13 19780.623047 bw MEMNODE2 4295.740723
13 19780.648438 bw MEMNODE0 3823.959961
13 19780.648438 bw MEMNODE2 3823.959961
13 19780.671875 bw MEMNODE0 3421.048340
13 19780.671875 bw MEMNODE2 3421.048340
13 19780.695313 bw MEMNODE0 3069.158203
13 19780.695313 bw MEMNODE2 3069.158203
13 19780.718750 bw MEMNODE0 2756.629639
13 19780.718750 bw MEMNODE2 2756.629639
13 19780.742188 bw MEMNODE0 2582.598389
13 19780.742188 bw MEMNODE2 2582.598389
13 19780.773438 bw MEMNODE0 0.000732
13 19780.773438 bw MEMNODE2 0.000732
13 19822.453125 bw MEMNODE0 253.340668
13 19822.453125 bw MEMNODE2 253.340668
13 19823.837891 bw MEMNODE0 531.488159
13 19823.837891 bw MEMNODE2 531.488159
13 19825.273438 bw MEMNODE0 841.040771
13 19825.273438 bw MEMNODE2 841.040771
13 19826.693360 bw MEMNODE0 1189.517822
13 19826.693360 bw MEMNODE2 1189.517822
13 19828.103516 bw MEMNODE0 1587.806396
13 19828.103516 bw MEMNODE2 1587.806396
13 19829.630860 bw MEMNODE0 2058.936035
13 19829.630860 bw MEMNODE2 2058.936035
13 19831.042969 bw MEMNODE0 2625.935059
13 19831.042969 bw MEMNODE2 2625.935059
13 19832.460938 bw MEMNODE0 3338.530762
13 19832.460938 bw MEMNODE2 3338.530762
13 19833.869141 bw MEMNODE0 4295.093262
13 19833.869141 bw MEMNODE2 4295.093262
13 19835.283203 bw MEMNODE0 5754.822266
13 19835.283203 bw MEMNODE2 5754.822266
13 19836.703125 bw MEMNODE0 8311.625977
13 19836.703125 bw MEMNODE2 8311.625977
13 19838.023438 bw MEMNODE0 6851.896973
13 19838.023438 bw MEMNODE2 6851.896973
13 19838.050781 bw MEMNODE0 5895.334473
13 19838.050781 bw MEMNODE2 5895.334473
13 19838.074219 bw MEMNODE0 5182.738770
13 19838.074219 bw MEMNODE2 5182.738770
13 19838.097657 bw MEMNODE0 4615.739746
13 19838.097657 bw MEMNODE2 4615.739746
13 19838.121094 bw MEMNODE0 4144.610352
13 19838.121094 bw MEMNODE2 4144.610352
13 19838.146485 bw MEMNODE0 3746.321777
13 19838.146485 bw MEMNODE2 3746.321777
13 19838.171875 bw MEMNODE0 3397.844727
13 19838.171875 bw MEMNODE2 3397.844727
13 19838.195313 bw MEMNODE0 3088.291992
13 19838.195313 bw MEMNODE2 3088.291992
13 19838.218750 bw MEMNODE0 2810.144531
13 19838.218750 bw MEMNODE2 2810.144531
13 19838.242188 bw MEMNODE0 2556.804688
13 19838.242188 bw MEMNODE2 2556.804688
13 19838.267578 bw MEMNODE0 0.000732
13 19838.267578 bw MEMNODE2 0.000732
13 19883.283203 bw MEMNODE0 232.068726
13 19883.283203 bw MEMNODE2 232.068726
13 19884.695313 bw MEMNODE0 485.252075
13 19884.695313 bw MEMNODE2 485.252075
13 19886.121094 bw MEMNODE0 763.967407
13 19886.121094 bw MEMNODE2 763.967407
13 19887.546875 bw MEMNODE0 1073.988525
13 19887.546875 bw MEMNODE2 1073.988525
13 19888.957031 bw MEMNODE0 1422.940674
13 19888.957031 bw MEMNODE2 1422.940674
13 19890.369141 bw MEMNODE0 1821.927612
13 19890.369141 bw MEMNODE2 1821.927612
13 19891.785157 bw MEMNODE0 2287.911621
13 19891.785157 bw MEMNODE2 2287.911621
13 19893.226563 bw MEMNODE0 2849.777100
13 19893.226563 bw MEMNODE2 2849.777100
13 19894.662110 bw MEMNODE0 3556.715332
13 19894.662110 bw MEMNODE2 3556.715332
13 19896.093750 bw MEMNODE0 4508.388184
13 19896.093750 bw MEMNODE2 4508.388184
13 19897.533203 bw MEMNODE0 5969.158691
13 19897.533203 bw MEMNODE2 5969.158691
13 19898.949219 bw MEMNODE0 8478.962891
13 19898.949219 bw MEMNODE2 8478.962891
13 19900.271485 bw MEMNODE0 7018.192383
13 19900.271485 bw MEMNODE2 7018.192383
13 19900.296875 bw MEMNODE0 6066.519531
13 19900.296875 bw MEMNODE2 6066.519531
13 19900.320313 bw MEMNODE0 5359.581055
13 19900.320313 bw MEMNODE2 5359.581055
13 19900.345703 bw MEMNODE0 4797.715332
13 19900.345703 bw MEMNODE2 4797.715332
13 19900.369141 bw MEMNODE0 4331.731445
13 19900.369141 bw MEMNODE2 4331.731445
13 19900.394531 bw MEMNODE0 3932.744629
13 19900.394531 bw MEMNODE2 3932.744629
13 19900.419922 bw MEMNODE0 3583.792480
13 19900.419922 bw MEMNODE2 3583.792480
13 19900.449219 bw MEMNODE0 3273.771240
13 19900.449219 bw MEMNODE2 3273.771240
13 19900.472657 bw MEMNODE0 2995.055908
13 19900.472657 bw MEMNODE2 2995.055908
13 19900.494141 bw MEMNODE0 2741.872559
13 19900.494141 bw MEMNODE2 2741.872559
13 19900.519531 bw MEMNODE0 2509.804688
13 19900.519531 bw MEMNODE2 2509.804688
13 19900.542969 bw MEMNODE0 0.000732
13 19900.542969 bw MEMNODE2 0.000732
13 19948.773438 bw MEMNODE0 145.465607
13 19948.773438 bw MEMNODE2 145.465607
13 19950.166016 bw MEMNODE0 298.827881
13 19950.166016 bw MEMNODE2 298.827881
13 19960.421875 bw MEMNODE0 551.948608
13 19960.421875 bw MEMNODE2 551.948608
13 19961.839844 bw MEMNODE0 830.474365
13 19961.839844 bw MEMNODE2 830.474365
13 19963.263672 bw MEMNODE0 1140.167358
13 19963.263672 bw MEMNODE2 1140.167358
13 19964.685547 bw MEMNODE0 1488.881836
13 19964.685547 bw MEMNODE2 1488.881836
13 19966.099610 bw MEMNODE0 1887.558105
13 19966.099610 bw MEMNODE2 1887.558105
13 19967.537110 bw MEMNODE0 2354.179199
13 19967.537110 bw MEMNODE2 2354.179199
13 19968.988281 bw MEMNODE0 2917.745605
13 19968.988281 bw MEMNODE2 2917.745605
13 19970.423828 bw MEMNODE0 3627.378418
13 19970.423828 bw MEMNODE2 3627.378418
13 19971.832031 bw MEMNODE0 4579.051270
13 19971.832031 bw MEMNODE2 4579.051270
13 19973.246094 bw MEMNODE0 6026.401367
13 19973.246094 bw MEMNODE2 6026.401367
13 19974.679688 bw MEMNODE0 8502.822266
13 19974.679688 bw MEMNODE2 8502.822266
13 19976.009766 bw MEMNODE0 7055.472656
13 19976.009766 bw MEMNODE2 7055.472656
13 19976.035157 bw MEMNODE0 6103.799805
13 19976.035157 bw MEMNODE2 6103.799805
13 19976.060547 bw MEMNODE0 5394.166992
13 19976.060547 bw MEMNODE2 5394.166992
13 19976.085938 bw MEMNODE0 4830.600586
13 19976.085938 bw MEMNODE2 4830.600586
13 19976.109375 bw MEMNODE0 4363.979492
13 19976.109375 bw MEMNODE2 4363.979492
13 19976.132813 bw MEMNODE0 3965.303223
13 19976.132813 bw MEMNODE2 3965.303223
13 19976.156250 bw MEMNODE0 3616.588867
13 19976.156250 bw MEMNODE2 3616.588867
13 19976.179688 bw MEMNODE0 3306.895752
13 19976.179688 bw MEMNODE2 3306.895752
13 19976.201172 bw MEMNODE0 3028.370117
13 19976.201172 bw MEMNODE2 3028.370117
13 19976.224610 bw MEMNODE0 2775.249268
13 19976.224610 bw MEMNODE2 2775.249268
13 19976.248047 bw MEMNODE0 2621.886963
13 19976.248047 bw MEMNODE2 2621.886963
13 19976.271485 bw MEMNODE0 2476.422119
13 19976.271485 bw MEMNODE2 2476.422119
13 19976.294922 bw MEMNODE0 0.001221
13 19976.294922 bw MEMNODE2 0.001221
13 20027.886719 bw MEMNODE0 198.874786
13 20027.886719 bw MEMNODE2 198.874786
13 20029.281250 bw MEMNODE0 412.809814
13 20029.281250 bw MEMNODE2 412.809814
13 20030.703125 bw MEMNODE0 644.693848
13 20030.703125 bw MEMNODE2 644.693848
13 20032.132813 bw MEMNODE0 897.908508
13 20032.132813 bw MEMNODE2 897.908508
13 20033.550781 bw MEMNODE0 1176.547974
13 20033.550781 bw MEMNODE2 1176.547974
13 20034.966797 bw MEMNODE0 1486.240967
13 20034.966797 bw MEMNODE2 1486.240967
13 20036.392578 bw MEMNODE0 1835.074219
13 20036.392578 bw MEMNODE2 1835.074219
13 20037.835938 bw MEMNODE0 2235.074219
13 20037.835938 bw MEMNODE2 2235.074219
13 20039.251953 bw MEMNODE0 2702.333984
13 20039.251953 bw MEMNODE2 2702.333984
13 20040.681641 bw MEMNODE0 3265.280762
13 20040.681641 bw MEMNODE2 3265.280762
13 20042.099610 bw MEMNODE0 3971.487793
13 20042.099610 bw MEMNODE2 3971.487793
13 20043.523438 bw MEMNODE0 4920.514648
13 20043.523438 bw MEMNODE2 4920.514648
13 20044.943360 bw MEMNODE0 6364.802246
13 20044.943360 bw MEMNODE2 6364.802246
13 20046.380860 bw MEMNODE0 8794.220703
13 20046.380860 bw MEMNODE2 8794.220703
13 20047.712891 bw MEMNODE0 7349.933105
13 20047.712891 bw MEMNODE2 7349.933105
13 20047.738281 bw MEMNODE0 6400.906250
13 20047.738281 bw MEMNODE2 6400.906250
13 20047.763672 bw MEMNODE0 5694.699219
13 20047.763672 bw MEMNODE2 5694.699219
13 20047.787110 bw MEMNODE0 5131.752441
13 20047.787110 bw MEMNODE2 5131.752441
13 20047.812500 bw MEMNODE0 4664.492676
13 20047.812500 bw MEMNODE2 4664.492676
13 20047.835938 bw MEMNODE0 4264.492676
13 20047.835938 bw MEMNODE2 4264.492676
13 20047.859375 bw MEMNODE0 3915.659424
13 20047.859375 bw MEMNODE2 3915.659424
13 20047.882813 bw MEMNODE0 3605.966309
13 20047.882813 bw MEMNODE2 3605.966309
13 20047.906250 bw MEMNODE0 3327.326904
13 20047.906250 bw MEMNODE2 3327.326904
13 20047.929688 bw MEMNODE0 3074.112305
13 20047.929688 bw MEMNODE2 3074.112305
13 20047.953125 bw MEMNODE0 2842.228271
13 20047.953125 bw MEMNODE2 2842.228271
13 20047.978516 bw MEMNODE0 2628.293213
13 20047.978516 bw MEMNODE2 2628.293213
13 20048.000000 bw MEMNODE0 2429.419678
13 20048.000000 bw MEMNODE2 2429.419678
13 20048.027344 bw MEMNODE0 0.000977
13 20048.027344 bw MEMNODE2 0.000977
13 20103.089844 bw MEMNODE0 131.291443
13 20103.089844 bw MEMNODE2 131.291443
13 20104.494141 bw MEMNODE0 269.036926
13 20104.494141 bw MEMNODE2 269.036926
13 20105.912110 bw MEMNODE0 413.966492
13 20105.912110 bw MEMNODE2 413.966492
13 20107.337891 bw MEMNODE0 566.939331
13 20107.337891 bw MEMNODE2 566.939331
13 20108.767578 bw MEMNODE0 728.913391
13 20108.767578 bw MEMNODE2 728.913391
13 20110.195313 bw MEMNODE0 900.999756
13 20110.195313 bw MEMNODE2 900.999756
13 20111.634766 bw MEMNODE0 1084.693359
13 20111.634766 bw MEMNODE2 1084.693359
13 20113.070313 bw MEMNODE0 1281.578613
13 20113.070313 bw MEMNODE2 1281.578613
13 20123.271485 bw MEMNODE0 1677.940186
13 20123.271485 bw MEMNODE2 1677.940186
13 20124.718750 bw MEMNODE0 2141.918457
13 20124.718750 bw MEMNODE2 2141.918457
13 20126.156250 bw MEMNODE0 2700.717773
13 20126.156250 bw MEMNODE2 2700.717773
13 20127.605469 bw MEMNODE0 3404.256104
13 20127.605469 bw MEMNODE2 3404.256104
13 20129.041016 bw MEMNODE0 4350.651855
13 20129.041016 bw MEMNODE2 4350.651855
13 20130.484375 bw MEMNODE0 5801.076660
13 20130.484375 bw MEMNODE2 5801.076660
13 20131.914063 bw MEMNODE0 8202.014648
13 20131.914063 bw MEMNODE2 8202.014648
13 20133.242188 bw MEMNODE0 6751.589844
13 20133.242188 bw MEMNODE2 6751.589844
13 20133.267578 bw MEMNODE0 5805.194336
13 20133.267578 bw MEMNODE2 5805.194336
13 20133.291016 bw MEMNODE0 5101.656250
13 20133.291016 bw MEMNODE2 5101.656250
13 20133.314453 bw MEMNODE0 4542.856934
13 20133.314453 bw MEMNODE2 4542.856934
13 20133.339844 bw MEMNODE0 4078.878662
13 20133.339844 bw MEMNODE2 4078.878662
13 20133.363281 bw MEMNODE0 3682.517090
13 20133.363281 bw MEMNODE2 3682.517090
13 20133.386719 bw MEMNODE0 3485.631836
13 20133.386719 bw MEMNODE2 3485.631836
13 20133.410157 bw MEMNODE0 3301.938232
13 20133.410157 bw MEMNODE2 3301.938232
13 20133.439453 bw MEMNODE0 3129.851807
13 20133.439453 bw MEMNODE2 3129.851807
13 20133.462891 bw MEMNODE0 2967.877686
13 20133.462891 bw MEMNODE2 2967.877686
13 20133.486328 bw MEMNODE0 2814.904785
13 20133.486328 bw MEMNODE2 2814.904785
13 20133.511719 bw MEMNODE0 2669.975098
13 20133.511719 bw MEMNODE2 2669.975098
13 20133.533203 bw MEMNODE0 2532.229492
13 20133.533203 bw MEMNODE2 2532.229492
13 20133.556641 bw MEMNODE0 2400.938965
13 20133.556641 bw MEMNODE2 2400.938965
13 20133.580078 bw MEMNODE0 0.000977
13 20133.580078 bw MEMNODE2 0.000977
13 20264.916016 bw MEMNODE2 559.716736
13 20264.916016 bw MEMNODE0 559.716736
13 20264.945313 bw MEMNODE2 1122.045166
13 20264.945313 bw MEMNODE0 1122.045166
13 20264.974610 bw MEMNODE2 1560.401367
13 20264.974610 bw MEMNODE0 1560.401367
13 20264.978516 bw MEMNODE2 1730.190796
13 20264.978516 bw MEMNODE0 1730.190796
13 20272.058594 bw MEMNODE2 1167.862427
13 20272.058594 bw MEMNODE0 1167.862427
13 20272.060547 bw MEMNODE2 1410.660278
13 20272.060547 bw MEMNODE0 1410.660278
13 20272.062500 bw MEMNODE2 850.944519
13 20272.062500 bw MEMNODE0 850.944519
13 20274.099610 bw MEMNODE2 412.588348
13 20274.099610 bw MEMNODE0 412.588348
13 20274.103516 bw MEMNODE2 689.794617
13 20274.103516 bw MEMNODE0 689.794617
13 20276.130860 bw MEMNODE2 1012.415894
13 20276.130860 bw MEMNODE0 1012.415894
13 20278.156250 bw MEMNODE2 1398.103271
13 20278.156250 bw MEMNODE0 1398.103271
13 20288.527344 bw MEMNODE2 1012.415894
13 20288.527344 bw MEMNODE0 1012.415894
13 20288.529297 bw MEMNODE2 689.794556
13 20288.529297 bw MEMNODE0 689.794556
13 20288.533203 bw MEMNODE2 412.588287
13 20288.533203 bw MEMNODE0 412.588287
13 20288.535157 bw MEMNODE2 169.790421
13 20288.535157 bw MEMNODE0 169.790421
13 20288.537110 bw MEMNODE2 0.000992
13 20288.537110 bw MEMNODE0 0.000992
13 20288.539063 bw MEMNODE2 750.184143
13 20288.539063 bw MEMNODE0 750.184143
13 20288.705078 bw MEMNODE0 1347.617065
13 20288.705078 bw MEMNODE1 597.432922
13 20290.164063 bw MEMNODE0 2114.945801
13 20290.164063 bw MEMNODE1 1364.761475
13 20291.503907 bw MEMNODE0 3154.012207
13 20291.503907 bw MEMNODE1 2403.827881
13 20292.804688 bw MEMNODE0 4739.151367
13 20292.804688 bw MEMNODE1 3988.967285
13 20293.871094 bw MEMNODE2 0.000977
13 20293.871094 bw MEMNODE0 3988.968262
13 20294.119141 bw MEMNODE0 5518.467773
13 20294.119141 bw MEMNODE1 5518.466797
13 20295.328125 bw MEMNODE0 3933.328613
13 20295.328125 bw MEMNODE1 3933.327637
13 20295.353516 bw MEMNODE0 2894.262207
13 20295.353516 bw MEMNODE1 2894.261230
13 20295.376953 bw MEMNODE0 2126.933594
13 20295.376953 bw MEMNODE1 2126.932617
13 20295.400391 bw MEMNODE0 1529.500732
13 20295.400391 bw MEMNODE1 1529.499756
13 20295.523438 bw MEMNODE0 4467.807617
13 20295.523438 bw MEMNODE1 4467.806641
13 20296.734375 bw MEMNODE0 2938.308105
13 20296.734375 bw MEMNODE1 2938.307129
13 20296.884766 bw MEMNODE0 0.000977
13 20296.884766 bw MEMNODE1 0.000000
13 20305.330078 bw MEMNODE1 403.308380
13 20305.330078 bw MEMNODE0 403.309357
13 20315.248047 bw MEMNODE1 0.000000
13 20315.248047 bw MEMNODE0 0.000977
13 20315.251953 bw MEMNODE1 399.064697
13 20315.251953 bw MEMNODE0 399.065674
13 20315.253907 bw MEMNODE0 2866.535645
13 20315.253907 bw MEMNODE2 2467.470947
13 20316.875000 bw MEMNODE0 399.065674
13 20316.875000 bw MEMNODE2 0.000977
13 20325.275391 bw MEMNODE1 0.000000
13 20325.275391 bw MEMNODE0 0.000977
13 20325.277344 bw MEMNODE0 2449.761719
13 20325.277344 bw MEMNODE2 2449.761719
13 20325.277344 bw MEMNODE1 397.130127
13 20325.277344 bw MEMNODE0 2846.891846
13 20326.910157 bw MEMNODE0 397.131104
13 20326.910157 bw MEMNODE2 0.000977
13 20335.349610 bw MEMNODE1 0.000000
13 20335.349610 bw MEMNODE0 0.000977
13 20335.351563 bw MEMNODE1 395.748779
13 20335.351563 bw MEMNODE0 395.749756
13 20335.351563 bw MEMNODE0 2975.094727
13 20335.351563 bw MEMNODE2 2579.345947
13 20336.902344 bw MEMNODE0 395.749756
13 20336.902344 bw MEMNODE2 0.000977
13 20345.349610 bw MEMNODE0 1000.414673
13 20345.349610 bw MEMNODE2 604.665894
13 20345.458985 bw MEMNODE1 0.000000
13 20345.458985 bw MEMNODE0 604.665894
13 20345.462891 bw MEMNODE1 2389.731689
13 20345.462891 bw MEMNODE0 2994.397461
13 20346.667969 bw MEMNODE0 3753.197021
13 20346.667969 bw MEMNODE2 1363.465454
13 20347.136719 bw MEMNODE1 0.000000
13 20347.136719 bw MEMNODE0 1363.465332
13 20347.996094 bw MEMNODE0 2384.402588
13 20347.996094 bw MEMNODE2 2384.402588
13 20349.273438 bw MEMNODE0 3912.760742
13 20349.273438 bw MEMNODE2 3912.760742
13 20350.566407 bw MEMNODE0 4748.679199
13 20350.566407 bw MEMNODE2 4748.679199
13 20351.890625 bw MEMNODE0 3220.321045
13 20351.890625 bw MEMNODE2 3220.321045
13 20351.914063 bw MEMNODE0 2199.383789
13 20351.914063 bw MEMNODE2 2199.383789
13 20351.939453 bw MEMNODE0 1440.584229
13 20351.939453 bw MEMNODE2 1440.584229
13 20351.964844 bw MEMNODE0 835.919312
13 20351.964844 bw MEMNODE2 835.919312
13 20355.351563 bw MEMNODE0 0.000916
13 20355.351563 bw MEMNODE2 0.000916
13 20809.800781 bw MEMNODE2 703.297607
13 20809.800781 bw MEMNODE0 703.297607
13 20809.828125 bw MEMNODE2 1220.599976
13 20809.828125 bw MEMNODE0 1220.599976
13 20809.832031 bw MEMNODE2 1385.588257
13 20809.832031 bw MEMNODE0 1385.588257
13 20815.488281 bw MEMNODE2 682.291565
13 20815.488281 bw MEMNODE0 682.291565
13 20815.490235 bw MEMNODE2 897.530640
13 20815.490235 bw MEMNODE0 897.530640
13 20817.560547 bw MEMNODE2 380.228271
13 20817.560547 bw MEMNODE0 380.228271
13 20817.562500 bw MEMNODE2 622.509155
13 20817.562500 bw MEMNODE0 622.509155
13 20819.605469 bw MEMNODE2 899.041687
13 20819.605469 bw MEMNODE0 899.041687
13 20821.638672 bw MEMNODE2 1220.851807
13 20821.638672 bw MEMNODE0 1220.851807
13 20823.679688 bw MEMNODE2 1605.958984
13 20823.679688 bw MEMNODE0 1605.958984
13 20834.066407 bw MEMNODE2 1220.851807
13 20834.066407 bw MEMNODE0 1220.851807
13 20834.068360 bw MEMNODE2 899.041626
13 20834.068360 bw MEMNODE0 899.041626
13 20834.070313 bw MEMNODE2 622.509094
13 20834.070313 bw MEMNODE0 622.509094
13 20834.072266 bw MEMNODE2 380.228241
13 20834.072266 bw MEMNODE0 380.228241
13 20834.074219 bw MEMNODE2 164.989151
13 20834.074219 bw MEMNODE0 164.989151
13 20834.076172 bw MEMNODE2 0.000839
13 20834.076172 bw MEMNODE0 0.000839
13 20834.210938 bw MEMNODE0 513.670288
13 20834.210938 bw MEMNODE1 513.669434
13 20835.492188 bw MEMNODE0 1130.909668
13 20835.492188 bw MEMNODE1 1130.908691
13 20836.787110 bw MEMNODE0 1906.080078
13 20836.787110 bw MEMNODE1 1906.079102
13 20838.089844 bw MEMNODE0 2949.381104
13 20838.089844 bw MEMNODE1 2949.380127
13 20839.398438 bw MEMNODE0 4549.380859
13 20839.398438 bw MEMNODE1 4549.379883
13 20840.693360 bw MEMNODE0 7496.143555
13 20840.693360 bw MEMNODE1 7496.142578
13 20841.898438 bw MEMNODE0 5896.143555
13 20841.898438 bw MEMNODE1 5896.142578
13 20841.923828 bw MEMNODE0 4852.842773
13 20841.923828 bw MEMNODE1 4852.841797
13 20841.947266 bw MEMNODE0 4077.672363
13 20841.947266 bw MEMNODE1 4077.671387
13 20841.972657 bw MEMNODE0 3460.433105
13 20841.972657 bw MEMNODE1 3460.432129
13 20841.998047 bw MEMNODE0 2946.763672
13 20841.998047 bw MEMNODE1 2946.762695
13 20842.050781 bw MEMNODE0 0.000977
13 20842.050781 bw MEMNODE1 0.000000
13 20850.494141 bw MEMNODE1 397.053131
13 20850.494141 bw MEMNODE0 397.054108
13 20860.568360 bw MEMNODE1 0.000000
13 20860.568360 bw MEMNODE0 0.000977
13 20860.570313 bw MEMNODE1 400.156311
13 20860.570313 bw MEMNODE0 400.157288
13 20860.572266 bw MEMNODE0 2969.793457
13 20860.572266 bw MEMNODE2 2569.636963
13 20862.128907 bw MEMNODE0 400.157227
13 20862.128907 bw MEMNODE2 0.000732
13 20870.566407 bw MEMNODE1 0.000000
13 20870.566407 bw MEMNODE0 0.000916
13 20870.568360 bw MEMNODE0 2625.642090
13 20870.568360 bw MEMNODE2 2625.641846
13 20870.568360 bw MEMNODE1 398.288605
13 20870.568360 bw MEMNODE0 3023.930664
13 20872.091797 bw MEMNODE0 398.289551
13 20872.091797 bw MEMNODE2 0.000732
13 20880.611328 bw MEMNODE1 0.000000
13 20880.611328 bw MEMNODE0 0.000946
13 20880.615235 bw MEMNODE1 394.377045
13 20880.615235 bw MEMNODE0 394.377991
13 20880.615235 bw MEMNODE0 3050.668457
13 20880.615235 bw MEMNODE2 2656.291260
13 20882.121094 bw MEMNODE0 394.377930
13 20882.121094 bw MEMNODE2 0.000732
13 20885.371094 bw MEMNODE0 1989.393555
13 20885.371094 bw MEMNODE2 1595.016357
13 20886.597657 bw MEMNODE0 4775.788086
13 20886.597657 bw MEMNODE2 4381.411133
13 20887.878907 bw MEMNODE0 3180.772461
13 20887.878907 bw MEMNODE2 2786.395508
13 20888.033203 bw MEMNODE0 394.377930
13 20888.033203 bw MEMNODE2 0.000977
13 20890.757813 bw MEMNODE1 0.000000
13 20890.757813 bw MEMNODE0 0.000885
13 20890.759766 bw MEMNODE1 2449.760742
13 20890.759766 bw MEMNODE0 2449.761719
13 20891.275391 bw MEMNODE0 3972.438477
13 20891.275391 bw MEMNODE2 1522.677612
13 20892.392578 bw MEMNODE1 0.000000
13 20892.392578 bw MEMNODE0 1522.677734
13 20892.582031 bw MEMNODE0 4235.260742
13 20892.582031 bw MEMNODE2 4235.260254
13 20893.902344 bw MEMNODE0 2712.583984
13 20893.902344 bw MEMNODE2 2712.583496
13 20894.056641 bw MEMNODE0 0.001221
13 20894.056641 bw MEMNODE2 0.000732
13 21278.162110 bw MEMNODE2 646.669495
13 21278.162110 bw MEMNODE0 646.669983
13 21278.164063 bw MEMNODE2 822.993225
13 21278.164063 bw MEMNODE0 822.993713
13 21282.308594 bw MEMNODE2 1038.753906
13 21282.308594 bw MEMNODE0 1038.754395
13 21284.347657 bw MEMNODE2 392.085144
13 21284.347657 bw MEMNODE0 392.085632
13 21284.351563 bw MEMNODE2 634.624207
13 21284.351563 bw MEMNODE0 634.624695
13 21286.375000 bw MEMNODE2 911.119385
13 21286.375000 bw MEMNODE0 911.119873
13 21288.404297 bw MEMNODE2 1232.777954
13 21288.404297 bw MEMNODE0 1232.778442
13 21290.453125 bw MEMNODE2 1617.957520
13 21290.453125 bw MEMNODE0 1617.958008
13 21300.837891 bw MEMNODE2 1232.777832
13 21300.837891 bw MEMNODE0 1232.778320
13 21300.839844 bw MEMNODE2 911.119263
13 21300.839844 bw MEMNODE0 911.119751
13 21300.841797 bw MEMNODE2 634.624023
13 21300.841797 bw MEMNODE0 634.624512
13 21300.843750 bw MEMNODE2 392.084961
13 21300.843750 bw MEMNODE0 392.085449
13 21300.847657 bw MEMNODE2 176.324326
13 21300.847657 bw MEMNODE0 176.324814
13 21300.849610 bw MEMNODE2 0.000610
13 21300.849610 bw MEMNODE0 0.001099
13 21300.970703 bw MEMNODE0 516.650940
13 21300.970703 bw MEMNODE1 516.649841
13 21302.234375 bw MEMNODE0 1136.318115
13 21302.234375 bw MEMNODE1 1136.317017
13 21303.521485 bw MEMNODE0 1914.138184
13 21303.521485 bw MEMNODE1 1914.136963
13 21304.806641 bw MEMNODE0 2957.439209
13 21304.806641 bw MEMNODE1 2957.437988
13 21306.095703 bw MEMNODE0 4546.267578
13 21306.095703 bw MEMNODE1 4546.266602
13 21307.388672 bw MEMNODE0 7451.232422
13 21307.388672 bw MEMNODE1 7451.231445
13 21308.613281 bw MEMNODE0 5862.403809
13 21308.613281 bw MEMNODE1 5862.402832
13 21308.640625 bw MEMNODE0 4819.102539
13 21308.640625 bw MEMNODE1 4819.101562
13 21308.664063 bw MEMNODE0 4041.282471
13 21308.664063 bw MEMNODE1 4041.281494
13 21308.689453 bw MEMNODE0 3421.615234
13 21308.689453 bw MEMNODE1 3421.614258
13 21308.712891 bw MEMNODE0 2904.965332
13 21308.712891 bw MEMNODE1 2904.964355
13 21308.765625 bw MEMNODE0 0.000732
13 21308.765625 bw MEMNODE1 -0.000244
13 21317.214844 bw MEMNODE1 397.592468
13 21317.214844 bw MEMNODE0 397.593445
13 21327.275391 bw MEMNODE1 -0.000244
13 21327.275391 bw MEMNODE0 0.000732
13 21327.277344 bw MEMNODE0 2677.125000
13 21327.277344 bw MEMNODE2 2677.125000
13 21327.279297 bw MEMNODE1 397.438141
13 21327.279297 bw MEMNODE0 3074.563477
13 21328.771485 bw MEMNODE0 397.439209
13 21328.771485 bw MEMNODE2 0.000732
13 21337.343750 bw MEMNODE1 -0.000244
13 21337.343750 bw MEMNODE0 0.000824
13 21337.345703 bw MEMNODE0 2659.740967
13 21337.345703 bw MEMNODE2 2659.740967
13 21337.345703 bw MEMNODE1 399.142212
13 21337.345703 bw MEMNODE0 3058.883301
13 21338.849610 bw MEMNODE0 399.143066
13 21338.849610 bw MEMNODE2 0.000732
13 21347.367188 bw MEMNODE1 -0.000244
13 21347.367188 bw MEMNODE0 0.000610
13 21347.369141 bw MEMNODE1 396.054688
13 21347.369141 bw MEMNODE0 396.055542
13 21347.369141 bw MEMNODE0 3076.683594
13 21347.369141 bw MEMNODE2 2680.628906
13 21348.861328 bw MEMNODE0 396.055420
13 21348.861328 bw MEMNODE2 0.000732
13 21352.181641 bw MEMNODE0 3296.905273
13 21352.181641 bw MEMNODE2 2900.850586
13 21353.560547 bw MEMNODE0 396.055420
13 21353.560547 bw MEMNODE2 0.000732
13 21357.468750 bw MEMNODE1 -0.000244
13 21357.468750 bw MEMNODE0 0.000488
13 21357.470703 bw MEMNODE1 2515.970215
13 21357.470703 bw MEMNODE0 2515.970947
13 21359.060547 bw MEMNODE1 -0.000244
13 21359.060547 bw MEMNODE0 0.000488
13 21360.044922 bw MEMNODE0 1543.331299
13 21360.044922 bw MEMNODE2 1543.331543
13 21361.300781 bw MEMNODE0 4238.068359
13 21361.300781 bw MEMNODE2 4238.068359
13 21362.636719 bw MEMNODE0 2694.737549
13 21362.636719 bw MEMNODE2 2694.737549
13 21362.785157 bw MEMNODE0 0.000732
13 21362.785157 bw MEMNODE2 0.000732
13 21712.107422 bw MEMNODE2 127.142525
13 21712.107422 bw MEMNODE0 127.142525
13 21714.160157 bw MEMNODE2 263.168030
13 21714.160157 bw MEMNODE0 263.168030
13 21716.183594 bw MEMNODE2 409.255493
13 21716.183594 bw MEMNODE0 409.255493
13 21718.218750 bw MEMNODE2 567.097534
13 21718.218750 bw MEMNODE0 567.097534
13 21731.154297 bw MEMNODE2 889.566406
13 21731.154297 bw MEMNODE0 889.566406
13 21733.183594 bw MEMNODE2 1275.181152
13 21733.183594 bw MEMNODE0 1275.181152
13 21743.556641 bw MEMNODE2 889.566406
13 21743.556641 bw MEMNODE0 889.566406
13 21743.558594 bw MEMNODE2 567.097534
13 21743.558594 bw MEMNODE0 567.097534
13 21743.560547 bw MEMNODE2 409.255524
13 21743.560547 bw MEMNODE0 409.255524
13 21743.564453 bw MEMNODE2 263.168091
13 21743.564453 bw MEMNODE0 263.168091
13 21743.566407 bw MEMNODE2 127.142593
13 21743.566407 bw MEMNODE0 127.142593
13 21743.568360 bw MEMNODE2 0.000801
13 21743.568360 bw MEMNODE0 0.000801
13 21743.687500 bw MEMNODE0 518.744446
13 21743.687500 bw MEMNODE1 518.743408
13 21744.947266 bw MEMNODE0 1141.047607
13 21744.947266 bw MEMNODE1 1141.046631
13 21746.230469 bw MEMNODE0 1922.130737
13 21746.230469 bw MEMNODE1 1922.129761
13 21747.517578 bw MEMNODE0 2972.387207
13 21747.517578 bw MEMNODE1 2972.386230
13 21748.806641 bw MEMNODE0 4576.145996
13 21748.806641 bw MEMNODE1 4576.145020
13 21750.097657 bw MEMNODE0 7518.674805
13 21750.097657 bw MEMNODE1 7518.673828
13 21751.300781 bw MEMNODE0 5914.916016
13 21751.300781 bw MEMNODE1 5914.915039
13 21751.326172 bw MEMNODE0 4864.659668
13 21751.326172 bw MEMNODE1 4864.658691
13 21751.351563 bw MEMNODE0 4083.576660
13 21751.351563 bw MEMNODE1 4083.575684
13 21751.375000 bw MEMNODE0 3461.273438
13 21751.375000 bw MEMNODE1 3461.272461
13 21751.398438 bw MEMNODE0 2942.529785
13 21751.398438 bw MEMNODE1 2942.528809
13 21751.457031 bw MEMNODE0 0.000977
13 21751.457031 bw MEMNODE1 0.000000
13 21759.908203 bw MEMNODE1 396.361511
13 21759.908203 bw MEMNODE0 396.362488
13 21770.000000 bw MEMNODE1 0.000000
13 21770.000000 bw MEMNODE0 0.000977
13 21770.001953 bw MEMNODE1 402.120544
13 21770.001953 bw MEMNODE0 402.121521
13 21770.001953 bw MEMNODE0 3044.702148
13 21770.001953 bw MEMNODE2 2642.581299
13 21771.515625 bw MEMNODE0 402.121582
13 21771.515625 bw MEMNODE2 0.000732
13 21779.949219 bw MEMNODE1 0.000000
13 21779.949219 bw MEMNODE0 0.001038
13 21779.951172 bw MEMNODE0 2670.144287
13 21779.951172 bw MEMNODE2 2670.144043
13 21779.951172 bw MEMNODE1 398.753906
13 21779.951172 bw MEMNODE0 3068.898193
13 21781.449219 bw MEMNODE0 398.754883
13 21781.449219 bw MEMNODE2 0.000732
13 21789.982422 bw MEMNODE1 0.000000
13 21789.982422 bw MEMNODE0 0.000977
13 21789.984375 bw MEMNODE0 2684.142578
13 21789.984375 bw MEMNODE2 2684.142334
13 21789.984375 bw MEMNODE1 397.053131
13 21789.984375 bw MEMNODE0 3081.195801
13 21791.474610 bw MEMNODE0 397.054199
13 21791.474610 bw MEMNODE2 0.000732
13 21800.058594 bw MEMNODE1 0.000000
13 21800.058594 bw MEMNODE0 0.001068
13 21800.060547 bw MEMNODE1 2452.694580
13 21800.060547 bw MEMNODE0 2452.695557
13 21800.060547 bw MEMNODE0 5129.819824
13 21800.060547 bw MEMNODE2 2677.125000
13 21801.554688 bw MEMNODE0 2452.695557
13 21801.554688 bw MEMNODE2 0.000732
13 21801.691407 bw MEMNODE1 0.000000
13 21801.691407 bw MEMNODE0 0.000977
13 21804.808594 bw MEMNODE0 2763.833740
13 21804.808594 bw MEMNODE2 2763.833496
13 21806.255860 bw MEMNODE0 0.000977
13 21806.255860 bw MEMNODE2 0.000732
13 22108.189453 bw MEMNODE2 216.011703
13 22108.189453 bw MEMNODE0 216.011948
13 22110.236328 bw MEMNODE2 458.895935
13 22110.236328 bw MEMNODE0 458.896179
13 22112.273438 bw MEMNODE2 736.102173
13 22112.273438 bw MEMNODE0 736.102417
13 22114.296875 bw MEMNODE2 1058.621826
13 22114.296875 bw MEMNODE0 1058.622070
13 22116.335938 bw MEMNODE2 1444.672729
13 22116.335938 bw MEMNODE0 1444.672974
13 22126.697266 bw MEMNODE2 1058.621826
13 22126.697266 bw MEMNODE0 1058.622070
13 22126.699219 bw MEMNODE2 736.102173
13 22126.699219 bw MEMNODE0 736.102417
13 22126.703125 bw MEMNODE2 458.895905
13 22126.703125 bw MEMNODE0 458.896149
13 22126.705078 bw MEMNODE2 216.011658
13 22126.705078 bw MEMNODE0 216.011902
13 22126.707031 bw MEMNODE2 0.000687
13 22126.707031 bw MEMNODE0 0.000931
13 22126.828125 bw MEMNODE0 263.816467
13 22126.828125 bw MEMNODE1 263.815521
13 22128.097657 bw MEMNODE0 552.226562
13 22128.097657 bw MEMNODE1 552.225586
13 22138.125000 bw MEMNODE0 1600.333008
13 22138.125000 bw MEMNODE1 1600.332031
13 22139.423828 bw MEMNODE0 3205.348633
13 22139.423828 bw MEMNODE1 3205.347656
13 22140.714844 bw MEMNODE0 6169.168945
13 22140.714844 bw MEMNODE1 6169.167969
13 22141.916016 bw MEMNODE0 4564.153320
13 22141.916016 bw MEMNODE1 4564.152344
13 22141.941407 bw MEMNODE0 3516.046875
13 22141.941407 bw MEMNODE1 3516.045898
13 22141.966797 bw MEMNODE0 3227.636719
13 22141.966797 bw MEMNODE1 3227.635742
13 22141.990235 bw MEMNODE0 2963.821289
13 22141.990235 bw MEMNODE1 2963.820312
13 22142.064453 bw MEMNODE0 0.000732
13 22142.064453 bw MEMNODE1 -0.000244
13 22150.519531 bw MEMNODE1 403.546539
13 22150.519531 bw MEMNODE0 403.547516
13 22160.431641 bw MEMNODE1 -0.000244
13 22160.431641 bw MEMNODE0 0.000732
13 22160.437500 bw MEMNODE1 400.704132
13 22160.437500 bw MEMNODE0 400.705109
13 22160.437500 bw MEMNODE0 3091.900879
13 22160.437500 bw MEMNODE2 2691.196533
13 22161.923828 bw MEMNODE0 400.705078
13 22161.923828 bw MEMNODE2 0.000732
13 22170.419922 bw MEMNODE1 -0.000244
13 22170.419922 bw MEMNODE0 0.000702
13 22170.421875 bw MEMNODE0 2673.629883
13 22170.421875 bw MEMNODE2 2673.629883
13 22170.421875 bw MEMNODE1 398.210907
13 22170.421875 bw MEMNODE0 3071.841064
13 22171.917969 bw MEMNODE0 398.211914
13 22171.917969 bw MEMNODE2 0.000732
13 22180.466797 bw MEMNODE1 -0.000244
13 22180.466797 bw MEMNODE0 0.000763
13 22180.468750 bw MEMNODE0 2687.664795
13 22180.468750 bw MEMNODE2 2687.664795
13 22180.468750 bw MEMNODE1 2488.456543
13 22180.468750 bw MEMNODE0 5176.121582
13 22181.957031 bw MEMNODE0 2488.457520
13 22181.957031 bw MEMNODE2 0.000732
13 22182.076172 bw MEMNODE1 -0.000244
13 22182.076172 bw MEMNODE0 0.000732
13 22185.195313 bw MEMNODE0 2752.688965
13 22185.195313 bw MEMNODE2 2752.688965
13 22186.648438 bw MEMNODE0 0.000732
13 22186.648438 bw MEMNODE2 0.000732
13 22464.351563 bw MEMNODE2 215.829590
13 22464.351563 bw MEMNODE0 215.829590
13 22466.390625 bw MEMNODE2 458.368652
13 22466.390625 bw MEMNODE0 458.368652
13 22468.425781 bw MEMNODE2 735.125366
13 22468.425781 bw MEMNODE0 735.125366
13 22470.455078 bw MEMNODE2 1057.137939
13 22470.455078 bw MEMNODE0 1057.137939
13 22472.503907 bw MEMNODE2 1442.897949
13 22472.503907 bw MEMNODE0 1442.897949
13 22482.873047 bw MEMNODE2 1057.137939
13 22482.873047 bw MEMNODE0 1057.137939
13 22482.876953 bw MEMNODE2 735.125366
13 22482.876953 bw MEMNODE0 735.125366
13 22482.878907 bw MEMNODE2 458.368622
13 22482.878907 bw MEMNODE0 458.368622
13 22482.882813 bw MEMNODE2 215.829544
13 22482.882813 bw MEMNODE0 215.829544
13 22482.884766 bw MEMNODE2 0.000687
13 22482.884766 bw MEMNODE0 0.000687
13 22483.009766 bw MEMNODE0 625.344177
13 22483.009766 bw MEMNODE1 625.343262
13 22484.271485 bw MEMNODE0 1407.919678
13 22484.271485 bw MEMNODE1 1407.918701
13 22485.562500 bw MEMNODE0 2461.959961
13 22485.562500 bw MEMNODE1 2461.958984
13 22486.845703 bw MEMNODE0 4070.758057
13 22486.845703 bw MEMNODE1 4070.757080
13 22488.128907 bw MEMNODE0 7021.766602
13 22488.128907 bw MEMNODE1 7021.765625
13 22489.332031 bw MEMNODE0 5412.968750
13 22489.332031 bw MEMNODE1 5412.967773
13 22489.357422 bw MEMNODE0 4358.928711
13 22489.357422 bw MEMNODE1 4358.927734
13 22489.382813 bw MEMNODE0 3576.353271
13 22489.382813 bw MEMNODE1 3576.352295
13 22489.406250 bw MEMNODE0 2951.009766
13 22489.406250 bw MEMNODE1 2951.008789
13 22489.484375 bw MEMNODE0 0.001221
13 22489.484375 bw MEMNODE1 0.000244
13 22497.941407 bw MEMNODE1 403.229218
13 22497.941407 bw MEMNODE0 403.230194
13 22507.861328 bw MEMNODE1 0.000244
13 22507.861328 bw MEMNODE0 0.001221
13 22507.863281 bw MEMNODE1 402.199768
13 22507.863281 bw MEMNODE0 402.200745
13 22507.863281 bw MEMNODE0 3055.050537
13 22507.863281 bw MEMNODE2 2652.850586
13 22509.371094 bw MEMNODE0 402.200684
13 22509.371094 bw MEMNODE2 0.000732
13 22517.808594 bw MEMNODE1 0.000244
13 22517.808594 bw MEMNODE0 0.001160
13 22517.812500 bw MEMNODE0 2687.665283
13 22517.812500 bw MEMNODE2 2687.664795
13 22517.812500 bw MEMNODE1 398.909485
13 22517.812500 bw MEMNODE0 3086.574463
13 22519.300781 bw MEMNODE0 398.910400
13 22519.300781 bw MEMNODE2 0.000732
13 22527.839844 bw MEMNODE1 0.000244
13 22527.839844 bw MEMNODE0 0.001160
13 22527.841797 bw MEMNODE0 2666.667969
13 22527.841797 bw MEMNODE2 2666.667480
13 22527.841797 bw MEMNODE1 2479.419189
13 22527.841797 bw MEMNODE0 5146.086914
13 22529.341797 bw MEMNODE0 2479.420166
13 22529.341797 bw MEMNODE2 0.000732
13 22529.455078 bw MEMNODE1 0.000244
13 22529.455078 bw MEMNODE0 0.001221
13 22532.652344 bw MEMNODE0 2767.568848
13 22532.652344 bw MEMNODE2 2767.568359
13 22534.097657 bw MEMNODE0 0.001221
13 22534.097657 bw MEMNODE2 0.000732
13 22785.583985 bw MEMNODE2 215.715927
13 22785.583985 bw MEMNODE0 215.716415
13 22787.623047 bw MEMNODE2 458.111481
13 22787.623047 bw MEMNODE0 458.111969
13 22789.652344 bw MEMNODE2 734.532043
13 22789.652344 bw MEMNODE0 734.532532
13 22791.685547 bw MEMNODE2 1056.241089
13 22791.685547 bw MEMNODE0 1056.241577
13 22793.710938 bw MEMNODE2 1440.625488
13 22793.710938 bw MEMNODE0 1440.625977
13 22804.117188 bw MEMNODE2 1056.241089
13 22804.117188 bw MEMNODE0 1056.241577
13 22804.119141 bw MEMNODE2 734.531982
13 22804.119141 bw MEMNODE0 734.532471
13 22804.123047 bw MEMNODE2 458.111420
13 22804.123047 bw MEMNODE0 458.111908
13 22804.125000 bw MEMNODE2 215.715866
13 22804.125000 bw MEMNODE0 215.716354
13 22804.126953 bw MEMNODE2 0.000671
13 22804.126953 bw MEMNODE0 0.001160
13 22804.251953 bw MEMNODE0 624.391418
13 22804.251953 bw MEMNODE1 624.390503
13 22805.521485 bw MEMNODE0 1406.667969
13 22805.521485 bw MEMNODE1 1406.666992
13 22806.804688 bw MEMNODE0 2458.002686
13 22806.804688 bw MEMNODE1 2458.001709
13 22808.095703 bw MEMNODE0 4066.800781
13 22808.095703 bw MEMNODE1 4066.799805
13 22809.380860 bw MEMNODE0 7026.338379
13 22809.380860 bw MEMNODE1 7026.337402
13 22810.582031 bw MEMNODE0 5417.540039
13 22810.582031 bw MEMNODE1 5417.539062
13 22810.609375 bw MEMNODE0 4366.205078
13 22810.609375 bw MEMNODE1 4366.204102
13 22810.634766 bw MEMNODE0 3583.928467
13 22810.634766 bw MEMNODE1 3583.927490
13 22810.658203 bw MEMNODE0 2959.538086
13 22810.658203 bw MEMNODE1 2959.537109
13 22810.732422 bw MEMNODE0 0.000488
13 22810.732422 bw MEMNODE1 -0.000488
13 22819.185547 bw MEMNODE1 403.546295
13 22819.185547 bw MEMNODE0 403.547272
13 22829.097657 bw MEMNODE1 -0.000488
13 22829.097657 bw MEMNODE0 0.000488
13 22829.099610 bw MEMNODE1 402.357086
13 22829.099610 bw MEMNODE0 402.358063
13 22829.101563 bw MEMNODE0 3055.208008
13 22829.101563 bw MEMNODE2 2652.850586
13 22830.609375 bw MEMNODE0 402.358154
13 22830.609375 bw MEMNODE2 0.000732
13 22839.041016 bw MEMNODE1 -0.000488
13 22839.041016 bw MEMNODE0 0.000580
13 22839.044922 bw MEMNODE0 2694.737305
13 22839.044922 bw MEMNODE2 2694.737549
13 22839.044922 bw MEMNODE1 399.141968
13 22839.044922 bw MEMNODE0 3093.879883
13 22840.529297 bw MEMNODE0 399.143066
13 22840.529297 bw MEMNODE2 0.000732
13 22849.066407 bw MEMNODE1 -0.000488
13 22849.066407 bw MEMNODE0 0.000610
13 22849.068360 bw MEMNODE1 2500.610107
13 22849.068360 bw MEMNODE0 2500.611328
13 22849.068360 bw MEMNODE0 5167.278320
13 22849.068360 bw MEMNODE2 2666.667480
13 22850.568360 bw MEMNODE0 2500.611572
13 22850.568360 bw MEMNODE2 0.000732
13 22850.667969 bw MEMNODE1 -0.000488
13 22850.667969 bw MEMNODE0 0.000977
13 22853.820313 bw MEMNODE0 2760.108887
13 22853.820313 bw MEMNODE2 2760.108643
13 22855.269531 bw MEMNODE0 0.000977
13 22855.269531 bw MEMNODE2 0.000732
13 23044.419922 bw MEMNODE2 241.823853
13 23044.419922 bw MEMNODE0 241.824097
13 23046.466797 bw MEMNODE2 517.834595
13 23046.466797 bw MEMNODE0 517.834839
13 23048.498047 bw MEMNODE2 838.888062
13 23048.498047 bw MEMNODE0 838.888306
13 23050.529297 bw MEMNODE2 1222.624268
13 23050.529297 bw MEMNODE0 1222.624512
13 23060.953125 bw MEMNODE2 838.888062
13 23060.953125 bw MEMNODE0 838.888306
13 23060.957031 bw MEMNODE2 517.834595
13 23060.957031 bw MEMNODE0 517.834839
13 23060.958985 bw MEMNODE2 241.823822
13 23060.958985 bw MEMNODE0 241.824066
13 23060.960938 bw MEMNODE2 0.000702
13 23060.960938 bw MEMNODE0 0.000946
13 23061.087891 bw MEMNODE0 784.976074
13 23061.087891 bw MEMNODE1 784.974609
13 23062.357422 bw MEMNODE0 1837.391235
13 23062.357422 bw MEMNODE1 1837.389771
13 23063.642578 bw MEMNODE0 3442.406738
13 23063.642578 bw MEMNODE1 3442.405273
13 23064.933594 bw MEMNODE0 6401.944336
13 23064.933594 bw MEMNODE1 6401.942871
13 23066.134766 bw MEMNODE0 4796.928711
13 23066.134766 bw MEMNODE1 4796.927246
13 23066.158203 bw MEMNODE0 3744.513672
13 23066.158203 bw MEMNODE1 3744.512207
13 23066.183594 bw MEMNODE0 2959.538574
13 23066.183594 bw MEMNODE1 2959.537109
13 23066.285157 bw MEMNODE0 0.000977
13 23066.285157 bw MEMNODE1 -0.000488
13 23074.736328 bw MEMNODE1 401.410736
13 23074.736328 bw MEMNODE0 401.412201
13 23084.701172 bw MEMNODE1 -0.000488
13 23084.701172 bw MEMNODE0 0.000977
13 23084.705078 bw MEMNODE0 2684.142578
13 23084.705078 bw MEMNODE2 2684.142334
13 23084.705078 bw MEMNODE1 400.547150
13 23084.705078 bw MEMNODE0 3084.690186
13 23086.195313 bw MEMNODE0 400.548584
13 23086.195313 bw MEMNODE2 0.000732
13 23094.691407 bw MEMNODE1 -0.000488
13 23094.691407 bw MEMNODE0 0.000946
13 23094.693360 bw MEMNODE1 2485.436523
13 23094.693360 bw MEMNODE0 2485.437988
13 23094.695313 bw MEMNODE0 5169.579590
13 23094.695313 bw MEMNODE2 2684.142334
13 23096.185547 bw MEMNODE0 2485.437988
13 23096.185547 bw MEMNODE2 0.000732
13 23096.302735 bw MEMNODE1 -0.000488
13 23096.302735 bw MEMNODE0 0.000977
13 23099.531250 bw MEMNODE0 2767.568604
13 23099.531250 bw MEMNODE2 2767.568359
13 23100.976563 bw MEMNODE0 0.000977
13 23100.976563 bw MEMNODE2 0.000732
13 23196.925781 bw MEMNODE2 1901.579224
13 23196.925781 bw MEMNODE0 1901.579468
13 23199.029297 bw MEMNODE2 0.000732
13 23199.029297 bw MEMNODE0 0.000977
13 23266.937500 bw MEMNODE0 1523.810547
13 23266.937500 bw MEMNODE2 1523.810303
13 23268.316407 bw MEMNODE0 4344.747070
13 23268.316407 bw MEMNODE1 2820.936035
13 23269.562500 bw MEMNODE0 2820.937500
13 23269.562500 bw MEMNODE2 0.000732
13 23269.564453 bw MEMNODE2 386.926849
13 23269.564453 bw MEMNODE0 3207.863525
13 23269.734375 bw MEMNODE0 386.927002
13 23269.734375 bw MEMNODE1 -0.000488
13 23279.902344 bw MEMNODE2 0.000732
13 23279.902344 bw MEMNODE0 0.000885
13 23279.906250 bw MEMNODE2 538.664612
13 23279.906250 bw MEMNODE0 538.664795
13 23280.039063 bw MEMNODE0 3431.320068
13 23280.039063 bw MEMNODE1 2892.654785
13 23281.421875 bw MEMNODE0 538.664795
13 23281.421875 bw MEMNODE1 -0.000488
13 23285.269531 bw MEMNODE2 2410.693848
13 23285.269531 bw MEMNODE0 2410.694092
13 23287.332031 bw MEMNODE2 1872.030029
13 23287.332031 bw MEMNODE0 1872.030273
13 23287.406250 bw MEMNODE2 0.000732
13 23287.406250 bw MEMNODE0 0.000977
13 23289.943360 bw MEMNODE0 1358.992310
13 23289.943360 bw MEMNODE1 1358.990845
13 23291.107422 bw MEMNODE1 1749.160400
13 23291.107422 bw MEMNODE0 1749.161865
13 23292.886719 bw MEMNODE0 390.170532
13 23292.886719 bw MEMNODE1 390.169067
13 23301.359375 bw MEMNODE1 -0.000488
13 23301.359375 bw MEMNODE0 0.000977
13 23301.363281 bw MEMNODE0 2670.144287
13 23301.363281 bw MEMNODE2 2670.144043
13 23301.363281 bw MEMNODE1 2373.116455
13 23301.363281 bw MEMNODE0 5043.261230
13 23302.861328 bw MEMNODE0 2373.117920
13 23302.861328 bw MEMNODE2 0.000732
13 23303.048828 bw MEMNODE1 -0.000488
13 23303.048828 bw MEMNODE0 0.000977
13 23306.189453 bw MEMNODE0 2756.394043
13 23306.189453 bw MEMNODE2 2756.393799
13 23307.640625 bw MEMNODE0 0.000977
13 23307.640625 bw MEMNODE2 0.000732
13 23355.501953 bw MEMNODE0 2730.667725
13 23355.501953 bw MEMNODE1 2730.666260
13 23355.529297 bw MEMNODE2 719.607178
13 23355.529297 bw MEMNODE0 3450.274170
13 23356.966797 bw MEMNODE0 719.607422
13 23356.966797 bw MEMNODE1 -0.000488
13 23357.662110 bw MEMNODE0 1895.267578
13 23357.662110 bw MEMNODE2 1895.267334
13 23358.855469 bw MEMNODE2 2275.089355
13 23358.855469 bw MEMNODE0 2275.089600
13 23361.064453 bw MEMNODE0 1099.429443
13 23361.064453 bw MEMNODE2 1099.429199
13 23361.087891 bw MEMNODE2 379.822754
13 23361.087891 bw MEMNODE0 379.822998
13 23361.224610 bw MEMNODE0 3382.755615
13 23361.224610 bw MEMNODE1 3002.932129
13 23362.556641 bw MEMNODE0 379.822998
13 23362.556641 bw MEMNODE1 -0.000488
13 23369.386719 bw MEMNODE2 0.000793
13 23369.386719 bw MEMNODE0 0.001038
13 23371.074219 bw MEMNODE0 1378.197510
13 23371.074219 bw MEMNODE1 1378.196045
13 23372.218750 bw MEMNODE1 1770.157715
13 23372.218750 bw MEMNODE0 1770.159180
13 23373.976563 bw MEMNODE0 391.962646
13 23373.976563 bw MEMNODE1 391.961182
13 23382.423828 bw MEMNODE1 -0.000549
13 23382.423828 bw MEMNODE0 0.000916
13 23382.425781 bw MEMNODE0 2691.196777
13 23382.425781 bw MEMNODE2 2691.196533
13 23382.425781 bw MEMNODE1 2420.803223
13 23382.425781 bw MEMNODE0 5112.000488
13 23383.912110 bw MEMNODE0 2420.804688
13 23383.912110 bw MEMNODE2 0.000732
13 23384.078125 bw MEMNODE1 -0.000488
13 23384.078125 bw MEMNODE0 0.000977
13 23387.244141 bw MEMNODE0 2756.394043
13 23387.244141 bw MEMNODE2 2756.393799
13 23388.695313 bw MEMNODE0 0.000977
13 23388.695313 bw MEMNODE2 0.000732
13 23476.689453 bw MEMNODE2 2537.794922
13 23476.689453 bw MEMNODE0 2537.795166
13 23478.265625 bw MEMNODE2 0.000732
13 23478.265625 bw MEMNODE0 0.000977
13 23546.095703 bw MEMNODE0 1139.678223
13 23546.095703 bw MEMNODE2 1139.677979
13 23547.322266 bw MEMNODE2 1518.166260
13 23547.322266 bw MEMNODE0 1518.166504
13 23547.472657 bw MEMNODE0 4147.177734
13 23547.472657 bw MEMNODE1 2629.010986
13 23548.994141 bw MEMNODE0 1518.166260
13 23548.994141 bw MEMNODE1 -0.000488
13 23549.605469 bw MEMNODE0 378.489014
13 23549.605469 bw MEMNODE2 378.489014
13 23557.890625 bw MEMNODE2 0.000763
13 23557.890625 bw MEMNODE0 0.000763
13 23558.013672 bw MEMNODE0 3020.649658
13 23558.013672 bw MEMNODE1 3020.648438
13 23559.337891 bw MEMNODE0 0.000732
13 23559.337891 bw MEMNODE1 -0.000488
13 23561.148438 bw MEMNODE2 1221.229126
13 23561.148438 bw MEMNODE0 1221.229126
13 23564.423828 bw MEMNODE2 0.000732
13 23564.423828 bw MEMNODE0 0.000732
13 23567.722657 bw MEMNODE1 2412.249268
13 23567.722657 bw MEMNODE0 2412.250488
13 23569.380860 bw MEMNODE1 -0.000488
13 23569.380860 bw MEMNODE0 0.000732
13 23571.486328 bw MEMNODE0 868.165222
13 23571.486328 bw MEMNODE2 868.165222
13 23576.093750 bw MEMNODE0 0.000732
13 23576.093750 bw MEMNODE2 0.000732
13 23632.005860 bw MEMNODE0 1551.515869
13 23632.005860 bw MEMNODE2 1551.515869
13 23633.341797 bw MEMNODE0 4380.245117
13 23633.341797 bw MEMNODE1 2828.728760
13 23634.583985 bw MEMNODE0 2828.729980
13 23634.583985 bw MEMNODE2 0.000732
13 23634.585938 bw MEMNODE2 386.634674
13 23634.585938 bw MEMNODE0 3215.364014
13 23634.755860 bw MEMNODE0 386.634766
13 23634.755860 bw MEMNODE1 -0.000488
13 23644.931641 bw MEMNODE2 0.000732
13 23644.931641 bw MEMNODE0 0.000824
13 23645.056641 bw MEMNODE0 3011.765381
13 23645.056641 bw MEMNODE1 3011.764160
13 23646.384766 bw MEMNODE0 0.000732
13 23646.384766 bw MEMNODE1 -0.000488
13 23648.273438 bw MEMNODE2 1210.402588
13 23648.273438 bw MEMNODE0 1210.402588
13 23651.578125 bw MEMNODE2 0.000732
13 23651.578125 bw MEMNODE0 0.000732
13 23654.775391 bw MEMNODE1 2420.803223
13 23654.775391 bw MEMNODE0 2420.804443
13 23656.427735 bw MEMNODE1 -0.000488
13 23656.427735 bw MEMNODE0 0.000732
13 23658.611328 bw MEMNODE0 2763.833496
13 23658.611328 bw MEMNODE2 2763.833496
13 23660.058594 bw MEMNODE0 0.000732
13 23660.058594 bw MEMNODE2 0.000732
13 23719.568360 bw MEMNODE0 359.298981
13 23719.568360 bw MEMNODE2 359.298981
13 23730.701172 bw MEMNODE0 0.000732
13 23730.701172 bw MEMNODE2 0.000732
13 23742.246094 bw MEMNODE2 1454.546143
13 23742.246094 bw MEMNODE0 1454.546143
13 23744.996094 bw MEMNODE2 0.000732
13 23744.996094 bw MEMNODE0 0.000732
13 23812.500000 bw MEMNODE0 2994.152832
13 23812.500000 bw MEMNODE2 2994.152832
13 23813.835938 bw MEMNODE0 0.000732
13 23813.835938 bw MEMNODE2 0.000732
13 23825.376953 bw MEMNODE2 2540.943604
13 23825.376953 bw MEMNODE0 2540.943604
13 23826.951172 bw MEMNODE2 0.000732
13 23826.951172 bw MEMNODE0 0.000732
13 23898.523438 bw MEMNODE2 1866.910522
13 23898.523438 bw MEMNODE0 1866.910522
13 23900.666016 bw MEMNODE2 0.000732
13 23900.666016 bw MEMNODE0 0.000732
13 23901.988281 bw MEMNODE2 1932.076172
13 23901.988281 bw MEMNODE0 1932.076172
13 23904.058594 bw MEMNODE2 0.000732
13 23904.058594 bw MEMNODE0 0.000732
13 23905.654297 bw MEMNODE2 1896.296997
13 23905.654297 bw MEMNODE0 1896.296997
13 23907.763672 bw MEMNODE2 0.000732
13 23907.763672 bw MEMNODE0 0.000732
13 23908.484375 bw MEMNODE2 1892.791870
13 23908.484375 bw MEMNODE0 1892.791870
13 23910.597657 bw MEMNODE2 0.000732
13 23910.597657 bw MEMNODE0 0.000732
13 23912.000000 bw MEMNODE2 111.833855
13 23912.000000 bw MEMNODE0 111.833855
13 23947.767578 bw MEMNODE2 0.000732
13 23947.767578 bw MEMNODE0 0.000732
13 23948.232422 bw MEMNODE2 1899.815186
13 23948.232422 bw MEMNODE0 1899.815186
13 23950.337891 bw MEMNODE2 0.000732
13 23950.337891 bw MEMNODE0 0.000732
13 23950.855469 bw MEMNODE2 2544.100098
13 23950.855469 bw MEMNODE0 2544.100098
13 23952.427735 bw MEMNODE2 0.000732
13 23952.427735 bw MEMNODE0 0.000732
13 23953.490235 bw MEMNODE2 2301.124268
13 23953.490235 bw MEMNODE0 2301.124268
13 23955.228516 bw MEMNODE2 0.000732
13 23955.228516 bw MEMNODE0 0.000732
13 23956.289063 bw MEMNODE2 121.198509
13 23956.289063 bw MEMNODE0 121.198509
13 23989.292969 bw MEMNODE2 0.000732
13 23989.292969 bw MEMNODE0 0.000732
13 23990.031250 bw MEMNODE2 1894.542847
13 23990.031250 bw MEMNODE0 1894.542847
13 23992.142578 bw MEMNODE2 0.000732
13 23992.142578 bw MEMNODE0 0.000732
13 23993.587891 bw MEMNODE2 1887.558350
13 23993.587891 bw MEMNODE0 1887.558350
13 23995.707031 bw MEMNODE2 0.000732
13 23995.707031 bw MEMNODE0 0.000732
13 23997.179688 bw MEMNODE2 111.657043
13 23997.179688 bw MEMNODE0 111.657043
13 24033.003907 bw MEMNODE2 0.000732
13 24033.003907 bw MEMNODE0 0.000732
13 24034.064453 bw MEMNODE2 1898.054443
13 24034.064453 bw MEMNODE0 1898.054443
13 24036.171875 bw MEMNODE2 0.000732
13 24036.171875 bw MEMNODE0 0.000732
13 24037.154297 bw MEMNODE2 1937.559814
13 24037.154297 bw MEMNODE0 1937.559814
13 24039.218750 bw MEMNODE2 0.000732
13 24039.218750 bw MEMNODE0 0.000732
13 24040.064453 bw MEMNODE2 171.928207
13 24040.064453 bw MEMNODE0 171.928207
13 24063.330078 bw MEMNODE2 0.000732
13 24063.330078 bw MEMNODE0 0.000732
13 24063.947266 bw MEMNODE2 1924.812744
13 24063.947266 bw MEMNODE0 1924.812744
13 24066.025391 bw MEMNODE2 0.000732
13 24066.025391 bw MEMNODE0 0.000732
13 24066.343750 bw MEMNODE2 1926.623535
13 24066.343750 bw MEMNODE0 1926.623535
13 24068.419922 bw MEMNODE2 0.000732
13 24068.419922 bw MEMNODE0 0.000732
13 24068.830078 bw MEMNODE2 2608.917969
13 24068.830078 bw MEMNODE0 2608.917969
13 24070.363281 bw MEMNODE2 0.000732
13 24070.363281 bw MEMNODE0 0.000732
13 24071.009766 bw MEMNODE2 1885.820312
13 24071.009766 bw MEMNODE0 1885.820312
13 24073.130860 bw MEMNODE2 0.000732
13 24073.130860 bw MEMNODE0 0.000732
13 24074.548828 bw MEMNODE2 2589.128418
13 24074.548828 bw MEMNODE0 2589.128418
13 24076.093750 bw MEMNODE2 0.000732
13 24076.093750 bw MEMNODE0 0.000732
13 24076.687500 bw MEMNODE2 2569.636963
13 24076.687500 bw MEMNODE0 2569.636963
13 24078.244141 bw MEMNODE2 0.000732
13 24078.244141 bw MEMNODE0 0.000732
13 24079.230469 bw MEMNODE2 143.518600
13 24079.230469 bw MEMNODE0 143.518600
13 24107.101563 bw MEMNODE2 0.000732
13 24107.101563 bw MEMNODE0 0.000732
13 24107.310547 bw MEMNODE2 1818.828491
13 24107.310547 bw MEMNODE0 1818.828491
13 24109.509766 bw MEMNODE2 0.000732
13 24109.509766 bw MEMNODE0 0.000732
13 24109.925781 bw MEMNODE2 2455.636230
13 24109.925781 bw MEMNODE0 2455.636230
13 24111.554688 bw MEMNODE2 0.000732
13 24111.554688 bw MEMNODE0 0.000732
13 24113.062500 bw MEMNODE2 1882.353638
13 24113.062500 bw MEMNODE0 1882.353638
13 24115.187500 bw MEMNODE2 0.000732
13 24115.187500 bw MEMNODE0 0.000732
13 24115.625000 bw MEMNODE2 1882.353638
13 24115.625000 bw MEMNODE0 1882.353638
13 24117.750000 bw MEMNODE2 0.000732
13 24117.750000 bw MEMNODE0 0.000732
13 24118.904297 bw MEMNODE2 2560.000732
13 24118.904297 bw MEMNODE0 2560.000732
13 24120.466797 bw MEMNODE2 0.000732
13 24120.466797 bw MEMNODE0 0.000732
13 24121.144531 bw MEMNODE2 1898.054443
13 24121.144531 bw MEMNODE0 1898.054443
13 24123.251953 bw MEMNODE2 0.000732
13 24123.251953 bw MEMNODE0 0.000732
13 24123.738281 bw MEMNODE2 1928.437622
13 24123.738281 bw MEMNODE0 1928.437622
13 24125.812500 bw MEMNODE2 0.000732
13 24125.812500 bw MEMNODE0 0.000732
13 24126.808594 bw MEMNODE2 1928.437622
13 24126.808594 bw MEMNODE0 1928.437622
13 24128.882813 bw MEMNODE2 0.000732
13 24128.882813 bw MEMNODE0 0.000732
13 24130.589844 bw MEMNODE2 1923.005371
13 24130.589844 bw MEMNODE0 1923.005371
13 24132.669922 bw MEMNODE2 0.000732
13 24132.669922 bw MEMNODE0 0.000732
13 24133.375000 bw MEMNODE2 2214.054688
13 24133.375000 bw MEMNODE0 2214.054688
13 24135.181641 bw MEMNODE2 0.000732
13 24135.181641 bw MEMNODE0 0.000732
13 24136.164063 bw MEMNODE2 2595.691406
13 24136.164063 bw MEMNODE0 2595.691406
13 24137.705078 bw MEMNODE2 0.000732
13 24137.705078 bw MEMNODE0 0.000732
13 24138.791016 bw MEMNODE2 1946.768799
13 24138.791016 bw MEMNODE0 1946.768799
13 24140.845703 bw MEMNODE2 0.000732
13 24140.845703 bw MEMNODE0 0.000732
13 24141.748047 bw MEMNODE2 113.268806
13 24141.748047 bw MEMNODE0 113.268806
13 24177.062500 bw MEMNODE2 0.000732
13 24177.062500 bw MEMNODE0 0.000732
13 24178.687500 bw MEMNODE2 104.129265
13 24178.687500 bw MEMNODE0 104.129265
13 24217.101563 bw MEMNODE2 0.000732
13 24217.101563 bw MEMNODE0 0.000732
13 24217.865235 bw MEMNODE2 2553.616699
13 24217.865235 bw MEMNODE0 2553.616699
13 24219.431641 bw MEMNODE2 0.000732
13 24219.431641 bw MEMNODE0 0.000732
13 24220.775391 bw MEMNODE2 2550.436523
13 24220.775391 bw MEMNODE0 2550.436523
13 24222.343750 bw MEMNODE2 0.000732
13 24222.343750 bw MEMNODE0 0.000732
13 24222.869141 bw MEMNODE2 118.382233
13 24222.869141 bw MEMNODE0 118.382233
13 24256.658203 bw MEMNODE2 0.000732
13 24256.658203 bw MEMNODE0 0.000732
13 24257.066407 bw MEMNODE2 2528.395752
13 24257.066407 bw MEMNODE0 2528.395752
13 24258.648438 bw MEMNODE2 0.000732
13 24258.648438 bw MEMNODE0 0.000732
13 24259.625000 bw MEMNODE2 116.054451
13 24259.625000 bw MEMNODE0 116.054451
13 24294.091797 bw MEMNODE2 0.000732
13 24294.091797 bw MEMNODE0 0.000732
13 24295.214844 bw MEMNODE2 119.752808
13 24295.214844 bw MEMNODE0 119.752808
13 24328.617188 bw MEMNODE2 0.000732
13 24328.617188 bw MEMNODE0 0.000732
13 24330.566407 bw MEMNODE2 1659.644165
13 24330.566407 bw MEMNODE0 1659.644165
13 24332.976563 bw MEMNODE2 0.000732
13 24332.976563 bw MEMNODE0 0.000732
13 24333.373047 bw MEMNODE2 115.772354
13 24333.373047 bw MEMNODE0 115.772354
13 24367.923828 bw MEMNODE2 0.000732
13 24367.923828 bw MEMNODE0 0.000732
13 24369.232422 bw MEMNODE2 2618.926514
13 24369.232422 bw MEMNODE0 2618.926514
13 24370.759766 bw MEMNODE2 0.000732
13 24370.759766 bw MEMNODE0 0.000732
13 24371.558594 bw MEMNODE2 2569.636963
13 24371.558594 bw MEMNODE0 2569.636963
13 24373.115235 bw MEMNODE2 0.000732
13 24373.115235 bw MEMNODE0 0.000732
13 24373.658203 bw MEMNODE2 1901.579224
13 24373.658203 bw MEMNODE0 1901.579224
13 24375.761719 bw MEMNODE2 0.000732
13 24375.761719 bw MEMNODE0 0.000732
13 24376.726563 bw MEMNODE2 1915.809937
13 24376.726563 bw MEMNODE0 1915.809937
13 24378.814453 bw MEMNODE2 0.000732
13 24378.814453 bw MEMNODE0 0.000732
13 24379.556641 bw MEMNODE2 111.087738
13 24379.556641 bw MEMNODE0 111.087738
13 24415.564453 bw MEMNODE2 0.000732
13 24415.564453 bw MEMNODE0 0.000732
13 24417.203125 bw MEMNODE2 2537.794922
13 24417.203125 bw MEMNODE0 2537.794922
13 24418.779297 bw MEMNODE2 0.000732
13 24418.779297 bw MEMNODE0 0.000732
13 24419.490235 bw MEMNODE2 2537.794922
13 24419.490235 bw MEMNODE0 2537.794922
13 24421.066407 bw MEMNODE2 0.000732
13 24421.066407 bw MEMNODE0 0.000732
13 24422.699219 bw MEMNODE2 1880.625122
13 24422.699219 bw MEMNODE0 1880.625122
13 24424.826172 bw MEMNODE2 0.000732
13 24424.826172 bw MEMNODE0 0.000732
13 24425.447266 bw MEMNODE2 2537.794922
13 24425.447266 bw MEMNODE0 2537.794922
13 24427.023438 bw MEMNODE2 0.000732
13 24427.023438 bw MEMNODE0 0.000732
13 24427.964844 bw MEMNODE2 1892.791870
13 24427.964844 bw MEMNODE0 1892.791870
13 24430.078125 bw MEMNODE2 0.000732
13 24430.078125 bw MEMNODE0 0.000732
13 24431.066407 bw MEMNODE2 115.706947
13 24431.066407 bw MEMNODE0 115.706947
13 24465.636719 bw MEMNODE2 0.000732
13 24465.636719 bw MEMNODE0 0.000732
13 24466.449219 bw MEMNODE2 2563.204834
13 24466.449219 bw MEMNODE0 2563.204834
13 24468.009766 bw MEMNODE2 0.000732
13 24468.009766 bw MEMNODE0 0.000732
13 24468.402344 bw MEMNODE2 987.464600
13 24468.402344 bw MEMNODE0 987.464600
13 24472.453125 bw MEMNODE2 0.000732
13 24472.453125 bw MEMNODE0 0.000732
13 24474.773438 bw MEMNODE2 1908.667969
13 24474.773438 bw MEMNODE0 1908.667969
13 24476.869141 bw MEMNODE2 0.000732
13 24476.869141 bw MEMNODE0 0.000732
13 24477.933594 bw MEMNODE2 111.045570
13 24477.933594 bw MEMNODE0 111.045570
13 24513.955078 bw MEMNODE2 0.000732
13 24513.955078 bw MEMNODE0 0.000732
13 24515.517578 bw MEMNODE2 2598.985596
13 24515.517578 bw MEMNODE0 2598.985596
13 24517.056641 bw MEMNODE2 0.000732
13 24517.056641 bw MEMNODE0 0.000732
13 24517.501953 bw MEMNODE2 1889.299683
13 24517.501953 bw MEMNODE0 1889.299683
13 24519.619141 bw MEMNODE2 0.000732
13 24519.619141 bw MEMNODE0 0.000732
13 24520.642578 bw MEMNODE2 1930.255249
13 24520.642578 bw MEMNODE0 1930.255249
13 24522.714844 bw MEMNODE2 0.000732
13 24522.714844 bw MEMNODE0 0.000732
13 24524.189453 bw MEMNODE2 1899.815186
13 24524.189453 bw MEMNODE0 1899.815186
13 24526.294922 bw MEMNODE2 0.000732
13 24526.294922 bw MEMNODE0 0.000732
13 24527.923828 bw MEMNODE2 2560.000732
13 24527.923828 bw MEMNODE0 2560.000732
13 24529.486328 bw MEMNODE2 0.000732
13 24529.486328 bw MEMNODE0 0.000732
13 24529.896485 bw MEMNODE2 2569.636963
13 24529.896485 bw MEMNODE0 2569.636963
13 24531.453125 bw MEMNODE2 0.000732
13 24531.453125 bw MEMNODE0 0.000732
13 24532.189453 bw MEMNODE2 2553.616699
13 24532.189453 bw MEMNODE0 2553.616699
13 24533.755860 bw MEMNODE2 0.000732
13 24533.755860 bw MEMNODE0 0.000732
13 24535.531250 bw MEMNODE2 1939.394653
13 24535.531250 bw MEMNODE0 1939.394653
13 24537.593750 bw MEMNODE2 0.000732
13 24537.593750 bw MEMNODE0 0.000732
13 24538.183594 bw MEMNODE2 1917.603760
13 24538.183594 bw MEMNODE0 1917.603760
13 24540.269531 bw MEMNODE2 0.000732
13 24540.269531 bw MEMNODE0 0.000732
13 24540.888672 bw MEMNODE2 102.257576
13 24540.888672 bw MEMNODE0 102.257576
13 24580.005860 bw MEMNODE2 0.000732
13 24580.005860 bw MEMNODE0 0.000732
13 24580.888672 bw MEMNODE2 2199.785889
13 24580.888672 bw MEMNODE0 2199.785889
13 24582.707031 bw MEMNODE2 0.000732
13 24582.707031 bw MEMNODE0 0.000732
13 24583.031250 bw MEMNODE2 2547.264404
13 24583.031250 bw MEMNODE0 2547.264404
13 24584.601563 bw MEMNODE2 0.000732
13 24584.601563 bw MEMNODE0 0.000732
13 24585.236328 bw MEMNODE2 2544.100098
13 24585.236328 bw MEMNODE0 2544.100098
13 24586.808594 bw MEMNODE2 0.000732
13 24586.808594 bw MEMNODE0 0.000732
13 24587.720703 bw MEMNODE2 1903.346436
13 24587.720703 bw MEMNODE0 1903.346436
13 24589.822266 bw MEMNODE2 0.000732
13 24589.822266 bw MEMNODE0 0.000732
13 24590.402344 bw MEMNODE2 1891.044189
13 24590.402344 bw MEMNODE0 1891.044189
13 24592.517578 bw MEMNODE2 0.000732
13 24592.517578 bw MEMNODE0 0.000732
%EventDef PajeDefineContainerType 1
% Alias string
% ContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEventType 2
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineStateType 3
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineVariableType 4
% Alias string
% Name string
%EndEventDef
%EventDef PajeDefineLinkType 5
% Alias string
% SourceContainerType string
% DestContainerType string
% Name string
%EndEventDef
%EventDef PajeDefineEntityValue 6
% Alias string
% EntityType string
% Name string
% Color color
%EndEventDef
%EventDef PajeCreateContainer 7
% Time date
% Alias string
% Type string
% Container string
% Name string
%EndEventDef
%EventDef PajeDestroyContainer 8
% Time date
% Name string
% Type string
%EndEventDef
%EventDef PajeNewEvent 9
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajeSetState 10
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajePushState 11
% Time date
% Type string
% Container string
% Value string
%EndEventDef
%EventDef PajePopState 12
% Time date
% Type string
% Container string
%EndEventDef
%EventDef PajeSetVariable 13
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeAddVariable 14
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeSubVariable 15
% Time date
% Type string
% Container string
% Value double
%EndEventDef
%EventDef PajeStartLink 18
% Time date
% Type string
% Container string
% Value string
% SourceContainer string
% Key string
%EndEventDef
%EventDef PajeEndLink 19
% Time date
% Type string
% Container string
% Value string
% DestContainer string
% Key string
%EndEventDef
1 MPIP 0 "MPI Program"
1 P MPIP "Program"
1 Mn P "Memory Node"
1 T Mn "Worker"
1 Sc P "Scheduler State"
2 event T "event type"
3 S T "Thread State"
3 MS Mn "Memory Node State"
4 ntask Sc "Number of tasks"
4 bw Mn "Bandwidth"
6 I S Initializing "0.0 .7 1.0"
6 D S Deinitializing "0.0 .1 .7"
6 Fi S FetchingInput "1.0 .1 1.0"
6 Po S PushingOutput "0.1 1.0 1.0"
6 C S Callback ".0 .3 .8"
6 B S Blocked ".9 .1 .0"
6 Sl S Sleeping ".9 .1 .0"
6 P S Progressing ".4 .1 .6"
6 A MS Allocating ".4 .1 .0"
6 Ar MS AllocatingReuse ".1 .1 .8"
6 R MS Reclaiming ".0 .1 .4"
6 Co MS DriverCopy ".3 .5 .1"
6 CoA MS DriverCopyAsync ".1 .3 .1"
6 No MS Nothing ".0 .0 .0"
5 MPIL MPIP P P MPIL
5 L P Mn Mn L
7 0.000000 MPIroot MPIP 0 root
7 0.000000 p P MPIroot program
7 0.000000 sched Sc p scheduler
13 0.000000 ntask sched 0.0
7 0.000000 0 Mn p MEMNODE0
13 0.000000 bw MEMNODE0 0.0
7 0.000000 1 Mn p MEMNODE1
13 0.000000 bw MEMNODE1 0.0
7 0.000000 24949 T MEMNODE0 24949
10 0.000000 S 24949 I
7 0.000000 24947 T MEMNODE1 24947
10 0.000000 S 24947 I
7 0.000000 24948 T MEMNODE0 24948
10 0.000000 S 24948 I
7 0.000000 24950 T MEMNODE0 24950
10 0.000000 S 24950 I
7 0.000000 24951 T MEMNODE0 24951
10 0.000000 S 24951 I
10 0.000000 S 24949 B
10 0.000000 S 24950 B
10 0.000000 S 24948 B
10 0.000000 S 24951 B
7 0.000000 24952 T MEMNODE0 24952
10 0.000000 S 24952 I
10 0.000000 S 24952 B
10 411.645996 S 24947 B
10 411.774994 S 24947 Fi
10 411.778015 S 24947 B
6 execute_on_all_wrapper S execute_on_all_wrapper "0.000000
0.600000 0.400000"
10 411.789001 S 24947 execute_on_all_wrapper
10 415.541992 S 64 B
10 415.549011 S 24947 Po
10 415.549988 S 24947 B
13 15506.465820 ntask sched 1.000000
13 15506.544922 ntask sched 0.000000
10 15506.551758 S 24948 Fi
10 15506.554688 S 24948 B
6 chol_model_11 S chol_model_11 "0.000000 0.600000
0.400000"
10 15506.556641 S 24948 chol_model_11
10 15575.632812 S 0 B
10 15575.635742 S 24948 Po
10 15575.649414 S 24948 B
13 15575.697266 ntask sched 1.000000
10 15575.707031 MS MEMNODE1 A
10 15576.306641 MS MEMNODE1 No
10 15576.313477 MS MEMNODE1 Co
18 15576.313477 L p 4000000 MEMNODE0 com_1
10 15576.337891 MS MEMNODE1 CoA
10 15577.722656 MS MEMNODE1 No
19 15577.722656 L p 1928086912 MEMNODE1 com_1928086720
10 15577.733398 MS MEMNODE1 A
13 15577.754883 ntask sched 2.000000
13 15577.772461 ntask sched 3.000000
13 15577.788086 ntask sched 4.000000
13 15577.802734 ntask sched 5.000000
13 15577.819336 ntask sched 6.000000
13 15577.833984 ntask sched 7.000000
13 15577.835938 ntask sched 6.000000
10 15577.838867 S 24949 Fi
10 15577.840820 S 24949 B
6 chol_model_21 S chol_model_21 "0.000000 0.600000
0.400000"
10 15577.841797 S 24949 chol_model_21
13 15577.849609 ntask sched 7.000000
13 15577.851562 ntask sched 6.000000
10 15577.853516 S 24950 Fi
10 15577.856445 S 24950 B
10 15577.857422 S 24950 chol_model_21
13 15577.866211 ntask sched 7.000000
13 15577.872070 ntask sched 6.000000
10 15577.875000 S 24951 Fi
10 15577.877930 S 24951 B
10 15577.878906 S 24951 chol_model_21
13 15577.883789 ntask sched 7.000000
13 15577.888672 ntask sched 6.000000
10 15577.891602 S 24952 Fi
10 15577.893555 S 24952 B
10 15577.894531 S 24952 chol_model_21
13 15577.898438 ntask sched 7.000000
13 15577.911133 ntask sched 8.000000
13 15577.922852 ntask sched 9.000000
13 15577.934570 ntask sched 10.000000
13 15577.948242 ntask sched 11.000000
13 15577.954102 ntask sched 10.000000
10 15577.955078 S 24948 Fi
10 15577.956055 S 24948 B
10 15577.957031 S 24948 chol_model_21
10 15577.965820 MS MEMNODE1 No
10 15577.968750 MS MEMNODE1 Co
18 15577.968750 L p 4000000 MEMNODE0 com_2
10 15577.992188 MS MEMNODE1 CoA
10 15579.256836 MS MEMNODE1 No
19 15579.256836 L p 1928086912 MEMNODE1 com_1928086720
13 15579.266602 ntask sched 9.000000
10 15579.268555 S 24947 Fi
10 15579.323242 MS MEMNODE1 No
19 15579.323242 L p 4000000 MEMNODE1 com_1
10 15579.325195 MS MEMNODE1 A
10 15579.650391 MS MEMNODE1 No
10 15579.652344 MS MEMNODE1 Co
18 15579.652344 L p 4000000 MEMNODE0 com_3
10 15579.666016 MS MEMNODE1 CoA
10 15580.898438 MS MEMNODE1 No
19 15580.898438 L p 1928086912 MEMNODE1 com_1928086720
10 15580.904297 MS MEMNODE1 A
10 15581.189453 MS MEMNODE1 No
10 15581.191406 MS MEMNODE1 Co
18 15581.191406 L p 4000000 MEMNODE0 com_4
10 15581.206055 MS MEMNODE1 CoA
10 15582.433594 MS MEMNODE1 No
19 15582.433594 L p 1928086912 MEMNODE1 com_1928086720
10 15582.440430 MS MEMNODE1 A
10 15582.725586 MS MEMNODE1 No
10 15582.727539 MS MEMNODE1 Co
18 15582.727539 L p 4000000 MEMNODE0 com_5
10 15582.740234 MS MEMNODE1 CoA
10 15583.994141 MS MEMNODE1 No
19 15583.994141 L p 1928086912 MEMNODE1 com_1928086720
10 15583.999023 MS MEMNODE1 A
10 15584.276367 MS MEMNODE1 No
10 15584.278320 MS MEMNODE1 Co
18 15584.278320 L p 4000000 MEMNODE0 com_6
10 15584.290039 MS MEMNODE1 CoA
10 15585.533203 MS MEMNODE1 No
19 15585.533203 L p 1928086912 MEMNODE1 com_1928086720
10 15585.538086 MS MEMNODE1 A
10 15585.803711 MS MEMNODE1 No
10 15585.805664 MS MEMNODE1 Co
18 15585.805664 L p 4000000 MEMNODE0 com_7
10 15585.818359 MS MEMNODE1 CoA
10 15586.988281 MS MEMNODE1 No
19 15586.988281 L p 1928086912 MEMNODE1 com_1928086720
10 15586.993164 MS MEMNODE1 A
10 15587.264648 MS MEMNODE1 No
10 15587.266602 MS MEMNODE1 Co
18 15587.266602 L p 4000000 MEMNODE0 com_8
10 15587.280273 MS MEMNODE1 CoA
10 15588.454102 MS MEMNODE1 No
19 15588.454102 L p 1928086912 MEMNODE1 com_1928086720
10 15588.458984 MS MEMNODE1 A
10 15588.722656 MS MEMNODE1 No
10 15588.724609 MS MEMNODE1 Co
18 15588.724609 L p 4000000 MEMNODE0 com_9
10 15588.737305 MS MEMNODE1 CoA
10 15589.918945 MS MEMNODE1 No
19 15589.918945 L p 1928086912 MEMNODE1 com_1928086720
10 15589.924805 MS MEMNODE1 A
10 15590.199219 MS MEMNODE1 No
10 15590.202148 MS MEMNODE1 Co
18 15590.202148 L p 4000000 MEMNODE0 com_10
10 15590.214844 MS MEMNODE1 CoA
10 15591.406250 MS MEMNODE1 No
19 15591.406250 L p 1928086912 MEMNODE1 com_1928086720
10 15591.410156 MS MEMNODE1 A
10 15591.679688 MS MEMNODE1 No
10 15591.681641 MS MEMNODE1 Co
18 15591.681641 L p 4000000 MEMNODE0 com_11
10 15591.694336 MS MEMNODE1 CoA
10 15592.869141 MS MEMNODE1 No
19 15592.869141 L p 1928086912 MEMNODE1 com_1928086720
10 15592.912109 MS MEMNODE1 No
19 15592.912109 L p 4000000 MEMNODE1 com_10
10 15592.935547 MS MEMNODE1 No
19 15592.935547 L p 4000000 MEMNODE1 com_9
10 15592.958984 MS MEMNODE1 No
19 15592.958984 L p 4000000 MEMNODE1 com_8
10 15592.983398 MS MEMNODE1 No
19 15592.983398 L p 4000000 MEMNODE1 com_7
10 15593.005859 MS MEMNODE1 No
19 15593.005859 L p 4000000 MEMNODE1 com_6
10 15593.030273 MS MEMNODE1 No
19 15593.030273 L p 4000000 MEMNODE1 com_5
10 15593.051758 MS MEMNODE1 No
19 15593.051758 L p 4000000 MEMNODE1 com_4
10 15593.075195 MS MEMNODE1 No
19 15593.075195 L p 4000000 MEMNODE1 com_3
10 15593.096680 MS MEMNODE1 No
19 15593.096680 L p 4000000 MEMNODE1 com_2
10 15593.100586 S 24947 B
10 15593.102539 S 24947 chol_model_21
10 15601.488281 S 64 B
10 15601.489258 S 24947 Po
10 15601.491211 S 24947 B
13 15601.517578 ntask sched 10.000000
10 15601.552734 MS MEMNODE1 No
19 15601.552734 L p 4000000 MEMNODE1 com_11
10 15601.554688 MS MEMNODE1 A
10 15601.980469 MS MEMNODE1 No
10 15601.982422 MS MEMNODE1 Co
18 15601.982422 L p 4000000 MEMNODE0 com_12
10 15601.990234 MS MEMNODE1 CoA
10 15603.205078 MS MEMNODE1 No
19 15603.205078 L p 1928086912 MEMNODE1 com_1928086720
13 15603.211914 ntask sched 9.000000
10 15603.213867 S 24947 Fi
10 15603.215820 S 24947 B
10 15603.216797 S 24947 chol_model_21
10 15611.567383 S 64 B
10 15611.568359 S 24947 Po
10 15611.570312 S 24947 B
13 15611.593750 ntask sched 10.000000
13 15611.605469 ntask sched 11.000000
10 15611.638672 MS MEMNODE1 No
19 15611.638672 L p 4000000 MEMNODE1 com_12
10 15611.640625 MS MEMNODE1 A
10 15612.036133 MS MEMNODE1 No
10 15612.038086 MS MEMNODE1 Co
18 15612.038086 L p 4000000 MEMNODE0 com_13
10 15612.044922 MS MEMNODE1 CoA
10 15613.254883 MS MEMNODE1 No
19 15613.254883 L p 1928086912 MEMNODE1 com_1928086720
10 15613.260742 MS MEMNODE1 A
10 15613.532227 MS MEMNODE1 No
10 15613.534180 MS MEMNODE1 Co
18 15613.534180 L p 4000000 MEMNODE0 com_14
10 15613.540039 MS MEMNODE1 CoA
10 15614.898438 MS MEMNODE1 No
19 15614.898438 L p 1928086912 MEMNODE1 com_1928086720
13 15614.907227 ntask sched 10.000000
10 15614.909180 S 24947 Fi
10 15614.912109 S 24947 B
10 15614.913086 S 24947 chol_model_21
10 15623.251953 S 64 B
10 15623.252930 S 24947 Po
10 15623.254883 S 24947 B
13 15623.278320 ntask sched 11.000000
13 15623.290039 ntask sched 12.000000
13 15623.300781 ntask sched 13.000000
10 15623.313477 MS MEMNODE1 No
19 15623.313477 L p 4000000 MEMNODE1 com_14
10 15623.315430 MS MEMNODE1 No
19 15623.315430 L p 4000000 MEMNODE1 com_13
10 15623.317383 MS MEMNODE1 A
10 15623.666016 MS MEMNODE1 No
10 15623.667969 MS MEMNODE1 Co
18 15623.667969 L p 4000000 MEMNODE0 com_15
10 15623.673828 MS MEMNODE1 CoA
10 15624.881836 MS MEMNODE1 No
19 15624.881836 L p 1928086912 MEMNODE1 com_1928086720
10 15624.887695 MS MEMNODE1 A
10 15625.167969 MS MEMNODE1 No
10 15625.169922 MS MEMNODE1 Co
18 15625.169922 L p 4000000 MEMNODE0 com_16
10 15625.175781 MS MEMNODE1 CoA
10 15626.396484 MS MEMNODE1 No
19 15626.396484 L p 1928086912 MEMNODE1 com_1928086720
10 15626.401367 MS MEMNODE1 A
10 15626.671875 MS MEMNODE1 No
10 15626.673828 MS MEMNODE1 Co
18 15626.673828 L p 4000000 MEMNODE0 com_17
10 15626.679688 MS MEMNODE1 CoA
10 15626.949219 S 0 B
10 15626.953125 S 24949 Po
10 15626.957031 S 24949 B
13 15626.999023 ntask sched 14.000000
13 15627.014648 ntask sched 15.000000
13 15627.032227 ntask sched 16.000000
13 15627.048828 ntask sched 17.000000
10 15627.058594 MS MEMNODE0 Co
18 15627.058594 L p 4000000 MEMNODE1 com_18
10 15627.119141 S 0 B
10 15627.121094 S 24950 Po
10 15627.123047 S 24950 B
10 15627.125977 S 0 B
10 15627.127930 S 24948 Po
10 15627.129883 S 24948 B
13 15627.147461 ntask sched 18.000000
13 15627.152344 ntask sched 19.000000
13 15627.163086 ntask sched 20.000000
10 15627.166016 MS MEMNODE0 Co
18 15627.166016 L p 4000000 MEMNODE1 com_19
13 15627.168945 ntask sched 21.000000
10 15627.222656 S 0 B
10 15627.224609 S 24952 Po
10 15627.224609 S 24951 Po
10 15627.226562 S 24952 B
10 15627.238281 S 24951 B
10 15627.889648 MS MEMNODE1 No
19 15627.889648 L p 1928086848 MEMNODE1 com_1928087104
10 15627.910156 MS MEMNODE0 CoA
10 15627.923828 MS MEMNODE0 CoA
13 15627.935547 ntask sched 20.000000
10 15627.938477 S 24947 Fi
10 15627.941406 S 24947 B
10 15627.942383 S 24947 chol_model_21
10 15629.448242 MS MEMNODE0 No
19 15629.448242 L p 1928086912 MEMNODE0 com_1928086720
10 15630.848633 MS MEMNODE0 No
19 15630.848633 L p 1928086920 MEMNODE0 com_1928086720
13 15630.878906 ntask sched 19.000000
10 15630.879883 MS MEMNODE0 Co
18 15630.879883 L p 4000000 MEMNODE1 com_20
10 15630.880859 S 24949 Fi
10 15630.882812 S 24949 B
6 chol_model_22 S chol_model_22 "0.000000 0.600000
0.400000"
10 15630.883789 S 24949 chol_model_22
13 15630.892578 ntask sched 20.000000
13 15630.901367 ntask sched 21.000000
13 15630.910156 ntask sched 22.000000
13 15630.925781 ntask sched 23.000000
13 15630.933594 ntask sched 22.000000
13 15630.934570 ntask sched 23.000000
10 15630.935547 S 24948 Fi
10 15630.940430 MS MEMNODE0 CoA
10 15634.880859 MS MEMNODE0 No
19 15634.880859 L p 1928086912 MEMNODE0 com_1928086720
10 15634.901367 MS MEMNODE0 No
19 15634.901367 L p 4000000 MEMNODE0 com_19
10 15634.907227 MS MEMNODE0 No
19 15634.907227 L p 4000000 MEMNODE0 com_18
10 15634.910156 S 24948 B
10 15634.911133 S 24948 chol_model_22
13 15634.946289 ntask sched 24.000000
13 15634.956055 ntask sched 25.000000
13 15634.958984 ntask sched 26.000000
13 15634.960938 ntask sched 27.000000
13 15634.969727 ntask sched 28.000000
13 15634.977539 ntask sched 29.000000
13 15634.978516 ntask sched 30.000000
13 15634.984375 ntask sched 31.000000
13 15634.992188 ntask sched 32.000000
13 15634.994141 ntask sched 33.000000
13 15634.998047 ntask sched 34.000000
13 15635.004883 ntask sched 35.000000
13 15635.008789 ntask sched 36.000000
13 15635.012695 ntask sched 37.000000
13 15635.013672 ntask sched 36.000000
10 15635.014648 S 24952 Fi
13 15635.024414 ntask sched 37.000000
13 15635.027344 ntask sched 38.000000
13 15635.035156 ntask sched 37.000000
10 15635.036133 S 24951 Fi
10 15635.038086 S 24951 B
13 15635.038086 ntask sched 38.000000
10 15635.039062 S 24951 chol_model_22
13 15635.053711 ntask sched 37.000000
10 15635.055664 S 24950 Fi
10 15635.058594 S 24950 B
10 15635.058594 S 24950 chol_model_22
10 15636.494141 MS MEMNODE0 No
19 15636.494141 L p 4000000 MEMNODE0 com_20
10 15636.496094 S 24952 B
10 15636.497070 S 24952 chol_model_22
10 15640.636719 S 64 B
10 15640.637695 S 24947 Po
10 15640.639648 S 24947 B
13 15640.666016 ntask sched 38.000000
13 15640.678711 ntask sched 39.000000
13 15640.691406 ntask sched 40.000000
13 15640.703125 ntask sched 41.000000
13 15640.715820 ntask sched 42.000000
13 15640.726562 ntask sched 43.000000
13 15640.739258 ntask sched 44.000000
13 15640.750977 ntask sched 45.000000
13 15640.761719 ntask sched 46.000000
10 15640.773438 MS MEMNODE1 No
19 15640.773438 L p 4000000 MEMNODE1 com_17
10 15640.775391 MS MEMNODE1 No
19 15640.775391 L p 4000000 MEMNODE1 com_16
10 15640.778320 MS MEMNODE1 No
19 15640.778320 L p 4000000 MEMNODE1 com_15
10 15640.779297 MS MEMNODE1 A
10 15641.275391 MS MEMNODE1 No
10 15641.277344 MS MEMNODE1 Co
18 15641.277344 L p 4000000 MEMNODE0 com_21
10 15641.284180 MS MEMNODE1 CoA
10 15642.470703 MS MEMNODE1 No
19 15642.470703 L p 1928086912 MEMNODE1 com_1928086720
10 15642.475586 MS MEMNODE1 A
10 15642.736328 MS MEMNODE1 No
10 15642.738281 MS MEMNODE1 Co
18 15642.738281 L p 4000000 MEMNODE0 com_22
10 15642.744141 MS MEMNODE1 CoA
10 15643.953125 MS MEMNODE1 No
19 15643.953125 L p 1928086912 MEMNODE1 com_1928086720
10 15643.958008 MS MEMNODE1 A
10 15644.262695 MS MEMNODE1 No
10 15644.264648 MS MEMNODE1 Co
18 15644.264648 L p 4000000 MEMNODE0 com_23
10 15644.271484 MS MEMNODE1 CoA
10 15645.484375 MS MEMNODE1 No
19 15645.484375 L p 1928086912 MEMNODE1 com_1928086720
10 15645.489258 MS MEMNODE1 A
10 15645.769531 MS MEMNODE1 No
10 15645.772461 MS MEMNODE1 Co
18 15645.772461 L p 4000000 MEMNODE0 com_24
10 15645.778320 MS MEMNODE1 CoA
10 15647.063477 MS MEMNODE1 No
19 15647.063477 L p 1928086912 MEMNODE1 com_1928086720
10 15647.068359 MS MEMNODE1 A
10 15647.356445 MS MEMNODE1 No
10 15647.358398 MS MEMNODE1 Co
18 15647.358398 L p 4000000 MEMNODE0 com_25
10 15647.381836 MS MEMNODE1 CoA
10 15648.591797 MS MEMNODE1 No
19 15648.591797 L p 1928086912 MEMNODE1 com_1928086720
10 15648.596680 MS MEMNODE1 A
10 15648.865234 MS MEMNODE1 No
10 15648.867188 MS MEMNODE1 Co
18 15648.867188 L p 4000000 MEMNODE0 com_26
10 15648.881836 MS MEMNODE1 CoA
10 15650.097656 MS MEMNODE1 No
19 15650.097656 L p 1928086912 MEMNODE1 com_1928086720
10 15650.102539 MS MEMNODE1 A
10 15650.370117 MS MEMNODE1 No
10 15650.372070 MS MEMNODE1 Co
18 15650.372070 L p 4000000 MEMNODE0 com_27
10 15650.387695 MS MEMNODE1 CoA
10 15651.592773 MS MEMNODE1 No
19 15651.592773 L p 1928086912 MEMNODE1 com_1928086720
10 15651.597656 MS MEMNODE1 A
10 15651.866211 MS MEMNODE1 No
10 15651.869141 MS MEMNODE1 Co
18 15651.869141 L p 4000000 MEMNODE0 com_28
10 15651.884766 MS MEMNODE1 CoA
10 15653.097656 MS MEMNODE1 No
19 15653.097656 L p 1928086912 MEMNODE1 com_1928086720
10 15653.102539 MS MEMNODE1 A
10 15653.369141 MS MEMNODE1 No
10 15653.372070 MS MEMNODE1 Co
18 15653.372070 L p 4000000 MEMNODE0 com_29
10 15653.387695 MS MEMNODE1 CoA
10 15654.602539 MS MEMNODE1 No
19 15654.602539 L p 1928086912 MEMNODE1 com_1928086720
10 15654.608398 MS MEMNODE1 A
10 15654.864258 MS MEMNODE1 No
10 15654.866211 MS MEMNODE1 Co
18 15654.866211 L p 4000000 MEMNODE0 com_30
10 15654.880859 MS MEMNODE1 CoA
10 15656.089844 MS MEMNODE1 No
19 15656.089844 L p 1928086912 MEMNODE1 com_1928086720
10 15656.096680 MS MEMNODE1 A
10 15656.365234 MS MEMNODE1 No
10 15656.367188 MS MEMNODE1 Co
18 15656.367188 L p 4000000 MEMNODE0 com_31
10 15656.382812 MS MEMNODE1 CoA
10 15657.593750 MS MEMNODE1 No
19 15657.593750 L p 1928086912 MEMNODE1 com_1928086720
10 15657.597656 MS MEMNODE1 A
10 15657.853516 MS MEMNODE1 No
10 15657.856445 MS MEMNODE1 Co
18 15657.856445 L p 4000000 MEMNODE0 com_32
10 15657.873047 MS MEMNODE1 CoA
10 15659.046875 MS MEMNODE1 No
19 15659.046875 L p 1928086912 MEMNODE1 com_1928086720
10 15659.051758 MS MEMNODE1 A
10 15659.324219 MS MEMNODE1 No
10 15659.327148 MS MEMNODE1 Co
18 15659.327148 L p 4000000 MEMNODE0 com_33
10 15659.349609 MS MEMNODE1 CoA
10 15660.553711 MS MEMNODE1 No
19 15660.553711 L p 1928086912 MEMNODE1 com_1928086720
10 15660.560547 MS MEMNODE1 A
10 15660.922852 MS MEMNODE1 No
10 15660.925781 MS MEMNODE1 Co
18 15660.925781 L p 4000000 MEMNODE0 com_34
10 15660.949219 MS MEMNODE1 CoA
10 15662.164062 MS MEMNODE1 No
19 15662.164062 L p 1928086912 MEMNODE1 com_1928086720
10 15662.168945 MS MEMNODE1 A
10 15671.275391 MS MEMNODE1 No
10 15671.278320 MS MEMNODE1 Co
18 15671.278320 L p 4000000 MEMNODE0 com_35
10 15671.289062 MS MEMNODE1 CoA
10 15672.510742 MS MEMNODE1 No
19 15672.510742 L p 1928086912 MEMNODE1 com_1928086720
10 15672.515625 MS MEMNODE1 A
10 15672.801758 MS MEMNODE1 No
10 15672.803711 MS MEMNODE1 Co
18 15672.803711 L p 4000000 MEMNODE0 com_36
10 15672.814453 MS MEMNODE1 CoA
10 15674.033203 MS MEMNODE1 No
19 15674.033203 L p 1928086912 MEMNODE1 com_1928086720
10 15674.037109 MS MEMNODE1 A
10 15674.315430 MS MEMNODE1 No
10 15674.317383 MS MEMNODE1 Co
18 15674.317383 L p 4000000 MEMNODE0 com_37
10 15674.327148 MS MEMNODE1 CoA
10 15675.488281 MS MEMNODE1 No
19 15675.488281 L p 1928086912 MEMNODE1 com_1928086720
10 15675.493164 MS MEMNODE1 A
10 15675.775391 MS MEMNODE1 No
10 15675.777344 MS MEMNODE1 Co
18 15675.777344 L p 4000000 MEMNODE0 com_38
10 15675.786133 MS MEMNODE1 CoA
10 15676.995117 MS MEMNODE1 No
19 15676.995117 L p 1928086912 MEMNODE1 com_1928086720
10 15677.000000 MS MEMNODE1 A
10 15677.282227 MS MEMNODE1 No
10 15677.285156 MS MEMNODE1 Co
18 15677.285156 L p 4000000 MEMNODE0 com_39
10 15677.293945 MS MEMNODE1 CoA
10 15678.461914 MS MEMNODE1 No
19 15678.461914 L p 1928086912 MEMNODE1 com_1928086720
10 15678.466797 MS MEMNODE1 A
10 15678.743164 MS MEMNODE1 No
10 15678.746094 MS MEMNODE1 Co
18 15678.746094 L p 4000000 MEMNODE0 com_40
10 15678.755859 MS MEMNODE1 CoA
10 15679.970703 MS MEMNODE1 No
19 15679.970703 L p 1928086912 MEMNODE1 com_1928086720
10 15679.975586 MS MEMNODE1 A
10 15680.250977 MS MEMNODE1 No
10 15680.253906 MS MEMNODE1 Co
18 15680.253906 L p 4000000 MEMNODE0 com_41
10 15680.263672 MS MEMNODE1 CoA
10 15681.501953 MS MEMNODE1 No
19 15681.501953 L p 1928086912 MEMNODE1 com_1928086720
10 15681.506836 MS MEMNODE1 A
10 15681.776367 MS MEMNODE1 No
10 15681.779297 MS MEMNODE1 Co
18 15681.779297 L p 4000000 MEMNODE0 com_42
10 15681.789062 MS MEMNODE1 CoA
10 15682.990234 MS MEMNODE1 No
19 15682.990234 L p 1928086912 MEMNODE1 com_1928086720
10 15682.995117 MS MEMNODE1 A
10 15683.308594 MS MEMNODE1 No
10 15683.310547 MS MEMNODE1 Co
18 15683.310547 L p 4000000 MEMNODE0 com_43
10 15683.323242 MS MEMNODE1 CoA
10 15684.586914 MS MEMNODE1 No
19 15684.586914 L p 1928086912 MEMNODE1 com_1928086720
10 15684.593750 MS MEMNODE1 A
10 15684.956055 MS MEMNODE1 No
10 15684.958984 MS MEMNODE1 Co
18 15684.958984 L p 4000000 MEMNODE0 com_44
10 15684.969727 MS MEMNODE1 CoA
10 15686.181641 MS MEMNODE1 No
19 15686.181641 L p 1928086912 MEMNODE1 com_1928086720
10 15686.186523 MS MEMNODE1 A
10 15686.464844 MS MEMNODE1 No
10 15686.467773 MS MEMNODE1 Co
18 15686.467773 L p 4000000 MEMNODE0 com_45
10 15686.478516 MS MEMNODE1 CoA
10 15687.631836 MS MEMNODE1 No
19 15687.631836 L p 1928086912 MEMNODE1 com_1928086720
10 15687.636719 MS MEMNODE1 A
10 15687.913086 MS MEMNODE1 No
10 15687.916016 MS MEMNODE1 Co
18 15687.916016 L p 4000000 MEMNODE0 com_46
10 15687.930664 MS MEMNODE1 CoA
10 15689.146484 MS MEMNODE1 No
19 15689.146484 L p 1928086912 MEMNODE1 com_1928086720
10 15689.151367 MS MEMNODE1 A
10 15689.425781 MS MEMNODE1 No
10 15689.428711 MS MEMNODE1 Co
18 15689.428711 L p 4000000 MEMNODE0 com_47
10 15689.440430 MS MEMNODE1 CoA
10 15690.653320 MS MEMNODE1 No
19 15690.653320 L p 1928086912 MEMNODE1 com_1928086720
10 15690.657227 MS MEMNODE1 A
10 15690.925781 MS MEMNODE1 No
10 15690.928711 MS MEMNODE1 Co
18 15690.928711 L p 4000000 MEMNODE0 com_48
10 15690.940430 MS MEMNODE1 CoA
10 15692.151367 MS MEMNODE1 No
19 15692.151367 L p 1928086912 MEMNODE1 com_1928086720
10 15692.156250 MS MEMNODE1 A
10 15692.428711 MS MEMNODE1 No
10 15692.430664 MS MEMNODE1 Co
18 15692.430664 L p 4000000 MEMNODE0 com_49
10 15692.442383 MS MEMNODE1 CoA
10 15693.598633 MS MEMNODE1 No
19 15693.598633 L p 1928086912 MEMNODE1 com_1928086720
10 15693.603516 MS MEMNODE1 A
10 15693.872070 MS MEMNODE1 No
10 15693.875000 MS MEMNODE1 Co
18 15693.875000 L p 4000000 MEMNODE0 com_50
10 15693.884766 MS MEMNODE1 CoA
10 15695.042969 MS MEMNODE1 No
19 15695.042969 L p 1928086912 MEMNODE1 com_1928086720
10 15695.047852 MS MEMNODE1 A
10 15695.322266 MS MEMNODE1 No
10 15695.324219 MS MEMNODE1 Co
18 15695.324219 L p 4000000 MEMNODE0 com_51
10 15695.335938 MS MEMNODE1 CoA
10 15696.545898 MS MEMNODE1 No
19 15696.545898 L p 1928086912 MEMNODE1 com_1928086720
10 15696.550781 MS MEMNODE1 A
10 15696.817383 MS MEMNODE1 No
10 15696.819336 MS MEMNODE1 Co
18 15696.819336 L p 4000000 MEMNODE0 com_52
10 15696.830078 MS MEMNODE1 CoA
10 15698.038086 MS MEMNODE1 No
19 15698.038086 L p 1928086912 MEMNODE1 com_1928086720
10 15698.042969 MS MEMNODE1 A
10 15698.322266 MS MEMNODE1 No
10 15698.324219 MS MEMNODE1 Co
18 15698.324219 L p 4000000 MEMNODE0 com_53
10 15698.335938 MS MEMNODE1 CoA
10 15699.544922 MS MEMNODE1 No
19 15699.544922 L p 1928086912 MEMNODE1 com_1928086720
10 15699.549805 MS MEMNODE1 A
10 15699.815430 MS MEMNODE1 No
10 15699.817383 MS MEMNODE1 Co
18 15699.817383 L p 4000000 MEMNODE0 com_54
10 15699.829102 MS MEMNODE1 CoA
10 15701.037109 MS MEMNODE1 No
19 15701.037109 L p 1928086912 MEMNODE1 com_1928086720
10 15701.041016 MS MEMNODE1 A
10 15701.309570 MS MEMNODE1 No
10 15701.311523 MS MEMNODE1 Co
18 15701.311523 L p 4000000 MEMNODE0 com_55
10 15701.324219 MS MEMNODE1 CoA
10 15702.543945 MS MEMNODE1 No
19 15702.543945 L p 1928086912 MEMNODE1 com_1928086720
13 15702.552734 ntask sched 45.000000
10 15702.555664 S 24947 Fi
10 15702.557617 S 24947 B
10 15702.559570 S 24947 chol_model_21
10 15710.916992 S 64 B
10 15710.918945 S 24947 Po
10 15710.921875 S 24947 B
13 15710.950195 ntask sched 46.000000
13 15710.961914 ntask sched 47.000000
13 15710.972656 ntask sched 48.000000
13 15710.984375 ntask sched 49.000000
13 15711.012695 ntask sched 50.000000
13 15711.025391 ntask sched 51.000000
13 15711.036133 ntask sched 52.000000
13 15711.046875 ntask sched 53.000000
13 15711.058594 ntask sched 54.000000
13 15711.070312 ntask sched 55.000000
10 15711.112305 MS MEMNODE1 No
19 15711.112305 L p 4000000 MEMNODE1 com_55
10 15711.115234 MS MEMNODE1 No
19 15711.115234 L p 4000000 MEMNODE1 com_54
10 15711.118164 MS MEMNODE1 No
19 15711.118164 L p 4000000 MEMNODE1 com_53
10 15711.120117 MS MEMNODE1 No
19 15711.120117 L p 4000000 MEMNODE1 com_52
10 15711.122070 MS MEMNODE1 No
19 15711.122070 L p 4000000 MEMNODE1 com_51
10 15711.125000 MS MEMNODE1 No
19 15711.125000 L p 4000000 MEMNODE1 com_50
10 15711.126953 MS MEMNODE1 No
19 15711.126953 L p 4000000 MEMNODE1 com_49
10 15711.129883 MS MEMNODE1 No
19 15711.129883 L p 4000000 MEMNODE1 com_48
10 15711.131836 MS MEMNODE1 No
19 15711.131836 L p 4000000 MEMNODE1 com_47
10 15711.134766 MS MEMNODE1 No
19 15711.134766 L p 4000000 MEMNODE1 com_46
10 15711.136719 MS MEMNODE1 No
19 15711.136719 L p 4000000 MEMNODE1 com_45
10 15711.139648 MS MEMNODE1 No
19 15711.139648 L p 4000000 MEMNODE1 com_44
10 15711.141602 MS MEMNODE1 No
19 15711.141602 L p 4000000 MEMNODE1 com_43
10 15711.143555 MS MEMNODE1 No
19 15711.143555 L p 4000000 MEMNODE1 com_42
10 15711.147461 MS MEMNODE1 No
19 15711.147461 L p 4000000 MEMNODE1 com_41
10 15711.149414 MS MEMNODE1 No
19 15711.149414 L p 4000000 MEMNODE1 com_40
10 15711.151367 MS MEMNODE1 No
19 15711.151367 L p 4000000 MEMNODE1 com_39
10 15711.153320 MS MEMNODE1 No
19 15711.153320 L p 4000000 MEMNODE1 com_38
10 15711.155273 MS MEMNODE1 No
19 15711.155273 L p 4000000 MEMNODE1 com_37
10 15711.158203 MS MEMNODE1 No
19 15711.158203 L p 4000000 MEMNODE1 com_36
10 15711.160156 MS MEMNODE1 No
19 15711.160156 L p 4000000 MEMNODE1 com_35
10 15711.162109 MS MEMNODE1 No
19 15711.162109 L p 4000000 MEMNODE1 com_34
10 15711.164062 MS MEMNODE1 No
19 15711.164062 L p 4000000 MEMNODE1 com_33
10 15711.166992 MS MEMNODE1 No
19 15711.166992 L p 4000000 MEMNODE1 com_32
10 15711.168945 MS MEMNODE1 No
19 15711.168945 L p 4000000 MEMNODE1 com_31
10 15711.170898 MS MEMNODE1 No
19 15711.170898 L p 4000000 MEMNODE1 com_30
10 15711.173828 MS MEMNODE1 No
19 15711.173828 L p 4000000 MEMNODE1 com_29
10 15711.175781 MS MEMNODE1 No
19 15711.175781 L p 4000000 MEMNODE1 com_28
10 15711.177734 MS MEMNODE1 No
19 15711.177734 L p 4000000 MEMNODE1 com_27
10 15711.179688 MS MEMNODE1 No
19 15711.179688 L p 4000000 MEMNODE1 com_26
10 15711.182617 MS MEMNODE1 No
19 15711.182617 L p 4000000 MEMNODE1 com_25
10 15711.184570 MS MEMNODE1 No
19 15711.184570 L p 4000000 MEMNODE1 com_24
10 15711.186523 MS MEMNODE1 No
19 15711.186523 L p 4000000 MEMNODE1 com_23
10 15711.189453 MS MEMNODE1 No
19 15711.189453 L p 4000000 MEMNODE1 com_22
10 15711.191406 MS MEMNODE1 No
19 15711.191406 L p 4000000 MEMNODE1 com_21
10 15711.194336 MS MEMNODE1 A
10 15711.691406 MS MEMNODE1 No
10 15711.693359 MS MEMNODE1 Co
18 15711.693359 L p 4000000 MEMNODE0 com_56
10 15711.701172 MS MEMNODE1 CoA
10 15712.923828 MS MEMNODE1 No
19 15712.923828 L p 1928086912 MEMNODE1 com_1928086720
10 15712.929688 MS MEMNODE1 A
10 15713.208008 MS MEMNODE1 No
10 15713.210938 MS MEMNODE1 Co
18 15713.210938 L p 4000000 MEMNODE0 com_57
10 15713.215820 MS MEMNODE1 CoA
10 15714.431641 MS MEMNODE1 No
19 15714.431641 L p 1928086912 MEMNODE1 com_1928086720
10 15714.436523 MS MEMNODE1 A
10 15714.743164 MS MEMNODE1 No
10 15714.745117 MS MEMNODE1 Co
18 15714.745117 L p 4000000 MEMNODE0 com_58
10 15714.750977 MS MEMNODE1 CoA
10 15715.960938 MS MEMNODE1 No
19 15715.960938 L p 1928086912 MEMNODE1 com_1928086720
10 15715.965820 MS MEMNODE1 A
10 15716.249023 MS MEMNODE1 No
10 15716.251953 MS MEMNODE1 Co
18 15716.251953 L p 4000000 MEMNODE0 com_59
10 15716.256836 MS MEMNODE1 CoA
10 15717.496094 MS MEMNODE1 No
19 15717.496094 L p 1928086912 MEMNODE1 com_1928086720
10 15717.500977 MS MEMNODE1 A
10 15717.780273 MS MEMNODE1 No
10 15717.783203 MS MEMNODE1 Co
18 15717.783203 L p 4000000 MEMNODE0 com_60
10 15717.789062 MS MEMNODE1 CoA
10 15718.999023 MS MEMNODE1 No
19 15718.999023 L p 1928086912 MEMNODE1 com_1928086720
10 15719.003906 MS MEMNODE1 A
10 15719.283203 MS MEMNODE1 No
10 15719.286133 MS MEMNODE1 Co
18 15719.286133 L p 4000000 MEMNODE0 com_61
10 15719.291992 MS MEMNODE1 CoA
10 15720.503906 MS MEMNODE1 No
19 15720.503906 L p 1928086912 MEMNODE1 com_1928086720
10 15720.508789 MS MEMNODE1 A
10 15720.785156 MS MEMNODE1 No
10 15720.787109 MS MEMNODE1 Co
18 15720.787109 L p 4000000 MEMNODE0 com_62
10 15720.791992 MS MEMNODE1 CoA
10 15722.002930 MS MEMNODE1 No
19 15722.002930 L p 1928086912 MEMNODE1 com_1928086720
13 15722.011719 ntask sched 54.000000
10 15722.014648 S 24947 Fi
10 15722.017578 S 24947 B
10 15722.018555 S 24947 chol_model_21
10 15722.582031 S 0 B
10 15722.585938 S 24949 Po
10 15722.589844 S 24949 B
10 15722.609375 MS MEMNODE0 Co
18 15722.609375 L p 4000000 MEMNODE1 com_63
10 15722.625977 MS MEMNODE0 CoA
10 15726.991211 S 0 B
10 15726.992188 S 24950 Po
10 15726.995117 S 24950 B
13 15727.004883 ntask sched 53.000000
10 15727.005859 S 24950 Fi
10 15727.210938 S 0 B
10 15727.211914 S 24948 Po
10 15727.214844 S 24948 B
13 15727.224609 ntask sched 52.000000
10 15727.225586 S 24948 Fi
10 15727.836914 S 0 B
10 15727.837891 S 24951 Po
10 15727.840820 S 24951 B
13 15727.859375 ntask sched 51.000000
10 15727.860352 S 24951 Fi
10 15728.740234 S 0 B
10 15728.741211 S 24952 Po
10 15728.743164 S 24952 B
13 15728.750977 ntask sched 50.000000
10 15728.752930 S 24952 Fi
10 15730.370117 S 64 B
10 15730.371094 S 24947 Po
10 15730.373047 S 24947 B
13 15730.398438 ntask sched 51.000000
10 15730.401367 MS MEMNODE0 Co
18 15730.401367 L p 4000000 MEMNODE1 com_64
10 15731.722656 MS MEMNODE0 No
19 15731.722656 L p 0 MEMNODE0 com_0
10 15731.733398 MS MEMNODE0 Co
18 15731.733398 L p 4000000 MEMNODE1 com_65
10 15731.739258 MS MEMNODE1 No
19 15731.739258 L p 4000000 MEMNODE1 com_62
10 15731.756836 MS MEMNODE0 CoA
10 15731.766602 MS MEMNODE0 CoA
10 15733.111328 MS MEMNODE0 No
19 15733.111328 L p 1928086912 MEMNODE0 com_1928086720
10 15735.184570 MS MEMNODE0 No
19 15735.184570 L p 1928086920 MEMNODE0 com_1928086720
10 15735.189453 MS MEMNODE0 No
19 15735.189453 L p 4000000 MEMNODE0 com_63
10 15735.191406 S 24951 B
10 15735.191406 S 24952 B
10 15735.192383 S 24951 chol_model_22
10 15735.192383 S 24952 chol_model_22
10 15735.194336 S 24948 B
10 15735.195312 MS MEMNODE1 No
19 15735.195312 L p 4000000 MEMNODE1 com_61
10 15735.196289 S 24948 chol_model_22
13 15735.256836 ntask sched 50.000000
10 15735.258789 S 24949 Fi
10 15735.259766 MS MEMNODE1 No
19 15735.259766 L p 4000000 MEMNODE1 com_60
10 15735.260742 S 24949 B
10 15735.261719 S 24949 chol_model_22
10 15735.264648 MS MEMNODE0 No
19 15735.264648 L p 4000000 MEMNODE0 com_64
10 15735.290039 MS MEMNODE1 No
19 15735.290039 L p 4000000 MEMNODE1 com_59
10 15735.316406 MS MEMNODE1 No
19 15735.316406 L p 4000000 MEMNODE1 com_58
10 15735.322266 MS MEMNODE0 No
19 15735.322266 L p 4000000 MEMNODE0 com_65
10 15735.324219 S 24950 B
10 15735.325195 S 24950 chol_model_22
10 15735.327148 MS MEMNODE1 No
19 15735.327148 L p 4000000 MEMNODE1 com_57
10 15735.331055 MS MEMNODE1 No
19 15735.331055 L p 4000000 MEMNODE1 com_56
13 15735.334961 ntask sched 51.000000
13 15735.349609 ntask sched 52.000000
13 15735.362305 ntask sched 53.000000
13 15735.374023 ntask sched 54.000000
13 15735.385742 ntask sched 55.000000
13 15735.398438 ntask sched 56.000000
13 15735.409180 ntask sched 57.000000
13 15735.419922 ntask sched 58.000000
13 15735.431641 ntask sched 59.000000
13 15735.443359 ntask sched 60.000000
10 15735.450195 MS MEMNODE1 A
10 15735.952148 MS MEMNODE1 No
10 15735.955078 MS MEMNODE1 Co
18 15735.955078 L p 4000000 MEMNODE0 com_66
10 15735.962891 MS MEMNODE1 CoA
10 15737.135742 MS MEMNODE1 No
19 15737.135742 L p 1928086912 MEMNODE1 com_1928086720
10 15737.140625 MS MEMNODE1 A
10 15737.451172 MS MEMNODE1 No
10 15737.454102 MS MEMNODE1 Co
18 15737.454102 L p 4000000 MEMNODE0 com_67
10 15737.459961 MS MEMNODE1 CoA
10 15738.621094 MS MEMNODE1 No
19 15738.621094 L p 1928086912 MEMNODE1 com_1928086720
10 15738.625000 MS MEMNODE1 A
10 15738.931641 MS MEMNODE1 No
10 15738.934570 MS MEMNODE1 Co
18 15738.934570 L p 4000000 MEMNODE0 com_68
10 15738.941406 MS MEMNODE1 CoA
10 15740.217773 MS MEMNODE1 No
19 15740.217773 L p 1928086912 MEMNODE1 com_1928086720
10 15740.222656 MS MEMNODE1 A
10 15740.509766 MS MEMNODE1 No
10 15740.511719 MS MEMNODE1 Co
18 15740.511719 L p 4000000 MEMNODE0 com_69
10 15740.517578 MS MEMNODE1 CoA
10 15741.679688 MS MEMNODE1 No
19 15741.679688 L p 1928086912 MEMNODE1 com_1928086720
10 15741.684570 MS MEMNODE1 A
10 15741.971680 MS MEMNODE1 No
10 15741.973633 MS MEMNODE1 Co
18 15741.973633 L p 4000000 MEMNODE0 com_70
10 15741.978516 MS MEMNODE1 CoA
10 15743.146484 MS MEMNODE1 No
19 15743.146484 L p 1928086912 MEMNODE1 com_1928086720
10 15743.150391 MS MEMNODE1 A
10 15752.228516 MS MEMNODE1 No
10 15752.232422 MS MEMNODE1 Co
18 15752.232422 L p 4000000 MEMNODE0 com_71
10 15752.239258 MS MEMNODE1 CoA
10 15753.416992 MS MEMNODE1 No
19 15753.416992 L p 1928086912 MEMNODE1 com_1928086720
10 15753.421875 MS MEMNODE1 A
10 15753.708008 MS MEMNODE1 No
10 15753.709961 MS MEMNODE1 Co
18 15753.709961 L p 4000000 MEMNODE0 com_72
10 15753.715820 MS MEMNODE1 CoA
10 15754.872070 MS MEMNODE1 No
19 15754.872070 L p 1928086912 MEMNODE1 com_1928086720
10 15754.875977 MS MEMNODE1 A
10 15755.162109 MS MEMNODE1 No
10 15755.164062 MS MEMNODE1 Co
18 15755.164062 L p 4000000 MEMNODE0 com_73
10 15755.168945 MS MEMNODE1 CoA
10 15756.320312 MS MEMNODE1 No
19 15756.320312 L p 1928086912 MEMNODE1 com_1928086720
13 15756.329102 ntask sched 59.000000
10 15756.331055 S 24947 Fi
10 15756.333984 S 24947 B
10 15756.335938 S 24947 chol_model_21
10 15764.679688 S 64 B
10 15764.681641 S 24947 Po
10 15764.684570 S 24947 B
13 15764.711914 ntask sched 60.000000
13 15764.723633 ntask sched 61.000000
13 15764.735352 ntask sched 62.000000
13 15764.746094 ntask sched 63.000000
13 15764.756836 ntask sched 64.000000
13 15764.767578 ntask sched 65.000000
13 15764.779297 ntask sched 66.000000
13 15764.789062 ntask sched 67.000000
13 15764.799805 ntask sched 68.000000
13 15764.810547 ntask sched 69.000000
13 15764.822266 ntask sched 70.000000
13 15764.833008 ntask sched 71.000000
10 15764.869141 MS MEMNODE1 No
19 15764.869141 L p 4000000 MEMNODE1 com_73
10 15764.872070 MS MEMNODE1 No
19 15764.872070 L p 4000000 MEMNODE1 com_72
10 15764.874023 MS MEMNODE1 No
19 15764.874023 L p 4000000 MEMNODE1 com_71
10 15764.876953 MS MEMNODE1 No
19 15764.876953 L p 4000000 MEMNODE1 com_70
10 15764.878906 MS MEMNODE1 No
19 15764.878906 L p 4000000 MEMNODE1 com_69
10 15764.880859 MS MEMNODE1 No
19 15764.880859 L p 4000000 MEMNODE1 com_68
10 15764.882812 MS MEMNODE1 No
19 15764.882812 L p 4000000 MEMNODE1 com_67
10 15764.884766 MS MEMNODE1 No
19 15764.884766 L p 4000000 MEMNODE1 com_66
10 15764.886719 MS MEMNODE1 A
10 15765.379883 MS MEMNODE1 No
10 15765.381836 MS MEMNODE1 Co
18 15765.381836 L p 4000000 MEMNODE0 com_74
10 15765.389648 MS MEMNODE1 CoA
10 15766.527344 MS MEMNODE1 No
19 15766.527344 L p 1928086912 MEMNODE1 com_1928086720
10 15766.532227 MS MEMNODE1 A
10 15766.819336 MS MEMNODE1 No
10 15766.822266 MS MEMNODE1 Co
18 15766.822266 L p 4000000 MEMNODE0 com_75
10 15766.827148 MS MEMNODE1 CoA
10 15767.986328 MS MEMNODE1 No
19 15767.986328 L p 1928086912 MEMNODE1 com_1928086720
10 15767.991211 MS MEMNODE1 A
10 15768.300781 MS MEMNODE1 No
10 15768.302734 MS MEMNODE1 Co
18 15768.302734 L p 4000000 MEMNODE0 com_76
10 15768.308594 MS MEMNODE1 CoA
10 15769.461914 MS MEMNODE1 No
19 15769.461914 L p 1928086912 MEMNODE1 com_1928086720
10 15769.466797 MS MEMNODE1 A
10 15769.766602 MS MEMNODE1 No
10 15769.768555 MS MEMNODE1 Co
18 15769.768555 L p 4000000 MEMNODE0 com_77
10 15769.774414 MS MEMNODE1 CoA
10 15770.930664 MS MEMNODE1 No
19 15770.930664 L p 1928086912 MEMNODE1 com_1928086720
10 15770.935547 MS MEMNODE1 A
10 15771.219727 MS MEMNODE1 No
10 15771.222656 MS MEMNODE1 Co
18 15771.222656 L p 4000000 MEMNODE0 com_78
10 15771.227539 MS MEMNODE1 CoA
10 15772.389648 MS MEMNODE1 No
19 15772.389648 L p 1928086912 MEMNODE1 com_1928086720
10 15772.393555 MS MEMNODE1 A
10 15772.678711 MS MEMNODE1 No
10 15772.680664 MS MEMNODE1 Co
18 15772.680664 L p 4000000 MEMNODE0 com_79
10 15772.686523 MS MEMNODE1 CoA
10 15773.843750 MS MEMNODE1 No
19 15773.843750 L p 1928086912 MEMNODE1 com_1928086720
10 15773.847656 MS MEMNODE1 A
10 15774.133789 MS MEMNODE1 No
10 15774.136719 MS MEMNODE1 Co
18 15774.136719 L p 4000000 MEMNODE0 com_80
10 15774.141602 MS MEMNODE1 CoA
10 15775.302734 MS MEMNODE1 No
19 15775.302734 L p 1928086912 MEMNODE1 com_1928086720
10 15775.306641 MS MEMNODE1 A
10 15775.575195 MS MEMNODE1 No
10 15775.577148 MS MEMNODE1 Co
18 15775.577148 L p 4000000 MEMNODE0 com_81
10 15775.583008 MS MEMNODE1 CoA
10 15776.743164 MS MEMNODE1 No
19 15776.743164 L p 1928086912 MEMNODE1 com_1928086720
10 15776.747070 MS MEMNODE1 A
10 15777.023438 MS MEMNODE1 No
10 15777.026367 MS MEMNODE1 Co
18 15777.026367 L p 4000000 MEMNODE0 com_82
10 15777.031250 MS MEMNODE1 CoA
10 15778.185547 MS MEMNODE1 No
19 15778.185547 L p 1928086912 MEMNODE1 com_1928086720
10 15778.191406 MS MEMNODE1 A
10 15778.459961 MS MEMNODE1 No
10 15778.461914 MS MEMNODE1 Co
18 15778.461914 L p 4000000 MEMNODE0 com_83
10 15778.467773 MS MEMNODE1 CoA
10 15779.621094 MS MEMNODE1 No
19 15779.621094 L p 1928086912 MEMNODE1 com_1928086720
10 15779.625977 MS MEMNODE1 A
10 15779.903320 MS MEMNODE1 No
10 15779.906250 MS MEMNODE1 Co
18 15779.906250 L p 4000000 MEMNODE0 com_84
10 15779.911133 MS MEMNODE1 CoA
10 15781.067383 MS MEMNODE1 No
19 15781.067383 L p 1928086912 MEMNODE1 com_1928086720
13 15781.075195 ntask sched 70.000000
10 15781.078125 S 24947 Fi
10 15781.081055 S 24947 B
10 15781.082031 S 24947 chol_model_21
10 15789.436523 S 64 B
10 15789.438477 S 24947 Po
10 15789.442383 S 24947 B
13 15789.469727 ntask sched 71.000000
13 15789.482422 ntask sched 72.000000
13 15789.493164 ntask sched 73.000000
13 15789.503906 ntask sched 74.000000
13 15789.514648 ntask sched 75.000000
13 15789.526367 ntask sched 76.000000
13 15789.537109 ntask sched 77.000000
13 15789.547852 ntask sched 78.000000
13 15789.557617 ntask sched 79.000000
13 15789.569336 ntask sched 80.000000
13 15789.580078 ntask sched 81.000000
13 15789.590820 ntask sched 82.000000
13 15789.600586 ntask sched 83.000000
10 15789.636719 MS MEMNODE1 No
19 15789.636719 L p 4000000 MEMNODE1 com_84
10 15789.638672 MS MEMNODE1 No
19 15789.638672 L p 4000000 MEMNODE1 com_83
10 15789.641602 MS MEMNODE1 No
19 15789.641602 L p 4000000 MEMNODE1 com_82
10 15789.648438 MS MEMNODE1 No
19 15789.648438 L p 4000000 MEMNODE1 com_81
10 15789.651367 MS MEMNODE1 No
19 15789.651367 L p 4000000 MEMNODE1 com_80
10 15789.653320 MS MEMNODE1 No
19 15789.653320 L p 4000000 MEMNODE1 com_79
10 15789.656250 MS MEMNODE1 No
19 15789.656250 L p 4000000 MEMNODE1 com_78
10 15789.658203 MS MEMNODE1 No
19 15789.658203 L p 4000000 MEMNODE1 com_77
10 15789.660156 MS MEMNODE1 No
19 15789.660156 L p 4000000 MEMNODE1 com_76
10 15789.662109 MS MEMNODE1 No
19 15789.662109 L p 4000000 MEMNODE1 com_75
10 15789.664062 MS MEMNODE1 No
19 15789.664062 L p 4000000 MEMNODE1 com_74
10 15789.666992 MS MEMNODE1 A
10 15790.166992 MS MEMNODE1 No
10 15790.168945 MS MEMNODE1 Co
18 15790.168945 L p 4000000 MEMNODE0 com_85
10 15790.175781 MS MEMNODE1 CoA
10 15791.314453 MS MEMNODE1 No
19 15791.314453 L p 1928086912 MEMNODE1 com_1928086720
10 15791.319336 MS MEMNODE1 A
10 15791.591797 MS MEMNODE1 No
10 15791.593750 MS MEMNODE1 Co
18 15791.593750 L p 4000000 MEMNODE0 com_86
10 15791.599609 MS MEMNODE1 CoA
10 15792.762695 MS MEMNODE1 No
19 15792.762695 L p 1928086912 MEMNODE1 com_1928086720
10 15792.767578 MS MEMNODE1 A
10 15793.077148 MS MEMNODE1 No
10 15793.079102 MS MEMNODE1 Co
18 15793.079102 L p 4000000 MEMNODE0 com_87
10 15793.086914 MS MEMNODE1 CoA
10 15794.243164 MS MEMNODE1 No
19 15794.243164 L p 1928086912 MEMNODE1 com_1928086720
10 15794.248047 MS MEMNODE1 A
10 15794.538086 MS MEMNODE1 No
10 15794.540039 MS MEMNODE1 Co
18 15794.540039 L p 4000000 MEMNODE0 com_88
10 15794.545898 MS MEMNODE1 CoA
10 15795.706055 MS MEMNODE1 No
19 15795.706055 L p 1928086912 MEMNODE1 com_1928086720
10 15795.710938 MS MEMNODE1 A
10 15795.993164 MS MEMNODE1 No
10 15795.995117 MS MEMNODE1 Co
18 15795.995117 L p 4000000 MEMNODE0 com_89
10 15796.000977 MS MEMNODE1 CoA
10 15797.157227 MS MEMNODE1 No
19 15797.157227 L p 1928086912 MEMNODE1 com_1928086720
10 15797.162109 MS MEMNODE1 A
10 15797.439453 MS MEMNODE1 No
10 15797.441406 MS MEMNODE1 Co
18 15797.441406 L p 4000000 MEMNODE0 com_90
10 15797.447266 MS MEMNODE1 CoA
10 15798.609375 MS MEMNODE1 No
19 15798.609375 L p 1928086912 MEMNODE1 com_1928086720
10 15798.614258 MS MEMNODE1 A
10 15798.906250 MS MEMNODE1 No
10 15798.909180 MS MEMNODE1 Co
18 15798.909180 L p 4000000 MEMNODE0 com_91
10 15798.914062 MS MEMNODE1 CoA
10 15800.070312 MS MEMNODE1 No
19 15800.070312 L p 1928086912 MEMNODE1 com_1928086720
10 15800.074219 MS MEMNODE1 A
10 15800.348633 MS MEMNODE1 No
10 15800.351562 MS MEMNODE1 Co
18 15800.351562 L p 4000000 MEMNODE0 com_92
10 15800.357422 MS MEMNODE1 CoA
10 15801.513672 MS MEMNODE1 No
19 15801.513672 L p 1928086912 MEMNODE1 com_1928086720
10 15801.518555 MS MEMNODE1 A
10 15801.793945 MS MEMNODE1 No
10 15801.796875 MS MEMNODE1 Co
18 15801.796875 L p 4000000 MEMNODE0 com_93
10 15801.801758 MS MEMNODE1 CoA
10 15802.956055 MS MEMNODE1 No
19 15802.956055 L p 1928086912 MEMNODE1 com_1928086720
13 15802.964844 ntask sched 82.000000
10 15802.966797 S 24947 Fi
10 15802.969727 S 24947 B
10 15802.970703 S 24947 chol_model_21
10 15811.330078 S 64 B
10 15811.332031 S 24947 Po
10 15811.334961 S 24947 B
13 15811.362305 ntask sched 83.000000
13 15811.373047 ntask sched 84.000000
13 15811.383789 ntask sched 85.000000
13 15811.394531 ntask sched 86.000000
13 15811.407227 ntask sched 87.000000
13 15811.416992 ntask sched 88.000000
13 15811.427734 ntask sched 89.000000
13 15811.439453 ntask sched 90.000000
13 15811.450195 ntask sched 91.000000
13 15811.461914 ntask sched 92.000000
13 15811.472656 ntask sched 93.000000
13 15811.484375 ntask sched 94.000000
13 15811.495117 ntask sched 95.000000
13 15811.504883 ntask sched 96.000000
10 15811.541016 MS MEMNODE1 No
19 15811.541016 L p 4000000 MEMNODE1 com_93
10 15811.543945 MS MEMNODE1 No
19 15811.543945 L p 4000000 MEMNODE1 com_92
10 15811.546875 MS MEMNODE1 No
19 15811.546875 L p 4000000 MEMNODE1 com_91
10 15811.548828 MS MEMNODE1 No
19 15811.548828 L p 4000000 MEMNODE1 com_90
10 15811.551758 MS MEMNODE1 No
19 15811.551758 L p 4000000 MEMNODE1 com_89
10 15811.553711 MS MEMNODE1 No
19 15811.553711 L p 4000000 MEMNODE1 com_88
10 15811.555664 MS MEMNODE1 No
19 15811.555664 L p 4000000 MEMNODE1 com_87
10 15811.558594 MS MEMNODE1 No
19 15811.558594 L p 4000000 MEMNODE1 com_86
10 15811.561523 MS MEMNODE1 No
19 15811.561523 L p 4000000 MEMNODE1 com_85
10 15811.564453 MS MEMNODE1 A
10 15812.060547 MS MEMNODE1 No
10 15812.063477 MS MEMNODE1 Co
18 15812.063477 L p 4000000 MEMNODE0 com_94
10 15812.071289 MS MEMNODE1 CoA
10 15813.214844 MS MEMNODE1 No
19 15813.214844 L p 1928086912 MEMNODE1 com_1928086720
10 15813.219727 MS MEMNODE1 A
10 15813.497070 MS MEMNODE1 No
10 15813.499023 MS MEMNODE1 Co
18 15813.499023 L p 4000000 MEMNODE0 com_95
10 15813.504883 MS MEMNODE1 CoA
10 15814.683594 MS MEMNODE1 No
19 15814.683594 L p 1928086912 MEMNODE1 com_1928086720
10 15814.689453 MS MEMNODE1 A
10 15815.008789 MS MEMNODE1 No
10 15815.010742 MS MEMNODE1 Co
18 15815.010742 L p 4000000 MEMNODE0 com_96
10 15815.016602 MS MEMNODE1 CoA
10 15816.190430 MS MEMNODE1 No
19 15816.190430 L p 1928086912 MEMNODE1 com_1928086720
10 15816.194336 MS MEMNODE1 A
10 15816.489258 MS MEMNODE1 No
10 15816.492188 MS MEMNODE1 Co
18 15816.492188 L p 4000000 MEMNODE0 com_97
10 15816.497070 MS MEMNODE1 CoA
10 15817.679688 MS MEMNODE1 No
19 15817.679688 L p 1928086912 MEMNODE1 com_1928086720
10 15817.684570 MS MEMNODE1 A
10 15817.975586 MS MEMNODE1 No
10 15817.978516 MS MEMNODE1 Co
18 15817.978516 L p 4000000 MEMNODE0 com_98
10 15817.984375 MS MEMNODE1 CoA
10 15819.142578 MS MEMNODE1 No
19 15819.142578 L p 1928086912 MEMNODE1 com_1928086720
10 15819.147461 MS MEMNODE1 A
10 15819.435547 MS MEMNODE1 No
10 15819.439453 MS MEMNODE1 Co
18 15819.439453 L p 4000000 MEMNODE0 com_99
10 15819.444336 MS MEMNODE1 CoA
10 15820.606445 MS MEMNODE1 No
19 15820.606445 L p 1928086912 MEMNODE1 com_1928086720
10 15820.610352 MS MEMNODE1 A
10 15820.897461 MS MEMNODE1 No
10 15820.899414 MS MEMNODE1 Co
18 15820.899414 L p 4000000 MEMNODE0 com_100
10 15820.905273 MS MEMNODE1 CoA
10 15822.060547 MS MEMNODE1 No
19 15822.060547 L p 1928086912 MEMNODE1 com_1928086720
10 15822.065430 MS MEMNODE1 A
10 15822.351562 MS MEMNODE1 No
10 15822.353516 MS MEMNODE1 Co
18 15822.353516 L p 4000000 MEMNODE0 com_101
10 15822.360352 MS MEMNODE1 CoA
10 15823.518555 MS MEMNODE1 No
19 15823.518555 L p 1928086912 MEMNODE1 com_1928086720
10 15823.524414 MS MEMNODE1 A
10 15823.807617 MS MEMNODE1 No
10 15823.810547 MS MEMNODE1 Co
18 15823.810547 L p 4000000 MEMNODE0 com_102
10 15823.817383 MS MEMNODE1 CoA
10 15824.973633 MS MEMNODE1 No
19 15824.973633 L p 1928086912 MEMNODE1 com_1928086720
10 15824.977539 MS MEMNODE1 A
10 15825.252930 MS MEMNODE1 No
10 15825.255859 MS MEMNODE1 Co
18 15825.255859 L p 4000000 MEMNODE0 com_103
10 15825.278320 MS MEMNODE1 CoA
10 15826.433594 MS MEMNODE1 No
19 15826.433594 L p 1928086912 MEMNODE1 com_1928086720
13 15826.443359 ntask sched 95.000000
10 15826.445312 S 24947 Fi
10 15826.448242 S 24947 B
10 15826.450195 S 24947 chol_model_21
10 15827.362305 S 0 B
10 15827.363281 S 24951 Po
10 15827.366211 S 0 B
10 15827.366211 S 24951 B
10 15827.367188 S 24952 Po
10 15827.369141 S 24952 B
10 15827.375000 S 0 B
10 15827.375977 MS MEMNODE0 Co
18 15827.375977 L p 4000000 MEMNODE1 com_104
13 15827.376953 ntask sched 94.000000
10 15827.376953 S 24949 Po
10 15827.377930 S 24952 Fi
10 15827.379883 S 24952 B
10 15827.380859 S 24952 chol_model_22
10 15827.381836 S 24949 B
10 15827.396484 MS MEMNODE0 CoA
10 15827.401367 S 0 B
13 15827.402344 ntask sched 93.000000
10 15827.403320 S 24948 Po
10 15827.404297 S 24949 Fi
10 15827.405273 S 24948 B
10 15827.407227 S 24949 B
10 15827.408203 S 24949 chol_model_22
13 15827.414062 ntask sched 92.000000
10 15827.416016 S 24948 Fi
10 15827.417969 S 24948 B
10 15827.417969 S 24948 chol_model_22
10 15827.585938 S 0 B
10 15827.587891 S 24950 Po
10 15827.590820 S 24950 B
13 15827.598633 ntask sched 91.000000
10 15827.599609 S 24950 Fi
10 15827.601562 S 24950 B
10 15827.602539 S 24950 chol_model_22
10 15834.797852 S 64 B
10 15834.798828 S 24947 Po
10 15834.800781 S 24947 B
13 15834.826172 ntask sched 92.000000
13 15834.837891 ntask sched 93.000000
13 15834.849609 ntask sched 94.000000
13 15834.862305 ntask sched 95.000000
13 15834.873047 ntask sched 96.000000
13 15834.883789 ntask sched 97.000000
13 15834.896484 ntask sched 98.000000
13 15834.907227 ntask sched 99.000000
13 15834.918945 ntask sched 100.000000
13 15834.929688 ntask sched 101.000000
13 15834.941406 ntask sched 102.000000
10 15836.118164 MS MEMNODE0 No
19 15836.118164 L p 1928086912 MEMNODE0 com_1928086720
10 15836.125000 MS MEMNODE1 No
19 15836.125000 L p 4000000 MEMNODE1 com_103
10 15836.130859 MS MEMNODE0 Co
18 15836.130859 L p 4000000 MEMNODE1 com_105
10 15836.132812 MS MEMNODE1 No
19 15836.132812 L p 4000000 MEMNODE1 com_102
10 15836.149414 MS MEMNODE0 CoA
10 15837.517578 MS MEMNODE0 No
19 15837.517578 L p 1928086912 MEMNODE0 com_1928086720
10 15837.521484 MS MEMNODE1 No
19 15837.521484 L p 4000000 MEMNODE1 com_101
10 15837.524414 MS MEMNODE0 Co
18 15837.524414 L p 4000000 MEMNODE1 com_106
10 15837.536133 MS MEMNODE0 CoA
10 15838.905273 MS MEMNODE0 No
19 15838.905273 L p 1928086912 MEMNODE0 com_1928086720
10 15838.911133 MS MEMNODE1 No
19 15838.911133 L p 4000000 MEMNODE1 com_100
13 15838.918945 ntask sched 101.000000
10 15838.918945 MS MEMNODE1 No
19 15838.918945 L p 4000000 MEMNODE1 com_99
10 15838.920898 S 24951 Fi
10 15838.922852 S 24951 B
10 15838.923828 S 24951 chol_model_22
10 15838.944336 MS MEMNODE1 No
19 15838.944336 L p 4000000 MEMNODE1 com_98
10 15838.966797 MS MEMNODE1 No
19 15838.966797 L p 4000000 MEMNODE1 com_97
10 15838.989258 MS MEMNODE1 No
19 15838.989258 L p 4000000 MEMNODE1 com_96
10 15839.011719 MS MEMNODE1 No
19 15839.011719 L p 4000000 MEMNODE1 com_95
10 15839.034180 MS MEMNODE1 No
19 15839.034180 L p 4000000 MEMNODE1 com_94
13 15839.049805 ntask sched 102.000000
13 15839.061523 ntask sched 103.000000
13 15839.074219 ntask sched 104.000000
13 15839.086914 ntask sched 105.000000
10 15839.091797 MS MEMNODE1 A
10 15848.394531 MS MEMNODE1 No
10 15848.398438 MS MEMNODE1 Co
18 15848.398438 L p 4000000 MEMNODE0 com_107
10 15848.407227 MS MEMNODE1 CoA
10 15849.591797 MS MEMNODE1 No
19 15849.591797 L p 1928086912 MEMNODE1 com_1928086720
10 15849.597656 MS MEMNODE1 A
10 15849.928711 MS MEMNODE1 No
10 15849.930664 MS MEMNODE1 Co
18 15849.930664 L p 4000000 MEMNODE0 com_108
10 15849.936523 MS MEMNODE1 CoA
10 15851.148438 MS MEMNODE1 No
19 15851.148438 L p 1928086912 MEMNODE1 com_1928086720
10 15851.153320 MS MEMNODE1 A
10 15851.571289 MS MEMNODE1 No
10 15851.574219 MS MEMNODE1 Co
18 15851.574219 L p 4000000 MEMNODE0 com_109
10 15851.580078 MS MEMNODE1 CoA
10 15852.748047 MS MEMNODE1 No
19 15852.748047 L p 1928086912 MEMNODE1 com_1928086720
10 15852.751953 MS MEMNODE1 A
10 15853.054688 MS MEMNODE1 No
10 15853.056641 MS MEMNODE1 Co
18 15853.056641 L p 4000000 MEMNODE0 com_110
10 15853.063477 MS MEMNODE1 CoA
10 15854.222656 MS MEMNODE1 No
19 15854.222656 L p 1928086912 MEMNODE1 com_1928086720
10 15854.227539 MS MEMNODE1 A
10 15854.526367 MS MEMNODE1 No
10 15854.529297 MS MEMNODE1 Co
18 15854.529297 L p 4000000 MEMNODE0 com_111
10 15854.535156 MS MEMNODE1 CoA
10 15855.692383 MS MEMNODE1 No
19 15855.692383 L p 1928086912 MEMNODE1 com_1928086720
10 15855.697266 MS MEMNODE1 A
10 15855.990234 MS MEMNODE1 No
10 15855.993164 MS MEMNODE1 Co
18 15855.993164 L p 4000000 MEMNODE0 com_112
10 15855.999023 MS MEMNODE1 CoA
10 15857.159180 MS MEMNODE1 No
19 15857.159180 L p 1928086912 MEMNODE1 com_1928086720
10 15857.164062 MS MEMNODE1 A
10 15857.453125 MS MEMNODE1 No
10 15857.456055 MS MEMNODE1 Co
18 15857.456055 L p 4000000 MEMNODE0 com_113
10 15857.460938 MS MEMNODE1 CoA
10 15858.619141 MS MEMNODE1 No
19 15858.619141 L p 1928086912 MEMNODE1 com_1928086720
10 15858.623047 MS MEMNODE1 A
10 15858.934570 MS MEMNODE1 No
10 15858.936523 MS MEMNODE1 Co
18 15858.936523 L p 4000000 MEMNODE0 com_114
10 15858.949219 MS MEMNODE1 CoA
10 15860.105469 MS MEMNODE1 No
19 15860.105469 L p 1928086912 MEMNODE1 com_1928086720
10 15860.110352 MS MEMNODE1 A
10 15860.400391 MS MEMNODE1 No
10 15860.402344 MS MEMNODE1 Co
18 15860.402344 L p 4000000 MEMNODE0 com_115
10 15860.414062 MS MEMNODE1 CoA
10 15861.574219 MS MEMNODE1 No
19 15861.574219 L p 1928086912 MEMNODE1 com_1928086720
10 15861.579102 MS MEMNODE1 A
10 15861.871094 MS MEMNODE1 No
10 15861.873047 MS MEMNODE1 Co
18 15861.873047 L p 4000000 MEMNODE0 com_116
10 15861.884766 MS MEMNODE1 CoA
10 15863.072266 MS MEMNODE1 No
19 15863.072266 L p 1928086912 MEMNODE1 com_1928086720
10 15863.079102 MS MEMNODE1 A
10 15863.455078 MS MEMNODE1 No
10 15863.458008 MS MEMNODE1 Co
18 15863.458008 L p 4000000 MEMNODE0 com_117
10 15863.469727 MS MEMNODE1 CoA
10 15864.741211 MS MEMNODE1 No
19 15864.741211 L p 1928086912 MEMNODE1 com_1928086720
10 15864.746094 MS MEMNODE1 A
10 15865.026367 MS MEMNODE1 No
10 15865.029297 MS MEMNODE1 Co
18 15865.029297 L p 4000000 MEMNODE0 com_118
10 15865.041016 MS MEMNODE1 CoA
10 15866.201172 MS MEMNODE1 No
19 15866.201172 L p 1928086912 MEMNODE1 com_1928086720
10 15866.205078 MS MEMNODE1 A
10 15866.489258 MS MEMNODE1 No
10 15866.491211 MS MEMNODE1 Co
18 15866.491211 L p 4000000 MEMNODE0 com_119
10 15866.502930 MS MEMNODE1 CoA
10 15867.659180 MS MEMNODE1 No
19 15867.659180 L p 1928086912 MEMNODE1 com_1928086720
10 15867.663086 MS MEMNODE1 A
10 15867.949219 MS MEMNODE1 No
10 15867.952148 MS MEMNODE1 Co
18 15867.952148 L p 4000000 MEMNODE0 com_120
10 15867.963867 MS MEMNODE1 CoA
10 15869.125977 MS MEMNODE1 No
19 15869.125977 L p 1928086912 MEMNODE1 com_1928086720
13 15869.134766 ntask sched 104.000000
10 15869.137695 S 24947 Fi
10 15869.139648 S 24947 B
10 15869.141602 S 24947 chol_model_22
10 15872.462891 S 64 B
10 15872.463867 S 24947 Po
10 15872.465820 S 24947 B
13 15872.490234 ntask sched 105.000000
10 15872.522461 MS MEMNODE1 No
19 15872.522461 L p 4000000 MEMNODE1 com_120
10 15872.525391 MS MEMNODE1 No
19 15872.525391 L p 4000000 MEMNODE1 com_119
10 15872.527344 MS MEMNODE1 No
19 15872.527344 L p 4000000 MEMNODE1 com_118
10 15872.529297 MS MEMNODE1 No
19 15872.529297 L p 4000000 MEMNODE1 com_117
10 15872.532227 MS MEMNODE1 No
19 15872.532227 L p 4000000 MEMNODE1 com_116
10 15872.534180 MS MEMNODE1 No
19 15872.534180 L p 4000000 MEMNODE1 com_115
10 15872.536133 MS MEMNODE1 No
19 15872.536133 L p 4000000 MEMNODE1 com_114
10 15872.538086 MS MEMNODE1 No
19 15872.538086 L p 4000000 MEMNODE1 com_113
10 15872.540039 MS MEMNODE1 No
19 15872.540039 L p 4000000 MEMNODE1 com_112
10 15872.542969 MS MEMNODE1 No
19 15872.542969 L p 4000000 MEMNODE1 com_111
10 15872.544922 MS MEMNODE1 No
19 15872.544922 L p 4000000 MEMNODE1 com_110
10 15872.546875 MS MEMNODE1 No
19 15872.546875 L p 4000000 MEMNODE1 com_109
10 15872.549805 MS MEMNODE1 No
19 15872.549805 L p 4000000 MEMNODE1 com_108
10 15872.551758 MS MEMNODE1 No
19 15872.551758 L p 4000000 MEMNODE1 com_107
13 15872.553711 ntask sched 104.000000
10 15872.554688 S 24947 Fi
10 15872.556641 S 24947 B
10 15872.557617 S 24947 chol_model_22
10 15875.836914 S 64 B
10 15875.837891 S 24947 Po
10 15875.839844 S 24947 B
13 15875.847656 ntask sched 103.000000
10 15875.848633 S 24947 Fi
10 15875.850586 S 24947 B
10 15875.850586 S 24947 chol_model_22
10 15879.127930 S 64 B
10 15879.128906 S 24947 Po
10 15879.130859 S 24947 B
13 15879.136719 ntask sched 102.000000
10 15879.137695 S 24947 Fi
10 15879.139648 S 24947 B
10 15879.140625 S 24947 chol_model_22
10 15882.417969 S 64 B
10 15882.418945 S 24947 Po
10 15882.420898 S 24947 B
13 15882.426758 ntask sched 101.000000
10 15882.427734 S 24947 Fi
10 15882.429688 S 24947 B
10 15882.429688 S 24947 chol_model_22
10 15885.708984 S 64 B
10 15885.709961 S 24947 Po
10 15885.710938 S 24947 B
13 15885.717773 ntask sched 100.000000
10 15885.718750 S 24947 Fi
10 15885.720703 S 24947 B
10 15885.720703 S 24947 chol_model_22
10 15888.996094 S 64 B
10 15888.997070 S 24947 Po
10 15888.999023 S 24947 B
13 15889.005859 ntask sched 99.000000
10 15889.006836 S 24947 Fi
10 15889.008789 S 24947 B
10 15889.009766 S 24947 chol_model_22
10 15892.286133 S 64 B
10 15892.287109 S 24947 Po
10 15892.288086 S 24947 B
13 15892.294922 ntask sched 98.000000
10 15892.295898 S 24947 Fi
10 15892.297852 S 24947 B
10 15892.297852 S 24947 chol_model_22
10 15895.572266 S 64 B
10 15895.573242 S 24947 Po
10 15895.575195 S 24947 B
13 15895.581055 ntask sched 97.000000
10 15895.582031 S 24947 Fi
10 15895.583984 S 24947 B
10 15895.584961 S 24947 chol_model_22
10 15898.860352 S 64 B
10 15898.861328 S 24947 Po
10 15898.863281 S 24947 B
13 15898.870117 ntask sched 96.000000
10 15898.872070 S 24947 Fi
10 15898.873047 S 24947 B
10 15898.874023 S 24947 chol_model_22
10 15902.147461 S 64 B
10 15902.147461 S 24947 Po
10 15902.149414 S 24947 B
13 15902.155273 ntask sched 95.000000
10 15902.157227 S 24947 Fi
10 15902.158203 S 24947 B
10 15902.159180 S 24947 chol_model_22
10 15905.430664 S 64 B
10 15905.431641 S 24947 Po
10 15905.433594 S 24947 B
13 15905.440430 ntask sched 94.000000
10 15905.441406 S 24947 Fi
10 15905.442383 S 24947 B
10 15905.443359 S 24947 chol_model_22
10 15908.722656 S 64 B
10 15908.723633 S 24947 Po
10 15908.725586 S 24947 B
13 15908.732422 ntask sched 93.000000
10 15908.733398 S 24947 Fi
10 15908.735352 S 24947 B
10 15908.736328 S 24947 chol_model_22
10 15912.002930 S 64 B
10 15912.003906 S 24947 Po
10 15912.005859 S 24947 B
13 15912.013672 ntask sched 92.000000
10 15912.014648 S 24947 Fi
10 15912.016602 S 24947 B
10 15912.016602 S 24947 chol_model_22
10 15915.298828 S 64 B
10 15915.299805 S 24947 Po
10 15915.300781 S 24947 B
13 15915.306641 ntask sched 91.000000
10 15915.308594 S 24947 Fi
10 15915.309570 S 24947 B
10 15915.310547 S 24947 chol_model_22
10 15918.589844 S 64 B
10 15918.590820 S 24947 Po
10 15918.591797 S 24947 B
13 15918.598633 ntask sched 90.000000
10 15918.599609 S 24947 Fi
10 15918.600586 S 24947 B
10 15918.601562 S 24947 chol_model_22
10 15918.816406 S 0 B
10 15918.817383 S 24952 Po
10 15918.819336 S 24952 B
10 15918.871094 MS MEMNODE0 No
19 15918.871094 L p 4000000 MEMNODE0 com_106
10 15918.897461 MS MEMNODE0 No
19 15918.897461 L p 4000000 MEMNODE0 com_105
10 15918.921875 MS MEMNODE0 No
19 15918.921875 L p 4000000 MEMNODE0 com_104
10 15918.923828 MS MEMNODE0 Co
18 15918.923828 L p 4000000 MEMNODE1 com_121
10 15918.948242 MS MEMNODE0 CoA
10 15919.001953 S 0 B
10 15919.003906 S 24949 Po
10 15919.007812 S 24949 B
13 15919.024414 ntask sched 89.000000
10 15919.026367 S 24949 Fi
10 15919.032227 S 0 B
10 15919.032227 S 24949 B
10 15919.033203 S 24949 chol_model_22
10 15919.033203 S 24948 Po
10 15919.036133 S 24948 B
13 15919.043945 ntask sched 88.000000
10 15919.044922 S 24948 Fi
10 15919.046875 S 24948 B
10 15919.047852 S 24948 chol_model_22
10 15919.315430 S 0 B
10 15919.316406 S 24950 Po
10 15919.318359 S 24950 B
13 15919.327148 ntask sched 87.000000
10 15919.328125 S 24950 Fi
10 15919.330078 S 24950 B
10 15919.331055 S 24950 chol_model_22
10 15921.885742 S 64 B
10 15921.886719 S 24947 Po
10 15921.888672 S 24947 B
13 15921.896484 ntask sched 86.000000
10 15921.898438 S 24947 Fi
10 15921.899414 S 24947 B
10 15921.900391 S 24947 chol_model_22
10 15923.212891 MS MEMNODE0 No
19 15923.212891 L p 1928086912 MEMNODE0 com_1928086720
10 15923.228516 MS MEMNODE0 Co
18 15923.228516 L p 4000000 MEMNODE1 com_122
10 15923.255859 MS MEMNODE0 CoA
10 15926.509766 S 64 B
10 15926.510742 S 24947 Po
10 15926.512695 S 24947 B
13 15926.519531 ntask sched 85.000000
10 15926.522461 S 24947 Fi
10 15926.523438 S 24947 B
10 15926.524414 S 24947 chol_model_22
10 15928.416016 MS MEMNODE0 No
19 15928.416016 L p 1928086912 MEMNODE0 com_1928086720
13 15928.446289 ntask sched 84.000000
10 15928.448242 S 24952 Fi
10 15928.450195 S 24952 B
10 15928.451172 S 24952 chol_model_22
10 15930.215820 S 0 B
10 15930.216797 S 24951 Po
10 15930.218750 S 24951 B
10 15930.267578 MS MEMNODE0 No
19 15930.267578 L p 4000000 MEMNODE0 com_121
13 15930.269531 ntask sched 83.000000
10 15930.272461 S 24951 Fi
10 15930.273438 S 24951 B
10 15930.274414 S 24951 chol_model_22
10 15931.697266 S 64 B
10 15931.698242 S 24947 Po
10 15931.699219 S 24947 B
13 15931.706055 ntask sched 82.000000
10 15931.707031 S 24947 Fi
10 15931.708984 S 24947 B
10 15931.709961 S 24947 chol_model_22
10 15934.992188 S 64 B
10 15934.993164 S 24947 Po
10 15934.994141 S 24947 B
13 15935.000977 ntask sched 81.000000
10 15935.001953 S 24947 Fi
10 15935.003906 S 24947 B
10 15935.003906 S 24947 chol_model_22
10 15938.280273 S 64 B
10 15938.281250 S 24947 Po
10 15938.282227 S 24947 B
13 15938.289062 ntask sched 80.000000
10 15938.290039 S 24947 Fi
10 15938.291992 S 24947 B
10 15938.291992 S 24947 chol_model_22
10 15941.563477 S 64 B
10 15941.564453 S 24947 Po
10 15941.566406 S 24947 B
13 15941.572266 ntask sched 79.000000
10 15941.573242 S 24947 Fi
10 15941.575195 S 24947 B
10 15941.575195 S 24947 chol_model_22
10 15944.848633 S 64 B
10 15944.849609 S 24947 Po
10 15944.850586 S 24947 B
13 15944.858398 ntask sched 78.000000
10 15944.859375 S 24947 Fi
10 15944.860352 S 24947 B
10 15944.861328 S 24947 chol_model_22
10 15948.134766 S 64 B
10 15948.134766 S 24947 Po
10 15948.136719 S 24947 B
13 15948.142578 ntask sched 77.000000
10 15948.143555 S 24947 Fi
10 15948.146484 S 24947 B
10 15948.146484 S 24947 chol_model_22
10 15951.419922 S 64 B
10 15951.420898 S 24947 Po
10 15951.421875 S 24947 B
13 15951.428711 ntask sched 76.000000
10 15951.429688 S 24947 Fi
10 15951.431641 S 24947 B
10 15951.431641 S 24947 chol_model_22
10 15954.712891 S 64 B
10 15954.713867 S 24947 Po
10 15954.715820 S 24947 B
13 15954.724609 ntask sched 75.000000
10 15954.725586 S 24947 Fi
10 15954.727539 S 24947 B
10 15954.727539 S 24947 chol_model_22
10 15958.009766 S 64 B
10 15958.010742 S 24947 Po
10 15958.012695 S 24947 B
13 15958.018555 ntask sched 74.000000
10 15958.021484 S 24947 Fi
10 15958.022461 S 24947 B
10 15958.022461 S 24947 chol_model_22
10 15961.294922 S 64 B
10 15961.295898 S 24947 Po
10 15961.296875 S 24947 B
13 15961.302734 ntask sched 73.000000
10 15961.304688 S 24947 Fi
10 15961.305664 S 24947 B
10 15961.306641 S 24947 chol_model_22
10 15964.584961 S 64 B
10 15964.585938 S 24947 Po
10 15964.586914 S 24947 B
13 15964.593750 ntask sched 72.000000
10 15964.594727 S 24947 Fi
10 15964.595703 S 24947 B
10 15964.596680 S 24947 chol_model_22
10 15967.873047 S 64 B
10 15967.874023 S 24947 Po
10 15967.875977 S 24947 B
13 15967.881836 ntask sched 71.000000
10 15967.883789 S 24947 Fi
10 15967.884766 S 24947 B
10 15967.885742 S 24947 chol_model_22
10 15971.168945 S 64 B
10 15971.169922 S 24947 Po
10 15971.170898 S 24947 B
13 15971.176758 ntask sched 70.000000
10 15971.177734 S 24947 Fi
10 15971.179688 S 24947 B
10 15971.180664 S 24947 chol_model_22
10 15974.455078 S 64 B
10 15974.456055 S 24947 Po
10 15974.457031 S 24947 B
13 15974.463867 ntask sched 69.000000
10 15974.464844 S 24947 Fi
10 15974.465820 S 24947 B
10 15974.466797 S 24947 chol_model_22
10 15977.746094 S 64 B
10 15977.747070 S 24947 Po
10 15977.749023 S 24947 B
13 15977.757812 ntask sched 68.000000
10 15977.759766 S 24947 Fi
10 15977.760742 S 24947 B
10 15977.761719 S 24947 chol_model_22
10 15981.049805 S 64 B
10 15981.050781 S 24947 Po
10 15981.052734 S 24947 B
13 15981.058594 ntask sched 67.000000
10 15981.059570 S 24947 Fi
10 15981.061523 S 24947 B
10 15981.063477 S 24947 chol_model_22
10 15984.335938 S 64 B
10 15984.336914 S 24947 Po
10 15984.337891 S 24947 B
13 15984.343750 ntask sched 66.000000
10 15984.344727 S 24947 Fi
10 15984.345703 S 24947 B
10 15984.346680 S 24947 chol_model_22
10 15987.620117 S 64 B
10 15987.621094 S 24947 Po
10 15987.623047 S 24947 B
13 15987.628906 ntask sched 65.000000
10 15987.629883 S 24947 Fi
10 15987.631836 S 24947 B
10 15987.632812 S 24947 chol_model_22
10 15990.910156 S 64 B
10 15990.911133 S 24947 Po
10 15990.913086 S 24947 B
13 15990.918945 ntask sched 64.000000
10 15990.919922 S 24947 Fi
10 15990.921875 S 24947 B
10 15990.922852 S 24947 chol_model_22
10 15994.198242 S 64 B
10 15994.199219 S 24947 Po
10 15994.201172 S 24947 B
13 15994.207031 ntask sched 63.000000
10 15994.208984 S 24947 Fi
10 15994.209961 S 24947 B
10 15994.210938 S 24947 chol_model_22
10 15997.486328 S 64 B
10 15997.487305 S 24947 Po
10 15997.488281 S 24947 B
13 15997.494141 ntask sched 62.000000
10 15997.496094 S 24947 Fi
10 15997.497070 S 24947 B
10 15997.498047 S 24947 chol_model_22
10 16000.784180 S 64 B
10 16000.785156 S 24947 Po
10 16000.787109 S 24947 B
13 16000.793945 ntask sched 61.000000
10 16000.795898 S 24947 Fi
10 16000.796875 S 24947 B
10 16000.797852 S 24947 chol_model_22
10 16004.078125 S 64 B
10 16004.078125 S 24947 Po
10 16004.080078 S 24947 B
13 16004.085938 ntask sched 60.000000
10 16004.086914 S 24947 Fi
10 16004.088867 S 24947 B
10 16004.089844 S 24947 chol_model_22
10 16007.375000 S 64 B
10 16007.375977 S 24947 Po
10 16007.376953 S 24947 B
13 16007.383789 ntask sched 59.000000
10 16007.384766 S 24947 Fi
10 16007.386719 S 24947 B
10 16007.387695 S 24947 chol_model_22
10 16010.672852 S 64 B
10 16010.673828 S 24947 Po
10 16010.674805 S 24947 B
13 16010.680664 ntask sched 58.000000
10 16010.682617 S 24947 Fi
10 16010.683594 S 24947 B
10 16010.684570 S 24947 chol_model_22
10 16010.835938 S 0 B
10 16010.837891 S 24949 Po
10 16010.842773 S 24949 B
10 16010.899414 S 0 B
10 16010.900391 S 24948 Po
10 16010.902344 S 24948 B
13 16010.913086 ntask sched 57.000000
10 16010.915039 S 24948 Fi
10 16010.917969 S 24948 B
10 16010.918945 S 24948 chol_model_22
10 16010.926758 S 0 B
10 16010.927734 S 24950 Po
10 16010.929688 MS MEMNODE0 No
19 16010.929688 L p 4000000 MEMNODE0 com_122
10 16010.930664 S 24950 B
13 16010.932617 ntask sched 56.000000
10 16010.933594 S 24949 Fi
10 16010.936523 S 24949 B
10 16010.938477 S 24949 chol_model_22
13 16010.941406 ntask sched 55.000000
10 16010.943359 S 24950 Fi
10 16010.945312 S 24950 B
10 16010.946289 S 24950 chol_model_22
10 16013.958008 S 64 B
10 16013.958984 S 24947 Po
10 16013.959961 S 24947 B
13 16013.966797 ntask sched 54.000000
10 16013.968750 S 24947 Fi
10 16013.970703 S 24947 B
10 16013.971680 S 24947 chol_model_22
10 16017.250977 S 64 B
10 16017.250977 S 24947 Po
10 16017.252930 S 24947 B
13 16017.259766 ntask sched 53.000000
10 16017.260742 S 24947 Fi
10 16017.262695 S 24947 B
10 16017.262695 S 24947 chol_model_22
10 16018.969727 S 0 B
10 16018.970703 S 24952 Po
10 16018.972656 S 24952 B
13 16018.982422 ntask sched 52.000000
10 16018.983398 S 24952 Fi
10 16018.984375 S 24952 B
10 16018.985352 S 24952 chol_model_22
10 16020.541016 S 64 B
10 16020.541992 S 24947 Po
10 16020.542969 S 24947 B
13 16020.548828 ntask sched 51.000000
10 16020.550781 S 24947 Fi
10 16020.552734 S 24947 B
10 16020.552734 S 24947 chol_model_22
10 16020.799805 S 0 B
10 16020.800781 S 24951 Po
10 16020.802734 S 24951 B
13 16020.809570 ntask sched 50.000000
10 16020.811523 S 24951 Fi
10 16020.813477 S 24951 B
10 16020.814453 S 24951 chol_model_22
10 16023.834961 S 64 B
10 16023.835938 S 24947 Po
10 16023.837891 S 24947 B
13 16023.843750 ntask sched 49.000000
10 16023.844727 S 24947 Fi
10 16023.845703 S 24947 B
10 16023.846680 S 24947 chol_model_22
10 16027.123047 S 64 B
10 16027.124023 S 24947 Po
10 16027.125000 S 24947 B
13 16027.130859 ntask sched 48.000000
10 16027.131836 S 24947 Fi
10 16027.133789 S 24947 B
10 16027.133789 S 24947 chol_model_22
10 16030.414062 S 64 B
10 16030.414062 S 24947 Po
10 16030.416016 S 24947 B
13 16030.421875 ntask sched 47.000000
10 16030.422852 S 24947 Fi
10 16030.424805 S 24947 B
10 16030.425781 S 24947 chol_model_22
10 16033.706055 S 64 B
10 16033.707031 S 24947 Po
10 16033.708008 S 24947 B
13 16033.714844 ntask sched 46.000000
10 16033.715820 S 24947 Fi
10 16033.717773 S 24947 B
10 16033.717773 S 24947 chol_model_22
10 16036.993164 S 64 B
10 16036.994141 S 24947 Po
10 16036.995117 S 24947 B
13 16037.000977 ntask sched 45.000000
10 16037.001953 S 24947 Fi
10 16037.003906 S 24947 B
10 16037.003906 S 24947 chol_model_22
10 16040.275391 S 64 B
10 16040.276367 S 24947 Po
10 16040.277344 S 24947 B
13 16040.284180 ntask sched 44.000000
10 16040.285156 S 24947 Fi
10 16040.286133 S 24947 B
10 16040.287109 S 24947 chol_model_22
10 16043.570312 S 64 B
10 16043.571289 S 24947 Po
10 16043.573242 S 24947 B
13 16043.579102 ntask sched 43.000000
10 16043.581055 S 24947 Fi
10 16043.582031 S 24947 B
10 16043.583008 S 24947 chol_model_22
10 16046.861328 S 64 B
10 16046.862305 S 24947 Po
10 16046.863281 S 24947 B
13 16046.870117 ntask sched 42.000000
10 16046.871094 S 24947 Fi
10 16046.873047 S 24947 B
10 16046.874023 S 24947 chol_model_22
10 16050.149414 S 64 B
10 16050.149414 S 24947 Po
10 16050.151367 S 24947 B
13 16050.157227 ntask sched 41.000000
10 16050.158203 S 24947 Fi
10 16050.160156 S 24947 B
10 16050.161133 S 24947 chol_model_22
10 16053.441406 S 64 B
10 16053.442383 S 24947 Po
10 16053.443359 S 24947 B
13 16053.449219 ntask sched 40.000000
10 16053.451172 S 24947 Fi
10 16053.452148 S 24947 B
10 16053.453125 S 24947 chol_model_22
10 16056.731445 S 64 B
10 16056.732422 S 24947 Po
10 16056.734375 S 24947 B
13 16056.740234 ntask sched 39.000000
10 16056.741211 S 24947 Fi
10 16056.743164 S 24947 B
10 16056.744141 S 24947 chol_model_22
10 16060.019531 S 64 B
10 16060.019531 S 24947 Po
10 16060.022461 S 24947 B
13 16060.028320 ntask sched 38.000000
10 16060.029297 S 24947 Fi
10 16060.031250 S 24947 B
10 16060.032227 S 24947 chol_model_22
10 16063.306641 S 64 B
10 16063.307617 S 24947 Po
10 16063.308594 S 24947 B
13 16063.315430 ntask sched 37.000000
10 16063.317383 S 24947 Fi
10 16063.318359 S 24947 B
10 16063.319336 S 24947 chol_model_22
10 16066.600586 S 64 B
10 16066.601562 S 24947 Po
10 16066.603516 S 24947 B
13 16066.610352 ntask sched 36.000000
10 16066.612305 S 24947 Fi
10 16066.613281 S 24947 B
10 16066.614258 S 24947 chol_model_22
10 16069.899414 S 64 B
10 16069.900391 S 24947 Po
10 16069.902344 S 24947 B
13 16069.908203 ntask sched 35.000000
10 16069.910156 S 24947 Fi
10 16069.911133 S 24947 B
10 16069.912109 S 24947 chol_model_22
10 16073.185547 S 64 B
10 16073.186523 S 24947 Po
10 16073.189453 S 24947 B
13 16073.195312 ntask sched 34.000000
10 16073.196289 S 24947 Fi
10 16073.197266 S 24947 B
10 16073.198242 S 24947 chol_model_22
10 16076.469727 S 64 B
10 16076.470703 S 24947 Po
10 16076.472656 S 24947 B
13 16076.478516 ntask sched 33.000000
10 16076.480469 S 24947 Fi
10 16076.482422 S 24947 B
10 16076.482422 S 24947 chol_model_22
10 16079.757812 S 64 B
10 16079.758789 S 24947 Po
10 16079.760742 S 24947 B
13 16079.766602 ntask sched 32.000000
10 16079.767578 S 24947 Fi
10 16079.768555 S 24947 B
10 16079.769531 S 24947 chol_model_22
10 16083.041992 S 64 B
10 16083.042969 S 24947 Po
10 16083.044922 S 24947 B
13 16083.050781 ntask sched 31.000000
10 16083.051758 S 24947 Fi
10 16083.053711 S 24947 B
10 16083.053711 S 24947 chol_model_22
10 16086.330078 S 64 B
10 16086.331055 S 24947 Po
10 16086.333008 S 24947 B
13 16086.337891 ntask sched 30.000000
10 16086.339844 S 24947 Fi
10 16086.340820 S 24947 B
10 16086.341797 S 24947 chol_model_22
10 16089.625977 S 64 B
10 16089.626953 S 24947 Po
10 16089.627930 S 24947 B
13 16089.634766 ntask sched 29.000000
10 16089.636719 S 24947 Fi
10 16089.637695 S 24947 B
10 16089.638672 S 24947 chol_model_22
10 16092.916992 S 64 B
10 16092.917969 S 24947 Po
10 16092.919922 S 24947 B
13 16092.925781 ntask sched 28.000000
10 16092.927734 S 24947 Fi
10 16092.928711 S 24947 B
10 16092.929688 S 24947 chol_model_22
10 16096.210938 S 64 B
10 16096.211914 S 24947 Po
10 16096.213867 S 24947 B
13 16096.219727 ntask sched 27.000000
10 16096.220703 S 24947 Fi
10 16096.221680 S 24947 B
10 16096.222656 S 24947 chol_model_22
10 16099.496094 S 64 B
10 16099.497070 S 24947 Po
10 16099.498047 S 24947 B
13 16099.503906 ntask sched 26.000000
10 16099.504883 S 24947 Fi
10 16099.506836 S 24947 B
10 16099.506836 S 24947 chol_model_22
10 16102.778320 S 64 B
10 16102.779297 S 24947 Po
10 16102.781250 S 24947 B
13 16102.787109 ntask sched 25.000000
10 16102.788086 S 24947 Fi
10 16102.790039 S 24947 B
10 16102.790039 S 24947 chol_model_22
10 16102.856445 S 0 B
10 16102.858398 S 24949 Po
10 16102.863281 S 24949 B
10 16103.041992 S 0 B
10 16103.042969 S 24948 Po
10 16103.045898 S 24948 B
10 16103.049805 S 0 B
10 16103.051758 S 24950 Po
10 16103.053711 S 24950 B
10 16106.067383 S 64 B
10 16106.067383 S 24947 Po
10 16106.069336 S 24947 B
13 16106.078125 ntask sched 24.000000
10 16106.080078 S 24947 Fi
10 16106.081055 S 24947 B
10 16106.082031 S 24947 chol_model_22
10 16109.097656 S 0 B
10 16109.098633 S 24952 Po
10 16109.100586 S 24952 B
13 16109.129883 ntask sched 23.000000
10 16109.132812 S 24952 Fi
10 16109.133789 S 24952 B
10 16109.134766 S 24952 chol_model_11
10 16109.363281 S 64 B
10 16109.364258 S 24947 Po
10 16109.365234 S 24947 B
13 16109.372070 ntask sched 22.000000
10 16109.374023 S 24947 Fi
10 16109.375000 S 24947 B
10 16109.375977 S 24947 chol_model_22
10 16110.986328 S 0 B
10 16110.987305 S 24951 Po
10 16110.989258 S 24951 B
10 16112.652344 S 64 B
10 16112.653320 S 24947 Po
10 16112.654297 S 24947 B
13 16112.661133 ntask sched 21.000000
10 16112.662109 S 24947 Fi
10 16112.664062 S 24947 B
10 16112.664062 S 24947 chol_model_22
10 16115.946289 S 64 B
10 16115.947266 S 24947 Po
10 16115.948242 S 24947 B
13 16115.955078 ntask sched 20.000000
10 16115.956055 S 24947 Fi
10 16115.958008 S 24947 B
10 16115.958984 S 24947 chol_model_22
10 16119.238281 S 64 B
10 16119.239258 S 24947 Po
10 16119.241211 S 24947 B
13 16119.247070 ntask sched 19.000000
10 16119.249023 S 24947 Fi
10 16119.250000 S 24947 B
10 16119.250977 S 24947 chol_model_22
10 16122.526367 S 64 B
10 16122.527344 S 24947 Po
10 16122.528320 S 24947 B
13 16122.535156 ntask sched 18.000000
10 16122.536133 S 24947 Fi
10 16122.538086 S 24947 B
10 16122.538086 S 24947 chol_model_22
10 16125.814453 S 64 B
10 16125.815430 S 24947 Po
10 16125.817383 S 24947 B
13 16125.823242 ntask sched 17.000000
10 16125.824219 S 24947 Fi
10 16125.826172 S 24947 B
10 16125.826172 S 24947 chol_model_22
10 16129.101562 S 64 B
10 16129.102539 S 24947 Po
10 16129.103516 S 24947 B
13 16129.111328 ntask sched 16.000000
10 16129.112305 S 24947 Fi
10 16129.113281 S 24947 B
10 16129.114258 S 24947 chol_model_22
10 16132.386719 S 64 B
10 16132.387695 S 24947 Po
10 16132.388672 S 24947 B
13 16132.394531 ntask sched 15.000000
10 16132.397461 S 24947 Fi
10 16132.398438 S 24947 B
10 16132.399414 S 24947 chol_model_22
10 16135.672852 S 64 B
10 16135.672852 S 24947 Po
10 16135.674805 S 24947 B
13 16135.681641 ntask sched 14.000000
10 16135.682617 S 24947 Fi
10 16135.683594 S 24947 B
10 16135.684570 S 24947 chol_model_22
10 16138.958984 S 64 B
10 16138.959961 S 24947 Po
10 16138.960938 S 24947 B
13 16138.967773 ntask sched 13.000000
10 16138.968750 S 24947 Fi
10 16138.970703 S 24947 B
10 16138.970703 S 24947 chol_model_22
10 16142.250977 S 64 B
10 16142.251953 S 24947 Po
10 16142.252930 S 24947 B
13 16142.258789 ntask sched 12.000000
10 16142.260742 S 24947 Fi
10 16142.261719 S 24947 B
10 16142.262695 S 24947 chol_model_22
10 16145.533203 S 64 B
10 16145.534180 S 24947 Po
10 16145.535156 S 24947 B
13 16145.541992 ntask sched 11.000000
10 16145.542969 S 24947 Fi
10 16145.544922 S 24947 B
10 16145.544922 S 24947 chol_model_22
10 16148.825195 S 64 B
10 16148.826172 S 24947 Po
10 16148.827148 S 24947 B
13 16148.833984 ntask sched 10.000000
10 16148.834961 S 24947 Fi
10 16148.836914 S 24947 B
10 16148.836914 S 24947 chol_model_22
10 16152.111328 S 64 B
10 16152.112305 S 24947 Po
10 16152.113281 S 24947 B
13 16152.119141 ntask sched 9.000000
10 16152.121094 S 24947 Fi
10 16152.122070 S 24947 B
10 16152.123047 S 24947 chol_model_22
10 16155.400391 S 64 B
10 16155.401367 S 24947 Po
10 16155.402344 S 24947 B
13 16155.409180 ntask sched 8.000000
10 16155.410156 S 24947 Fi
10 16155.412109 S 24947 B
10 16155.413086 S 24947 chol_model_22
10 16158.683594 S 64 B
10 16158.684570 S 24947 Po
10 16158.686523 S 24947 B
13 16158.693359 ntask sched 7.000000
10 16158.694336 S 24947 Fi
10 16158.696289 S 24947 B
10 16158.696289 S 24947 chol_model_22
10 16161.972656 S 64 B
10 16161.972656 S 24947 Po
10 16161.974609 S 24947 B
13 16161.981445 ntask sched 6.000000
10 16161.982422 S 24947 Fi
10 16161.984375 S 24947 B
10 16161.985352 S 24947 chol_model_22
10 16165.253906 S 64 B
10 16165.254883 S 24947 Po
10 16165.255859 S 24947 B
13 16165.262695 ntask sched 5.000000
10 16165.263672 S 24947 Fi
10 16165.265625 S 24947 B
10 16165.265625 S 24947 chol_model_22
10 16168.542969 S 64 B
10 16168.543945 S 24947 Po
10 16168.544922 S 24947 B
13 16168.550781 ntask sched 4.000000
10 16168.552734 S 24947 Fi
10 16168.553711 S 24947 B
10 16168.554688 S 24947 chol_model_22
10 16171.824219 S 64 B
10 16171.825195 S 24947 Po
10 16171.827148 S 24947 B
13 16171.833008 ntask sched 3.000000
10 16171.833984 S 24947 Fi
10 16171.835938 S 24947 B
10 16171.836914 S 24947 chol_model_22
10 16174.786133 S 0 B
10 16174.786133 S 24952 Po
10 16174.788086 S 24952 B
13 16174.814453 ntask sched 4.000000
13 16174.828125 ntask sched 5.000000
13 16174.842773 ntask sched 6.000000
13 16174.857422 ntask sched 7.000000
13 16174.870117 ntask sched 8.000000
13 16174.876953 ntask sched 7.000000
10 16174.880859 S 24948 Fi
10 16174.882812 S 24948 B
10 16174.884766 S 24948 chol_model_21
13 16174.888672 ntask sched 8.000000
10 16174.890625 MS MEMNODE0 Co
18 16174.890625 L p 4000000 MEMNODE1 com_123
13 16174.903320 ntask sched 9.000000
13 16174.905273 ntask sched 8.000000
10 16174.908203 S 24950 Fi
10 16174.909180 S 24950 B
10 16174.910156 S 24950 chol_model_21
10 16174.915039 MS MEMNODE0 CoA
13 16174.916992 ntask sched 9.000000
10 16174.917969 MS MEMNODE0 Co
18 16174.917969 L p 4000000 MEMNODE1 com_124
13 16174.928711 ntask sched 10.000000
13 16174.941406 ntask sched 11.000000
13 16174.953125 ntask sched 12.000000
13 16174.965820 ntask sched 13.000000
13 16174.977539 ntask sched 14.000000
13 16174.989258 ntask sched 15.000000
10 16174.993164 MS MEMNODE0 Co
18 16174.993164 L p 4000000 MEMNODE1 com_125
10 16175.114258 S 64 B
10 16175.115234 S 24947 Po
10 16175.117188 S 24947 B
10 16175.123047 MS MEMNODE1 Co
18 16175.123047 L p 4000000 MEMNODE0 com_126
10 16176.541992 MS MEMNODE0 No
19 16176.541992 L p 0 MEMNODE0 com_0
10 16176.551758 MS MEMNODE0 CoA
10 16176.559570 MS MEMNODE0 CoA
10 16178.489258 MS MEMNODE0 No
19 16178.489258 L p 1928086912 MEMNODE0 com_1928086720
13 16178.504883 ntask sched 14.000000
10 16178.507812 S 24949 Fi
10 16178.522461 MS MEMNODE1 CoA
10 16180.087891 MS MEMNODE0 No
19 16180.087891 L p 1928086912 MEMNODE0 com_1928086720
13 16180.096680 ntask sched 13.000000
10 16180.098633 S 24951 Fi
10 16181.314453 MS MEMNODE1 No
19 16181.314453 L p 1928086912 MEMNODE1 com_1928086720
10 16181.321289 MS MEMNODE0 No
19 16181.321289 L p 4000000 MEMNODE0 com_123
13 16181.332031 ntask sched 12.000000
10 16181.333008 MS MEMNODE0 No
19 16181.333008 L p 4000000 MEMNODE0 com_124
10 16181.333008 S 24952 Fi
10 16181.339844 MS MEMNODE1 A
10 16181.341797 S 24949 B
10 16181.342773 S 24951 B
10 16181.342773 S 24949 chol_model_21
10 16181.343750 S 24951 chol_model_21
10 16181.997070 MS MEMNODE1 No
10 16181.999023 MS MEMNODE0 No
19 16181.999023 L p 4000000 MEMNODE0 com_125
10 16182.000000 MS MEMNODE1 Co
18 16182.000000 L p 4000000 MEMNODE0 com_127
10 16182.000977 S 24952 B
10 16182.001953 S 24952 chol_model_21
10 16182.009766 MS MEMNODE1 CoA
10 16183.278320 MS MEMNODE1 No
19 16183.278320 L p 1928086912 MEMNODE1 com_1928086720
10 16183.283203 MS MEMNODE1 A
10 16183.594727 MS MEMNODE1 No
10 16183.596680 MS MEMNODE1 Co
18 16183.596680 L p 4000000 MEMNODE0 com_128
10 16183.612305 MS MEMNODE1 CoA
10 16184.786133 MS MEMNODE1 No
19 16184.786133 L p 1928086912 MEMNODE1 com_1928086720
10 16184.791016 MS MEMNODE1 A
10 16185.105469 MS MEMNODE1 No
10 16185.107422 MS MEMNODE1 Co
18 16185.107422 L p 4000000 MEMNODE0 com_129
10 16185.117188 MS MEMNODE1 CoA
10 16186.292969 MS MEMNODE1 No
19 16186.292969 L p 1928086912 MEMNODE1 com_1928086720
10 16186.296875 MS MEMNODE1 A
10 16186.602539 MS MEMNODE1 No
10 16186.606445 MS MEMNODE1 Co
18 16186.606445 L p 4000000 MEMNODE0 com_130
10 16186.617188 MS MEMNODE1 CoA
10 16187.800781 MS MEMNODE1 No
19 16187.800781 L p 1928086912 MEMNODE1 com_1928086720
13 16187.808594 ntask sched 11.000000
10 16187.811523 S 24947 Fi
10 16187.815430 S 24947 B
10 16187.816406 S 24947 chol_model_22
10 16191.125000 S 64 B
10 16191.125977 S 24947 Po
10 16191.128906 S 24947 B
10 16191.163086 MS MEMNODE1 No
19 16191.163086 L p 4000000 MEMNODE1 com_130
10 16191.166016 MS MEMNODE1 No
19 16191.166016 L p 4000000 MEMNODE1 com_129
10 16191.168945 MS MEMNODE1 No
19 16191.168945 L p 4000000 MEMNODE1 com_128
10 16191.171875 MS MEMNODE1 No
19 16191.171875 L p 4000000 MEMNODE1 com_127
10 16191.173828 MS MEMNODE1 No
19 16191.173828 L p 4000000 MEMNODE1 com_126
13 16191.175781 ntask sched 10.000000
10 16191.177734 S 24947 Fi
10 16191.179688 S 24947 B
10 16191.180664 S 24947 chol_model_22
10 16194.455078 S 64 B
10 16194.455078 S 24947 Po
10 16194.457031 S 24947 B
13 16194.462891 ntask sched 9.000000
10 16194.464844 S 24947 Fi
10 16194.465820 S 24947 B
10 16194.466797 S 24947 chol_model_22
10 16197.747070 S 64 B
10 16197.748047 S 24947 Po
10 16197.750000 S 24947 B
13 16197.755859 ntask sched 8.000000
10 16197.757812 S 24947 Fi
10 16197.758789 S 24947 B
10 16197.759766 S 24947 chol_model_21
10 16206.086914 S 64 B
10 16206.087891 S 24947 Po
10 16206.089844 S 24947 B
13 16206.113281 ntask sched 9.000000
13 16206.120117 ntask sched 8.000000
10 16206.121094 S 24947 Fi
10 16206.122070 S 24947 B
10 16206.122070 S 24947 chol_model_21
10 16214.431641 S 64 B
10 16214.432617 S 24947 Po
10 16214.434570 S 24947 B
13 16214.451172 ntask sched 9.000000
13 16214.462891 ntask sched 10.000000
13 16214.467773 ntask sched 9.000000
10 16214.468750 S 24947 Fi
10 16214.470703 S 24947 B
10 16214.470703 S 24947 chol_model_21
10 16222.788086 S 64 B
10 16222.789062 S 24947 Po
10 16222.790039 S 24947 B
13 16222.806641 ntask sched 10.000000
13 16222.818359 ntask sched 11.000000
13 16222.829102 ntask sched 12.000000
13 16222.834961 ntask sched 11.000000
10 16222.835938 S 24947 Fi
10 16222.836914 S 24947 B
10 16222.837891 S 24947 chol_model_21
10 16223.486328 S 0 B
10 16223.489258 S 24950 Po
10 16223.489258 S 24948 Po
10 16223.493164 S 24950 B
10 16223.493164 S 24948 B
13 16223.525391 ntask sched 12.000000
13 16223.531250 ntask sched 13.000000
13 16223.542969 ntask sched 14.000000
13 16223.546875 ntask sched 15.000000
13 16223.556641 ntask sched 16.000000
13 16223.561523 ntask sched 17.000000
13 16223.571289 ntask sched 18.000000
13 16223.576172 ntask sched 19.000000
10 16223.583984 MS MEMNODE0 Co
18 16223.583984 L p 4000000 MEMNODE1 com_131
13 16223.585938 ntask sched 20.000000
10 16223.590820 MS MEMNODE0 Co
18 16223.590820 L p 4000000 MEMNODE1 com_132
10 16223.606445 MS MEMNODE0 CoA
10 16223.611328 MS MEMNODE0 CoA
10 16229.343750 S 0 B
10 16229.344727 S 24949 Po
10 16229.346680 S 24949 B
13 16229.370117 ntask sched 21.000000
13 16229.384766 ntask sched 22.000000
13 16229.399414 ntask sched 23.000000
13 16229.413086 ntask sched 24.000000
13 16229.426758 ntask sched 25.000000
13 16229.442383 ntask sched 26.000000
10 16229.447266 MS MEMNODE0 Co
18 16229.447266 L p 4000000 MEMNODE1 com_133
10 16229.504883 S 0 B
10 16229.505859 S 24951 Po
10 16229.507812 S 24951 B
10 16230.098633 S 0 B
10 16230.100586 S 24952 Po
10 16230.101562 S 24952 B
10 16231.166992 S 64 B
10 16231.167969 S 24947 Po
10 16231.169922 S 24947 B
10 16232.515625 MS MEMNODE0 No
19 16232.515625 L p 1928086848 MEMNODE0 com_1928087104
10 16233.927734 MS MEMNODE0 No
19 16233.927734 L p 1928086920 MEMNODE0 com_1928086720
10 16233.935547 MS MEMNODE0 CoA
13 16233.951172 ntask sched 25.000000
10 16233.953125 S 24950 Fi
13 16233.955078 ntask sched 24.000000
10 16233.957031 S 24948 Fi
10 16235.369141 MS MEMNODE0 No
19 16235.369141 L p 1928086912 MEMNODE0 com_1928086720
10 16235.375000 MS MEMNODE0 No
19 16235.375000 L p 4000000 MEMNODE0 com_131
10 16235.379883 MS MEMNODE0 No
19 16235.379883 L p 4000000 MEMNODE0 com_132
10 16235.381836 S 24948 B
10 16235.381836 S 24950 B
10 16235.382812 S 24948 chol_model_22
10 16235.382812 S 24950 chol_model_22
10 16235.386719 MS MEMNODE0 Co
18 16235.386719 L p 4000000 MEMNODE1 com_134
10 16235.392578 MS MEMNODE0 CoA
13 16235.403320 ntask sched 25.000000
13 16235.405273 ntask sched 26.000000
13 16235.417969 ntask sched 27.000000
13 16235.419922 ntask sched 28.000000
13 16235.432617 ntask sched 29.000000
13 16235.433594 ntask sched 30.000000
13 16235.449219 ntask sched 31.000000
13 16235.453125 ntask sched 32.000000
13 16235.466797 ntask sched 33.000000
13 16235.467773 ntask sched 34.000000
13 16235.481445 ntask sched 35.000000
13 16235.484375 ntask sched 36.000000
13 16235.496094 ntask sched 37.000000
13 16235.498047 ntask sched 38.000000
13 16235.503906 ntask sched 37.000000
10 16235.505859 S 24952 Fi
13 16235.509766 ntask sched 38.000000
10 16235.514648 MS MEMNODE1 A
10 16236.863281 MS MEMNODE0 No
19 16236.863281 L p 1928086912 MEMNODE0 com_1928086720
10 16236.867188 MS MEMNODE0 No
19 16236.867188 L p 4000000 MEMNODE0 com_133
13 16236.871094 ntask sched 39.000000
10 16236.875000 MS MEMNODE0 Co
18 16236.875000 L p 4000000 MEMNODE1 com_135
10 16237.446289 MS MEMNODE1 No
10 16237.448242 MS MEMNODE1 Co
18 16237.448242 L p 4000000 MEMNODE0 com_136
10 16237.455078 MS MEMNODE0 CoA
10 16237.456055 MS MEMNODE1 CoA
10 16237.459961 MS MEMNODE0 No
19 16237.459961 L p 4000000 MEMNODE0 com_134
10 16238.860352 MS MEMNODE0 No
19 16238.860352 L p 0 MEMNODE0 com_0
10 16240.132812 MS MEMNODE1 No
19 16240.132812 L p 1928086920 MEMNODE1 com_1928086720
10 16240.143555 MS MEMNODE0 Co
18 16240.143555 L p 4000000 MEMNODE1 com_137
13 16240.144531 ntask sched 40.000000
10 16240.152344 MS MEMNODE1 A
10 16240.158203 MS MEMNODE0 CoA
10 16241.696289 MS MEMNODE0 No
19 16241.696289 L p 1928086912 MEMNODE0 com_1928086720
10 16241.986328 MS MEMNODE1 No
10 16241.989258 MS MEMNODE1 Co
18 16241.989258 L p 4000000 MEMNODE0 com_138
10 16241.990234 MS MEMNODE0 No
19 16241.990234 L p 4000000 MEMNODE0 com_135
13 16242.005859 ntask sched 39.000000
10 16242.009766 S 24949 Fi
10 16242.012695 S 24949 B
10 16242.014648 S 24949 chol_model_22
10 16242.022461 MS MEMNODE1 CoA
10 16243.205078 MS MEMNODE1 No
19 16243.205078 L p 1928086912 MEMNODE1 com_1928086720
10 16243.210938 MS MEMNODE0 No
19 16243.210938 L p 4000000 MEMNODE0 com_137
13 16243.213867 ntask sched 40.000000
10 16243.213867 S 24952 B
10 16243.214844 MS MEMNODE1 A
10 16243.214844 S 24952 chol_model_22
13 16243.228516 ntask sched 41.000000
13 16243.242188 ntask sched 42.000000
13 16243.254883 ntask sched 43.000000
13 16243.266602 ntask sched 44.000000
13 16243.279297 ntask sched 45.000000
13 16243.291992 ntask sched 46.000000
10 16243.298828 MS MEMNODE0 Co
18 16243.298828 L p 4000000 MEMNODE1 com_139
10 16243.549805 MS MEMNODE1 No
10 16243.552734 MS MEMNODE1 Co
18 16243.552734 L p 4000000 MEMNODE0 com_140
10 16243.554688 MS MEMNODE0 CoA
10 16243.566406 MS MEMNODE1 CoA
10 16245.534180 MS MEMNODE0 No
19 16245.534180 L p 1928086912 MEMNODE0 com_1928086720
10 16246.702148 MS MEMNODE1 No
19 16246.702148 L p 1928086920 MEMNODE1 com_1928086720
10 16246.710938 MS MEMNODE0 Co
18 16246.710938 L p 4000000 MEMNODE1 com_141
10 16246.719727 MS MEMNODE1 A
10 16246.723633 MS MEMNODE0 CoA
10 16247.184570 MS MEMNODE1 No
10 16247.188477 MS MEMNODE1 Co
18 16247.188477 L p 4000000 MEMNODE0 com_142
10 16248.542969 MS MEMNODE0 No
19 16248.542969 L p 0 MEMNODE0 com_0
10 16248.554688 MS MEMNODE1 CoA
13 16248.565430 ntask sched 45.000000
10 16248.568359 S 24951 Fi
10 16248.570312 S 24951 B
10 16248.571289 S 24951 chol_model_22
10 16249.822266 MS MEMNODE1 No
19 16249.822266 L p 1928086912 MEMNODE1 com_1928086720
10 16249.829102 MS MEMNODE1 Co
18 16249.829102 L p 4000000 MEMNODE0 com_143
10 16249.848633 MS MEMNODE1 CoA
10 16251.037109 MS MEMNODE1 No
19 16251.037109 L p 1928086912 MEMNODE1 com_1928086720
10 16251.041992 MS MEMNODE1 A
10 16251.590820 MS MEMNODE1 No
10 16251.594727 MS MEMNODE1 Co
18 16251.594727 L p 4000000 MEMNODE0 com_144
10 16251.609375 MS MEMNODE1 CoA
10 16252.837891 MS MEMNODE1 No
19 16252.837891 L p 1928086912 MEMNODE1 com_1928086720
10 16252.842773 MS MEMNODE1 Co
18 16252.842773 L p 4000000 MEMNODE0 com_145
10 16252.858398 MS MEMNODE1 CoA
10 16254.098633 MS MEMNODE1 No
19 16254.098633 L p 1928086912 MEMNODE1 com_1928086720
10 16254.105469 MS MEMNODE1 A
10 16254.594727 MS MEMNODE1 No
10 16254.597656 MS MEMNODE1 Co
18 16254.597656 L p 4000000 MEMNODE0 com_146
10 16254.608398 MS MEMNODE1 CoA
10 16255.764648 MS MEMNODE1 No
19 16255.764648 L p 1928086912 MEMNODE1 com_1928086720
10 16255.769531 MS MEMNODE1 A
10 16256.074219 MS MEMNODE1 No
10 16256.076172 MS MEMNODE1 Co
18 16256.076172 L p 4000000 MEMNODE0 com_147
10 16256.086914 MS MEMNODE1 CoA
10 16257.250977 MS MEMNODE1 No
19 16257.250977 L p 1928086912 MEMNODE1 com_1928086720
13 16257.258789 ntask sched 44.000000
10 16257.261719 S 24947 Fi
10 16257.264648 S 24947 B
10 16257.265625 S 24947 chol_model_21
10 16265.620117 S 64 B
10 16265.622070 S 24947 Po
10 16265.626953 S 24947 B
13 16265.657227 ntask sched 45.000000
13 16265.668945 ntask sched 46.000000
13 16265.682617 ntask sched 47.000000
13 16265.694336 ntask sched 48.000000
13 16265.706055 ntask sched 49.000000
13 16265.718750 ntask sched 50.000000
13 16265.730469 ntask sched 51.000000
13 16265.741211 ntask sched 52.000000
13 16265.751953 ntask sched 53.000000
13 16265.764648 ntask sched 54.000000
10 16265.803711 MS MEMNODE1 No
19 16265.803711 L p 4000000 MEMNODE1 com_147
10 16265.806641 MS MEMNODE1 No
19 16265.806641 L p 4000000 MEMNODE1 com_146
10 16265.808594 MS MEMNODE1 No
19 16265.808594 L p 4000000 MEMNODE1 com_145
10 16265.810547 MS MEMNODE1 No
19 16265.810547 L p 4000000 MEMNODE1 com_144
10 16265.814453 MS MEMNODE1 No
19 16265.814453 L p 4000000 MEMNODE1 com_143
10 16265.816406 MS MEMNODE1 No
19 16265.816406 L p 4000000 MEMNODE1 com_142
10 16265.819336 MS MEMNODE1 No
19 16265.819336 L p 4000000 MEMNODE1 com_140
10 16265.821289 MS MEMNODE1 No
19 16265.821289 L p 4000000 MEMNODE1 com_138
10 16265.824219 MS MEMNODE1 No
19 16265.824219 L p 4000000 MEMNODE1 com_136
10 16265.826172 MS MEMNODE1 Co
18 16265.826172 L p 4000000 MEMNODE0 com_148
10 16265.832031 MS MEMNODE1 CoA
10 16267.136719 MS MEMNODE1 No
19 16267.136719 L p 1928086912 MEMNODE1 com_1928086720
10 16267.142578 MS MEMNODE1 A
10 16267.822266 MS MEMNODE1 No
10 16267.825195 MS MEMNODE1 Co
18 16267.825195 L p 4000000 MEMNODE0 com_149
10 16267.832031 MS MEMNODE1 CoA
10 16269.126953 MS MEMNODE1 No
19 16269.126953 L p 1928086912 MEMNODE1 com_1928086720
10 16269.133789 MS MEMNODE1 A
10 16269.461914 MS MEMNODE1 No
10 16269.464844 MS MEMNODE1 Co
18 16269.464844 L p 4000000 MEMNODE0 com_150
10 16269.469727 MS MEMNODE1 CoA
10 16270.761719 MS MEMNODE1 No
19 16270.761719 L p 1928086912 MEMNODE1 com_1928086720
13 16270.769531 ntask sched 53.000000
10 16270.773438 S 24947 Fi
10 16270.776367 S 24947 B
10 16270.777344 S 24947 chol_model_21
10 16279.132812 S 64 B
10 16279.134766 S 24947 Po
10 16279.136719 S 24947 B
13 16279.163086 ntask sched 54.000000
13 16279.174805 ntask sched 55.000000
13 16279.186523 ntask sched 56.000000
13 16279.198242 ntask sched 57.000000
13 16279.208984 ntask sched 58.000000
13 16279.220703 ntask sched 59.000000
13 16279.232422 ntask sched 60.000000
13 16279.244141 ntask sched 61.000000
13 16279.254883 ntask sched 62.000000
13 16279.265625 ntask sched 63.000000
13 16279.278320 ntask sched 64.000000
10 16279.313477 MS MEMNODE1 No
19 16279.313477 L p 4000000 MEMNODE1 com_150
10 16279.316406 MS MEMNODE1 No
19 16279.316406 L p 4000000 MEMNODE1 com_149
10 16279.319336 MS MEMNODE1 No
19 16279.319336 L p 4000000 MEMNODE1 com_148
10 16279.321289 MS MEMNODE1 A
10 16279.874023 MS MEMNODE1 No
10 16279.876953 MS MEMNODE1 Co
18 16279.876953 L p 4000000 MEMNODE0 com_151
10 16279.883789 MS MEMNODE1 CoA
10 16281.022461 MS MEMNODE1 No
19 16281.022461 L p 1928086912 MEMNODE1 com_1928086720
13 16281.029297 ntask sched 63.000000
10 16281.031250 S 24947 Fi
10 16281.033203 S 24947 B
10 16281.034180 S 24947 chol_model_21
10 16289.372070 S 64 B
10 16289.374023 S 24947 Po
10 16289.375977 S 24947 B
13 16289.397461 ntask sched 64.000000
13 16289.409180 ntask sched 65.000000
13 16289.419922 ntask sched 66.000000
13 16289.430664 ntask sched 67.000000
13 16289.442383 ntask sched 68.000000
13 16289.454102 ntask sched 69.000000
13 16289.464844 ntask sched 70.000000
13 16289.475586 ntask sched 71.000000
13 16289.487305 ntask sched 72.000000
13 16289.498047 ntask sched 73.000000
13 16289.508789 ntask sched 74.000000
13 16289.519531 ntask sched 75.000000
10 16289.552734 MS MEMNODE1 No
19 16289.552734 L p 4000000 MEMNODE1 com_151
10 16289.554688 MS MEMNODE1 A
10 16290.007812 MS MEMNODE1 No
10 16290.009766 MS MEMNODE1 Co
18 16290.009766 L p 4000000 MEMNODE0 com_152
10 16290.015625 MS MEMNODE1 CoA
10 16291.207031 MS MEMNODE1 No
19 16291.207031 L p 1928086912 MEMNODE1 com_1928086720
10 16291.212891 MS MEMNODE1 A
10 16291.618164 MS MEMNODE1 No
10 16291.621094 MS MEMNODE1 Co
18 16291.621094 L p 4000000 MEMNODE0 com_153
10 16291.626953 MS MEMNODE1 CoA
10 16292.795898 MS MEMNODE1 No
19 16292.795898 L p 1928086912 MEMNODE1 com_1928086720
10 16292.800781 MS MEMNODE1 A
10 16293.106445 MS MEMNODE1 No
10 16293.108398 MS MEMNODE1 Co
18 16293.108398 L p 4000000 MEMNODE0 com_154
10 16293.114258 MS MEMNODE1 CoA
10 16294.272461 MS MEMNODE1 No
19 16294.272461 L p 1928086912 MEMNODE1 com_1928086720
13 16294.280273 ntask sched 74.000000
10 16294.283203 S 24947 Fi
10 16294.285156 S 24947 B
10 16294.286133 S 24947 chol_model_21
10 16302.650391 S 64 B
10 16302.652344 S 24947 Po
10 16302.655273 S 24947 B
13 16302.680664 ntask sched 75.000000
13 16302.693359 ntask sched 76.000000
13 16302.704102 ntask sched 77.000000
13 16302.714844 ntask sched 78.000000
13 16302.725586 ntask sched 79.000000
13 16302.737305 ntask sched 80.000000
13 16302.748047 ntask sched 81.000000
13 16302.757812 ntask sched 82.000000
13 16302.769531 ntask sched 83.000000
13 16302.781250 ntask sched 84.000000
13 16302.791992 ntask sched 85.000000
13 16302.801758 ntask sched 86.000000
13 16302.813477 ntask sched 87.000000
10 16302.847656 MS MEMNODE1 No
19 16302.847656 L p 4000000 MEMNODE1 com_154
10 16302.850586 MS MEMNODE1 No
19 16302.850586 L p 4000000 MEMNODE1 com_153
10 16302.853516 MS MEMNODE1 No
19 16302.853516 L p 4000000 MEMNODE1 com_152
10 16302.856445 MS MEMNODE1 A
10 16303.353516 MS MEMNODE1 No
10 16303.356445 MS MEMNODE1 Co
18 16303.356445 L p 4000000 MEMNODE0 com_155
10 16303.363281 MS MEMNODE1 CoA
10 16304.508789 MS MEMNODE1 No
19 16304.508789 L p 1928086912 MEMNODE1 com_1928086720
10 16304.513672 MS MEMNODE1 A
10 16304.799805 MS MEMNODE1 No
10 16304.801758 MS MEMNODE1 Co
18 16304.801758 L p 4000000 MEMNODE0 com_156
10 16304.807617 MS MEMNODE1 CoA
10 16305.985352 MS MEMNODE1 No
19 16305.985352 L p 1928086912 MEMNODE1 com_1928086720
10 16305.991211 MS MEMNODE1 A
10 16315.197266 MS MEMNODE1 No
10 16315.201172 MS MEMNODE1 Co
18 16315.201172 L p 4000000 MEMNODE0 com_157
10 16315.210938 MS MEMNODE1 CoA
10 16316.464844 MS MEMNODE1 No
19 16316.464844 L p 1928086912 MEMNODE1 com_1928086720
10 16316.471680 MS MEMNODE1 A
10 16316.827148 MS MEMNODE1 No
10 16316.829102 MS MEMNODE1 Co
18 16316.829102 L p 4000000 MEMNODE0 com_158
10 16316.840820 MS MEMNODE1 CoA
10 16318.021484 MS MEMNODE1 No
19 16318.021484 L p 1928086912 MEMNODE1 com_1928086720
13 16318.030273 ntask sched 86.000000
10 16318.032227 S 24947 Fi
10 16318.035156 S 24947 B
10 16318.036133 S 24947 chol_model_21
10 16326.376953 S 64 B
10 16326.378906 S 24947 Po
10 16326.380859 S 24947 B
13 16326.408203 ntask sched 87.000000
13 16326.420898 ntask sched 88.000000
13 16326.433594 ntask sched 89.000000
13 16326.447266 ntask sched 90.000000
13 16326.459961 ntask sched 91.000000
13 16326.472656 ntask sched 92.000000
13 16326.487305 ntask sched 93.000000
13 16326.500977 ntask sched 94.000000
13 16326.513672 ntask sched 95.000000
13 16326.526367 ntask sched 96.000000
13 16326.539062 ntask sched 97.000000
13 16326.551758 ntask sched 98.000000
13 16326.565430 ntask sched 99.000000
13 16326.587891 ntask sched 100.000000
10 16326.625000 MS MEMNODE1 No
19 16326.625000 L p 4000000 MEMNODE1 com_158
10 16326.627930 MS MEMNODE1 No
19 16326.627930 L p 4000000 MEMNODE1 com_157
10 16326.629883 MS MEMNODE1 No
19 16326.629883 L p 4000000 MEMNODE1 com_156
10 16326.632812 MS MEMNODE1 No
19 16326.632812 L p 4000000 MEMNODE1 com_155
13 16326.634766 ntask sched 99.000000
10 16326.635742 S 24947 Fi
10 16326.636719 S 24947 B
10 16326.637695 S 24947 chol_model_22
10 16326.672852 S 0 B
10 16326.675781 S 24948 Po
10 16326.679688 S 24948 B
10 16326.764648 MS MEMNODE0 No
19 16326.764648 L p 4000000 MEMNODE0 com_141
10 16326.791992 MS MEMNODE0 No
19 16326.791992 L p 4000000 MEMNODE0 com_139
10 16326.793945 MS MEMNODE0 Co
18 16326.793945 L p 4000000 MEMNODE1 com_159
10 16326.806641 MS MEMNODE0 CoA
10 16326.919922 S 0 B
10 16326.921875 S 24950 Po
10 16326.923828 S 24950 B
13 16326.932617 ntask sched 98.000000
10 16326.934570 S 24950 Fi
10 16326.936523 S 24950 B
10 16326.938477 S 24950 chol_model_22
10 16329.925781 S 64 B
10 16329.926758 S 24947 Po
10 16329.928711 S 24947 B
13 16329.947266 ntask sched 99.000000
13 16329.952148 ntask sched 98.000000
10 16329.953125 S 24947 Fi
10 16329.955078 S 24947 B
10 16329.955078 S 24947 chol_model_22
10 16331.901367 MS MEMNODE0 No
19 16331.901367 L p 1928086912 MEMNODE0 com_1928086720
10 16331.936523 MS MEMNODE0 Co
18 16331.936523 L p 4000000 MEMNODE1 com_160
10 16331.947266 MS MEMNODE0 CoA
10 16333.137695 S 0 B
10 16333.139648 S 24949 Po
10 16333.142578 S 24949 B
10 16333.169922 MS MEMNODE0 Co
18 16333.169922 L p 4000000 MEMNODE1 com_161
10 16334.906250 S 0 B
10 16334.907227 S 24952 Po
10 16334.909180 S 24952 B
13 16334.922852 ntask sched 97.000000
10 16334.923828 S 24952 Fi
10 16335.185547 S 64 B
10 16335.186523 S 24947 Po
10 16335.189453 S 24947 B
13 16335.196289 ntask sched 96.000000
10 16335.197266 S 24947 Fi
10 16335.198242 S 24947 B
10 16335.199219 S 24947 chol_model_22
10 16336.545898 MS MEMNODE0 No
19 16336.545898 L p 1928086912 MEMNODE0 com_1928086720
10 16336.551758 MS MEMNODE0 CoA
10 16336.590820 MS MEMNODE0 No
19 16336.590820 L p 4000000 MEMNODE0 com_159
10 16336.592773 S 24952 B
10 16336.593750 S 24952 chol_model_22
10 16340.303711 S 0 B
10 16340.304688 S 24951 Po
10 16340.306641 S 24951 B
13 16340.318359 ntask sched 95.000000
10 16340.319336 S 24951 Fi
10 16341.211914 MS MEMNODE0 No
19 16341.211914 L p 1928086912 MEMNODE0 com_1928086720
10 16341.218750 MS MEMNODE0 Co
18 16341.218750 L p 4000000 MEMNODE1 com_162
10 16341.228516 MS MEMNODE0 CoA
10 16341.290039 S 64 B
10 16341.291016 S 24947 Po
10 16341.292969 S 24947 B
13 16341.297852 ntask sched 94.000000
13 16341.298828 ntask sched 93.000000
10 16341.300781 S 24949 Fi
10 16341.300781 S 24947 Fi
10 16341.302734 S 24947 B
10 16341.302734 S 24947 chol_model_22
10 16341.304688 S 24949 B
10 16341.306641 S 24949 chol_model_22
10 16343.338867 MS MEMNODE0 No
19 16343.338867 L p 1928086912 MEMNODE0 com_1928086720
10 16343.343750 MS MEMNODE0 No
19 16343.343750 L p 4000000 MEMNODE0 com_160
10 16343.349609 MS MEMNODE0 No
19 16343.349609 L p 4000000 MEMNODE0 com_161
10 16343.382812 MS MEMNODE0 Co
18 16343.382812 L p 4000000 MEMNODE1 com_163
10 16343.392578 MS MEMNODE0 CoA
10 16346.639648 S 64 B
10 16346.640625 S 24947 Po
10 16346.648438 S 24947 B
13 16346.655273 ntask sched 92.000000
10 16346.657227 S 24947 Fi
10 16346.658203 S 24947 B
10 16346.659180 S 24947 chol_model_22
10 16348.748047 MS MEMNODE0 No
19 16348.748047 L p 1928086912 MEMNODE0 com_1928086720
10 16348.759766 MS MEMNODE0 Co
18 16348.759766 L p 4000000 MEMNODE1 com_164
10 16348.763672 MS MEMNODE0 No
19 16348.763672 L p 4000000 MEMNODE0 com_162
10 16348.765625 S 24951 B
10 16348.766602 S 24951 chol_model_22
10 16348.791992 MS MEMNODE0 CoA
10 16352.053711 S 64 B
10 16352.054688 S 24947 Po
10 16352.056641 S 24947 B
13 16352.065430 ntask sched 91.000000
10 16352.066406 S 24947 Fi
10 16352.068359 S 24947 B
10 16352.068359 S 24947 chol_model_22
10 16354.018555 MS MEMNODE0 No
19 16354.018555 L p 1928086912 MEMNODE0 com_1928086720
10 16354.037109 MS MEMNODE0 Co
18 16354.037109 L p 4000000 MEMNODE1 com_165
10 16354.065430 MS MEMNODE0 CoA
10 16357.316406 S 64 B
10 16357.316406 S 24947 Po
10 16357.318359 S 24947 B
13 16357.325195 ntask sched 90.000000
10 16357.327148 S 24947 Fi
10 16357.328125 S 24947 B
10 16357.329102 S 24947 chol_model_22
10 16359.277344 MS MEMNODE0 No
19 16359.277344 L p 1928086912 MEMNODE0 com_1928086720
10 16359.296875 MS MEMNODE0 Co
18 16359.296875 L p 4000000 MEMNODE1 com_166
10 16359.326172 MS MEMNODE0 CoA
10 16362.582031 S 64 B
10 16362.583008 S 24947 Po
10 16362.584961 S 24947 B
13 16362.593750 ntask sched 89.000000
10 16362.595703 S 24947 Fi
10 16362.597656 S 24947 B
10 16362.597656 S 24947 chol_model_22
10 16364.541992 MS MEMNODE0 No
19 16364.541992 L p 1928086912 MEMNODE0 com_1928086720
10 16376.419922 MS MEMNODE0 Co
18 16376.419922 L p 4000000 MEMNODE1 com_167
10 16376.440430 MS MEMNODE0 CoA
10 16388.263672 S 64 B
10 16388.265625 S 24947 Po
10 16388.269531 S 24947 B
13 16388.285156 ntask sched 88.000000
10 16388.287109 S 24947 Fi
10 16388.291016 S 24947 B
10 16388.292969 S 24947 chol_model_22
10 16390.320312 MS MEMNODE0 No
19 16390.320312 L p 1928086912 MEMNODE0 com_1928086720
10 16390.343750 MS MEMNODE0 Co
18 16390.343750 L p 4000000 MEMNODE1 com_168
10 16390.380859 MS MEMNODE0 CoA
10 16393.630859 S 64 B
10 16393.630859 S 24947 Po
10 16393.632812 S 24947 B
13 16393.644531 ntask sched 87.000000
10 16393.646484 S 24947 Fi
10 16393.648438 S 24947 B
10 16393.648438 S 24947 chol_model_22
10 16395.597656 MS MEMNODE0 No
19 16395.597656 L p 1928086912 MEMNODE0 com_1928086720
10 16395.613281 MS MEMNODE0 Co
18 16395.613281 L p 4000000 MEMNODE1 com_169
10 16395.646484 MS MEMNODE0 CoA
10 16398.904297 S 64 B
10 16398.904297 S 24947 Po
10 16398.906250 S 24947 B
13 16398.914062 ntask sched 86.000000
10 16398.914062 S 24947 Fi
10 16398.917969 S 24947 B
10 16398.917969 S 24947 chol_model_22
10 16400.876953 MS MEMNODE0 No
19 16400.876953 L p 1928086912 MEMNODE0 com_1928086720
10 16400.892578 MS MEMNODE0 Co
18 16400.892578 L p 4000000 MEMNODE1 com_170
10 16400.919922 MS MEMNODE0 CoA
10 16404.169922 S 64 B
10 16404.169922 S 24947 Po
10 16404.171875 S 24947 B
13 16404.179688 ntask sched 85.000000
10 16404.179688 S 24947 Fi
10 16404.181641 S 24947 B
10 16404.181641 S 24947 chol_model_22
10 16406.138672 MS MEMNODE0 No
19 16406.138672 L p 1928086912 MEMNODE0 com_1928086720
10 16406.158203 MS MEMNODE0 Co
18 16406.158203 L p 4000000 MEMNODE1 com_171
10 16406.183594 MS MEMNODE0 CoA
10 16409.447266 S 64 B
10 16409.449219 S 24947 Po
10 16409.451172 S 24947 B
13 16409.464844 ntask sched 84.000000
10 16409.466797 S 24947 Fi
10 16409.468750 S 24947 B
10 16409.468750 S 24947 chol_model_22
10 16411.427734 MS MEMNODE0 No
19 16411.427734 L p 1928086912 MEMNODE0 com_1928086720
10 16411.445312 MS MEMNODE0 Co
18 16411.445312 L p 4000000 MEMNODE1 com_172
10 16411.478516 MS MEMNODE0 CoA
10 16414.734375 S 64 B
10 16414.734375 S 24947 Po
10 16414.736328 S 24947 B
13 16414.744141 ntask sched 83.000000
10 16414.744141 S 24947 Fi
10 16414.746094 S 24947 B
10 16414.748047 S 24947 chol_model_22
10 16416.742188 MS MEMNODE0 No
19 16416.742188 L p 1928086912 MEMNODE0 com_1928086720
10 16416.761719 MS MEMNODE0 Co
18 16416.761719 L p 4000000 MEMNODE1 com_173
10 16416.787109 MS MEMNODE0 CoA
10 16417.623047 S 0 B
10 16417.625000 S 24950 Po
10 16417.628906 S 24950 B
10 16420.052734 S 64 B
10 16420.052734 S 24947 Po
10 16420.054688 S 24947 B
13 16420.062500 ntask sched 82.000000
10 16420.064453 S 24947 Fi
10 16420.064453 S 24947 B
10 16420.066406 S 24947 chol_model_22
10 16422.121094 MS MEMNODE0 No
19 16422.121094 L p 1928086912 MEMNODE0 com_1928086720
10 16422.128906 MS MEMNODE0 No
19 16422.128906 L p 4000000 MEMNODE0 com_172
10 16422.146484 MS MEMNODE0 Co
18 16422.146484 L p 4000000 MEMNODE1 com_174
10 16422.175781 MS MEMNODE0 CoA
10 16422.179688 MS MEMNODE0 No
19 16422.179688 L p 4000000 MEMNODE0 com_171
10 16425.429688 S 64 B
10 16425.429688 S 24947 Po
10 16425.431641 S 24947 B
13 16425.437500 ntask sched 81.000000
10 16425.439453 S 24947 Fi
10 16425.441406 S 24947 B
10 16425.443359 S 24947 chol_model_22
10 16427.134766 S 0 B
10 16427.136719 S 24952 Po
10 16427.138672 S 24952 B
10 16427.367188 MS MEMNODE0 No
19 16427.367188 L p 1928086912 MEMNODE0 com_1928086720
10 16427.373047 MS MEMNODE0 No
19 16427.373047 L p 4000000 MEMNODE0 com_170
10 16427.402344 MS MEMNODE0 No
19 16427.402344 L p 4000000 MEMNODE0 com_173
13 16427.406250 ntask sched 80.000000
10 16427.408203 S 24952 Fi
10 16427.408203 S 24952 B
10 16427.410156 S 24952 chol_model_22
10 16427.417969 MS MEMNODE0 No
19 16427.417969 L p 4000000 MEMNODE0 com_169
10 16427.460938 MS MEMNODE0 Co
18 16427.460938 L p 4000000 MEMNODE1 com_175
10 16427.464844 MS MEMNODE0 No
19 16427.464844 L p 4000000 MEMNODE0 com_168
10 16427.468750 MS MEMNODE0 CoA
10 16430.671875 S 64 B
10 16430.673828 S 24947 Po
10 16430.675781 S 24947 B
13 16430.685547 ntask sched 79.000000
10 16430.687500 S 24947 Fi
10 16430.689453 S 24947 B
10 16430.689453 S 24947 chol_model_22
10 16432.205078 S 0 B
10 16432.207031 S 24949 Po
10 16432.210938 S 24949 B
10 16432.599609 MS MEMNODE0 No
19 16432.599609 L p 1928086912 MEMNODE0 com_1928086720
10 16432.603516 MS MEMNODE0 No
19 16432.603516 L p 4000000 MEMNODE0 com_167
10 16432.621094 MS MEMNODE0 No
19 16432.621094 L p 4000000 MEMNODE0 com_174
13 16432.625000 ntask sched 78.000000
10 16432.626953 S 24949 Fi
10 16432.652344 MS MEMNODE0 No
19 16432.652344 L p 4000000 MEMNODE0 com_166
13 16432.685547 ntask sched 77.000000
10 16432.687500 S 24948 Fi
10 16432.689453 S 24948 B
10 16432.691406 S 24948 chol_model_22
10 16432.695312 MS MEMNODE0 No
19 16432.695312 L p 4000000 MEMNODE0 com_165
10 16432.724609 MS MEMNODE0 No
19 16432.724609 L p 4000000 MEMNODE0 com_164
10 16432.750000 MS MEMNODE0 No
19 16432.750000 L p 4000000 MEMNODE0 com_163
10 16432.751953 S 24949 B
10 16432.751953 S 24949 chol_model_22
13 16432.753906 ntask sched 76.000000
10 16432.753906 S 24950 Fi
10 16432.755859 S 24950 B
10 16432.757812 S 24950 chol_model_22
10 16435.898438 S 64 B
10 16435.900391 S 24947 Po
10 16435.902344 S 24947 B
13 16435.908203 ntask sched 75.000000
10 16435.910156 S 24947 Fi
10 16435.912109 S 24947 B
10 16435.912109 S 24947 chol_model_22
10 16439.191406 S 64 B
10 16439.191406 S 24947 Po
10 16439.193359 S 24947 B
13 16439.199219 ntask sched 74.000000
10 16439.201172 S 24947 Fi
10 16439.203125 S 24947 B
10 16439.203125 S 24947 chol_model_22
10 16442.486328 S 64 B
10 16442.486328 S 24947 Po
10 16442.488281 S 24947 B
13 16442.494141 ntask sched 73.000000
10 16442.496094 S 24947 Fi
10 16442.498047 S 24947 B
10 16442.498047 S 24947 chol_model_22
10 16445.773438 S 64 B
10 16445.773438 S 24947 Po
10 16445.775391 S 24947 B
13 16445.781250 ntask sched 72.000000
10 16445.783203 S 24947 Fi
10 16445.785156 S 24947 B
10 16445.785156 S 24947 chol_model_22
10 16449.064453 S 64 B
10 16449.064453 S 24947 Po
10 16449.066406 S 24947 B
13 16449.072266 ntask sched 71.000000
10 16449.074219 S 24947 Fi
10 16449.074219 S 24947 B
10 16449.076172 S 24947 chol_model_22
10 16451.248047 S 0 B
10 16451.250000 S 24951 Po
10 16451.251953 S 24951 B
10 16451.306641 MS MEMNODE0 No
19 16451.306641 L p 4000000 MEMNODE0 com_175
13 16451.310547 ntask sched 70.000000
10 16451.310547 S 24951 Fi
10 16451.312500 S 24951 B
10 16451.314453 S 24951 chol_model_22
10 16452.351562 S 64 B
10 16452.353516 S 24947 Po
10 16452.355469 S 24947 B
13 16452.361328 ntask sched 69.000000
10 16452.363281 S 24947 Fi
10 16452.363281 S 24947 B
10 16452.365234 S 24947 chol_model_22
10 16455.656250 S 64 B
10 16455.658203 S 24947 Po
10 16455.658203 S 24947 B
13 16455.666016 ntask sched 68.000000
10 16455.667969 S 24947 Fi
10 16455.669922 S 24947 B
10 16455.669922 S 24947 chol_model_22
10 16458.945312 S 64 B
10 16458.947266 S 24947 Po
10 16458.949219 S 24947 B
13 16458.955078 ntask sched 67.000000
10 16458.955078 S 24947 Fi
10 16458.957031 S 24947 B
10 16458.957031 S 24947 chol_model_22
10 16462.236328 S 64 B
10 16462.236328 S 24947 Po
10 16462.238281 S 24947 B
13 16462.244141 ntask sched 66.000000
10 16462.244141 S 24947 Fi
10 16462.246094 S 24947 B
10 16462.248047 S 24947 chol_model_22
10 16465.521484 S 64 B
10 16465.521484 S 24947 Po
10 16465.523438 S 24947 B
13 16465.529297 ntask sched 65.000000
10 16465.531250 S 24947 Fi
10 16465.533203 S 24947 B
10 16465.533203 S 24947 chol_model_22
10 16468.814453 S 64 B
10 16468.814453 S 24947 Po
10 16468.816406 S 24947 B
13 16468.822266 ntask sched 64.000000
10 16468.824219 S 24947 Fi
10 16468.826172 S 24947 B
10 16468.826172 S 24947 chol_model_22
10 16472.097656 S 64 B
10 16472.097656 S 24947 Po
10 16472.099609 S 24947 B
13 16472.105469 ntask sched 63.000000
10 16472.107422 S 24947 Fi
10 16472.109375 S 24947 B
10 16472.109375 S 24947 chol_model_22
10 16475.390625 S 64 B
10 16475.392578 S 24947 Po
10 16475.394531 S 24947 B
13 16475.402344 ntask sched 62.000000
10 16475.404297 S 24947 Fi
10 16475.406250 S 24947 B
10 16475.406250 S 24947 chol_model_22
10 16478.691406 S 64 B
10 16478.691406 S 24947 Po
10 16478.693359 S 24947 B
13 16478.699219 ntask sched 61.000000
10 16478.701172 S 24947 Fi
10 16478.703125 S 24947 B
10 16478.703125 S 24947 chol_model_22
10 16481.984375 S 64 B
10 16481.984375 S 24947 Po
10 16481.986328 S 24947 B
13 16481.992188 ntask sched 60.000000
10 16481.994141 S 24947 Fi
10 16481.994141 S 24947 B
10 16481.996094 S 24947 chol_model_22
10 16485.271484 S 64 B
10 16485.271484 S 24947 Po
10 16485.273438 S 24947 B
13 16485.279297 ntask sched 59.000000
10 16485.281250 S 24947 Fi
10 16485.281250 S 24947 B
10 16485.283203 S 24947 chol_model_22
10 16488.556641 S 64 B
10 16488.558594 S 24947 Po
10 16488.558594 S 24947 B
13 16488.566406 ntask sched 58.000000
10 16488.566406 S 24947 Fi
10 16488.568359 S 24947 B
10 16488.568359 S 24947 chol_model_22
10 16491.857422 S 64 B
10 16491.857422 S 24947 Po
10 16491.859375 S 24947 B
13 16491.865234 ntask sched 57.000000
10 16491.867188 S 24947 Fi
10 16491.869141 S 24947 B
10 16491.869141 S 24947 chol_model_22
10 16495.146484 S 64 B
10 16495.146484 S 24947 Po
10 16495.148438 S 24947 B
13 16495.154297 ntask sched 56.000000
10 16495.156250 S 24947 Fi
10 16495.156250 S 24947 B
10 16495.158203 S 24947 chol_model_22
10 16498.435547 S 64 B
10 16498.437500 S 24947 Po
10 16498.439453 S 24947 B
13 16498.447266 ntask sched 55.000000
10 16498.449219 S 24947 Fi
10 16498.451172 S 24947 B
10 16498.451172 S 24947 chol_model_22
10 16501.736328 S 64 B
10 16501.738281 S 24947 Po
10 16501.740234 S 24947 B
13 16501.746094 ntask sched 54.000000
10 16501.746094 S 24947 Fi
10 16501.748047 S 24947 B
10 16501.748047 S 24947 chol_model_22
10 16505.021484 S 64 B
10 16505.023438 S 24947 Po
10 16505.023438 S 24947 B
13 16505.031250 ntask sched 53.000000
10 16505.031250 S 24947 Fi
10 16505.033203 S 24947 B
10 16505.033203 S 24947 chol_model_22
10 16508.310547 S 64 B
10 16508.310547 S 24947 Po
10 16508.312500 S 24947 B
13 16508.318359 ntask sched 52.000000
10 16508.320312 S 24947 Fi
10 16508.322266 S 24947 B
10 16508.322266 S 24947 chol_model_22
10 16511.595703 S 64 B
10 16511.597656 S 24947 Po
10 16511.599609 S 24947 B
13 16511.605469 ntask sched 51.000000
10 16511.605469 S 24947 Fi
10 16511.607422 S 24947 B
10 16511.607422 S 24947 chol_model_22
10 16514.884766 S 64 B
10 16514.884766 S 24947 Po
10 16514.886719 S 24947 B
13 16514.892578 ntask sched 50.000000
10 16514.894531 S 24947 Fi
10 16514.896484 S 24947 B
10 16514.896484 S 24947 chol_model_22
10 16517.691406 S 0 B
10 16517.691406 S 24952 Po
10 16517.695312 S 24952 B
13 16517.703125 ntask sched 49.000000
10 16517.705078 S 24952 Fi
10 16517.707031 S 24952 B
10 16517.707031 S 24952 chol_model_22
10 16518.171875 S 64 B
10 16518.171875 S 24947 Po
10 16518.173828 S 24947 B
13 16518.179688 ntask sched 48.000000
10 16518.181641 S 24947 Fi
10 16518.183594 S 24947 B
10 16518.183594 S 24947 chol_model_22
10 16521.466797 S 64 B
10 16521.466797 S 24947 Po
10 16521.468750 S 24947 B
13 16521.474609 ntask sched 47.000000
10 16521.476562 S 24947 Fi
10 16521.478516 S 24947 B
10 16521.478516 S 24947 chol_model_22
10 16524.412109 S 0 B
10 16524.414062 S 24949 Po
10 16524.419922 S 24949 B
13 16524.437500 ntask sched 46.000000
10 16524.439453 S 24949 Fi
10 16524.447266 S 24949 B
10 16524.449219 S 24949 chol_model_22
10 16524.761719 S 64 B
10 16524.763672 S 24947 Po
10 16524.765625 S 24947 B
13 16524.771484 ntask sched 45.000000
10 16524.773438 S 24947 Fi
10 16524.773438 S 24947 B
10 16524.775391 S 24947 chol_model_22
10 16524.789062 S 0 B
10 16524.792969 S 0 B
10 16524.791016 S 24950 Po
10 16524.792969 S 24948 Po
10 16524.794922 S 24950 B
10 16524.796875 S 24948 B
13 16524.802734 ntask sched 44.000000
10 16524.804688 S 24950 Fi
13 16524.806641 ntask sched 43.000000
10 16524.806641 S 24950 B
10 16524.806641 S 24950 chol_model_22
10 16524.806641 S 24948 Fi
10 16524.808594 S 24948 B
10 16524.810547 S 24948 chol_model_22
10 16528.054688 S 64 B
10 16528.056641 S 24947 Po
10 16528.058594 S 24947 B
13 16528.064453 ntask sched 42.000000
10 16528.066406 S 24947 Fi
10 16528.066406 S 24947 B
10 16528.068359 S 24947 chol_model_22
10 16531.343750 S 64 B
10 16531.343750 S 24947 Po
10 16531.345703 S 24947 B
13 16531.351562 ntask sched 41.000000
10 16531.353516 S 24947 Fi
10 16531.355469 S 24947 B
10 16531.355469 S 24947 chol_model_22
10 16534.632812 S 64 B
10 16534.632812 S 24947 Po
10 16534.634766 S 24947 B
13 16534.646484 ntask sched 40.000000
10 16534.648438 S 24947 Fi
10 16534.648438 S 24947 B
10 16534.650391 S 24947 chol_model_22
10 16537.927734 S 64 B
10 16537.927734 S 24947 Po
10 16537.929688 S 24947 B
13 16537.935547 ntask sched 39.000000
10 16537.935547 S 24947 Fi
10 16537.937500 S 24947 B
10 16537.937500 S 24947 chol_model_22
10 16541.216797 S 64 B
10 16541.218750 S 24947 Po
10 16541.218750 S 24947 B
13 16541.226562 ntask sched 38.000000
10 16541.228516 S 24947 Fi
10 16541.228516 S 24947 B
10 16541.230469 S 24947 chol_model_22
10 16541.880859 S 0 B
10 16541.882812 S 24951 Po
10 16541.884766 S 24951 B
13 16541.892578 ntask sched 37.000000
10 16541.892578 S 24951 Fi
10 16541.894531 S 24951 B
10 16541.896484 S 24951 chol_model_22
10 16544.509766 S 64 B
10 16544.509766 S 24947 Po
10 16544.511719 S 24947 B
13 16544.517578 ntask sched 36.000000
10 16544.519531 S 24947 Fi
10 16544.521484 S 24947 B
10 16544.521484 S 24947 chol_model_22
10 16547.806641 S 64 B
10 16547.808594 S 24947 Po
10 16547.810547 S 24947 B
13 16547.816406 ntask sched 35.000000
10 16547.816406 S 24947 Fi
10 16547.818359 S 24947 B
10 16547.818359 S 24947 chol_model_22
10 16551.095703 S 64 B
10 16551.095703 S 24947 Po
10 16551.097656 S 24947 B
13 16551.103516 ntask sched 34.000000
10 16551.105469 S 24947 Fi
10 16551.105469 S 24947 B
10 16551.107422 S 24947 chol_model_22
10 16554.378906 S 64 B
10 16554.378906 S 24947 Po
10 16554.380859 S 24947 B
13 16554.386719 ntask sched 33.000000
10 16554.388672 S 24947 Fi
10 16554.390625 S 24947 B
10 16554.390625 S 24947 chol_model_22
10 16557.662109 S 64 B
10 16557.664062 S 24947 Po
10 16557.666016 S 24947 B
13 16557.671875 ntask sched 32.000000
10 16557.673828 S 24947 Fi
10 16557.675781 S 24947 B
10 16557.675781 S 24947 chol_model_22
10 16560.955078 S 64 B
10 16560.955078 S 24947 Po
10 16560.957031 S 24947 B
13 16560.964844 ntask sched 31.000000
10 16560.964844 S 24947 Fi
10 16560.966797 S 24947 B
10 16560.966797 S 24947 chol_model_22
10 16564.240234 S 64 B
10 16564.240234 S 24947 Po
10 16564.242188 S 24947 B
13 16564.250000 ntask sched 30.000000
10 16564.251953 S 24947 Fi
10 16564.253906 S 24947 B
10 16564.253906 S 24947 chol_model_22
10 16567.529297 S 64 B
10 16567.531250 S 24947 Po
10 16567.533203 S 24947 B
13 16567.539062 ntask sched 29.000000
10 16567.541016 S 24947 Fi
10 16567.542969 S 24947 B
10 16567.542969 S 24947 chol_model_22
10 16570.824219 S 64 B
10 16570.826172 S 24947 Po
10 16570.828125 S 24947 B
13 16570.833984 ntask sched 28.000000
10 16570.835938 S 24947 Fi
10 16570.835938 S 24947 B
10 16570.837891 S 24947 chol_model_22
10 16574.115234 S 64 B
10 16574.117188 S 24947 Po
10 16574.119141 S 24947 B
13 16574.125000 ntask sched 27.000000
10 16574.126953 S 24947 Fi
10 16574.128906 S 24947 B
10 16574.128906 S 24947 chol_model_22
10 16577.408203 S 64 B
10 16577.408203 S 24947 Po
10 16577.410156 S 24947 B
13 16577.416016 ntask sched 26.000000
10 16577.417969 S 24947 Fi
10 16577.419922 S 24947 B
10 16577.419922 S 24947 chol_model_22
10 16580.695312 S 64 B
10 16580.697266 S 24947 Po
10 16580.699219 S 24947 B
13 16580.705078 ntask sched 25.000000
10 16580.705078 S 24947 Fi
10 16580.707031 S 24947 B
10 16580.707031 S 24947 chol_model_22
10 16583.984375 S 64 B
10 16583.986328 S 24947 Po
10 16583.988281 S 24947 B
13 16583.994141 ntask sched 24.000000
10 16583.994141 S 24947 Fi
10 16583.996094 S 24947 B
10 16583.996094 S 24947 chol_model_22
10 16587.279297 S 64 B
10 16587.279297 S 24947 Po
10 16587.281250 S 24947 B
13 16587.287109 ntask sched 23.000000
10 16587.289062 S 24947 Fi
10 16587.291016 S 24947 B
10 16587.291016 S 24947 chol_model_22
10 16590.562500 S 64 B
10 16590.562500 S 24947 Po
10 16590.564453 S 24947 B
13 16590.572266 ntask sched 22.000000
10 16590.574219 S 24947 Fi
10 16590.576172 S 24947 B
10 16590.576172 S 24947 chol_model_22
10 16593.861328 S 64 B
10 16593.861328 S 24947 Po
10 16593.863281 S 24947 B
13 16593.869141 ntask sched 21.000000
10 16593.871094 S 24947 Fi
10 16593.873047 S 24947 B
10 16593.873047 S 24947 chol_model_22
10 16597.142578 S 64 B
10 16597.142578 S 24947 Po
10 16597.144531 S 24947 B
13 16597.150391 ntask sched 20.000000
10 16597.152344 S 24947 Fi
10 16597.152344 S 24947 B
10 16597.154297 S 24947 chol_model_22
10 16600.437500 S 64 B
10 16600.437500 S 24947 Po
10 16600.439453 S 24947 B
13 16600.447266 ntask sched 19.000000
10 16600.447266 S 24947 Fi
10 16600.449219 S 24947 B
10 16600.449219 S 24947 chol_model_22
10 16603.728516 S 64 B
10 16603.728516 S 24947 Po
10 16603.730469 S 24947 B
13 16603.736328 ntask sched 18.000000
10 16603.738281 S 24947 Fi
10 16603.740234 S 24947 B
10 16603.740234 S 24947 chol_model_22
10 16607.019531 S 64 B
10 16607.021484 S 24947 Po
10 16607.021484 S 24947 B
13 16607.027344 ntask sched 17.000000
10 16607.031250 S 24947 Fi
10 16607.031250 S 24947 B
10 16607.033203 S 24947 chol_model_22
10 16607.906250 S 0 B
10 16607.908203 S 24952 Po
10 16607.910156 S 24952 B
10 16610.312500 S 64 B
10 16610.312500 S 24947 Po
10 16610.314453 S 24947 B
13 16610.322266 ntask sched 16.000000
10 16610.322266 S 24947 Fi
10 16610.324219 S 24947 B
10 16610.324219 S 24947 chol_model_22
10 16613.599609 S 64 B
10 16613.599609 S 24947 Po
10 16613.601562 S 24947 B
13 16613.607422 ntask sched 15.000000
10 16613.609375 S 24947 Fi
10 16613.611328 S 24947 B
10 16613.611328 S 24947 chol_model_22
10 16615.638672 S 0 B
10 16615.646484 S 24949 Po
10 16615.650391 S 24949 B
10 16616.251953 S 0 B
10 16616.251953 S 24948 Po
10 16616.253906 S 24948 B
13 16616.265625 ntask sched 14.000000
10 16616.267578 S 24948 Fi
10 16616.271484 S 24948 B
10 16616.271484 S 24948 chol_model_22
10 16616.376953 S 0 B
10 16616.376953 S 24950 Po
10 16616.380859 S 24950 B
13 16616.394531 ntask sched 13.000000
10 16616.394531 S 24950 Fi
10 16616.396484 S 24950 B
10 16616.398438 S 24950 chol_model_11
10 16616.896484 S 64 B
10 16616.898438 S 24947 Po
10 16616.898438 S 24947 B
13 16616.906250 ntask sched 12.000000
10 16616.906250 S 24947 Fi
10 16616.908203 S 24947 B
10 16616.910156 S 24947 chol_model_22
10 16620.179688 S 64 B
10 16620.181641 S 24947 Po
10 16620.183594 S 24947 B
13 16620.189453 ntask sched 11.000000
10 16620.191406 S 24947 Fi
10 16620.191406 S 24947 B
10 16620.193359 S 24947 chol_model_22
10 16623.468750 S 64 B
10 16623.470703 S 24947 Po
10 16623.472656 S 24947 B
13 16623.478516 ntask sched 10.000000
10 16623.478516 S 24947 Fi
10 16623.480469 S 24947 B
10 16623.482422 S 24947 chol_model_22
10 16626.753906 S 64 B
10 16626.755859 S 24947 Po
10 16626.757812 S 24947 B
13 16626.763672 ntask sched 9.000000
10 16626.763672 S 24947 Fi
10 16626.765625 S 24947 B
10 16626.765625 S 24947 chol_model_22
10 16630.041016 S 64 B
10 16630.042969 S 24947 Po
10 16630.042969 S 24947 B
13 16630.050781 ntask sched 8.000000
10 16630.050781 S 24947 Fi
10 16630.052734 S 24947 B
10 16630.052734 S 24947 chol_model_22
10 16631.978516 S 0 B
10 16631.980469 S 24951 Po
10 16631.982422 S 24951 B
10 16633.322266 S 64 B
10 16633.322266 S 24947 Po
10 16633.324219 S 24947 B
13 16633.330078 ntask sched 7.000000
10 16633.332031 S 24947 Fi
10 16633.333984 S 24947 B
10 16633.335938 S 24947 chol_model_22
10 16636.605469 S 64 B
10 16636.607422 S 24947 Po
10 16636.609375 S 24947 B
13 16636.615234 ntask sched 6.000000
10 16636.615234 S 24947 Fi
10 16636.617188 S 24947 B
10 16636.617188 S 24947 chol_model_22
10 16639.894531 S 64 B
10 16639.894531 S 24947 Po
10 16639.896484 S 24947 B
13 16639.904297 ntask sched 5.000000
10 16639.906250 S 24947 Fi
10 16639.906250 S 24947 B
10 16639.908203 S 24947 chol_model_22
10 16643.185547 S 64 B
10 16643.185547 S 24947 Po
10 16643.187500 S 24947 B
13 16643.193359 ntask sched 4.000000
10 16643.195312 S 24947 Fi
10 16643.195312 S 24947 B
10 16643.197266 S 24947 chol_model_22
10 16646.468750 S 64 B
10 16646.470703 S 24947 Po
10 16646.472656 S 24947 B
13 16646.478516 ntask sched 3.000000
10 16646.478516 S 24947 Fi
10 16646.480469 S 24947 B
10 16646.480469 S 24947 chol_model_22
10 16649.751953 S 64 B
10 16649.751953 S 24947 Po
10 16649.753906 S 24947 B
13 16649.759766 ntask sched 2.000000
10 16649.761719 S 24947 Fi
10 16649.763672 S 24947 B
10 16649.763672 S 24947 chol_model_22
10 16653.037109 S 64 B
10 16653.037109 S 24947 Po
10 16653.039062 S 24947 B
13 16653.046875 ntask sched 1.000000
10 16653.048828 S 24947 Fi
10 16653.048828 S 24947 B
10 16653.050781 S 24947 chol_model_22
10 16656.332031 S 64 B
10 16656.333984 S 24947 Po
10 16656.335938 S 24947 B
13 16656.341797 ntask sched 0.000000
10 16656.343750 S 24947 Fi
10 16656.343750 S 24947 B
10 16656.345703 S 24947 chol_model_22
10 16659.621094 S 64 B
10 16659.621094 S 24947 Po
10 16659.623047 S 24947 B
10 16684.371094 S 0 B
10 16684.373047 S 24950 Po
10 16684.376953 S 24950 B
10 16684.416016 MS MEMNODE1 Co
18 16684.416016 L p 4000000 MEMNODE0 com_176
13 16684.416016 ntask sched 1.000000
10 16684.425781 MS MEMNODE1 CoA
10 16685.585938 MS MEMNODE1 No
19 16685.585938 L p 1928086912 MEMNODE1 com_1928086720
13 16685.593750 ntask sched 0.000000
10 16685.595703 S 24947 Fi
13 16685.611328 ntask sched 1.000000
13 16685.628906 ntask sched 2.000000
13 16685.664062 ntask sched 3.000000
13 16685.681641 ntask sched 4.000000
10 16685.681641 MS MEMNODE1 Co
18 16685.681641 L p 4000000 MEMNODE0 com_177
10 16685.687500 MS MEMNODE1 CoA
13 16685.697266 ntask sched 5.000000
10 16685.697266 MS MEMNODE0 Co
18 16685.697266 L p 4000000 MEMNODE1 com_178
13 16685.699219 ntask sched 4.000000
10 16685.701172 S 24949 Fi
13 16685.710938 ntask sched 5.000000
10 16685.714844 MS MEMNODE0 Co
18 16685.714844 L p 4000000 MEMNODE1 com_179
13 16685.724609 ntask sched 6.000000
10 16685.726562 MS MEMNODE0 Co
18 16685.726562 L p 4000000 MEMNODE1 com_180
13 16685.738281 ntask sched 7.000000
13 16685.751953 ntask sched 8.000000
13 16685.763672 ntask sched 9.000000
13 16685.777344 ntask sched 10.000000
13 16685.789062 ntask sched 11.000000
13 16685.796875 ntask sched 10.000000
10 16685.798828 S 24950 Fi
10 16686.855469 MS MEMNODE1 No
19 16686.855469 L p 1928086912 MEMNODE1 com_1928086720
10 16686.863281 MS MEMNODE0 CoA
10 16686.873047 MS MEMNODE0 CoA
10 16686.888672 MS MEMNODE0 CoA
10 16688.986328 MS MEMNODE0 No
19 16688.986328 L p 1928086912 MEMNODE0 com_1928086720
10 16691.017578 MS MEMNODE0 No
19 16691.017578 L p 1928086920 MEMNODE0 com_1928086720
10 16693.037109 MS MEMNODE0 No
19 16693.037109 L p 1928086920 MEMNODE0 com_1928086720
10 16693.042969 MS MEMNODE1 No
19 16693.042969 L p 4000000 MEMNODE1 com_176
10 16693.046875 S 24947 B
10 16693.048828 S 24947 chol_model_21
13 16693.050781 ntask sched 9.000000
10 16693.052734 S 24952 Fi
10 16693.054688 S 24952 B
10 16693.054688 S 24952 chol_model_21
13 16693.056641 ntask sched 8.000000
10 16693.058594 S 24951 Fi
10 16693.173828 MS MEMNODE0 No
19 16693.173828 L p 4000000 MEMNODE0 com_178
10 16693.179688 MS MEMNODE0 No
19 16693.179688 L p 4000000 MEMNODE0 com_179
10 16693.183594 S 24950 B
10 16693.185547 S 24950 chol_model_21
10 16693.187500 MS MEMNODE0 No
19 16693.187500 L p 4000000 MEMNODE0 com_180
10 16693.191406 S 24951 B
10 16693.193359 S 24949 B
10 16693.193359 S 24951 chol_model_21
10 16693.193359 S 24949 chol_model_21
10 16701.476562 S 64 B
10 16701.478516 S 24947 Po
10 16701.480469 S 24947 B
13 16701.505859 ntask sched 9.000000
10 16701.517578 MS MEMNODE1 No
19 16701.517578 L p 4000000 MEMNODE1 com_177
13 16701.519531 ntask sched 8.000000
10 16701.521484 S 24947 Fi
10 16701.523438 S 24947 B
10 16701.523438 S 24947 chol_model_21
10 16706.978516 S 0 B
10 16706.980469 S 24948 Po
10 16706.984375 S 24948 B
13 16707.000000 ntask sched 7.000000
10 16707.001953 S 24948 Fi
10 16707.005859 S 24948 B
10 16707.007812 S 24948 chol_model_21
10 16709.841797 S 64 B
10 16709.841797 S 24947 Po
10 16709.843750 S 24947 B
13 16709.861328 ntask sched 8.000000
13 16709.873047 ntask sched 9.000000
13 16709.878906 ntask sched 8.000000
10 16709.878906 S 24947 Fi
10 16709.880859 S 24947 B
10 16709.880859 S 24947 chol_model_21
10 16718.201172 S 64 B
10 16718.201172 S 24947 Po
10 16718.203125 S 24947 B
13 16718.220703 ntask sched 9.000000
13 16718.232422 ntask sched 10.000000
13 16718.242188 ntask sched 11.000000
13 16718.248047 ntask sched 10.000000
10 16718.248047 S 24947 Fi
10 16718.250000 S 24947 B
10 16718.251953 S 24947 chol_model_21
10 16726.564453 S 64 B
10 16726.566406 S 24947 Po
10 16726.566406 S 24947 B
13 16726.583984 ntask sched 11.000000
13 16726.595703 ntask sched 12.000000
13 16726.607422 ntask sched 13.000000
13 16726.617188 ntask sched 14.000000
13 16726.623047 ntask sched 13.000000
10 16726.623047 S 24947 Fi
10 16726.625000 S 24947 B
10 16726.626953 S 24947 chol_model_21
10 16734.933594 S 64 B
10 16734.933594 S 24947 Po
10 16734.935547 S 24947 B
13 16734.953125 ntask sched 14.000000
13 16734.966797 ntask sched 15.000000
13 16734.980469 ntask sched 16.000000
13 16734.992188 ntask sched 17.000000
13 16735.003906 ntask sched 18.000000
10 16735.009766 MS MEMNODE1 A
10 16735.664062 MS MEMNODE1 No
10 16735.667969 MS MEMNODE1 Co
18 16735.667969 L p 4000000 MEMNODE0 com_181
10 16735.675781 MS MEMNODE1 CoA
10 16736.863281 MS MEMNODE1 No
19 16736.863281 L p 1928086912 MEMNODE1 com_1928086720
10 16736.869141 MS MEMNODE1 A
10 16737.222656 MS MEMNODE1 No
10 16737.226562 MS MEMNODE1 Co
18 16737.226562 L p 4000000 MEMNODE0 com_182
10 16737.248047 MS MEMNODE1 CoA
10 16738.464844 MS MEMNODE1 No
19 16738.464844 L p 1928086912 MEMNODE1 com_1928086720
13 16738.472656 ntask sched 17.000000
10 16738.474609 S 24947 Fi
10 16738.476562 S 24947 B
10 16738.478516 S 24947 chol_model_21
10 16741.341797 S 0 B
10 16741.343750 S 24952 Po
10 16741.345703 S 24952 B
10 16741.353516 S 0 B
10 16741.353516 S 24951 Po
10 16741.355469 S 24951 B
13 16741.369141 ntask sched 18.000000
13 16741.378906 ntask sched 19.000000
13 16741.382812 ntask sched 20.000000
13 16741.392578 ntask sched 21.000000
13 16741.396484 ntask sched 22.000000
13 16741.404297 ntask sched 23.000000
13 16741.408203 ntask sched 24.000000
13 16741.419922 ntask sched 25.000000
13 16741.423828 ntask sched 26.000000
13 16741.433594 ntask sched 27.000000
13 16741.435547 ntask sched 28.000000
10 16741.439453 S 0 B
10 16741.441406 S 24949 Po
10 16741.443359 MS MEMNODE0 Co
18 16741.443359 L p 4000000 MEMNODE1 com_183
13 16741.445312 ntask sched 29.000000
10 16741.447266 S 24949 B
10 16741.451172 MS MEMNODE0 CoA
13 16741.457031 ntask sched 30.000000
10 16741.462891 MS MEMNODE0 Co
18 16741.462891 L p 4000000 MEMNODE1 com_184
13 16741.484375 ntask sched 31.000000
13 16741.498047 ntask sched 32.000000
10 16741.511719 S 0 B
13 16741.511719 ntask sched 33.000000
10 16741.513672 S 24950 Po
10 16741.515625 S 24950 B
10 16741.535156 MS MEMNODE0 Co
18 16741.535156 L p 4000000 MEMNODE1 com_185
13 16741.535156 ntask sched 34.000000
13 16741.550781 ntask sched 35.000000
13 16741.562500 ntask sched 36.000000
10 16741.566406 MS MEMNODE0 Co
18 16741.566406 L p 4000000 MEMNODE1 com_186
10 16746.822266 S 64 B
10 16746.824219 S 24947 Po
10 16746.826172 S 24947 B
10 16748.691406 MS MEMNODE0 No
19 16748.691406 L p 1928086848 MEMNODE0 com_1928087104
10 16748.697266 MS MEMNODE0 CoA
10 16748.710938 MS MEMNODE0 CoA
10 16748.718750 MS MEMNODE0 CoA
10 16750.132812 MS MEMNODE0 No
19 16750.132812 L p 1928086912 MEMNODE0 com_1928086720
10 16750.144531 MS MEMNODE0 Co
18 16750.144531 L p 4000000 MEMNODE1 com_187
10 16751.550781 MS MEMNODE0 No
19 16751.550781 L p 0 MEMNODE0 com_0
10 16751.556641 MS MEMNODE1 No
19 16751.556641 L p 4000000 MEMNODE1 com_182
10 16753.001953 MS MEMNODE0 No
19 16753.001953 L p 0 MEMNODE0 com_0
10 16753.017578 MS MEMNODE0 CoA
13 16753.029297 ntask sched 37.000000
10 16753.031250 MS MEMNODE0 Co
18 16753.031250 L p 4000000 MEMNODE1 com_188
10 16753.035156 MS MEMNODE1 No
19 16753.035156 L p 4000000 MEMNODE1 com_181
10 16753.041016 MS MEMNODE0 CoA
13 16753.050781 ntask sched 38.000000
13 16753.066406 ntask sched 39.000000
13 16753.072266 ntask sched 40.000000
13 16753.083984 ntask sched 41.000000
13 16753.101562 ntask sched 42.000000
13 16753.107422 ntask sched 43.000000
13 16753.136719 ntask sched 44.000000
13 16753.166016 ntask sched 45.000000
13 16753.191406 ntask sched 46.000000
13 16753.205078 ntask sched 47.000000
13 16753.220703 ntask sched 48.000000
13 16753.234375 ntask sched 49.000000
13 16753.248047 ntask sched 50.000000
10 16753.255859 MS MEMNODE1 A
10 16754.480469 MS MEMNODE0 No
19 16754.480469 L p 1928086912 MEMNODE0 com_1928086720
13 16754.509766 ntask sched 51.000000
13 16754.527344 ntask sched 52.000000
13 16754.542969 ntask sched 53.000000
13 16754.558594 ntask sched 54.000000
13 16754.574219 ntask sched 55.000000
10 16755.298828 S 0 B
10 16755.298828 S 24948 Po
10 16755.300781 S 24948 B
13 16755.324219 ntask sched 56.000000
13 16755.339844 ntask sched 57.000000
13 16755.355469 ntask sched 58.000000
13 16755.371094 ntask sched 59.000000
13 16755.386719 ntask sched 60.000000
13 16755.402344 ntask sched 61.000000
13 16755.417969 ntask sched 62.000000
10 16755.419922 MS MEMNODE0 Co
18 16755.419922 L p 4000000 MEMNODE1 com_189
10 16755.857422 MS MEMNODE0 No
19 16755.857422 L p 0 MEMNODE0 com_0
10 16755.865234 MS MEMNODE0 No
19 16755.865234 L p 4000000 MEMNODE0 com_184
10 16756.312500 MS MEMNODE1 No
10 16756.314453 MS MEMNODE1 Co
18 16756.314453 L p 4000000 MEMNODE0 com_190
10 16756.318359 MS MEMNODE0 Co
18 16756.318359 L p 4000000 MEMNODE1 com_191
10 16756.322266 MS MEMNODE1 CoA
10 16756.324219 MS MEMNODE0 No
19 16756.324219 L p 4000000 MEMNODE0 com_186
10 16756.330078 MS MEMNODE0 CoA
10 16756.335938 MS MEMNODE0 No
19 16756.335938 L p 4000000 MEMNODE0 com_185
10 16758.384766 MS MEMNODE0 No
19 16758.384766 L p 0 MEMNODE0 com_0
10 16759.601562 MS MEMNODE1 No
19 16759.601562 L p 1928086920 MEMNODE1 com_1928086720
13 16759.609375 ntask sched 61.000000
10 16759.611328 S 24951 Fi
10 16759.613281 MS MEMNODE0 CoA
10 16759.621094 MS MEMNODE0 No
19 16759.621094 L p 4000000 MEMNODE0 com_187
10 16759.626953 MS MEMNODE0 No
19 16759.626953 L p 4000000 MEMNODE0 com_183
13 16759.628906 ntask sched 60.000000
10 16759.630859 S 24949 Fi
10 16759.632812 S 24949 B
10 16759.634766 S 24949 chol_model_22
10 16759.634766 MS MEMNODE0 Co
18 16759.634766 L p 4000000 MEMNODE1 com_192
10 16759.646484 MS MEMNODE1 A
10 16759.648438 MS MEMNODE0 CoA
13 16759.662109 ntask sched 61.000000
13 16759.677734 ntask sched 62.000000
13 16759.691406 ntask sched 63.000000
13 16759.701172 ntask sched 62.000000
10 16759.703125 S 24950 Fi
10 16759.906250 MS MEMNODE1 No
10 16759.908203 MS MEMNODE1 Co
18 16759.908203 L p 4000000 MEMNODE0 com_193
10 16761.949219 MS MEMNODE0 No
19 16761.949219 L p 0 MEMNODE0 com_0
10 16761.955078 MS MEMNODE0 No
19 16761.955078 L p 4000000 MEMNODE0 com_188
10 16764.175781 MS MEMNODE0 No
19 16764.175781 L p 0 MEMNODE0 com_0
10 16764.208984 MS MEMNODE1 CoA
10 16764.220703 MS MEMNODE0 Co
18 16764.220703 L p 4000000 MEMNODE1 com_194
10 16764.226562 MS MEMNODE0 No
19 16764.226562 L p 4000000 MEMNODE0 com_189
10 16764.230469 S 24951 B
10 16764.232422 MS MEMNODE0 CoA
10 16764.232422 S 24951 chol_model_22
10 16765.494141 MS MEMNODE1 No
19 16765.494141 L p 1928086912 MEMNODE1 com_1928086720
10 16765.500000 MS MEMNODE1 Co
18 16765.500000 L p 4000000 MEMNODE0 com_195
10 16765.509766 MS MEMNODE0 Co
18 16765.509766 L p 4000000 MEMNODE1 com_196
10 16767.029297 MS MEMNODE0 No
19 16767.029297 L p 0 MEMNODE0 com_0
10 16767.037109 MS MEMNODE0 No
19 16767.037109 L p 4000000 MEMNODE0 com_191
10 16767.058594 MS MEMNODE1 CoA
10 16767.070312 MS MEMNODE0 CoA
10 16767.080078 MS MEMNODE0 Co
18 16767.080078 L p 4000000 MEMNODE1 com_197
10 16769.054688 MS MEMNODE0 No
19 16769.054688 L p 0 MEMNODE0 com_0
10 16770.146484 MS MEMNODE1 No
19 16770.146484 L p 1928086920 MEMNODE1 com_1928086720
10 16770.152344 MS MEMNODE0 No
19 16770.152344 L p 4000000 MEMNODE0 com_192
10 16770.158203 MS MEMNODE0 CoA
10 16770.195312 MS MEMNODE1 Co
18 16770.195312 L p 4000000 MEMNODE0 com_198
13 16770.210938 ntask sched 63.000000
13 16770.228516 ntask sched 64.000000
13 16770.240234 ntask sched 65.000000
13 16770.253906 ntask sched 64.000000
10 16770.255859 S 24948 Fi
10 16770.257812 S 24948 B
10 16770.257812 S 24948 chol_model_22
10 16771.683594 MS MEMNODE0 No
19 16771.683594 L p 1928086912 MEMNODE0 com_1928086720
10 16771.689453 MS MEMNODE0 No
19 16771.689453 L p 4000000 MEMNODE0 com_194
10 16771.703125 MS MEMNODE1 CoA
10 16771.710938 MS MEMNODE0 Co
18 16771.710938 L p 4000000 MEMNODE1 com_199
10 16771.716797 MS MEMNODE0 No
19 16771.716797 L p 4000000 MEMNODE0 com_196
10 16772.880859 MS MEMNODE1 No
19 16772.880859 L p 0 MEMNODE1 com_0
10 16772.888672 MS MEMNODE1 Co
18 16772.888672 L p 4000000 MEMNODE0 com_200
10 16772.890625 MS MEMNODE0 CoA
10 16772.904297 MS MEMNODE1 CoA
10 16774.087891 MS MEMNODE1 No
19 16774.087891 L p 1928086912 MEMNODE1 com_1928086720
10 16775.666016 MS MEMNODE0 No
19 16775.666016 L p 1928086920 MEMNODE0 com_1928086720
10 16775.671875 MS MEMNODE0 No
19 16775.671875 L p 4000000 MEMNODE0 com_197
10 16775.679688 MS MEMNODE1 Co
18 16775.679688 L p 4000000 MEMNODE0 com_201
10 16775.693359 MS MEMNODE1 CoA
13 16775.705078 ntask sched 63.000000
10 16775.707031 S 24952 Fi
10 16775.710938 S 24952 B
10 16775.712891 S 24952 chol_model_22
10 16776.933594 MS MEMNODE1 No
19 16776.933594 L p 1928086912 MEMNODE1 com_1928086720
10 16776.941406 MS MEMNODE0 No
19 16776.941406 L p 4000000 MEMNODE0 com_199
10 16776.943359 S 24950 B
10 16776.945312 S 24950 chol_model_22
10 16776.951172 MS MEMNODE1 Co
18 16776.951172 L p 4000000 MEMNODE0 com_202
10 16776.970703 MS MEMNODE1 CoA
10 16778.201172 MS MEMNODE1 No
19 16778.201172 L p 1928086912 MEMNODE1 com_1928086720
10 16778.205078 MS MEMNODE1 Co
18 16778.205078 L p 4000000 MEMNODE0 com_203
10 16778.220703 MS MEMNODE1 CoA
10 16779.421875 MS MEMNODE1 No
19 16779.421875 L p 1928086912 MEMNODE1 com_1928086720
13 16779.429688 ntask sched 62.000000
10 16779.433594 S 24947 Fi
10 16779.435547 S 24947 B
10 16779.437500 S 24947 chol_model_21
10 16787.779297 S 64 B
10 16787.781250 S 24947 Po
10 16787.783203 S 24947 B
13 16787.806641 ntask sched 63.000000
13 16787.818359 ntask sched 64.000000
13 16787.830078 ntask sched 65.000000
13 16787.843750 ntask sched 66.000000
13 16787.869141 ntask sched 67.000000
13 16787.880859 ntask sched 68.000000
13 16787.892578 ntask sched 69.000000
13 16787.904297 ntask sched 70.000000
13 16787.916016 ntask sched 71.000000
13 16787.927734 ntask sched 72.000000
13 16787.937500 ntask sched 73.000000
13 16787.949219 ntask sched 74.000000
10 16787.986328 MS MEMNODE1 No
19 16787.986328 L p 4000000 MEMNODE1 com_203
10 16787.990234 MS MEMNODE1 No
19 16787.990234 L p 4000000 MEMNODE1 com_202
10 16787.992188 MS MEMNODE1 No
19 16787.992188 L p 4000000 MEMNODE1 com_201
10 16787.994141 MS MEMNODE1 No
19 16787.994141 L p 4000000 MEMNODE1 com_200
10 16787.996094 MS MEMNODE1 No
19 16787.996094 L p 4000000 MEMNODE1 com_198
10 16787.998047 MS MEMNODE1 No
19 16787.998047 L p 4000000 MEMNODE1 com_195
10 16788.001953 MS MEMNODE1 No
19 16788.001953 L p 4000000 MEMNODE1 com_193
10 16788.003906 MS MEMNODE1 No
19 16788.003906 L p 4000000 MEMNODE1 com_190
10 16788.005859 MS MEMNODE1 Co
18 16788.005859 L p 4000000 MEMNODE0 com_204
10 16788.011719 MS MEMNODE1 CoA
10 16789.230469 MS MEMNODE1 No
19 16789.230469 L p 1928086912 MEMNODE1 com_1928086720
10 16789.236328 MS MEMNODE1 Co
18 16789.236328 L p 4000000 MEMNODE0 com_205
10 16789.240234 MS MEMNODE1 CoA
10 16790.402344 MS MEMNODE1 No
19 16790.402344 L p 1928086912 MEMNODE1 com_1928086720
10 16790.406250 MS MEMNODE1 Co
18 16790.406250 L p 4000000 MEMNODE0 com_206
10 16790.412109 MS MEMNODE1 CoA
10 16791.566406 MS MEMNODE1 No
19 16791.566406 L p 1928086912 MEMNODE1 com_1928086720
10 16791.572266 MS MEMNODE1 Co
18 16791.572266 L p 4000000 MEMNODE0 com_207
10 16791.576172 MS MEMNODE1 CoA
10 16792.740234 MS MEMNODE1 No
19 16792.740234 L p 1928086912 MEMNODE1 com_1928086720
10 16792.744141 MS MEMNODE1 Co
18 16792.744141 L p 4000000 MEMNODE0 com_208
10 16792.748047 MS MEMNODE1 CoA
10 16793.923828 MS MEMNODE1 No
19 16793.923828 L p 1928086912 MEMNODE1 com_1928086720
10 16793.927734 MS MEMNODE1 Co
18 16793.927734 L p 4000000 MEMNODE0 com_209
10 16793.933594 MS MEMNODE1 CoA
10 16795.169922 MS MEMNODE1 No
19 16795.169922 L p 1928086912 MEMNODE1 com_1928086720
10 16795.173828 MS MEMNODE1 Co
18 16795.173828 L p 4000000 MEMNODE0 com_210
10 16795.177734 MS MEMNODE1 CoA
10 16796.335938 MS MEMNODE1 No
19 16796.335938 L p 1928086912 MEMNODE1 com_1928086720
13 16796.343750 ntask sched 73.000000
10 16796.347656 S 24947 Fi
10 16796.349609 S 24947 B
10 16796.351562 S 24947 chol_model_21
10 16804.689453 S 64 B
10 16804.689453 S 24947 Po
10 16804.693359 S 24947 B
13 16804.720703 ntask sched 74.000000
13 16804.732422 ntask sched 75.000000
13 16804.742188 ntask sched 76.000000
13 16804.755859 ntask sched 77.000000
13 16804.765625 ntask sched 78.000000
13 16804.777344 ntask sched 79.000000
13 16804.787109 ntask sched 80.000000
13 16804.798828 ntask sched 81.000000
13 16804.810547 ntask sched 82.000000
13 16804.820312 ntask sched 83.000000
13 16804.832031 ntask sched 84.000000
13 16804.843750 ntask sched 85.000000
13 16804.853516 ntask sched 86.000000
10 16804.888672 MS MEMNODE1 No
19 16804.888672 L p 4000000 MEMNODE1 com_210
10 16804.890625 MS MEMNODE1 No
19 16804.890625 L p 4000000 MEMNODE1 com_209
10 16804.892578 MS MEMNODE1 No
19 16804.892578 L p 4000000 MEMNODE1 com_208
10 16804.896484 MS MEMNODE1 No
19 16804.896484 L p 4000000 MEMNODE1 com_207
10 16804.898438 MS MEMNODE1 No
19 16804.898438 L p 4000000 MEMNODE1 com_206
10 16804.900391 MS MEMNODE1 No
19 16804.900391 L p 4000000 MEMNODE1 com_205
10 16804.902344 MS MEMNODE1 No
19 16804.902344 L p 4000000 MEMNODE1 com_204
10 16804.904297 MS MEMNODE1 Co
18 16804.904297 L p 4000000 MEMNODE0 com_211
10 16804.910156 MS MEMNODE1 CoA
10 16806.048828 MS MEMNODE1 No
19 16806.048828 L p 1928086912 MEMNODE1 com_1928086720
10 16806.054688 MS MEMNODE1 Co
18 16806.054688 L p 4000000 MEMNODE0 com_212
10 16806.058594 MS MEMNODE1 CoA
10 16807.238281 MS MEMNODE1 No
19 16807.238281 L p 1928086912 MEMNODE1 com_1928086720
10 16807.242188 MS MEMNODE1 Co
18 16807.242188 L p 4000000 MEMNODE0 com_213
10 16807.248047 MS MEMNODE1 CoA
10 16808.404297 MS MEMNODE1 No
19 16808.404297 L p 1928086912 MEMNODE1 com_1928086720
10 16808.410156 MS MEMNODE1 Co
18 16808.410156 L p 4000000 MEMNODE0 com_214
10 16808.414062 MS MEMNODE1 CoA
10 16809.574219 MS MEMNODE1 No
19 16809.574219 L p 1928086912 MEMNODE1 com_1928086720
13 16809.582031 ntask sched 85.000000
10 16809.585938 S 24947 Fi
10 16809.589844 S 24947 B
10 16809.591797 S 24947 chol_model_22
10 16812.910156 S 64 B
10 16812.912109 S 24947 Po
10 16812.914062 S 24947 B
13 16812.937500 ntask sched 86.000000
10 16812.970703 MS MEMNODE1 No
19 16812.970703 L p 4000000 MEMNODE1 com_214
10 16812.974609 MS MEMNODE1 No
19 16812.974609 L p 4000000 MEMNODE1 com_213
10 16812.976562 MS MEMNODE1 No
19 16812.976562 L p 4000000 MEMNODE1 com_212
10 16812.978516 MS MEMNODE1 No
19 16812.978516 L p 4000000 MEMNODE1 com_211
13 16812.980469 ntask sched 85.000000
10 16812.982422 S 24947 Fi
10 16812.982422 S 24947 B
10 16812.984375 S 24947 chol_model_22
10 16816.265625 S 64 B
10 16816.267578 S 24947 Po
10 16816.269531 S 24947 B
13 16816.275391 ntask sched 84.000000
10 16816.277344 S 24947 Fi
10 16816.277344 S 24947 B
10 16816.279297 S 24947 chol_model_22
10 16819.552734 S 64 B
10 16819.554688 S 24947 Po
10 16819.556641 S 24947 B
13 16819.562500 ntask sched 83.000000
10 16819.564453 S 24947 Fi
10 16819.566406 S 24947 B
10 16819.566406 S 24947 chol_model_22
10 16822.847656 S 64 B
10 16822.847656 S 24947 Po
10 16822.849609 S 24947 B
13 16822.857422 ntask sched 82.000000
10 16822.857422 S 24947 Fi
10 16822.859375 S 24947 B
10 16822.859375 S 24947 chol_model_22
10 16826.128906 S 64 B
10 16826.130859 S 24947 Po
10 16826.132812 S 24947 B
13 16826.138672 ntask sched 81.000000
10 16826.138672 S 24947 Fi
10 16826.140625 S 24947 B
10 16826.140625 S 24947 chol_model_22
10 16829.416016 S 64 B
10 16829.417969 S 24947 Po
10 16829.417969 S 24947 B
13 16829.423828 ntask sched 80.000000
10 16829.425781 S 24947 Fi
10 16829.427734 S 24947 B
10 16829.427734 S 24947 chol_model_22
10 16832.710938 S 64 B
10 16832.710938 S 24947 Po
10 16832.712891 S 24947 B
13 16832.718750 ntask sched 79.000000
10 16832.720703 S 24947 Fi
10 16832.722656 S 24947 B
10 16832.722656 S 24947 chol_model_22
10 16836.003906 S 64 B
10 16836.005859 S 24947 Po
10 16836.007812 S 24947 B
13 16836.015625 ntask sched 78.000000
10 16836.017578 S 24947 Fi
10 16836.017578 S 24947 B
10 16836.019531 S 24947 chol_model_22
10 16839.292969 S 64 B
10 16839.292969 S 24947 Po
10 16839.294922 S 24947 B
13 16839.300781 ntask sched 77.000000
10 16839.302734 S 24947 Fi
10 16839.302734 S 24947 B
10 16839.304688 S 24947 chol_model_22
10 16842.574219 S 64 B
10 16842.576172 S 24947 Po
10 16842.578125 S 24947 B
13 16842.583984 ntask sched 76.000000
10 16842.585938 S 24947 Fi
10 16842.587891 S 24947 B
10 16842.587891 S 24947 chol_model_22
10 16845.865234 S 64 B
10 16845.867188 S 24947 Po
10 16845.867188 S 24947 B
13 16845.875000 ntask sched 75.000000
10 16845.876953 S 24947 Fi
10 16845.876953 S 24947 B
10 16845.878906 S 24947 chol_model_22
10 16849.156250 S 64 B
10 16849.156250 S 24947 Po
10 16849.158203 S 24947 B
13 16849.164062 ntask sched 74.000000
10 16849.164062 S 24947 Fi
10 16849.167969 S 24947 B
10 16849.167969 S 24947 chol_model_22
10 16850.720703 S 0 B
10 16850.722656 S 24949 Po
10 16850.728516 S 24949 B
10 16850.744141 MS MEMNODE0 Co
18 16850.744141 L p 4000000 MEMNODE1 com_215
10 16850.763672 MS MEMNODE0 CoA
10 16852.449219 S 64 B
10 16852.449219 S 24947 Po
10 16852.451172 S 24947 B
13 16852.458984 ntask sched 73.000000
10 16852.460938 S 24947 Fi
10 16852.462891 S 24947 B
10 16852.462891 S 24947 chol_model_22
10 16854.433594 MS MEMNODE0 No
19 16854.433594 L p 1928086912 MEMNODE0 com_1928086720
10 16854.453125 MS MEMNODE0 Co
18 16854.453125 L p 4000000 MEMNODE1 com_216
10 16854.482422 MS MEMNODE0 CoA
10 16855.455078 S 0 B
10 16855.457031 S 24951 Po
10 16855.460938 S 24951 B
10 16857.732422 S 64 B
10 16857.734375 S 24947 Po
10 16857.736328 S 24947 B
13 16857.742188 ntask sched 72.000000
10 16857.742188 S 24947 Fi
10 16857.744141 S 24947 B
10 16857.744141 S 24947 chol_model_22
10 16859.687500 MS MEMNODE0 No
19 16859.687500 L p 1928086912 MEMNODE0 com_1928086720
10 16859.691406 MS MEMNODE0 No
19 16859.691406 L p 4000000 MEMNODE0 com_215
13 16859.695312 ntask sched 71.000000
10 16859.697266 S 24951 Fi
10 16859.699219 S 24951 B
10 16859.699219 S 24951 chol_model_22
10 16859.710938 MS MEMNODE0 Co
18 16859.710938 L p 4000000 MEMNODE1 com_217
10 16859.732422 MS MEMNODE0 CoA
10 16861.513672 S 0 B
10 16861.515625 S 24948 Po
10 16861.519531 S 24948 B
10 16862.984375 S 64 B
10 16862.984375 S 24947 Po
10 16862.986328 S 24947 B
13 16862.994141 ntask sched 70.000000
10 16862.996094 S 24947 Fi
10 16862.998047 S 24947 B
10 16862.998047 S 24947 chol_model_22
10 16864.310547 MS MEMNODE0 No
19 16864.310547 L p 1928086912 MEMNODE0 com_1928086720
10 16864.314453 MS MEMNODE0 No
19 16864.314453 L p 4000000 MEMNODE0 com_216
13 16864.318359 ntask sched 69.000000
10 16864.320312 S 24948 Fi
10 16864.324219 S 24948 B
10 16864.324219 S 24948 chol_model_22
10 16864.357422 MS MEMNODE0 Co
18 16864.357422 L p 4000000 MEMNODE1 com_218
10 16864.363281 MS MEMNODE0 CoA
10 16866.744141 S 0 B
10 16866.746094 S 24952 Po
10 16866.748047 S 24952 B
13 16866.763672 ntask sched 68.000000
10 16866.765625 S 24952 Fi
10 16866.765625 S 24952 B
10 16866.767578 S 24952 chol_model_22
10 16867.609375 S 64 B
10 16867.611328 S 24947 Po
10 16867.611328 S 24947 B
13 16867.619141 ntask sched 67.000000
10 16867.621094 S 24947 Fi
10 16867.623047 S 24947 B
10 16867.623047 S 24947 chol_model_22
10 16868.146484 S 0 B
10 16868.148438 S 24950 Po
10 16868.152344 S 24950 B
10 16869.529297 MS MEMNODE0 No
19 16869.529297 L p 1928086912 MEMNODE0 com_1928086720
10 16869.580078 MS MEMNODE0 Co
18 16869.580078 L p 4000000 MEMNODE1 com_219
10 16869.587891 MS MEMNODE0 No
19 16869.587891 L p 4000000 MEMNODE0 com_217
13 16869.591797 ntask sched 66.000000
10 16869.591797 MS MEMNODE0 CoA
10 16869.593750 S 24950 Fi
10 16869.595703 S 24950 B
10 16869.595703 S 24950 chol_model_22
10 16872.841797 S 64 B
10 16872.843750 S 24947 Po
10 16872.845703 S 24947 B
13 16872.853516 ntask sched 65.000000
10 16872.855469 S 24947 Fi
10 16872.855469 S 24947 B
10 16872.857422 S 24947 chol_model_22
10 16874.201172 MS MEMNODE0 No
19 16874.201172 L p 1928086912 MEMNODE0 com_1928086720
10 16874.220703 MS MEMNODE0 Co
18 16874.220703 L p 4000000 MEMNODE1 com_220
10 16874.261719 MS MEMNODE0 CoA
10 16877.500000 S 64 B
10 16877.501953 S 24947 Po
10 16877.503906 S 24947 B
13 16877.511719 ntask sched 64.000000
10 16877.513672 S 24947 Fi
10 16877.513672 S 24947 B
10 16877.515625 S 24947 chol_model_22
10 16879.455078 MS MEMNODE0 No
19 16879.455078 L p 1928086912 MEMNODE0 com_1928086720
10 16879.476562 MS MEMNODE0 Co
18 16879.476562 L p 4000000 MEMNODE1 com_221
10 16879.505859 MS MEMNODE0 CoA
10 16882.755859 S 64 B
10 16882.757812 S 24947 Po
10 16882.759766 S 24947 B
13 16882.765625 ntask sched 63.000000
10 16882.767578 S 24947 Fi
10 16882.769531 S 24947 B
10 16882.769531 S 24947 chol_model_22
10 16884.726562 MS MEMNODE0 No
19 16884.726562 L p 1928086912 MEMNODE0 com_1928086720
10 16884.744141 MS MEMNODE0 Co
18 16884.744141 L p 4000000 MEMNODE1 com_222
10 16884.781250 MS MEMNODE0 CoA
10 16888.054688 S 64 B
10 16888.054688 S 24947 Po
10 16888.056641 S 24947 B
13 16888.066406 ntask sched 62.000000
10 16888.068359 S 24947 Fi
10 16888.070312 S 24947 B
10 16888.070312 S 24947 chol_model_22
10 16890.050781 MS MEMNODE0 No
19 16890.050781 L p 1928086912 MEMNODE0 com_1928086720
10 16890.097656 MS MEMNODE0 Co
18 16890.097656 L p 4000000 MEMNODE1 com_223
10 16890.119141 MS MEMNODE0 CoA
10 16893.345703 S 64 B
10 16893.345703 S 24947 Po
10 16893.347656 S 24947 B
13 16893.357422 ntask sched 61.000000
10 16893.359375 S 24947 Fi
10 16893.359375 S 24947 B
10 16893.361328 S 24947 chol_model_22
10 16894.707031 MS MEMNODE0 No
19 16894.707031 L p 1928086912 MEMNODE0 com_1928086720
13 16894.730469 ntask sched 60.000000
10 16894.734375 S 24949 Fi
10 16894.738281 S 24949 B
10 16894.740234 S 24949 chol_model_22
10 16898.003906 S 64 B
10 16898.003906 S 24947 Po
10 16898.005859 S 24947 B
13 16898.013672 ntask sched 59.000000
10 16898.015625 S 24947 Fi
10 16898.017578 S 24947 B
10 16898.017578 S 24947 chol_model_22
10 16901.302734 S 64 B
10 16901.304688 S 24947 Po
10 16901.306641 S 24947 B
13 16901.312500 ntask sched 58.000000
10 16901.314453 S 24947 Fi
10 16901.316406 S 24947 B
10 16901.316406 S 24947 chol_model_22
10 16904.591797 S 64 B
10 16904.593750 S 24947 Po
10 16904.595703 S 24947 B
13 16904.601562 ntask sched 57.000000
10 16904.603516 S 24947 Fi
10 16904.603516 S 24947 B
10 16904.605469 S 24947 chol_model_22
10 16907.884766 S 64 B
10 16907.886719 S 24947 Po
10 16907.888672 S 24947 B
13 16907.894531 ntask sched 56.000000
10 16907.894531 S 24947 Fi
10 16907.896484 S 24947 B
10 16907.898438 S 24947 chol_model_22
10 16911.179688 S 64 B
10 16911.179688 S 24947 Po
10 16911.181641 S 24947 B
13 16911.189453 ntask sched 55.000000
10 16911.191406 S 24947 Fi
10 16911.193359 S 24947 B
10 16911.193359 S 24947 chol_model_22
10 16914.472656 S 64 B
10 16914.474609 S 24947 Po
10 16914.476562 S 24947 B
13 16914.482422 ntask sched 54.000000
10 16914.484375 S 24947 Fi
10 16914.484375 S 24947 B
10 16914.486328 S 24947 chol_model_22
10 16917.769531 S 64 B
10 16917.769531 S 24947 Po
10 16917.771484 S 24947 B
13 16917.779297 ntask sched 53.000000
10 16917.781250 S 24947 Fi
10 16917.783203 S 24947 B
10 16917.783203 S 24947 chol_model_22
10 16921.060547 S 64 B
10 16921.060547 S 24947 Po
10 16921.062500 S 24947 B
13 16921.068359 ntask sched 52.000000
10 16921.070312 S 24947 Fi
10 16921.072266 S 24947 B
10 16921.072266 S 24947 chol_model_22
10 16924.349609 S 64 B
10 16924.351562 S 24947 Po
10 16924.351562 S 24947 B
13 16924.359375 ntask sched 51.000000
10 16924.359375 S 24947 Fi
10 16924.361328 S 24947 B
10 16924.363281 S 24947 chol_model_22
10 16927.644531 S 64 B
10 16927.646484 S 24947 Po
10 16927.648438 S 24947 B
13 16927.654297 ntask sched 50.000000
10 16927.656250 S 24947 Fi
10 16927.656250 S 24947 B
10 16927.658203 S 24947 chol_model_22
10 16930.939453 S 64 B
10 16930.939453 S 24947 Po
10 16930.941406 S 24947 B
13 16930.947266 ntask sched 49.000000
10 16930.949219 S 24947 Fi
10 16930.949219 S 24947 B
10 16930.951172 S 24947 chol_model_22
10 16934.228516 S 64 B
10 16934.228516 S 24947 Po
10 16934.230469 S 24947 B
13 16934.236328 ntask sched 48.000000
10 16934.238281 S 24947 Fi
10 16934.240234 S 24947 B
10 16934.240234 S 24947 chol_model_22
10 16937.529297 S 64 B
10 16937.529297 S 24947 Po
10 16937.531250 S 24947 B
13 16937.539062 ntask sched 47.000000
10 16937.539062 S 24947 Fi
10 16937.542969 S 24947 B
10 16937.542969 S 24947 chol_model_22
10 16940.822266 S 64 B
10 16940.822266 S 24947 Po
10 16940.824219 S 24947 B
13 16940.830078 ntask sched 46.000000
10 16940.832031 S 24947 Fi
10 16940.833984 S 24947 B
10 16940.835938 S 24947 chol_model_22
10 16944.113281 S 64 B
10 16944.113281 S 24947 Po
10 16944.115234 S 24947 B
13 16944.123047 ntask sched 45.000000
10 16944.123047 S 24947 Fi
10 16944.126953 S 24947 B
10 16944.126953 S 24947 chol_model_22
10 16947.400391 S 64 B
10 16947.400391 S 24947 Po
10 16947.402344 S 24947 B
13 16947.408203 ntask sched 44.000000
10 16947.410156 S 24947 Fi
10 16947.412109 S 24947 B
10 16947.412109 S 24947 chol_model_22
10 16950.697266 S 64 B
10 16950.697266 S 24947 Po
10 16950.699219 S 24947 B
13 16950.705078 ntask sched 43.000000
10 16950.707031 S 24947 Fi
10 16950.708984 S 24947 B
10 16950.710938 S 24947 chol_model_22
10 16953.986328 S 64 B
10 16953.988281 S 24947 Po
10 16953.988281 S 24947 B
13 16953.994141 ntask sched 42.000000
10 16953.996094 S 24947 Fi
10 16953.998047 S 24947 B
10 16953.998047 S 24947 chol_model_22
10 16955.564453 S 0 B
10 16955.566406 S 24948 Po
10 16955.570312 S 24948 B
10 16955.658203 MS MEMNODE0 No
19 16955.658203 L p 4000000 MEMNODE0 com_223
10 16955.685547 MS MEMNODE0 No
19 16955.685547 L p 4000000 MEMNODE0 com_222
10 16955.710938 MS MEMNODE0 No
19 16955.710938 L p 4000000 MEMNODE0 com_221
10 16955.736328 MS MEMNODE0 No
19 16955.736328 L p 4000000 MEMNODE0 com_220
10 16955.761719 MS MEMNODE0 No
19 16955.761719 L p 4000000 MEMNODE0 com_219
10 16955.789062 MS MEMNODE0 No
19 16955.789062 L p 4000000 MEMNODE0 com_218
13 16955.792969 ntask sched 41.000000
10 16955.794922 S 24948 Fi
10 16955.798828 S 24948 B
10 16955.800781 S 24948 chol_model_22
10 16957.277344 S 64 B
10 16957.277344 S 24947 Po
10 16957.279297 S 24947 B
13 16957.287109 ntask sched 40.000000
10 16957.287109 S 24947 Fi
10 16957.289062 S 24947 B
10 16957.289062 S 24947 chol_model_22
10 16958.478516 S 0 B
10 16958.480469 S 24951 Po
10 16958.482422 S 24951 B
13 16958.490234 ntask sched 39.000000
10 16958.492188 S 24951 Fi
10 16958.494141 S 24951 B
10 16958.494141 S 24951 chol_model_22
10 16960.576172 S 64 B
10 16960.578125 S 24947 Po
10 16960.578125 S 24947 B
13 16960.585938 ntask sched 38.000000
10 16960.587891 S 24947 Fi
10 16960.589844 S 24947 B
10 16960.589844 S 24947 chol_model_22
10 16960.781250 S 0 B
10 16960.783203 S 24950 Po
10 16960.787109 S 24950 B
13 16960.800781 ntask sched 37.000000
10 16960.802734 S 24950 Fi
10 16960.812500 S 24950 B
10 16960.812500 S 24950 chol_model_22
10 16963.876953 S 64 B
10 16963.878906 S 24947 Po
10 16963.880859 S 24947 B
13 16963.886719 ntask sched 36.000000
10 16963.888672 S 24947 Fi
10 16963.890625 S 24947 B
10 16963.890625 S 24947 chol_model_22
10 16965.884766 S 0 B
10 16965.886719 S 24952 Po
10 16965.888672 S 24952 B
13 16965.896484 ntask sched 35.000000
10 16965.898438 S 24952 Fi
10 16965.898438 S 24952 B
10 16965.900391 S 24952 chol_model_22
10 16967.173828 S 64 B
10 16967.175781 S 24947 Po
10 16967.177734 S 24947 B
13 16967.183594 ntask sched 34.000000
10 16967.183594 S 24947 Fi
10 16967.185547 S 24947 B
10 16967.187500 S 24947 chol_model_22
10 16970.466797 S 64 B
10 16970.466797 S 24947 Po
10 16970.468750 S 24947 B
13 16970.474609 ntask sched 33.000000
10 16970.476562 S 24947 Fi
10 16970.478516 S 24947 B
10 16970.478516 S 24947 chol_model_22
10 16973.755859 S 64 B
10 16973.757812 S 24947 Po
10 16973.759766 S 24947 B
13 16973.765625 ntask sched 32.000000
10 16973.767578 S 24947 Fi
10 16973.769531 S 24947 B
10 16973.769531 S 24947 chol_model_22
10 16977.044922 S 64 B
10 16977.044922 S 24947 Po
10 16977.046875 S 24947 B
13 16977.054688 ntask sched 31.000000
10 16977.054688 S 24947 Fi
10 16977.056641 S 24947 B
10 16977.056641 S 24947 chol_model_22
10 16980.341797 S 64 B
10 16980.341797 S 24947 Po
10 16980.343750 S 24947 B
13 16980.349609 ntask sched 30.000000
10 16980.351562 S 24947 Fi
10 16980.353516 S 24947 B
10 16980.353516 S 24947 chol_model_22
10 16983.626953 S 64 B
10 16983.626953 S 24947 Po
10 16983.628906 S 24947 B
13 16983.634766 ntask sched 29.000000
10 16983.636719 S 24947 Fi
10 16983.642578 S 24947 B
10 16983.642578 S 24947 chol_model_22
10 16986.015625 S 0 B
10 16986.019531 S 24949 Po
10 16986.025391 S 24949 B
13 16986.044922 ntask sched 28.000000
10 16986.046875 S 24949 Fi
10 16986.050781 S 24949 B
10 16986.050781 S 24949 chol_model_22
10 16986.925781 S 64 B
10 16986.927734 S 24947 Po
10 16986.929688 S 24947 B
13 16986.935547 ntask sched 27.000000
10 16986.937500 S 24947 Fi
10 16986.939453 S 24947 B
10 16986.939453 S 24947 chol_model_22
10 16990.218750 S 64 B
10 16990.218750 S 24947 Po
10 16990.220703 S 24947 B
13 16990.226562 ntask sched 26.000000
10 16990.228516 S 24947 Fi
10 16990.230469 S 24947 B
10 16990.230469 S 24947 chol_model_22
10 16993.511719 S 64 B
10 16993.513672 S 24947 Po
10 16993.515625 S 24947 B
13 16993.521484 ntask sched 25.000000
10 16993.523438 S 24947 Fi
10 16993.525391 S 24947 B
10 16993.525391 S 24947 chol_model_22
10 16996.804688 S 64 B
10 16996.804688 S 24947 Po
10 16996.806641 S 24947 B
13 16996.812500 ntask sched 24.000000
10 16996.814453 S 24947 Fi
10 16996.814453 S 24947 B
10 16996.816406 S 24947 chol_model_22
10 17000.089844 S 64 B
10 17000.091797 S 24947 Po
10 17000.091797 S 24947 B
13 17000.097656 ntask sched 23.000000
10 17000.099609 S 24947 Fi
10 17000.101562 S 24947 B
10 17000.101562 S 24947 chol_model_22
10 17003.373047 S 64 B
10 17003.373047 S 24947 Po
10 17003.376953 S 24947 B
13 17003.382812 ntask sched 22.000000
10 17003.382812 S 24947 Fi
10 17003.384766 S 24947 B
10 17003.384766 S 24947 chol_model_22
10 17006.656250 S 64 B
10 17006.658203 S 24947 Po
10 17006.660156 S 24947 B
13 17006.666016 ntask sched 21.000000
10 17006.667969 S 24947 Fi
10 17006.667969 S 24947 B
10 17006.669922 S 24947 chol_model_22
10 17009.947266 S 64 B
10 17009.949219 S 24947 Po
10 17009.951172 S 24947 B
13 17009.957031 ntask sched 20.000000
10 17009.958984 S 24947 Fi
10 17009.960938 S 24947 B
10 17009.962891 S 24947 chol_model_22
10 17013.250000 S 64 B
10 17013.251953 S 24947 Po
10 17013.253906 S 24947 B
13 17013.259766 ntask sched 19.000000
10 17013.261719 S 24947 Fi
10 17013.261719 S 24947 B
10 17013.263672 S 24947 chol_model_22
10 17016.542969 S 64 B
10 17016.542969 S 24947 Po
10 17016.544922 S 24947 B
13 17016.550781 ntask sched 18.000000
10 17016.552734 S 24947 Fi
10 17016.554688 S 24947 B
10 17016.554688 S 24947 chol_model_22
10 17019.837891 S 64 B
10 17019.839844 S 24947 Po
10 17019.839844 S 24947 B
13 17019.845703 ntask sched 17.000000
10 17019.847656 S 24947 Fi
10 17019.849609 S 24947 B
10 17019.849609 S 24947 chol_model_22
10 17023.130859 S 64 B
10 17023.130859 S 24947 Po
10 17023.132812 S 24947 B
13 17023.140625 ntask sched 16.000000
10 17023.140625 S 24947 Fi
10 17023.142578 S 24947 B
10 17023.142578 S 24947 chol_model_22
10 17026.423828 S 64 B
10 17026.423828 S 24947 Po
10 17026.425781 S 24947 B
13 17026.431641 ntask sched 15.000000
10 17026.433594 S 24947 Fi
10 17026.435547 S 24947 B
10 17026.435547 S 24947 chol_model_22
10 17029.714844 S 64 B
10 17029.714844 S 24947 Po
10 17029.716797 S 24947 B
13 17029.722656 ntask sched 14.000000
10 17029.724609 S 24947 Fi
10 17029.724609 S 24947 B
10 17029.726562 S 24947 chol_model_22
10 17033.005859 S 64 B
10 17033.005859 S 24947 Po
10 17033.007812 S 24947 B
13 17033.013672 ntask sched 13.000000
10 17033.015625 S 24947 Fi
10 17033.017578 S 24947 B
10 17033.017578 S 24947 chol_model_22
10 17036.296875 S 64 B
10 17036.296875 S 24947 Po
10 17036.298828 S 24947 B
13 17036.304688 ntask sched 12.000000
10 17036.304688 S 24947 Fi
10 17036.306641 S 24947 B
10 17036.308594 S 24947 chol_model_22
10 17039.585938 S 64 B
10 17039.587891 S 24947 Po
10 17039.587891 S 24947 B
13 17039.595703 ntask sched 11.000000
10 17039.595703 S 24947 Fi
10 17039.597656 S 24947 B
10 17039.597656 S 24947 chol_model_22
10 17042.873047 S 64 B
10 17042.875000 S 24947 Po
10 17042.876953 S 24947 B
13 17042.882812 ntask sched 10.000000
10 17042.884766 S 24947 Fi
10 17042.884766 S 24947 B
10 17042.886719 S 24947 chol_model_22
10 17046.156250 S 64 B
10 17046.158203 S 24947 Po
10 17046.160156 S 24947 B
13 17046.166016 ntask sched 9.000000
10 17046.167969 S 24947 Fi
10 17046.169922 S 24947 B
10 17046.169922 S 24947 chol_model_22
10 17046.933594 S 0 B
10 17046.937500 S 24948 Po
10 17046.941406 S 24948 B
10 17049.449219 S 64 B
10 17049.449219 S 24947 Po
10 17049.451172 S 24947 B
13 17049.458984 ntask sched 8.000000
10 17049.460938 S 24947 Fi
10 17049.462891 S 24947 B
10 17049.462891 S 24947 chol_model_22
10 17051.654297 S 0 B
10 17051.656250 S 24951 Po
10 17051.658203 S 24951 B
13 17051.669922 ntask sched 7.000000
10 17051.671875 S 24951 Fi
10 17051.671875 S 24951 B
10 17051.673828 S 24951 chol_model_11
10 17052.042969 S 0 B
10 17052.044922 S 24950 Po
10 17052.046875 S 24950 B
10 17052.740234 S 64 B
10 17052.742188 S 24947 Po
10 17052.744141 S 24947 B
13 17052.750000 ntask sched 6.000000
10 17052.751953 S 24947 Fi
10 17052.753906 S 24947 B
10 17052.753906 S 24947 chol_model_22
10 17056.027344 S 64 B
10 17056.027344 S 24947 Po
10 17056.029297 S 24947 B
13 17056.035156 ntask sched 5.000000
10 17056.037109 S 24947 Fi
10 17056.039062 S 24947 B
10 17056.039062 S 24947 chol_model_22
10 17058.257812 S 0 B
10 17058.259766 S 24952 Po
10 17058.261719 S 24952 B
10 17059.316406 S 64 B
10 17059.316406 S 24947 Po
10 17059.318359 S 24947 B
13 17059.324219 ntask sched 4.000000
10 17059.326172 S 24947 Fi
10 17059.328125 S 24947 B
10 17059.328125 S 24947 chol_model_22
10 17062.595703 S 64 B
10 17062.597656 S 24947 Po
10 17062.599609 S 24947 B
13 17062.605469 ntask sched 3.000000
10 17062.607422 S 24947 Fi
10 17062.607422 S 24947 B
10 17062.609375 S 24947 chol_model_22
10 17065.884766 S 64 B
10 17065.884766 S 24947 Po
10 17065.886719 S 24947 B
13 17065.892578 ntask sched 2.000000
10 17065.894531 S 24947 Fi
10 17065.894531 S 24947 B
10 17065.896484 S 24947 chol_model_22
10 17069.171875 S 64 B
10 17069.173828 S 24947 Po
10 17069.175781 S 24947 B
13 17069.181641 ntask sched 1.000000
10 17069.183594 S 24947 Fi
10 17069.185547 S 24947 B
10 17069.185547 S 24947 chol_model_22
10 17072.460938 S 64 B
10 17072.462891 S 24947 Po
10 17072.462891 S 24947 B
13 17072.468750 ntask sched 0.000000
10 17072.470703 S 24947 Fi
10 17072.472656 S 24947 B
10 17072.472656 S 24947 chol_model_22
10 17075.744141 S 64 B
10 17075.744141 S 24947 Po
10 17075.746094 S 24947 B
10 17076.980469 S 0 B
10 17076.982422 S 24949 Po
10 17076.986328 S 24949 B
10 17117.453125 S 0 B
10 17117.455078 S 24951 Po
10 17117.455078 S 24951 B
13 17117.482422 ntask sched 1.000000
10 17117.482422 MS MEMNODE1 Co
18 17117.482422 L p 4000000 MEMNODE0 com_224
10 17117.494141 MS MEMNODE1 CoA
10 17118.593750 MS MEMNODE1 No
19 17118.593750 L p 1928086912 MEMNODE1 com_1928086720
13 17118.599609 ntask sched 0.000000
10 17118.599609 S 24947 Fi
13 17118.630859 ntask sched 1.000000
13 17118.654297 ntask sched 2.000000
13 17118.669922 ntask sched 3.000000
13 17118.691406 ntask sched 4.000000
13 17118.716797 ntask sched 5.000000
13 17118.726562 ntask sched 4.000000
10 17118.730469 S 24948 Fi
10 17118.734375 S 24948 B
10 17118.734375 S 24948 chol_model_21
13 17118.736328 ntask sched 5.000000
10 17118.740234 MS MEMNODE0 Co
18 17118.740234 L p 4000000 MEMNODE1 com_225
13 17118.746094 ntask sched 4.000000
10 17118.748047 S 24949 Fi
10 17118.748047 MS MEMNODE0 CoA
13 17118.761719 ntask sched 5.000000
10 17118.763672 MS MEMNODE0 Co
18 17118.763672 L p 4000000 MEMNODE1 com_226
10 17120.123047 MS MEMNODE0 No
19 17120.123047 L p 0 MEMNODE0 com_0
10 17120.132812 MS MEMNODE0 CoA
10 17120.138672 MS MEMNODE1 No
19 17120.138672 L p 4000000 MEMNODE1 com_224
10 17120.140625 S 24947 B
10 17120.140625 S 24947 chol_model_21
13 17120.144531 ntask sched 6.000000
10 17120.148438 MS MEMNODE0 Co
18 17120.148438 L p 4000000 MEMNODE1 com_227
10 17120.154297 MS MEMNODE0 CoA
13 17120.158203 ntask sched 7.000000
13 17120.171875 ntask sched 8.000000
13 17120.183594 ntask sched 9.000000
10 17120.189453 MS MEMNODE0 Co
18 17120.189453 L p 4000000 MEMNODE1 com_228
10 17123.404297 MS MEMNODE0 No
19 17123.404297 L p 0 MEMNODE0 com_0
10 17124.744141 MS MEMNODE0 No
19 17124.744141 L p 1928086920 MEMNODE0 com_1928086720
10 17124.751953 MS MEMNODE0 CoA
10 17124.759766 MS MEMNODE0 No
19 17124.759766 L p 4000000 MEMNODE0 com_225
10 17124.763672 S 24949 B
10 17124.765625 S 24949 chol_model_21
13 17124.781250 ntask sched 8.000000
10 17124.783203 S 24950 Fi
10 17126.125000 MS MEMNODE0 No
19 17126.125000 L p 1928086912 MEMNODE0 com_1928086720
13 17126.132812 ntask sched 7.000000
10 17126.134766 S 24952 Fi
10 17126.183594 MS MEMNODE0 No
19 17126.183594 L p 4000000 MEMNODE0 com_226
10 17126.185547 S 24950 B
10 17126.185547 S 24950 chol_model_21
13 17126.193359 ntask sched 6.000000
10 17126.193359 S 24951 Fi
10 17126.197266 MS MEMNODE0 No
19 17126.197266 L p 4000000 MEMNODE0 com_227
10 17126.201172 S 24951 B
10 17126.201172 S 24951 chol_model_21
10 17126.398438 MS MEMNODE0 No
19 17126.398438 L p 4000000 MEMNODE0 com_228
10 17126.400391 S 24952 B
10 17126.400391 S 24952 chol_model_21
10 17133.279297 S 64 B
10 17133.281250 S 24947 Po
10 17133.283203 S 24947 B
13 17133.306641 ntask sched 7.000000
10 17133.314453 MS MEMNODE1 Co
18 17133.314453 L p 4000000 MEMNODE0 com_229
10 17133.320312 MS MEMNODE1 CoA
10 17134.474609 MS MEMNODE1 No
19 17134.474609 L p 1928086912 MEMNODE1 com_1928086720
13 17134.482422 ntask sched 6.000000
10 17134.484375 S 24947 Fi
10 17134.484375 S 24947 B
10 17134.486328 S 24947 chol_model_21
10 17142.826172 S 64 B
10 17142.828125 S 24947 Po
10 17142.830078 S 24947 B
13 17142.851562 ntask sched 7.000000
13 17142.863281 ntask sched 8.000000
10 17142.896484 MS MEMNODE1 No
19 17142.896484 L p 4000000 MEMNODE1 com_229
13 17142.898438 ntask sched 7.000000
10 17142.900391 S 24947 Fi
10 17142.900391 S 24947 B
10 17142.902344 S 24947 chol_model_21
10 17151.218750 S 64 B
10 17151.218750 S 24947 Po
10 17151.220703 S 24947 B
13 17151.238281 ntask sched 8.000000
13 17151.251953 ntask sched 9.000000
13 17151.261719 ntask sched 10.000000
13 17151.267578 ntask sched 9.000000
10 17151.269531 S 24947 Fi
10 17151.269531 S 24947 B
10 17151.269531 S 24947 chol_model_21
10 17159.580078 S 64 B
10 17159.580078 S 24947 Po
10 17159.582031 S 24947 B
13 17159.599609 ntask sched 10.000000
13 17159.611328 ntask sched 11.000000
13 17159.623047 ntask sched 12.000000
13 17159.634766 ntask sched 13.000000
13 17159.642578 ntask sched 12.000000
10 17159.644531 S 24947 Fi
10 17159.644531 S 24947 B
10 17159.646484 S 24947 chol_model_21
10 17166.949219 S 0 B
10 17166.953125 S 24948 Po
10 17166.957031 S 24948 B
13 17166.990234 ntask sched 13.000000
13 17167.003906 ntask sched 14.000000
13 17167.017578 ntask sched 15.000000
13 17167.029297 ntask sched 16.000000
13 17167.041016 ntask sched 17.000000
10 17167.962891 S 64 B
10 17167.962891 S 24947 Po
10 17167.964844 S 24947 B
13 17167.984375 ntask sched 18.000000
13 17168.000000 ntask sched 19.000000
13 17168.013672 ntask sched 20.000000
13 17168.027344 ntask sched 21.000000
13 17168.039062 ntask sched 22.000000
13 17168.054688 ntask sched 23.000000
10 17168.060547 MS MEMNODE1 Co
18 17168.060547 L p 4000000 MEMNODE0 com_230
10 17168.066406 MS MEMNODE1 CoA
10 17169.275391 MS MEMNODE1 No
19 17169.275391 L p 1928086912 MEMNODE1 com_1928086720
13 17169.283203 ntask sched 22.000000
10 17169.285156 S 24947 Fi
10 17169.287109 S 24947 B
10 17169.287109 S 24947 chol_model_21
10 17172.917969 S 0 B
10 17172.917969 S 24949 Po
10 17172.919922 S 24949 B
13 17172.943359 ntask sched 23.000000
13 17172.957031 ntask sched 24.000000
10 17172.972656 MS MEMNODE0 Co
18 17172.972656 L p 4000000 MEMNODE1 com_231
13 17172.972656 ntask sched 25.000000
13 17172.986328 ntask sched 26.000000
10 17172.990234 MS MEMNODE0 CoA
13 17173.000000 ntask sched 27.000000
13 17173.015625 ntask sched 28.000000
13 17173.027344 ntask sched 29.000000
10 17173.033203 MS MEMNODE0 Co
18 17173.033203 L p 4000000 MEMNODE1 com_232
10 17174.287109 S 0 B
10 17174.287109 S 24950 Po
10 17174.289062 S 24950 B
13 17174.312500 ntask sched 30.000000
13 17174.326172 ntask sched 31.000000
10 17174.330078 MS MEMNODE0 Co
18 17174.330078 L p 4000000 MEMNODE1 com_233
10 17174.347656 S 0 B
10 17174.349609 S 24951 Po
10 17174.351562 S 24951 B
10 17174.417969 S 0 B
10 17174.417969 S 24952 Po
10 17174.419922 S 24952 B
10 17177.615234 S 64 B
10 17177.615234 S 24947 Po
10 17177.617188 S 24947 B
10 17178.974609 MS MEMNODE0 No
19 17178.974609 L p 1928086848 MEMNODE0 com_1928087104
10 17178.980469 MS MEMNODE0 CoA
10 17178.986328 MS MEMNODE0 CoA
10 17180.412109 MS MEMNODE0 No
19 17180.412109 L p 1928086912 MEMNODE0 com_1928086720
13 17180.423828 ntask sched 30.000000
10 17180.425781 S 24948 Fi
10 17180.425781 MS MEMNODE1 No
19 17180.425781 L p 4000000 MEMNODE1 com_230
10 17180.427734 MS MEMNODE1 Co
18 17180.427734 L p 4000000 MEMNODE0 com_234
10 17181.886719 MS MEMNODE0 No
19 17181.886719 L p 0 MEMNODE0 com_0
10 17181.892578 MS MEMNODE0 Co
18 17181.892578 L p 4000000 MEMNODE1 com_235
10 17181.898438 MS MEMNODE1 CoA
10 17181.902344 MS MEMNODE0 CoA
10 17183.046875 MS MEMNODE1 No
19 17183.046875 L p 1928086912 MEMNODE1 com_1928086720
10 17183.052734 MS MEMNODE0 No
19 17183.052734 L p 4000000 MEMNODE0 com_231
10 17185.191406 MS MEMNODE0 No
19 17185.191406 L p 0 MEMNODE0 com_0
10 17185.199219 MS MEMNODE0 Co
18 17185.199219 L p 4000000 MEMNODE1 com_236
10 17185.203125 MS MEMNODE0 No
19 17185.203125 L p 4000000 MEMNODE0 com_232
10 17185.205078 MS MEMNODE0 CoA
10 17185.205078 S 24948 B
10 17185.207031 S 24948 chol_model_22
10 17185.212891 MS MEMNODE1 Co
18 17185.212891 L p 4000000 MEMNODE0 com_237
13 17185.218750 ntask sched 31.000000
13 17185.234375 ntask sched 32.000000
13 17185.248047 ntask sched 33.000000
13 17185.263672 ntask sched 34.000000
13 17185.277344 ntask sched 35.000000
13 17185.292969 ntask sched 36.000000
13 17185.306641 ntask sched 37.000000
13 17185.320312 ntask sched 38.000000
13 17185.328125 ntask sched 37.000000
10 17185.328125 S 24951 Fi
10 17187.277344 MS MEMNODE0 No
19 17187.277344 L p 1928086912 MEMNODE0 com_1928086720
13 17187.287109 ntask sched 36.000000
10 17187.289062 S 24949 Fi
10 17187.289062 MS MEMNODE1 CoA
10 17187.292969 S 24949 B
10 17187.292969 S 24949 chol_model_22
10 17187.294922 MS MEMNODE0 No
19 17187.294922 L p 4000000 MEMNODE0 com_233
13 17187.298828 ntask sched 37.000000
13 17187.314453 ntask sched 38.000000
13 17187.328125 ntask sched 39.000000
13 17187.341797 ntask sched 40.000000
13 17187.355469 ntask sched 41.000000
13 17187.367188 ntask sched 42.000000
13 17187.380859 ntask sched 43.000000
13 17187.392578 ntask sched 44.000000
13 17187.406250 ntask sched 45.000000
13 17187.412109 ntask sched 44.000000
10 17187.412109 S 24952 Fi
10 17187.414062 S 24952 B
10 17187.414062 S 24952 chol_model_22
10 17188.484375 MS MEMNODE1 No
19 17188.484375 L p 1928086912 MEMNODE1 com_1928086720
10 17188.505859 MS MEMNODE0 No
19 17188.505859 L p 4000000 MEMNODE0 com_235
13 17188.517578 ntask sched 45.000000
13 17188.529297 ntask sched 46.000000
13 17188.535156 ntask sched 47.000000
13 17188.544922 ntask sched 48.000000
13 17188.550781 ntask sched 49.000000
13 17188.560547 ntask sched 50.000000
13 17188.564453 ntask sched 51.000000
13 17188.574219 ntask sched 52.000000
13 17188.578125 ntask sched 53.000000
13 17188.589844 ntask sched 54.000000
13 17188.593750 ntask sched 55.000000
13 17188.603516 ntask sched 56.000000
13 17188.609375 ntask sched 57.000000
10 17188.609375 MS MEMNODE0 Co
18 17188.609375 L p 4000000 MEMNODE1 com_238
10 17188.615234 MS MEMNODE0 CoA
13 17188.617188 ntask sched 58.000000
13 17188.625000 ntask sched 59.000000
13 17188.632812 ntask sched 60.000000
13 17188.644531 ntask sched 61.000000
13 17188.650391 ntask sched 62.000000
13 17188.662109 ntask sched 63.000000
10 17190.017578 MS MEMNODE0 No
19 17190.017578 L p 1928086912 MEMNODE0 com_1928086720
10 17190.023438 MS MEMNODE0 No
19 17190.023438 L p 4000000 MEMNODE0 com_236
10 17190.025391 MS MEMNODE0 Co
18 17190.025391 L p 4000000 MEMNODE1 com_239
10 17190.027344 MS MEMNODE1 No
19 17190.027344 L p 4000000 MEMNODE1 com_237
10 17190.035156 MS MEMNODE0 CoA
10 17190.044922 S 24951 B
10 17190.046875 S 24951 chol_model_22
10 17192.087891 MS MEMNODE0 No
19 17192.087891 L p 1928086912 MEMNODE0 com_1928086720
10 17192.093750 MS MEMNODE1 No
19 17192.093750 L p 4000000 MEMNODE1 com_234
10 17192.095703 MS MEMNODE1 Co
18 17192.095703 L p 4000000 MEMNODE0 com_240
10 17192.105469 MS MEMNODE0 Co
18 17192.105469 L p 4000000 MEMNODE1 com_241
10 17192.109375 MS MEMNODE1 CoA
10 17192.111328 MS MEMNODE0 CoA
10 17193.261719 MS MEMNODE1 No
19 17193.261719 L p 1928086912 MEMNODE1 com_1928086720
10 17195.451172 MS MEMNODE0 No
19 17195.451172 L p 1928086920 MEMNODE0 com_1928086720
10 17195.460938 MS MEMNODE1 Co
18 17195.460938 L p 4000000 MEMNODE0 com_242
10 17195.468750 MS MEMNODE0 Co
18 17195.468750 L p 4000000 MEMNODE1 com_243
10 17195.474609 MS MEMNODE1 CoA
10 17195.476562 MS MEMNODE0 CoA
10 17196.634766 MS MEMNODE1 No
19 17196.634766 L p 1928086912 MEMNODE1 com_1928086720
10 17198.923828 MS MEMNODE0 No
19 17198.923828 L p 1928086920 MEMNODE0 com_1928086720
10 17198.931641 MS MEMNODE1 Co
18 17198.931641 L p 4000000 MEMNODE0 com_244
13 17198.945312 ntask sched 62.000000
10 17198.949219 S 24950 Fi
10 17198.953125 S 24950 B
10 17198.955078 S 24950 chol_model_22
10 17198.964844 MS MEMNODE1 CoA
10 17200.164062 MS MEMNODE1 No
19 17200.164062 L p 1928086912 MEMNODE1 com_1928086720
10 17200.169922 MS MEMNODE1 Co
18 17200.169922 L p 4000000 MEMNODE0 com_245
10 17200.183594 MS MEMNODE1 CoA
10 17201.341797 MS MEMNODE1 No
19 17201.341797 L p 1928086912 MEMNODE1 com_1928086720
10 17201.347656 MS MEMNODE1 Co
18 17201.347656 L p 4000000 MEMNODE0 com_246
10 17201.359375 MS MEMNODE1 CoA
10 17202.515625 MS MEMNODE1 No
19 17202.515625 L p 1928086912 MEMNODE1 com_1928086720
10 17202.521484 MS MEMNODE1 Co
18 17202.521484 L p 4000000 MEMNODE0 com_247
10 17202.533203 MS MEMNODE1 CoA
10 17203.693359 MS MEMNODE1 No
19 17203.693359 L p 1928086912 MEMNODE1 com_1928086720
13 17203.701172 ntask sched 61.000000
10 17203.703125 S 24947 Fi
10 17203.707031 S 24947 B
10 17203.708984 S 24947 chol_model_21
10 17212.050781 S 64 B
10 17212.052734 S 24947 Po
10 17212.054688 S 24947 B
13 17212.078125 ntask sched 62.000000
13 17212.091797 ntask sched 63.000000
13 17212.101562 ntask sched 64.000000
13 17212.113281 ntask sched 65.000000
13 17212.125000 ntask sched 66.000000
13 17212.136719 ntask sched 67.000000
13 17212.148438 ntask sched 68.000000
13 17212.158203 ntask sched 69.000000
13 17212.169922 ntask sched 70.000000
13 17212.181641 ntask sched 71.000000
13 17212.193359 ntask sched 72.000000
13 17212.203125 ntask sched 73.000000
10 17212.238281 MS MEMNODE1 No
19 17212.238281 L p 4000000 MEMNODE1 com_247
10 17212.240234 MS MEMNODE1 No
19 17212.240234 L p 4000000 MEMNODE1 com_246
10 17212.242188 MS MEMNODE1 No
19 17212.242188 L p 4000000 MEMNODE1 com_245
10 17212.244141 MS MEMNODE1 No
19 17212.244141 L p 4000000 MEMNODE1 com_244
10 17212.248047 MS MEMNODE1 No
19 17212.248047 L p 4000000 MEMNODE1 com_242
10 17212.250000 MS MEMNODE1 No
19 17212.250000 L p 4000000 MEMNODE1 com_240
10 17212.251953 MS MEMNODE1 Co
18 17212.251953 L p 4000000 MEMNODE0 com_248
10 17212.257812 MS MEMNODE1 CoA
10 17213.396484 MS MEMNODE1 No
19 17213.396484 L p 1928086912 MEMNODE1 com_1928086720
10 17213.402344 MS MEMNODE1 Co
18 17213.402344 L p 4000000 MEMNODE0 com_249
10 17213.406250 MS MEMNODE1 CoA
10 17214.611328 MS MEMNODE1 No
19 17214.611328 L p 1928086912 MEMNODE1 com_1928086720
10 17214.615234 MS MEMNODE1 Co
18 17214.615234 L p 4000000 MEMNODE0 com_250
10 17214.623047 MS MEMNODE1 CoA
10 17215.783203 MS MEMNODE1 No
19 17215.783203 L p 1928086912 MEMNODE1 com_1928086720
10 17215.787109 MS MEMNODE1 Co
18 17215.787109 L p 4000000 MEMNODE0 com_251
10 17215.792969 MS MEMNODE1 CoA
10 17216.957031 MS MEMNODE1 No
19 17216.957031 L p 1928086912 MEMNODE1 com_1928086720
13 17216.964844 ntask sched 72.000000
10 17216.968750 S 24947 Fi
10 17216.970703 S 24947 B
10 17216.972656 S 24947 chol_model_22
10 17220.304688 S 64 B
10 17220.304688 S 24947 Po
10 17220.306641 S 24947 B
13 17220.330078 ntask sched 73.000000
10 17220.361328 MS MEMNODE1 No
19 17220.361328 L p 4000000 MEMNODE1 com_251
10 17220.365234 MS MEMNODE1 No
19 17220.365234 L p 4000000 MEMNODE1 com_250
10 17220.367188 MS MEMNODE1 No
19 17220.367188 L p 4000000 MEMNODE1 com_249
10 17220.369141 MS MEMNODE1 No
19 17220.369141 L p 4000000 MEMNODE1 com_248
13 17220.371094 ntask sched 72.000000
10 17220.371094 S 24947 Fi
10 17220.373047 S 24947 B
10 17220.375000 S 24947 chol_model_22
10 17223.660156 S 64 B
10 17223.660156 S 24947 Po
10 17223.662109 S 24947 B
13 17223.669922 ntask sched 71.000000
10 17223.669922 S 24947 Fi
10 17223.671875 S 24947 B
10 17223.671875 S 24947 chol_model_22
10 17226.945312 S 64 B
10 17226.945312 S 24947 Po
10 17226.947266 S 24947 B
13 17226.953125 ntask sched 70.000000
10 17226.955078 S 24947 Fi
10 17226.957031 S 24947 B
10 17226.957031 S 24947 chol_model_22
10 17230.234375 S 64 B
10 17230.236328 S 24947 Po
10 17230.238281 S 24947 B
13 17230.244141 ntask sched 69.000000
10 17230.244141 S 24947 Fi
10 17230.246094 S 24947 B
10 17230.248047 S 24947 chol_model_22
10 17233.525391 S 64 B
10 17233.525391 S 24947 Po
10 17233.527344 S 24947 B
13 17233.533203 ntask sched 68.000000
10 17233.535156 S 24947 Fi
10 17233.537109 S 24947 B
10 17233.537109 S 24947 chol_model_22
10 17236.812500 S 64 B
10 17236.812500 S 24947 Po
10 17236.814453 S 24947 B
13 17236.822266 ntask sched 67.000000
10 17236.824219 S 24947 Fi
10 17236.824219 S 24947 B
10 17236.826172 S 24947 chol_model_22
10 17240.109375 S 64 B
10 17240.109375 S 24947 Po
10 17240.111328 S 24947 B
13 17240.119141 ntask sched 66.000000
10 17240.121094 S 24947 Fi
10 17240.123047 S 24947 B
10 17240.123047 S 24947 chol_model_22
10 17243.404297 S 64 B
10 17243.406250 S 24947 Po
10 17243.406250 S 24947 B
13 17243.412109 ntask sched 65.000000
10 17243.414062 S 24947 Fi
10 17243.416016 S 24947 B
10 17243.417969 S 24947 chol_model_22
10 17246.689453 S 64 B
10 17246.691406 S 24947 Po
10 17246.691406 S 24947 B
13 17246.697266 ntask sched 64.000000
10 17246.699219 S 24947 Fi
10 17246.701172 S 24947 B
10 17246.701172 S 24947 chol_model_22
10 17249.974609 S 64 B
10 17249.976562 S 24947 Po
10 17249.978516 S 24947 B
13 17249.984375 ntask sched 63.000000
10 17249.986328 S 24947 Fi
10 17249.988281 S 24947 B
10 17249.988281 S 24947 chol_model_22
10 17253.273438 S 64 B
10 17253.273438 S 24947 Po
10 17253.275391 S 24947 B
13 17253.281250 ntask sched 62.000000
10 17253.283203 S 24947 Fi
10 17253.285156 S 24947 B
10 17253.285156 S 24947 chol_model_22
10 17256.558594 S 64 B
10 17256.558594 S 24947 Po
10 17256.560547 S 24947 B
13 17256.566406 ntask sched 61.000000
10 17256.566406 S 24947 Fi
10 17256.568359 S 24947 B
10 17256.570312 S 24947 chol_model_22
10 17259.845703 S 64 B
10 17259.847656 S 24947 Po
10 17259.849609 S 24947 B
13 17259.855469 ntask sched 60.000000
10 17259.855469 S 24947 Fi
10 17259.857422 S 24947 B
10 17259.859375 S 24947 chol_model_22
10 17263.134766 S 64 B
10 17263.136719 S 24947 Po
10 17263.138672 S 24947 B
13 17263.146484 ntask sched 59.000000
10 17263.148438 S 24947 Fi
10 17263.148438 S 24947 B
10 17263.150391 S 24947 chol_model_22
10 17266.421875 S 64 B
10 17266.421875 S 24947 Po
10 17266.423828 S 24947 B
13 17266.429688 ntask sched 58.000000
10 17266.431641 S 24947 Fi
10 17266.433594 S 24947 B
10 17266.433594 S 24947 chol_model_22
10 17269.712891 S 64 B
10 17269.712891 S 24947 Po
10 17269.714844 S 24947 B
13 17269.720703 ntask sched 57.000000
10 17269.722656 S 24947 Fi
10 17269.724609 S 24947 B
10 17269.724609 S 24947 chol_model_22
10 17273.003906 S 64 B
10 17273.003906 S 24947 Po
10 17273.005859 S 24947 B
13 17273.011719 ntask sched 56.000000
10 17273.013672 S 24947 Fi
10 17273.015625 S 24947 B
10 17273.015625 S 24947 chol_model_22
10 17276.294922 S 64 B
10 17276.294922 S 24947 Po
10 17276.296875 S 24947 B
13 17276.302734 ntask sched 55.000000
10 17276.302734 S 24947 Fi
10 17276.304688 S 24947 B
10 17276.306641 S 24947 chol_model_22
10 17276.689453 S 0 B
10 17276.693359 S 24948 Po
10 17276.697266 S 24948 B
10 17276.787109 MS MEMNODE0 No
19 17276.787109 L p 4000000 MEMNODE0 com_243
10 17276.814453 MS MEMNODE0 No
19 17276.814453 L p 4000000 MEMNODE0 com_241
10 17276.839844 MS MEMNODE0 No
19 17276.839844 L p 4000000 MEMNODE0 com_239
10 17276.865234 MS MEMNODE0 No
19 17276.865234 L p 4000000 MEMNODE0 com_238
10 17276.867188 MS MEMNODE0 Co
18 17276.867188 L p 4000000 MEMNODE1 com_252
10 17276.882812 MS MEMNODE0 CoA
10 17278.177734 S 0 B
10 17278.179688 S 24952 Po
10 17278.181641 S 24952 B
13 17278.189453 ntask sched 54.000000
10 17278.191406 S 24952 Fi
10 17278.193359 S 24952 B
10 17278.193359 S 24952 chol_model_22
10 17278.626953 S 0 B
10 17278.628906 S 24949 Po
10 17278.630859 S 24949 B
13 17278.646484 ntask sched 53.000000
10 17278.648438 S 24949 Fi
10 17278.652344 S 24949 B
10 17278.652344 S 24949 chol_model_22
10 17279.593750 S 64 B
10 17279.595703 S 24947 Po
10 17279.597656 S 24947 B
13 17279.603516 ntask sched 52.000000
10 17279.605469 S 24947 Fi
10 17279.605469 S 24947 B
10 17279.607422 S 24947 chol_model_22
10 17281.017578 MS MEMNODE0 No
19 17281.017578 L p 1928086912 MEMNODE0 com_1928086720
13 17281.041016 ntask sched 51.000000
10 17281.044922 S 24948 Fi
10 17281.046875 S 24948 B
10 17281.048828 S 24948 chol_model_22
10 17281.226562 S 0 B
10 17281.228516 S 24951 Po
10 17281.230469 S 24951 B
10 17281.279297 MS MEMNODE0 No
19 17281.279297 L p 4000000 MEMNODE0 com_252
13 17281.281250 ntask sched 50.000000
10 17281.283203 S 24951 Fi
10 17281.285156 S 24951 B
10 17281.285156 S 24951 chol_model_22
10 17284.316406 S 64 B
10 17284.318359 S 24947 Po
10 17284.320312 S 24947 B
13 17284.326172 ntask sched 49.000000
10 17284.328125 S 24947 Fi
10 17284.330078 S 24947 B
10 17284.330078 S 24947 chol_model_22
10 17287.603516 S 64 B
10 17287.605469 S 24947 Po
10 17287.605469 S 24947 B
13 17287.613281 ntask sched 48.000000
10 17287.613281 S 24947 Fi
10 17287.615234 S 24947 B
10 17287.615234 S 24947 chol_model_22
10 17290.408203 S 0 B
10 17290.412109 S 24950 Po
10 17290.416016 S 24950 B
13 17290.431641 ntask sched 47.000000
10 17290.433594 S 24950 Fi
10 17290.437500 S 24950 B
10 17290.437500 S 24950 chol_model_22
10 17290.888672 S 64 B
10 17290.888672 S 24947 Po
10 17290.890625 S 24947 B
13 17290.898438 ntask sched 46.000000
10 17290.898438 S 24947 Fi
10 17290.900391 S 24947 B
10 17290.900391 S 24947 chol_model_22
10 17294.181641 S 64 B
10 17294.181641 S 24947 Po
10 17294.183594 S 24947 B
13 17294.189453 ntask sched 45.000000
10 17294.191406 S 24947 Fi
10 17294.191406 S 24947 B
10 17294.193359 S 24947 chol_model_22
10 17297.462891 S 64 B
10 17297.462891 S 24947 Po
10 17297.464844 S 24947 B
13 17297.470703 ntask sched 44.000000
10 17297.472656 S 24947 Fi
10 17297.472656 S 24947 B
10 17297.474609 S 24947 chol_model_22
10 17300.753906 S 64 B
10 17300.753906 S 24947 Po
10 17300.755859 S 24947 B
13 17300.761719 ntask sched 43.000000
10 17300.763672 S 24947 Fi
10 17300.763672 S 24947 B
10 17300.765625 S 24947 chol_model_22
10 17304.054688 S 64 B
10 17304.054688 S 24947 Po
10 17304.056641 S 24947 B
13 17304.064453 ntask sched 42.000000
10 17304.064453 S 24947 Fi
10 17304.066406 S 24947 B
10 17304.066406 S 24947 chol_model_22
10 17307.339844 S 64 B
10 17307.339844 S 24947 Po
10 17307.341797 S 24947 B
13 17307.347656 ntask sched 41.000000
10 17307.349609 S 24947 Fi
10 17307.351562 S 24947 B
10 17307.351562 S 24947 chol_model_22
10 17310.630859 S 64 B
10 17310.630859 S 24947 Po
10 17310.632812 S 24947 B
13 17310.644531 ntask sched 40.000000
10 17310.644531 S 24947 Fi
10 17310.646484 S 24947 B
10 17310.648438 S 24947 chol_model_22
10 17313.923828 S 64 B
10 17313.925781 S 24947 Po
10 17313.925781 S 24947 B
13 17313.931641 ntask sched 39.000000
10 17313.933594 S 24947 Fi
10 17313.935547 S 24947 B
10 17313.935547 S 24947 chol_model_22
10 17317.212891 S 64 B
10 17317.212891 S 24947 Po
10 17317.214844 S 24947 B
13 17317.220703 ntask sched 38.000000
10 17317.222656 S 24947 Fi
10 17317.224609 S 24947 B
10 17317.224609 S 24947 chol_model_22
10 17320.505859 S 64 B
10 17320.505859 S 24947 Po
10 17320.507812 S 24947 B
13 17320.513672 ntask sched 37.000000
10 17320.515625 S 24947 Fi
10 17320.517578 S 24947 B
10 17320.517578 S 24947 chol_model_22
10 17323.789062 S 64 B
10 17323.789062 S 24947 Po
10 17323.792969 S 24947 B
13 17323.798828 ntask sched 36.000000
10 17323.798828 S 24947 Fi
10 17323.800781 S 24947 B
10 17323.800781 S 24947 chol_model_22
10 17327.072266 S 64 B
10 17327.072266 S 24947 Po
10 17327.074219 S 24947 B
13 17327.080078 ntask sched 35.000000
10 17327.082031 S 24947 Fi
10 17327.083984 S 24947 B
10 17327.085938 S 24947 chol_model_22
10 17330.363281 S 64 B
10 17330.365234 S 24947 Po
10 17330.367188 S 24947 B
13 17330.373047 ntask sched 34.000000
10 17330.375000 S 24947 Fi
10 17330.376953 S 24947 B
10 17330.378906 S 24947 chol_model_22
10 17333.652344 S 64 B
10 17333.652344 S 24947 Po
10 17333.654297 S 24947 B
13 17333.660156 ntask sched 33.000000
10 17333.662109 S 24947 Fi
10 17333.662109 S 24947 B
10 17333.664062 S 24947 chol_model_22
10 17336.935547 S 64 B
10 17336.937500 S 24947 Po
10 17336.939453 S 24947 B
13 17336.945312 ntask sched 32.000000
10 17336.945312 S 24947 Fi
10 17336.947266 S 24947 B
10 17336.947266 S 24947 chol_model_22
10 17340.216797 S 64 B
10 17340.216797 S 24947 Po
10 17340.218750 S 24947 B
13 17340.224609 ntask sched 31.000000
10 17340.226562 S 24947 Fi
10 17340.228516 S 24947 B
10 17340.228516 S 24947 chol_model_22
10 17343.505859 S 64 B
10 17343.505859 S 24947 Po
10 17343.507812 S 24947 B
13 17343.513672 ntask sched 30.000000
10 17343.515625 S 24947 Fi
10 17343.517578 S 24947 B
10 17343.517578 S 24947 chol_model_22
10 17346.800781 S 64 B
10 17346.800781 S 24947 Po
10 17346.802734 S 24947 B
13 17346.808594 ntask sched 29.000000
10 17346.810547 S 24947 Fi
10 17346.810547 S 24947 B
10 17346.812500 S 24947 chol_model_22
10 17350.087891 S 64 B
10 17350.087891 S 24947 Po
10 17350.089844 S 24947 B
13 17350.097656 ntask sched 28.000000
10 17350.097656 S 24947 Fi
10 17350.099609 S 24947 B
10 17350.099609 S 24947 chol_model_22
10 17353.371094 S 64 B
10 17353.373047 S 24947 Po
10 17353.375000 S 24947 B
13 17353.382812 ntask sched 27.000000
10 17353.382812 S 24947 Fi
10 17353.384766 S 24947 B
10 17353.384766 S 24947 chol_model_22
10 17356.667969 S 64 B
10 17356.667969 S 24947 Po
10 17356.669922 S 24947 B
13 17356.675781 ntask sched 26.000000
10 17356.677734 S 24947 Fi
10 17356.679688 S 24947 B
10 17356.679688 S 24947 chol_model_22
10 17359.962891 S 64 B
10 17359.964844 S 24947 Po
10 17359.966797 S 24947 B
13 17359.972656 ntask sched 25.000000
10 17359.972656 S 24947 Fi
10 17359.974609 S 24947 B
10 17359.976562 S 24947 chol_model_22
10 17363.259766 S 64 B
10 17363.259766 S 24947 Po
10 17363.261719 S 24947 B
13 17363.267578 ntask sched 24.000000
10 17363.269531 S 24947 Fi
10 17363.271484 S 24947 B
10 17363.271484 S 24947 chol_model_22
10 17368.453125 S 0 B
10 17368.455078 S 24952 Po
10 17368.457031 S 24952 B
10 17369.916016 S 0 B
10 17369.917969 S 24949 Po
10 17369.923828 S 24949 B
10 17371.466797 S 0 B
10 17371.466797 S 24951 Po
10 17371.468750 S 24951 B
10 17372.400391 S 0 B
10 17372.400391 S 24948 Po
10 17372.404297 S 24948 B
13 17372.414062 ntask sched 23.000000
10 17372.417969 S 24948 Fi
10 17372.419922 S 24948 B
10 17372.421875 S 24948 chol_model_11
10 17376.580078 S 64 B
10 17376.582031 S 24947 Po
10 17376.583984 S 24947 B
13 17376.591797 ntask sched 22.000000
10 17376.593750 S 24947 Fi
10 17376.593750 S 24947 B
10 17376.595703 S 24947 chol_model_22
10 17381.615234 S 0 B
10 17381.617188 S 24950 Po
10 17381.619141 S 24950 B
10 17388.445312 S 64 B
10 17388.447266 S 24947 Po
10 17388.449219 S 24947 B
13 17388.455078 ntask sched 21.000000
10 17388.457031 S 24947 Fi
10 17388.458984 S 24947 B
10 17388.460938 S 24947 chol_model_22
10 17391.740234 S 64 B
10 17391.740234 S 24947 Po
10 17391.742188 S 24947 B
13 17391.748047 ntask sched 20.000000
10 17391.750000 S 24947 Fi
10 17391.751953 S 24947 B
10 17391.751953 S 24947 chol_model_22
10 17395.029297 S 64 B
10 17395.031250 S 24947 Po
10 17395.033203 S 24947 B
13 17395.039062 ntask sched 19.000000
10 17395.039062 S 24947 Fi
10 17395.042969 S 24947 B
10 17395.042969 S 24947 chol_model_22
10 17398.324219 S 64 B
10 17398.324219 S 24947 Po
10 17398.326172 S 24947 B
13 17398.332031 ntask sched 18.000000
10 17398.335938 S 24947 Fi
10 17398.335938 S 24947 B
10 17398.337891 S 24947 chol_model_22
10 17401.615234 S 64 B
10 17401.617188 S 24947 Po
10 17401.619141 S 24947 B
13 17401.625000 ntask sched 17.000000
10 17401.626953 S 24947 Fi
10 17401.628906 S 24947 B
10 17401.628906 S 24947 chol_model_22
10 17404.902344 S 64 B
10 17404.904297 S 24947 Po
10 17404.904297 S 24947 B
13 17404.910156 ntask sched 16.000000
10 17404.912109 S 24947 Fi
10 17404.914062 S 24947 B
10 17404.914062 S 24947 chol_model_22
10 17408.183594 S 64 B
10 17408.183594 S 24947 Po
10 17408.185547 S 24947 B
13 17408.191406 ntask sched 15.000000
10 17408.193359 S 24947 Fi
10 17408.195312 S 24947 B
10 17408.195312 S 24947 chol_model_22
10 17411.462891 S 64 B
10 17411.464844 S 24947 Po
10 17411.466797 S 24947 B
13 17411.472656 ntask sched 14.000000
10 17411.472656 S 24947 Fi
10 17411.474609 S 24947 B
10 17411.476562 S 24947 chol_model_22
10 17414.751953 S 64 B
10 17414.753906 S 24947 Po
10 17414.753906 S 24947 B
13 17414.759766 ntask sched 13.000000
10 17414.761719 S 24947 Fi
10 17414.763672 S 24947 B
10 17414.763672 S 24947 chol_model_22
10 17418.033203 S 64 B
10 17418.035156 S 24947 Po
10 17418.037109 S 24947 B
13 17418.042969 ntask sched 12.000000
10 17418.044922 S 24947 Fi
10 17418.046875 S 24947 B
10 17418.046875 S 24947 chol_model_22
10 17421.318359 S 64 B
10 17421.318359 S 24947 Po
10 17421.320312 S 24947 B
13 17421.326172 ntask sched 11.000000
10 17421.328125 S 24947 Fi
10 17421.328125 S 24947 B
10 17421.330078 S 24947 chol_model_22
10 17424.601562 S 64 B
10 17424.603516 S 24947 Po
10 17424.603516 S 24947 B
13 17424.611328 ntask sched 10.000000
10 17424.611328 S 24947 Fi
10 17424.613281 S 24947 B
10 17424.613281 S 24947 chol_model_22
10 17427.886719 S 64 B
10 17427.886719 S 24947 Po
10 17427.888672 S 24947 B
13 17427.894531 ntask sched 9.000000
10 17427.894531 S 24947 Fi
10 17427.896484 S 24947 B
10 17427.896484 S 24947 chol_model_22
10 17431.171875 S 64 B
10 17431.171875 S 24947 Po
10 17431.173828 S 24947 B
13 17431.179688 ntask sched 8.000000
10 17431.181641 S 24947 Fi
10 17431.183594 S 24947 B
10 17431.183594 S 24947 chol_model_22
10 17434.458984 S 64 B
10 17434.460938 S 24947 Po
10 17434.462891 S 24947 B
13 17434.468750 ntask sched 7.000000
10 17434.470703 S 24947 Fi
10 17434.470703 S 24947 B
10 17434.472656 S 24947 chol_model_22
10 17437.748047 S 64 B
10 17437.748047 S 24947 Po
10 17437.751953 S 24947 B
13 17437.757812 ntask sched 6.000000
10 17437.757812 S 24947 Fi
10 17437.759766 S 24947 B
10 17437.761719 S 24947 chol_model_22
10 17439.248047 S 0 B
10 17439.251953 S 24948 Po
10 17439.251953 S 24948 B
13 17439.283203 ntask sched 7.000000
13 17439.300781 ntask sched 8.000000
13 17439.314453 ntask sched 9.000000
13 17439.330078 ntask sched 10.000000
10 17439.332031 MS MEMNODE0 Co
18 17439.332031 L p 4000000 MEMNODE1 com_253
13 17439.333984 ntask sched 9.000000
10 17439.335938 S 24949 Fi
10 17439.343750 MS MEMNODE0 CoA
13 17439.345703 ntask sched 10.000000
10 17439.349609 MS MEMNODE0 Co
18 17439.349609 L p 4000000 MEMNODE1 com_254
13 17439.361328 ntask sched 11.000000
10 17439.361328 MS MEMNODE0 Co
18 17439.361328 L p 4000000 MEMNODE1 com_255
13 17439.376953 ntask sched 12.000000
13 17439.390625 ntask sched 13.000000
10 17439.390625 MS MEMNODE0 Co
18 17439.390625 L p 4000000 MEMNODE1 com_256
13 17439.404297 ntask sched 14.000000
13 17439.419922 ntask sched 15.000000
13 17439.433594 ntask sched 16.000000
13 17439.437500 ntask sched 15.000000
10 17439.439453 S 24948 Fi
10 17441.039062 S 64 B
10 17441.041016 S 24947 Po
10 17441.042969 S 24947 B
10 17441.048828 MS MEMNODE1 Co
18 17441.048828 L p 4000000 MEMNODE0 com_257
10 17442.902344 MS MEMNODE0 No
19 17442.902344 L p 0 MEMNODE0 com_0
10 17442.908203 MS MEMNODE0 CoA
10 17442.917969 MS MEMNODE0 CoA
10 17442.925781 MS MEMNODE0 CoA
10 17444.919922 MS MEMNODE0 No
19 17444.919922 L p 1928086912 MEMNODE0 com_1928086720
13 17444.935547 ntask sched 14.000000
10 17444.937500 S 24951 Fi
10 17446.994141 MS MEMNODE0 No
19 17446.994141 L p 1928086912 MEMNODE0 com_1928086720
10 17447.001953 MS MEMNODE1 CoA
10 17449.021484 MS MEMNODE0 No
19 17449.021484 L p 1928086912 MEMNODE0 com_1928086720
13 17449.031250 ntask sched 13.000000
10 17449.033203 S 24950 Fi
10 17449.035156 MS MEMNODE0 No
19 17449.035156 L p 4000000 MEMNODE0 com_253
13 17449.078125 ntask sched 12.000000
10 17449.080078 S 24952 Fi
10 17450.244141 MS MEMNODE1 No
19 17450.244141 L p 1928086912 MEMNODE1 com_1928086720
10 17450.265625 MS MEMNODE0 No
19 17450.265625 L p 4000000 MEMNODE0 com_255
10 17450.275391 MS MEMNODE0 No
19 17450.275391 L p 4000000 MEMNODE0 com_254
13 17450.285156 ntask sched 11.000000
10 17450.287109 S 24947 Fi
10 17450.287109 S 24950 B
10 17450.287109 S 24951 B
10 17450.289062 S 24950 chol_model_21
10 17450.289062 S 24947 B
10 17450.289062 S 24951 chol_model_21
10 17450.289062 S 24947 chol_model_22
10 17450.289062 S 24949 B
10 17450.291016 S 24949 chol_model_21
10 17450.292969 S 24948 B
10 17450.292969 S 24948 chol_model_21
10 17450.451172 MS MEMNODE0 No
19 17450.451172 L p 4000000 MEMNODE0 com_256
10 17450.453125 S 24952 B
10 17450.453125 S 24952 chol_model_21
10 17453.675781 S 64 B
10 17453.677734 S 24947 Po
10 17453.679688 S 24947 B
10 17453.710938 MS MEMNODE1 No
19 17453.710938 L p 4000000 MEMNODE1 com_257
13 17453.712891 ntask sched 10.000000
10 17453.714844 S 24947 Fi
10 17453.714844 S 24947 B
10 17453.716797 S 24947 chol_model_22
10 17456.992188 S 64 B
10 17456.992188 S 24947 Po
10 17456.994141 S 24947 B
13 17457.001953 ntask sched 9.000000
10 17457.001953 S 24947 Fi
10 17457.003906 S 24947 B
10 17457.003906 S 24947 chol_model_22
10 17460.287109 S 64 B
10 17460.287109 S 24947 Po
10 17460.289062 S 24947 B
13 17460.296875 ntask sched 8.000000
10 17460.298828 S 24947 Fi
10 17460.300781 S 24947 B
10 17460.300781 S 24947 chol_model_22
10 17463.580078 S 64 B
10 17463.580078 S 24947 Po
10 17463.582031 S 24947 B
13 17463.589844 ntask sched 7.000000
10 17463.589844 S 24947 Fi
10 17463.591797 S 24947 B
10 17463.593750 S 24947 chol_model_22
10 17466.861328 S 64 B
10 17466.861328 S 24947 Po
10 17466.863281 S 24947 B
13 17466.869141 ntask sched 6.000000
10 17466.871094 S 24947 Fi
10 17466.871094 S 24947 B
10 17466.871094 S 24947 chol_model_22
10 17470.146484 S 64 B
10 17470.148438 S 24947 Po
10 17470.148438 S 24947 B
13 17470.154297 ntask sched 5.000000
10 17470.156250 S 24947 Fi
10 17470.158203 S 24947 B
10 17470.158203 S 24947 chol_model_21
10 17478.474609 S 64 B
10 17478.476562 S 24947 Po
10 17478.478516 S 24947 B
13 17478.500000 ntask sched 6.000000
13 17478.505859 ntask sched 5.000000
10 17478.507812 S 24947 Fi
10 17478.509766 S 24947 B
10 17478.509766 S 24947 chol_model_21
10 17486.828125 S 64 B
10 17486.828125 S 24947 Po
10 17486.830078 S 24947 B
13 17486.847656 ntask sched 6.000000
13 17486.859375 ntask sched 7.000000
13 17486.863281 ntask sched 6.000000
10 17486.865234 S 24947 Fi
10 17486.867188 S 24947 B
10 17486.867188 S 24947 chol_model_21
10 17495.185547 S 64 B
10 17495.185547 S 24947 Po
10 17495.187500 S 24947 B
13 17495.205078 ntask sched 7.000000
13 17495.220703 ntask sched 8.000000
13 17495.232422 ntask sched 9.000000
13 17495.238281 ntask sched 8.000000
10 17495.238281 S 24947 Fi
10 17495.240234 S 24947 B
10 17495.240234 S 24947 chol_model_21
10 17498.441406 S 0 B
10 17498.443359 S 24951 Po
10 17498.445312 S 24951 B
13 17498.468750 ntask sched 9.000000
13 17498.482422 ntask sched 10.000000
13 17498.496094 ntask sched 11.000000
10 17498.501953 S 0 B
10 17498.503906 S 24952 Po
10 17498.505859 S 24952 B
13 17498.511719 ntask sched 12.000000
13 17498.525391 ntask sched 13.000000
13 17498.539062 ntask sched 14.000000
13 17498.554688 ntask sched 15.000000
13 17498.568359 ntask sched 16.000000
13 17498.582031 ntask sched 17.000000
10 17498.642578 S 0 B
10 17498.644531 S 24949 Po
10 17498.650391 S 24949 B
13 17498.689453 ntask sched 18.000000
13 17498.707031 ntask sched 19.000000
13 17498.724609 ntask sched 20.000000
13 17498.738281 ntask sched 21.000000
13 17498.755859 ntask sched 22.000000
13 17498.773438 ntask sched 23.000000
10 17498.775391 MS MEMNODE0 Co
18 17498.775391 L p 4000000 MEMNODE1 com_258
10 17498.783203 MS MEMNODE0 CoA
10 17498.826172 S 0 B
10 17498.828125 S 24948 Po
10 17498.830078 S 24948 B
10 17498.847656 S 0 B
10 17498.849609 S 24950 Po
10 17498.851562 S 24950 B
13 17498.853516 ntask sched 24.000000
10 17498.855469 MS MEMNODE0 Co
18 17498.855469 L p 4000000 MEMNODE1 com_259
10 17498.873047 MS MEMNODE0 Co
18 17498.873047 L p 4000000 MEMNODE1 com_260
13 17498.873047 ntask sched 25.000000
10 17498.875000 MS MEMNODE0 Co
18 17498.875000 L p 4000000 MEMNODE1 com_261
13 17498.890625 ntask sched 26.000000
13 17498.904297 ntask sched 27.000000
13 17498.919922 ntask sched 28.000000
13 17498.933594 ntask sched 29.000000
13 17498.949219 ntask sched 30.000000
10 17498.953125 MS MEMNODE0 Co
18 17498.953125 L p 4000000 MEMNODE1 com_262
10 17503.550781 S 64 B
10 17503.550781 S 24947 Po
10 17503.552734 S 24947 B
10 17503.558594 MS MEMNODE1 Co
18 17503.558594 L p 4000000 MEMNODE0 com_263
10 17504.845703 MS MEMNODE0 No
19 17504.845703 L p 0 MEMNODE0 com_0
10 17504.855469 MS MEMNODE0 CoA
10 17504.863281 MS MEMNODE0 CoA
10 17506.248047 MS MEMNODE0 No
19 17506.248047 L p 1928086912 MEMNODE0 com_1928086720
10 17506.255859 MS MEMNODE0 CoA
10 17506.265625 MS MEMNODE1 CoA
13 17506.279297 ntask sched 29.000000
10 17506.283203 S 24951 Fi
10 17506.289062 MS MEMNODE0 CoA
10 17508.298828 MS MEMNODE0 No
19 17508.298828 L p 1928086912 MEMNODE0 com_1928086720
10 17508.306641 MS MEMNODE0 Co
18 17508.306641 L p 4000000 MEMNODE1 com_264
10 17509.740234 MS MEMNODE0 No
19 17509.740234 L p 0 MEMNODE0 com_0
10 17509.748047 MS MEMNODE0 Co
18 17509.748047 L p 4000000 MEMNODE1 com_265
10 17511.136719 MS MEMNODE0 No
19 17511.136719 L p 0 MEMNODE0 com_0
10 17511.146484 MS MEMNODE0 No
19 17511.146484 L p 4000000 MEMNODE0 com_258
13 17511.158203 ntask sched 28.000000
10 17511.162109 S 24952 Fi
10 17511.166016 MS MEMNODE0 CoA
10 17512.283203 MS MEMNODE1 No
19 17512.283203 L p 1928086912 MEMNODE1 com_1928086720
10 17512.291016 MS MEMNODE0 CoA
10 17512.312500 MS MEMNODE0 No
19 17512.312500 L p 4000000 MEMNODE0 com_262
10 17513.937500 MS MEMNODE0 No
19 17513.937500 L p 0 MEMNODE0 com_0
13 17513.947266 ntask sched 27.000000
10 17513.949219 S 24949 Fi
10 17513.960938 MS MEMNODE1 Co
18 17513.960938 L p 4000000 MEMNODE0 com_266
10 17515.472656 MS MEMNODE0 No
19 17515.472656 L p 0 MEMNODE0 com_0
10 17515.480469 MS MEMNODE0 Co
18 17515.480469 L p 4000000 MEMNODE1 com_267
10 17515.486328 MS MEMNODE0 No
19 17515.486328 L p 4000000 MEMNODE0 com_261
10 17515.494141 MS MEMNODE0 No
19 17515.494141 L p 4000000 MEMNODE0 com_260
10 17515.503906 MS MEMNODE1 CoA
10 17515.509766 MS MEMNODE0 No
19 17515.509766 L p 4000000 MEMNODE0 com_264
10 17516.642578 MS MEMNODE1 No
19 17516.642578 L p 0 MEMNODE1 com_0
10 17516.650391 MS MEMNODE0 CoA
10 17516.658203 MS MEMNODE0 No
19 17516.658203 L p 4000000 MEMNODE0 com_259
10 17516.660156 S 24949 B
10 17516.660156 S 24949 chol_model_22
10 17516.664062 MS MEMNODE0 No
19 17516.664062 L p 4000000 MEMNODE0 com_265
10 17516.667969 S 24951 B
10 17516.669922 S 24951 chol_model_22
13 17516.669922 ntask sched 28.000000
10 17516.673828 MS MEMNODE1 Co
18 17516.673828 L p 4000000 MEMNODE0 com_268
13 17516.687500 ntask sched 29.000000
13 17516.703125 ntask sched 30.000000
13 17516.716797 ntask sched 31.000000
13 17516.730469 ntask sched 32.000000
13 17516.744141 ntask sched 33.000000
13 17516.757812 ntask sched 34.000000
10 17518.296875 MS MEMNODE0 No
19 17518.296875 L p 1928086912 MEMNODE0 com_1928086720
10 17518.304688 MS MEMNODE1 CoA
10 17519.427734 MS MEMNODE1 No
19 17519.427734 L p 1928086912 MEMNODE1 com_1928086720
13 17519.441406 ntask sched 33.000000
10 17519.443359 S 24948 Fi
10 17519.445312 MS MEMNODE1 Co
18 17519.445312 L p 4000000 MEMNODE0 com_269
10 17519.449219 S 24948 B
10 17519.451172 S 24948 chol_model_22
10 17519.451172 MS MEMNODE1 CoA
13 17519.460938 ntask sched 34.000000
13 17519.468750 ntask sched 33.000000
10 17519.470703 S 24950 Fi
10 17519.472656 S 24950 B
10 17519.472656 S 24950 chol_model_22
10 17520.623047 MS MEMNODE1 No
19 17520.623047 L p 1928086912 MEMNODE1 com_1928086720
10 17520.628906 MS MEMNODE0 No
19 17520.628906 L p 4000000 MEMNODE0 com_267
10 17520.630859 MS MEMNODE1 Co
18 17520.630859 L p 4000000 MEMNODE0 com_270
10 17520.640625 MS MEMNODE1 CoA
10 17521.824219 MS MEMNODE1 No
19 17521.824219 L p 1928086912 MEMNODE1 com_1928086720
10 17521.828125 MS MEMNODE1 Co
18 17521.828125 L p 4000000 MEMNODE0 com_271
10 17521.853516 MS MEMNODE1 CoA
10 17523.066406 MS MEMNODE1 No
19 17523.066406 L p 1928086912 MEMNODE1 com_1928086720
10 17523.072266 S 24952 B
10 17523.074219 S 24952 chol_model_22
13 17523.093750 ntask sched 34.000000
13 17523.107422 ntask sched 35.000000
13 17523.119141 ntask sched 36.000000
13 17523.132812 ntask sched 37.000000
13 17523.144531 ntask sched 38.000000
13 17523.156250 ntask sched 39.000000
13 17523.169922 ntask sched 40.000000
13 17523.181641 ntask sched 41.000000
13 17523.193359 ntask sched 42.000000
10 17523.234375 MS MEMNODE1 No
19 17523.234375 L p 4000000 MEMNODE1 com_270
10 17523.257812 MS MEMNODE1 No
19 17523.257812 L p 4000000 MEMNODE1 com_269
10 17523.281250 MS MEMNODE1 No
19 17523.281250 L p 4000000 MEMNODE1 com_268
10 17523.304688 MS MEMNODE1 No
19 17523.304688 L p 4000000 MEMNODE1 com_266
10 17523.328125 MS MEMNODE1 No
19 17523.328125 L p 4000000 MEMNODE1 com_263
10 17523.330078 MS MEMNODE1 Co
18 17523.330078 L p 4000000 MEMNODE0 com_272
10 17523.333984 MS MEMNODE1 CoA
10 17524.519531 MS MEMNODE1 No
19 17524.519531 L p 1928086912 MEMNODE1 com_1928086720
10 17524.525391 MS MEMNODE1 Co
18 17524.525391 L p 4000000 MEMNODE0 com_273
10 17524.529297 MS MEMNODE1 CoA
10 17525.685547 MS MEMNODE1 No
19 17525.685547 L p 1928086912 MEMNODE1 com_1928086720
10 17525.689453 MS MEMNODE1 Co
18 17525.689453 L p 4000000 MEMNODE0 com_274
10 17525.693359 MS MEMNODE1 CoA
10 17526.849609 MS MEMNODE1 No
19 17526.849609 L p 1928086912 MEMNODE1 com_1928086720
10 17526.853516 MS MEMNODE1 Co
18 17526.853516 L p 4000000 MEMNODE0 com_275
10 17526.857422 MS MEMNODE1 CoA
10 17528.023438 MS MEMNODE1 No
19 17528.023438 L p 1928086912 MEMNODE1 com_1928086720
10 17528.027344 MS MEMNODE1 Co
18 17528.027344 L p 4000000 MEMNODE0 com_276
10 17528.031250 MS MEMNODE1 CoA
10 17529.195312 MS MEMNODE1 No
19 17529.195312 L p 1928086912 MEMNODE1 com_1928086720
10 17529.199219 MS MEMNODE1 Co
18 17529.199219 L p 4000000 MEMNODE0 com_277
10 17529.224609 MS MEMNODE1 CoA
10 17530.386719 MS MEMNODE1 No
19 17530.386719 L p 1928086912 MEMNODE1 com_1928086720
10 17530.390625 MS MEMNODE1 Co
18 17530.390625 L p 4000000 MEMNODE0 com_278
10 17530.404297 MS MEMNODE1 CoA
10 17531.566406 MS MEMNODE1 No
19 17531.566406 L p 1928086912 MEMNODE1 com_1928086720
13 17531.574219 ntask sched 41.000000
10 17531.578125 S 24947 Fi
10 17531.580078 S 24947 B
10 17531.582031 S 24947 chol_model_21
10 17539.929688 S 64 B
10 17539.931641 S 24947 Po
10 17539.933594 S 24947 B
13 17539.957031 ntask sched 42.000000
13 17539.970703 ntask sched 43.000000
13 17539.982422 ntask sched 44.000000
13 17539.994141 ntask sched 45.000000
13 17540.005859 ntask sched 46.000000
13 17540.015625 ntask sched 47.000000
13 17540.027344 ntask sched 48.000000
13 17540.037109 ntask sched 49.000000
13 17540.048828 ntask sched 50.000000
13 17540.060547 ntask sched 51.000000
10 17540.093750 MS MEMNODE1 No
19 17540.093750 L p 4000000 MEMNODE1 com_278
10 17540.097656 MS MEMNODE1 No
19 17540.097656 L p 4000000 MEMNODE1 com_277
10 17540.099609 MS MEMNODE1 No
19 17540.099609 L p 4000000 MEMNODE1 com_276
10 17540.101562 MS MEMNODE1 No
19 17540.101562 L p 4000000 MEMNODE1 com_275
10 17540.103516 MS MEMNODE1 No
19 17540.103516 L p 4000000 MEMNODE1 com_274
10 17540.105469 MS MEMNODE1 No
19 17540.105469 L p 4000000 MEMNODE1 com_273
10 17540.109375 MS MEMNODE1 No
19 17540.109375 L p 4000000 MEMNODE1 com_272
10 17540.111328 MS MEMNODE1 No
19 17540.111328 L p 4000000 MEMNODE1 com_271
13 17540.113281 ntask sched 50.000000
10 17540.113281 S 24947 Fi
10 17540.115234 S 24947 B
10 17540.115234 S 24947 chol_model_21
10 17548.439453 S 64 B
10 17548.439453 S 24947 Po
10 17548.441406 S 24947 B
13 17548.464844 ntask sched 51.000000
13 17548.476562 ntask sched 52.000000
13 17548.488281 ntask sched 53.000000
13 17548.498047 ntask sched 54.000000
13 17548.509766 ntask sched 55.000000
13 17548.519531 ntask sched 56.000000
13 17548.531250 ntask sched 57.000000
13 17548.541016 ntask sched 58.000000
13 17548.552734 ntask sched 59.000000
13 17548.562500 ntask sched 60.000000
13 17548.574219 ntask sched 61.000000
13 17548.578125 ntask sched 60.000000
10 17548.580078 S 24947 Fi
10 17548.580078 S 24947 B
10 17548.582031 S 24947 chol_model_22
10 17551.880859 S 64 B
10 17551.880859 S 24947 Po
10 17551.882812 S 24947 B
13 17551.898438 ntask sched 61.000000
13 17551.902344 ntask sched 60.000000
10 17551.904297 S 24947 Fi
10 17551.904297 S 24947 B
10 17551.906250 S 24947 chol_model_22
10 17555.181641 S 64 B
10 17555.183594 S 24947 Po
10 17555.183594 S 24947 B
13 17555.191406 ntask sched 59.000000
10 17555.191406 S 24947 Fi
10 17555.193359 S 24947 B
10 17555.193359 S 24947 chol_model_22
10 17558.466797 S 64 B
10 17558.466797 S 24947 Po
10 17558.468750 S 24947 B
13 17558.474609 ntask sched 58.000000
10 17558.476562 S 24947 Fi
10 17558.478516 S 24947 B
10 17558.478516 S 24947 chol_model_22
10 17561.763672 S 64 B
10 17561.765625 S 24947 Po
10 17561.767578 S 24947 B
13 17561.773438 ntask sched 57.000000
10 17561.775391 S 24947 Fi
10 17561.775391 S 24947 B
10 17561.777344 S 24947 chol_model_22
10 17565.058594 S 64 B
10 17565.060547 S 24947 Po
10 17565.060547 S 24947 B
13 17565.068359 ntask sched 56.000000
10 17565.070312 S 24947 Fi
10 17565.070312 S 24947 B
10 17565.072266 S 24947 chol_model_22
10 17568.347656 S 64 B
10 17568.349609 S 24947 Po
10 17568.351562 S 24947 B
13 17568.357422 ntask sched 55.000000
10 17568.357422 S 24947 Fi
10 17568.359375 S 24947 B
10 17568.361328 S 24947 chol_model_22
10 17571.644531 S 64 B
10 17571.646484 S 24947 Po
10 17571.648438 S 24947 B
13 17571.654297 ntask sched 54.000000
10 17571.656250 S 24947 Fi
10 17571.658203 S 24947 B
10 17571.658203 S 24947 chol_model_22
10 17574.939453 S 64 B
10 17574.939453 S 24947 Po
10 17574.941406 S 24947 B
13 17574.947266 ntask sched 53.000000
10 17574.949219 S 24947 Fi
10 17574.949219 S 24947 B
10 17574.951172 S 24947 chol_model_22
10 17578.230469 S 64 B
10 17578.232422 S 24947 Po
10 17578.232422 S 24947 B
13 17578.238281 ntask sched 52.000000
10 17578.240234 S 24947 Fi
10 17578.242188 S 24947 B
10 17578.242188 S 24947 chol_model_22
10 17581.517578 S 64 B
10 17581.517578 S 24947 Po
10 17581.519531 S 24947 B
13 17581.525391 ntask sched 51.000000
10 17581.527344 S 24947 Fi
10 17581.527344 S 24947 B
10 17581.529297 S 24947 chol_model_22
10 17584.816406 S 64 B
10 17584.816406 S 24947 Po
10 17584.818359 S 24947 B
13 17584.824219 ntask sched 50.000000
10 17584.826172 S 24947 Fi
10 17584.826172 S 24947 B
10 17584.828125 S 24947 chol_model_22
10 17588.115234 S 64 B
10 17588.115234 S 24947 Po
10 17588.117188 S 24947 B
13 17588.125000 ntask sched 49.000000
10 17588.126953 S 24947 Fi
10 17588.126953 S 24947 B
10 17588.128906 S 24947 chol_model_22
10 17591.402344 S 64 B
10 17591.402344 S 24947 Po
10 17591.404297 S 24947 B
13 17591.410156 ntask sched 48.000000
10 17591.412109 S 24947 Fi
10 17591.412109 S 24947 B
10 17591.414062 S 24947 chol_model_22
10 17594.689453 S 64 B
10 17594.691406 S 24947 Po
10 17594.693359 S 24947 B
13 17594.699219 ntask sched 47.000000
10 17594.701172 S 24947 Fi
10 17594.701172 S 24947 B
10 17594.703125 S 24947 chol_model_22
10 17597.978516 S 64 B
10 17597.980469 S 24947 Po
10 17597.982422 S 24947 B
13 17597.988281 ntask sched 46.000000
10 17597.988281 S 24947 Fi
10 17597.990234 S 24947 B
10 17597.990234 S 24947 chol_model_22
10 17601.265625 S 64 B
10 17601.267578 S 24947 Po
10 17601.269531 S 24947 B
13 17601.275391 ntask sched 45.000000
10 17601.277344 S 24947 Fi
10 17601.277344 S 24947 B
10 17601.279297 S 24947 chol_model_22
10 17604.552734 S 64 B
10 17604.554688 S 24947 Po
10 17604.554688 S 24947 B
13 17604.562500 ntask sched 44.000000
10 17604.562500 S 24947 Fi
10 17604.564453 S 24947 B
10 17604.564453 S 24947 chol_model_22
10 17607.835938 S 0 B
10 17607.835938 S 24951 Po
10 17607.837891 S 64 B
10 17607.837891 S 24951 B
10 17607.839844 S 24947 Po
10 17607.839844 S 24947 B
13 17607.849609 ntask sched 43.000000
10 17607.849609 S 24947 Fi
10 17607.851562 MS MEMNODE0 Co
18 17607.851562 L p 4000000 MEMNODE1 com_279
10 17607.851562 S 24947 B
10 17607.851562 S 24947 chol_model_22
10 17607.863281 MS MEMNODE0 CoA
10 17607.935547 S 0 B
10 17607.937500 S 24949 Po
10 17607.941406 S 24949 B
13 17607.957031 ntask sched 42.000000
10 17607.960938 S 24949 Fi
10 17610.947266 S 0 B
10 17610.949219 S 24948 Po
10 17610.951172 S 24948 B
13 17610.966797 ntask sched 41.000000
10 17610.968750 S 24948 Fi
10 17611.023438 S 0 B
10 17611.025391 S 24950 Po
10 17611.027344 S 24950 B
13 17611.035156 ntask sched 40.000000
10 17611.035156 S 24950 Fi
10 17611.148438 S 64 B
10 17611.148438 S 24947 Po
10 17611.150391 S 24947 B
13 17611.158203 ntask sched 39.000000
10 17611.158203 S 24947 Fi
10 17611.160156 S 24947 B
10 17611.162109 S 24947 chol_model_22
10 17612.472656 MS MEMNODE0 No
19 17612.472656 L p 1928086912 MEMNODE0 com_1928086720
10 17612.488281 MS MEMNODE0 Co
18 17612.488281 L p 4000000 MEMNODE1 com_280
10 17612.560547 MS MEMNODE0 CoA
10 17612.566406 MS MEMNODE0 No
19 17612.566406 L p 4000000 MEMNODE0 com_279
10 17612.568359 S 24949 B
10 17612.570312 S 24949 chol_model_22
10 17613.892578 S 0 B
10 17613.894531 S 24952 Po
10 17613.896484 S 24952 B
13 17613.912109 ntask sched 38.000000
10 17613.914062 S 24952 Fi
10 17615.822266 S 64 B
10 17615.822266 S 24947 Po
10 17615.824219 S 24947 B
13 17615.830078 ntask sched 37.000000
10 17615.832031 S 24947 Fi
10 17615.833984 S 24947 B
10 17615.835938 S 24947 chol_model_22
10 17617.152344 MS MEMNODE0 No
19 17617.152344 L p 1928086912 MEMNODE0 com_1928086720
10 17617.193359 MS MEMNODE0 Co
18 17617.193359 L p 4000000 MEMNODE1 com_281
10 17617.201172 MS MEMNODE0 CoA
10 17620.443359 S 64 B
10 17620.443359 S 24947 Po
10 17620.445312 S 24947 B
13 17620.453125 ntask sched 36.000000
10 17620.455078 S 24947 Fi
10 17620.455078 S 24947 B
10 17620.457031 S 24947 chol_model_22
10 17621.751953 MS MEMNODE0 No
19 17621.751953 L p 1928086912 MEMNODE0 com_1928086720
10 17621.779297 MS MEMNODE0 No
19 17621.779297 L p 4000000 MEMNODE0 com_280
10 17621.785156 MS MEMNODE0 Co
18 17621.785156 L p 4000000 MEMNODE1 com_282
10 17621.792969 MS MEMNODE0 CoA
10 17625.035156 S 64 B
10 17625.037109 S 24947 Po
10 17625.037109 S 24947 B
13 17625.046875 ntask sched 35.000000
10 17625.046875 S 24947 Fi
10 17625.048828 S 24947 B
10 17625.050781 S 24947 chol_model_22
10 17626.328125 MS MEMNODE0 No
19 17626.328125 L p 1928086912 MEMNODE0 com_1928086720
10 17626.349609 MS MEMNODE0 No
19 17626.349609 L p 4000000 MEMNODE0 com_281
10 17626.351562 S 24952 B
10 17626.353516 S 24952 chol_model_22
10 17626.355469 MS MEMNODE0 Co
18 17626.355469 L p 4000000 MEMNODE1 com_283
10 17626.396484 MS MEMNODE0 CoA
10 17626.402344 MS MEMNODE0 No
19 17626.402344 L p 4000000 MEMNODE0 com_282
10 17626.404297 S 24948 B
10 17626.408203 S 24948 chol_model_22
10 17629.658203 S 64 B
10 17629.660156 S 24947 Po
10 17629.662109 S 24947 B
13 17629.669922 ntask sched 34.000000
10 17629.671875 S 24947 Fi
10 17629.673828 S 24947 B
10 17629.673828 S 24947 chol_model_22
10 17630.974609 MS MEMNODE0 No
19 17630.974609 L p 1928086912 MEMNODE0 com_1928086720
10 17630.990234 MS MEMNODE0 Co
18 17630.990234 L p 4000000 MEMNODE1 com_284
10 17631.052734 MS MEMNODE0 CoA
10 17631.060547 MS MEMNODE0 No
19 17631.060547 L p 4000000 MEMNODE0 com_283
10 17634.294922 S 64 B
10 17634.296875 S 24947 Po
10 17634.298828 S 24947 B
13 17634.306641 ntask sched 33.000000
10 17634.306641 S 24947 Fi
10 17634.308594 S 24947 B
10 17634.310547 S 24947 chol_model_22
10 17635.609375 MS MEMNODE0 No
19 17635.609375 L p 1928086912 MEMNODE0 com_1928086720
10 17635.621094 MS MEMNODE0 Co
18 17635.621094 L p 4000000 MEMNODE1 com_285
10 17635.673828 MS MEMNODE0 CoA
10 17635.683594 MS MEMNODE0 No
19 17635.683594 L p 4000000 MEMNODE0 com_284
10 17635.685547 S 24950 B
10 17635.687500 S 24950 chol_model_22
10 17638.929688 S 64 B
10 17638.929688 S 24947 Po
10 17638.931641 S 24947 B
13 17638.939453 ntask sched 32.000000
10 17638.939453 S 24947 Fi
10 17638.941406 S 24947 B
10 17638.941406 S 24947 chol_model_22
10 17640.845703 MS MEMNODE0 No
19 17640.845703 L p 1928086912 MEMNODE0 com_1928086720
13 17640.861328 ntask sched 31.000000
10 17640.863281 S 24951 Fi
10 17640.865234 S 24951 B
10 17640.867188 S 24951 chol_model_22
10 17644.134766 S 64 B
10 17644.134766 S 24947 Po
10 17644.136719 S 24947 B
13 17644.144531 ntask sched 30.000000
10 17644.144531 S 24947 Fi
10 17644.146484 S 24947 B
10 17644.148438 S 24947 chol_model_22
10 17647.437500 S 64 B
10 17647.439453 S 24947 Po
10 17647.439453 S 24947 B
13 17647.445312 ntask sched 29.000000
10 17647.447266 S 24947 Fi
10 17647.449219 S 24947 B
10 17647.449219 S 24947 chol_model_22
10 17650.732422 S 64 B
10 17650.732422 S 24947 Po
10 17650.734375 S 24947 B
13 17650.742188 ntask sched 28.000000
10 17650.742188 S 24947 Fi
10 17650.744141 S 24947 B
10 17650.744141 S 24947 chol_model_22
10 17654.015625 S 64 B
10 17654.017578 S 24947 Po
10 17654.017578 S 24947 B
13 17654.023438 ntask sched 27.000000
10 17654.025391 S 24947 Fi
10 17654.027344 S 24947 B
10 17654.027344 S 24947 chol_model_22
10 17657.300781 S 64 B
10 17657.300781 S 24947 Po
10 17657.302734 S 24947 B
13 17657.308594 ntask sched 26.000000
10 17657.310547 S 24947 Fi
10 17657.312500 S 24947 B
10 17657.312500 S 24947 chol_model_22
10 17660.585938 S 64 B
10 17660.587891 S 24947 Po
10 17660.587891 S 24947 B
13 17660.595703 ntask sched 25.000000
10 17660.595703 S 24947 Fi
10 17660.597656 S 24947 B
10 17660.599609 S 24947 chol_model_22
10 17663.871094 S 64 B
10 17663.873047 S 24947 Po
10 17663.875000 S 24947 B
13 17663.880859 ntask sched 24.000000
10 17663.882812 S 24947 Fi
10 17663.884766 S 24947 B
10 17663.884766 S 24947 chol_model_22
10 17667.160156 S 64 B
10 17667.160156 S 24947 Po
10 17667.162109 S 24947 B
13 17667.169922 ntask sched 23.000000
10 17667.171875 S 24947 Fi
10 17667.173828 S 24947 B
10 17667.173828 S 24947 chol_model_22
10 17670.455078 S 64 B
10 17670.457031 S 24947 Po
10 17670.458984 S 24947 B
13 17670.464844 ntask sched 22.000000
10 17670.466797 S 24947 Fi
10 17670.468750 S 24947 B
10 17670.468750 S 24947 chol_model_22
10 17673.736328 S 64 B
10 17673.738281 S 24947 Po
10 17673.740234 S 24947 B
13 17673.746094 ntask sched 21.000000
10 17673.748047 S 24947 Fi
10 17673.750000 S 24947 B
10 17673.751953 S 24947 chol_model_22
10 17677.031250 S 64 B
10 17677.031250 S 24947 Po
10 17677.033203 S 24947 B
13 17677.039062 ntask sched 20.000000
10 17677.041016 S 24947 Fi
10 17677.042969 S 24947 B
10 17677.042969 S 24947 chol_model_22
10 17680.320312 S 64 B
10 17680.320312 S 24947 Po
10 17680.322266 S 24947 B
13 17680.328125 ntask sched 19.000000
10 17680.330078 S 24947 Fi
10 17680.330078 S 24947 B
10 17680.332031 S 24947 chol_model_22
10 17683.609375 S 64 B
10 17683.611328 S 24947 Po
10 17683.613281 S 24947 B
13 17683.619141 ntask sched 18.000000
10 17683.621094 S 24947 Fi
10 17683.621094 S 24947 B
10 17683.623047 S 24947 chol_model_22
10 17686.900391 S 64 B
10 17686.900391 S 24947 Po
10 17686.902344 S 24947 B
13 17686.908203 ntask sched 17.000000
10 17686.910156 S 24947 Fi
10 17686.910156 S 24947 B
10 17686.912109 S 24947 chol_model_22
10 17690.185547 S 64 B
10 17690.185547 S 24947 Po
10 17690.187500 S 24947 B
13 17690.195312 ntask sched 16.000000
10 17690.195312 S 24947 Fi
10 17690.197266 S 24947 B
10 17690.199219 S 24947 chol_model_22
10 17693.478516 S 64 B
10 17693.480469 S 24947 Po
10 17693.480469 S 24947 B
13 17693.486328 ntask sched 15.000000
10 17693.488281 S 24947 Fi
10 17693.490234 S 24947 B
10 17693.490234 S 24947 chol_model_22
10 17696.771484 S 64 B
10 17696.773438 S 24947 Po
10 17696.775391 S 24947 B
13 17696.781250 ntask sched 14.000000
10 17696.783203 S 24947 Fi
10 17696.785156 S 24947 B
10 17696.785156 S 24947 chol_model_22
10 17700.066406 S 64 B
10 17700.066406 S 24947 Po
10 17700.068359 S 24947 B
13 17700.074219 ntask sched 13.000000
10 17700.076172 S 24947 Fi
10 17700.076172 S 24947 B
10 17700.078125 S 24947 chol_model_22
10 17703.355469 S 64 B
10 17703.357422 S 24947 Po
10 17703.357422 S 24947 B
13 17703.365234 ntask sched 12.000000
10 17703.365234 S 24947 Fi
10 17703.367188 S 24947 B
10 17703.367188 S 24947 chol_model_22
10 17704.037109 S 0 B
10 17704.039062 S 24949 Po
10 17704.044922 S 24949 B
10 17704.128906 MS MEMNODE0 No
19 17704.128906 L p 4000000 MEMNODE0 com_285
10 17706.642578 S 64 B
10 17706.644531 S 24947 Po
10 17706.646484 S 24947 B
13 17706.652344 ntask sched 11.000000
10 17706.654297 S 24947 Fi
10 17706.656250 S 24947 B
10 17706.656250 S 24947 chol_model_22
10 17709.927734 S 64 B
10 17709.929688 S 24947 Po
10 17709.931641 S 24947 B
13 17709.937500 ntask sched 10.000000
10 17709.939453 S 24947 Fi
10 17709.939453 S 24947 B
10 17709.941406 S 24947 chol_model_22
10 17713.218750 S 64 B
10 17713.218750 S 24947 Po
10 17713.220703 S 24947 B
13 17713.228516 ntask sched 9.000000
10 17713.230469 S 24947 Fi
10 17713.232422 S 24947 B
10 17713.232422 S 24947 chol_model_22
10 17716.505859 S 64 B
10 17716.505859 S 24947 Po
10 17716.507812 S 24947 B
13 17716.513672 ntask sched 8.000000
10 17716.515625 S 24947 Fi
10 17716.517578 S 24947 B
10 17716.517578 S 24947 chol_model_22
10 17716.771484 S 0 B
10 17716.771484 S 24952 Po
10 17716.773438 S 24952 B
10 17717.386719 S 0 B
10 17717.388672 S 24948 Po
10 17717.392578 S 24948 B
10 17719.794922 S 64 B
10 17719.796875 S 24947 Po
10 17719.798828 S 24947 B
13 17719.804688 ntask sched 7.000000
10 17719.806641 S 24947 Fi
10 17719.808594 S 24947 B
10 17719.808594 S 24947 chol_model_22
10 17723.080078 S 64 B
10 17723.082031 S 24947 Po
10 17723.083984 S 24947 B
13 17723.089844 ntask sched 6.000000
10 17723.091797 S 24947 Fi
10 17723.093750 S 24947 B
10 17723.093750 S 24947 chol_model_22
10 17726.376953 S 64 B
10 17726.376953 S 24947 Po
10 17726.378906 S 24947 B
13 17726.384766 ntask sched 5.000000
10 17726.386719 S 24947 Fi
10 17726.388672 S 24947 B
10 17726.388672 S 24947 chol_model_22
10 17727.292969 S 0 B
10 17727.292969 S 24950 Po
10 17727.294922 S 24950 B
10 17729.664062 S 64 B
10 17729.664062 S 24947 Po
10 17729.666016 S 24947 B
13 17729.673828 ntask sched 4.000000
10 17729.675781 S 24947 Fi
10 17729.677734 S 24947 B
10 17729.677734 S 24947 chol_model_22
10 17731.398438 S 0 B
10 17731.400391 S 24951 Po
10 17731.402344 S 24951 B
13 17731.408203 ntask sched 3.000000
10 17731.410156 S 24951 Fi
10 17731.410156 S 24951 B
10 17731.412109 S 24951 chol_model_11
10 17732.955078 S 64 B
10 17732.955078 S 24947 Po
10 17732.957031 S 24947 B
13 17732.962891 ntask sched 2.000000
10 17732.964844 S 24947 Fi
10 17732.966797 S 24947 B
10 17732.966797 S 24947 chol_model_22
10 17736.244141 S 64 B
10 17736.244141 S 24947 Po
10 17736.246094 S 24947 B
13 17736.253906 ntask sched 1.000000
10 17736.253906 S 24947 Fi
10 17736.255859 S 24947 B
10 17736.255859 S 24947 chol_model_22
10 17739.523438 S 64 B
10 17739.523438 S 24947 Po
10 17739.525391 S 24947 B
13 17739.531250 ntask sched 0.000000
10 17739.531250 S 24947 Fi
10 17739.533203 S 24947 B
10 17739.533203 S 24947 chol_model_22
10 17742.814453 S 64 B
10 17742.814453 S 24947 Po
10 17742.816406 S 24947 B
10 17797.173828 S 0 B
10 17797.175781 S 24951 Po
10 17797.175781 S 24951 B
13 17797.203125 ntask sched 1.000000
10 17797.203125 MS MEMNODE1 Co
18 17797.203125 L p 4000000 MEMNODE0 com_286
10 17797.214844 MS MEMNODE1 CoA
10 17798.308594 MS MEMNODE1 No
19 17798.308594 L p 1928086912 MEMNODE1 com_1928086720
13 17798.314453 ntask sched 0.000000
10 17798.316406 S 24947 Fi
13 17798.330078 ntask sched 1.000000
13 17798.355469 ntask sched 2.000000
13 17798.371094 ntask sched 3.000000
10 17798.373047 MS MEMNODE1 Co
18 17798.373047 L p 4000000 MEMNODE0 com_287
10 17798.382812 MS MEMNODE1 CoA
13 17798.386719 ntask sched 4.000000
13 17798.400391 ntask sched 5.000000
13 17798.417969 ntask sched 6.000000
10 17798.421875 MS MEMNODE0 Co
18 17798.421875 L p 4000000 MEMNODE1 com_288
13 17798.423828 ntask sched 5.000000
10 17798.427734 S 24948 Fi
13 17798.435547 ntask sched 6.000000
10 17798.437500 MS MEMNODE0 Co
18 17798.437500 L p 4000000 MEMNODE1 com_289
13 17798.451172 ntask sched 7.000000
10 17798.451172 MS MEMNODE0 Co
18 17798.451172 L p 4000000 MEMNODE1 com_290
13 17798.466797 ntask sched 8.000000
13 17798.470703 ntask sched 7.000000
10 17798.472656 S 24951 Fi
10 17798.474609 S 24951 B
10 17798.474609 S 24951 chol_model_21
10 17799.574219 MS MEMNODE1 No
19 17799.574219 L p 1928086912 MEMNODE1 com_1928086720
10 17799.585938 MS MEMNODE0 CoA
10 17799.591797 MS MEMNODE0 CoA
10 17801.765625 MS MEMNODE0 No
19 17801.765625 L p 1928086912 MEMNODE0 com_1928086720
10 17801.781250 MS MEMNODE0 CoA
10 17803.933594 MS MEMNODE0 No
19 17803.933594 L p 1928086912 MEMNODE0 com_1928086720
13 17803.943359 ntask sched 6.000000
10 17803.945312 S 24950 Fi
10 17805.421875 MS MEMNODE0 No
19 17805.421875 L p 1928086912 MEMNODE0 com_1928086720
10 17805.429688 MS MEMNODE1 No
19 17805.429688 L p 4000000 MEMNODE1 com_286
10 17805.431641 S 24947 B
10 17805.433594 S 24947 chol_model_21
13 17805.439453 ntask sched 5.000000
10 17805.441406 MS MEMNODE0 No
19 17805.441406 L p 4000000 MEMNODE0 com_288
10 17805.441406 S 24949 Fi
10 17805.443359 S 24948 B
10 17805.445312 S 24948 chol_model_21
10 17805.523438 MS MEMNODE0 No
19 17805.523438 L p 4000000 MEMNODE0 com_289
10 17805.523438 S 24949 B
10 17805.525391 S 24949 chol_model_21
10 17805.527344 MS MEMNODE0 No
19 17805.527344 L p 4000000 MEMNODE0 com_290
10 17805.531250 S 24950 B
10 17805.533203 S 24950 chol_model_21
10 17813.814453 S 64 B
10 17813.816406 S 24947 Po
10 17813.818359 S 24947 B
13 17813.841797 ntask sched 6.000000
10 17813.851562 MS MEMNODE1 No
19 17813.851562 L p 4000000 MEMNODE1 com_287
13 17813.853516 ntask sched 5.000000
10 17813.853516 S 24947 Fi
10 17813.855469 S 24947 B
10 17813.857422 S 24947 chol_model_21
10 17822.164062 S 64 B
10 17822.164062 S 24947 Po
10 17822.167969 S 24947 B
13 17822.183594 ntask sched 6.000000
13 17822.195312 ntask sched 7.000000
13 17822.201172 ntask sched 6.000000
10 17822.201172 S 24947 Fi
10 17822.203125 S 24947 B
10 17822.203125 S 24947 chol_model_21
10 17830.521484 S 64 B
10 17830.523438 S 24947 Po
10 17830.525391 S 24947 B
13 17830.541016 ntask sched 7.000000
13 17830.552734 ntask sched 8.000000
13 17830.564453 ntask sched 9.000000
13 17830.570312 ntask sched 8.000000
10 17830.570312 S 24947 Fi
10 17830.572266 S 24947 B
10 17830.572266 S 24947 chol_model_21
10 17838.886719 S 64 B
10 17838.886719 S 24947 Po
10 17838.888672 S 24947 B
13 17838.906250 ntask sched 9.000000
13 17838.919922 ntask sched 10.000000
13 17838.929688 ntask sched 11.000000
13 17838.941406 ntask sched 12.000000
10 17838.947266 MS MEMNODE1 Co
18 17838.947266 L p 4000000 MEMNODE0 com_291
10 17838.953125 MS MEMNODE1 CoA
10 17840.123047 MS MEMNODE1 No
19 17840.123047 L p 1928086912 MEMNODE1 com_1928086720
10 17840.128906 MS MEMNODE1 Co
18 17840.128906 L p 4000000 MEMNODE0 com_292
10 17840.132812 MS MEMNODE1 CoA
10 17841.324219 MS MEMNODE1 No
19 17841.324219 L p 1928086912 MEMNODE1 com_1928086720
10 17841.328125 MS MEMNODE1 Co
18 17841.328125 L p 4000000 MEMNODE0 com_293
10 17841.333984 MS MEMNODE1 CoA
10 17842.517578 MS MEMNODE1 No
19 17842.517578 L p 1928086912 MEMNODE1 com_1928086720
13 17842.523438 ntask sched 11.000000
10 17842.525391 S 24947 Fi
10 17842.527344 S 24947 B
10 17842.529297 S 24947 chol_model_21
10 17846.679688 S 0 B
10 17846.681641 S 24951 Po
10 17846.681641 S 24951 B
13 17846.705078 ntask sched 12.000000
13 17846.718750 ntask sched 13.000000
13 17846.730469 ntask sched 14.000000
13 17846.742188 ntask sched 15.000000
13 17846.755859 ntask sched 16.000000
10 17850.861328 S 64 B
10 17850.861328 S 24947 Po
10 17850.863281 S 24947 B
13 17850.882812 ntask sched 17.000000
13 17850.896484 ntask sched 18.000000
13 17850.910156 ntask sched 19.000000
13 17850.923828 ntask sched 20.000000
13 17850.935547 ntask sched 21.000000
13 17850.951172 ntask sched 22.000000
10 17850.984375 MS MEMNODE1 No
19 17850.984375 L p 4000000 MEMNODE1 com_293
10 17850.986328 MS MEMNODE1 No
19 17850.986328 L p 4000000 MEMNODE1 com_292
10 17850.988281 MS MEMNODE1 No
19 17850.988281 L p 4000000 MEMNODE1 com_291
10 17850.990234 MS MEMNODE1 Co
18 17850.990234 L p 4000000 MEMNODE0 com_294
10 17850.994141 MS MEMNODE1 CoA
10 17852.062500 MS MEMNODE1 No
19 17852.062500 L p 1928086912 MEMNODE1 com_1928086720
13 17852.068359 ntask sched 21.000000
10 17852.070312 S 24947 Fi
10 17852.072266 S 24947 B
10 17852.072266 S 24947 chol_model_21
10 17853.794922 S 0 B
10 17853.796875 S 24948 Po
10 17853.796875 S 24949 Po
10 17853.800781 S 24948 B
10 17853.808594 S 24949 B
10 17853.814453 S 0 B
10 17853.816406 S 24950 Po
10 17853.818359 S 24950 B
13 17853.833984 ntask sched 22.000000
13 17853.835938 ntask sched 23.000000
13 17853.841797 ntask sched 24.000000
13 17853.851562 ntask sched 25.000000
13 17853.853516 ntask sched 26.000000
13 17853.859375 ntask sched 27.000000
10 17853.861328 MS MEMNODE0 Co
18 17853.861328 L p 4000000 MEMNODE1 com_295
10 17853.867188 MS MEMNODE0 CoA
13 17853.869141 ntask sched 28.000000
10 17853.871094 MS MEMNODE0 Co
18 17853.871094 L p 4000000 MEMNODE1 com_296
13 17853.886719 ntask sched 29.000000
10 17853.892578 MS MEMNODE0 Co
18 17853.892578 L p 4000000 MEMNODE1 com_297
10 17853.902344 MS MEMNODE0 Co
18 17853.902344 L p 4000000 MEMNODE1 com_298
13 17853.904297 ntask sched 30.000000
13 17853.917969 ntask sched 31.000000
13 17853.933594 ntask sched 32.000000
10 17853.939453 MS MEMNODE0 Co
18 17853.939453 L p 4000000 MEMNODE1 com_299
10 17860.392578 S 64 B
10 17860.392578 S 24947 Po
10 17860.394531 S 24947 B
13 17860.416016 ntask sched 33.000000
10 17862.253906 MS MEMNODE0 No
19 17862.253906 L p 1928086912 MEMNODE0 com_1928086720
10 17862.259766 MS MEMNODE0 CoA
10 17862.271484 MS MEMNODE0 CoA
10 17862.281250 MS MEMNODE0 CoA
10 17862.289062 MS MEMNODE0 CoA
10 17862.298828 MS MEMNODE1 No
19 17862.298828 L p 4000000 MEMNODE1 com_294
10 17862.302734 MS MEMNODE1 Co
18 17862.302734 L p 4000000 MEMNODE0 com_300
13 17862.318359 ntask sched 32.000000
10 17862.318359 S 24952 Fi
10 17864.292969 MS MEMNODE0 No
19 17864.292969 L p 1928086912 MEMNODE0 com_1928086720
10 17866.089844 MS MEMNODE0 No
19 17866.089844 L p 1928086920 MEMNODE0 com_1928086720
10 17868.066406 MS MEMNODE0 No
19 17868.066406 L p 1928086920 MEMNODE0 com_1928086720
10 17869.992188 MS MEMNODE0 No
19 17869.992188 L p 1928086920 MEMNODE0 com_1928086720
13 17870.003906 ntask sched 31.000000
10 17870.005859 S 24949 Fi
10 17870.009766 MS MEMNODE0 No
19 17870.009766 L p 4000000 MEMNODE0 com_295
10 17870.046875 MS MEMNODE0 Co
18 17870.046875 L p 4000000 MEMNODE1 com_301
10 17870.093750 MS MEMNODE0 Co
18 17870.093750 L p 4000000 MEMNODE1 com_302
10 17870.103516 MS MEMNODE0 CoA
10 17870.111328 MS MEMNODE1 CoA
10 17870.117188 MS MEMNODE0 No
19 17870.117188 L p 4000000 MEMNODE0 com_299
10 17871.273438 MS MEMNODE1 No
19 17871.273438 L p 0 MEMNODE1 com_0
10 17871.277344 MS MEMNODE0 No
19 17871.277344 L p 4000000 MEMNODE0 com_296
10 17873.416016 MS MEMNODE0 No
19 17873.416016 L p 0 MEMNODE0 com_0
10 17873.427734 MS MEMNODE0 CoA
10 17873.435547 MS MEMNODE0 No
19 17873.435547 L p 4000000 MEMNODE0 com_297
13 17873.441406 ntask sched 32.000000
10 17873.441406 MS MEMNODE0 Co
18 17873.441406 L p 4000000 MEMNODE1 com_303
10 17873.443359 MS MEMNODE1 Co
18 17873.443359 L p 4000000 MEMNODE0 com_304
10 17873.449219 MS MEMNODE0 CoA
13 17873.464844 ntask sched 33.000000
10 17874.812500 MS MEMNODE0 No
19 17874.812500 L p 1928086912 MEMNODE0 com_1928086720
10 17874.818359 MS MEMNODE0 No
19 17874.818359 L p 4000000 MEMNODE0 com_298
13 17874.830078 ntask sched 34.000000
13 17874.832031 ntask sched 35.000000
10 17874.841797 MS MEMNODE1 CoA
13 17874.851562 ntask sched 36.000000
13 17874.867188 ntask sched 37.000000
13 17874.880859 ntask sched 38.000000
10 17876.279297 MS MEMNODE0 No
19 17876.279297 L p 1928086912 MEMNODE0 com_1928086720
13 17876.287109 ntask sched 37.000000
10 17876.289062 S 24951 Fi
10 17877.472656 MS MEMNODE1 No
19 17877.472656 L p 1928086912 MEMNODE1 com_1928086720
10 17877.478516 MS MEMNODE0 No
19 17877.478516 L p 4000000 MEMNODE0 com_302
10 17877.490234 S 24952 B
10 17877.492188 MS MEMNODE0 No
19 17877.492188 L p 4000000 MEMNODE0 com_301
10 17877.492188 S 24952 chol_model_22
10 17877.498047 MS MEMNODE1 Co
18 17877.498047 L p 4000000 MEMNODE0 com_305
10 17877.501953 S 24949 B
10 17877.501953 S 24949 chol_model_22
10 17877.505859 MS MEMNODE1 CoA
13 17877.513672 ntask sched 38.000000
10 17878.730469 MS MEMNODE1 No
19 17878.730469 L p 1928086912 MEMNODE1 com_1928086720
10 17878.736328 MS MEMNODE0 No
19 17878.736328 L p 4000000 MEMNODE0 com_303
10 17878.738281 S 24951 B
10 17878.740234 S 24951 chol_model_22
13 17878.755859 ntask sched 39.000000
13 17878.759766 ntask sched 40.000000
13 17878.761719 ntask sched 41.000000
13 17878.773438 ntask sched 42.000000
13 17878.775391 ntask sched 43.000000
13 17878.779297 ntask sched 44.000000
13 17878.781250 ntask sched 43.000000
10 17878.783203 S 24948 Fi
10 17878.785156 S 24948 B
10 17878.785156 S 24948 chol_model_22
13 17878.791016 ntask sched 44.000000
13 17878.794922 ntask sched 45.000000
13 17878.796875 ntask sched 44.000000
10 17878.798828 S 24950 Fi
10 17878.800781 S 24950 B
10 17878.800781 S 24950 chol_model_22
13 17878.806641 ntask sched 45.000000
13 17878.820312 ntask sched 46.000000
13 17878.832031 ntask sched 47.000000
13 17878.845703 ntask sched 48.000000
13 17878.857422 ntask sched 49.000000
13 17878.869141 ntask sched 50.000000
10 17878.908203 MS MEMNODE1 No
19 17878.908203 L p 4000000 MEMNODE1 com_304
10 17878.931641 MS MEMNODE1 No
19 17878.931641 L p 4000000 MEMNODE1 com_300
10 17878.933594 MS MEMNODE1 Co
18 17878.933594 L p 4000000 MEMNODE0 com_306
10 17878.939453 MS MEMNODE1 CoA
10 17880.162109 MS MEMNODE1 No
19 17880.162109 L p 1928086912 MEMNODE1 com_1928086720
10 17880.167969 MS MEMNODE1 Co
18 17880.167969 L p 4000000 MEMNODE0 com_307
10 17880.171875 MS MEMNODE1 CoA
10 17881.328125 MS MEMNODE1 No
19 17881.328125 L p 1928086912 MEMNODE1 com_1928086720
10 17881.332031 MS MEMNODE1 Co
18 17881.332031 L p 4000000 MEMNODE0 com_308
10 17881.337891 MS MEMNODE1 CoA
10 17882.498047 MS MEMNODE1 No
19 17882.498047 L p 1928086912 MEMNODE1 com_1928086720
13 17882.505859 ntask sched 49.000000
10 17882.507812 S 24947 Fi
10 17882.511719 S 24947 B
10 17882.513672 S 24947 chol_model_22
10 17885.826172 S 64 B
10 17885.826172 S 24947 Po
10 17885.828125 S 24947 B
13 17885.851562 ntask sched 50.000000
10 17885.884766 MS MEMNODE1 No
19 17885.884766 L p 4000000 MEMNODE1 com_308
10 17885.886719 MS MEMNODE1 No
19 17885.886719 L p 4000000 MEMNODE1 com_307
10 17885.888672 MS MEMNODE1 No
19 17885.888672 L p 4000000 MEMNODE1 com_306
10 17885.890625 MS MEMNODE1 No
19 17885.890625 L p 4000000 MEMNODE1 com_305
13 17885.892578 ntask sched 49.000000
10 17885.894531 S 24947 Fi
10 17885.896484 S 24947 B
10 17885.896484 S 24947 chol_model_22
10 17889.173828 S 64 B
10 17889.173828 S 24947 Po
10 17889.175781 S 24947 B
13 17889.181641 ntask sched 48.000000
10 17889.183594 S 24947 Fi
10 17889.183594 S 24947 B
10 17889.185547 S 24947 chol_model_22
10 17892.457031 S 64 B
10 17892.457031 S 24947 Po
10 17892.460938 S 24947 B
13 17892.466797 ntask sched 47.000000
10 17892.466797 S 24947 Fi
10 17892.468750 S 24947 B
10 17892.468750 S 24947 chol_model_22
10 17895.746094 S 64 B
10 17895.748047 S 24947 Po
10 17895.748047 S 24947 B
13 17895.755859 ntask sched 46.000000
10 17895.755859 S 24947 Fi
10 17895.757812 S 24947 B
10 17895.759766 S 24947 chol_model_22
10 17899.041016 S 64 B
10 17899.042969 S 24947 Po
10 17899.042969 S 24947 B
13 17899.048828 ntask sched 45.000000
10 17899.050781 S 24947 Fi
10 17899.050781 S 24947 B
10 17899.052734 S 24947 chol_model_22
10 17902.330078 S 64 B
10 17902.330078 S 24947 Po
10 17902.332031 S 24947 B
13 17902.341797 ntask sched 44.000000
10 17902.343750 S 24947 Fi
10 17902.345703 S 24947 B
10 17902.345703 S 24947 chol_model_22
10 17905.623047 S 64 B
10 17905.623047 S 24947 Po
10 17905.626953 S 24947 B
13 17905.636719 ntask sched 43.000000
10 17905.638672 S 24947 Fi
10 17905.640625 S 24947 B
10 17905.640625 S 24947 chol_model_22
10 17908.925781 S 64 B
10 17908.927734 S 24947 Po
10 17908.929688 S 24947 B
13 17908.935547 ntask sched 42.000000
10 17908.935547 S 24947 Fi
10 17908.937500 S 24947 B
10 17908.937500 S 24947 chol_model_22
10 17912.214844 S 64 B
10 17912.214844 S 24947 Po
10 17912.216797 S 24947 B
13 17912.222656 ntask sched 41.000000
10 17912.222656 S 24947 Fi
10 17912.224609 S 24947 B
10 17912.224609 S 24947 chol_model_22
10 17915.500000 S 64 B
10 17915.501953 S 24947 Po
10 17915.503906 S 24947 B
13 17915.509766 ntask sched 40.000000
10 17915.509766 S 24947 Fi
10 17915.511719 S 24947 B
10 17915.511719 S 24947 chol_model_22
10 17918.796875 S 64 B
10 17918.796875 S 24947 Po
10 17918.798828 S 24947 B
13 17918.804688 ntask sched 39.000000
10 17918.806641 S 24947 Fi
10 17918.808594 S 24947 B
10 17918.808594 S 24947 chol_model_22
10 17922.087891 S 64 B
10 17922.087891 S 24947 Po
10 17922.089844 S 24947 B
13 17922.095703 ntask sched 38.000000
10 17922.097656 S 24947 Fi
10 17922.097656 S 24947 B
10 17922.099609 S 24947 chol_model_22
10 17925.375000 S 64 B
10 17925.376953 S 24947 Po
10 17925.378906 S 24947 B
13 17925.384766 ntask sched 37.000000
10 17925.386719 S 24947 Fi
10 17925.386719 S 24947 B
10 17925.388672 S 24947 chol_model_22
10 17928.669922 S 64 B
10 17928.671875 S 24947 Po
10 17928.673828 S 24947 B
13 17928.679688 ntask sched 36.000000
10 17928.681641 S 24947 Fi
10 17928.681641 S 24947 B
10 17928.683594 S 24947 chol_model_22
10 17931.960938 S 64 B
10 17931.960938 S 24947 Po
10 17931.962891 S 24947 B
13 17931.968750 ntask sched 35.000000
10 17931.970703 S 24947 Fi
10 17931.970703 S 24947 B
10 17931.972656 S 24947 chol_model_22
10 17935.250000 S 64 B
10 17935.251953 S 24947 Po
10 17935.253906 S 24947 B
13 17935.259766 ntask sched 34.000000
10 17935.259766 S 24947 Fi
10 17935.261719 S 24947 B
10 17935.263672 S 24947 chol_model_22
10 17938.539062 S 64 B
10 17938.541016 S 24947 Po
10 17938.542969 S 24947 B
13 17938.548828 ntask sched 33.000000
10 17938.550781 S 24947 Fi
10 17938.550781 S 24947 B
10 17938.552734 S 24947 chol_model_22
10 17941.826172 S 64 B
10 17941.826172 S 24947 Po
10 17941.828125 S 24947 B
13 17941.833984 ntask sched 32.000000
10 17941.835938 S 24947 Fi
10 17941.837891 S 24947 B
10 17941.837891 S 24947 chol_model_22
10 17945.113281 S 64 B
10 17945.113281 S 24947 Po
10 17945.115234 S 24947 B
13 17945.121094 ntask sched 31.000000
10 17945.123047 S 24947 Fi
10 17945.123047 S 24947 B
10 17945.125000 S 24947 chol_model_22
10 17948.392578 S 64 B
10 17948.394531 S 24947 Po
10 17948.394531 S 24947 B
13 17948.402344 ntask sched 30.000000
10 17948.404297 S 24947 Fi
10 17948.406250 S 24947 B
10 17948.406250 S 24947 chol_model_22
10 17951.689453 S 64 B
10 17951.691406 S 24947 Po
10 17951.691406 S 24947 B
13 17951.699219 ntask sched 29.000000
10 17951.699219 S 24947 Fi
10 17951.701172 S 24947 B
10 17951.703125 S 24947 chol_model_22
10 17954.984375 S 64 B
10 17954.984375 S 24947 Po
10 17954.986328 S 24947 B
13 17954.992188 ntask sched 28.000000
10 17954.994141 S 24947 Fi
10 17954.994141 S 24947 B
10 17954.996094 S 24947 chol_model_22
10 17958.275391 S 64 B
10 17958.275391 S 24947 Po
10 17958.277344 S 24947 B
13 17958.283203 ntask sched 27.000000
10 17958.285156 S 24947 Fi
10 17958.285156 S 24947 B
10 17958.287109 S 24947 chol_model_22
10 17961.566406 S 64 B
10 17961.566406 S 24947 Po
10 17961.568359 S 24947 B
13 17961.574219 ntask sched 26.000000
10 17961.576172 S 24947 Fi
10 17961.576172 S 24947 B
10 17961.578125 S 24947 chol_model_22
10 17964.855469 S 64 B
10 17964.857422 S 24947 Po
10 17964.859375 S 24947 B
13 17964.865234 ntask sched 25.000000
10 17964.865234 S 24947 Fi
10 17964.867188 S 24947 B
10 17964.867188 S 24947 chol_model_22
10 17968.144531 S 64 B
10 17968.144531 S 24947 Po
10 17968.146484 S 24947 B
13 17968.152344 ntask sched 24.000000
10 17968.152344 S 24947 Fi
10 17968.154297 S 24947 B
10 17968.154297 S 24947 chol_model_22
10 17968.273438 S 0 B
10 17968.273438 S 24952 Po
10 17968.275391 S 24952 B
10 17968.283203 MS MEMNODE0 Co
18 17968.283203 L p 4000000 MEMNODE1 com_309
10 17968.292969 MS MEMNODE0 CoA
10 17968.947266 S 0 B
10 17968.949219 S 24949 Po
10 17968.955078 S 24949 B
10 17969.742188 S 0 B
10 17969.744141 S 24951 Po
10 17969.746094 S 24951 B
10 17970.611328 S 0 B
10 17970.613281 S 24948 Po
10 17970.615234 S 24948 B
13 17970.623047 ntask sched 23.000000
10 17970.625000 S 24948 Fi
10 17970.628906 S 24948 B
10 17970.628906 S 24948 chol_model_22
10 17970.703125 S 0 B
10 17970.705078 S 24950 Po
10 17970.707031 S 24950 B
10 17971.439453 S 64 B
10 17971.439453 S 24947 Po
10 17971.441406 S 24947 B
13 17971.449219 ntask sched 22.000000
10 17971.449219 S 24947 Fi
10 17971.451172 S 24947 B
10 17971.453125 S 24947 chol_model_22
10 17973.349609 MS MEMNODE0 No
19 17973.349609 L p 1928086912 MEMNODE0 com_1928086720
13 17973.384766 ntask sched 21.000000
10 17973.386719 S 24952 Fi
10 17976.636719 S 64 B
10 17976.638672 S 24947 Po
10 17976.640625 S 24947 B
13 17976.648438 ntask sched 20.000000
10 17976.648438 S 24947 Fi
10 17976.650391 S 24947 B
10 17976.652344 S 24947 chol_model_22
10 17976.714844 MS MEMNODE0 No
19 17976.714844 L p 4000000 MEMNODE0 com_309
10 17976.716797 S 24952 B
10 17976.716797 S 24952 chol_model_11
10 17979.962891 S 64 B
10 17979.962891 S 24947 Po
10 17979.964844 S 24947 B
13 17979.972656 ntask sched 19.000000
10 17979.974609 S 24947 Fi
10 17979.976562 S 24947 B
10 17979.976562 S 24947 chol_model_22
10 17983.257812 S 64 B
10 17983.257812 S 24947 Po
10 17983.259766 S 24947 B
13 17983.267578 ntask sched 18.000000
10 17983.267578 S 24947 Fi
10 17983.269531 S 24947 B
10 17983.269531 S 24947 chol_model_22
10 17986.548828 S 64 B
10 17986.548828 S 24947 Po
10 17986.550781 S 24947 B
13 17986.556641 ntask sched 17.000000
10 17986.558594 S 24947 Fi
10 17986.560547 S 24947 B
10 17986.560547 S 24947 chol_model_22
10 17989.841797 S 64 B
10 17989.843750 S 24947 Po
10 17989.843750 S 24947 B
13 17989.851562 ntask sched 16.000000
10 17989.851562 S 24947 Fi
10 17989.853516 S 24947 B
10 17989.853516 S 24947 chol_model_22
10 17993.128906 S 64 B
10 17993.128906 S 24947 Po
10 17993.130859 S 24947 B
13 17993.136719 ntask sched 15.000000
10 17993.138672 S 24947 Fi
10 17993.138672 S 24947 B
10 17993.138672 S 24947 chol_model_22
10 17996.414062 S 64 B
10 17996.414062 S 24947 Po
10 17996.416016 S 24947 B
13 17996.421875 ntask sched 14.000000
10 17996.423828 S 24947 Fi
10 17996.425781 S 24947 B
10 17996.425781 S 24947 chol_model_22
10 17999.701172 S 64 B
10 17999.701172 S 24947 Po
10 17999.703125 S 24947 B
13 17999.708984 ntask sched 13.000000
10 17999.710938 S 24947 Fi
10 17999.712891 S 24947 B
10 17999.712891 S 24947 chol_model_22
10 18002.988281 S 64 B
10 18002.988281 S 24947 Po
10 18002.990234 S 24947 B
13 18002.996094 ntask sched 12.000000
10 18002.998047 S 24947 Fi
10 18003.000000 S 24947 B
10 18003.000000 S 24947 chol_model_22
10 18006.269531 S 64 B
10 18006.271484 S 24947 Po
10 18006.271484 S 24947 B
13 18006.279297 ntask sched 11.000000
10 18006.279297 S 24947 Fi
10 18006.281250 S 24947 B
10 18006.281250 S 24947 chol_model_22
10 18009.556641 S 64 B
10 18009.558594 S 24947 Po
10 18009.560547 S 24947 B
13 18009.566406 ntask sched 10.000000
10 18009.566406 S 24947 Fi
10 18009.568359 S 24947 B
10 18009.570312 S 24947 chol_model_22
10 18012.853516 S 64 B
10 18012.853516 S 24947 Po
10 18012.855469 S 24947 B
13 18012.861328 ntask sched 9.000000
10 18012.861328 S 24947 Fi
10 18012.863281 S 24947 B
10 18012.863281 S 24947 chol_model_22
10 18016.138672 S 64 B
10 18016.138672 S 24947 Po
10 18016.140625 S 24947 B
13 18016.146484 ntask sched 8.000000
10 18016.146484 S 24947 Fi
10 18016.148438 S 24947 B
10 18016.148438 S 24947 chol_model_22
10 18019.427734 S 64 B
10 18019.427734 S 24947 Po
10 18019.429688 S 24947 B
13 18019.435547 ntask sched 7.000000
10 18019.437500 S 24947 Fi
10 18019.439453 S 24947 B
10 18019.439453 S 24947 chol_model_22
10 18022.718750 S 64 B
10 18022.718750 S 24947 Po
10 18022.720703 S 24947 B
13 18022.728516 ntask sched 6.000000
10 18022.728516 S 24947 Fi
10 18022.730469 S 24947 B
10 18022.730469 S 24947 chol_model_22
10 18026.001953 S 64 B
10 18026.003906 S 24947 Po
10 18026.003906 S 24947 B
13 18026.009766 ntask sched 5.000000
10 18026.011719 S 24947 Fi
10 18026.013672 S 24947 B
10 18026.013672 S 24947 chol_model_22
10 18029.287109 S 64 B
10 18029.287109 S 24947 Po
10 18029.289062 S 24947 B
13 18029.296875 ntask sched 4.000000
10 18029.296875 S 24947 Fi
10 18029.298828 S 24947 B
10 18029.298828 S 24947 chol_model_22
10 18032.564453 S 64 B
10 18032.564453 S 24947 Po
10 18032.566406 S 24947 B
13 18032.572266 ntask sched 3.000000
10 18032.574219 S 24947 Fi
10 18032.574219 S 24947 B
10 18032.576172 S 24947 chol_model_22
10 18035.849609 S 64 B
10 18035.849609 S 24947 Po
10 18035.851562 S 24947 B
13 18035.857422 ntask sched 2.000000
10 18035.859375 S 24947 Fi
10 18035.859375 S 24947 B
10 18035.861328 S 24947 chol_model_22
10 18039.136719 S 64 B
10 18039.138672 S 24947 Po
10 18039.138672 S 24947 B
13 18039.144531 ntask sched 1.000000
10 18039.146484 S 24947 Fi
10 18039.148438 S 24947 B
10 18039.148438 S 24947 chol_model_22
10 18042.429688 S 64 B
10 18042.431641 S 24947 Po
10 18042.433594 S 24947 B
13 18042.439453 ntask sched 0.000000
10 18042.441406 S 24947 Fi
10 18042.443359 S 24947 B
10 18042.443359 S 24947 chol_model_22
10 18042.494141 S 0 B
10 18042.496094 S 24952 Po
10 18042.498047 S 24952 B
13 18042.525391 ntask sched 1.000000
13 18042.539062 ntask sched 2.000000
13 18042.552734 ntask sched 3.000000
13 18042.566406 ntask sched 4.000000
13 18042.578125 ntask sched 5.000000
13 18042.593750 ntask sched 6.000000
10 18042.603516 MS MEMNODE0 Co
18 18042.603516 L p 4000000 MEMNODE1 com_310
13 18042.609375 ntask sched 7.000000
10 18042.609375 MS MEMNODE0 Co
18 18042.609375 L p 4000000 MEMNODE1 com_311
13 18042.613281 ntask sched 6.000000
10 18042.619141 S 24950 Fi
10 18042.619141 MS MEMNODE0 CoA
13 18042.625000 ntask sched 7.000000
10 18042.625000 MS MEMNODE0 Co
18 18042.625000 L p 4000000 MEMNODE1 com_312
10 18042.628906 MS MEMNODE0 CoA
13 18042.644531 ntask sched 8.000000
10 18042.648438 MS MEMNODE0 Co
18 18042.648438 L p 4000000 MEMNODE1 com_313
10 18045.724609 S 64 B
10 18045.726562 S 24947 Po
10 18045.726562 S 24947 B
10 18045.732422 MS MEMNODE1 Co
18 18045.732422 L p 4000000 MEMNODE0 com_314
10 18047.019531 MS MEMNODE0 No
19 18047.019531 L p 0 MEMNODE0 com_0
10 18047.027344 MS MEMNODE0 CoA
10 18049.031250 MS MEMNODE0 No
19 18049.031250 L p 1928086912 MEMNODE0 com_1928086720
10 18049.041016 MS MEMNODE0 CoA
10 18049.052734 MS MEMNODE1 CoA
13 18049.066406 ntask sched 7.000000
10 18049.068359 S 24951 Fi
10 18051.169922 MS MEMNODE0 No
19 18051.169922 L p 1928086912 MEMNODE0 com_1928086720
13 18051.183594 ntask sched 6.000000
10 18051.185547 S 24949 Fi
10 18052.583984 MS MEMNODE0 No
19 18052.583984 L p 1928086912 MEMNODE0 com_1928086720
10 18053.671875 MS MEMNODE1 No
19 18053.671875 L p 1928086920 MEMNODE1 com_1928086720
10 18053.677734 MS MEMNODE0 No
19 18053.677734 L p 4000000 MEMNODE0 com_311
10 18053.689453 S 24950 B
10 18053.691406 MS MEMNODE0 No
19 18053.691406 L p 4000000 MEMNODE0 com_310
10 18053.691406 S 24950 chol_model_21
13 18053.718750 ntask sched 5.000000
10 18053.718750 S 24949 B
10 18053.720703 S 24949 chol_model_21
10 18053.720703 S 24947 Fi
10 18053.867188 MS MEMNODE0 No
19 18053.867188 L p 4000000 MEMNODE0 com_312
10 18053.904297 MS MEMNODE1 No
19 18053.904297 L p 4000000 MEMNODE1 com_314
10 18053.908203 S 24947 B
10 18053.910156 S 24947 chol_model_21
10 18053.957031 MS MEMNODE0 No
19 18053.957031 L p 4000000 MEMNODE0 com_313
10 18053.958984 S 24951 B
10 18053.960938 S 24951 chol_model_21
10 18061.033203 S 0 B
10 18061.037109 S 24948 Po
10 18061.041016 S 24948 B
10 18062.242188 S 64 B
10 18062.242188 S 24947 Po
10 18062.244141 S 24947 B
13 18062.267578 ntask sched 6.000000
13 18062.273438 ntask sched 5.000000
10 18062.273438 S 24947 Fi
10 18062.275391 S 24947 B
10 18062.275391 S 24947 chol_model_21
10 18070.583984 S 64 B
10 18070.585938 S 24947 Po
10 18070.587891 S 24947 B
13 18070.605469 ntask sched 6.000000
13 18070.619141 ntask sched 7.000000
13 18070.625000 ntask sched 6.000000
10 18070.626953 S 24947 Fi
10 18070.628906 S 24947 B
10 18070.628906 S 24947 chol_model_21
10 18078.931641 S 64 B
10 18078.933594 S 24947 Po
10 18078.933594 S 24947 B
13 18078.953125 ntask sched 7.000000
13 18078.966797 ntask sched 8.000000
13 18078.982422 ntask sched 9.000000
13 18078.986328 ntask sched 8.000000
10 18078.988281 S 24947 Fi
10 18078.988281 S 24947 B
10 18078.990234 S 24947 chol_model_21
10 18087.296875 S 64 B
10 18087.296875 S 24947 Po
10 18087.298828 S 24947 B
13 18087.316406 ntask sched 9.000000
13 18087.330078 ntask sched 10.000000
13 18087.345703 ntask sched 11.000000
13 18087.359375 ntask sched 12.000000
13 18087.363281 ntask sched 11.000000
10 18087.365234 S 24947 Fi
10 18087.367188 S 24947 B
10 18087.367188 S 24947 chol_model_21
10 18095.673828 S 64 B
10 18095.675781 S 24947 Po
10 18095.677734 S 24947 B
13 18095.695312 ntask sched 12.000000
13 18095.708984 ntask sched 13.000000
13 18095.722656 ntask sched 14.000000
13 18095.736328 ntask sched 15.000000
13 18095.751953 ntask sched 16.000000
13 18095.755859 ntask sched 15.000000
10 18095.757812 S 24947 Fi
10 18095.757812 S 24947 B
10 18095.759766 S 24947 chol_model_22
10 18099.042969 S 64 B
10 18099.044922 S 24947 Po
10 18099.044922 S 24947 B
13 18099.064453 ntask sched 16.000000
13 18099.068359 ntask sched 15.000000
10 18099.070312 MS MEMNODE0 Co
18 18099.070312 L p 4000000 MEMNODE1 com_315
10 18099.070312 S 24947 Fi
10 18099.070312 S 24947 B
10 18099.072266 S 24947 chol_model_22
10 18099.103516 MS MEMNODE0 CoA
10 18101.845703 S 0 B
10 18101.847656 S 24949 Po
10 18101.849609 S 24949 B
13 18101.884766 ntask sched 16.000000
13 18101.900391 ntask sched 17.000000
10 18101.904297 S 0 B
10 18101.906250 S 24950 Po
10 18101.908203 S 24950 B
13 18101.917969 ntask sched 18.000000
13 18101.933594 ntask sched 19.000000
13 18101.935547 ntask sched 20.000000
13 18101.949219 ntask sched 21.000000
10 18101.951172 S 0 B
10 18101.951172 S 24951 Po
13 18101.953125 ntask sched 22.000000
10 18101.953125 S 24951 B
13 18101.966797 ntask sched 23.000000
13 18101.968750 ntask sched 24.000000
13 18101.976562 ntask sched 25.000000
13 18101.982422 ntask sched 26.000000
13 18101.994141 ntask sched 27.000000
13 18102.001953 ntask sched 28.000000
13 18102.011719 ntask sched 29.000000
13 18102.017578 ntask sched 30.000000
13 18102.027344 ntask sched 31.000000
13 18102.035156 ntask sched 32.000000
10 18102.035156 MS MEMNODE0 Co
18 18102.035156 L p 4000000 MEMNODE1 com_316
13 18102.039062 ntask sched 31.000000
13 18102.041016 ntask sched 30.000000
10 18102.042969 S 24949 Fi
10 18102.042969 S 24950 Fi
10 18102.044922 MS MEMNODE0 Co
18 18102.044922 L p 4000000 MEMNODE1 com_317
10 18102.044922 S 24950 B
13 18102.044922 ntask sched 31.000000
10 18102.046875 S 24950 chol_model_21
13 18102.058594 ntask sched 32.000000
13 18102.072266 ntask sched 33.000000
13 18102.085938 ntask sched 34.000000
10 18102.089844 MS MEMNODE0 Co
18 18102.089844 L p 4000000 MEMNODE1 com_318
10 18102.351562 S 64 B
10 18102.351562 S 24947 Po
10 18102.353516 S 24947 B
10 18102.359375 MS MEMNODE1 Co
18 18102.359375 L p 4000000 MEMNODE0 com_319
10 18103.761719 MS MEMNODE0 No
19 18103.761719 L p 0 MEMNODE0 com_0
10 18103.771484 MS MEMNODE0 CoA
10 18103.781250 MS MEMNODE0 CoA
10 18105.115234 MS MEMNODE0 No
19 18105.115234 L p 1928086912 MEMNODE0 com_1928086720
10 18105.119141 MS MEMNODE1 CoA
13 18105.132812 ntask sched 33.000000
10 18105.134766 S 24948 Fi
10 18105.142578 MS MEMNODE0 CoA
10 18107.160156 MS MEMNODE0 No
19 18107.160156 L p 1928086912 MEMNODE0 com_1928086720
13 18107.175781 ntask sched 32.000000
10 18107.177734 S 24952 Fi
10 18108.326172 MS MEMNODE1 No
19 18108.326172 L p 1928086912 MEMNODE1 com_1928086720
10 18109.847656 MS MEMNODE0 No
19 18109.847656 L p 1928086920 MEMNODE0 com_1928086720
10 18109.855469 MS MEMNODE0 No
19 18109.855469 L p 4000000 MEMNODE0 com_315
10 18109.857422 S 24948 B
10 18109.859375 S 24948 chol_model_11
10 18109.873047 MS MEMNODE0 No
19 18109.873047 L p 4000000 MEMNODE0 com_316
10 18109.906250 MS MEMNODE1 Co
18 18109.906250 L p 4000000 MEMNODE0 com_320
10 18109.917969 MS MEMNODE0 Co
18 18109.917969 L p 4000000 MEMNODE1 com_321
10 18109.927734 MS MEMNODE0 No
19 18109.927734 L p 4000000 MEMNODE0 com_317
10 18109.929688 S 24949 B
10 18109.931641 S 24949 chol_model_22
10 18109.941406 MS MEMNODE1 CoA
10 18109.949219 MS MEMNODE0 CoA
10 18111.228516 MS MEMNODE1 No
19 18111.228516 L p 1928086912 MEMNODE1 com_1928086720
10 18112.886719 MS MEMNODE0 No
19 18112.886719 L p 1928086920 MEMNODE0 com_1928086720
10 18112.892578 MS MEMNODE0 No
19 18112.892578 L p 4000000 MEMNODE0 com_318
10 18112.898438 MS MEMNODE1 Co
18 18112.898438 L p 4000000 MEMNODE0 com_322
13 18112.906250 ntask sched 31.000000
10 18112.908203 MS MEMNODE1 CoA
10 18112.908203 S 24951 Fi
10 18112.910156 S 24951 B
10 18112.912109 S 24951 chol_model_22
10 18114.164062 MS MEMNODE1 No
19 18114.164062 L p 1928086912 MEMNODE1 com_1928086720
10 18114.171875 MS MEMNODE0 No
19 18114.171875 L p 4000000 MEMNODE0 com_321
10 18114.173828 S 24952 B
10 18114.175781 MS MEMNODE1 Co
18 18114.175781 L p 4000000 MEMNODE0 com_323
10 18114.175781 S 24952 chol_model_22
10 18114.181641 MS MEMNODE1 CoA
10 18115.558594 MS MEMNODE1 No
19 18115.558594 L p 1928086912 MEMNODE1 com_1928086720
10 18115.564453 MS MEMNODE1 Co
18 18115.564453 L p 4000000 MEMNODE0 com_324
10 18115.570312 MS MEMNODE1 CoA
10 18116.751953 MS MEMNODE1 No
19 18116.751953 L p 1928086912 MEMNODE1 com_1928086720
10 18116.755859 MS MEMNODE1 Co
18 18116.755859 L p 4000000 MEMNODE0 com_325
10 18116.761719 MS MEMNODE1 CoA
10 18117.953125 MS MEMNODE1 No
19 18117.953125 L p 1928086912 MEMNODE1 com_1928086720
10 18117.958984 MS MEMNODE1 Co
18 18117.958984 L p 4000000 MEMNODE0 com_326
10 18117.982422 MS MEMNODE1 CoA
10 18119.171875 MS MEMNODE1 No
19 18119.171875 L p 1928086912 MEMNODE1 com_1928086720
13 18119.181641 ntask sched 30.000000
10 18119.183594 S 24947 Fi
10 18119.187500 S 24947 B
10 18119.189453 S 24947 chol_model_22
10 18122.500000 S 64 B
10 18122.501953 S 24947 Po
10 18122.503906 S 24947 B
10 18122.537109 MS MEMNODE1 No
19 18122.537109 L p 4000000 MEMNODE1 com_326
10 18122.539062 MS MEMNODE1 No
19 18122.539062 L p 4000000 MEMNODE1 com_325
10 18122.542969 MS MEMNODE1 No
19 18122.542969 L p 4000000 MEMNODE1 com_324
10 18122.544922 MS MEMNODE1 No
19 18122.544922 L p 4000000 MEMNODE1 com_323
10 18122.548828 MS MEMNODE1 No
19 18122.548828 L p 4000000 MEMNODE1 com_322
10 18122.550781 MS MEMNODE1 No
19 18122.550781 L p 4000000 MEMNODE1 com_320
10 18122.552734 MS MEMNODE1 No
19 18122.552734 L p 4000000 MEMNODE1 com_319
13 18122.554688 ntask sched 29.000000
10 18122.556641 S 24947 Fi
10 18122.558594 S 24947 B
10 18122.558594 S 24947 chol_model_22
10 18125.845703 S 64 B
10 18125.845703 S 24947 Po
10 18125.847656 S 24947 B
13 18125.853516 ntask sched 28.000000
10 18125.855469 S 24947 Fi
10 18125.857422 S 24947 B
10 18125.857422 S 24947 chol_model_22
10 18129.125000 S 64 B
10 18129.126953 S 24947 Po
10 18129.128906 S 24947 B
13 18129.134766 ntask sched 27.000000
10 18129.134766 S 24947 Fi
10 18129.136719 S 24947 B
10 18129.136719 S 24947 chol_model_22
10 18132.406250 S 64 B
10 18132.406250 S 24947 Po
10 18132.408203 S 24947 B
13 18132.414062 ntask sched 26.000000
10 18132.416016 S 24947 Fi
10 18132.417969 S 24947 B
10 18132.417969 S 24947 chol_model_22
10 18135.697266 S 64 B
10 18135.697266 S 24947 Po
10 18135.699219 S 24947 B
13 18135.705078 ntask sched 25.000000
10 18135.705078 S 24947 Fi
10 18135.707031 S 24947 B
10 18135.708984 S 24947 chol_model_22
10 18138.990234 S 64 B
10 18138.992188 S 24947 Po
10 18138.996094 S 24947 B
13 18139.005859 ntask sched 24.000000
10 18139.005859 S 24947 Fi
10 18139.007812 S 24947 B
10 18139.009766 S 24947 chol_model_22
10 18142.285156 S 64 B
10 18142.285156 S 24947 Po
10 18142.287109 S 24947 B
13 18142.294922 ntask sched 23.000000
10 18142.294922 S 24947 Fi
10 18142.296875 S 24947 B
10 18142.296875 S 24947 chol_model_22
10 18145.568359 S 64 B
10 18145.570312 S 24947 Po
10 18145.572266 S 24947 B
13 18145.578125 ntask sched 22.000000
10 18145.578125 S 24947 Fi
10 18145.582031 S 24947 B
10 18145.582031 S 24947 chol_model_22
10 18148.859375 S 64 B
10 18148.861328 S 24947 Po
10 18148.863281 S 24947 B
13 18148.869141 ntask sched 21.000000
10 18148.869141 S 24947 Fi
10 18148.871094 S 24947 B
10 18148.871094 S 24947 chol_model_22
10 18150.628906 S 0 B
10 18150.636719 S 24950 Po
10 18150.640625 S 24950 B
13 18150.675781 ntask sched 22.000000
13 18150.689453 ntask sched 23.000000
13 18150.701172 ntask sched 24.000000
13 18150.714844 ntask sched 25.000000
13 18150.726562 ntask sched 26.000000
13 18150.738281 ntask sched 27.000000
13 18150.753906 ntask sched 28.000000
13 18150.765625 ntask sched 29.000000
13 18150.777344 ntask sched 30.000000
10 18150.785156 MS MEMNODE0 Co
18 18150.785156 L p 4000000 MEMNODE1 com_327
10 18150.802734 MS MEMNODE0 CoA
10 18152.156250 S 64 B
10 18152.158203 S 24947 Po
10 18152.160156 S 24947 B
10 18152.167969 MS MEMNODE1 Co
18 18152.167969 L p 4000000 MEMNODE0 com_328
10 18154.082031 MS MEMNODE0 No
19 18154.082031 L p 0 MEMNODE0 com_0
10 18154.091797 MS MEMNODE1 CoA
13 18154.103516 ntask sched 29.000000
10 18154.105469 S 24950 Fi
10 18155.296875 MS MEMNODE1 No
19 18155.296875 L p 1928086912 MEMNODE1 com_1928086720
10 18155.302734 MS MEMNODE0 No
19 18155.302734 L p 4000000 MEMNODE0 com_327
10 18155.304688 S 24950 B
10 18155.304688 MS MEMNODE1 Co
18 18155.304688 L p 4000000 MEMNODE0 com_329
10 18155.304688 S 24950 chol_model_22
10 18155.308594 MS MEMNODE1 CoA
10 18156.519531 MS MEMNODE1 No
19 18156.519531 L p 1928086912 MEMNODE1 com_1928086720
10 18156.523438 MS MEMNODE1 Co
18 18156.523438 L p 4000000 MEMNODE0 com_330
10 18156.529297 MS MEMNODE1 CoA
10 18157.728516 MS MEMNODE1 No
19 18157.728516 L p 1928086912 MEMNODE1 com_1928086720
13 18157.736328 ntask sched 28.000000
10 18157.738281 S 24947 Fi
10 18157.742188 S 24947 B
10 18157.744141 S 24947 chol_model_22
10 18161.052734 S 64 B
10 18161.054688 S 24947 Po
10 18161.056641 S 24947 B
10 18161.093750 MS MEMNODE1 No
19 18161.093750 L p 4000000 MEMNODE1 com_330
10 18161.095703 MS MEMNODE1 No
19 18161.095703 L p 4000000 MEMNODE1 com_329
10 18161.097656 MS MEMNODE1 No
19 18161.097656 L p 4000000 MEMNODE1 com_328
13 18161.099609 ntask sched 27.000000
10 18161.101562 S 24947 Fi
10 18161.103516 S 24947 B
10 18161.103516 S 24947 chol_model_22
10 18164.380859 S 64 B
10 18164.380859 S 24947 Po
10 18164.382812 S 24947 B
13 18164.390625 ntask sched 26.000000
10 18164.392578 S 24947 Fi
10 18164.392578 S 24947 B
10 18164.394531 S 24947 chol_model_22
10 18167.673828 S 64 B
10 18167.673828 S 24947 Po
10 18167.675781 S 24947 B
13 18167.681641 ntask sched 25.000000
10 18167.683594 S 24947 Fi
10 18167.685547 S 24947 B
10 18167.685547 S 24947 chol_model_22
10 18170.962891 S 64 B
10 18170.962891 S 24947 Po
10 18170.964844 S 24947 B
13 18170.970703 ntask sched 24.000000
10 18170.972656 S 24947 Fi
10 18170.972656 S 24947 B
10 18170.974609 S 24947 chol_model_22
10 18174.251953 S 64 B
10 18174.251953 S 24947 Po
10 18174.253906 S 24947 B
13 18174.259766 ntask sched 23.000000
10 18174.261719 S 24947 Fi
10 18174.263672 S 24947 B
10 18174.263672 S 24947 chol_model_22
10 18177.537109 S 64 B
10 18177.539062 S 24947 Po
10 18177.539062 S 24947 B
13 18177.546875 ntask sched 22.000000
10 18177.548828 S 24947 Fi
10 18177.550781 S 24947 B
10 18177.550781 S 24947 chol_model_22
10 18180.832031 S 64 B
10 18180.833984 S 24947 Po
10 18180.835938 S 24947 B
13 18180.841797 ntask sched 21.000000
10 18180.843750 S 24947 Fi
10 18180.845703 S 24947 B
10 18180.845703 S 24947 chol_model_22
10 18181.283203 S 0 B
10 18181.287109 S 24948 Po
10 18181.291016 S 24948 B
13 18181.328125 ntask sched 22.000000
13 18181.341797 ntask sched 23.000000
13 18181.353516 ntask sched 24.000000
13 18181.367188 ntask sched 25.000000
13 18181.378906 ntask sched 26.000000
13 18181.390625 ntask sched 27.000000
10 18181.398438 MS MEMNODE0 Co
18 18181.398438 L p 4000000 MEMNODE1 com_331
10 18181.419922 MS MEMNODE0 CoA
10 18184.136719 S 64 B
10 18184.138672 S 24947 Po
10 18184.140625 S 24947 B
10 18184.148438 MS MEMNODE1 Co
18 18184.148438 L p 4000000 MEMNODE0 com_332
10 18185.544922 MS MEMNODE0 No
19 18185.544922 L p 0 MEMNODE0 com_0
10 18185.552734 MS MEMNODE1 CoA
10 18185.560547 MS MEMNODE0 Co
18 18185.560547 L p 4000000 MEMNODE1 com_333
10 18186.767578 MS MEMNODE1 No
19 18186.767578 L p 0 MEMNODE1 com_0
10 18186.775391 MS MEMNODE0 CoA
13 18186.787109 ntask sched 26.000000
10 18186.789062 S 24947 Fi
10 18186.792969 S 24947 B
10 18186.792969 S 24947 chol_model_22
10 18188.347656 MS MEMNODE0 No
19 18188.347656 L p 1928086912 MEMNODE0 com_1928086720
10 18188.365234 MS MEMNODE0 Co
18 18188.365234 L p 4000000 MEMNODE1 com_334
10 18188.398438 MS MEMNODE0 CoA
10 18191.658203 S 64 B
10 18191.660156 S 24947 Po
10 18191.662109 S 24947 B
10 18193.617188 MS MEMNODE0 No
19 18193.617188 L p 1928086912 MEMNODE0 com_1928086720
10 18193.623047 MS MEMNODE1 No
19 18193.623047 L p 4000000 MEMNODE1 com_332
13 18193.626953 ntask sched 25.000000
10 18193.628906 S 24947 Fi
10 18193.630859 S 24947 B
10 18193.634766 S 24947 chol_model_22
10 18193.634766 MS MEMNODE0 Co
18 18193.634766 L p 4000000 MEMNODE1 com_335
10 18193.642578 MS MEMNODE0 CoA
10 18196.929688 S 64 B
10 18196.931641 S 24947 Po
10 18196.933594 S 24947 B
13 18196.941406 ntask sched 24.000000
10 18196.941406 S 24947 Fi
10 18196.943359 S 24947 B
10 18196.943359 S 24947 chol_model_22
10 18198.908203 MS MEMNODE0 No
19 18198.908203 L p 1928086912 MEMNODE0 com_1928086720
13 18198.953125 ntask sched 23.000000
10 18198.955078 S 24948 Fi
10 18198.996094 MS MEMNODE0 No
19 18198.996094 L p 4000000 MEMNODE0 com_334
10 18199.023438 MS MEMNODE0 No
19 18199.023438 L p 4000000 MEMNODE0 com_333
10 18199.048828 MS MEMNODE0 No
19 18199.048828 L p 4000000 MEMNODE0 com_331
10 18199.050781 S 24948 B
10 18199.052734 S 24948 chol_model_21
10 18201.148438 S 0 B
10 18201.150391 S 24949 Po
10 18201.154297 S 24949 B
13 18201.171875 ntask sched 22.000000
10 18201.173828 S 24949 Fi
10 18201.175781 S 24949 B
10 18201.175781 S 24949 chol_model_21
10 18202.193359 S 64 B
10 18202.193359 S 24947 Po
10 18202.195312 S 24947 B
13 18202.203125 ntask sched 21.000000
10 18202.203125 S 24947 Fi
10 18202.205078 S 24947 B
10 18202.207031 S 24947 chol_model_22
10 18204.250000 S 0 B
10 18204.251953 S 24951 Po
10 18204.253906 S 24951 B
10 18204.298828 MS MEMNODE0 No
19 18204.298828 L p 4000000 MEMNODE0 com_335
13 18204.302734 ntask sched 20.000000
10 18204.302734 S 24951 Fi
10 18204.304688 S 24951 B
10 18204.306641 S 24951 chol_model_21
10 18205.460938 S 0 B
10 18205.460938 S 24952 Po
10 18205.464844 S 24952 B
13 18205.470703 ntask sched 19.000000
10 18205.472656 S 24952 Fi
10 18205.474609 S 24952 B
10 18205.474609 S 24952 chol_model_21
10 18205.484375 S 64 B
10 18205.484375 S 24947 Po
10 18205.486328 S 24947 B
13 18205.494141 ntask sched 18.000000
10 18205.494141 S 24947 Fi
10 18205.496094 S 24947 B
10 18205.496094 S 24947 chol_model_22
10 18208.773438 S 64 B
10 18208.773438 S 24947 Po
10 18208.775391 S 24947 B
13 18208.798828 ntask sched 19.000000
13 18208.802734 ntask sched 18.000000
10 18208.804688 S 24947 Fi
10 18208.804688 S 24947 B
10 18208.806641 S 24947 chol_model_22
10 18212.078125 S 64 B
10 18212.078125 S 24947 Po
10 18212.080078 S 24947 B
13 18212.087891 ntask sched 17.000000
10 18212.087891 S 24947 Fi
10 18212.089844 S 24947 B
10 18212.091797 S 24947 chol_model_22
10 18215.369141 S 64 B
10 18215.369141 S 24947 Po
10 18215.371094 S 24947 B
13 18215.378906 ntask sched 16.000000
10 18215.380859 S 24947 Fi
10 18215.380859 S 24947 B
10 18215.382812 S 24947 chol_model_22
10 18218.666016 S 64 B
10 18218.667969 S 24947 Po
10 18218.669922 S 24947 B
13 18218.675781 ntask sched 15.000000
10 18218.675781 S 24947 Fi
10 18218.677734 S 24947 B
10 18218.679688 S 24947 chol_model_22
10 18221.962891 S 64 B
10 18221.962891 S 24947 Po
10 18221.964844 S 24947 B
13 18221.970703 ntask sched 14.000000
10 18221.970703 S 24947 Fi
10 18221.972656 S 24947 B
10 18221.972656 S 24947 chol_model_22
10 18225.251953 S 64 B
10 18225.251953 S 24947 Po
10 18225.253906 S 24947 B
13 18225.259766 ntask sched 13.000000
10 18225.261719 S 24947 Fi
10 18225.261719 S 24947 B
10 18225.263672 S 24947 chol_model_22
10 18228.529297 S 64 B
10 18228.531250 S 24947 Po
10 18228.531250 S 24947 B
13 18228.539062 ntask sched 12.000000
10 18228.539062 S 24947 Fi
10 18228.541016 S 24947 B
10 18228.542969 S 24947 chol_model_22
10 18231.824219 S 64 B
10 18231.826172 S 24947 Po
10 18231.828125 S 24947 B
13 18231.833984 ntask sched 11.000000
10 18231.835938 S 24947 Fi
10 18231.835938 S 24947 B
10 18231.837891 S 24947 chol_model_22
10 18235.107422 S 64 B
10 18235.107422 S 24947 Po
10 18235.109375 S 24947 B
13 18235.115234 ntask sched 10.000000
10 18235.117188 S 24947 Fi
10 18235.117188 S 24947 B
10 18235.119141 S 24947 chol_model_22
10 18238.394531 S 64 B
10 18238.394531 S 24947 Po
10 18238.396484 S 24947 B
13 18238.414062 ntask sched 11.000000
13 18238.419922 ntask sched 10.000000
10 18238.419922 S 24947 Fi
10 18238.421875 S 24947 B
10 18238.421875 S 24947 chol_model_22
10 18241.705078 S 64 B
10 18241.705078 S 24947 Po
10 18241.707031 S 24947 B
13 18241.714844 ntask sched 9.000000
10 18241.716797 S 24947 Fi
10 18241.716797 S 24947 B
10 18241.718750 S 24947 chol_model_22
10 18244.994141 S 64 B
10 18244.994141 S 24947 Po
10 18244.996094 S 24947 B
13 18245.001953 ntask sched 8.000000
10 18245.003906 S 24947 Fi
10 18245.005859 S 24947 B
10 18245.005859 S 24947 chol_model_22
10 18246.910156 S 0 B
10 18246.912109 S 24950 Po
10 18246.917969 S 24950 B
10 18246.937500 MS MEMNODE0 Co
18 18246.937500 L p 4000000 MEMNODE1 com_336
10 18246.955078 MS MEMNODE0 CoA
10 18247.367188 S 0 B
10 18247.369141 S 24948 Po
10 18247.371094 S 24948 B
13 18247.398438 ntask sched 9.000000
10 18248.287109 S 64 B
10 18248.289062 S 24947 Po
10 18248.291016 S 24947 B
10 18248.298828 MS MEMNODE1 Co
18 18248.298828 L p 4000000 MEMNODE0 com_337
10 18249.294922 S 0 B
10 18249.296875 S 24949 Po
10 18249.298828 S 24949 B
10 18250.257812 MS MEMNODE0 No
19 18250.257812 L p 1928086848 MEMNODE0 com_1928087104
10 18250.265625 MS MEMNODE1 CoA
13 18250.275391 ntask sched 8.000000
10 18250.277344 S 24950 Fi
10 18251.478516 MS MEMNODE1 No
19 18251.478516 L p 1928086912 MEMNODE1 com_1928086720
10 18251.486328 MS MEMNODE0 No
19 18251.486328 L p 4000000 MEMNODE0 com_336
10 18251.486328 S 24950 B
10 18251.488281 S 24950 chol_model_21
13 18251.498047 ntask sched 7.000000
10 18251.500000 S 24947 Fi
10 18251.503906 S 24947 B
10 18251.503906 S 24947 chol_model_22
13 18251.513672 ntask sched 8.000000
13 18251.527344 ntask sched 9.000000
10 18252.527344 S 0 B
10 18252.527344 S 24951 Po
10 18252.529297 S 24951 B
13 18252.552734 ntask sched 10.000000
13 18252.568359 ntask sched 11.000000
13 18252.582031 ntask sched 12.000000
10 18253.568359 S 0 B
10 18253.570312 S 24952 Po
10 18253.570312 S 24952 B
13 18253.591797 ntask sched 13.000000
13 18253.607422 ntask sched 14.000000
13 18253.621094 ntask sched 15.000000
13 18253.642578 ntask sched 16.000000
10 18254.800781 S 64 B
10 18254.800781 S 24947 Po
10 18254.802734 S 24947 B
10 18254.835938 MS MEMNODE1 No
19 18254.835938 L p 4000000 MEMNODE1 com_337
10 18254.837891 MS MEMNODE1 Co
18 18254.837891 L p 4000000 MEMNODE0 com_338
10 18254.843750 MS MEMNODE1 CoA
10 18256.019531 MS MEMNODE1 No
19 18256.019531 L p 1928086912 MEMNODE1 com_1928086720
10 18256.023438 MS MEMNODE1 Co
18 18256.023438 L p 4000000 MEMNODE0 com_339
10 18256.029297 MS MEMNODE1 CoA
10 18257.144531 MS MEMNODE1 No
19 18257.144531 L p 1928086912 MEMNODE1 com_1928086720
10 18257.148438 MS MEMNODE1 Co
18 18257.148438 L p 4000000 MEMNODE0 com_340
10 18257.154297 MS MEMNODE1 CoA
10 18258.269531 MS MEMNODE1 No
19 18258.269531 L p 1928086912 MEMNODE1 com_1928086720
13 18258.275391 ntask sched 15.000000
10 18258.277344 S 24947 Fi
10 18258.279297 S 24947 B
10 18258.281250 S 24947 chol_model_22
10 18261.576172 S 64 B
10 18261.578125 S 24947 Po
10 18261.580078 S 24947 B
10 18261.613281 MS MEMNODE1 No
19 18261.613281 L p 4000000 MEMNODE1 com_340
10 18261.615234 MS MEMNODE1 No
19 18261.615234 L p 4000000 MEMNODE1 com_339
10 18261.617188 MS MEMNODE1 No
19 18261.617188 L p 4000000 MEMNODE1 com_338
13 18261.619141 ntask sched 14.000000
10 18261.621094 S 24947 Fi
10 18261.623047 S 24947 B
10 18261.623047 S 24947 chol_model_22
10 18264.898438 S 64 B
10 18264.898438 S 24947 Po
10 18264.900391 S 24947 B
13 18264.906250 ntask sched 13.000000
10 18264.908203 S 24947 Fi
10 18264.910156 S 24947 B
10 18264.910156 S 24947 chol_model_22
10 18268.181641 S 64 B
10 18268.181641 S 24947 Po
10 18268.183594 S 24947 B
13 18268.189453 ntask sched 12.000000
10 18268.191406 S 24947 Fi
10 18268.191406 S 24947 B
10 18268.193359 S 24947 chol_model_21
10 18276.511719 S 64 B
10 18276.511719 S 24947 Po
10 18276.513672 S 24947 B
13 18276.535156 ntask sched 13.000000
13 18276.552734 ntask sched 14.000000
13 18276.566406 ntask sched 15.000000
13 18276.580078 ntask sched 16.000000
13 18276.595703 ntask sched 17.000000
13 18276.601562 ntask sched 16.000000
10 18276.601562 S 24947 Fi
10 18276.603516 S 24947 B
10 18276.603516 S 24947 chol_model_21
10 18284.910156 S 64 B
10 18284.910156 S 24947 Po
10 18284.912109 S 24947 B
13 18284.933594 ntask sched 17.000000
13 18284.947266 ntask sched 18.000000
13 18284.962891 ntask sched 19.000000
13 18284.976562 ntask sched 20.000000
13 18284.990234 ntask sched 21.000000
13 18285.005859 ntask sched 22.000000
10 18285.009766 MS MEMNODE1 Co
18 18285.009766 L p 4000000 MEMNODE0 com_341
10 18285.015625 MS MEMNODE1 CoA
10 18286.113281 MS MEMNODE1 No
19 18286.113281 L p 1928086912 MEMNODE1 com_1928086720
13 18286.119141 ntask sched 21.000000
10 18286.121094 S 24947 Fi
10 18286.123047 S 24947 B
10 18286.123047 S 24947 chol_model_21
10 18294.435547 S 64 B
10 18294.437500 S 24947 Po
10 18294.439453 S 24947 B
13 18294.458984 ntask sched 22.000000
13 18294.472656 ntask sched 23.000000
13 18294.488281 ntask sched 24.000000
13 18294.503906 ntask sched 25.000000
13 18294.517578 ntask sched 26.000000
13 18294.531250 ntask sched 27.000000
13 18294.546875 ntask sched 28.000000
10 18294.576172 MS MEMNODE1 No
19 18294.576172 L p 4000000 MEMNODE1 com_341
10 18294.578125 MS MEMNODE1 Co
18 18294.578125 L p 4000000 MEMNODE0 com_342
10 18294.582031 MS MEMNODE1 CoA
10 18295.681641 MS MEMNODE1 No
19 18295.681641 L p 1928086912 MEMNODE1 com_1928086720
10 18295.685547 MS MEMNODE1 Co
18 18295.685547 L p 4000000 MEMNODE0 com_343
10 18295.689453 MS MEMNODE1 CoA
10 18296.814453 MS MEMNODE1 No
19 18296.814453 L p 1928086912 MEMNODE1 com_1928086720
13 18296.820312 ntask sched 27.000000
10 18296.822266 S 24947 Fi
10 18296.824219 S 24947 B
10 18296.824219 S 24947 chol_model_22
10 18299.496094 S 0 B
10 18299.498047 S 24950 Po
10 18299.501953 S 24950 B
13 18299.531250 ntask sched 28.000000
10 18299.533203 MS MEMNODE0 Co
18 18299.533203 L p 4000000 MEMNODE1 com_344
13 18299.548828 ntask sched 29.000000
10 18299.548828 MS MEMNODE0 Co
18 18299.548828 L p 4000000 MEMNODE1 com_345
10 18299.550781 MS MEMNODE0 CoA
10 18299.558594 MS MEMNODE0 CoA
13 18299.568359 ntask sched 30.000000
10 18299.570312 MS MEMNODE0 Co
18 18299.570312 L p 4000000 MEMNODE1 com_346
13 18299.587891 ntask sched 31.000000
10 18299.587891 MS MEMNODE0 Co
18 18299.587891 L p 4000000 MEMNODE1 com_347
13 18299.603516 ntask sched 32.000000
13 18299.619141 ntask sched 33.000000
13 18299.638672 ntask sched 34.000000
13 18299.654297 ntask sched 35.000000
10 18299.658203 MS MEMNODE0 Co
18 18299.658203 L p 4000000 MEMNODE1 com_348
10 18300.125000 S 64 B
10 18300.126953 S 24947 Po
10 18300.128906 S 24947 B
13 18300.148438 ntask sched 36.000000
10 18302.314453 MS MEMNODE0 No
19 18302.314453 L p 1928086912 MEMNODE0 com_1928086720
10 18304.298828 MS MEMNODE0 No
19 18304.298828 L p 1928086920 MEMNODE0 com_1928086720
10 18304.308594 MS MEMNODE0 CoA
10 18304.318359 MS MEMNODE0 CoA
10 18304.328125 MS MEMNODE0 CoA
10 18304.337891 MS MEMNODE1 No
19 18304.337891 L p 4000000 MEMNODE1 com_343
10 18306.349609 MS MEMNODE0 No
19 18306.349609 L p 0 MEMNODE0 com_0
13 18306.359375 ntask sched 35.000000
10 18306.361328 S 24949 Fi
10 18307.726562 MS MEMNODE0 No
19 18307.726562 L p 1928086912 MEMNODE0 com_1928086720
10 18309.162109 MS MEMNODE0 No
19 18309.162109 L p 1928086920 MEMNODE0 com_1928086720
13 18309.173828 ntask sched 34.000000
10 18309.175781 S 24948 Fi
10 18309.175781 MS MEMNODE1 No
19 18309.175781 L p 4000000 MEMNODE1 com_342
10 18309.177734 MS MEMNODE1 Co
18 18309.177734 L p 4000000 MEMNODE0 com_349
10 18309.212891 MS MEMNODE0 Co
18 18309.212891 L p 4000000 MEMNODE1 com_350
10 18309.216797 MS MEMNODE0 No
19 18309.216797 L p 4000000 MEMNODE0 com_345
10 18309.218750 MS MEMNODE0 Co
18 18309.218750 L p 4000000 MEMNODE1 com_351
10 18309.222656 MS MEMNODE0 CoA
13 18309.240234 ntask sched 33.000000
10 18309.242188 S 24952 Fi
10 18311.195312 MS MEMNODE0 No
19 18311.195312 L p 1928086912 MEMNODE0 com_1928086720
10 18311.199219 MS MEMNODE0 No
19 18311.199219 L p 4000000 MEMNODE0 com_344
10 18311.203125 S 24948 B
13 18311.203125 ntask sched 32.000000
10 18311.203125 S 24948 chol_model_22
10 18311.205078 S 24950 Fi
13 18311.216797 ntask sched 31.000000
10 18311.220703 S 24951 Fi
10 18312.664062 MS MEMNODE0 No
19 18312.664062 L p 1928086912 MEMNODE0 com_1928086720
10 18312.673828 MS MEMNODE1 CoA
10 18312.681641 MS MEMNODE0 No
19 18312.681641 L p 4000000 MEMNODE0 com_347
10 18313.794922 MS MEMNODE1 No
19 18313.794922 L p 0 MEMNODE1 com_0
10 18313.798828 MS MEMNODE0 No
19 18313.798828 L p 4000000 MEMNODE0 com_346
10 18313.810547 S 24949 B
10 18313.812500 S 24949 chol_model_22
10 18313.816406 MS MEMNODE0 No
19 18313.816406 L p 4000000 MEMNODE0 com_350
10 18313.826172 MS MEMNODE0 No
19 18313.826172 L p 4000000 MEMNODE0 com_348
10 18313.837891 MS MEMNODE1 Co
18 18313.837891 L p 4000000 MEMNODE0 com_352
10 18313.837891 S 24951 B
10 18313.837891 S 24952 B
10 18313.839844 S 24951 chol_model_22
10 18313.839844 S 24950 B
10 18313.841797 S 24952 chol_model_22
10 18313.841797 S 24950 chol_model_22
10 18313.845703 MS MEMNODE1 CoA
10 18315.162109 MS MEMNODE1 No
19 18315.162109 L p 1928086912 MEMNODE1 com_1928086720
13 18315.171875 ntask sched 30.000000
10 18315.173828 S 24947 Fi
10 18315.175781 S 24947 B
10 18315.177734 S 24947 chol_model_22
10 18318.478516 S 64 B
10 18318.478516 S 24947 Po
10 18318.480469 S 24947 B
10 18318.492188 MS MEMNODE1 No
19 18318.492188 L p 4000000 MEMNODE1 com_352
10 18318.494141 MS MEMNODE1 No
19 18318.494141 L p 4000000 MEMNODE1 com_349
13 18318.496094 ntask sched 29.000000
10 18318.498047 S 24947 Fi
10 18318.498047 S 24947 B
10 18318.500000 S 24947 chol_model_22
10 18321.775391 S 64 B
10 18321.777344 S 24947 Po
10 18321.777344 S 24947 B
13 18321.783203 ntask sched 28.000000
10 18321.785156 S 24947 Fi
10 18321.787109 S 24947 B
10 18321.787109 S 24947 chol_model_22
10 18325.060547 S 64 B
10 18325.060547 S 24947 Po
10 18325.062500 S 24947 B
13 18325.068359 ntask sched 27.000000
10 18325.070312 S 24947 Fi
10 18325.072266 S 24947 B
10 18325.072266 S 24947 chol_model_22
10 18328.345703 S 64 B
10 18328.347656 S 24947 Po
10 18328.347656 S 24947 B
13 18328.353516 ntask sched 26.000000
10 18328.355469 S 24947 Fi
10 18328.357422 S 24947 B
10 18328.357422 S 24947 chol_model_22
10 18331.636719 S 64 B
10 18331.636719 S 24947 Po
10 18331.638672 S 24947 B
13 18331.646484 ntask sched 25.000000
10 18331.646484 S 24947 Fi
10 18331.648438 S 24947 B
10 18331.648438 S 24947 chol_model_22
10 18334.923828 S 64 B
10 18334.923828 S 24947 Po
10 18334.925781 S 24947 B
13 18334.931641 ntask sched 24.000000
10 18334.931641 S 24947 Fi
10 18334.933594 S 24947 B
10 18334.935547 S 24947 chol_model_22
10 18338.210938 S 64 B
10 18338.210938 S 24947 Po
10 18338.212891 S 24947 B
13 18338.220703 ntask sched 23.000000
10 18338.220703 S 24947 Fi
10 18338.222656 S 24947 B
10 18338.224609 S 24947 chol_model_22
10 18341.501953 S 64 B
10 18341.503906 S 24947 Po
10 18341.505859 S 24947 B
13 18341.511719 ntask sched 22.000000
10 18341.513672 S 24947 Fi
10 18341.513672 S 24947 B
10 18341.515625 S 24947 chol_model_22
10 18344.787109 S 64 B
10 18344.787109 S 24947 Po
10 18344.789062 S 24947 B
13 18344.796875 ntask sched 21.000000
10 18344.796875 S 24947 Fi
10 18344.798828 S 24947 B
10 18344.798828 S 24947 chol_model_22
10 18348.076172 S 64 B
10 18348.078125 S 24947 Po
10 18348.078125 S 24947 B
13 18348.085938 ntask sched 20.000000
10 18348.087891 S 24947 Fi
10 18348.089844 S 24947 B
10 18348.089844 S 24947 chol_model_22
10 18351.363281 S 64 B
10 18351.363281 S 24947 Po
10 18351.365234 S 24947 B
13 18351.371094 ntask sched 19.000000
10 18351.371094 S 24947 Fi
10 18351.373047 S 24947 B
10 18351.375000 S 24947 chol_model_22
10 18354.656250 S 64 B
10 18354.656250 S 24947 Po
10 18354.658203 S 24947 B
13 18354.664062 ntask sched 18.000000
10 18354.666016 S 24947 Fi
10 18354.667969 S 24947 B
10 18354.667969 S 24947 chol_model_22
10 18357.937500 S 64 B
10 18357.937500 S 24947 Po
10 18357.939453 S 24947 B
13 18357.945312 ntask sched 17.000000
10 18357.947266 S 24947 Fi
10 18357.947266 S 24947 B
10 18357.949219 S 24947 chol_model_22
10 18361.234375 S 64 B
10 18361.234375 S 24947 Po
10 18361.236328 S 24947 B
13 18361.246094 ntask sched 16.000000
10 18361.246094 S 24947 Fi
10 18361.248047 S 24947 B
10 18361.248047 S 24947 chol_model_22
10 18364.541016 S 64 B
10 18364.542969 S 24947 Po
10 18364.544922 S 24947 B
13 18364.550781 ntask sched 15.000000
10 18364.550781 S 24947 Fi
10 18364.552734 S 24947 B
10 18364.554688 S 24947 chol_model_22
10 18376.289062 S 64 B
10 18376.289062 S 24947 Po
10 18376.292969 S 24947 B
13 18376.300781 ntask sched 14.000000
10 18376.302734 S 24947 Fi
10 18376.304688 S 24947 B
10 18376.304688 S 24947 chol_model_22
10 18388.394531 S 64 B
10 18388.396484 S 24947 Po
10 18388.398438 S 24947 B
13 18388.406250 ntask sched 13.000000
10 18388.408203 S 24947 Fi
10 18388.408203 S 24947 B
10 18388.410156 S 24947 chol_model_22
10 18391.695312 S 64 B
10 18391.697266 S 24947 Po
10 18391.697266 S 24947 B
13 18391.705078 ntask sched 12.000000
10 18391.705078 S 24947 Fi
10 18391.707031 S 24947 B
10 18391.707031 S 24947 chol_model_22
10 18394.978516 S 64 B
10 18394.978516 S 24947 Po
10 18394.980469 S 24947 B
13 18394.986328 ntask sched 11.000000
10 18394.988281 S 24947 Fi
10 18394.988281 S 24947 B
10 18394.990234 S 24947 chol_model_22
10 18398.267578 S 64 B
10 18398.269531 S 24947 Po
10 18398.271484 S 24947 B
13 18398.277344 ntask sched 10.000000
10 18398.279297 S 24947 Fi
10 18398.281250 S 24947 B
10 18398.281250 S 24947 chol_model_22
10 18401.554688 S 64 B
10 18401.556641 S 24947 Po
10 18401.558594 S 24947 B
13 18401.564453 ntask sched 9.000000
10 18401.566406 S 24947 Fi
10 18401.566406 S 24947 B
10 18401.568359 S 24947 chol_model_22
10 18402.648438 S 0 B
10 18402.650391 S 24948 Po
10 18402.656250 S 24948 B
10 18402.732422 MS MEMNODE0 No
19 18402.732422 L p 4000000 MEMNODE0 com_351
13 18402.738281 ntask sched 8.000000
10 18402.740234 S 24948 Fi
10 18402.742188 S 24948 B
10 18402.744141 S 24948 chol_model_11
10 18404.810547 S 0 B
10 18404.812500 S 24952 Po
10 18404.814453 S 24952 B
10 18404.855469 S 64 B
10 18404.855469 S 24947 Po
10 18404.857422 S 24947 B
13 18404.865234 ntask sched 7.000000
10 18404.867188 S 24947 Fi
10 18404.869141 S 24947 B
10 18404.869141 S 24947 chol_model_22
10 18405.261719 S 0 B
10 18405.263672 S 24949 Po
10 18405.265625 S 24949 B
10 18405.671875 S 0 B
10 18405.673828 S 24950 Po
10 18405.675781 S 24950 B
10 18408.152344 S 64 B
10 18408.152344 S 24947 Po
10 18408.154297 S 24947 B
13 18408.162109 ntask sched 6.000000
10 18408.164062 S 24947 Fi
10 18408.166016 S 24947 B
10 18408.167969 S 24947 chol_model_22
10 18411.437500 S 64 B
10 18411.437500 S 24947 Po
10 18411.439453 S 24947 B
13 18411.445312 ntask sched 5.000000
10 18411.447266 S 24947 Fi
10 18411.449219 S 24947 B
10 18411.449219 S 24947 chol_model_22
10 18414.728516 S 64 B
10 18414.730469 S 24947 Po
10 18414.732422 S 24947 B
13 18414.738281 ntask sched 4.000000
10 18414.740234 S 24947 Fi
10 18414.742188 S 24947 B
10 18414.742188 S 24947 chol_model_22
10 18416.789062 S 0 B
10 18416.789062 S 24951 Po
10 18416.792969 S 24951 B
10 18418.007812 S 64 B
10 18418.007812 S 24947 Po
10 18418.009766 S 24947 B
13 18418.015625 ntask sched 3.000000
10 18418.017578 S 24947 Fi
10 18418.019531 S 24947 B
10 18418.019531 S 24947 chol_model_22
10 18421.294922 S 64 B
10 18421.294922 S 24947 Po
10 18421.296875 S 24947 B
13 18421.302734 ntask sched 2.000000
10 18421.304688 S 24947 Fi
10 18421.306641 S 24947 B
10 18421.306641 S 24947 chol_model_22
10 18424.582031 S 64 B
10 18424.582031 S 24947 Po
10 18424.583984 S 24947 B
13 18424.591797 ntask sched 1.000000
10 18424.591797 S 24947 Fi
10 18424.593750 S 24947 B
10 18424.593750 S 24947 chol_model_22
10 18427.865234 S 64 B
10 18427.865234 S 24947 Po
10 18427.867188 S 24947 B
13 18427.873047 ntask sched 0.000000
10 18427.875000 S 24947 Fi
10 18427.876953 S 24947 B
10 18427.876953 S 24947 chol_model_22
10 18431.146484 S 64 B
10 18431.148438 S 24947 Po
10 18431.150391 S 24947 B
10 18469.552734 S 0 B
10 18469.554688 S 24948 Po
10 18469.556641 S 24948 B
13 18469.591797 ntask sched 1.000000
10 18469.591797 MS MEMNODE1 Co
18 18469.591797 L p 4000000 MEMNODE0 com_353
10 18469.601562 MS MEMNODE1 CoA
10 18470.765625 MS MEMNODE1 No
19 18470.765625 L p 1928086912 MEMNODE1 com_1928086720
13 18470.771484 ntask sched 0.000000
10 18470.773438 S 24947 Fi
13 18470.816406 ntask sched 1.000000
13 18470.841797 ntask sched 2.000000
13 18470.857422 ntask sched 3.000000
13 18470.873047 ntask sched 4.000000
13 18470.888672 ntask sched 5.000000
13 18470.904297 ntask sched 6.000000
10 18470.906250 MS MEMNODE0 Co
18 18470.906250 L p 4000000 MEMNODE1 com_354
13 18470.910156 ntask sched 5.000000
13 18470.912109 ntask sched 4.000000
10 18470.912109 S 24949 Fi
10 18470.912109 S 24948 Fi
10 18470.914062 S 24948 B
10 18470.914062 S 24948 chol_model_21
10 18470.916016 MS MEMNODE0 CoA
10 18472.359375 MS MEMNODE0 No
19 18472.359375 L p 1928086912 MEMNODE0 com_1928086720
10 18472.363281 MS MEMNODE1 No
19 18472.363281 L p 4000000 MEMNODE1 com_353
10 18472.365234 S 24947 B
10 18472.365234 S 24947 chol_model_21
10 18472.416016 MS MEMNODE0 No
19 18472.416016 L p 4000000 MEMNODE0 com_354
10 18472.417969 S 24949 B
10 18472.419922 S 24949 chol_model_21
10 18480.714844 S 64 B
10 18480.716797 S 24947 Po
10 18480.718750 S 24947 B
13 18480.742188 ntask sched 5.000000
13 18480.748047 ntask sched 4.000000
10 18480.748047 S 24947 Fi
10 18480.751953 S 24947 B
10 18480.751953 S 24947 chol_model_21
10 18489.056641 S 64 B
10 18489.056641 S 24947 Po
10 18489.058594 S 24947 B
13 18489.076172 ntask sched 5.000000
13 18489.091797 ntask sched 6.000000
13 18489.095703 ntask sched 5.000000
10 18489.097656 S 24947 Fi
10 18489.097656 S 24947 B
10 18489.097656 S 24947 chol_model_21
10 18497.400391 S 64 B
10 18497.402344 S 24947 Po
10 18497.404297 S 24947 B
13 18497.421875 ntask sched 6.000000
13 18497.435547 ntask sched 7.000000
13 18497.449219 ntask sched 8.000000
13 18497.455078 ntask sched 7.000000
10 18497.455078 S 24947 Fi
10 18497.457031 S 24947 B
10 18497.457031 S 24947 chol_model_21
10 18505.765625 S 64 B
10 18505.767578 S 24947 Po
10 18505.769531 S 24947 B
13 18505.787109 ntask sched 8.000000
13 18505.800781 ntask sched 9.000000
13 18505.814453 ntask sched 10.000000
13 18505.828125 ntask sched 11.000000
13 18505.832031 ntask sched 10.000000
10 18505.833984 S 24947 Fi
10 18505.835938 S 24947 B
10 18505.835938 S 24947 chol_model_21
10 18514.140625 S 64 B
10 18514.140625 S 24947 Po
10 18514.142578 S 24947 B
13 18514.160156 ntask sched 11.000000
13 18514.175781 ntask sched 12.000000
13 18514.187500 ntask sched 13.000000
13 18514.201172 ntask sched 14.000000
13 18514.216797 ntask sched 15.000000
13 18514.220703 ntask sched 14.000000
10 18514.220703 S 24947 Fi
10 18514.222656 S 24947 B
10 18514.222656 S 24947 chol_model_22
10 18517.505859 S 64 B
10 18517.507812 S 24947 Po
10 18517.507812 S 24947 B
13 18517.527344 ntask sched 15.000000
10 18517.527344 MS MEMNODE0 Co
18 18517.527344 L p 4000000 MEMNODE1 com_355
13 18517.533203 ntask sched 14.000000
10 18517.535156 MS MEMNODE0 CoA
10 18517.535156 S 24947 Fi
10 18517.535156 S 24947 B
10 18517.537109 S 24947 chol_model_22
13 18517.537109 ntask sched 13.000000
10 18517.544922 S 24950 Fi
10 18519.140625 S 0 B
10 18519.144531 S 24948 Po
10 18519.146484 S 24948 B
13 18519.179688 ntask sched 14.000000
13 18519.193359 ntask sched 15.000000
13 18519.207031 ntask sched 16.000000
13 18519.220703 ntask sched 17.000000
13 18519.234375 ntask sched 18.000000
13 18519.246094 ntask sched 19.000000
10 18519.492188 MS MEMNODE0 No
19 18519.492188 L p 1928086912 MEMNODE0 com_1928086720
10 18520.392578 S 0 B
10 18520.394531 S 24949 Po
10 18520.396484 S 24949 B
13 18520.417969 ntask sched 20.000000
13 18520.433594 ntask sched 21.000000
13 18520.449219 ntask sched 22.000000
13 18520.464844 ntask sched 23.000000
13 18520.480469 ntask sched 24.000000
13 18520.496094 ntask sched 25.000000
13 18520.511719 ntask sched 26.000000
10 18522.767578 S 64 B
10 18522.767578 S 24947 Po
10 18522.769531 S 24947 B
10 18522.777344 MS MEMNODE1 Co
18 18522.777344 L p 4000000 MEMNODE0 com_356
10 18522.783203 MS MEMNODE1 CoA
10 18523.968750 MS MEMNODE1 No
19 18523.968750 L p 1928086912 MEMNODE1 com_1928086720
10 18523.972656 MS MEMNODE1 Co
18 18523.972656 L p 4000000 MEMNODE0 com_357
10 18523.976562 MS MEMNODE0 No
19 18523.976562 L p 4000000 MEMNODE0 com_355
10 18523.978516 MS MEMNODE1 CoA
10 18523.978516 S 24950 B
10 18523.980469 S 24950 chol_model_11
10 18525.119141 MS MEMNODE1 No
19 18525.119141 L p 1928086912 MEMNODE1 com_1928086720
10 18525.123047 MS MEMNODE1 Co
18 18525.123047 L p 4000000 MEMNODE0 com_358
10 18525.128906 MS MEMNODE1 CoA
10 18526.265625 MS MEMNODE1 No
19 18526.265625 L p 1928086912 MEMNODE1 com_1928086720
10 18526.269531 MS MEMNODE1 Co
18 18526.269531 L p 4000000 MEMNODE0 com_359
10 18526.273438 MS MEMNODE1 CoA
10 18527.406250 MS MEMNODE1 No
19 18527.406250 L p 1928086912 MEMNODE1 com_1928086720
10 18527.410156 MS MEMNODE1 Co
18 18527.410156 L p 4000000 MEMNODE0 com_360
10 18527.414062 MS MEMNODE1 CoA
10 18528.548828 MS MEMNODE1 No
19 18528.548828 L p 1928086912 MEMNODE1 com_1928086720
10 18528.552734 MS MEMNODE1 Co
18 18528.552734 L p 4000000 MEMNODE0 com_361
10 18528.556641 MS MEMNODE1 CoA
10 18529.724609 MS MEMNODE1 No
19 18529.724609 L p 1928086912 MEMNODE1 com_1928086720
13 18529.730469 ntask sched 25.000000
10 18529.734375 S 24947 Fi
10 18529.736328 S 24947 B
10 18529.738281 S 24947 chol_model_22
10 18533.044922 S 64 B
10 18533.046875 S 24947 Po
10 18533.048828 S 24947 B
10 18533.082031 MS MEMNODE1 No
19 18533.082031 L p 4000000 MEMNODE1 com_361
10 18533.085938 MS MEMNODE1 No
19 18533.085938 L p 4000000 MEMNODE1 com_360
10 18533.087891 MS MEMNODE1 No
19 18533.087891 L p 4000000 MEMNODE1 com_359
10 18533.089844 MS MEMNODE1 No
19 18533.089844 L p 4000000 MEMNODE1 com_358
10 18533.093750 MS MEMNODE1 No
19 18533.093750 L p 4000000 MEMNODE1 com_357
10 18533.095703 MS MEMNODE1 No
19 18533.095703 L p 4000000 MEMNODE1 com_356
13 18533.097656 ntask sched 24.000000
10 18533.097656 S 24947 Fi
10 18533.099609 S 24947 B
10 18533.101562 S 24947 chol_model_22
10 18536.373047 S 64 B
10 18536.375000 S 24947 Po
10 18536.376953 S 24947 B
13 18536.384766 ntask sched 23.000000
10 18536.384766 S 24947 Fi
10 18536.386719 S 24947 B
10 18536.386719 S 24947 chol_model_22
10 18539.666016 S 64 B
10 18539.667969 S 24947 Po
10 18539.667969 S 24947 B
13 18539.673828 ntask sched 22.000000
10 18539.675781 S 24947 Fi
10 18539.677734 S 24947 B
10 18539.677734 S 24947 chol_model_22
10 18542.949219 S 64 B
10 18542.951172 S 24947 Po
10 18542.953125 S 24947 B
13 18542.958984 ntask sched 21.000000
10 18542.960938 S 24947 Fi
10 18542.962891 S 24947 B
10 18542.962891 S 24947 chol_model_22
10 18546.240234 S 64 B
10 18546.242188 S 24947 Po
10 18546.244141 S 24947 B
13 18546.250000 ntask sched 20.000000
10 18546.251953 S 24947 Fi
10 18546.253906 S 24947 B
10 18546.253906 S 24947 chol_model_22
10 18549.527344 S 64 B
10 18549.529297 S 24947 Po
10 18549.531250 S 24947 B
13 18549.537109 ntask sched 19.000000
10 18549.537109 S 24947 Fi
10 18549.539062 S 24947 B
10 18549.539062 S 24947 chol_model_22
10 18552.820312 S 64 B
10 18552.820312 S 24947 Po
10 18552.822266 S 24947 B
13 18552.828125 ntask sched 18.000000
10 18552.830078 S 24947 Fi
10 18552.830078 S 24947 B
10 18552.832031 S 24947 chol_model_22
10 18556.103516 S 64 B
10 18556.105469 S 24947 Po
10 18556.105469 S 24947 B
13 18556.113281 ntask sched 17.000000
10 18556.113281 S 24947 Fi
10 18556.115234 S 24947 B
10 18556.115234 S 24947 chol_model_22
10 18559.394531 S 64 B
10 18559.394531 S 24947 Po
10 18559.396484 S 24947 B
13 18559.402344 ntask sched 16.000000
10 18559.402344 S 24947 Fi
10 18559.404297 S 24947 B
10 18559.406250 S 24947 chol_model_22
10 18562.685547 S 64 B
10 18562.685547 S 24947 Po
10 18562.687500 S 24947 B
13 18562.693359 ntask sched 15.000000
10 18562.695312 S 24947 Fi
10 18562.695312 S 24947 B
10 18562.697266 S 24947 chol_model_22
10 18565.964844 S 64 B
10 18565.964844 S 24947 Po
10 18565.966797 S 24947 B
13 18565.972656 ntask sched 14.000000
10 18565.974609 S 24947 Fi
10 18565.974609 S 24947 B
10 18565.976562 S 24947 chol_model_22
10 18569.248047 S 64 B
10 18569.250000 S 24947 Po
10 18569.251953 S 24947 B
13 18569.257812 ntask sched 13.000000
10 18569.259766 S 24947 Fi
10 18569.259766 S 24947 B
10 18569.261719 S 24947 chol_model_22
10 18572.535156 S 64 B
10 18572.535156 S 24947 Po
10 18572.537109 S 24947 B
13 18572.544922 ntask sched 12.000000
10 18572.544922 S 24947 Fi
10 18572.546875 S 24947 B
10 18572.546875 S 24947 chol_model_22
10 18575.822266 S 64 B
10 18575.822266 S 24947 Po
10 18575.824219 S 24947 B
13 18575.832031 ntask sched 11.000000
10 18575.832031 S 24947 Fi
10 18575.835938 S 24947 B
10 18575.835938 S 24947 chol_model_22
10 18579.111328 S 64 B
10 18579.113281 S 24947 Po
10 18579.113281 S 24947 B
13 18579.121094 ntask sched 10.000000
10 18579.121094 S 24947 Fi
10 18579.123047 S 24947 B
10 18579.123047 S 24947 chol_model_22
10 18582.394531 S 64 B
10 18582.396484 S 24947 Po
10 18582.396484 S 24947 B
13 18582.402344 ntask sched 9.000000
10 18582.404297 S 24947 Fi
10 18582.406250 S 24947 B
10 18582.406250 S 24947 chol_model_22
10 18585.679688 S 64 B
10 18585.679688 S 24947 Po
10 18585.681641 S 24947 B
13 18585.687500 ntask sched 8.000000
10 18585.689453 S 24947 Fi
10 18585.691406 S 24947 B
10 18585.691406 S 24947 chol_model_22
10 18588.957031 S 64 B
10 18588.957031 S 24947 Po
10 18588.958984 S 24947 B
13 18588.964844 ntask sched 7.000000
10 18588.966797 S 24947 Fi
10 18588.968750 S 24947 B
10 18588.968750 S 24947 chol_model_22
10 18590.671875 S 0 B
10 18590.673828 S 24950 Po
10 18590.675781 S 24950 B
13 18590.703125 ntask sched 8.000000
13 18590.718750 ntask sched 9.000000
13 18590.734375 ntask sched 10.000000
10 18590.736328 MS MEMNODE0 Co
18 18590.736328 L p 4000000 MEMNODE1 com_362
13 18590.738281 ntask sched 9.000000
10 18590.740234 S 24948 Fi
10 18590.744141 MS MEMNODE0 CoA
13 18590.751953 ntask sched 10.000000
10 18590.751953 MS MEMNODE0 Co
18 18590.751953 L p 4000000 MEMNODE1 com_363
13 18590.765625 ntask sched 11.000000
10 18590.767578 MS MEMNODE0 Co
18 18590.767578 L p 4000000 MEMNODE1 com_364
13 18590.771484 ntask sched 10.000000
10 18590.773438 S 24950 Fi
10 18592.248047 S 64 B
10 18592.248047 S 24947 Po
10 18592.250000 S 24947 B
10 18592.257812 MS MEMNODE1 Co
18 18592.257812 L p 4000000 MEMNODE0 com_365
10 18593.537109 MS MEMNODE0 No
19 18593.537109 L p 0 MEMNODE0 com_0
10 18593.546875 MS MEMNODE0 CoA
10 18593.554688 MS MEMNODE0 CoA
10 18595.501953 MS MEMNODE0 No
19 18595.501953 L p 1928086912 MEMNODE0 com_1928086720
10 18595.521484 MS MEMNODE1 CoA
10 18596.906250 MS MEMNODE0 No
19 18596.906250 L p 1928086912 MEMNODE0 com_1928086720
13 18596.925781 ntask sched 9.000000
10 18596.927734 S 24949 Fi
10 18598.097656 MS MEMNODE1 No
19 18598.097656 L p 1928086912 MEMNODE1 com_1928086720
10 18598.103516 MS MEMNODE0 No
19 18598.103516 L p 4000000 MEMNODE0 com_362
10 18598.109375 MS MEMNODE0 No
19 18598.109375 L p 4000000 MEMNODE0 com_364
10 18598.111328 S 24950 B
10 18598.111328 S 24950 chol_model_21
10 18598.140625 S 24948 B
10 18598.140625 S 24948 chol_model_21
13 18598.140625 ntask sched 8.000000
10 18598.142578 MS MEMNODE0 No
19 18598.142578 L p 4000000 MEMNODE0 com_363
10 18598.142578 S 24947 Fi
10 18598.144531 S 24947 B
10 18598.146484 S 24947 chol_model_22
10 18598.146484 S 24949 B
10 18598.148438 S 24949 chol_model_21
10 18601.427734 S 64 B
10 18601.427734 S 24947 Po
10 18601.429688 S 24947 B
13 18601.453125 ntask sched 9.000000
10 18601.482422 MS MEMNODE1 No
19 18601.482422 L p 4000000 MEMNODE1 com_365
13 18601.484375 ntask sched 8.000000
10 18601.486328 S 24947 Fi
10 18601.486328 S 24947 B
10 18601.488281 S 24947 chol_model_22
10 18604.763672 S 64 B
10 18604.763672 S 24947 Po
10 18604.765625 S 24947 B
13 18604.771484 ntask sched 7.000000
10 18604.773438 S 24947 Fi
10 18604.775391 S 24947 B
10 18604.775391 S 24947 chol_model_22
10 18608.052734 S 64 B
10 18608.052734 S 24947 Po
10 18608.054688 S 24947 B
13 18608.060547 ntask sched 6.000000
10 18608.060547 S 24947 Fi
10 18608.062500 S 24947 B
10 18608.062500 S 24947 chol_model_22
10 18611.332031 S 64 B
10 18611.332031 S 24947 Po
10 18611.333984 S 24947 B
13 18611.339844 ntask sched 5.000000
10 18611.341797 S 24947 Fi
10 18611.341797 S 24947 B
10 18611.343750 S 24947 chol_model_22
10 18614.613281 S 64 B
10 18614.613281 S 24947 Po
10 18614.615234 S 24947 B
13 18614.621094 ntask sched 4.000000
10 18614.623047 S 24947 Fi
10 18614.625000 S 24947 B
10 18614.626953 S 24947 chol_model_22
10 18617.914062 S 64 B
10 18617.914062 S 24947 Po
10 18617.917969 S 24947 B
13 18617.923828 ntask sched 3.000000
10 18617.925781 S 24947 Fi
10 18617.927734 S 24947 B
10 18617.927734 S 24947 chol_model_22
10 18621.203125 S 64 B
10 18621.203125 S 24947 Po
10 18621.205078 S 24947 B
13 18621.212891 ntask sched 2.000000
10 18621.214844 S 24947 Fi
10 18621.214844 S 24947 B
10 18621.216797 S 24947 chol_model_21
10 18629.521484 S 64 B
10 18629.521484 S 24947 Po
10 18629.523438 S 24947 B
13 18629.542969 ntask sched 3.000000
13 18629.546875 ntask sched 2.000000
10 18629.546875 S 24947 Fi
10 18629.548828 S 24947 B
10 18629.548828 S 24947 chol_model_21
10 18637.857422 S 64 B
10 18637.857422 S 24947 Po
10 18637.859375 S 24947 B
13 18637.876953 ntask sched 3.000000
13 18637.888672 ntask sched 4.000000
13 18637.894531 ntask sched 3.000000
10 18637.896484 S 24947 Fi
10 18637.896484 S 24947 B
10 18637.898438 S 24947 chol_model_21
10 18646.205078 S 64 B
10 18646.207031 S 24947 Po
10 18646.207031 S 24947 B
13 18646.226562 ntask sched 4.000000
13 18646.240234 ntask sched 5.000000
13 18646.255859 ntask sched 6.000000
13 18646.259766 ntask sched 5.000000
10 18646.261719 S 24947 Fi
10 18646.261719 S 24947 B
10 18646.263672 S 24947 chol_model_22
10 18646.804688 S 0 B
10 18646.806641 S 0 B
10 18646.806641 S 24950 Po
10 18646.806641 S 24949 Po
10 18646.806641 S 24948 Po
10 18646.812500 S 24948 B
10 18646.812500 S 24949 B
10 18646.820312 S 24950 B
13 18646.847656 ntask sched 6.000000
13 18646.849609 ntask sched 7.000000
13 18646.863281 ntask sched 8.000000
13 18646.865234 ntask sched 9.000000
13 18646.871094 ntask sched 10.000000
13 18646.880859 ntask sched 11.000000
13 18646.886719 ntask sched 12.000000
13 18646.890625 ntask sched 13.000000
13 18646.896484 ntask sched 14.000000
13 18646.902344 ntask sched 15.000000
13 18646.910156 ntask sched 16.000000
13 18646.914062 ntask sched 17.000000
13 18646.921875 ntask sched 18.000000
13 18646.929688 ntask sched 19.000000
13 18646.945312 ntask sched 20.000000
10 18649.542969 S 64 B
10 18649.542969 S 24947 Po
10 18649.544922 S 24947 B
13 18649.564453 ntask sched 21.000000
10 18649.566406 MS MEMNODE0 Co
18 18649.566406 L p 4000000 MEMNODE1 com_366
13 18649.566406 ntask sched 20.000000
10 18649.568359 S 24948 Fi
10 18649.570312 MS MEMNODE1 Co
18 18649.570312 L p 4000000 MEMNODE0 com_367
10 18649.576172 MS MEMNODE1 CoA
10 18650.703125 MS MEMNODE1 No
19 18650.703125 L p 1928086912 MEMNODE1 com_1928086720
10 18650.712891 MS MEMNODE0 CoA
10 18650.724609 MS MEMNODE1 Co
18 18650.724609 L p 4000000 MEMNODE0 com_368
10 18652.878906 MS MEMNODE0 No
19 18652.878906 L p 0 MEMNODE0 com_0
10 18652.886719 MS MEMNODE1 CoA
10 18654.042969 MS MEMNODE1 No
19 18654.042969 L p 1928086912 MEMNODE1 com_1928086720
10 18654.048828 MS MEMNODE0 No
19 18654.048828 L p 4000000 MEMNODE0 com_366
10 18654.054688 MS MEMNODE1 Co
18 18654.054688 L p 4000000 MEMNODE0 com_369
10 18654.060547 MS MEMNODE1 CoA
10 18654.062500 S 24948 B
10 18654.062500 S 24948 chol_model_11
10 18655.228516 MS MEMNODE1 No
19 18655.228516 L p 1928086912 MEMNODE1 com_1928086720
13 18655.234375 ntask sched 19.000000
10 18655.238281 S 24947 Fi
10 18655.240234 S 24947 B
10 18655.242188 S 24947 chol_model_22
10 18658.539062 S 64 B
10 18658.541016 S 24947 Po
10 18658.542969 S 24947 B
10 18658.574219 MS MEMNODE1 No
19 18658.574219 L p 4000000 MEMNODE1 com_369
10 18658.578125 MS MEMNODE1 No
19 18658.578125 L p 4000000 MEMNODE1 com_368
10 18658.580078 MS MEMNODE1 No
19 18658.580078 L p 4000000 MEMNODE1 com_367
13 18658.582031 ntask sched 18.000000
10 18658.583984 S 24947 Fi
10 18658.585938 S 24947 B
10 18658.585938 S 24947 chol_model_22
10 18661.861328 S 64 B
10 18661.861328 S 24947 Po
10 18661.863281 S 24947 B
13 18661.869141 ntask sched 17.000000
10 18661.871094 S 24947 Fi
10 18661.871094 S 24947 B
10 18661.873047 S 24947 chol_model_22
10 18665.150391 S 64 B
10 18665.150391 S 24947 Po
10 18665.152344 S 24947 B
13 18665.158203 ntask sched 16.000000
10 18665.160156 S 24947 Fi
10 18665.160156 S 24947 B
10 18665.162109 S 24947 chol_model_22
10 18668.439453 S 64 B
10 18668.439453 S 24947 Po
10 18668.441406 S 24947 B
13 18668.447266 ntask sched 15.000000
10 18668.447266 S 24947 Fi
10 18668.449219 S 24947 B
10 18668.449219 S 24947 chol_model_22
10 18671.722656 S 64 B
10 18671.724609 S 24947 Po
10 18671.726562 S 24947 B
13 18671.732422 ntask sched 14.000000
10 18671.732422 S 24947 Fi
10 18671.734375 S 24947 B
10 18671.734375 S 24947 chol_model_22
10 18675.009766 S 64 B
10 18675.009766 S 24947 Po
10 18675.011719 S 24947 B
13 18675.017578 ntask sched 13.000000
10 18675.019531 S 24947 Fi
10 18675.021484 S 24947 B
10 18675.021484 S 24947 chol_model_22
10 18678.294922 S 64 B
10 18678.296875 S 24947 Po
10 18678.298828 S 24947 B
13 18678.304688 ntask sched 12.000000
10 18678.304688 S 24947 Fi
10 18678.306641 S 24947 B
10 18678.308594 S 24947 chol_model_22
10 18681.576172 S 64 B
10 18681.576172 S 24947 Po
10 18681.578125 S 24947 B
13 18681.585938 ntask sched 11.000000
10 18681.585938 S 24947 Fi
10 18681.587891 S 24947 B
10 18681.587891 S 24947 chol_model_22
10 18684.865234 S 64 B
10 18684.865234 S 24947 Po
10 18684.867188 S 24947 B
13 18684.873047 ntask sched 10.000000
10 18684.873047 S 24947 Fi
10 18684.876953 S 24947 B
10 18684.876953 S 24947 chol_model_22
10 18688.152344 S 64 B
10 18688.154297 S 24947 Po
10 18688.156250 S 24947 B
13 18688.162109 ntask sched 9.000000
10 18688.162109 S 24947 Fi
10 18688.164062 S 24947 B
10 18688.164062 S 24947 chol_model_22
10 18691.439453 S 64 B
10 18691.441406 S 24947 Po
10 18691.443359 S 24947 B
13 18691.449219 ntask sched 8.000000
10 18691.451172 S 24947 Fi
10 18691.451172 S 24947 B
10 18691.453125 S 24947 chol_model_22
10 18694.722656 S 64 B
10 18694.722656 S 24947 Po
10 18694.724609 S 24947 B
13 18694.730469 ntask sched 7.000000
10 18694.732422 S 24947 Fi
10 18694.732422 S 24947 B
10 18694.734375 S 24947 chol_model_22
10 18698.007812 S 64 B
10 18698.007812 S 24947 Po
10 18698.009766 S 24947 B
13 18698.015625 ntask sched 6.000000
10 18698.017578 S 24947 Fi
10 18698.017578 S 24947 B
10 18698.019531 S 24947 chol_model_22
10 18701.294922 S 64 B
10 18701.294922 S 24947 Po
10 18701.296875 S 24947 B
13 18701.302734 ntask sched 5.000000
10 18701.304688 S 24947 Fi
10 18701.306641 S 24947 B
10 18701.306641 S 24947 chol_model_22
10 18704.578125 S 64 B
10 18704.578125 S 24947 Po
10 18704.580078 S 24947 B
13 18704.585938 ntask sched 4.000000
10 18704.587891 S 24947 Fi
10 18704.589844 S 24947 B
10 18704.589844 S 24947 chol_model_22
10 18707.867188 S 64 B
10 18707.867188 S 24947 Po
10 18707.869141 S 24947 B
13 18707.875000 ntask sched 3.000000
10 18707.876953 S 24947 Fi
10 18707.878906 S 24947 B
10 18707.878906 S 24947 chol_model_22
10 18711.144531 S 64 B
10 18711.144531 S 24947 Po
10 18711.146484 S 24947 B
13 18711.152344 ntask sched 2.000000
10 18711.154297 S 24947 Fi
10 18711.156250 S 24947 B
10 18711.156250 S 24947 chol_model_22
10 18714.433594 S 64 B
10 18714.433594 S 24947 Po
10 18714.435547 S 24947 B
13 18714.441406 ntask sched 1.000000
10 18714.443359 S 24947 Fi
10 18714.445312 S 24947 B
10 18714.445312 S 24947 chol_model_22
10 18717.724609 S 64 B
10 18717.726562 S 24947 Po
10 18717.726562 S 24947 B
13 18717.734375 ntask sched 0.000000
10 18717.734375 S 24947 Fi
10 18717.736328 S 24947 B
10 18717.736328 S 24947 chol_model_22
10 18720.916016 S 0 B
10 18720.917969 S 24948 Po
10 18720.919922 S 24948 B
13 18720.947266 ntask sched 1.000000
13 18720.962891 ntask sched 2.000000
13 18720.978516 ntask sched 3.000000
13 18720.992188 ntask sched 4.000000
10 18721.007812 S 64 B
13 18721.007812 ntask sched 5.000000
10 18721.007812 S 24947 Po
10 18721.009766 S 24947 B
10 18721.017578 MS MEMNODE1 Co
18 18721.017578 L p 4000000 MEMNODE0 com_370
10 18721.021484 MS MEMNODE1 CoA
10 18722.169922 MS MEMNODE1 No
19 18722.169922 L p 1928086912 MEMNODE1 com_1928086720
13 18722.177734 ntask sched 4.000000
10 18722.179688 S 24947 Fi
10 18722.365234 MS MEMNODE1 No
19 18722.365234 L p 4000000 MEMNODE1 com_370
10 18722.367188 S 24947 B
10 18722.367188 S 24947 chol_model_21
10 18730.691406 S 64 B
10 18730.691406 S 24947 Po
10 18730.693359 S 24947 B
13 18730.716797 ntask sched 5.000000
13 18730.722656 ntask sched 4.000000
10 18730.724609 S 24947 Fi
10 18730.724609 S 24947 B
10 18730.724609 S 24947 chol_model_21
10 18739.035156 S 64 B
10 18739.037109 S 24947 Po
10 18739.039062 S 24947 B
13 18739.058594 ntask sched 5.000000
13 18739.074219 ntask sched 6.000000
13 18739.085938 ntask sched 5.000000
10 18739.085938 S 24947 Fi
10 18739.087891 S 24947 B
10 18739.087891 S 24947 chol_model_21
10 18747.406250 S 64 B
10 18747.408203 S 24947 Po
10 18747.410156 S 24947 B
13 18747.431641 ntask sched 6.000000
13 18747.445312 ntask sched 7.000000
13 18747.460938 ntask sched 8.000000
13 18747.466797 ntask sched 7.000000
10 18747.466797 S 24947 Fi
10 18747.468750 S 24947 B
10 18747.468750 S 24947 chol_model_21
10 18755.781250 S 64 B
10 18755.781250 S 24947 Po
10 18755.783203 S 24947 B
13 18755.802734 ntask sched 8.000000
13 18755.818359 ntask sched 9.000000
13 18755.832031 ntask sched 10.000000
13 18755.847656 ntask sched 11.000000
13 18755.853516 ntask sched 10.000000
10 18755.853516 S 24947 Fi
10 18755.855469 S 24947 B
10 18755.855469 S 24947 chol_model_21
10 18764.167969 S 64 B
10 18764.169922 S 24947 Po
10 18764.169922 S 24947 B
13 18764.189453 ntask sched 11.000000
13 18764.205078 ntask sched 12.000000
13 18764.220703 ntask sched 13.000000
13 18764.236328 ntask sched 14.000000
13 18764.251953 ntask sched 15.000000
13 18764.255859 ntask sched 14.000000
10 18764.255859 S 24947 Fi
10 18764.257812 S 24947 B
10 18764.257812 S 24947 chol_model_22
10 18767.533203 S 64 B
10 18767.533203 S 24947 Po
10 18767.535156 S 24947 B
13 18767.554688 ntask sched 15.000000
10 18767.556641 MS MEMNODE0 Co
18 18767.556641 L p 4000000 MEMNODE1 com_371
13 18767.558594 ntask sched 14.000000
10 18767.560547 S 24947 Fi
10 18767.560547 S 24947 B
13 18767.562500 ntask sched 13.000000
10 18767.562500 S 24947 chol_model_22
10 18767.564453 S 24948 Fi
10 18767.572266 MS MEMNODE0 CoA
10 18770.859375 S 64 B
10 18770.859375 S 24947 Po
10 18770.861328 S 24947 B
13 18770.869141 ntask sched 12.000000
10 18770.869141 S 24947 Fi
10 18770.871094 S 24947 B
10 18770.871094 S 24947 chol_model_22
10 18772.837891 MS MEMNODE0 No
19 18772.837891 L p 1928086912 MEMNODE0 com_1928086720
10 18772.906250 MS MEMNODE0 No
19 18772.906250 L p 4000000 MEMNODE0 com_371
10 18772.906250 S 24948 B
10 18772.908203 S 24948 chol_model_11
10 18776.152344 S 64 B
10 18776.154297 S 24947 Po
10 18776.154297 S 24947 B
13 18776.162109 ntask sched 11.000000
10 18776.164062 S 24947 Fi
10 18776.164062 S 24947 B
10 18776.166016 S 24947 chol_model_22
10 18779.439453 S 64 B
10 18779.439453 S 24947 Po
10 18779.441406 S 24947 B
13 18779.447266 ntask sched 10.000000
10 18779.449219 S 24947 Fi
10 18779.449219 S 24947 B
10 18779.451172 S 24947 chol_model_22
10 18782.732422 S 64 B
10 18782.732422 S 24947 Po
10 18782.734375 S 24947 B
13 18782.740234 ntask sched 9.000000
10 18782.740234 S 24947 Fi
10 18782.742188 S 24947 B
10 18782.742188 S 24947 chol_model_22
10 18786.011719 S 64 B
10 18786.013672 S 24947 Po
10 18786.013672 S 24947 B
13 18786.021484 ntask sched 8.000000
10 18786.021484 S 24947 Fi
10 18786.023438 S 24947 B
10 18786.023438 S 24947 chol_model_22
10 18789.300781 S 64 B
10 18789.302734 S 24947 Po
10 18789.304688 S 24947 B
13 18789.308594 ntask sched 7.000000
10 18789.310547 S 24947 Fi
10 18789.312500 S 24947 B
10 18789.312500 S 24947 chol_model_22
10 18792.589844 S 64 B
10 18792.589844 S 24947 Po
10 18792.591797 S 24947 B
13 18792.597656 ntask sched 6.000000
10 18792.599609 S 24947 Fi
10 18792.601562 S 24947 B
10 18792.601562 S 24947 chol_model_22
10 18795.876953 S 64 B
10 18795.876953 S 24947 Po
10 18795.878906 S 24947 B
13 18795.884766 ntask sched 5.000000
10 18795.886719 S 24947 Fi
10 18795.886719 S 24947 B
10 18795.888672 S 24947 chol_model_22
10 18799.156250 S 64 B
10 18799.156250 S 24947 Po
10 18799.158203 S 24947 B
13 18799.164062 ntask sched 4.000000
10 18799.166016 S 24947 Fi
10 18799.167969 S 24947 B
10 18799.167969 S 24947 chol_model_22
10 18802.439453 S 64 B
10 18802.441406 S 24947 Po
10 18802.441406 S 24947 B
13 18802.447266 ntask sched 3.000000
10 18802.449219 S 24947 Fi
10 18802.451172 S 24947 B
10 18802.451172 S 24947 chol_model_22
10 18805.728516 S 64 B
10 18805.728516 S 24947 Po
10 18805.730469 S 24947 B
13 18805.736328 ntask sched 2.000000
10 18805.736328 S 24947 Fi
10 18805.738281 S 24947 B
10 18805.738281 S 24947 chol_model_22
10 18809.005859 S 64 B
10 18809.007812 S 24947 Po
10 18809.007812 S 24947 B
13 18809.013672 ntask sched 1.000000
10 18809.015625 S 24947 Fi
10 18809.017578 S 24947 B
10 18809.017578 S 24947 chol_model_22
10 18812.289062 S 64 B
10 18812.291016 S 24947 Po
10 18812.292969 S 24947 B
13 18812.298828 ntask sched 0.000000
10 18812.298828 S 24947 Fi
10 18812.300781 S 24947 B
10 18812.300781 S 24947 chol_model_22
10 18815.574219 S 64 B
10 18815.574219 S 24947 Po
10 18815.576172 S 24947 B
10 18839.765625 S 0 B
10 18839.765625 S 24948 Po
10 18839.767578 S 24948 B
13 18839.794922 ntask sched 1.000000
10 18839.794922 MS MEMNODE1 Co
18 18839.794922 L p 4000000 MEMNODE0 com_372
10 18839.802734 MS MEMNODE1 CoA
10 18840.947266 MS MEMNODE1 No
19 18840.947266 L p 1928086912 MEMNODE1 com_1928086720
13 18840.953125 ntask sched 0.000000
10 18840.955078 S 24947 Fi
13 18840.968750 ntask sched 1.000000
13 18840.984375 ntask sched 2.000000
13 18841.000000 ntask sched 3.000000
10 18841.142578 MS MEMNODE1 No
19 18841.142578 L p 4000000 MEMNODE1 com_372
10 18841.144531 S 24947 B
10 18841.144531 S 24947 chol_model_21
10 18849.455078 S 64 B
10 18849.455078 S 24947 Po
10 18849.457031 S 24947 B
13 18849.478516 ntask sched 4.000000
13 18849.484375 ntask sched 3.000000
10 18849.484375 S 24947 Fi
10 18849.486328 S 24947 B
10 18849.486328 S 24947 chol_model_21
10 18857.794922 S 64 B
10 18857.794922 S 24947 Po
10 18857.796875 S 24947 B
13 18857.816406 ntask sched 4.000000
13 18857.832031 ntask sched 5.000000
13 18857.837891 ntask sched 4.000000
10 18857.837891 S 24947 Fi
10 18857.839844 S 24947 B
10 18857.839844 S 24947 chol_model_21
10 18866.146484 S 64 B
10 18866.148438 S 24947 Po
10 18866.150391 S 24947 B
13 18866.169922 ntask sched 5.000000
13 18866.185547 ntask sched 6.000000
13 18866.201172 ntask sched 7.000000
13 18866.207031 ntask sched 6.000000
10 18866.207031 S 24947 Fi
10 18866.208984 S 24947 B
10 18866.210938 S 24947 chol_model_21
10 18874.509766 S 64 B
10 18874.511719 S 24947 Po
10 18874.513672 S 24947 B
13 18874.531250 ntask sched 7.000000
13 18874.546875 ntask sched 8.000000
13 18874.562500 ntask sched 9.000000
13 18874.576172 ntask sched 10.000000
13 18874.582031 ntask sched 9.000000
10 18874.582031 S 24947 Fi
10 18874.583984 S 24947 B
10 18874.583984 S 24947 chol_model_22
10 18877.867188 S 64 B
10 18877.867188 S 24947 Po
10 18877.869141 S 24947 B
13 18877.892578 ntask sched 10.000000
10 18877.894531 MS MEMNODE0 Co
18 18877.894531 L p 4000000 MEMNODE1 com_373
13 18877.894531 ntask sched 9.000000
10 18877.896484 S 24948 Fi
13 18877.898438 ntask sched 8.000000
10 18877.898438 S 24947 Fi
10 18877.900391 S 24947 B
10 18877.900391 S 24947 chol_model_22
10 18877.910156 MS MEMNODE0 CoA
10 18881.203125 S 64 B
10 18881.205078 S 24947 Po
10 18881.205078 S 24947 B
13 18881.212891 ntask sched 7.000000
10 18881.214844 S 24947 Fi
10 18881.214844 S 24947 B
10 18881.216797 S 24947 chol_model_22
10 18883.123047 MS MEMNODE0 No
19 18883.123047 L p 1928086912 MEMNODE0 com_1928086720
10 18883.191406 MS MEMNODE0 No
19 18883.191406 L p 4000000 MEMNODE0 com_373
10 18883.193359 S 24948 B
10 18883.195312 S 24948 chol_model_11
10 18886.441406 S 64 B
10 18886.443359 S 24947 Po
10 18886.443359 S 24947 B
13 18886.451172 ntask sched 6.000000
10 18886.451172 S 24947 Fi
10 18886.453125 S 24947 B
10 18886.453125 S 24947 chol_model_22
10 18889.734375 S 64 B
10 18889.734375 S 24947 Po
10 18889.736328 S 24947 B
13 18889.742188 ntask sched 5.000000
10 18889.744141 S 24947 Fi
10 18889.744141 S 24947 B
10 18889.744141 S 24947 chol_model_22
10 18893.015625 S 64 B
10 18893.015625 S 24947 Po
10 18893.017578 S 24947 B
13 18893.023438 ntask sched 4.000000
10 18893.023438 S 24947 Fi
10 18893.025391 S 24947 B
10 18893.025391 S 24947 chol_model_22
10 18896.294922 S 64 B
10 18896.294922 S 24947 Po
10 18896.296875 S 24947 B
13 18896.302734 ntask sched 3.000000
10 18896.304688 S 24947 Fi
10 18896.304688 S 24947 B
10 18896.306641 S 24947 chol_model_22
10 18899.574219 S 64 B
10 18899.576172 S 24947 Po
10 18899.576172 S 24947 B
13 18899.582031 ntask sched 2.000000
10 18899.585938 S 24947 Fi
10 18899.585938 S 24947 B
10 18899.587891 S 24947 chol_model_22
10 18902.865234 S 64 B
10 18902.865234 S 24947 Po
10 18902.867188 S 24947 B
13 18902.875000 ntask sched 1.000000
10 18902.876953 S 24947 Fi
10 18902.878906 S 24947 B
10 18902.878906 S 24947 chol_model_22
10 18906.156250 S 64 B
10 18906.158203 S 24947 Po
10 18906.160156 S 24947 B
13 18906.167969 ntask sched 0.000000
10 18906.167969 S 24947 Fi
10 18906.169922 S 24947 B
10 18906.169922 S 24947 chol_model_22
10 18909.441406 S 64 B
10 18909.441406 S 24947 Po
10 18909.443359 S 24947 B
10 18950.093750 S 0 B
10 18950.095703 S 24948 Po
10 18950.097656 S 24948 B
13 18950.123047 ntask sched 1.000000
10 18950.125000 MS MEMNODE1 Co
18 18950.125000 L p 4000000 MEMNODE0 com_374
10 18950.130859 MS MEMNODE1 CoA
10 18951.273438 MS MEMNODE1 No
19 18951.273438 L p 1928086912 MEMNODE1 com_1928086720
13 18951.279297 ntask sched 0.000000
10 18951.281250 S 24947 Fi
13 18951.308594 ntask sched 1.000000
13 18951.324219 ntask sched 2.000000
10 18951.468750 MS MEMNODE1 No
19 18951.468750 L p 4000000 MEMNODE1 com_374
10 18951.470703 S 24947 B
10 18951.470703 S 24947 chol_model_21
10 18959.785156 S 64 B
10 18959.785156 S 24947 Po
10 18959.787109 S 24947 B
13 18959.808594 ntask sched 3.000000
13 18959.814453 ntask sched 2.000000
10 18959.814453 S 24947 Fi
10 18959.816406 S 24947 B
10 18959.816406 S 24947 chol_model_21
10 18968.132812 S 64 B
10 18968.134766 S 24947 Po
10 18968.134766 S 24947 B
13 18968.154297 ntask sched 3.000000
13 18968.169922 ntask sched 4.000000
13 18968.175781 ntask sched 3.000000
10 18968.177734 S 24947 Fi
10 18968.177734 S 24947 B
10 18968.177734 S 24947 chol_model_21
10 18976.488281 S 64 B
10 18976.490234 S 24947 Po
10 18976.492188 S 24947 B
13 18976.511719 ntask sched 4.000000
13 18976.525391 ntask sched 5.000000
13 18976.541016 ntask sched 6.000000
13 18976.544922 ntask sched 5.000000
10 18976.546875 S 24947 Fi
10 18976.546875 S 24947 B
10 18976.548828 S 24947 chol_model_22
10 18979.826172 S 64 B
10 18979.826172 S 24947 Po
10 18979.828125 S 24947 B
13 18979.847656 ntask sched 6.000000
10 18979.849609 MS MEMNODE0 Co
18 18979.849609 L p 4000000 MEMNODE1 com_375
13 18979.851562 ntask sched 5.000000
13 18979.853516 ntask sched 4.000000
10 18979.853516 S 24948 Fi
10 18979.853516 S 24947 Fi
10 18979.855469 S 24947 B
10 18979.855469 S 24947 chol_model_22
10 18979.857422 MS MEMNODE0 CoA
10 18981.203125 MS MEMNODE0 No
19 18981.203125 L p 1928086912 MEMNODE0 com_1928086720
10 18984.486328 S 64 B
10 18984.486328 S 24947 Po
10 18984.488281 S 24947 B
13 18984.496094 ntask sched 3.000000
10 18984.496094 S 24947 Fi
10 18984.498047 S 24947 B
10 18984.498047 S 24947 chol_model_22
10 18984.541016 MS MEMNODE0 No
19 18984.541016 L p 4000000 MEMNODE0 com_375
10 18984.542969 S 24948 B
10 18984.542969 S 24948 chol_model_11
10 18987.785156 S 64 B
10 18987.785156 S 24947 Po
10 18987.787109 S 24947 B
13 18987.794922 ntask sched 2.000000
10 18987.794922 S 24947 Fi
10 18987.796875 S 24947 B
10 18987.798828 S 24947 chol_model_22
10 18991.078125 S 64 B
10 18991.080078 S 24947 Po
10 18991.080078 S 24947 B
13 18991.089844 ntask sched 1.000000
10 18991.089844 S 24947 Fi
10 18991.091797 S 24947 B
10 18991.091797 S 24947 chol_model_22
10 18994.363281 S 64 B
10 18994.365234 S 24947 Po
10 18994.365234 S 24947 B
13 18994.371094 ntask sched 0.000000
10 18994.373047 S 24947 Fi
10 18994.375000 S 24947 B
10 18994.375000 S 24947 chol_model_22
10 18997.644531 S 64 B
10 18997.646484 S 24947 Po
10 18997.646484 S 24947 B
10 19051.835938 S 0 B
10 19051.835938 S 24948 Po
10 19051.837891 S 24948 B
13 19051.863281 ntask sched 1.000000
10 19051.863281 MS MEMNODE1 Co
18 19051.863281 L p 4000000 MEMNODE0 com_376
10 19051.871094 MS MEMNODE1 CoA
10 19053.015625 MS MEMNODE1 No
19 19053.015625 L p 1928086912 MEMNODE1 com_1928086720
13 19053.021484 ntask sched 0.000000
10 19053.023438 S 24947 Fi
13 19053.070312 ntask sched 1.000000
10 19053.210938 MS MEMNODE1 No
19 19053.210938 L p 4000000 MEMNODE1 com_376
10 19053.212891 S 24947 B
10 19053.212891 S 24947 chol_model_21
10 19061.525391 S 64 B
10 19061.525391 S 24947 Po
10 19061.527344 S 24947 B
13 19061.548828 ntask sched 2.000000
13 19061.552734 ntask sched 1.000000
10 19061.554688 S 24947 Fi
10 19061.556641 S 24947 B
10 19061.556641 S 24947 chol_model_21
10 19069.859375 S 64 B
10 19069.859375 S 24947 Po
10 19069.861328 S 24947 B
13 19069.882812 ntask sched 2.000000
13 19069.898438 ntask sched 3.000000
13 19069.902344 ntask sched 2.000000
10 19069.902344 S 24947 Fi
10 19069.904297 S 24947 B
10 19069.904297 S 24947 chol_model_22
10 19073.181641 S 64 B
10 19073.181641 S 24947 Po
10 19073.183594 S 24947 B
13 19073.203125 ntask sched 3.000000
10 19073.203125 MS MEMNODE0 Co
18 19073.203125 L p 4000000 MEMNODE1 com_377
13 19073.205078 ntask sched 2.000000
10 19073.207031 S 24948 Fi
13 19073.207031 ntask sched 1.000000
10 19073.208984 S 24947 Fi
10 19073.210938 S 24947 B
10 19073.210938 S 24947 chol_model_22
10 19073.212891 MS MEMNODE0 CoA
10 19074.562500 MS MEMNODE0 No
19 19074.562500 L p 1928086912 MEMNODE0 com_1928086720
10 19074.621094 MS MEMNODE0 No
19 19074.621094 L p 4000000 MEMNODE0 com_377
10 19074.636719 S 24948 B
10 19074.638672 S 24948 chol_model_11
10 19077.880859 S 64 B
10 19077.882812 S 24947 Po
10 19077.884766 S 24947 B
13 19077.890625 ntask sched 0.000000
10 19077.892578 S 24947 Fi
10 19077.892578 S 24947 B
10 19077.894531 S 24947 chol_model_22
10 19081.173828 S 64 B
10 19081.175781 S 24947 Po
10 19081.175781 S 24947 B
10 19141.623047 S 0 B
10 19141.625000 S 24948 Po
10 19141.630859 S 24948 B
13 19141.660156 ntask sched 1.000000
10 19141.660156 MS MEMNODE1 Co
18 19141.660156 L p 4000000 MEMNODE0 com_378
10 19141.667969 MS MEMNODE1 CoA
10 19142.869141 MS MEMNODE1 No
19 19142.869141 L p 1928086912 MEMNODE1 com_1928086720
13 19142.876953 ntask sched 0.000000
10 19142.876953 S 24947 Fi
10 19143.066406 MS MEMNODE1 No
19 19143.066406 L p 4000000 MEMNODE1 com_378
10 19143.066406 S 24947 B
10 19143.068359 S 24947 chol_model_21
10 19151.382812 S 64 B
10 19151.384766 S 24947 Po
10 19151.384766 S 24947 B
13 19151.406250 ntask sched 1.000000
13 19151.412109 ntask sched 0.000000
10 19151.412109 S 24947 Fi
10 19151.414062 S 24947 B
10 19151.414062 S 24947 chol_model_22
10 19154.691406 S 64 B
10 19154.693359 S 24947 Po
10 19154.693359 S 24947 B
13 19154.712891 ntask sched 1.000000
10 19154.714844 MS MEMNODE0 Co
18 19154.714844 L p 4000000 MEMNODE1 com_379
13 19154.716797 ntask sched 0.000000
10 19154.718750 S 24948 Fi
10 19154.720703 MS MEMNODE0 CoA
10 19156.070312 MS MEMNODE0 No
19 19156.070312 L p 1928086912 MEMNODE0 com_1928086720
10 19156.121094 MS MEMNODE0 No
19 19156.121094 L p 4000000 MEMNODE0 com_379
10 19156.123047 S 24948 B
10 19156.123047 S 24948 chol_model_11
10 19223.121094 S 0 B
10 19223.121094 S 24948 Po
10 19223.123047 S 24948 B
10 19233.111328 MS MEMNODE0 Co
18 19233.111328 L p 4000000 MEMNODE1 com_380
10 19233.126953 MS MEMNODE0 CoA
10 19234.664062 MS MEMNODE0 No
19 19234.664062 L p 1928086912 MEMNODE0 com_1928086720
10 19234.724609 MS MEMNODE0 No
19 19234.724609 L p 4000000 MEMNODE0 com_380
10 19237.519531 MS MEMNODE0 Co
18 19237.519531 L p 4000000 MEMNODE1 com_381
10 19237.529297 MS MEMNODE0 CoA
10 19238.966797 MS MEMNODE0 No
19 19238.966797 L p 1928086912 MEMNODE0 com_1928086720
10 19239.019531 MS MEMNODE0 No
19 19239.019531 L p 4000000 MEMNODE0 com_381
10 19241.748047 MS MEMNODE0 Co
18 19241.748047 L p 4000000 MEMNODE1 com_382
10 19241.894531 MS MEMNODE0 CoA
10 19277.123047 MS MEMNODE0 No
19 19277.123047 L p 1928086912 MEMNODE0 com_1928086720
10 19277.226562 MS MEMNODE0 No
19 19277.226562 L p 4000000 MEMNODE0 com_382
10 19278.750000 MS MEMNODE0 Co
18 19278.750000 L p 4000000 MEMNODE1 com_383
10 19278.796875 MS MEMNODE0 CoA
10 19280.281250 MS MEMNODE0 No
19 19280.281250 L p 1928086912 MEMNODE0 com_1928086720
10 19280.326172 MS MEMNODE0 No
19 19280.326172 L p 4000000 MEMNODE0 com_383
10 19281.509766 MS MEMNODE0 Co
18 19281.509766 L p 4000000 MEMNODE1 com_384
10 19281.515625 MS MEMNODE0 CoA
10 19283.478516 MS MEMNODE0 No
19 19283.478516 L p 1928086912 MEMNODE0 com_1928086720
10 19283.521484 MS MEMNODE0 No
19 19283.521484 L p 4000000 MEMNODE0 com_384
10 19286.603516 MS MEMNODE0 Co
18 19286.603516 L p 4000000 MEMNODE1 com_385
10 19286.609375 MS MEMNODE0 CoA
10 19288.570312 MS MEMNODE0 No
19 19288.570312 L p 1928086912 MEMNODE0 com_1928086720
10 19288.615234 MS MEMNODE0 No
19 19288.615234 L p 4000000 MEMNODE0 com_385
10 19289.236328 MS MEMNODE0 Co
18 19289.236328 L p 4000000 MEMNODE1 com_386
10 19289.257812 MS MEMNODE0 CoA
10 19290.664062 MS MEMNODE0 No
19 19290.664062 L p 1928086912 MEMNODE0 com_1928086720
10 19290.710938 MS MEMNODE0 No
19 19290.710938 L p 4000000 MEMNODE0 com_386
10 19292.972656 MS MEMNODE0 Co
18 19292.972656 L p 4000000 MEMNODE1 com_387
10 19293.109375 MS MEMNODE0 CoA
10 19316.255859 MS MEMNODE0 No
19 19316.255859 L p 1928086912 MEMNODE0 com_1928086720
10 19316.423828 MS MEMNODE0 No
19 19316.423828 L p 4000000 MEMNODE0 com_387
10 19316.960938 MS MEMNODE0 Co
18 19316.960938 L p 4000000 MEMNODE1 com_388
10 19316.970703 MS MEMNODE0 CoA
10 19318.320312 MS MEMNODE0 No
19 19318.320312 L p 1928086912 MEMNODE0 com_1928086720
10 19318.369141 MS MEMNODE0 No
19 19318.369141 L p 4000000 MEMNODE0 com_388
10 19318.677734 MS MEMNODE0 Co
18 19318.677734 L p 4000000 MEMNODE1 com_389
10 19318.685547 MS MEMNODE0 CoA
10 19320.718750 MS MEMNODE0 No
19 19320.718750 L p 1928086912 MEMNODE0 com_1928086720
10 19320.763672 MS MEMNODE0 No
19 19320.763672 L p 4000000 MEMNODE0 com_389
10 19322.562500 MS MEMNODE0 Co
18 19322.562500 L p 4000000 MEMNODE1 com_390
10 19322.568359 MS MEMNODE0 CoA
10 19324.576172 MS MEMNODE0 No
19 19324.576172 L p 1928086912 MEMNODE0 com_1928086720
10 19324.630859 MS MEMNODE0 No
19 19324.630859 L p 4000000 MEMNODE0 com_390
10 19325.437500 MS MEMNODE0 Co
18 19325.437500 L p 4000000 MEMNODE1 com_391
10 19325.443359 MS MEMNODE0 CoA
10 19327.492188 MS MEMNODE0 No
19 19327.492188 L p 1928086912 MEMNODE0 com_1928086720
10 19327.542969 MS MEMNODE0 No
19 19327.542969 L p 4000000 MEMNODE0 com_391
10 19327.988281 MS MEMNODE0 Co
18 19327.988281 L p 4000000 MEMNODE1 com_392
10 19328.003906 MS MEMNODE0 CoA
10 19330.099609 MS MEMNODE0 No
19 19330.099609 L p 1928086912 MEMNODE0 com_1928086720
10 19330.142578 MS MEMNODE0 No
19 19330.142578 L p 4000000 MEMNODE0 com_392
10 19330.431641 MS MEMNODE0 Co
18 19330.431641 L p 4000000 MEMNODE1 com_393
10 19330.439453 MS MEMNODE0 CoA
10 19332.406250 MS MEMNODE0 No
19 19332.406250 L p 1928086912 MEMNODE0 com_1928086720
10 19332.451172 MS MEMNODE0 No
19 19332.451172 L p 4000000 MEMNODE0 com_393
10 19333.265625 MS MEMNODE0 Co
18 19333.265625 L p 4000000 MEMNODE1 com_394
10 19333.283203 MS MEMNODE0 CoA
10 19334.650391 MS MEMNODE0 No
19 19334.650391 L p 1928086912 MEMNODE0 com_1928086720
10 19334.693359 MS MEMNODE0 No
19 19334.693359 L p 4000000 MEMNODE0 com_394
10 19336.517578 MS MEMNODE0 Co
18 19336.517578 L p 4000000 MEMNODE1 com_395
10 19336.525391 MS MEMNODE0 CoA
10 19338.531250 MS MEMNODE0 No
19 19338.531250 L p 1928086912 MEMNODE0 com_1928086720
10 19338.583984 MS MEMNODE0 No
19 19338.583984 L p 4000000 MEMNODE0 com_395
10 19339.140625 MS MEMNODE0 Co
18 19339.140625 L p 4000000 MEMNODE1 com_396
10 19339.279297 MS MEMNODE0 CoA
10 19362.021484 MS MEMNODE0 No
19 19362.021484 L p 1928086912 MEMNODE0 com_1928086720
10 19362.123047 MS MEMNODE0 No
19 19362.123047 L p 4000000 MEMNODE0 com_396
10 19362.431641 MS MEMNODE0 Co
18 19362.431641 L p 4000000 MEMNODE1 com_397
10 19362.472656 MS MEMNODE0 CoA
10 19398.535156 MS MEMNODE0 No
19 19398.535156 L p 1928086912 MEMNODE0 com_1928086720
10 19398.644531 MS MEMNODE0 No
19 19398.644531 L p 4000000 MEMNODE0 com_397
10 19399.828125 MS MEMNODE0 Co
18 19399.828125 L p 4000000 MEMNODE1 com_398
10 19399.851562 MS MEMNODE0 CoA
10 19401.863281 MS MEMNODE0 No
19 19401.863281 L p 1928086912 MEMNODE0 com_1928086720
10 19401.910156 MS MEMNODE0 No
19 19401.910156 L p 4000000 MEMNODE0 com_398
10 19402.597656 MS MEMNODE0 Co
18 19402.597656 L p 4000000 MEMNODE1 com_399
10 19402.605469 MS MEMNODE0 CoA
10 19404.613281 MS MEMNODE0 No
19 19404.613281 L p 1928086912 MEMNODE0 com_1928086720
10 19404.664062 MS MEMNODE0 No
19 19404.664062 L p 4000000 MEMNODE0 com_399
10 19405.644531 MS MEMNODE0 Co
18 19405.644531 L p 4000000 MEMNODE1 com_400
10 19405.652344 MS MEMNODE0 CoA
10 19407.009766 MS MEMNODE0 No
19 19407.009766 L p 1928086912 MEMNODE0 com_1928086720
10 19407.048828 MS MEMNODE0 No
19 19407.048828 L p 4000000 MEMNODE0 com_400
10 19407.384766 MS MEMNODE0 Co
18 19407.384766 L p 4000000 MEMNODE1 com_401
10 19407.390625 MS MEMNODE0 CoA
10 19409.357422 MS MEMNODE0 No
19 19409.357422 L p 1928086912 MEMNODE0 com_1928086720
10 19409.578125 MS MEMNODE0 No
19 19409.578125 L p 4000000 MEMNODE0 com_401
10 19410.261719 MS MEMNODE0 Co
18 19410.261719 L p 4000000 MEMNODE1 com_402
10 19410.269531 MS MEMNODE0 CoA
10 19412.275391 MS MEMNODE0 No
19 19412.275391 L p 1928086912 MEMNODE0 com_1928086720
10 19412.322266 MS MEMNODE0 No
19 19412.322266 L p 4000000 MEMNODE0 com_402
10 19412.630859 MS MEMNODE0 Co
18 19412.630859 L p 4000000 MEMNODE1 com_403
10 19412.638672 MS MEMNODE0 CoA
10 19414.605469 MS MEMNODE0 No
19 19414.605469 L p 1928086912 MEMNODE0 com_1928086720
10 19414.654297 MS MEMNODE0 No
19 19414.654297 L p 4000000 MEMNODE0 com_403
10 19415.037109 MS MEMNODE0 Co
18 19415.037109 L p 4000000 MEMNODE1 com_404
10 19415.042969 MS MEMNODE0 CoA
10 19417.011719 MS MEMNODE0 No
19 19417.011719 L p 1928086912 MEMNODE0 com_1928086720
10 19417.050781 MS MEMNODE0 No
19 19417.050781 L p 4000000 MEMNODE0 com_404
10 19420.488281 MS MEMNODE0 Co
18 19420.488281 L p 4000000 MEMNODE1 com_405
10 19420.498047 MS MEMNODE0 CoA
10 19422.544922 MS MEMNODE0 No
19 19422.544922 L p 1928086912 MEMNODE0 com_1928086720
10 19422.585938 MS MEMNODE0 No
19 19422.585938 L p 4000000 MEMNODE0 com_405
10 19422.945312 MS MEMNODE0 Co
18 19422.945312 L p 4000000 MEMNODE1 com_406
10 19422.953125 MS MEMNODE0 CoA
10 19424.990234 MS MEMNODE0 No
19 19424.990234 L p 1928086912 MEMNODE0 com_1928086720
10 19425.039062 MS MEMNODE0 No
19 19425.039062 L p 4000000 MEMNODE0 com_406
10 19425.326172 MS MEMNODE0 Co
18 19425.326172 L p 4000000 MEMNODE1 com_407
10 19425.335938 MS MEMNODE0 CoA
10 19427.382812 MS MEMNODE0 No
19 19427.382812 L p 1928086912 MEMNODE0 com_1928086720
10 19427.427734 MS MEMNODE0 No
19 19427.427734 L p 4000000 MEMNODE0 com_407
10 19427.689453 MS MEMNODE0 Co
18 19427.689453 L p 4000000 MEMNODE1 com_408
10 19427.865234 MS MEMNODE0 CoA
10 19450.664062 MS MEMNODE0 No
19 19450.664062 L p 1928086912 MEMNODE0 com_1928086720
10 19450.769531 MS MEMNODE0 No
19 19450.769531 L p 4000000 MEMNODE0 com_408
10 19452.154297 MS MEMNODE0 Co
18 19452.154297 L p 4000000 MEMNODE1 com_409
10 19452.162109 MS MEMNODE0 CoA
10 19454.210938 MS MEMNODE0 No
19 19454.210938 L p 1928086912 MEMNODE0 com_1928086720
10 19454.250000 MS MEMNODE0 No
19 19454.250000 L p 4000000 MEMNODE0 com_409
10 19455.349609 MS MEMNODE0 Co
18 19455.349609 L p 4000000 MEMNODE1 com_410
10 19455.357422 MS MEMNODE0 CoA
10 19457.359375 MS MEMNODE0 No
19 19457.359375 L p 1928086912 MEMNODE0 com_1928086720
10 19457.402344 MS MEMNODE0 No
19 19457.402344 L p 4000000 MEMNODE0 com_410
10 19457.873047 MS MEMNODE0 Co
18 19457.873047 L p 4000000 MEMNODE1 com_411
10 19457.890625 MS MEMNODE0 CoA
10 19459.246094 MS MEMNODE0 No
19 19459.246094 L p 1928086912 MEMNODE0 com_1928086720
10 19459.291016 MS MEMNODE0 No
19 19459.291016 L p 4000000 MEMNODE0 com_411
10 19459.656250 MS MEMNODE0 Co
18 19459.656250 L p 4000000 MEMNODE1 com_412
10 19459.816406 MS MEMNODE0 CoA
10 19482.472656 MS MEMNODE0 No
19 19482.472656 L p 1928086912 MEMNODE0 com_1928086720
10 19482.662109 MS MEMNODE0 No
19 19482.662109 L p 4000000 MEMNODE0 com_412
10 19482.929688 MS MEMNODE0 Co
18 19482.929688 L p 4000000 MEMNODE1 com_413
10 19482.937500 MS MEMNODE0 CoA
10 19484.980469 MS MEMNODE0 No
19 19484.980469 L p 1928086912 MEMNODE0 com_1928086720
10 19485.021484 MS MEMNODE0 No
19 19485.021484 L p 4000000 MEMNODE0 com_413
10 19485.367188 MS MEMNODE0 Co
18 19485.367188 L p 4000000 MEMNODE1 com_414
10 19485.474609 MS MEMNODE0 CoA
10 19509.300781 MS MEMNODE0 No
19 19509.300781 L p 1928086912 MEMNODE0 com_1928086720
10 19509.484375 MS MEMNODE0 No
19 19509.484375 L p 4000000 MEMNODE0 com_414
10 19509.888672 MS MEMNODE0 Co
18 19509.888672 L p 4000000 MEMNODE1 com_415
10 19509.968750 MS MEMNODE0 CoA
10 19531.304688 MS MEMNODE0 No
19 19531.304688 L p 1928086912 MEMNODE0 com_1928086720
10 19531.376953 MS MEMNODE0 No
19 19531.376953 L p 4000000 MEMNODE0 com_415
10 19531.695312 MS MEMNODE0 Co
18 19531.695312 L p 4000000 MEMNODE1 com_416
10 19531.703125 MS MEMNODE0 CoA
10 19533.669922 MS MEMNODE0 No
19 19533.669922 L p 1928086912 MEMNODE0 com_1928086720
10 19533.714844 MS MEMNODE0 No
19 19533.714844 L p 4000000 MEMNODE0 com_416
10 19534.552734 S 24947 Fi
10 19534.552734 S 24947 B
10 19534.554688 S 24947 execute_on_all_wrapper
10 19534.767578 S 64 B
10 19534.767578 S 24947 Po
10 19534.769531 S 24947 B
10 19535.042969 S 24947 D
10 19535.042969 S 24950 D
10 19535.044922 S 24949 D
10 19535.044922 S 24951 D
10 19535.044922 S 24948 D
10 19535.044922 S 24952 D
8 19535.101562 24952 T
8 19535.103516 24951 T
8 19535.107422 24948 T
8 19535.111328 24950 T
8 19535.113281 24949 T
8 19606.673828 24947 T
13 15576.313477 bw MEMNODE0 1329.007080
13 15576.313477 bw MEMNODE1 1329.007080
13 15577.968750 bw MEMNODE0 1593.418701
13 15577.968750 bw MEMNODE1 1593.418701
13 15579.323242 bw MEMNODE0 264.411621
13 15579.323242 bw MEMNODE1 264.411621
13 15579.652344 bw MEMNODE0 562.410889
13 15579.652344 bw MEMNODE1 562.410889
13 15581.191406 bw MEMNODE0 899.669006
13 15581.191406 bw MEMNODE1 899.669006
13 15582.727539 bw MEMNODE0 1287.915527
13 15582.727539 bw MEMNODE1 1287.915527
13 15584.278320 bw MEMNODE0 1746.234863
13 15584.278320 bw MEMNODE1 1746.234863
13 15585.805664 bw MEMNODE0 2303.513672
13 15585.805664 bw MEMNODE1 2303.513672
13 15587.266602 bw MEMNODE0 3006.207031
13 15587.266602 bw MEMNODE1 3006.207031
13 15588.724609 bw MEMNODE0 3956.114258
13 15588.724609 bw MEMNODE1 3956.114258
13 15590.202148 bw MEMNODE0 5432.150391
13 15590.202148 bw MEMNODE1 5432.150391
13 15591.681641 bw MEMNODE0 5837.374023
13 15591.681641 bw MEMNODE1 5837.374023
13 15592.912109 bw MEMNODE0 4361.337891
13 15592.912109 bw MEMNODE1 4361.337891
13 15592.935547 bw MEMNODE0 3411.430664
13 15592.935547 bw MEMNODE1 3411.430664
13 15592.958984 bw MEMNODE0 2708.737305
13 15592.958984 bw MEMNODE1 2708.737305
13 15592.983398 bw MEMNODE0 2151.458496
13 15592.983398 bw MEMNODE1 2151.458496
13 15593.005859 bw MEMNODE0 1693.139160
13 15593.005859 bw MEMNODE1 1693.139160
13 15593.030273 bw MEMNODE0 1304.892700
13 15593.030273 bw MEMNODE1 1304.892700
13 15593.051758 bw MEMNODE0 967.634583
13 15593.051758 bw MEMNODE1 967.634583
13 15593.075195 bw MEMNODE0 669.635315
13 15593.075195 bw MEMNODE1 669.635315
13 15593.096680 bw MEMNODE0 405.223724
13 15593.096680 bw MEMNODE1 405.223724
13 15601.552734 bw MEMNODE0 0.000153
13 15601.552734 bw MEMNODE1 0.000153
13 15601.982422 bw MEMNODE0 414.239624
13 15601.982422 bw MEMNODE1 414.239624
13 15611.638672 bw MEMNODE0 0.000153
13 15611.638672 bw MEMNODE1 0.000153
13 15612.038086 bw MEMNODE0 354.693604
13 15612.038086 bw MEMNODE1 354.693604
13 15613.534180 bw MEMNODE0 763.720947
13 15613.534180 bw MEMNODE1 763.720947
13 15623.313477 bw MEMNODE0 354.693573
13 15623.313477 bw MEMNODE1 354.693573
13 15623.315430 bw MEMNODE0 0.000122
13 15623.315430 bw MEMNODE1 0.000122
13 15623.667969 bw MEMNODE0 233.776733
13 15623.667969 bw MEMNODE1 233.776733
13 15625.169922 bw MEMNODE0 490.097137
13 15625.169922 bw MEMNODE1 490.097137
13 15626.673828 bw MEMNODE0 773.792969
13 15626.673828 bw MEMNODE1 773.792969
13 15627.058594 bw MEMNODE1 1283.435913
13 15627.058594 bw MEMNODE0 1283.435913
13 15627.166016 bw MEMNODE1 1800.542358
13 15627.166016 bw MEMNODE0 1800.542358
13 15630.879883 bw MEMNODE1 2513.014160
13 15630.879883 bw MEMNODE0 2513.014160
13 15634.901367 bw MEMNODE1 1995.907715
13 15634.901367 bw MEMNODE0 1995.907715
13 15634.907227 bw MEMNODE1 1486.264771
13 15634.907227 bw MEMNODE0 1486.264771
13 15636.494141 bw MEMNODE1 773.793030
13 15636.494141 bw MEMNODE0 773.793030
13 15640.773438 bw MEMNODE0 490.097229
13 15640.773438 bw MEMNODE1 490.097229
13 15640.775391 bw MEMNODE0 233.776825
13 15640.775391 bw MEMNODE1 233.776825
13 15640.778320 bw MEMNODE0 0.000214
13 15640.778320 bw MEMNODE1 0.000214
13 15641.277344 bw MEMNODE0 57.213310
13 15641.277344 bw MEMNODE1 57.213310
13 15642.738281 bw MEMNODE0 115.649124
13 15642.738281 bw MEMNODE1 115.649124
13 15644.264648 bw MEMNODE0 175.420319
13 15644.264648 bw MEMNODE1 175.420319
13 15645.772461 bw MEMNODE0 236.571075
13 15645.772461 bw MEMNODE1 236.571075
13 15647.358398 bw MEMNODE0 299.243225
13 15647.358398 bw MEMNODE1 299.243225
13 15648.867188 bw MEMNODE0 363.435791
13 15648.867188 bw MEMNODE1 363.435791
13 15650.372070 bw MEMNODE0 429.219147
13 15650.372070 bw MEMNODE1 429.219147
13 15651.869141 bw MEMNODE0 496.665222
13 15651.869141 bw MEMNODE1 496.665222
13 15653.372070 bw MEMNODE0 565.867249
13 15653.372070 bw MEMNODE1 565.867249
13 15654.866211 bw MEMNODE0 636.909302
13 15654.866211 bw MEMNODE1 636.909302
13 15656.367188 bw MEMNODE0 709.899658
13 15656.367188 bw MEMNODE1 709.899658
13 15657.856445 bw MEMNODE0 784.931702
13 15657.856445 bw MEMNODE1 784.931702
13 15659.327148 bw MEMNODE0 862.096802
13 15659.327148 bw MEMNODE1 862.096802
13 15660.925781 bw MEMNODE0 941.720459
13 15660.925781 bw MEMNODE1 941.720459
13 15671.278320 bw MEMNODE0 1042.016724
13 15671.278320 bw MEMNODE1 1042.016724
13 15672.803711 bw MEMNODE0 1146.307007
13 15672.803711 bw MEMNODE1 1146.307007
13 15674.317383 bw MEMNODE0 1254.890869
13 15674.317383 bw MEMNODE1 1254.890869
13 15675.777344 bw MEMNODE0 1367.961914
13 15675.777344 bw MEMNODE1 1367.961914
13 15677.285156 bw MEMNODE0 1486.073730
13 15677.285156 bw MEMNODE1 1486.073730
13 15678.746094 bw MEMNODE0 1609.517822
13 15678.746094 bw MEMNODE1 1609.517822
13 15680.253906 bw MEMNODE0 1738.994629
13 15680.253906 bw MEMNODE1 1738.994629
13 15681.779297 bw MEMNODE0 1875.214600
13 15681.779297 bw MEMNODE1 1875.214600
13 15683.310547 bw MEMNODE0 2018.938965
13 15683.310547 bw MEMNODE1 2018.938965
13 15684.958984 bw MEMNODE0 2171.723389
13 15684.958984 bw MEMNODE1 2171.723389
13 15686.467773 bw MEMNODE0 2333.870605
13 15686.467773 bw MEMNODE1 2333.870605
13 15687.916016 bw MEMNODE0 2506.145264
13 15687.916016 bw MEMNODE1 2506.145264
13 15689.428711 bw MEMNODE0 2690.450439
13 15689.428711 bw MEMNODE1 2690.450439
13 15690.928711 bw MEMNODE0 2888.458740
13 15690.928711 bw MEMNODE1 2888.458740
13 15692.430664 bw MEMNODE0 3102.405029
13 15692.430664 bw MEMNODE1 3102.405029
13 15693.875000 bw MEMNODE0 3334.289062
13 15693.875000 bw MEMNODE1 3334.289062
13 15695.324219 bw MEMNODE0 3587.488037
13 15695.324219 bw MEMNODE1 3587.488037
13 15696.819336 bw MEMNODE0 3867.193115
13 15696.819336 bw MEMNODE1 3867.193115
13 15698.324219 bw MEMNODE0 4179.840820
13 15698.324219 bw MEMNODE1 4179.840820
13 15699.817383 bw MEMNODE0 4533.890625
13 15699.817383 bw MEMNODE1 4533.890625
13 15701.311523 bw MEMNODE0 4942.021484
13 15701.311523 bw MEMNODE1 4942.021484
13 15711.112305 bw MEMNODE0 4533.890625
13 15711.112305 bw MEMNODE1 4533.890625
13 15711.115234 bw MEMNODE0 4179.840820
13 15711.115234 bw MEMNODE1 4179.840820
13 15711.118164 bw MEMNODE0 3867.192871
13 15711.118164 bw MEMNODE1 3867.192871
13 15711.120117 bw MEMNODE0 3587.487793
13 15711.120117 bw MEMNODE1 3587.487793
13 15711.122070 bw MEMNODE0 3334.288818
13 15711.122070 bw MEMNODE1 3334.288818
13 15711.125000 bw MEMNODE0 3102.404785
13 15711.125000 bw MEMNODE1 3102.404785
13 15711.126953 bw MEMNODE0 2888.458496
13 15711.126953 bw MEMNODE1 2888.458496
13 15711.129883 bw MEMNODE0 2690.450195
13 15711.129883 bw MEMNODE1 2690.450195
13 15711.131836 bw MEMNODE0 2506.145020
13 15711.131836 bw MEMNODE1 2506.145020
13 15711.134766 bw MEMNODE0 2333.870361
13 15711.134766 bw MEMNODE1 2333.870361
13 15711.136719 bw MEMNODE0 2171.723145
13 15711.136719 bw MEMNODE1 2171.723145
13 15711.139648 bw MEMNODE0 2018.938599
13 15711.139648 bw MEMNODE1 2018.938599
13 15711.141602 bw MEMNODE0 1875.214233
13 15711.141602 bw MEMNODE1 1875.214233
13 15711.143555 bw MEMNODE0 1738.994141
13 15711.143555 bw MEMNODE1 1738.994141
13 15711.147461 bw MEMNODE0 1609.517334
13 15711.147461 bw MEMNODE1 1609.517334
13 15711.149414 bw MEMNODE0 1486.073242
13 15711.149414 bw MEMNODE1 1486.073242
13 15711.151367 bw MEMNODE0 1367.961426
13 15711.151367 bw MEMNODE1 1367.961426
13 15711.153320 bw MEMNODE0 1254.890381
13 15711.153320 bw MEMNODE1 1254.890381
13 15711.155273 bw MEMNODE0 1146.306519
13 15711.155273 bw MEMNODE1 1146.306519
13 15711.158203 bw MEMNODE0 1042.016235
13 15711.158203 bw MEMNODE1 1042.016235
13 15711.160156 bw MEMNODE0 941.719971
13 15711.160156 bw MEMNODE1 941.719971
13 15711.162109 bw MEMNODE0 862.096313
13 15711.162109 bw MEMNODE1 862.096313
13 15711.164062 bw MEMNODE0 784.931213
13 15711.164062 bw MEMNODE1 784.931213
13 15711.166992 bw MEMNODE0 709.899170
13 15711.166992 bw MEMNODE1 709.899170
13 15711.168945 bw MEMNODE0 636.908813
13 15711.168945 bw MEMNODE1 636.908813
13 15711.170898 bw MEMNODE0 565.866760
13 15711.170898 bw MEMNODE1 565.866760
13 15711.173828 bw MEMNODE0 496.664703
13 15711.173828 bw MEMNODE1 496.664703
13 15711.175781 bw MEMNODE0 429.218628
13 15711.175781 bw MEMNODE1 429.218628
13 15711.177734 bw MEMNODE0 363.435272
13 15711.177734 bw MEMNODE1 363.435272
13 15711.179688 bw MEMNODE0 299.242676
13 15711.179688 bw MEMNODE1 299.242676
13 15711.182617 bw MEMNODE0 236.570541
13 15711.182617 bw MEMNODE1 236.570541
13 15711.184570 bw MEMNODE0 175.419785
13 15711.184570 bw MEMNODE1 175.419785
13 15711.186523 bw MEMNODE0 115.648598
13 15711.186523 bw MEMNODE1 115.648598
13 15711.189453 bw MEMNODE0 57.212784
13 15711.189453 bw MEMNODE1 57.212784
13 15711.191406 bw MEMNODE0 -0.000313
13 15711.191406 bw MEMNODE1 -0.000313
13 15711.693359 bw MEMNODE0 169.220917
13 15711.693359 bw MEMNODE1 169.220917
13 15713.210938 bw MEMNODE0 350.083740
13 15713.210938 bw MEMNODE1 350.083740
13 15714.745117 bw MEMNODE0 544.529541
13 15714.745117 bw MEMNODE1 544.529541
13 15716.251953 bw MEMNODE0 754.634705
13 15716.251953 bw MEMNODE1 754.634705
13 15717.783203 bw MEMNODE0 983.512695
13 15717.783203 bw MEMNODE1 983.512695
13 15719.286133 bw MEMNODE0 1234.939819
13 15719.286133 bw MEMNODE1 1234.939819
13 15720.787109 bw MEMNODE0 1600.165039
13 15720.787109 bw MEMNODE1 1600.165039
13 15722.609375 bw MEMNODE1 1918.128052
13 15722.609375 bw MEMNODE0 1918.128052
13 15730.401367 bw MEMNODE1 2740.618164
13 15730.401367 bw MEMNODE0 2740.618164
13 15731.733398 bw MEMNODE1 3855.176025
13 15731.733398 bw MEMNODE0 3855.176025
13 15731.739258 bw MEMNODE0 3489.950928
13 15731.739258 bw MEMNODE1 3489.950928
13 15735.189453 bw MEMNODE1 3171.987793
13 15735.189453 bw MEMNODE0 3171.987793
13 15735.195312 bw MEMNODE0 2920.560547
13 15735.195312 bw MEMNODE1 2920.560547
13 15735.259766 bw MEMNODE0 2691.682617
13 15735.259766 bw MEMNODE1 2691.682617
13 15735.264648 bw MEMNODE1 1869.192627
13 15735.264648 bw MEMNODE0 1869.192627
13 15735.290039 bw MEMNODE0 1659.087524
13 15735.290039 bw MEMNODE1 1659.087524
13 15735.316406 bw MEMNODE0 1464.641724
13 15735.316406 bw MEMNODE1 1464.641724
13 15735.322266 bw MEMNODE1 350.083862
13 15735.322266 bw MEMNODE0 350.083862
13 15735.327148 bw MEMNODE0 169.221054
13 15735.327148 bw MEMNODE1 169.221054
13 15735.331055 bw MEMNODE0 -0.000183
13 15735.331055 bw MEMNODE1 -0.000183
13 15735.955078 bw MEMNODE0 138.266083
13 15735.955078 bw MEMNODE1 138.266083
13 15737.454102 bw MEMNODE0 284.098694
13 15737.454102 bw MEMNODE1 284.098694
13 15738.934570 bw MEMNODE0 438.263306
13 15738.934570 bw MEMNODE1 438.263306
13 15740.511719 bw MEMNODE0 602.418457
13 15740.511719 bw MEMNODE1 602.418457
13 15741.973633 bw MEMNODE0 777.065613
13 15741.973633 bw MEMNODE1 777.065613
13 15752.232422 bw MEMNODE0 1093.481201
13 15752.232422 bw MEMNODE1 1093.481201
13 15753.709961 bw MEMNODE0 1451.836426
13 15753.709961 bw MEMNODE1 1451.836426
13 15755.164062 bw MEMNODE0 1863.991821
13 15755.164062 bw MEMNODE1 1863.991821
13 15764.869141 bw MEMNODE0 1451.836426
13 15764.869141 bw MEMNODE1 1451.836426
13 15764.872070 bw MEMNODE0 1093.481201
13 15764.872070 bw MEMNODE1 1093.481201
13 15764.874023 bw MEMNODE0 777.065552
13 15764.874023 bw MEMNODE1 777.065552
13 15764.876953 bw MEMNODE0 602.418396
13 15764.876953 bw MEMNODE1 602.418396
13 15764.878906 bw MEMNODE0 438.263214
13 15764.878906 bw MEMNODE1 438.263214
13 15764.880859 bw MEMNODE0 284.098572
13 15764.880859 bw MEMNODE1 284.098572
13 15764.882812 bw MEMNODE0 138.265976
13 15764.882812 bw MEMNODE1 138.265976
13 15764.884766 bw MEMNODE0 -0.000290
13 15764.884766 bw MEMNODE1 -0.000290
13 15765.381836 bw MEMNODE0 164.729248
13 15765.381836 bw MEMNODE1 164.729248
13 15766.822266 bw MEMNODE0 339.861816
13 15766.822266 bw MEMNODE1 339.861816
13 15768.302734 bw MEMNODE0 527.150330
13 15768.302734 bw MEMNODE1 527.150330
13 15769.768555 bw MEMNODE0 728.259949
13 15769.768555 bw MEMNODE1 728.259949
13 15771.222656 bw MEMNODE0 945.255066
13 15771.222656 bw MEMNODE1 945.255066
13 15772.680664 bw MEMNODE0 1180.928223
13 15772.680664 bw MEMNODE1 1180.928223
13 15774.136719 bw MEMNODE0 1438.749023
13 15774.136719 bw MEMNODE1 1438.749023
13 15775.577148 bw MEMNODE0 1723.015869
13 15775.577148 bw MEMNODE1 1723.015869
13 15777.026367 bw MEMNODE0 2040.092773
13 15777.026367 bw MEMNODE1 2040.092773
13 15778.461914 bw MEMNODE0 2397.978271
13 15778.461914 bw MEMNODE1 2397.978271
13 15779.906250 bw MEMNODE0 2809.058105
13 15779.906250 bw MEMNODE1 2809.058105
13 15789.636719 bw MEMNODE0 2397.978271
13 15789.636719 bw MEMNODE1 2397.978271
13 15789.638672 bw MEMNODE0 2040.092773
13 15789.638672 bw MEMNODE1 2040.092773
13 15789.641602 bw MEMNODE0 1723.015869
13 15789.641602 bw MEMNODE1 1723.015869
13 15789.648438 bw MEMNODE0 1438.749023
13 15789.648438 bw MEMNODE1 1438.749023
13 15789.651367 bw MEMNODE0 1180.928223
13 15789.651367 bw MEMNODE1 1180.928223
13 15789.653320 bw MEMNODE0 945.255005
13 15789.653320 bw MEMNODE1 945.255005
13 15789.656250 bw MEMNODE0 728.259888
13 15789.656250 bw MEMNODE1 728.259888
13 15789.658203 bw MEMNODE0 527.150269
13 15789.658203 bw MEMNODE1 527.150269
13 15789.660156 bw MEMNODE0 339.861755
13 15789.660156 bw MEMNODE1 339.861755
13 15789.662109 bw MEMNODE0 164.729202
13 15789.662109 bw MEMNODE1 164.729202
13 15789.664062 bw MEMNODE0 -0.000336
13 15789.664062 bw MEMNODE1 -0.000336
13 15790.168945 bw MEMNODE0 186.980408
13 15790.168945 bw MEMNODE1 186.980408
13 15791.593750 bw MEMNODE0 387.332581
13 15791.593750 bw MEMNODE1 387.332581
13 15793.079102 bw MEMNODE0 603.823059
13 15793.079102 bw MEMNODE1 603.823059
13 15794.540039 bw MEMNODE0 838.928101
13 15794.540039 bw MEMNODE1 838.928101
13 15795.995117 bw MEMNODE0 1096.052979
13 15795.995117 bw MEMNODE1 1096.052979
13 15797.441406 bw MEMNODE0 1379.591675
13 15797.441406 bw MEMNODE1 1379.591675
13 15798.909180 bw MEMNODE0 1696.105103
13 15798.909180 bw MEMNODE1 1696.105103
13 15800.351562 bw MEMNODE0 2053.490967
13 15800.351562 bw MEMNODE1 2053.490967
13 15801.796875 bw MEMNODE0 2463.994141
13 15801.796875 bw MEMNODE1 2463.994141
13 15811.541016 bw MEMNODE0 2053.490967
13 15811.541016 bw MEMNODE1 2053.490967
13 15811.543945 bw MEMNODE0 1696.104980
13 15811.543945 bw MEMNODE1 1696.104980
13 15811.546875 bw MEMNODE0 1379.591553
13 15811.546875 bw MEMNODE1 1379.591553
13 15811.548828 bw MEMNODE0 1096.052856
13 15811.548828 bw MEMNODE1 1096.052856
13 15811.551758 bw MEMNODE0 838.927979
13 15811.551758 bw MEMNODE1 838.927979
13 15811.553711 bw MEMNODE0 603.822937
13 15811.553711 bw MEMNODE1 603.822937
13 15811.555664 bw MEMNODE0 387.332458
13 15811.555664 bw MEMNODE1 387.332458
13 15811.558594 bw MEMNODE0 186.980270
13 15811.558594 bw MEMNODE1 186.980270
13 15811.561523 bw MEMNODE0 -0.000473
13 15811.561523 bw MEMNODE1 -0.000473
13 15812.063477 bw MEMNODE0 148.308594
13 15812.063477 bw MEMNODE1 148.308594
13 15813.499023 bw MEMNODE0 305.093262
13 15813.499023 bw MEMNODE1 305.093262
13 15815.010742 bw MEMNODE0 471.909241
13 15815.010742 bw MEMNODE1 471.909241
13 15816.492188 bw MEMNODE0 649.887878
13 15816.492188 bw MEMNODE1 649.887878
13 15817.978516 bw MEMNODE0 840.674561
13 15817.978516 bw MEMNODE1 840.674561
13 15819.439453 bw MEMNODE0 1046.018677
13 15819.439453 bw MEMNODE1 1046.018677
13 15820.899414 bw MEMNODE0 1268.096313
13 15820.899414 bw MEMNODE1 1268.096313
13 15822.353516 bw MEMNODE0 1531.809937
13 15822.353516 bw MEMNODE1 1531.809937
13 15823.810547 bw MEMNODE0 1856.425537
13 15823.810547 bw MEMNODE1 1856.425537
13 15825.255859 bw MEMNODE0 2224.439941
13 15825.255859 bw MEMNODE1 2224.439941
13 15827.375977 bw MEMNODE1 2268.133789
13 15827.375977 bw MEMNODE0 2268.133789
13 15836.125000 bw MEMNODE0 1900.119385
13 15836.125000 bw MEMNODE1 1900.119385
13 15836.130859 bw MEMNODE1 1948.447998
13 15836.130859 bw MEMNODE0 1948.447998
13 15836.132812 bw MEMNODE0 1623.832397
13 15836.132812 bw MEMNODE1 1623.832397
13 15837.521484 bw MEMNODE0 1360.118774
13 15837.521484 bw MEMNODE1 1360.118774
13 15837.524414 bw MEMNODE1 1409.291016
13 15837.524414 bw MEMNODE0 1409.291016
13 15838.911133 bw MEMNODE0 1187.213379
13 15838.911133 bw MEMNODE1 1187.213379
13 15838.918945 bw MEMNODE0 981.869202
13 15838.918945 bw MEMNODE1 981.869202
13 15838.944336 bw MEMNODE0 791.082520
13 15838.944336 bw MEMNODE1 791.082520
13 15838.966797 bw MEMNODE0 613.103882
13 15838.966797 bw MEMNODE1 613.103882
13 15838.989258 bw MEMNODE0 446.287903
13 15838.989258 bw MEMNODE1 446.287903
13 15839.011719 bw MEMNODE0 289.503235
13 15839.011719 bw MEMNODE1 289.503235
13 15839.034180 bw MEMNODE0 141.194168
13 15839.034180 bw MEMNODE1 141.194168
13 15848.398438 bw MEMNODE0 306.802856
13 15848.398438 bw MEMNODE1 306.802856
13 15849.930664 bw MEMNODE0 483.644226
13 15849.930664 bw MEMNODE1 483.644226
13 15851.574219 bw MEMNODE0 674.368774
13 15851.574219 bw MEMNODE1 674.368774
13 15853.056641 bw MEMNODE0 879.620361
13 15853.056641 bw MEMNODE1 879.620361
13 15854.529297 bw MEMNODE0 1101.673950
13 15854.529297 bw MEMNODE1 1101.673950
13 15855.993164 bw MEMNODE0 1343.411377
13 15855.993164 bw MEMNODE1 1343.411377
13 15857.456055 bw MEMNODE0 1608.627686
13 15857.456055 bw MEMNODE1 1608.627686
13 15858.936523 bw MEMNODE0 1902.753784
13 15858.936523 bw MEMNODE1 1902.753784
13 15860.402344 bw MEMNODE0 2232.464844
13 15860.402344 bw MEMNODE1 2232.464844
13 15861.873047 bw MEMNODE0 2607.728271
13 15861.873047 bw MEMNODE1 2607.728271
13 15863.458008 bw MEMNODE0 3048.679932
13 15863.458008 bw MEMNODE1 3048.679932
13 15865.029297 bw MEMNODE0 3582.152100
13 15865.029297 bw MEMNODE1 3582.152100
13 15866.491211 bw MEMNODE0 4245.042480
13 15866.491211 bw MEMNODE1 4245.042480
13 15867.952148 bw MEMNODE0 5120.256348
13 15867.952148 bw MEMNODE1 5120.256348
13 15872.522461 bw MEMNODE0 4245.042480
13 15872.522461 bw MEMNODE1 4245.042480
13 15872.525391 bw MEMNODE0 3582.152100
13 15872.525391 bw MEMNODE1 3582.152100
13 15872.527344 bw MEMNODE0 3048.679932
13 15872.527344 bw MEMNODE1 3048.679932
13 15872.529297 bw MEMNODE0 2607.728271
13 15872.529297 bw MEMNODE1 2607.728271
13 15872.532227 bw MEMNODE0 2232.464844
13 15872.532227 bw MEMNODE1 2232.464844
13 15872.534180 bw MEMNODE0 1902.753784
13 15872.534180 bw MEMNODE1 1902.753784
13 15872.536133 bw MEMNODE0 1608.627686
13 15872.536133 bw MEMNODE1 1608.627686
13 15872.538086 bw MEMNODE0 1343.411377
13 15872.538086 bw MEMNODE1 1343.411377
13 15872.540039 bw MEMNODE0 1101.673828
13 15872.540039 bw MEMNODE1 1101.673828
13 15872.542969 bw MEMNODE0 879.620239
13 15872.542969 bw MEMNODE1 879.620239
13 15872.544922 bw MEMNODE0 674.368652
13 15872.544922 bw MEMNODE1 674.368652
13 15872.546875 bw MEMNODE0 483.644104
13 15872.546875 bw MEMNODE1 483.644104
13 15872.549805 bw MEMNODE0 306.802734
13 15872.549805 bw MEMNODE1 306.802734
13 15872.551758 bw MEMNODE0 141.194031
13 15872.551758 bw MEMNODE1 141.194031
13 15918.871094 bw MEMNODE1 92.021774
13 15918.871094 bw MEMNODE0 92.021774
13 15918.897461 bw MEMNODE1 43.693100
13 15918.897461 bw MEMNODE0 43.693100
13 15918.921875 bw MEMNODE1 -0.000828
13 15918.921875 bw MEMNODE0 -0.000828
13 15918.923828 bw MEMNODE1 352.616241
13 15918.923828 bw MEMNODE0 352.616241
13 15923.228516 bw MEMNODE1 398.225677
13 15923.228516 bw MEMNODE0 398.225677
13 15930.267578 bw MEMNODE1 45.608612
13 15930.267578 bw MEMNODE0 45.608612
13 16010.929688 bw MEMNODE1 -0.000813
13 16010.929688 bw MEMNODE0 -0.000813
13 16174.890625 bw MEMNODE1 622.018921
13 16174.890625 bw MEMNODE0 622.018921
13 16174.917969 bw MEMNODE1 1245.553711
13 16174.917969 bw MEMNODE0 1245.553711
13 16174.993164 bw MEMNODE1 1816.504395
13 16174.993164 bw MEMNODE0 1816.504395
13 16175.123047 bw MEMNODE0 2065.713379
13 16175.123047 bw MEMNODE1 2065.713379
13 16181.321289 bw MEMNODE1 1443.693604
13 16181.321289 bw MEMNODE0 1443.693604
13 16181.333008 bw MEMNODE1 820.158813
13 16181.333008 bw MEMNODE0 820.158813
13 16181.999023 bw MEMNODE1 249.208130
13 16181.999023 bw MEMNODE0 249.208130
13 16182.000000 bw MEMNODE0 685.323975
13 16182.000000 bw MEMNODE1 685.323975
13 16183.596680 bw MEMNODE0 1213.567383
13 16183.596680 bw MEMNODE1 1213.567383
13 16185.107422 bw MEMNODE0 1873.786621
13 16185.107422 bw MEMNODE1 1873.786621
13 16186.606445 bw MEMNODE0 2751.626465
13 16186.606445 bw MEMNODE1 2751.626465
13 16191.163086 bw MEMNODE0 1873.786743
13 16191.163086 bw MEMNODE1 1873.786743
13 16191.166016 bw MEMNODE0 1213.567505
13 16191.166016 bw MEMNODE1 1213.567505
13 16191.168945 bw MEMNODE0 685.324036
13 16191.168945 bw MEMNODE1 685.324036
13 16191.171875 bw MEMNODE0 249.208191
13 16191.171875 bw MEMNODE1 249.208191
13 16191.173828 bw MEMNODE0 -0.000870
13 16191.173828 bw MEMNODE1 -0.000870
13 16223.583984 bw MEMNODE1 339.240479
13 16223.583984 bw MEMNODE0 339.240479
13 16223.590820 bw MEMNODE1 678.538025
13 16223.590820 bw MEMNODE0 678.538025
13 16229.447266 bw MEMNODE1 1217.627197
13 16229.447266 bw MEMNODE0 1217.627197
13 16235.375000 bw MEMNODE1 878.385864
13 16235.375000 bw MEMNODE0 878.385864
13 16235.379883 bw MEMNODE1 539.088318
13 16235.379883 bw MEMNODE0 539.088318
13 16235.386719 bw MEMNODE1 2468.433594
13 16235.386719 bw MEMNODE0 2468.433594
13 16236.867188 bw MEMNODE1 1929.344360
13 16236.867188 bw MEMNODE0 1929.344360
13 16236.875000 bw MEMNODE1 2711.322266
13 16236.875000 bw MEMNODE0 2711.322266
13 16237.448242 bw MEMNODE0 2852.286621
13 16237.448242 bw MEMNODE1 2852.286621
13 16237.459961 bw MEMNODE1 922.941406
13 16237.459961 bw MEMNODE0 922.941406
13 16240.143555 bw MEMNODE1 2226.984863
13 16240.143555 bw MEMNODE0 2226.984863
13 16241.989258 bw MEMNODE0 2394.826172
13 16241.989258 bw MEMNODE1 2394.826172
13 16241.990234 bw MEMNODE1 1612.848389
13 16241.990234 bw MEMNODE0 1612.848389
13 16243.210938 bw MEMNODE1 308.805054
13 16243.210938 bw MEMNODE0 308.805054
13 16243.298828 bw MEMNODE1 356.713165
13 16243.298828 bw MEMNODE0 356.713165
13 16243.552734 bw MEMNODE0 536.354431
13 16243.552734 bw MEMNODE1 536.354431
13 16246.710938 bw MEMNODE1 586.320862
13 16246.710938 bw MEMNODE0 586.320862
13 16247.188477 bw MEMNODE0 801.052185
13 16247.188477 bw MEMNODE1 801.052185
13 16249.829102 bw MEMNODE0 1051.281250
13 16249.829102 bw MEMNODE1 1051.281250
13 16251.594727 bw MEMNODE0 1332.657959
13 16251.594727 bw MEMNODE1 1332.657959
13 16252.842773 bw MEMNODE0 1641.161377
13 16252.842773 bw MEMNODE1 1641.161377
13 16254.597656 bw MEMNODE0 1998.017944
13 16254.597656 bw MEMNODE1 1998.017944
13 16256.076172 bw MEMNODE0 2409.221680
13 16256.076172 bw MEMNODE1 2409.221680
13 16265.803711 bw MEMNODE0 1998.017944
13 16265.803711 bw MEMNODE1 1998.017944
13 16265.806641 bw MEMNODE0 1641.161377
13 16265.806641 bw MEMNODE1 1641.161377
13 16265.808594 bw MEMNODE0 1332.657959
13 16265.808594 bw MEMNODE1 1332.657959
13 16265.810547 bw MEMNODE0 1051.281250
13 16265.810547 bw MEMNODE1 1051.281250
13 16265.814453 bw MEMNODE0 801.052124
13 16265.814453 bw MEMNODE1 801.052124
13 16265.816406 bw MEMNODE0 586.320801
13 16265.816406 bw MEMNODE1 586.320801
13 16265.819336 bw MEMNODE0 406.679565
13 16265.819336 bw MEMNODE1 406.679565
13 16265.821289 bw MEMNODE0 238.838226
13 16265.821289 bw MEMNODE1 238.838226
13 16265.824219 bw MEMNODE0 97.873917
13 16265.824219 bw MEMNODE1 97.873917
13 16265.826172 bw MEMNODE0 394.320312
13 16265.826172 bw MEMNODE1 394.320312
13 16267.825195 bw MEMNODE0 742.412476
13 16267.825195 bw MEMNODE1 742.412476
13 16269.464844 bw MEMNODE0 1148.560181
13 16269.464844 bw MEMNODE1 1148.560181
13 16279.313477 bw MEMNODE0 742.412476
13 16279.313477 bw MEMNODE1 742.412476
13 16279.316406 bw MEMNODE0 394.320343
13 16279.316406 bw MEMNODE1 394.320343
13 16279.319336 bw MEMNODE0 97.873932
13 16279.319336 bw MEMNODE1 97.873932
13 16279.876953 bw MEMNODE0 511.277252
13 16279.876953 bw MEMNODE1 511.277252
13 16289.552734 bw MEMNODE0 97.873932
13 16289.552734 bw MEMNODE1 97.873932
13 16290.009766 bw MEMNODE0 409.309448
13 16290.009766 bw MEMNODE1 409.309448
13 16291.621094 bw MEMNODE0 765.514343
13 16291.621094 bw MEMNODE1 765.514343
13 16293.108398 bw MEMNODE0 1176.223267
13 16293.108398 bw MEMNODE1 1176.223267
13 16302.847656 bw MEMNODE0 765.514343
13 16302.847656 bw MEMNODE1 765.514343
13 16302.850586 bw MEMNODE0 409.309448
13 16302.850586 bw MEMNODE1 409.309448
13 16302.853516 bw MEMNODE0 97.873932
13 16302.853516 bw MEMNODE1 97.873932
13 16303.356445 bw MEMNODE0 269.722046
13 16303.356445 bw MEMNODE1 269.722046
13 16304.801758 bw MEMNODE0 452.971863
13 16304.801758 bw MEMNODE1 452.971863
13 16315.201172 bw MEMNODE0 803.027405
13 16315.201172 bw MEMNODE1 803.027405
13 16316.829102 bw MEMNODE0 1211.361572
13 16316.829102 bw MEMNODE1 1211.361572
13 16326.625000 bw MEMNODE0 803.027405
13 16326.625000 bw MEMNODE1 803.027405
13 16326.627930 bw MEMNODE0 452.971863
13 16326.627930 bw MEMNODE1 452.971863
13 16326.629883 bw MEMNODE0 269.722046
13 16326.629883 bw MEMNODE1 269.722046
13 16326.632812 bw MEMNODE0 97.873917
13 16326.632812 bw MEMNODE1 97.873917
13 16326.764648 bw MEMNODE1 47.907463
13 16326.764648 bw MEMNODE0 47.907463
13 16326.791992 bw MEMNODE1 -0.000652
13 16326.791992 bw MEMNODE0 -0.000652
13 16326.793945 bw MEMNODE1 408.292816
13 16326.793945 bw MEMNODE0 408.292816
13 16331.936523 bw MEMNODE1 758.947754
13 16331.936523 bw MEMNODE0 758.947754
13 16333.169922 bw MEMNODE1 1151.887085
13 16333.169922 bw MEMNODE0 1151.887085
13 16336.590820 bw MEMNODE1 743.593628
13 16336.590820 bw MEMNODE0 743.593628
13 16341.218750 bw MEMNODE1 1273.751465
13 16341.218750 bw MEMNODE0 1273.751465
13 16343.343750 bw MEMNODE1 923.096558
13 16343.343750 bw MEMNODE0 923.096558
13 16343.349609 bw MEMNODE1 530.157227
13 16343.349609 bw MEMNODE0 530.157227
13 16343.382812 bw MEMNODE1 574.916382
13 16343.382812 bw MEMNODE0 574.916382
13 16348.759766 bw MEMNODE1 622.555359
13 16348.759766 bw MEMNODE0 622.555359
13 16348.763672 bw MEMNODE1 92.397461
13 16348.763672 bw MEMNODE0 92.397461
13 16354.037109 bw MEMNODE1 143.250397
13 16354.037109 bw MEMNODE0 143.250397
13 16359.296875 bw MEMNODE1 197.779388
13 16359.296875 bw MEMNODE0 197.779388
13 16376.419922 bw MEMNODE1 268.974548
13 16376.419922 bw MEMNODE0 268.974548
13 16390.343750 bw MEMNODE1 376.729980
13 16390.343750 bw MEMNODE0 376.729980
13 16395.613281 bw MEMNODE1 502.497620
13 16395.613281 bw MEMNODE0 502.497620
13 16400.892578 bw MEMNODE1 653.552368
13 16400.892578 bw MEMNODE0 653.552368
13 16406.158203 bw MEMNODE1 903.217163
13 16406.158203 bw MEMNODE0 903.217163
13 16411.445312 bw MEMNODE1 1277.623047
13 16411.445312 bw MEMNODE0 1277.623047
13 16416.761719 bw MEMNODE1 1653.540771
13 16416.761719 bw MEMNODE0 1653.540771
13 16422.128906 bw MEMNODE1 1279.134888
13 16422.128906 bw MEMNODE0 1279.134888
13 16422.146484 bw MEMNODE1 1661.010742
13 16422.146484 bw MEMNODE0 1661.010742
13 16422.179688 bw MEMNODE1 1411.345947
13 16422.179688 bw MEMNODE0 1411.345947
13 16427.373047 bw MEMNODE1 1260.291260
13 16427.373047 bw MEMNODE0 1260.291260
13 16427.402344 bw MEMNODE1 884.373535
13 16427.402344 bw MEMNODE0 884.373535
13 16427.417969 bw MEMNODE1 758.605896
13 16427.417969 bw MEMNODE0 758.605896
13 16427.460938 bw MEMNODE1 926.351013
13 16427.460938 bw MEMNODE0 926.351013
13 16427.464844 bw MEMNODE1 818.595581
13 16427.464844 bw MEMNODE0 818.595581
13 16432.603516 bw MEMNODE1 747.400391
13 16432.603516 bw MEMNODE0 747.400391
13 16432.621094 bw MEMNODE1 365.524567
13 16432.621094 bw MEMNODE0 365.524567
13 16432.652344 bw MEMNODE1 310.995575
13 16432.652344 bw MEMNODE0 310.995575
13 16432.695312 bw MEMNODE1 260.142639
13 16432.695312 bw MEMNODE0 260.142639
13 16432.724609 bw MEMNODE1 212.503662
13 16432.724609 bw MEMNODE0 212.503662
13 16432.750000 bw MEMNODE1 167.744507
13 16432.750000 bw MEMNODE0 167.744507
13 16451.306641 bw MEMNODE1 -0.000595
13 16451.306641 bw MEMNODE0 -0.000595
13 16684.416016 bw MEMNODE0 463.662537
13 16684.416016 bw MEMNODE1 463.662537
13 16685.681641 bw MEMNODE0 716.252563
13 16685.681641 bw MEMNODE1 716.252563
13 16685.697266 bw MEMNODE1 1251.257812
13 16685.697266 bw MEMNODE0 1251.257812
13 16685.714844 bw MEMNODE1 1787.102905
13 16685.714844 bw MEMNODE0 1787.102905
13 16685.726562 bw MEMNODE1 2323.228516
13 16685.726562 bw MEMNODE0 2323.228516
13 16693.042969 bw MEMNODE0 1859.565430
13 16693.042969 bw MEMNODE1 1859.565430
13 16693.173828 bw MEMNODE1 1324.560181
13 16693.173828 bw MEMNODE0 1324.560181
13 16693.179688 bw MEMNODE1 788.715088
13 16693.179688 bw MEMNODE0 788.715088
13 16693.187500 bw MEMNODE1 252.589417
13 16693.187500 bw MEMNODE0 252.589417
13 16701.517578 bw MEMNODE0 -0.000626
13 16701.517578 bw MEMNODE1 -0.000626
13 16735.667969 bw MEMNODE0 230.318756
13 16735.667969 bw MEMNODE1 230.318756
13 16737.226562 bw MEMNODE0 509.451904
13 16737.226562 bw MEMNODE1 509.451904
13 16741.443359 bw MEMNODE1 729.430420
13 16741.443359 bw MEMNODE0 729.430420
13 16741.462891 bw MEMNODE1 1007.162964
13 16741.462891 bw MEMNODE0 1007.162964
13 16741.535156 bw MEMNODE1 1277.418945
13 16741.535156 bw MEMNODE0 1277.418945
13 16741.566406 bw MEMNODE1 1548.461792
13 16741.566406 bw MEMNODE0 1548.461792
13 16750.144531 bw MEMNODE1 1970.555786
13 16750.144531 bw MEMNODE0 1970.555786
13 16751.556641 bw MEMNODE0 1691.422607
13 16751.556641 bw MEMNODE1 1691.422607
13 16753.031250 bw MEMNODE1 2139.660645
13 16753.031250 bw MEMNODE0 2139.660645
13 16753.035156 bw MEMNODE0 1909.341309
13 16753.035156 bw MEMNODE1 1909.341309
13 16755.419922 bw MEMNODE1 2363.543945
13 16755.419922 bw MEMNODE0 2363.543945
13 16755.865234 bw MEMNODE1 2085.811279
13 16755.865234 bw MEMNODE0 2085.811279
13 16756.314453 bw MEMNODE0 2212.036133
13 16756.314453 bw MEMNODE1 2212.036133
13 16756.318359 bw MEMNODE1 2585.213867
13 16756.318359 bw MEMNODE0 2585.213867
13 16756.324219 bw MEMNODE1 2314.170898
13 16756.324219 bw MEMNODE0 2314.170898
13 16756.335938 bw MEMNODE1 2043.914917
13 16756.335938 bw MEMNODE0 2043.914917
13 16759.621094 bw MEMNODE1 1621.820923
13 16759.621094 bw MEMNODE0 1621.820923
13 16759.626953 bw MEMNODE1 1401.842407
13 16759.626953 bw MEMNODE0 1401.842407
13 16759.634766 bw MEMNODE1 1782.158081
13 16759.634766 bw MEMNODE0 1782.158081
13 16759.908203 bw MEMNODE0 1924.538452
13 16759.908203 bw MEMNODE1 1924.538452
13 16761.955078 bw MEMNODE1 1476.300293
13 16761.955078 bw MEMNODE0 1476.300293
13 16764.220703 bw MEMNODE1 2011.865234
13 16764.220703 bw MEMNODE0 2011.865234
13 16764.226562 bw MEMNODE1 1557.662598
13 16764.226562 bw MEMNODE0 1557.662598
13 16765.500000 bw MEMNODE0 1735.455811
13 16765.500000 bw MEMNODE1 1735.455811
13 16765.509766 bw MEMNODE1 2379.886230
13 16765.509766 bw MEMNODE0 2379.886230
13 16767.037109 bw MEMNODE1 2006.708374
13 16767.037109 bw MEMNODE0 2006.708374
13 16767.080078 bw MEMNODE1 2472.268799
13 16767.080078 bw MEMNODE0 2472.268799
13 16770.152344 bw MEMNODE1 2091.953125
13 16770.152344 bw MEMNODE0 2091.953125
13 16770.195312 bw MEMNODE0 2316.662354
13 16770.195312 bw MEMNODE1 2316.662354
13 16771.689453 bw MEMNODE1 1781.097412
13 16771.689453 bw MEMNODE0 1781.097412
13 16771.710938 bw MEMNODE1 2545.847168
13 16771.710938 bw MEMNODE0 2545.847168
13 16771.716797 bw MEMNODE1 1901.416748
13 16771.716797 bw MEMNODE0 1901.416748
13 16772.888672 bw MEMNODE0 2166.221436
13 16772.888672 bw MEMNODE1 2166.221436
13 16775.671875 bw MEMNODE1 1700.661133
13 16775.671875 bw MEMNODE0 1700.661133
13 16775.679688 bw MEMNODE0 2025.534180
13 16775.679688 bw MEMNODE1 2025.534180
13 16776.941406 bw MEMNODE1 1260.784424
13 16776.941406 bw MEMNODE0 1260.784424
13 16776.951172 bw MEMNODE0 1623.134033
13 16776.951172 bw MEMNODE1 1623.134033
13 16778.205078 bw MEMNODE0 2032.079712
13 16778.205078 bw MEMNODE1 2032.079712
13 16787.986328 bw MEMNODE0 1623.134033
13 16787.986328 bw MEMNODE1 1623.134033
13 16787.990234 bw MEMNODE0 1260.784424
13 16787.990234 bw MEMNODE1 1260.784424
13 16787.992188 bw MEMNODE0 935.911316
13 16787.992188 bw MEMNODE1 935.911316
13 16787.994141 bw MEMNODE0 671.106567
13 16787.994141 bw MEMNODE1 671.106567
13 16787.996094 bw MEMNODE0 446.397339
13 16787.996094 bw MEMNODE1 446.397339
13 16787.998047 bw MEMNODE0 268.604126
13 16787.998047 bw MEMNODE1 268.604126
13 16788.001953 bw MEMNODE0 126.223709
13 16788.001953 bw MEMNODE1 126.223709
13 16788.003906 bw MEMNODE0 -0.001251
13 16788.003906 bw MEMNODE1 -0.001251
13 16788.005859 bw MEMNODE0 236.734390
13 16788.005859 bw MEMNODE1 236.734390
13 16789.236328 bw MEMNODE0 492.096008
13 16789.236328 bw MEMNODE1 492.096008
13 16790.406250 bw MEMNODE0 768.106812
13 16790.406250 bw MEMNODE1 768.106812
13 16791.572266 bw MEMNODE0 1068.312012
13 16791.572266 bw MEMNODE1 1068.312012
13 16792.744141 bw MEMNODE0 1397.572510
13 16792.744141 bw MEMNODE1 1397.572510
13 16793.927734 bw MEMNODE0 1762.439819
13 16793.927734 bw MEMNODE1 1762.439819
13 16795.173828 bw MEMNODE0 2174.180908
13 16795.173828 bw MEMNODE1 2174.180908
13 16804.888672 bw MEMNODE0 1762.439819
13 16804.888672 bw MEMNODE1 1762.439819
13 16804.890625 bw MEMNODE0 1397.572510
13 16804.890625 bw MEMNODE1 1397.572510
13 16804.892578 bw MEMNODE0 1068.312012
13 16804.892578 bw MEMNODE1 1068.312012
13 16804.896484 bw MEMNODE0 768.106812
13 16804.896484 bw MEMNODE1 768.106812
13 16804.898438 bw MEMNODE0 492.096039
13 16804.898438 bw MEMNODE1 492.096039
13 16804.900391 bw MEMNODE0 236.734436
13 16804.900391 bw MEMNODE1 236.734436
13 16804.902344 bw MEMNODE0 -0.001205
13 16804.902344 bw MEMNODE1 -0.001205
13 16804.904297 bw MEMNODE0 495.402771
13 16804.904297 bw MEMNODE1 495.402771
13 16806.054688 bw MEMNODE0 1073.280884
13 16806.054688 bw MEMNODE1 1073.280884
13 16807.242188 bw MEMNODE0 1771.066162
13 16807.242188 bw MEMNODE1 1771.066162
13 16808.410156 bw MEMNODE0 2648.153809
13 16808.410156 bw MEMNODE1 2648.153809
13 16812.970703 bw MEMNODE0 1771.066040
13 16812.970703 bw MEMNODE1 1771.066040
13 16812.974609 bw MEMNODE0 1073.280762
13 16812.974609 bw MEMNODE1 1073.280762
13 16812.976562 bw MEMNODE0 495.402649
13 16812.976562 bw MEMNODE1 495.402649
13 16812.978516 bw MEMNODE0 -0.001312
13 16812.978516 bw MEMNODE1 -0.001312
13 16850.744141 bw MEMNODE1 447.062653
13 16850.744141 bw MEMNODE0 447.062653
13 16854.453125 bw MEMNODE1 852.687500
13 16854.453125 bw MEMNODE0 852.687500
13 16859.691406 bw MEMNODE1 405.623535
13 16859.691406 bw MEMNODE0 405.623535
13 16859.710938 bw MEMNODE1 810.606689
13 16859.710938 bw MEMNODE0 810.606689
13 16864.314453 bw MEMNODE1 404.981812
13 16864.314453 bw MEMNODE0 404.981812
13 16864.357422 bw MEMNODE1 448.730347
13 16864.357422 bw MEMNODE0 448.730347
13 16869.580078 bw MEMNODE1 495.143951
13 16869.580078 bw MEMNODE0 495.143951
13 16869.587891 bw MEMNODE1 90.160767
13 16869.587891 bw MEMNODE0 90.160767
13 16874.220703 bw MEMNODE1 139.231110
13 16874.220703 bw MEMNODE0 139.231110
13 16879.476562 bw MEMNODE1 191.700882
13 16879.476562 bw MEMNODE0 191.700882
13 16884.744141 bw MEMNODE1 248.085449
13 16884.744141 bw MEMNODE0 248.085449
13 16890.097656 bw MEMNODE1 309.097748
13 16890.097656 bw MEMNODE0 309.097748
13 16955.658203 bw MEMNODE1 248.085449
13 16955.658203 bw MEMNODE0 248.085449
13 16955.685547 bw MEMNODE1 191.700897
13 16955.685547 bw MEMNODE0 191.700897
13 16955.710938 bw MEMNODE1 139.231125
13 16955.710938 bw MEMNODE0 139.231125
13 16955.736328 bw MEMNODE1 90.160782
13 16955.736328 bw MEMNODE0 90.160782
13 16955.761719 bw MEMNODE1 43.747185
13 16955.761719 bw MEMNODE0 43.747185
13 16955.789062 bw MEMNODE1 -0.001347
13 16955.789062 bw MEMNODE0 -0.001347
13 17117.482422 bw MEMNODE0 1505.880981
13 17117.482422 bw MEMNODE1 1505.880981
13 17118.740234 bw MEMNODE1 2170.384521
13 17118.740234 bw MEMNODE0 2170.384521
13 17118.763672 bw MEMNODE1 2709.473633
13 17118.763672 bw MEMNODE0 2709.473633
13 17120.138672 bw MEMNODE0 1203.591309
13 17120.138672 bw MEMNODE1 1203.591309
13 17120.148438 bw MEMNODE1 1864.876465
13 17120.148438 bw MEMNODE0 1864.876465
13 17120.189453 bw MEMNODE1 2509.104248
13 17120.189453 bw MEMNODE0 2509.104248
13 17124.759766 bw MEMNODE1 1844.600708
13 17124.759766 bw MEMNODE0 1844.600708
13 17126.183594 bw MEMNODE1 1305.511475
13 17126.183594 bw MEMNODE0 1305.511475
13 17126.197266 bw MEMNODE1 644.226379
13 17126.197266 bw MEMNODE0 644.226379
13 17126.398438 bw MEMNODE1 -0.001343
13 17126.398438 bw MEMNODE0 -0.001343
13 17133.314453 bw MEMNODE0 417.446686
13 17133.314453 bw MEMNODE1 417.446686
13 17142.896484 bw MEMNODE0 -0.001343
13 17142.896484 bw MEMNODE1 -0.001343
13 17168.060547 bw MEMNODE0 323.486267
13 17168.060547 bw MEMNODE1 323.486267
13 17172.972656 bw MEMNODE1 720.308594
13 17172.972656 bw MEMNODE0 720.308594
13 17173.033203 bw MEMNODE1 1048.987793
13 17173.033203 bw MEMNODE0 1048.987793
13 17174.330078 bw MEMNODE1 1357.514404
13 17174.330078 bw MEMNODE0 1357.514404
13 17180.425781 bw MEMNODE0 1034.026855
13 17180.425781 bw MEMNODE1 1034.026855
13 17180.427734 bw MEMNODE0 1376.903076
13 17180.427734 bw MEMNODE1 1376.903076
13 17181.892578 bw MEMNODE1 1981.746582
13 17181.892578 bw MEMNODE0 1981.746582
13 17183.052734 bw MEMNODE1 1584.924316
13 17183.052734 bw MEMNODE0 1584.924316
13 17185.199219 bw MEMNODE1 2414.074219
13 17185.199219 bw MEMNODE0 2414.074219
13 17185.203125 bw MEMNODE1 2085.395020
13 17185.203125 bw MEMNODE0 2085.395020
13 17185.212891 bw MEMNODE0 2916.226562
13 17185.212891 bw MEMNODE1 2916.226562
13 17187.294922 bw MEMNODE1 2607.699951
13 17187.294922 bw MEMNODE0 2607.699951
13 17188.505859 bw MEMNODE1 2002.856445
13 17188.505859 bw MEMNODE0 2002.856445
13 17188.609375 bw MEMNODE1 2048.179199
13 17188.609375 bw MEMNODE0 2048.179199
13 17190.023438 bw MEMNODE1 1219.029419
13 17190.023438 bw MEMNODE0 1219.029419
13 17190.025391 bw MEMNODE1 1265.104736
13 17190.025391 bw MEMNODE0 1265.104736
13 17190.027344 bw MEMNODE0 434.273071
13 17190.027344 bw MEMNODE1 434.273071
13 17192.093750 bw MEMNODE0 91.396790
13 17192.093750 bw MEMNODE1 91.396790
13 17192.095703 bw MEMNODE0 289.865631
13 17192.095703 bw MEMNODE1 289.865631
13 17192.105469 bw MEMNODE1 337.086121
13 17192.105469 bw MEMNODE0 337.086121
13 17195.460938 bw MEMNODE0 575.364197
13 17195.460938 bw MEMNODE1 575.364197
13 17195.468750 bw MEMNODE1 624.553589
13 17195.468750 bw MEMNODE0 624.553589
13 17198.931641 bw MEMNODE0 925.023071
13 17198.931641 bw MEMNODE1 925.023071
13 17200.169922 bw MEMNODE0 1256.361084
13 17200.169922 bw MEMNODE1 1256.361084
13 17201.347656 bw MEMNODE0 1623.583618
13 17201.347656 bw MEMNODE1 1623.583618
13 17202.521484 bw MEMNODE0 2035.241943
13 17202.521484 bw MEMNODE1 2035.241943
13 17212.238281 bw MEMNODE0 1623.583618
13 17212.238281 bw MEMNODE1 1623.583618
13 17212.240234 bw MEMNODE0 1256.361084
13 17212.240234 bw MEMNODE1 1256.361084
13 17212.242188 bw MEMNODE0 925.023071
13 17212.242188 bw MEMNODE1 925.023071
13 17212.244141 bw MEMNODE0 624.553589
13 17212.244141 bw MEMNODE1 624.553589
13 17212.248047 bw MEMNODE0 386.275513
13 17212.248047 bw MEMNODE1 386.275513
13 17212.250000 bw MEMNODE0 187.806671
13 17212.250000 bw MEMNODE1 187.806671
13 17212.251953 bw MEMNODE0 680.588196
13 17212.251953 bw MEMNODE1 680.588196
13 17213.402344 bw MEMNODE0 1254.901123
13 17213.402344 bw MEMNODE1 1254.901123
13 17214.615234 bw MEMNODE0 1950.553223
13 17214.615234 bw MEMNODE1 1950.553223
13 17215.787109 bw MEMNODE0 2825.019531
13 17215.787109 bw MEMNODE1 2825.019531
13 17220.361328 bw MEMNODE0 1950.553223
13 17220.361328 bw MEMNODE1 1950.553223
13 17220.365234 bw MEMNODE0 1254.901123
13 17220.365234 bw MEMNODE1 1254.901123
13 17220.367188 bw MEMNODE0 680.588196
13 17220.367188 bw MEMNODE1 680.588196
13 17220.369141 bw MEMNODE0 187.806671
13 17220.369141 bw MEMNODE1 187.806671
13 17276.787109 bw MEMNODE1 138.617279
13 17276.787109 bw MEMNODE0 138.617279
13 17276.814453 bw MEMNODE1 91.396790
13 17276.814453 bw MEMNODE0 91.396790
13 17276.839844 bw MEMNODE1 45.321514
13 17276.839844 bw MEMNODE0 45.321514
13 17276.865234 bw MEMNODE1 -0.001255
13 17276.865234 bw MEMNODE0 -0.001255
13 17276.867188 bw MEMNODE1 906.594543
13 17276.867188 bw MEMNODE0 906.594543
13 17281.279297 bw MEMNODE1 -0.001282
13 17281.279297 bw MEMNODE0 -0.001282
13 17439.332031 bw MEMNODE1 412.237030
13 17439.332031 bw MEMNODE0 412.237030
13 17439.349609 bw MEMNODE1 778.343567
13 17439.349609 bw MEMNODE0 778.343567
13 17439.361328 bw MEMNODE1 1145.171387
13 17439.361328 bw MEMNODE0 1145.171387
13 17439.390625 bw MEMNODE1 1506.817139
13 17439.390625 bw MEMNODE0 1506.817139
13 17441.048828 bw MEMNODE0 1822.720215
13 17441.048828 bw MEMNODE1 1822.720215
13 17449.035156 bw MEMNODE1 1410.481934
13 17449.035156 bw MEMNODE0 1410.481934
13 17450.265625 bw MEMNODE1 1043.654053
13 17450.265625 bw MEMNODE0 1043.654053
13 17450.275391 bw MEMNODE1 677.547485
13 17450.275391 bw MEMNODE0 677.547485
13 17450.451172 bw MEMNODE1 315.901703
13 17450.451172 bw MEMNODE0 315.901703
13 17453.710938 bw MEMNODE0 -0.001434
13 17453.710938 bw MEMNODE1 -0.001434
13 17498.775391 bw MEMNODE1 323.332947
13 17498.775391 bw MEMNODE0 323.332947
13 17498.855469 bw MEMNODE1 548.017517
13 17498.855469 bw MEMNODE0 548.017517
13 17498.873047 bw MEMNODE1 788.675537
13 17498.873047 bw MEMNODE0 788.675537
13 17498.875000 bw MEMNODE1 1029.475098
13 17498.875000 bw MEMNODE0 1029.475098
13 17498.953125 bw MEMNODE1 1328.890259
13 17498.953125 bw MEMNODE0 1328.890259
13 17503.558594 bw MEMNODE0 1531.221802
13 17503.558594 bw MEMNODE1 1531.221802
13 17508.306641 bw MEMNODE1 2086.536377
13 17508.306641 bw MEMNODE0 2086.536377
13 17509.748047 bw MEMNODE1 2664.904053
13 17509.748047 bw MEMNODE0 2664.904053
13 17511.146484 bw MEMNODE1 2341.569580
13 17511.146484 bw MEMNODE0 2341.569580
13 17512.312500 bw MEMNODE1 2042.154419
13 17512.312500 bw MEMNODE0 2042.154419
13 17513.960938 bw MEMNODE0 2470.248047
13 17513.960938 bw MEMNODE1 2470.248047
13 17515.480469 bw MEMNODE1 3247.182861
13 17515.480469 bw MEMNODE0 3247.182861
13 17515.486328 bw MEMNODE1 3006.383301
13 17515.486328 bw MEMNODE0 3006.383301
13 17515.494141 bw MEMNODE1 2765.725342
13 17515.494141 bw MEMNODE0 2765.725342
13 17515.509766 bw MEMNODE1 2210.410889
13 17515.509766 bw MEMNODE0 2210.410889
13 17516.658203 bw MEMNODE1 1985.726318
13 17516.658203 bw MEMNODE0 1985.726318
13 17516.664062 bw MEMNODE1 1407.358643
13 17516.664062 bw MEMNODE0 1407.358643
13 17516.673828 bw MEMNODE0 2012.738525
13 17516.673828 bw MEMNODE1 2012.738525
13 17519.445312 bw MEMNODE0 3061.918945
13 17519.445312 bw MEMNODE1 3061.918945
13 17520.628906 bw MEMNODE1 2284.984131
13 17520.628906 bw MEMNODE0 2284.984131
13 17520.630859 bw MEMNODE0 3821.368164
13 17520.630859 bw MEMNODE1 3821.368164
13 17521.828125 bw MEMNODE0 4040.148193
13 17521.828125 bw MEMNODE1 4040.148193
13 17523.234375 bw MEMNODE0 2503.764160
13 17523.234375 bw MEMNODE1 2503.764160
13 17523.257812 bw MEMNODE0 1454.583862
13 17523.257812 bw MEMNODE1 1454.583862
13 17523.281250 bw MEMNODE0 849.204041
13 17523.281250 bw MEMNODE1 849.204041
13 17523.304688 bw MEMNODE0 421.110382
13 17523.304688 bw MEMNODE1 421.110382
13 17523.328125 bw MEMNODE0 218.778824
13 17523.328125 bw MEMNODE1 218.778824
13 17523.330078 bw MEMNODE0 457.167847
13 17523.330078 bw MEMNODE1 457.167847
13 17524.525391 bw MEMNODE0 713.906006
13 17524.525391 bw MEMNODE1 713.906006
13 17525.689453 bw MEMNODE0 991.412781
13 17525.689453 bw MEMNODE1 991.412781
13 17526.853516 bw MEMNODE0 1293.344116
13 17526.853516 bw MEMNODE1 1293.344116
13 17528.027344 bw MEMNODE0 1624.682129
13 17528.027344 bw MEMNODE1 1624.682129
13 17529.199219 bw MEMNODE0 1991.707275
13 17529.199219 bw MEMNODE1 1991.707275
13 17530.390625 bw MEMNODE0 2403.945557
13 17530.390625 bw MEMNODE1 2403.945557
13 17540.093750 bw MEMNODE0 1991.707275
13 17540.093750 bw MEMNODE1 1991.707275
13 17540.097656 bw MEMNODE0 1624.682129
13 17540.097656 bw MEMNODE1 1624.682129
13 17540.099609 bw MEMNODE0 1293.344116
13 17540.099609 bw MEMNODE1 1293.344116
13 17540.101562 bw MEMNODE0 991.412842
13 17540.101562 bw MEMNODE1 991.412842
13 17540.103516 bw MEMNODE0 713.906067
13 17540.103516 bw MEMNODE1 713.906067
13 17540.105469 bw MEMNODE0 457.167938
13 17540.105469 bw MEMNODE1 457.167938
13 17540.109375 bw MEMNODE0 218.778931
13 17540.109375 bw MEMNODE1 218.778931
13 17540.111328 bw MEMNODE0 -0.001114
13 17540.111328 bw MEMNODE1 -0.001114
13 17607.851562 bw MEMNODE1 848.383301
13 17607.851562 bw MEMNODE0 848.383301
13 17612.488281 bw MEMNODE1 1278.906738
13 17612.488281 bw MEMNODE0 1278.906738
13 17612.566406 bw MEMNODE1 430.522339
13 17612.566406 bw MEMNODE0 430.522339
13 17617.193359 bw MEMNODE1 867.382446
13 17617.193359 bw MEMNODE0 867.382446
13 17621.779297 bw MEMNODE1 436.859009
13 17621.779297 bw MEMNODE0 436.859009
13 17621.785156 bw MEMNODE1 1303.187256
13 17621.785156 bw MEMNODE0 1303.187256
13 17626.349609 bw MEMNODE1 866.327148
13 17626.349609 bw MEMNODE0 866.327148
13 17626.355469 bw MEMNODE1 1716.472412
13 17626.355469 bw MEMNODE0 1716.472412
13 17626.402344 bw MEMNODE1 850.144165
13 17626.402344 bw MEMNODE0 850.144165
13 17630.990234 bw MEMNODE1 1702.412109
13 17630.990234 bw MEMNODE0 1702.412109
13 17631.060547 bw MEMNODE1 852.266846
13 17631.060547 bw MEMNODE0 852.266846
13 17635.621094 bw MEMNODE1 910.654358
13 17635.621094 bw MEMNODE0 910.654358
13 17635.683594 bw MEMNODE1 58.386353
13 17635.683594 bw MEMNODE0 58.386353
13 17704.128906 bw MEMNODE1 -0.001148
13 17704.128906 bw MEMNODE0 -0.001148
13 17797.203125 bw MEMNODE0 486.228668
13 17797.203125 bw MEMNODE1 486.228668
13 17798.373047 bw MEMNODE0 744.651367
13 17798.373047 bw MEMNODE1 744.651367
13 17798.421875 bw MEMNODE1 1314.489990
13 17798.421875 bw MEMNODE0 1314.489990
13 17798.437500 bw MEMNODE1 1878.988281
13 17798.437500 bw MEMNODE0 1878.988281
13 17798.451172 bw MEMNODE1 2444.265625
13 17798.451172 bw MEMNODE0 2444.265625
13 17805.429688 bw MEMNODE0 1958.035767
13 17805.429688 bw MEMNODE1 1958.035767
13 17805.441406 bw MEMNODE1 1388.197144
13 17805.441406 bw MEMNODE0 1388.197144
13 17805.523438 bw MEMNODE1 823.698792
13 17805.523438 bw MEMNODE0 823.698792
13 17805.527344 bw MEMNODE1 258.421387
13 17805.527344 bw MEMNODE0 258.421387
13 17813.851562 bw MEMNODE0 -0.001312
13 17813.851562 bw MEMNODE1 -0.001312
13 17838.947266 bw MEMNODE0 332.196594
13 17838.947266 bw MEMNODE1 332.196594
13 17840.128906 bw MEMNODE0 700.608154
13 17840.128906 bw MEMNODE1 700.608154
13 17841.328125 bw MEMNODE0 1114.847656
13 17841.328125 bw MEMNODE1 1114.847656
13 17850.984375 bw MEMNODE0 700.608154
13 17850.984375 bw MEMNODE1 700.608154
13 17850.986328 bw MEMNODE0 332.196564
13 17850.986328 bw MEMNODE1 332.196564
13 17850.988281 bw MEMNODE0 -0.001343
13 17850.988281 bw MEMNODE1 -0.001343
13 17850.990234 bw MEMNODE0 353.711945
13 17850.990234 bw MEMNODE1 353.711945
13 17853.861328 bw MEMNODE1 601.413940
13 17853.861328 bw MEMNODE0 601.413940
13 17853.871094 bw MEMNODE1 831.216431
13 17853.871094 bw MEMNODE0 831.216431
13 17853.892578 bw MEMNODE1 1035.893677
13 17853.892578 bw MEMNODE0 1035.893677
13 17853.902344 bw MEMNODE1 1227.134644
13 17853.902344 bw MEMNODE0 1227.134644
13 17853.939453 bw MEMNODE1 1474.388062
13 17853.939453 bw MEMNODE0 1474.388062
13 17862.298828 bw MEMNODE0 1120.674805
13 17862.298828 bw MEMNODE1 1120.674805
13 17862.302734 bw MEMNODE0 1361.219727
13 17862.302734 bw MEMNODE1 1361.219727
13 17870.009766 bw MEMNODE1 1113.517700
13 17870.009766 bw MEMNODE0 1113.517700
13 17870.046875 bw MEMNODE1 1650.768555
13 17870.046875 bw MEMNODE0 1650.768555
13 17870.093750 bw MEMNODE1 2192.424316
13 17870.093750 bw MEMNODE0 2192.424316
13 17870.117188 bw MEMNODE1 1945.170898
13 17870.117188 bw MEMNODE0 1945.170898
13 17871.277344 bw MEMNODE1 1715.368408
13 17871.277344 bw MEMNODE0 1715.368408
13 17873.435547 bw MEMNODE1 1510.691162
13 17873.435547 bw MEMNODE0 1510.691162
13 17873.441406 bw MEMNODE1 2266.131836
13 17873.441406 bw MEMNODE0 2266.131836
13 17873.443359 bw MEMNODE0 2998.083252
13 17873.443359 bw MEMNODE1 2998.083252
13 17874.818359 bw MEMNODE1 2806.842285
13 17874.818359 bw MEMNODE0 2806.842285
13 17877.478516 bw MEMNODE1 2265.186523
13 17877.478516 bw MEMNODE0 2265.186523
13 17877.492188 bw MEMNODE1 1727.935791
13 17877.492188 bw MEMNODE0 1727.935791
13 17877.498047 bw MEMNODE0 2204.547363
13 17877.498047 bw MEMNODE1 2204.547363
13 17878.736328 bw MEMNODE1 1449.106567
13 17878.736328 bw MEMNODE0 1449.106567
13 17878.908203 bw MEMNODE0 717.155151
13 17878.908203 bw MEMNODE1 717.155151
13 17878.931641 bw MEMNODE0 476.610168
13 17878.931641 bw MEMNODE1 476.610168
13 17878.933594 bw MEMNODE0 1051.729492
13 17878.933594 bw MEMNODE1 1051.729492
13 17880.167969 bw MEMNODE0 1751.183105
13 17880.167969 bw MEMNODE1 1751.183105
13 17881.332031 bw MEMNODE0 2629.775879
13 17881.332031 bw MEMNODE1 2629.775879
13 17885.884766 bw MEMNODE0 1751.182983
13 17885.884766 bw MEMNODE1 1751.182983
13 17885.886719 bw MEMNODE0 1051.729492
13 17885.886719 bw MEMNODE1 1051.729492
13 17885.888672 bw MEMNODE0 476.610168
13 17885.888672 bw MEMNODE1 476.610168
13 17885.890625 bw MEMNODE0 -0.001434
13 17885.890625 bw MEMNODE1 -0.001434
13 17968.283203 bw MEMNODE1 474.402100
13 17968.283203 bw MEMNODE0 474.402100
13 17976.714844 bw MEMNODE1 -0.001434
13 17976.714844 bw MEMNODE0 -0.001434
13 18042.603516 bw MEMNODE1 360.752472
13 18042.603516 bw MEMNODE0 360.752472
13 18042.609375 bw MEMNODE1 722.142944
13 18042.609375 bw MEMNODE0 722.142944
13 18042.625000 bw MEMNODE1 1077.945557
13 18042.625000 bw MEMNODE0 1077.945557
13 18042.648438 bw MEMNODE1 1431.658813
13 18042.648438 bw MEMNODE0 1431.658813
13 18045.732422 bw MEMNODE0 1921.142578
13 18045.732422 bw MEMNODE1 1921.142578
13 18053.677734 bw MEMNODE1 1559.752075
13 18053.677734 bw MEMNODE0 1559.752075
13 18053.691406 bw MEMNODE1 1198.998169
13 18053.691406 bw MEMNODE0 1198.998169
13 18053.867188 bw MEMNODE1 843.195557
13 18053.867188 bw MEMNODE0 843.195557
13 18053.904297 bw MEMNODE0 353.711823
13 18053.904297 bw MEMNODE1 353.711823
13 18053.957031 bw MEMNODE1 -0.001465
13 18053.957031 bw MEMNODE0 -0.001465
13 18099.070312 bw MEMNODE1 370.878662
13 18099.070312 bw MEMNODE0 370.878662
13 18102.035156 bw MEMNODE1 881.220093
13 18102.035156 bw MEMNODE0 881.220093
13 18102.044922 bw MEMNODE1 1388.653198
13 18102.044922 bw MEMNODE0 1388.653198
13 18102.089844 bw MEMNODE1 1758.929810
13 18102.089844 bw MEMNODE0 1758.929810
13 18102.359375 bw MEMNODE0 1957.014771
13 18102.359375 bw MEMNODE1 1957.014771
13 18109.855469 bw MEMNODE1 1586.134644
13 18109.855469 bw MEMNODE0 1586.134644
13 18109.873047 bw MEMNODE1 1075.793213
13 18109.873047 bw MEMNODE0 1075.793213
13 18109.906250 bw MEMNODE0 1392.135498
13 18109.906250 bw MEMNODE1 1392.135498
13 18109.917969 bw MEMNODE1 2332.447754
13 18109.917969 bw MEMNODE0 2332.447754
13 18109.927734 bw MEMNODE1 1825.014648
13 18109.927734 bw MEMNODE0 1825.014648
13 18112.892578 bw MEMNODE1 1454.738037
13 18112.892578 bw MEMNODE0 1454.738037
13 18112.898438 bw MEMNODE0 1869.229004
13 18112.898438 bw MEMNODE1 1869.229004
13 18114.171875 bw MEMNODE1 928.916809
13 18114.171875 bw MEMNODE0 928.916809
13 18114.175781 bw MEMNODE0 1406.863159
13 18114.175781 bw MEMNODE1 1406.863159
13 18115.564453 bw MEMNODE0 1980.051025
13 18115.564453 bw MEMNODE1 1980.051025
13 18116.755859 bw MEMNODE0 2671.709229
13 18116.755859 bw MEMNODE1 2671.709229
13 18117.958984 bw MEMNODE0 3545.429443
13 18117.958984 bw MEMNODE1 3545.429443
13 18122.537109 bw MEMNODE0 2671.709229
13 18122.537109 bw MEMNODE1 2671.709229
13 18122.539062 bw MEMNODE0 1980.051025
13 18122.539062 bw MEMNODE1 1980.051025
13 18122.542969 bw MEMNODE0 1406.863281
13 18122.542969 bw MEMNODE1 1406.863281
13 18122.544922 bw MEMNODE0 928.916992
13 18122.544922 bw MEMNODE1 928.916992
13 18122.548828 bw MEMNODE0 514.426025
13 18122.548828 bw MEMNODE1 514.426025
13 18122.550781 bw MEMNODE0 198.083740
13 18122.550781 bw MEMNODE1 198.083740
13 18122.552734 bw MEMNODE0 -0.001175
13 18122.552734 bw MEMNODE1 -0.001175
13 18150.785156 bw MEMNODE1 885.429016
13 18150.785156 bw MEMNODE0 885.429016
13 18152.167969 bw MEMNODE0 1333.373047
13 18152.167969 bw MEMNODE1 1333.373047
13 18155.302734 bw MEMNODE1 447.942871
13 18155.302734 bw MEMNODE0 447.942871
13 18155.304688 bw MEMNODE0 1138.667969
13 18155.304688 bw MEMNODE1 1138.667969
13 18156.523438 bw MEMNODE0 2013.881592
13 18156.523438 bw MEMNODE1 2013.881592
13 18161.093750 bw MEMNODE0 1138.667969
13 18161.093750 bw MEMNODE1 1138.667969
13 18161.095703 bw MEMNODE0 447.942871
13 18161.095703 bw MEMNODE1 447.942871
13 18161.097656 bw MEMNODE0 -0.001129
13 18161.097656 bw MEMNODE1 -0.001129
13 18181.398438 bw MEMNODE1 226.622757
13 18181.398438 bw MEMNODE0 226.622757
13 18184.148438 bw MEMNODE0 648.803772
13 18184.148438 bw MEMNODE1 648.803772
13 18185.560547 bw MEMNODE1 945.916748
13 18185.560547 bw MEMNODE0 945.916748
13 18188.365234 bw MEMNODE1 1322.179810
13 18188.365234 bw MEMNODE0 1322.179810
13 18193.623047 bw MEMNODE0 899.998779
13 18193.623047 bw MEMNODE1 899.998779
13 18193.634766 bw MEMNODE1 1275.090332
13 18193.634766 bw MEMNODE0 1275.090332
13 18198.996094 bw MEMNODE1 898.827271
13 18198.996094 bw MEMNODE0 898.827271
13 18199.023438 bw MEMNODE1 601.714233
13 18199.023438 bw MEMNODE0 601.714233
13 18199.048828 bw MEMNODE1 375.090332
13 18199.048828 bw MEMNODE0 375.090332
13 18204.298828 bw MEMNODE1 -0.001251
13 18204.298828 bw MEMNODE0 -0.001251
13 18246.937500 bw MEMNODE1 879.346069
13 18246.937500 bw MEMNODE0 879.346069
13 18248.298828 bw MEMNODE0 1491.237305
13 18248.298828 bw MEMNODE1 1491.237305
13 18251.486328 bw MEMNODE1 611.889954
13 18251.486328 bw MEMNODE0 611.889954
13 18254.835938 bw MEMNODE0 -0.001282
13 18254.835938 bw MEMNODE1 -0.001282
13 18254.837891 bw MEMNODE0 590.030396
13 18254.837891 bw MEMNODE1 590.030396
13 18256.023438 bw MEMNODE0 1305.364014
13 18256.023438 bw MEMNODE1 1305.364014
13 18257.148438 bw MEMNODE0 2201.251953
13 18257.148438 bw MEMNODE1 2201.251953
13 18261.613281 bw MEMNODE0 1305.364014
13 18261.613281 bw MEMNODE1 1305.364014
13 18261.615234 bw MEMNODE0 590.030457
13 18261.615234 bw MEMNODE1 590.030457
13 18261.617188 bw MEMNODE0 -0.001221
13 18261.617188 bw MEMNODE1 -0.001221
13 18285.009766 bw MEMNODE0 418.128632
13 18285.009766 bw MEMNODE1 418.128632
13 18294.576172 bw MEMNODE0 -0.001221
13 18294.576172 bw MEMNODE1 -0.001221
13 18294.578125 bw MEMNODE0 274.015381
13 18294.578125 bw MEMNODE1 274.015381
13 18295.685547 bw MEMNODE0 736.317871
13 18295.685547 bw MEMNODE1 736.317871
13 18299.533203 bw MEMNODE1 1079.194092
13 18299.533203 bw MEMNODE0 1079.194092
13 18299.548828 bw MEMNODE1 1492.931396
13 18299.548828 bw MEMNODE0 1492.931396
13 18299.570312 bw MEMNODE1 1774.057007
13 18299.570312 bw MEMNODE0 1774.057007
13 18299.587891 bw MEMNODE1 2079.546387
13 18299.587891 bw MEMNODE0 2079.546387
13 18299.658203 bw MEMNODE1 2361.873291
13 18299.658203 bw MEMNODE0 2361.873291
13 18304.337891 bw MEMNODE0 1899.570801
13 18304.337891 bw MEMNODE1 1899.570801
13 18309.175781 bw MEMNODE0 1625.554199
13 18309.175781 bw MEMNODE1 1625.554199
13 18309.177734 bw MEMNODE0 2054.904297
13 18309.177734 bw MEMNODE1 2054.904297
13 18309.212891 bw MEMNODE1 2923.805420
13 18309.212891 bw MEMNODE0 2923.805420
13 18309.216797 bw MEMNODE1 2510.068115
13 18309.216797 bw MEMNODE0 2510.068115
13 18309.218750 bw MEMNODE1 2552.842529
13 18309.218750 bw MEMNODE0 2552.842529
13 18311.199219 bw MEMNODE1 2209.966309
13 18311.199219 bw MEMNODE0 2209.966309
13 18312.681641 bw MEMNODE1 1904.477051
13 18312.681641 bw MEMNODE0 1904.477051
13 18313.798828 bw MEMNODE1 1623.351440
13 18313.798828 bw MEMNODE0 1623.351440
13 18313.816406 bw MEMNODE1 754.450317
13 18313.816406 bw MEMNODE0 754.450317
13 18313.826172 bw MEMNODE1 472.123322
13 18313.826172 bw MEMNODE0 472.123322
13 18313.837891 bw MEMNODE0 1331.544189
13 18313.837891 bw MEMNODE1 1331.544189
13 18318.492188 bw MEMNODE0 472.123291
13 18318.492188 bw MEMNODE1 472.123291
13 18318.494141 bw MEMNODE0 42.773193
13 18318.494141 bw MEMNODE1 42.773193
13 18402.732422 bw MEMNODE1 -0.001301
13 18402.732422 bw MEMNODE0 -0.001301
13 18469.591797 bw MEMNODE0 1443.268555
13 18469.591797 bw MEMNODE1 1443.268555
13 18470.906250 bw MEMNODE1 4092.686523
13 18470.906250 bw MEMNODE0 4092.686523
13 18472.363281 bw MEMNODE0 2649.416504
13 18472.363281 bw MEMNODE1 2649.416504
13 18472.416016 bw MEMNODE1 -0.001465
13 18472.416016 bw MEMNODE0 -0.001465
13 18517.527344 bw MEMNODE1 620.228699
13 18517.527344 bw MEMNODE0 620.228699
13 18522.777344 bw MEMNODE0 1007.887207
13 18522.777344 bw MEMNODE1 1007.887207
13 18523.972656 bw MEMNODE0 1446.431152
13 18523.972656 bw MEMNODE1 1446.431152
13 18523.976562 bw MEMNODE1 826.200989
13 18523.976562 bw MEMNODE0 826.200989
13 18525.123047 bw MEMNODE0 1328.284790
13 18525.123047 bw MEMNODE1 1328.284790
13 18526.269531 bw MEMNODE0 1914.936157
13 18526.269531 bw MEMNODE1 1914.936157
13 18527.410156 bw MEMNODE0 2619.685059
13 18527.410156 bw MEMNODE1 2619.685059
13 18528.552734 bw MEMNODE0 3502.824219
13 18528.552734 bw MEMNODE1 3502.824219
13 18533.082031 bw MEMNODE0 2619.685059
13 18533.082031 bw MEMNODE1 2619.685059
13 18533.085938 bw MEMNODE0 1914.936279
13 18533.085938 bw MEMNODE1 1914.936279
13 18533.087891 bw MEMNODE0 1328.284912
13 18533.087891 bw MEMNODE1 1328.284912
13 18533.089844 bw MEMNODE0 826.201050
13 18533.089844 bw MEMNODE1 826.201050
13 18533.093750 bw MEMNODE0 387.657166
13 18533.093750 bw MEMNODE1 387.657166
13 18533.095703 bw MEMNODE0 -0.001373
13 18533.095703 bw MEMNODE1 -0.001373
13 18590.736328 bw MEMNODE1 542.946655
13 18590.736328 bw MEMNODE0 542.946655
13 18590.751953 bw MEMNODE1 1084.172852
13 18590.751953 bw MEMNODE0 1084.172852
13 18590.767578 bw MEMNODE1 1628.998535
13 18590.767578 bw MEMNODE0 1628.998535
13 18592.257812 bw MEMNODE0 2062.621338
13 18592.257812 bw MEMNODE1 2062.621338
13 18598.103516 bw MEMNODE1 1519.673340
13 18598.103516 bw MEMNODE0 1519.673340
13 18598.109375 bw MEMNODE1 974.847595
13 18598.109375 bw MEMNODE0 974.847595
13 18598.142578 bw MEMNODE1 433.621399
13 18598.142578 bw MEMNODE0 433.621399
13 18601.482422 bw MEMNODE0 -0.001312
13 18601.482422 bw MEMNODE1 -0.001312
13 18649.566406 bw MEMNODE1 892.373413
13 18649.566406 bw MEMNODE0 892.373413
13 18649.570312 bw MEMNODE0 1336.336182
13 18649.570312 bw MEMNODE1 1336.336182
13 18650.724609 bw MEMNODE0 1845.662231
13 18650.724609 bw MEMNODE1 1845.662231
13 18654.048828 bw MEMNODE1 953.287476
13 18654.048828 bw MEMNODE0 953.287476
13 18654.054688 bw MEMNODE0 1838.334961
13 18654.054688 bw MEMNODE1 1838.334961
13 18658.574219 bw MEMNODE0 953.287415
13 18658.574219 bw MEMNODE1 953.287415
13 18658.578125 bw MEMNODE0 443.961365
13 18658.578125 bw MEMNODE1 443.961365
13 18658.580078 bw MEMNODE0 -0.001343
13 18658.580078 bw MEMNODE1 -0.001343
13 18721.017578 bw MEMNODE0 2968.114746
13 18721.017578 bw MEMNODE1 2968.114746
13 18722.365234 bw MEMNODE0 -0.001221
13 18722.365234 bw MEMNODE1 -0.001221
13 18767.556641 bw MEMNODE1 747.716919
13 18767.556641 bw MEMNODE0 747.716919
13 18772.906250 bw MEMNODE1 -0.001221
13 18772.906250 bw MEMNODE0 -0.001221
13 18839.794922 bw MEMNODE0 2968.114746
13 18839.794922 bw MEMNODE1 2968.114746
13 18841.142578 bw MEMNODE0 -0.001221
13 18841.142578 bw MEMNODE1 -0.001221
13 18877.894531 bw MEMNODE1 755.161011
13 18877.894531 bw MEMNODE0 755.161011
13 18883.191406 bw MEMNODE1 -0.001221
13 18883.191406 bw MEMNODE0 -0.001221
13 18950.125000 bw MEMNODE0 2976.742920
13 18950.125000 bw MEMNODE1 2976.742920
13 18951.468750 bw MEMNODE0 -0.001221
13 18951.468750 bw MEMNODE1 -0.001221
13 18979.849609 bw MEMNODE1 852.621582
13 18979.849609 bw MEMNODE0 852.621582
13 18984.541016 bw MEMNODE1 -0.001221
13 18984.541016 bw MEMNODE0 -0.001221
13 19051.863281 bw MEMNODE0 2968.114746
13 19051.863281 bw MEMNODE1 2968.114746
13 19053.210938 bw MEMNODE0 -0.001221
13 19053.210938 bw MEMNODE1 -0.001221
13 19073.203125 bw MEMNODE1 2820.935303
13 19073.203125 bw MEMNODE0 2820.935303
13 19074.621094 bw MEMNODE1 -0.001221
13 19074.621094 bw MEMNODE0 -0.001221
13 19141.660156 bw MEMNODE0 2844.443115
13 19141.660156 bw MEMNODE1 2844.443115
13 19143.066406 bw MEMNODE0 -0.001221
13 19143.066406 bw MEMNODE1 -0.001221
13 19154.714844 bw MEMNODE1 2844.443115
13 19154.714844 bw MEMNODE0 2844.443115
13 19156.121094 bw MEMNODE1 -0.001221
13 19156.121094 bw MEMNODE0 -0.001221
13 19233.111328 bw MEMNODE1 2479.417725
13 19233.111328 bw MEMNODE0 2479.417725
13 19234.724609 bw MEMNODE1 -0.001221
13 19234.724609 bw MEMNODE0 -0.001221
13 19237.519531 bw MEMNODE1 2666.665527
13 19237.519531 bw MEMNODE0 2666.665527
13 19239.019531 bw MEMNODE1 -0.001221
13 19239.019531 bw MEMNODE0 -0.001221
13 19241.748047 bw MEMNODE1 112.743065
13 19241.748047 bw MEMNODE0 112.743065
13 19277.226562 bw MEMNODE1 -0.001221
13 19277.226562 bw MEMNODE0 -0.001221
13 19278.750000 bw MEMNODE1 2537.792969
13 19278.750000 bw MEMNODE0 2537.792969
13 19280.326172 bw MEMNODE1 -0.001221
13 19280.326172 bw MEMNODE0 -0.001221
13 19281.509766 bw MEMNODE1 1988.348267
13 19281.509766 bw MEMNODE0 1988.348267
13 19283.521484 bw MEMNODE1 -0.001221
13 19283.521484 bw MEMNODE0 -0.001221
13 19286.603516 bw MEMNODE1 1988.348267
13 19286.603516 bw MEMNODE0 1988.348267
13 19288.615234 bw MEMNODE1 -0.001221
13 19288.615234 bw MEMNODE0 -0.001221
13 19289.236328 bw MEMNODE1 2712.581543
13 19289.236328 bw MEMNODE0 2712.581543
13 19290.710938 bw MEMNODE1 -0.001221
13 19290.710938 bw MEMNODE0 -0.001221
13 19292.972656 bw MEMNODE1 170.565948
13 19292.972656 bw MEMNODE0 170.565948
13 19316.423828 bw MEMNODE1 -0.001221
13 19316.423828 bw MEMNODE0 -0.001221
13 19316.960938 bw MEMNODE1 2840.498047
13 19316.960938 bw MEMNODE0 2840.498047
13 19318.369141 bw MEMNODE1 -0.001221
13 19318.369141 bw MEMNODE0 -0.001221
13 19318.677734 bw MEMNODE1 1917.601807
13 19318.677734 bw MEMNODE0 1917.601807
13 19320.763672 bw MEMNODE1 -0.001221
13 19320.763672 bw MEMNODE0 -0.001221
13 19322.562500 bw MEMNODE1 1933.898682
13 19322.562500 bw MEMNODE0 1933.898682
13 19324.630859 bw MEMNODE1 -0.001221
13 19324.630859 bw MEMNODE0 -0.001221
13 19325.437500 bw MEMNODE1 1899.813232
13 19325.437500 bw MEMNODE0 1899.813232
13 19327.542969 bw MEMNODE1 -0.001221
13 19327.542969 bw MEMNODE0 -0.001221
13 19327.988281 bw MEMNODE1 1856.753052
13 19327.988281 bw MEMNODE0 1856.753052
13 19330.142578 bw MEMNODE1 -0.001221
13 19330.142578 bw MEMNODE0 -0.001221
13 19330.431641 bw MEMNODE1 1980.656372
13 19330.431641 bw MEMNODE0 1980.656372
13 19332.451172 bw MEMNODE1 -0.001221
13 19332.451172 bw MEMNODE0 -0.001221
13 19333.265625 bw MEMNODE1 2801.640381
13 19333.265625 bw MEMNODE0 2801.640381
13 19334.693359 bw MEMNODE1 -0.001221
13 19334.693359 bw MEMNODE0 -0.001221
13 19336.517578 bw MEMNODE1 1935.726562
13 19336.517578 bw MEMNODE0 1935.726562
13 19338.583984 bw MEMNODE1 -0.001221
13 19338.583984 bw MEMNODE0 -0.001221
13 19339.140625 bw MEMNODE1 174.044846
13 19339.140625 bw MEMNODE0 174.044846
13 19362.123047 bw MEMNODE1 -0.001221
13 19362.123047 bw MEMNODE0 -0.001221
13 19362.431641 bw MEMNODE1 110.456680
13 19362.431641 bw MEMNODE0 110.456680
13 19398.644531 bw MEMNODE1 -0.001221
13 19398.644531 bw MEMNODE0 -0.001221
13 19399.828125 bw MEMNODE1 1921.199585
13 19399.828125 bw MEMNODE0 1921.199585
13 19401.910156 bw MEMNODE1 -0.001221
13 19401.910156 bw MEMNODE0 -0.001221
13 19402.597656 bw MEMNODE1 1935.726562
13 19402.597656 bw MEMNODE0 1935.726562
13 19404.664062 bw MEMNODE1 -0.001221
13 19404.664062 bw MEMNODE0 -0.001221
13 19405.644531 bw MEMNODE1 2848.399414
13 19405.644531 bw MEMNODE0 2848.399414
13 19407.048828 bw MEMNODE1 -0.001221
13 19407.048828 bw MEMNODE0 -0.001221
13 19407.384766 bw MEMNODE1 1823.685303
13 19407.384766 bw MEMNODE0 1823.685303
13 19409.578125 bw MEMNODE1 -0.001221
13 19409.578125 bw MEMNODE0 -0.001221
13 19410.261719 bw MEMNODE1 1941.230957
13 19410.261719 bw MEMNODE0 1941.230957
13 19412.322266 bw MEMNODE1 -0.001221
13 19412.322266 bw MEMNODE0 -0.001221
13 19412.630859 bw MEMNODE1 1976.832764
13 19412.630859 bw MEMNODE0 1976.832764
13 19414.654297 bw MEMNODE1 -0.001221
13 19414.654297 bw MEMNODE0 -0.001221
13 19415.037109 bw MEMNODE1 1986.419678
13 19415.037109 bw MEMNODE0 1986.419678
13 19417.050781 bw MEMNODE1 -0.001221
13 19417.050781 bw MEMNODE0 -0.001221
13 19420.488281 bw MEMNODE1 1906.888916
13 19420.488281 bw MEMNODE0 1906.888916
13 19422.585938 bw MEMNODE1 -0.001221
13 19422.585938 bw MEMNODE0 -0.001221
13 19422.945312 bw MEMNODE1 1910.446533
13 19422.945312 bw MEMNODE0 1910.446533
13 19425.039062 bw MEMNODE1 -0.001221
13 19425.039062 bw MEMNODE0 -0.001221
13 19425.326172 bw MEMNODE1 1903.344482
13 19425.326172 bw MEMNODE0 1903.344482
13 19427.427734 bw MEMNODE1 -0.001221
13 19427.427734 bw MEMNODE0 -0.001221
13 19427.689453 bw MEMNODE1 173.308411
13 19427.689453 bw MEMNODE0 173.308411
13 19450.769531 bw MEMNODE1 -0.001221
13 19450.769531 bw MEMNODE0 -0.001221
13 19452.154297 bw MEMNODE1 1908.666016
13 19452.154297 bw MEMNODE0 1908.666016
13 19454.250000 bw MEMNODE1 -0.001221
13 19454.250000 bw MEMNODE0 -0.001221
13 19455.349609 bw MEMNODE1 1948.619141
13 19455.349609 bw MEMNODE0 1948.619141
13 19457.402344 bw MEMNODE1 -0.001221
13 19457.402344 bw MEMNODE0 -0.001221
13 19457.873047 bw MEMNODE1 2820.935303
13 19457.873047 bw MEMNODE0 2820.935303
13 19459.291016 bw MEMNODE1 -0.001221
13 19459.291016 bw MEMNODE0 -0.001221
13 19459.656250 bw MEMNODE1 173.867523
13 19459.656250 bw MEMNODE0 173.867523
13 19482.662109 bw MEMNODE1 -0.001221
13 19482.662109 bw MEMNODE0 -0.001221
13 19482.929688 bw MEMNODE1 1912.230347
13 19482.929688 bw MEMNODE0 1912.230347
13 19485.021484 bw MEMNODE1 -0.001221
13 19485.021484 bw MEMNODE0 -0.001221
13 19485.367188 bw MEMNODE1 165.855591
13 19485.367188 bw MEMNODE0 165.855591
13 19509.484375 bw MEMNODE1 -0.001221
13 19509.484375 bw MEMNODE0 -0.001221
13 19509.888672 bw MEMNODE1 186.146759
13 19509.888672 bw MEMNODE0 186.146759
13 19531.376953 bw MEMNODE1 -0.001221
13 19531.376953 bw MEMNODE0 -0.001221
13 19531.695312 bw MEMNODE1 1980.656372
13 19531.695312 bw MEMNODE0 1980.656372
13 19533.714844 bw MEMNODE1 -0.001221
13 19533.714844 bw MEMNODE0 -0.001221
  • [Starpu-devel] bad performance scaling behavior of cholesky decomposition, Mario Tacconi, 11/05/2012
Haut de le page
