Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] bad performance scaling behavior of cholesky decomposition
Veuillez patienter...
starpu-devel@inria.fr
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] bad performance scaling behavior of cholesky decomposition
  • Date: Fri, 25 May 2012 18:42:54 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 25/05/2012 17:12, Samuel Thibault wrote:
> Mario Tacconi, le Fri 25 May 2012 17:08:07 +0200, a écrit :
>> As you suggest below the cause of the problematic scaling behavior was a
>> bogus performance model.
>> By resetting the performance model I was able to obtain a pretty decent
>> scaling over a wide range of GPU+CPU configurations, as the graphs in
>> attach show :)
>> I was able to obtain a good performance model by using 2 GPU, 2 CPU
>> worker, STARPU_CALIBRATE=1 and the
>> "ws" scheduling policy.
> Mmm, the ws scheduling policy actually does not make any use of
> performance models. So dmda performs worse than ws? That's bad news :)
No, wait... I used the ws policy only to harvest data for the
performance model. The idea was that by using ws (or eager) policy all the
workers would have got an adequate amount of tasks and speed up the
statistics "convergence" of the history based model.
During the benchmarks I found that the dmdas policy actually gives the
best performance.
On my system, for the Cholesky "tile tag", and for each combination of
CPU/GPU I tried:
dmdas>heft>dmdar>~dmda>>>ws/eager
>>> That could be odd, or maybe not. Our cholesky factorization is really
>>> not advanced, and suffers from lack of parallelism, so it is not
>>> necessarily surprising that it does not scale ; maybe you could rather
>>> give a try at Magma 1.1 or later revision, which is the state of the
>>> art for cholesky, and supports using StarPU for exploiting hybrid
>>> machines.
>> I know the magma library. Actually I discovered the StarPU project trying
>> to compile their dynamically-scheduled version of the LU and Cholesky
>> factorization.
>> I have to admit that I could not succeed in obtaining working code froma
>> that compilation: I think the Magma are using
>> an old version of StarPU along with the StarPU's deprecated interface.
> Mmm, it's odd, we tested that compilation before releasing StarPU 1.0,
> there should only be warnings, and no errors.
> Which error are you getting?
good question. It happened months ago, I think I better try to recompile
the whole thing.
I'll let you know about that :)
Thank you for all that support
Mario
>> Actually, I'm using the cholesky benchmarks I attached to this mail in a
>> internal seminar on StarPU:
>> I hope I can convince my collegues (and my boss...) to use StarPU in our
>> future projects.
> Great :)
> Samuel
Haut de le page
