Archives de la liste
[Starpu-devel] Performance issues when specifying const and __attribute__ ((output))
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Performance issues when specifying const and __attribute__ ((output))
- Date: Mon, 02 Jul 2012 12:10:08 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
I'm still playing with the GCC plugin.
I have a quite simple code :
/* Start timer. */
timer_start();
p4a_launcher_main(s, ny);
p4a_launcher_main_1((double *)A, p, q, nx, ny);
for(i = 0; i <= nx-1; i += 1) {
double r_0 = r[i];
p4a_launcher_main_2((double *)A, s, i, ny, r_0);
/* Stop and print timer. */
#pragma starpu unregister s
#pragma starpu unregister q
timer_stop_display();
A,r,s,p,q are arrays registered to StarPU. The p4a_launcher_xxxx functions are tasks that launch very simple CUDA kernel. A CPU implementation is also given but is avoided at runtime using STARPU_NCPUS environment variable.
I tried to make use of "const" qualifier and "__attribute__((output))" on task parameter to hint StarPU about the data transfer.
However it seems to impact badly the runtime since using only one GPU I get the following execution time:
$ STARPU_NCUDA=1 STARPU_NCPUS=0 ./bicg_starpu_naive
192.2
746.5
Nearly four times slower !
Using CUDA_PROFILE=1 environment variable I confirmed that the GPU time is very close for both execution, and that the only difference is the few more data transfers for the fastest naive version.
Is it a known issue or do you have hints to explain this behavior?
Thanks,
Mehdi
- [Starpu-devel] Performance issues when specifying const and __attribute__ ((output)), Mehdi AMINI, 02/07/2012
- Re: [Starpu-devel] Performance issues when specifying const and __attribute__ ((output)), Samuel Thibault, 02/07/2012
- Re: [Starpu-devel] Performance issues when specifying const and __attribute__ ((output)), Mehdi AMINI, 02/07/2012
- Re: [Starpu-devel] Performance issues when specifying const and __attribute__ ((output)), Mehdi AMINI, 05/07/2012
- Re: [Starpu-devel] Performance issues when specifying const and __attribute__ ((output)), Ludovic Courtès, 05/07/2012
