Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] CPU data on a GPU kernel
- Date: Mon, 9 Jul 2012 16:14:26 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
I suppose it will be the same if I need a working buffer (STARPU_SCRATCH) for
the CPU part of my kernel, I have to deal with it by hand ?
XL.
Le 9 juil. 2012 à 09:42, Xavier Lacoste a écrit :
> Ok thanks, so i'll do it by hand.
> Le 7 juil. 2012 à 13:57, Samuel Thibault a écrit :
>> Xavier Lacoste, le Fri 06 Jul 2012 16:59:40 +0200, a écrit :
>>> Is there a way to do a reduction on a variable hosted on a CPU on a CUDA
>>> kernel ?
>> That would make the code quite more hairy to handle this special use.
>> StarPU has also not much to optimize in that case, I'm not sure you will
>> gain much from using its reduction mode here.
>> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] CPU data on a GPU kernel, Xavier Lacoste, 06/07/2012
- Re: [Starpu-devel] CPU data on a GPU kernel, Samuel Thibault, 07/07/2012
- Re: [Starpu-devel] CPU data on a GPU kernel, Xavier Lacoste, 09/07/2012
- Re: [Starpu-devel] CPU data on a GPU kernel, Samuel Thibault, 10/07/2012
