Archives de la liste
- To: bicatali@gentoo.org
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] parallel_tasks test failures
- Date: Fri, 17 Aug 2012 16:45:04 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 08/16/2012 09:44 PM, Sébastien Fabbro wrote:
Hello,
Hello,
I'm seeing failures [1] for two tests while running the test suite of starpu:
FAIL: parallel_tasks/parallel_kernels
[error] test has been blocked for 600 seconds. Mark it as failed
FAIL: parallel_tasks/parallel_kernels_spmd
Is this something I should worry about?
Thanks for reporting this bug.
These tests use the "Parallel Heft" scheduler, which is still kind of experimental. If you can easily reproduce this bug, could you please run these tests in gdb, wait for them to hang, run "thread apply all bt" and send us the output ? I think this is a mutex problem, and I'd like to know which threads are waiting, and which mutexes are involved.
Cyril Roelandt.
- [Starpu-devel] parallel_tasks test failures, Sébastien Fabbro, 16/08/2012
- Re: [Starpu-devel] parallel_tasks test failures, Cyril Roelandt, 17/08/2012
