Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Data interfaces in StarPU
Archives de la liste
Chronologique Discussions
  • To: Albert Sidelnik <sidelnik@gmail.com>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Data interfaces in StarPU
  • Date: Tue, 28 Aug 2012 13:22:48 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello !
On 08/28/2012 06:48 AM, Albert Sidelnik wrote:
I was hoping that somebody could explain how/where the routines that are
part of the data interface system work. I am implementing my own interface
that is based on the "variable interface" but instead of allocating new
data or copying data, I only pass pointers around (somewhat similar to the
cl_arg argument). Maybe I am missing something, but the allocate and copy
routines never seem to be invoked. If what I am trying to do is impossible
or makes no sense, are there any better alternative options of using the
data management system but without having to allocate data internally?
I am not sure that diving into the internals of StarPU will really help you figure out what's going on in your interface.
In order to trigger a a call to your copy function, you could do something like this:
1) Register a piece of data on a CPU using your interface
2) Submit a task that must be executed on an OpenCL device (or a CUDA device, but not a CPU)
3) StarPU will then try to copy the piece of data you registered to the OpenCL device, and will do this by calling the "copy_ram_to_opencl_async" function of your interface.
What do you mean by "pass pointers around" ? If you modify the piece of data you registered on the CPU, the OpenCL/CUDA pointer is no longer pointing to a valid piece of data, so you probably have to make a copy.
Maybe showing us some code could help :)
WBR,
Cyril Roelandt.
Haut de le page
