Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Finding Nvidia capabilities when configuring StarPU.
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] Finding Nvidia capabilities when configuring StarPU.
  • Date: Wed, 05 Sep 2012 17:28:07 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi !
On Hydra, some tests fail with CUDA on Darwin. The Nvidia GPU is a 1.1 card, and the examples are compiled with "-arch sm_13" (cf. examples/Makefile.am). An easy fix would be to either use "-arch sm_11" or no option at all. The thing is, using "-arch sm_xx" is probably good for performance.
On a related topic, I had to find the card capabilities for r.7325, but this patch still isn't perfect. What we should do is:
- if there is no card >= 1.3, disable the cuda_funcs in the example;
- if there is no card < 1.3, do not use the .can_execute field;
- otherwise, use both fields.
We could do something similar for the NVCCFLAGS in examples/Makefile.am: add "-sm_$(min_capabilities)".
So we basically need to find the minimum and maximum capabilities when running configure; in order to do that, we need to run NVCC. I'm not sure this can be done cleanly with AC_LANG, though. Does anyone see how to do this in a non-hackish way ?
Cyril.
Haut de le page
