Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Regarding StarPU installation
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: alankrutha reddy <alankruthareddy46@gmail.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Regarding StarPU installation
  • Date: Fri, 26 Oct 2012 13:47:57 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 26/10/2012 13:27, alankrutha reddy wrote: Hello,
      I want to use StarPU in SkePU library system. Do I need to install hwloc.?
Regards
Alankrutha
I do not know if you need hwloc for SkePU. If someone else on the mailing list knows?
However, it is strongly recommended to use StarPU with hwloc enabled. If the target machine is hyperthreaded, the performance may be impacted a lot.
Cheers,
Nathalie
Haut de le page
