Archives de la liste
- To: Happy Boy <itsmyemail10@yahoo.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Question About StarUP with AMD Architecture.
- Date: Thu, 08 Nov 2012 14:12:21 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 10/31/2012 05:19 PM, Happy Boy wrote:
Dear Starup developers,
Hello !
Actually, the project is called "StarPU", as in "*PU" :)
Can i use StarUP library with OpenCL AMD (CPU, GPU)?
You can run OpenCL kernels on an AMD CPU by setting the "STARPU_OPENCL_ON_CPUS" environment variable to 1.
We've just bought a few Radeon HD 7970, and StarPU seems to be working well with these. The only known issue is that asynchronous transfers must be disabled, by setting the "STARPU_DISABLE_ASYNCHRONOUS_OPENCL_COPY" to 1.
It seems like this cannot work with free drivers though, so we had to use the non-free drivers provided by AMD.
My current AMD GPU is AMD Radeon™ HD 6850
I use OpenCL AMD Accelerated Parallel Processing (APP) SDK
My CPU& GPU both of AMD architecture.
This should work.
WBR,
Cyril Roelandt.
- Re: [Starpu-devel] Question About StarUP with AMD Architecture., Cyril Roelandt, 08/11/2012
