Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] How to use starpu_mpi_task_insert
Archives de la liste
Chronologique Discussions
  • From: Ravi Teja Mullapudi <raviteja.mullapudi@gmail.com>
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, Roshan D <roshan18@gmail.com>, Uday Reddy <udayreddy@gmail.com>
  • Subject: Re: [Starpu-devel] How to use starpu_mpi_task_insert
  • Date: Sat, 30 Mar 2013 21:13:39 +0530
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks for the quick reply. I am using version 1.0.5, the latest release. I did try to set the mpi_tag but I was running into other problems maybe I did not do it right, I will try and let you know. Also the sample in documentation section where starpu_mpi_task_insert usage is shown does not clearly specify that the a tag needs to be set for the data handle. It will be nice if that can be documented.
On Sat, Mar 30, 2013 at 7:40 PM, Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
Hi,
You are missing a call to starpu_data_get_tag to tell StarPU-MPI which tag should be used when sending or receiving a data. The tag must be unique. A possible solution would be to add the following line
             starpu_data_set_tag(data_handles[i*num_blocks + j], i*num_blocks + j);
after the call to starpu_data_set_rank.
Could you please tell us which version of StarPU you are using? The error message you are getting needs to be fixed, as it is misleading as it is mentioning a test on the tag value and a call to to the set_rank function.
Thanks,
Nathalie
On Mar 30, 19:19, Ravi Teja Mullapudi wrote:
> Hi,
> I am trying to use starpu_mpi_task_insert to avoid explicitly doing MPI
> communication and letting starpu handle it. I am trying to do a floyd
> warshall implantation. The following is the outline of the code.
> Task Creation
> create_dist_tasks(int matrix_size, int block_size, starpu_data_handle_t *
> data_handles)
>     int i,j,k;
>     int ret;
>     int num_blocks = matrix_size/block_size;
>     /* Create non-entry tasks */
>     for(k = 0; k < matrix_size; k++) {
>         for(i = 0; i < num_blocks ; i++) {
>             for(j = 0; j < num_blocks; j++) {
>                 starpu_mpi_insert_task(MPI_COMM_WORLD, &dist_cl,
>                                        STARPU_VALUE, &k,
>                                        STARPU_VALUE, &i,
>                                        STARPU_VALUE, &j,
>                                        STARPU_RW, data_handles[i*num_blocks
> +j],
>                                        STARPU_R,  data_handles[i*num_blocks
> +(k/block_size)],
>                                        STARPU_R,
>  data_handles[(k/block_size)*num_blocks + j],
>                                        STARPU_EXECUTE_ON_DATA,
> data_handles[i*num_blocks +j],
>                                        0);
>     return 0;
> Registering Data
>     for(i = 0; i < num_blocks; i++) {
>         for (j = 0; j < num_blocks; j++) {
>             int mpi_rank = data_distribution(i, j, num_nodes);
>             if (mpi_rank == my_rank)
>                 /* Owning data */
>                 starpu_vector_data_register(&data_handles[i*num_blocks +
> j], 0,
>                         (uintptr_t)(tiles[i*num_blocks + j]), block_size
> *block_size, sizeof(double));
>             else
>                 /* This can probably be further optimized */
> j], -1,
>             /* Marking where to find what data */
>             starpu_data_set_rank(data_handles[i*num_blocks + j], mpi_rank);
> Codelet
> void dist_task(void *buffers[], void *cl_arg)
>     int k, i, j, block_size;
>     starpu_codelet_unpack_args(cl_arg, &k, &i, &j);
>     /* Get block size */
>     block_size = STARPU_VECTOR_GET_NX(buffers[0]);
>     double *block_ij = (double *)STARPU_VECTOR_GET_PTR(buffers[0]);
>     double *block_ik = (double *)STARPU_VECTOR_GET_PTR(buffers[1]);
>     double *block_kj = (double *)STARPU_VECTOR_GET_PTR(buffers[2]);
>     for (int p = 0; p < block_size; p++){
>         for (int q = 0; q < block_size; q++) {
>             for (int r = 0; r < block_size; r++) {
>                 block_ij[q*block_size +r] = min(block_ik[q*block_size + p]
> + block_kj[p*block_size + r], block_ij[q*block_size +r]);
> The problem with the above approach is I hit the following assertion
> starpu_mpi_insert_task: Assertion `mpi_tag >= 0 && "StarPU needs to be told
> the MPI rank of this data, using starpu_data_set_rank"' failed.
> I do not clearly understand how the mpi_tag must be specified I was under
> the assumption that the the above is all that is required for starpu to
> handle the communication automatically. I understand that I can rewrite
> using starpu_mpi_send and starpu_mpi_recv but I do not explicitly want to
> specify the communication. I am basically evaluating StarPU vs Intel CnC in
> a distributed setting. Attaching the implementation for a complete context.
> Any help or inputs are appreciated.
> Thanks,
> Ravi Teja.
> #include <stdint.h>
> #include <inttypes.h>
> #include <starpu.h>
> #include <starpu_mpi.h>
> #include <unistd.h>
> #include "../utils/utils.h"
> #include "floyd_starpu.h"
> #define FPRINTF(ofile, fmt, args ...) do { if (!getenv("STARPU_SSILENT")) {fprintf(ofile, fmt, ##args); }} while(0)
> #define TAG(iter, i, j) ((starpu_tag_t) ( ((uint64_t)(iter)<<47) |  ((uint64_t)(j)<<11) | (i)) )
> struct params
>     int k;
>     int i;
>     int j;
>     // This is redundant for every task, but I do not like globals and secondly this
>     // is the way to for a distributed memory setting. CnC has context where the
>     // parameters for the task graph can be stored. It can manage this redundancy much
>     // better.
>     double   *matrix;
>     int matrix_size;
>     int block_size;
> static struct starpu_perfmodel mult_perf_model = {
>     .type = STARPU_HISTORY_BASED,
>     .symbol = "mult_perf_model"
> static void express_deps(int k, int i, int j, int block_size)
>     if (k > 0)
>         starpu_tag_declare_deps(TAG(k, i, j), 3, TAG(k-1, i, k/block_size), TAG(k-1, k/block_size, j), TAG(k-1, i, j));
> static void tag_cleanup(int matrix_size, int block_size)
>     int i,j,k;
>     for (k = 0; k < matrix_size; k++)
>         for (i = 0; i < num_blocks ; i++)
>                 starpu_tag_remove(TAG(k, i, j));
> /* Every implementation of a codelet must have this prototype, the first
>  * argument (buffers) describes the buffers/streams that are managed by the
>  * DSM; the second arguments references read-only data that is passed as an
>  * argument of the codelet (task->cl_arg). Here, "buffers" is unused as there
>  * are no data input/output managed by the DSM (cl.nbuffers = 0) */
> void shared_mem_task(void *buffers[], void *cl_arg)
>     struct params *params = (struct params *) cl_arg;
>     int i, j, k, size, block_size;
>     k = params->k;
>     double* path_distance_matrix = params->matrix;
>     size = params->matrix_size;
>     block_size = params->block_size;
>     //printf("Task Scheduled(%d %d %d) TAG=%" PRIu64 "\n", params->k, params->i, params->j, TAG(k ,i, j));
>     for(i = params->i * block_size; i < (params->i + 1) * block_size; i++)
>         for(j = params->j * block_size; j < (params->j + 1) * block_size; j++)
>             path_distance_matrix[i*size + j] = min(path_distance_matrix[i*size + k] + path_distance_matrix[k*size + j], path_distance_matrix[i*size + j]);
> struct starpu_codelet shared_mem_cl =
>     .where = STARPU_CPU,
>     .cpu_funcs = { shared_mem_task, NULL },
>     .nbuffers = 0,
>     .model = &mult_perf_model,
>     .name = "Floyd"
> static int create_shared_mem_tasks(int matrix_size, int block_size, struct params* params)
>     int i,j,k;
>     int ret;
>                 /* Create a new task */
>                 struct starpu_task *task = starpu_task_create();
>                 task->callback_func      = NULL;
>                 task->cl                 = &shared_mem_cl;
>                 task->cl_arg             = &params[k*num_blocks*num_blocks + i*num_blocks + j];
>                 task->cl_arg_size        = sizeof(struct params);
>                 task->use_tag = 1;
>                 task->tag_id = TAG(k, i, j);
>                 //printf("Task(%d %d %d) TAG=%" PRIu64 "\n", k, i, j, task->tag_id);
>                 express_deps(k, i, j, block_size);
>                 ret = starpu_task_submit(task);
>                 if (ret == -ENODEV) return 77;
>                 STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
>     return 0;
> int floyd_shared_mem_starpu(double* path_distance_matrix, int matrix_size, int block_size)
>     int num_blocks, k, i, j, ret;
>     // Creating parameters for tasks
>     struct params *params = (struct params*) malloc (sizeof(struct params) * matrix_size * (num_blocks) * (num_blocks));
>     for( k = 0; k < matrix_size; k++)
>         for( i = 0; i < num_blocks; i++)
>             for( j = 0; j < num_blocks; j++)
>                 struct params* p = &params[(k*num_blocks*num_blocks) + (i*num_blocks) + j];
>                 p->k = k; p->i = i; p->j = j;
>                 p->matrix      = path_distance_matrix;
>                 p->matrix_size = matrix_size;
>                 p->block_size  = block_size;
>     /* initialize StarPU : passing a NULL argument means that we use
>      * default configuration for the scheduling policies and the number of
>      * processors/accelerators */
>     ret = starpu_init(NULL);
>     if (ret == -ENODEV)
>         return 77;
>     STARPU_CHECK_RETURN_VALUE(ret, "starpu_init");
>     /* Create tasks*/
>     ret = create_shared_mem_tasks(matrix_size, block_size, params);
>     if (ret == 0)
>         starpu_task_wait_for_all();
>     tag_cleanup(matrix_size, block_size);
>     /* terminate StarPU: statistics and other debug outputs are not
>      * guaranteed to be generated unless this function is called. Once it
>      * is called, it is not possible to submit tasks anymore, and the user
>      * is responsible for making sure all tasks have already been executed:
>      * calling starpu_shutdown() before the termination of all the tasks
>      * results in an undefined behaviour */
>     starpu_shutdown();
>     free(params);
>     return ret;
>     //printf("Task Scheduled(%d %d %d)\n", k, i, j);
>                 block_ij[q*block_size +r] = min(block_ik[q*block_size + p] + block_kj[p*block_size + r], block_ij[q*block_size +r]);
> struct starpu_codelet dist_cl =
>     .cpu_funcs = { dist_task, NULL },
>     .nbuffers = 3,
>     .name = "Floyd Dist"
> static int create_dist_tasks(int matrix_size, int block_size, starpu_data_handle_t * data_handles)
>     int i,j,k;
>     int ret;
>                                        STARPU_VALUE, &k,
>                                        STARPU_VALUE, &i,
>                                        STARPU_VALUE, &j,
>                                        STARPU_RW, data_handles[i*num_blocks +j],
>                                        STARPU_R,  data_handles[i*num_blocks +(k/block_size)],
>                                        STARPU_R,  data_handles[(k/block_size)*num_blocks + j],
>                                        0);
>     return 0;
> /* Returns the MPI node number where data is */
> int data_distribution(int x, int y, int num_nodes) {
>     /* Block distrib */
>     //return ((int)(x / sqrt(num_nodes) + (y / sqrt(num_nodes)) * sqrt(num_nodes))) % num_nodes;
>     // /* Other examples useful for other kinds of computations */
>     // /* / distrib */
>     // return (x+y) % num_nodes;
>     // /* Block cyclic distrib */
>     // unsigned side = sqrt(num_nodes);
>     // return x % side + (y % side) * size;
>     return 0;
> int floyd_dist_starpu(double* path_distance_matrix, int matrix_size, int block_size)
>     int num_blocks, k, i, j, ret, my_rank, num_nodes;
>     /* Initialize StarPU : passing a NULL argument means that we use
>     if (ret == -ENODEV)
>         return 77;
>     /* Initializaing StarPU MPI */
>     ret = starpu_mpi_initialize_extended(&my_rank, &num_nodes);
>     if (ret == -ENODEV)
>         return 77;
>     starpu_data_handle_t* data_handles = (starpu_data_handle_t*) malloc(sizeof(starpu_data_handle_t) * num_blocks * num_blocks);
>     double** tiles = (double**) malloc(sizeof(double*) * num_blocks * num_blocks);
>             /* Allocate memory for the tile*/
>             tiles[i*num_blocks + j] = (double*) malloc (sizeof(double) * block_size * block_size);
>             double * tile = tiles[i*num_blocks + j];
>             for(int org_i = i*block_size,t_i = 0; t_i < block_size; org_i++,t_i++) {
>                 for(int org_j = j*block_size,t_j = 0; t_j < block_size; org_j++,t_j++) {
>                     tile[t_i*block_size + t_j] = path_distance_matrix[org_i*matrix_size + org_j];
>                 /* Owning data */
>                 starpu_vector_data_register(&data_handles[i*num_blocks + j], 0,
>                         (uintptr_t)(tiles[i*num_blocks + j]), block_size *block_size, sizeof(double));
>             else
>                 starpu_vector_data_register(&data_handles[i*num_blocks + j], -1,
>     /* Create tasks*/
>     ret = create_dist_tasks(matrix_size, block_size, data_handles);
>     if (ret == 0)
>             starpu_data_unregister(data_handles[i*num_blocks + j]);
>     /* Collecting all the data at rank 0*/
>     starpu_mpi_shutdown();
>     starpu_shutdown();
>     for (i = 0; i < num_blocks; i++) {
>             free(tiles[i*num_blocks + j]);
>     free(tiles);
>     free(data_handles);
>     return ret;
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento                         CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour                Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE                  Fax: +33 (0)5 24 57 40 41
Haut de le page
