Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StsrPU
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: alankrutha reddy <alankruthareddy46@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StsrPU
  • Date: Fri, 5 Apr 2013 09:15:33 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
alankrutha reddy, le Fri 05 Apr 2013 06:50:06 +0200, a écrit :
>   I have 2 functions. One is cuda function and another one is OpenCL
> function.
> I have only one NVDIA GPU. I want to run those programs one after other.
> Can I
> run it on the same GPU.?
That is not easily supported by the Nvidia driver itself: after having
run a CUDA kernel, one has to deinitialize CUDA and initialize OpenCL
before being able to run an OpenCL, and vice-versa, which means dropping
all memory etc. So we haven't implemented any particular support, and
you have to call starpu_shutdown() and starpu_init() again with a
different configuration, to choose between running the GPU in CUDA mode
or in OpenCL mode.
Samuel
Haut de le page
