Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] bug de compilation ? .//etc/OpenCL/vendors/*.icd: file not found
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Simon Archipoff <simon.archipoff@etu.u-bordeaux1.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] bug de compilation ? .//etc/OpenCL/vendors/*.icd: file not found
  • Date: Tue, 23 Apr 2013 15:31:07 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
The problem is fixed, the script did not detect an empty directory.
Thanks for reporting the bug,
Nathalie
On Apr 23, 15:17, Simon Archipoff wrote:
> Yes I'm using the trunk,
> /etc/OpenCL/vendors is an empty repertory
> $ ls -l /etc/OpenCL/vendors/
> total 0
> Le 23/04/2013 15:06, Nathalie Furmento a écrit :
> >Are you using the trunk? Assuming you are, the problem comes from the
> >following part of configure.ac
> >if test -d /etc/OpenCL/vendors; then
> > for icd in /etc/OpenCL/vendors/*.icd ; do
> > if test "$(basename $icd)" != "socl.icd" ; then
> > new_icd=$(basename $icd)
> > AC_CONFIG_LINKS([socl/vendors/$new_icd:$icd])
> > fi
> > done
> >fi
> >Could you please send us the output of the command
> >ls /etc/OpenCL/vendors
> >Thanks,
> >Nathalie
> >On Apr 23, 14:37, Simon Archipoff wrote:
> >>Bonjour,
> >>J'ai essayé de compiler la version svn de starpu, sur une debian 7 amd64,
> >>avec ça pour opencl (l'implémentation d'intel) :
> >>opencl-1.2-base 3.0.56860-2
> >>opencl-1.2-devel 3.0.56860-2
> >>opencl-1.2-intel-cpu 3.0.56860-2
> >>opencl-1.2-intel-devel 3.0.56860-2
> >>quand je lance
> >>./configure --with-opencl-dir=/opt/intel/opencl-1.2-3.0.56860
> >>--prefix=/opt/
> >>La compilation s'arrête avec le message suivant :
> >>config.status: linking .//etc/OpenCL/vendors/*.icd to
> >>socl/vendors/socl.icd
> >>config.status: error: .//etc/OpenCL/vendors/*.icd: file not found
> >>Le fichier en question se trouve dans
> >>/opt/intel/opencl-1.2-3.0.56860/etc/intel64.icd
> >>Ceci dit, dans les autres implémentations d'opencl dans les dépots debian
> >>les fichiers icd se trouvent bien dans ce bon répertoire
> >>amd-opencl-icd: /etc/OpenCL/vendors/amdocl64.icd
> >>nvidia-opencl-common: /etc/OpenCL/vendors/nvidia.icd
> >>C'est le paquet opencl qui est buggé ?
> >>Merci beaucoup
> >>_______________________________________________
> >>Starpu-devel mailing list
> >>Starpu-devel@lists.gforge.inria.fr
> >>http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
