Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Checking for main -lopencl failed
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Sébastien Frémal <sebastien.fremal@gmail.com>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Checking for main -lopencl failed
  • Date: Thu, 23 May 2013 17:02:57 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Sébastien Frémal, le Thu 23 May 2013 17:00:25 +0200, a écrit :
> I didn't know config.log. I understood what's the problem. My library
> depends
> on other libraries and the compilation failed because these libraries are
> not
> linked :
> configure:23359: gcc -o conftest -g -O2  -D_GNU_SOURCE
> -I/home/fremals/GVirtus
> /CL  -L/home/fremals/GVirtus/Frontend/lib conftest.c -lOpenCL  -lm
> -lpthread  >
> &5
> /home/fremals/GVirtus/util/bin/libutil.so.1: undefined reference to
> `shm_open'
> `XML_ParserCreate'
> `XML_SetUserData'
> `XML_ParserFree'
> `XML_SetElementHandler'
> `XML_Parse'
> `XML_SetCharacterDataHandler'
> I'm going to search how to compile the library to avoid this disadvantage.
You should just need to pass the required -l flags when building
libutil.so
Samuel
Haut de le page
