Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error Report
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Kaixi Hou <kaixihou@vt.edu>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error Report
  • Date: Wed, 12 Jun 2013 10:04:45 -0400
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
Thanks for your rapid reply.
It seems that I only have starpu_data_cpy, parallel_kernel_test, parallel_kernel_test_spmd files in ~/.starpu/sampling/codelets. I have attached them in this email.
Regards,
Kaixi
On Wed, Jun 12, 2013 at 9:39 AM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Kaixi Hou, le Wed 12 Jun 2013 15:29:26 +0200, a écrit :
> lt-increment_redux_lazy: ../../src/core/perfmodel/perfmodel_history.c:292: parse_model_file: Assertion `ret == 1' failed.
> lt-starpu_data_cpy: ../../src/core/perfmodel/perfmodel_history.c:292: parse_model_file: Assertion `ret == 1' failed.
> lt-overlap: ../../src/core/perfmodel/perfmodel_history.c:292: parse_model_file: Assertion `ret == 1' failed.
> lt-parallel_kernels: ../../src/core/perfmodel/perfmodel_history.c:292: parse_model_file: Assertion `ret == 1' failed.
> lt-parallel_kernels_spmd: ../../src/core/perfmodel/perfmodel_history.c:292: parse_model_file: Assertion `ret == 1' failed.
This kind of thing happens when the performance model file in
~/.starpu/sampling/codelets has become bogus. I'm wondering how this
could have happened, could you post your
~/.starpu/sampling/codelets/redux_cpu_kernel, neutral_cpu_kernel,
starpu_data_cpy, codelet_sleep, parallel_kernel_test,
files?
Dropping them after that should fix the issue.
Samuel
Attachment: parallel_kernel_test.charon
Description: Binary data
Attachment: parallel_kernel_test_spmd.charon
Attachment: starpu_data_cpy.charon
Haut de le page
