Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Question about matrix splicing
- Date: Tue, 2 Jul 2013 14:46:50 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear Samuel,
thanks a lot, this helped me.
It seems that the strange offset behaviour was also due to my
different attempts trying to get the code working.
If I am using starpu_matrix_filter_block I would get
ptr -> A[0]
dev_handle -> A[0]+1
offset -> 4
and this I will get for any matrix sizes. Due to your explanations
this should be the correct behaviour.
Best regards,
Christian
On Tue, Jul 2, 2013 at 1:58 PM, Samuel Thibault
<samuel.thibault@ens-lyon.org> wrote:
> christian eder, le Mon 01 Jul 2013 18:08:44 +0200, a écrit :
>> fa.filter_func = starpu_matrix_filter_block;
>> fa.nchildren = l;
>> fb.filter_func = starpu_matrix_filter_block;
>> fb.nchildren = n;
>> fc.filter_func = starpu_matrix_filter_vertical_block;
>> fc.nchildren = n;
>> I only get offsets of 1, so sub_a and sub_b are just shifted by 1
>> entry, but not by one row.
> See the reference documentation for starpu_matrix_filter_block: “This
> partitions a dense Matrix along the x dimension”. So getting 1 offsets
> is expected. You need to use starpu_matrix_filter_vertical_block to
> partition along the y dimension.
>> If I try the same doing by hand, i.e. using
>> STARPU_MATRIX_GET_DEV_HANDLE and STARPU_MATRIX_GET_OFFSET
>> the offset is not correct. So, for example, for two 8x8 matrices I get
>> with the above setting offsets of 4, with 16x16 matrices an offset of
>> 12.
> This, however, is more surprising. Could you provide the exact values of
> ptr, dev_handle and offset?
> Samuel
gpg: http://pgp.mit.edu:11371/pks/lookup?op=get&search=0x6E0D034B959FDE6A
- [Starpu-devel] Question about matrix splicing, christian eder, 01/07/2013
- Re: [Starpu-devel] Question about matrix splicing, christian eder, 01/07/2013
- Re: [Starpu-devel] Question about matrix splicing, Samuel Thibault, 02/07/2013
- Re: [Starpu-devel] Question about matrix splicing, christian eder, 02/07/2013
