Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] pheft problem?
- Date: Tue, 13 Aug 2013 02:17:56 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
When using pheft on my algorithm, i have a problem with a specific task, which hangs the scheduler as soon as it's sampling information has 10 executions
Cumprimentos
As soon as i delete the information for that specific task (~/.starpu/sampling/codelets/task_name), i can once again run the task with no problem, until around 10 executions are stored again
After a very long bug hunting, i narrowed down the problem to here. If i switch from pheft to peager, everything runs smoothly.
Is this a bug with the pheft scheduler?
Cumprimentos
Miguel Palhas
- [Starpu-devel] pheft problem?, Miguel Palhas, 13/08/2013
- Re: [Starpu-devel] pheft problem?, Miguel Palhas, 13/08/2013
