Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU task_submit failure on gpu
- Date: Sat, 5 Oct 2013 22:24:09 -0400
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello Team, I am working with StarPU and trying to submit task on GPU's. While making StarPU the configuration instruction showed that there were 4 GPU devices available. I believe if the device is available it would by default enable its support for CUDA during installation. Next, what I did was: changed .where variable in codelet structure cl of vector_scal.c in basic_example directory of StarPU to following: .where = STARPU_CUDA STARPU_USE_CUDA macro works as expected and detects CUDA. The compilation of program is successful but when I try to run it it gives me below error: [starpu] Unexpected value: <-19> returned for starpu_task_submit I did try to explicitly state the STARPU_NCUDA=2. On adding this it showed up below message: [starpu][_starpu_init_machine_config] Warning: 2 CUDA devices requested. Only 0 available. what does only 0 available mean? Also, I did run normal basic cuda programs and they were working fine. Can you please help me with understanding of this behavior? Regards, Ankit Khandelwal
- [Starpu-devel] StarPU task_submit failure on gpu, Ankit Khandelwal, 06/10/2013
- Re: [Starpu-devel] StarPU task_submit failure on gpu, Nathalie Furmento, 07/10/2013
- Re: [Starpu-devel] StarPU task_submit failure on gpu, Samuel Thibault, 07/10/2013
- Re: [Starpu-devel] StarPU task_submit failure on gpu, Ankit Khandelwal, 08/10/2013
