Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Only 2 OpenCL Devices available
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Only 2 OpenCL Devices available
  • Date: Sun, 10 Nov 2013 20:13:55 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
OpenCL CPU implementations do not show CPU cores as separate devices.
Sub devices have been introduced in latter revisions of the spec (1.2 if I remember correctly) but StarPU does not use them : http://www.khronos.org/registry/cl/sdk/1.2/docs/man/xhtml/clCreateSubDevices.html
Enabling OpenCL on CPU in StarPU has no influence on the activation of the CPU driver. In fact there is no interaction between the two drivers and the same CPU cores can be used simultaneously through both drivers (CPU and OpenCL) without StarPU preventing it. Moreover, kernels executed with OpenCL on CPU may use the cores reserved by StarPU to execute the GPU workers.
Sylvain
Le 10/11/2013 19:51, Samuel Thibault a écrit :
Hello,
Please *always* keep the list in Cc. That not only increases the
chances of getting an answer quickly, but that also increases the
chances of getting a useful answer at all.
"Julian Holzmüller", le Sun 10 Nov 2013 19:39:04 +0100, a écrit :
StarPU has found :
2 CPU cores
CPU 0
CPU 1
0 CUDA devices
2 OpenCL devices
OpenCL 0 (Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz)
OpenCL 1 (Quadro FX 880M)
I can only use 1 core as an OpenCL device.
Maybe in the CPU case we didn't think of automatically disabling the CPU
driver. Nathalie, Sylvain, do you know about it? I indeed don't see
that in the source code.
In the meanwhile, you can use STARPU_NCPU=0 to disable the CPU driver.
I believe the OpenCL driver actually does use all 4 cores, and it just
doesn't show up in StarPU just because that's hidden by the OpenCL
layer.
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
