Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Benoît Lizé <benoit.lize@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Is StarPU busy-waiting for tasks ?
- Date: Wed, 4 Dec 2013 18:01:06 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Here is a new version of the patch, with your (Samuel's) remarks taken into account, and more documentation.
It applies cleanly on r10350, and make check is OK.
Benoit Lize
diff --git a/doc/doxygen/chapters/api/initialization.doxy b/doc/doxygen/chapters/api/initialization.doxy index 8d0235d..cbed989 100644 --- a/doc/doxygen/chapters/api/initialization.doxy +++ b/doc/doxygen/chapters/api/initialization.doxy @@ -189,6 +189,18 @@ This is StarPU termination method. It must be called at the end of the application: statistics and other post-mortem debugging information are not guaranteed to be available until this method has been called. +\fn void starpu_pause(void) +\ingroup API_Initialization_and_Termination +This call is used to suspend the processing of new tasks by +workers. It can be used in a program where StarPU is used during only +a part of the execution. Without this call, the workers continue to +poll for new tasks in a tight loop, wasting CPU time. The symmetric +call to \ref starpu_resume() should be used to unfreeze the workers. + +\fn vois starpu_resume(void) +This is the symmetrical call to \ref starpu_pause(), used to resume +the workers polling for new tasks. + \fn int starpu_asynchronous_copy_disabled(void) \ingroup API_Initialization_and_Termination Return 1 if asynchronous data transfers between CPU and accelerators diff --git a/doc/doxygen/chapters/tips_and_tricks.doxy b/doc/doxygen/chapters/tips_and_tricks.doxy index 24f6772..4932dbd 100644 --- a/doc/doxygen/chapters/tips_and_tricks.doxy +++ b/doc/doxygen/chapters/tips_and_tricks.doxy @@ -111,4 +111,40 @@ Using this configuration, StarPU uses only 1 core, no matter the value of The solution is to set the environment variable KMP_AFFINITY to <c>disabled</c> (http://software.intel.com/sites/products/documentation/studio/composer/en-us/2011Update/compiler_c/optaps/common/optaps_openmp_thread_affinity.htm). + +\section PauseResume Interleaving StarPU and non-StarPU code + +If your application only partially uses StarPU, and you do not want to +call \ref starpu_init() / \ref starpu_shutdown() at the beginning/end +of each section, StarPU workers will poll for work between the +sections. To avoid this behavior, you can "pause" StarPU with the \ref +starpu_pause() function. This will prevent the StarPU workers from +accepting new work (tasks that are already in progress will not be +frozen), and stop them from polling for more work. + +Note that this does not prevent you from submitting new tasks, but +they won't execute until \ref starpu_resume() is called. Also note +that StarPU must not be paused when you call starpu_shutdown(), and +that this function pair works in a push/pull manner, ie you need to +match the number of calls to these functions to clear their effect. + + +One way to use these functions could be: +\code{.c} +starpu_init(NULL); +starpu_pause(); // To submit all the tasks without a single one executing +submit_some_tasks(); +starpu_resume(); // The tasks start executing + + +starpu_task_wait_for_all(); +starpu_pause(); // Stop the workers from polling + +// Non-StarPU code + +starpu_resume(); +// ... +starpu_sutdown(); +\endcode + */ diff --git a/include/starpu.h b/include/starpu.h index 1e8e7f8..223ccb1 100644 --- a/include/starpu.h +++ b/include/starpu.h @@ -115,6 +115,9 @@ int starpu_conf_init(struct starpu_conf *conf); int starpu_init(struct starpu_conf *conf) STARPU_WARN_UNUSED_RESULT; +void starpu_pause(); +void starpu_resume(); + void starpu_shutdown(void); void starpu_topology_print(FILE *f); diff --git a/src/core/workers.c b/src/core/workers.c index 684c356..f67b665 100644 --- a/src/core/workers.c +++ b/src/core/workers.c @@ -402,6 +402,7 @@ void _starpu_worker_start(struct _starpu_worker *worker, unsigned fut_key) static void _starpu_launch_drivers(struct _starpu_machine_config *pconfig) { pconfig->running = 1; + pconfig->pause_depth = 0; pconfig->submitting = 1; STARPU_PTHREAD_KEY_CREATE(&worker_key, NULL); @@ -897,17 +898,44 @@ out: } } +/* Condition variable and mutex used to pause/resume. */ +static starpu_pthread_cond_t pause_cond = STARPU_PTHREAD_COND_INITIALIZER; +static starpu_pthread_mutex_t pause_mutex = STARPU_PTHREAD_MUTEX_INITIALIZER; unsigned _starpu_machine_is_running(void) { unsigned ret; - /* running is just protected by a memory barrier */ + /* running and pause_depth are just protected by a memory barrier */ STARPU_RMB(); + + if (STARPU_UNLIKELY(config.pause_depth > 0)) { + STARPU_PTHREAD_MUTEX_LOCK(&pause_mutex); + if (config.pause_depth > 0) { + STARPU_PTHREAD_COND_WAIT(&pause_cond, &pause_mutex); + } + STARPU_PTHREAD_MUTEX_UNLOCK(&pause_mutex); + } + ANNOTATE_HAPPENS_AFTER(&config.running); ret = config.running; ANNOTATE_HAPPENS_BEFORE(&config.running); return ret; } +void starpu_pause() +{ + config.pause_depth += 1; +} + +void starpu_resume() +{ + STARPU_PTHREAD_MUTEX_LOCK(&pause_mutex); + config.pause_depth -= 1; + if (!config.pause_depth) { + STARPU_PTHREAD_COND_BROADCAST(&pause_cond); + } + STARPU_PTHREAD_MUTEX_UNLOCK(&pause_mutex); +} + unsigned _starpu_worker_can_block(unsigned memnode STARPU_ATTRIBUTE_UNUSED) { #ifdef STARPU_NON_BLOCKING_DRIVERS @@ -962,6 +990,9 @@ void starpu_shutdown(void) initialized = CHANGING; STARPU_PTHREAD_MUTEX_UNLOCK(&init_mutex); + /* If the workers are frozen, no progress can be made. */ + STARPU_ASSERT(config.pause_depth <= 0); + starpu_task_wait_for_no_ready(); /* tell all workers to shutdown */ diff --git a/src/core/workers.h b/src/core/workers.h index 7cb56a2..06484dd 100644 --- a/src/core/workers.h +++ b/src/core/workers.h @@ -240,6 +240,10 @@ struct _starpu_machine_config /* this flag is set until the runtime is stopped */ unsigned running; + /* Number of calls to starpu_pause() - calls to starpu_resume(). When >0, + * StarPU should pause. */ + int pause_depth; + /* all the sched ctx of the current instance of starpu */ struct _starpu_sched_ctx sched_ctxs[STARPU_NMAX_SCHED_CTXS]; diff --git a/tests/Makefile.am b/tests/Makefile.am index 1d2b854..fea194f 100644 --- a/tests/Makefile.am +++ b/tests/Makefile.am @@ -137,6 +137,7 @@ noinst_PROGRAMS = \ main/starpu_init \ main/starpu_worker_exists \ main/submit \ + main/pause_resume \ datawizard/allocate \ datawizard/acquire_cb \ datawizard/acquire_cb_insert \ diff --git a/tests/main/pause_resume.c b/tests/main/pause_resume.c new file mode 100644 index 0000000..bfbd1a3 --- /dev/null +++ b/tests/main/pause_resume.c @@ -0,0 +1,111 @@ +/* StarPU --- Runtime system for heterogeneous multicore architectures. + * + * Copyright (C) 2010-2011, 2013 Université de Bordeaux 1 + * Copyright (C) 2010, 2011, 2012, 2013 Centre National de la Recherche Scientifique + * + * StarPU is free software; you can redistribute it and/or modify + * it under the terms of the GNU Lesser General Public License as published by + * the Free Software Foundation; either version 2.1 of the License, or (at + * your option) any later version. + * + * StarPU is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. + * + * See the GNU Lesser General Public License in COPYING.LGPL for more details. + */ + +#include <sys/time.h> +#include <stdio.h> +#include <unistd.h> + +#include <starpu.h> +#include "../helper.h" + +#ifdef STARPU_QUICK_CHECK +static unsigned ntasks = 64; +#else +static unsigned ntasks = 200000; +#endif + +static void dummy_func(void *descr[] STARPU_ATTRIBUTE_UNUSED, void *arg STARPU_ATTRIBUTE_UNUSED) +{ +} + +static struct starpu_codelet dummy_codelet = +{ + .cpu_funcs = {dummy_func, NULL}, + .cuda_funcs = {dummy_func, NULL}, + .opencl_funcs = {dummy_func, NULL}, + .model = NULL, + .nbuffers = 0 +}; + + +int main(int argc, char **argv) +{ + double timing; + struct timeval start; + struct timeval end; + int ret; + +#ifdef STARPU_HAVE_VALGRIND_H + if(RUNNING_ON_VALGRIND) ntasks = 5; +#endif + + ret = starpu_init(NULL); + if (ret == -ENODEV) return STARPU_TEST_SKIPPED; + STARPU_CHECK_RETURN_VALUE(ret, "starpu_init"); + + /* Check that we can submit tasks to a "paused" StarPU and then have + * it run normally. + */ + starpu_pause(); + unsigned i; + for (i = 0; i < ntasks; i++) + { + ret = starpu_insert_task(&dummy_codelet, 0); + STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_insert"); + } + + gettimeofday(&start, NULL); + starpu_resume(); + starpu_task_wait_for_all(); + gettimeofday(&end, NULL); + timing = (double)((end.tv_sec - start.tv_sec)*1000000 + (end.tv_usec - start.tv_usec)); + + FPRINTF(stderr, "Without interruptions:\n\tTotal: %f secs\n", timing/1000000); + FPRINTF(stderr, "\tPer task: %f usecs\n", timing/ntasks); + + /* Do the same thing, but with a lot of interuptions to see if there + * is any overhead associated with the pause/resume calls. + */ + starpu_pause(); + for (i = 0; i < ntasks; i++) { + ret = starpu_insert_task(&dummy_codelet, 0); + STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_insert"); + } + starpu_resume(); + + gettimeofday(&start, NULL); + for (i = 0; i < 100; i++) { + starpu_pause(); + starpu_resume(); + } + starpu_task_wait_for_all(); + gettimeofday(&end, NULL); + timing = (double)((end.tv_sec - start.tv_sec)*1000000 + (end.tv_usec - start.tv_usec)); + + FPRINTF(stderr, "With 100 interruptions:\n\tTotal: %f secs\n", timing/1000000); + FPRINTF(stderr, "\tPer task: %f usecs\n", timing/ntasks); + + /* Finally, check that the nesting of pause/resume calls works. */ + starpu_pause(); + starpu_pause(); + starpu_resume(); + starpu_resume(); + + starpu_shutdown(); + + return EXIT_SUCCESS; +}
- Re: [Starpu-devel] Is StarPU busy-waiting for tasks ?, Benoît Lizé, 04/12/2013
