Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Xavier Lacoste <xavier.lacoste@inria.fr>
  • Cc: Mathieu Faverge <Mathieu.Faverge@inria.fr>, Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr, Pierre Ramet <ramet@labri.fr>
  • Subject: Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
  • Date: Fri, 17 Jan 2014 10:00:16 +0100
  • Authentication-results: iona.labri.fr (amavisd-new); dkim=pass (1024-bit key) reason="pass (just generated, assumed good)" header.d=labri.fr
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks Xavier.
I will add the patch asap.
Cheers,
Nathalie
On 17/01/2014 09:57, Xavier Lacoste wrote:
Hello,
Here is a patch on trunk that add EXECUTE_ON_WORKER as parameter of starpu_task_build().
https://gist.github.com/XL64/8470303
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Le 10 déc. 2013 à 14:29, Samuel Thibault <samuel.thibault@ens-lyon.org> a écrit :
Xavier Lacoste, le Tue 10 Dec 2013 10:15:42 +0100, a écrit :
For the execute_on_worker issue, I'll add a
#define STARPU_EXECUTE_ON_WORKER (15<<16)
And create a patch modifying starpu_mpi_insert_task.c /
starpu_insert_task_util.c that i'll send you.
STARPU_EXECUTE_ON_WORKER, workerid, would set workerid and
execute_on_a_specific_worker except if workerid is -1.
That can be useful, yes.
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
