Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build()
- Date: Wed, 26 Feb 2014 16:56:05 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Le 26 févr. 2014 à 16:30, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Wed 26 Feb 2014 15:43:26 +0100, a écrit :
>> I tried to use STARPU_COMMUTE with MPI but the option gives an error when
>> building MPI task.
>> Indeed it does not appear in the test "if (arg_type==STARPU_R ||
>> arg_type==STARPU_W || arg_type==STARPU_RW || arg_type==STARPU_SCRATCH ||
>> arg_type==STARPU_REDUX" in starpu_mpi_task_insert.c
>> Is this the only thing missing or is it more complicated ?
> On the top of my head I think it's a matter of testing against
> arg_type & ~STARPU_COMMUTE to get it working at least. Getting it
> optimized is probably another question, could you show us your use case?
I have several task preforming a GEMM updating a data that can be executed in
parallel.
In shared memory mode I just used
starpu_data_set_sequential_consistency_flag() and listed all my dependencies,
but as it was more complicated to get the list of tasks in distributed, I
tried STARPU_COMMUTE.
So, in my algorithm, I have several GEMM tasks unlocking a GETRF+TRSM
unlocking an other list of GEMMs etc.
Is that what you wanted to know ?
XL.
- [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 26/02/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 26/02/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 26/02/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 28/02/2014
