Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Void interface and StarPU-MPI
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Void interface and StarPU-MPI
  • Date: Mon, 3 Mar 2014 10:26:03 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I'm using StarPU (trunk r12309) with the MPI extension. I think I've found something that is either a missing functionnality in StarPU, or that shoud be mentionned in the documentation.
The issue is around the use of a data handle from the VOID interface with the MPI extensions. I'm using a void data handle to express a dependency that is external to StarPU. With MPI, I get the following error (STARPU_VOID_INTERFACE_ID=6) :
[starpu][_starpu_mpi_handle_allocate_datatype][assert failure] Handle To Datatype Function not defined for StarPU data interface 6
AS_ELFIP_FMM: starpu_mpi_datatype.c:130: _starpu_mpi_handle_allocate_datatype: Assertion `func' failed.
This seems fairly sensible, as the meaning of a void data dependency might not be very clear in an MPI context, but this perhaps should be mentionned in the documentation.
What do you think ?
Benoit Lize
Haut de le page
